[Mapbender-commits] r5532 - in branches/2.6: http/javascripts
resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org
Sat Feb 20 04:48:26 EST 2010
Author: marc
Date: 2010-02-20 04:48:25 -0500 (Sat, 20 Feb 2010)
New Revision: 5532
branches/2.6/http/javascripts/mod_measure.php
branches/2.6/resources/db/pgsql/UTF-8/update/update_2.6_to_2.6.1_pgsql_UTF-8.sql
http://trac.osgeo.org/mapbender/ticket/590
Modified: branches/2.6/http/javascripts/mod_measure.php
--- branches/2.6/http/javascripts/mod_measure.php 2010-02-20 08:06:19 UTC (rev 5531)
+++ branches/2.6/http/javascripts/mod_measure.php 2010-02-20 09:48:25 UTC (rev 5532)
@@ -27,7 +27,7 @@
var mod_measure_fontsize = "9px";
var mod_measure_basepoint = "#8a2be2";
var mod_measure_linepoint = "#ff00ff";
-var mod_measure_bg = "";
+var mod_measure_bg = "white";
var mod_measure_pgsql = true;
var mod_measure_win = null;
@@ -50,11 +50,6 @@
var mod_measure_img_off = new Image(); mod_measure_img_off.src = "<?php echo $e_src; ?>";
var mod_measure_img_over = new Image(); mod_measure_img_over.src = "<?php echo preg_replace("/_off/","_over",$e_src); ?>";
-eventBeforeInit.register(function () {
- mb_regButton(function (ind) {
- init_mod_measure(ind);
function init_mod_measure(ind){
mod_measure_mapObj = getMapObjByName(mod_measure_target);
Modified: branches/2.6/resources/db/pgsql/UTF-8/update/update_2.6_to_2.6.1_pgsql_UTF-8.sql
--- branches/2.6/resources/db/pgsql/UTF-8/update/update_2.6_to_2.6.1_pgsql_UTF-8.sql 2010-02-20 08:06:19 UTC (rev 5531)
+++ branches/2.6/resources/db/pgsql/UTF-8/update/update_2.6_to_2.6.1_pgsql_UTF-8.sql 2010-02-20 09:48:25 UTC (rev 5532)
@@ -345,4 +345,7 @@
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type)
SELECT gui_element.fkey_gui_id, 'treeGDE', 'switchwms', 'true', 'enables/disables all layer of a wms' ,'var'
FROM gui_element WHERE gui_element.e_id = 'treeGDE' AND gui_element.fkey_gui_id NOT IN
-(SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'switchwms' AND fkey_e_id = 'treeGDE');
+(SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'switchwms' AND fkey_e_id = 'treeGDE');
+-- http://trac.osgeo.org/mapbender/ticket/590 toggle Module and measure
+UPDATE gui_element set e_attributes ='onmouseover = "mb_regButton(''init_mod_measure'')"' where e_id='measure'
More information about the Mapbender_commits
