[Mapbender-commits] r5300 - trunk/mapbender/lib
svn_mapbender at osgeo.org
Fri Jan 8 07:51:52 EST 2010
Author: verenadiewald
Date: 2010-01-08 07:51:52 -0500 (Fri, 08 Jan 2010)
New Revision: 5300
trunk/mapbender/lib/ajax.js
possibility to set async in ajaxSetup to false
Modified: trunk/mapbender/lib/ajax.js
--- trunk/mapbender/lib/ajax.js 2010-01-08 12:49:22 UTC (rev 5299)
+++ trunk/mapbender/lib/ajax.js 2010-01-08 12:51:52 UTC (rev 5300)
@@ -62,18 +62,28 @@
var type = (options.type) ? options.type.toUpperCase() : "POST";
var log = (options.log) ? options.log : false;
var method = (options.method) ? options.method : "";
+ var async = (typeof options.async === "boolean") ? options.async : true;
var parameters = (options.parameters) ? options.parameters : {};
this.send = function () {
+ $.ajaxSetup({
+ async: async
switch (type.toUpperCase()) {
case "POST" :
$.post(url, getParameters(), function () {
+ $.ajaxSetup({
+ async: true
break;
case "GET" :
$.get(url, getParameters(), function () {
+ $.ajaxSetup({
+ async: true
break;
default:
new Mapbender.Exception("Invalid type (" + type +
@@ -130,6 +140,7 @@
var callback = (options.callback) ? options.callback : null;
var scope = (options.scope) ? options.scope : null;
else {
new Mapbender.Exception("No options specified in " +
@@ -248,12 +259,21 @@
+ $.ajaxSetup({
+ async: async
switch (type) {
case "POST" :
$.post(url, getParameters(), callbackWrapper);
+ $.ajaxSetup({
+ async: true
break;
case "GET" :
$.get(url, getParameters(), callbackWrapper);
+ $.ajaxSetup({
+ async: true
break;
default:
return false;
More information about the Mapbender_commits
