[Mapbender-commits] r5299 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Jan 8 07:49:24 EST 2010
Author: verenadiewald
Date: 2010-01-08 07:49:22 -0500 (Fri, 08 Jan 2010)
New Revision: 5299
   trunk/mapbender/http/javascripts/mod_digitize_tab.php
new events beforeUpdate and beforeInsert
Modified: trunk/mapbender/http/javascripts/mod_digitize_tab.php
--- trunk/mapbender/http/javascripts/mod_digitize_tab.php	2010-01-07 16:19:54 UTC (rev 5298)
+++ trunk/mapbender/http/javascripts/mod_digitize_tab.php	2010-01-08 12:49:22 UTC (rev 5299)
@@ -150,8 +150,13 @@
 	parent.Mapbender.modules[mod_digitize_elName].events = {
 		closeGeometry: eventCloseGeometry,
-		beforeUpdateOrInsert: new parent.Mapbender.Event()
+		beforeUpdateOrInsert: new parent.Mapbender.Event(),
+		beforeUpdate: new parent.Mapbender.Event(),
+		beforeInsert: new parent.Mapbender.Event()
+	parent.Mapbender.modules[mod_digitize_elName].cancelAjaxRequest = false;
+	parent.Mapbender.modules[mod_digitize_elName].cancelAjaxRequestMessage = "An error occured.";
@@ -1877,7 +1882,7 @@
 	// preselect the correct entry of the box
-	patternString = "option( )+value( )*=( )*'"+elementValue+"'";
+	patternString = "option( )+value( )*=( )*('|\")"+elementValue+"('|\")";
 	pattern = new RegExp(patternString);
 	var patternStringForReplace = "option value = '"+elementValue+"'";
 	formElementHtml = formElementHtml.replace(pattern, patternStringForReplace+" selected");
@@ -1902,7 +1907,7 @@
 	formElementHtml = formElementHtml.replace(pattern, patternString + classString);
 	// set name of select box to elementlabel
-	patternString = "name\s*=\s*\\*'\w+\\*'";
+	patternString = "name\s*=\s*\\*('|\")\w+\\*('|\")";
 	if (pattern.test(formElementHtml)) {
 		formElementHtml = formElementHtml.replace(pattern, "name='" + elementLabel + "'");
@@ -1938,7 +1943,7 @@
@@ -2249,12 +2254,32 @@
 //		str = parent.get_wfs_str(myconf, d, m, type, fid);
-		parent.Mapbender.modules[mod_digitize_elName].events.beforeUpdateOrInsert.trigger({
-			feature: d.get(m)
+		if (type === "insert" || type === "update") {
+			var module = parent.Mapbender.modules[mod_digitize_elName];
+			module.events.beforeUpdateOrInsert.trigger({
+				feature: d.get(m)
+			if (type === "insert") {
+				module.events.beforeInsert.trigger({
+					feature: d.get(m)
+			if (type === "update") {
+				module.events.beforeUpdate.trigger({
+					feature: d.get(m)
+			if (module.cancelAjaxRequest) {
+				alert(module.cancelAjaxRequestMessage);
+				module.cancelAjaxRequest = false;
+				module.cancelAjaxRequestMessage = "An error occured.";
+				return;
 		var geoJson = d.featureToString(m);
 		parent.mb_ajax_post(
 			"../extensions/geom2wfst.php",
More information about the Mapbender_commits mailing list
