[Mapbender-commits] r5533 - in trunk/mapbender: http/javascripts
resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org
Sat Feb 20 04:56:58 EST 2010
Author: marc
Date: 2010-02-20 04:56:57 -0500 (Sat, 20 Feb 2010)
New Revision: 5533
trunk/mapbender/http/javascripts/mod_measure.php
trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6_to_2.6.1_pgsql_UTF-8.sql
http://trac.osgeo.org/mapbender/ticket/590
Modified: trunk/mapbender/http/javascripts/mod_measure.php
--- trunk/mapbender/http/javascripts/mod_measure.php 2010-02-20 09:48:25 UTC (rev 5532)
+++ trunk/mapbender/http/javascripts/mod_measure.php 2010-02-20 09:56:57 UTC (rev 5533)
@@ -50,12 +50,8 @@
var mod_measure_img_off = new Image(); mod_measure_img_off.src = "<?php echo $e_src; ?>";
var mod_measure_img_over = new Image(); mod_measure_img_over.src = "<?php echo preg_replace("/_off/","_over",$e_src); ?>";
-eventBeforeInit.register(function () {
- mb_regButton(function (ind) {
- init_mod_measure(ind);
function init_mod_measure(ind){
mod_measure_mapObj = getMapObjByName(mod_measure_target);
//ensure we have the div elements in Mapframe
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6_to_2.6.1_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6_to_2.6.1_pgsql_UTF-8.sql 2010-02-20 09:48:25 UTC (rev 5532)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6_to_2.6.1_pgsql_UTF-8.sql 2010-02-20 09:56:57 UTC (rev 5533)
@@ -350,4 +350,8 @@
-- missing wz_jsgraphics in gazetteer
-- replacing obsolete tablesorter
-UPDATE gui_element SET e_mb_mod = 'geometry.js,requestGeometryConstructor.js,popup.js,../extensions/wz_jsgraphics.js,../extensions/jquery.tablesorter.js' WHERE e_id = 'gazetteerWFS';
\ No newline at end of file
+UPDATE gui_element SET e_mb_mod = 'geometry.js,requestGeometryConstructor.js,popup.js,../extensions/wz_jsgraphics.js,../extensions/jquery.tablesorter.js' WHERE e_id = 'gazetteerWFS';
+-- http://trac.osgeo.org/mapbender/ticket/590 toggle Module and measure
+UPDATE gui_element set e_attributes ='onmouseover = "mb_regButton(''init_mod_measure'')"' where e_id='measure'
More information about the Mapbender_commits
