[Mapbender-commits] r7316 - trunk/mapbender/http/plugins
    svn_mapbender at osgeo.org
    Thu Dec 16 05:04:13 EST 2010
Author: christoph
Date: 2010-12-16 02:04:13 -0800 (Thu, 16 Dec 2010)
New Revision: 7316
Added:
   trunk/mapbender/http/plugins/mb_button.js
#742
Added: trunk/mapbender/http/plugins/mb_button.js
--- trunk/mapbender/http/plugins/mb_button.js	                        (rev 0)
+++ trunk/mapbender/http/plugins/mb_button.js	2010-12-16 10:04:13 UTC (rev 7316)
@@ -0,0 +1,65 @@
+ * Package: button
+ * Description:
+ * Imagine you have a DIV element in your application. In order to save screen
+ * real estate, you might want to only show the DIV if the user clicked a
+ * button. That's what this module does. The button will open a dialog
+ * containing the element specified in the target column. In the example, a
+ * button will open the print form in a new dialog.
+ * Files:
+ *  - ../plugins/mb_button.js
+ * SQL:
+ * > INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment,
+ * > e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height,
+ * > e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod,
+ * > e_target, e_requires, e_url) VALUES('<appId>','printButton',1,1,'',
+ * > 'Print','img','../img/button_blue_red/print_off.png','',NULL ,NULL ,24,24,
+ * > NULL ,'','','','../plugins/mb_button.js','','printPDF','','');
+ * Maintainer:
+ * http://www.mapbender.org/User:Christoph_Baudson
+ * Parameters:
+ * License:
+ * Copyright (c) 2009, Open Source Geospatial Foundation
+ * This program is dual licensed under the GNU General Public License
+ * and Simplified BSD license.
+ * http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
+var $button = $(this);
+var ButtonApi = function (o) {
+	var that = this;
+	var target = (o.$target && o.$target.jquery && o.$target.size() === 1) ?
+		o.$target : $([]);
+	var dialog = target.css({
+		position: "static",
+		width: "auto",
+		height: "auto",
+		top: "auto",
+		left: "auto"
+	}).hide().dialog({
+		autoOpen: false
+	var openDialog = function () {
+		dialog.dialog("open");
+		button.stop();
+	var button = new Mapbender.Button({
+		domElement: $button.get(0),
+		over: o.src.replace(/_off/, "_over"),
+		on: o.src.replace(/_off/, "_on"),
+		off: o.src,
+		name: o.id,
+		go: openDialog
+$button.mapbender(new ButtonApi(options));
\ No newline at end of file
More information about the Mapbender_commits
