[Mapbender-commits] r5358 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Jan 19 17:51:46 EST 2010
Author: astrid_emde
Date: 2010-01-19 17:51:45 -0500 (Tue, 19 Jan 2010)
New Revision: 5358
Added:
   trunk/mapbender/http/classes/class_weldMaps2PNG_rotate.php
   trunk/mapbender/http/classes/class_weldOverview2PNG_rotate.php
classes for new print module, created by christop, rotation
Added: trunk/mapbender/http/classes/class_weldMaps2PNG_rotate.php
--- trunk/mapbender/http/classes/class_weldMaps2PNG_rotate.php	                        (rev 0)
+++ trunk/mapbender/http/classes/class_weldMaps2PNG_rotate.php	2010-01-19 22:51:45 UTC (rev 5358)
@@ -0,0 +1,95 @@
+<?php
+# $Id: class_weldMaps2PNG_rotate.php 2684 2008-07-22 07:26:19Z christoph $
+# http://www.mapbender.org/index.php/class_weldMaps2PNG_rotate.php
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+* class_weldMaps2PNG_rotate
+* @version 1.0.0
+* get/post '___' separated maprequests
+require_once(dirname(__FILE__)."/../../core/globalSettings.php");
+require_once(dirname(__FILE__)."/class_stripRequest.php");
+require_once(dirname(__FILE__)."/class_connector.php");
+require_once(dirname(__FILE__)."/class_weldMaps2PNG.php");
+class weldMaps2PNG_rotate extends weldMaps2PNG{
+    function weldMaps2PNG_rotate($urls,$filename, $angle){
+        if(!$urls || $urls == ""){
+            $e = new mb_exception("weldMaps2PNG_rotate: no maprequests delivered");
+        $url = explode("___", $urls);
+        $obj1 = new stripRequest($url[0]);
+        $width = $obj1->get("width");
+        $height = $obj1->get("height");
+        //calculate rotated dimensions
+        $neededWidth = round(abs(sin(deg2rad($angle))*$height)+abs(cos(deg2rad($angle))*$width));
+        $neededHeight = round(abs(sin(deg2rad($angle))*$width)+abs(cos(deg2rad($angle))*$height));
+        //modify requests
+        for($i=0; $i<count($url); $i++){
+            $obj = new stripRequest($url[$i]);
+            $obj->set("width", $neededWidth);
+            $obj->set("height", $neededHeight);
+            $map_extent = $obj->get("BBOX");
+            $coord = split(",",$map_extent);
+            $coord = $this->enlargeExtent($coord, $width, $height, $neededWidth, $neededHeight);
+            $obj->set("BBOX", implode(",", $coord));
+            $url[$i] = $obj->url;
+        //get image
+        $urls = implode("___", $url);
+        $this->weldMaps2PNG($urls, $filename);
+        //rotate image
+        $imagick = new Imagick();
+        $imagick->readImage($filename);
+        $imagick->rotateImage(new ImagickPixel(), $angle);
+        //get the new dimensions
+        $imgWidth = $imagick->getImageWidth();
+        $imgHeight = $imagick->getImageHeight();
+        //crop empty areas
+        $imagick->cropImage($width, $height, ($imgWidth-$width)/2, ($imgHeight-$height)/2);
+        //write modified image
+        $imagick->writeImage();
+        $image = imagecreatefrompng($filename);
+        imagepng($image,$filename);
+    function enlargeExtent($coordArray, $oldWidth, $oldHeight, $newWidth, $newHeight){
+         $extentx = ($coordArray[2] - $coordArray[0]);
+         $extenty = ($coordArray[3] - $coordArray[1]);
+         $coordArray[0]+=($extentx/$oldWidth)*($oldWidth-$newWidth)/2;
+         $coordArray[2]+=($extentx/$oldWidth)*($newWidth-$oldWidth)/2;
+         $coordArray[1]+=($extenty/$oldHeight)*($oldHeight-$newHeight)/2;
+         $coordArray[3]+=($extenty/$oldHeight)*($newHeight-$oldHeight)/2;
+        return $coordArray;
\ No newline at end of file
Added: trunk/mapbender/http/classes/class_weldOverview2PNG_rotate.php
--- trunk/mapbender/http/classes/class_weldOverview2PNG_rotate.php	                        (rev 0)
+++ trunk/mapbender/http/classes/class_weldOverview2PNG_rotate.php	2010-01-19 22:51:45 UTC (rev 5358)
@@ -0,0 +1,148 @@
+<?php
+# $Id: class_weldOverview2PNG.php 1584 2007-08-06 07:56:11Z christoph $
+# $Header: /cvsroot/mapbender/mapbender/http/classes/class_weldOverview2PNG.php,v 1.3 2006/02/22 11:56:22 astrid_emde Exp $
+* class_weldOverview2PNG
+* @version 1.0.0
+require_once(dirname(__FILE__)."/class_mb_exception.php");
+class weldOverview2PNG_rotate{
+	function weldOverview2PNG_rotate($url_overview,$url_extent,$filename, $rotatedExtent){
+		if(!$url_overview || $url_overview == ""){
+			$e = new mb_exception("weldOverview2PNG: no maprequests delivered");
+		$url = $url_overview;
+		$obj1 = new stripRequest($url);
+		$e = new mb_exception("--------overview-----------------");
+		$e = new mb_exception("-----width ".$width." / height: ".$height."--------------------");
+		$e = new mb_exception("url_overview: ".$url_overview);
+		$e = new mb_exception("url_extent: ".$url_extent);
+		$image = imagecreatetruecolor($width, $height);
+		$white = ImageColorAllocate($image,255,255, 255);
+		ImageFilledRectangle($image,0,0,$width,$height,$white);
+		//overview
+		$obj = new stripRequest($url_overview);
+		$xurl_overview = $obj->setPNG();
+		$xurl_overview = $obj->encodeGET();
+		$img = $this->loadpng($xurl_overview);
+		if($img != false){
+			imagecopy($image, $img, 0, 0, 0, 0, $width, $height);
+		else{
+			$e = new mb_exception("weldMaps2PNG: unable to load image: " . $url_overview);
+		// rectangle - position of the map in the overview
+		$objx = new stripRequest($url_extent);
+		$ex_width = $objx->get("width");
+		$ex_height = $objx->get("height");
+		$extent = explode(",",$objx->get("BBOX"));
+		$p1 = $this->makeRealWorld2mapPos($url_overview, round($rotatedExtent[0][0]), round($rotatedExtent[0][1]));
+		$p2 = $this->makeRealWorld2mapPos($url_overview, round($rotatedExtent[1][0]), round($rotatedExtent[1][1]));
+		$p3 = $this->makeRealWorld2mapPos($url_overview, round($rotatedExtent[2][0]), round($rotatedExtent[2][1]));
+		$p4 = $this->makeRealWorld2mapPos($url_overview, round($rotatedExtent[3][0]), round($rotatedExtent[3][1]));
+		$e = new mb_exception("ex_width: " .$ex_width);
+		$e = new mb_exception("ex_height: " . $ex_height);
+		$e = new mb_exception("bbox:".$extent[0]."--".$extent[1]."--".$extent[2]."--------".$extent[3]);
+		$e = new mb_exception("ll: " . $lowerleft[0]." / ".$lowerleft[1]);
+		$e = new mb_exception("ur: " . $upperright[0]." / ".$upperright[1]);
+		$red = ImageColorAllocate($image,255,0,0);
+		imageline ( $image, $p1[0], $p1[1], $p2[0], $p2[1], $red);
+		imageline ( $image, $p2[0], $p2[1], $p3[0], $p3[1], $red);
+		imageline ( $image, $p3[0], $p3[1], $p4[0], $p4[1], $red);
+		imageline ( $image, $p4[0], $p4[1], $p1[0], $p1[1], $red);
+		// black frame - size of the overview
+		$black = ImageColorAllocate($image,0,0,0);
+		imageline ( $image, 0, 0, $width-1, 0, $black);
+		imageline ( $image, $width-1, 0, $width-1, $height-1, $black);
+		imageline ( $image, $width-1, $height-1, 0, $height-1, $black);
+		imageline ( $image, 0, $height-1, 0, 0, $black);
+		imagedestroy($image);
+	function loadpng ($imgurl) {
+		$obj = new stripRequest($imgurl);
+		$x = new connector($imgurl);
+		$f = $obj->get("format");
+		$im = @imagecreatefromstring($x->file);
+		if(!$im){
+			$im = false;
+			$e = new mb_exception("weldOverview2PNG: unable to load image: ".$imgurl);
+		return $im;
+	function makeRealWorld2mapPos($url, $rw_posx, $rw_posy){
+	   	$obj = new stripRequest($url);
+		$width = $obj->get("width");
+		$height = $obj->get("height");
+		#$e = new mb_exception("weld_url: ".$url);
+		#$e = new mb_exception("w: ".$width."height".$height);
+	   $arrayBBox = explode(",",$obj->get("BBOX"));
+	   $minX = $arrayBBox[0];
+	   $minY = $arrayBBox[1];
+	   $maxX = $arrayBBox[2];
+	   $maxY = $arrayBBox[3];
+	#$e = new mb_exception("------- minx: ".$minX." miny:".$minY." maxx:".$maxX." maxy:".$maxY."----------");
+	   $xtentx = $maxX - $minX ;
+	   $xtenty = $maxY - $minY ;
+	   $pixPos_x = round((($rw_posx - $minX)/$xtentx)*$width);
+	   $pixPos_y = round((($maxY - $rw_posy)/$xtenty)*$height);
+	   $pixPos = array($pixPos_x, $pixPos_y);
+	   return $pixPos;
More information about the Mapbender_commits mailing list
