[Mapbender-commits] r5359 - in trunk/mapbender/http/extensions: . fpdf fpdf/decoder fpdf/font fpdf/font/makefont
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Jan 19 18:07:49 EST 2010
Author: astrid_emde
Date: 2010-01-19 18:07:49 -0500 (Tue, 19 Jan 2010)
New Revision: 5359
Added:
   trunk/mapbender/http/extensions/fpdf/
   trunk/mapbender/http/extensions/fpdf/decoder/
   trunk/mapbender/http/extensions/fpdf/decoder/ASCII85Decode.php
   trunk/mapbender/http/extensions/fpdf/decoder/LZWDecode.php
   trunk/mapbender/http/extensions/fpdf/font/
   trunk/mapbender/http/extensions/fpdf/font/courier.php
   trunk/mapbender/http/extensions/fpdf/font/desktop.ini
   trunk/mapbender/http/extensions/fpdf/font/helvetica.php
   trunk/mapbender/http/extensions/fpdf/font/helveticab.php
   trunk/mapbender/http/extensions/fpdf/font/helveticabi.php
   trunk/mapbender/http/extensions/fpdf/font/helveticai.php
   trunk/mapbender/http/extensions/fpdf/font/makefont/
   trunk/mapbender/http/extensions/fpdf/font/makefont/cp1250.map
   trunk/mapbender/http/extensions/fpdf/font/makefont/cp1251.map
   trunk/mapbender/http/extensions/fpdf/font/makefont/cp1252.map
   trunk/mapbender/http/extensions/fpdf/font/makefont/cp1253.map
   trunk/mapbender/http/extensions/fpdf/font/makefont/cp1254.map
   trunk/mapbender/http/extensions/fpdf/font/makefont/cp1255.map
   trunk/mapbender/http/extensions/fpdf/font/makefont/cp1257.map
   trunk/mapbender/http/extensions/fpdf/font/makefont/cp1258.map
   trunk/mapbender/http/extensions/fpdf/font/makefont/cp874.map
   trunk/mapbender/http/extensions/fpdf/font/makefont/iso-8859-1.map
   trunk/mapbender/http/extensions/fpdf/font/makefont/iso-8859-11.map
   trunk/mapbender/http/extensions/fpdf/font/makefont/iso-8859-15.map
   trunk/mapbender/http/extensions/fpdf/font/makefont/iso-8859-16.map
   trunk/mapbender/http/extensions/fpdf/font/makefont/iso-8859-2.map
   trunk/mapbender/http/extensions/fpdf/font/makefont/iso-8859-4.map
   trunk/mapbender/http/extensions/fpdf/font/makefont/iso-8859-5.map
   trunk/mapbender/http/extensions/fpdf/font/makefont/iso-8859-7.map
   trunk/mapbender/http/extensions/fpdf/font/makefont/iso-8859-9.map
   trunk/mapbender/http/extensions/fpdf/font/makefont/koi8-r.map
   trunk/mapbender/http/extensions/fpdf/font/makefont/koi8-u.map
   trunk/mapbender/http/extensions/fpdf/font/makefont/makefont.php
   trunk/mapbender/http/extensions/fpdf/font/symbol.php
   trunk/mapbender/http/extensions/fpdf/font/times.php
   trunk/mapbender/http/extensions/fpdf/font/timesb.php
   trunk/mapbender/http/extensions/fpdf/font/timesbi.php
   trunk/mapbender/http/extensions/fpdf/font/timesi.php
   trunk/mapbender/http/extensions/fpdf/fpdf.php
   trunk/mapbender/http/extensions/fpdf/fpdf_tpl.php
   trunk/mapbender/http/extensions/fpdf/fpdi.php
   trunk/mapbender/http/extensions/fpdf/fpdi2tcpdf_bridge.php
   trunk/mapbender/http/extensions/fpdf/fpdi_pdf_parser.php
   trunk/mapbender/http/extensions/fpdf/license.txt
   trunk/mapbender/http/extensions/fpdf/mb_fpdi.php
   trunk/mapbender/http/extensions/fpdf/pdf_context.php
   trunk/mapbender/http/extensions/fpdf/pdf_parser.php
   trunk/mapbender/http/extensions/fpdf/wrapper_functions.php
code from http://www.fpdf.de/ + Add-ons
Added: trunk/mapbender/http/extensions/fpdf/decoder/ASCII85Decode.php
--- trunk/mapbender/http/extensions/fpdf/decoder/ASCII85Decode.php	                        (rev 0)
+++ trunk/mapbender/http/extensions/fpdf/decoder/ASCII85Decode.php	2010-01-19 23:07:49 UTC (rev 5359)
@@ -0,0 +1,95 @@
+<?php
+//  FPDI - Version 1.2.1
+//    Copyright 2004-2008 Setasign - Jan Slabon
+//  Licensed under the Apache License, Version 2.0 (the "License");
+//  you may not use this file except in compliance with the License.
+//  You may obtain a copy of the License at
+//      http://www.apache.org/licenses/LICENSE-2.0
+//  Unless required by applicable law or agreed to in writing, software
+//  distributed under the License is distributed on an "AS IS" BASIS,
+//  WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
+//  See the License for the specific language governing permissions and
+//  limitations under the License.
+if (!defined("ORD_z"))
+	define("ORD_z",ord('z'));
+if (!defined("ORD_exclmark"))
+	define("ORD_exclmark", ord('!'));
+if (!defined("ORD_u"))
+	define("ORD_u", ord("u"));
+if (!defined("ORD_tilde"))
+	define("ORD_tilde", ord('~'));
+class ASCII85Decode {
+    function ASCII85Decode(&$fpdi) {
+        $this->fpdi =& $fpdi;
+    function decode($in) {
+        $out = "";
+        $state = 0;
+        $chn = null;
+        $l = strlen($in);
+        for ($k = 0; $k < $l; ++$k) {
+            $ch = ord($in[$k]) & 0xff;
+            if ($ch == ORD_tilde) {
+                break;
+            if (preg_match("/^\s$/",chr($ch))) {
+                continue;
+            if ($ch == ORD_z && $state == 0) {
+                $out .= chr(0).chr(0).chr(0).chr(0);
+                continue;
+            if ($ch < ORD_exclmark || $ch > ORD_u) {
+                $this->fpdi->error("Illegal character in ASCII85Decode.");
+            $chn[$state++] = $ch - ORD_exclmark;
+            if ($state == 5) {
+                $state = 0;
+                $r = 0;
+                for ($j = 0; $j < 5; ++$j)
+                    $r = $r * 85 + $chn[$j];
+                $out .= chr($r >> 24);
+                $out .= chr($r >> 16);
+                $out .= chr($r >> 8);
+                $out .= chr($r);
+        $r = 0;
+        if ($state == 1)
+            $this->fpdi->error("Illegal length in ASCII85Decode.");
+        if ($state == 2) {
+            $r = $chn[0] * 85 * 85 * 85 * 85 + ($chn[1]+1) * 85 * 85 * 85;
+        else if ($state == 3) {
+            $r = $chn[0] * 85 * 85 * 85 * 85 + $chn[1] * 85 * 85 * 85  + ($chn[2]+1) * 85 * 85;
+        else if ($state == 4) {
+            $r = $chn[0] * 85 * 85 * 85 * 85 + $chn[1] * 85 * 85 * 85  + $chn[2] * 85 * 85  + ($chn[3]+1) * 85 ;
+        return $out;
\ No newline at end of file
Added: trunk/mapbender/http/extensions/fpdf/decoder/LZWDecode.php
--- trunk/mapbender/http/extensions/fpdf/decoder/LZWDecode.php	                        (rev 0)
+++ trunk/mapbender/http/extensions/fpdf/decoder/LZWDecode.php	2010-01-19 23:07:49 UTC (rev 5359)
@@ -0,0 +1,147 @@
+<?php
+class LZWDecode {
+    var $sTable = array();
+    var $data = null;
+    var $tIdx;
+    var $bitsToGet = 9;
+    var $bytePointer;
+    var $bitPointer;
+    var $nextData = 0;
+    var $nextBits = 0;
+    var $andTable = array(511, 1023, 2047, 4095);
+    function LZWDecode(&$fpdi) {
+     * Method to decode LZW compressed data.
+     * @param string data    The compressed data.
+    function decode($data) {
+        if($data[0] == 0x00 && $data[1] == 0x01) {
+            $this->fpdi->error("LZW flavour not supported.");
+        $this->initsTable();
+        $this->data = $data;
+        // Initialize pointers
+        $this->bytePointer = 0;
+        $this->bitPointer = 0;
+        $this->nextData = 0;
+        $this->nextBits = 0;
+        $oldCode = 0;
+        $string = "";
+        $uncompData = "";
+        while (($code = $this->getNextCode()) != 257) {
+            if ($code == 256) {
+                $code = $this->getNextCode();
+                if ($code == 257) {
+                    break;
+                $uncompData .= $this->sTable[$code];
+                $oldCode = $code;
+            } else {
+                if ($code < $this->tIdx) {
+                    $string = $this->sTable[$code];
+                    $uncompData .= $string;
+                    $this->addStringToTable($this->sTable[$oldCode], $string[0]);
+                    $oldCode = $code;
+                } else {
+                    $string = $this->sTable[$oldCode];
+                    $string = $string.$string[0];
+                    $this->addStringToTable($string);
+                    $oldCode = $code;
+        return $uncompData;
+     * Initialize the string table.
+    function initsTable() {
+        $this->sTable = array();
+        for ($i = 0; $i < 256; $i++)
+            $this->sTable[$i] = chr($i);
+        $this->tIdx = 258;
+        $this->bitsToGet = 9;
+     * Add a new string to the string table.
+    function addStringToTable ($oldString, $newString="") {
+        $string = $oldString.$newString;
+        // Add this new String to the table
+        $this->sTable[$this->tIdx++] = $string;
+        if ($this->tIdx == 511) {
+            $this->bitsToGet = 10;
+        } else if ($this->tIdx == 1023) {
+            $this->bitsToGet = 11;
+        } else if ($this->tIdx == 2047) {
+            $this->bitsToGet = 12;
+    // Returns the next 9, 10, 11 or 12 bits
+    function getNextCode() {
+        if ($this->bytePointer == strlen($this->data))
+            return 257;
+        $this->nextData = ($this->nextData << 8) | (ord($this->data[$this->bytePointer++]) & 0xff);
+        $this->nextBits += 8;
+        if ($this->nextBits < $this->bitsToGet) {
+        $code = ($this->nextData >> ($this->nextBits - $this->bitsToGet)) & $this->andTable[$this->bitsToGet-9];
+        $this->nextBits -= $this->bitsToGet;
+        return $code;
Added: trunk/mapbender/http/extensions/fpdf/font/courier.php
--- trunk/mapbender/http/extensions/fpdf/font/courier.php	                        (rev 0)
+++ trunk/mapbender/http/extensions/fpdf/font/courier.php	2010-01-19 23:07:49 UTC (rev 5359)
@@ -0,0 +1,7 @@
+<?php
+for($i=0;$i<=255;$i++)
+	$fpdf_charwidths['courier'][chr($i)]=600;
+$fpdf_charwidths['courierB']=$fpdf_charwidths['courier'];
+$fpdf_charwidths['courierI']=$fpdf_charwidths['courier'];
+$fpdf_charwidths['courierBI']=$fpdf_charwidths['courier'];
Added: trunk/mapbender/http/extensions/fpdf/font/desktop.ini
--- trunk/mapbender/http/extensions/fpdf/font/desktop.ini	                        (rev 0)
+++ trunk/mapbender/http/extensions/fpdf/font/desktop.ini	2010-01-19 23:07:49 UTC (rev 5359)
@@ -0,0 +1,4 @@
+[ViewState]
+Mode=
+Vid=
+FolderType=NotSpecified
Added: trunk/mapbender/http/extensions/fpdf/font/helvetica.php
--- trunk/mapbender/http/extensions/fpdf/font/helvetica.php	                        (rev 0)
+++ trunk/mapbender/http/extensions/fpdf/font/helvetica.php	2010-01-19 23:07:49 UTC (rev 5359)
@@ -0,0 +1,15 @@
+<?php
+$fpdf_charwidths['helvetica']=array(
+	chr(0)=>278,chr(1)=>278,chr(2)=>278,chr(3)=>278,chr(4)=>278,chr(5)=>278,chr(6)=>278,chr(7)=>278,chr(8)=>278,chr(9)=>278,chr(10)=>278,chr(11)=>278,chr(12)=>278,chr(13)=>278,chr(14)=>278,chr(15)=>278,chr(16)=>278,chr(17)=>278,chr(18)=>278,chr(19)=>278,chr(20)=>278,chr(21)=>278,
+	chr(22)=>278,chr(23)=>278,chr(24)=>278,chr(25)=>278,chr(26)=>278,chr(27)=>278,chr(28)=>278,chr(29)=>278,chr(30)=>278,chr(31)=>278,' '=>278,'!'=>278,'"'=>355,'#'=>556,'$'=>556,'%'=>889,'&'=>667,'\''=>191,'('=>333,')'=>333,'*'=>389,'+'=>584,
+	','=>278,'-'=>333,'.'=>278,'/'=>278,'0'=>556,'1'=>556,'2'=>556,'3'=>556,'4'=>556,'5'=>556,'6'=>556,'7'=>556,'8'=>556,'9'=>556,':'=>278,';'=>278,'<'=>584,'='=>584,'>'=>584,'?'=>556,'@'=>1015,'A'=>667,
+	'B'=>667,'C'=>722,'D'=>722,'E'=>667,'F'=>611,'G'=>778,'H'=>722,'I'=>278,'J'=>500,'K'=>667,'L'=>556,'M'=>833,'N'=>722,'O'=>778,'P'=>667,'Q'=>778,'R'=>722,'S'=>667,'T'=>611,'U'=>722,'V'=>667,'W'=>944,
+	'X'=>667,'Y'=>667,'Z'=>611,'['=>278,'\\'=>278,']'=>278,'^'=>469,'_'=>556,'`'=>333,'a'=>556,'b'=>556,'c'=>500,'d'=>556,'e'=>556,'f'=>278,'g'=>556,'h'=>556,'i'=>222,'j'=>222,'k'=>500,'l'=>222,'m'=>833,
+	'n'=>556,'o'=>556,'p'=>556,'q'=>556,'r'=>333,'s'=>500,'t'=>278,'u'=>556,'v'=>500,'w'=>722,'x'=>500,'y'=>500,'z'=>500,'{'=>334,'|'=>260,'}'=>334,'~'=>584,chr(127)=>350,chr(128)=>556,chr(129)=>350,chr(130)=>222,chr(131)=>556,
+	chr(132)=>333,chr(133)=>1000,chr(134)=>556,chr(135)=>556,chr(136)=>333,chr(137)=>1000,chr(138)=>667,chr(139)=>333,chr(140)=>1000,chr(141)=>350,chr(142)=>611,chr(143)=>350,chr(144)=>350,chr(145)=>222,chr(146)=>222,chr(147)=>333,chr(148)=>333,chr(149)=>350,chr(150)=>556,chr(151)=>1000,chr(152)=>333,chr(153)=>1000,
+	chr(154)=>500,chr(155)=>333,chr(156)=>944,chr(157)=>350,chr(158)=>500,chr(159)=>667,chr(160)=>278,chr(161)=>333,chr(162)=>556,chr(163)=>556,chr(164)=>556,chr(165)=>556,chr(166)=>260,chr(167)=>556,chr(168)=>333,chr(169)=>737,chr(170)=>370,chr(171)=>556,chr(172)=>584,chr(173)=>333,chr(174)=>737,chr(175)=>333,
+	chr(176)=>400,chr(177)=>584,chr(178)=>333,chr(179)=>333,chr(180)=>333,chr(181)=>556,chr(182)=>537,chr(183)=>278,chr(184)=>333,chr(185)=>333,chr(186)=>365,chr(187)=>556,chr(188)=>834,chr(189)=>834,chr(190)=>834,chr(191)=>611,chr(192)=>667,chr(193)=>667,chr(194)=>667,chr(195)=>667,chr(196)=>667,chr(197)=>667,
+	chr(198)=>1000,chr(199)=>722,chr(200)=>667,chr(201)=>667,chr(202)=>667,chr(203)=>667,chr(204)=>278,chr(205)=>278,chr(206)=>278,chr(207)=>278,chr(208)=>722,chr(209)=>722,chr(210)=>778,chr(211)=>778,chr(212)=>778,chr(213)=>778,chr(214)=>778,chr(215)=>584,chr(216)=>778,chr(217)=>722,chr(218)=>722,chr(219)=>722,
+	chr(220)=>722,chr(221)=>667,chr(222)=>667,chr(223)=>611,chr(224)=>556,chr(225)=>556,chr(226)=>556,chr(227)=>556,chr(228)=>556,chr(229)=>556,chr(230)=>889,chr(231)=>500,chr(232)=>556,chr(233)=>556,chr(234)=>556,chr(235)=>556,chr(236)=>278,chr(237)=>278,chr(238)=>278,chr(239)=>278,chr(240)=>556,chr(241)=>556,
+	chr(242)=>556,chr(243)=>556,chr(244)=>556,chr(245)=>556,chr(246)=>556,chr(247)=>584,chr(248)=>611,chr(249)=>556,chr(250)=>556,chr(251)=>556,chr(252)=>556,chr(253)=>500,chr(254)=>556,chr(255)=>500);
Added: trunk/mapbender/http/extensions/fpdf/font/helveticab.php
--- trunk/mapbender/http/extensions/fpdf/font/helveticab.php	                        (rev 0)
+++ trunk/mapbender/http/extensions/fpdf/font/helveticab.php	2010-01-19 23:07:49 UTC (rev 5359)
@@ -0,0 +1,15 @@
+<?php
+$fpdf_charwidths['helveticaB']=array(
+	chr(22)=>278,chr(23)=>278,chr(24)=>278,chr(25)=>278,chr(26)=>278,chr(27)=>278,chr(28)=>278,chr(29)=>278,chr(30)=>278,chr(31)=>278,' '=>278,'!'=>333,'"'=>474,'#'=>556,'$'=>556,'%'=>889,'&'=>722,'\''=>238,'('=>333,')'=>333,'*'=>389,'+'=>584,
+	','=>278,'-'=>333,'.'=>278,'/'=>278,'0'=>556,'1'=>556,'2'=>556,'3'=>556,'4'=>556,'5'=>556,'6'=>556,'7'=>556,'8'=>556,'9'=>556,':'=>333,';'=>333,'<'=>584,'='=>584,'>'=>584,'?'=>611,'@'=>975,'A'=>722,
+	'B'=>722,'C'=>722,'D'=>722,'E'=>667,'F'=>611,'G'=>778,'H'=>722,'I'=>278,'J'=>556,'K'=>722,'L'=>611,'M'=>833,'N'=>722,'O'=>778,'P'=>667,'Q'=>778,'R'=>722,'S'=>667,'T'=>611,'U'=>722,'V'=>667,'W'=>944,
+	'X'=>667,'Y'=>667,'Z'=>611,'['=>333,'\\'=>278,']'=>333,'^'=>584,'_'=>556,'`'=>333,'a'=>556,'b'=>611,'c'=>556,'d'=>611,'e'=>556,'f'=>333,'g'=>611,'h'=>611,'i'=>278,'j'=>278,'k'=>556,'l'=>278,'m'=>889,
+	'n'=>611,'o'=>611,'p'=>611,'q'=>611,'r'=>389,'s'=>556,'t'=>333,'u'=>611,'v'=>556,'w'=>778,'x'=>556,'y'=>556,'z'=>500,'{'=>389,'|'=>280,'}'=>389,'~'=>584,chr(127)=>350,chr(128)=>556,chr(129)=>350,chr(130)=>278,chr(131)=>556,
+	chr(132)=>500,chr(133)=>1000,chr(134)=>556,chr(135)=>556,chr(136)=>333,chr(137)=>1000,chr(138)=>667,chr(139)=>333,chr(140)=>1000,chr(141)=>350,chr(142)=>611,chr(143)=>350,chr(144)=>350,chr(145)=>278,chr(146)=>278,chr(147)=>500,chr(148)=>500,chr(149)=>350,chr(150)=>556,chr(151)=>1000,chr(152)=>333,chr(153)=>1000,
+	chr(154)=>556,chr(155)=>333,chr(156)=>944,chr(157)=>350,chr(158)=>500,chr(159)=>667,chr(160)=>278,chr(161)=>333,chr(162)=>556,chr(163)=>556,chr(164)=>556,chr(165)=>556,chr(166)=>280,chr(167)=>556,chr(168)=>333,chr(169)=>737,chr(170)=>370,chr(171)=>556,chr(172)=>584,chr(173)=>333,chr(174)=>737,chr(175)=>333,
+	chr(176)=>400,chr(177)=>584,chr(178)=>333,chr(179)=>333,chr(180)=>333,chr(181)=>611,chr(182)=>556,chr(183)=>278,chr(184)=>333,chr(185)=>333,chr(186)=>365,chr(187)=>556,chr(188)=>834,chr(189)=>834,chr(190)=>834,chr(191)=>611,chr(192)=>722,chr(193)=>722,chr(194)=>722,chr(195)=>722,chr(196)=>722,chr(197)=>722,
+	chr(220)=>722,chr(221)=>667,chr(222)=>667,chr(223)=>611,chr(224)=>556,chr(225)=>556,chr(226)=>556,chr(227)=>556,chr(228)=>556,chr(229)=>556,chr(230)=>889,chr(231)=>556,chr(232)=>556,chr(233)=>556,chr(234)=>556,chr(235)=>556,chr(236)=>278,chr(237)=>278,chr(238)=>278,chr(239)=>278,chr(240)=>611,chr(241)=>611,
+	chr(242)=>611,chr(243)=>611,chr(244)=>611,chr(245)=>611,chr(246)=>611,chr(247)=>584,chr(248)=>611,chr(249)=>611,chr(250)=>611,chr(251)=>611,chr(252)=>611,chr(253)=>556,chr(254)=>611,chr(255)=>556);
Added: trunk/mapbender/http/extensions/fpdf/font/helveticabi.php
--- trunk/mapbender/http/extensions/fpdf/font/helveticabi.php	                        (rev 0)
+++ trunk/mapbender/http/extensions/fpdf/font/helveticabi.php	2010-01-19 23:07:49 UTC (rev 5359)
@@ -0,0 +1,15 @@
+<?php
+$fpdf_charwidths['helveticaBI']=array(
Added: trunk/mapbender/http/extensions/fpdf/font/helveticai.php
--- trunk/mapbender/http/extensions/fpdf/font/helveticai.php	                        (rev 0)
+++ trunk/mapbender/http/extensions/fpdf/font/helveticai.php	2010-01-19 23:07:49 UTC (rev 5359)
@@ -0,0 +1,15 @@
+<?php
+$fpdf_charwidths['helveticaI']=array(
Added: trunk/mapbender/http/extensions/fpdf/font/makefont/cp1250.map
--- trunk/mapbender/http/extensions/fpdf/font/makefont/cp1250.map	                        (rev 0)
+++ trunk/mapbender/http/extensions/fpdf/font/makefont/cp1250.map	2010-01-19 23:07:49 UTC (rev 5359)
@@ -0,0 +1,251 @@
+!00 U+0000 .notdef
+!01 U+0001 .notdef
+!02 U+0002 .notdef
+!03 U+0003 .notdef
+!04 U+0004 .notdef
+!05 U+0005 .notdef
+!06 U+0006 .notdef
+!07 U+0007 .notdef
+!08 U+0008 .notdef
+!09 U+0009 .notdef
+!0A U+000A .notdef
+!0B U+000B .notdef
+!0C U+000C .notdef
+!0D U+000D .notdef
+!0E U+000E .notdef
+!0F U+000F .notdef
+!10 U+0010 .notdef
+!11 U+0011 .notdef
+!12 U+0012 .notdef
+!13 U+0013 .notdef
+!14 U+0014 .notdef
+!15 U+0015 .notdef
+!16 U+0016 .notdef
+!17 U+0017 .notdef
+!18 U+0018 .notdef
+!19 U+0019 .notdef
+!1A U+001A .notdef
+!1B U+001B .notdef
+!1C U+001C .notdef
+!1D U+001D .notdef
+!1E U+001E .notdef
+!1F U+001F .notdef
+!20 U+0020 space
+!21 U+0021 exclam
+!22 U+0022 quotedbl
+!23 U+0023 numbersign
+!24 U+0024 dollar
+!25 U+0025 percent
+!26 U+0026 ampersand
+!27 U+0027 quotesingle
+!28 U+0028 parenleft
+!29 U+0029 parenright
+!2A U+002A asterisk
+!2B U+002B plus
+!2C U+002C comma
+!2D U+002D hyphen
+!2E U+002E period
+!2F U+002F slash
+!30 U+0030 zero
+!31 U+0031 one
+!32 U+0032 two
+!33 U+0033 three
+!34 U+0034 four
+!35 U+0035 five
+!36 U+0036 six
+!37 U+0037 seven
+!38 U+0038 eight
+!39 U+0039 nine
+!3A U+003A colon
+!3B U+003B semicolon
+!3C U+003C less
+!3D U+003D equal
+!3E U+003E greater
+!3F U+003F question
+!40 U+0040 at
+!41 U+0041 A
+!42 U+0042 B
+!43 U+0043 C
+!44 U+0044 D
+!45 U+0045 E
+!46 U+0046 F
+!47 U+0047 G
+!48 U+0048 H
+!49 U+0049 I
+!4A U+004A J
+!4B U+004B K
+!4C U+004C L
+!4D U+004D M
+!4E U+004E N
+!4F U+004F O
+!50 U+0050 P
+!51 U+0051 Q
+!52 U+0052 R
+!53 U+0053 S
+!54 U+0054 T
+!55 U+0055 U
+!56 U+0056 V
+!57 U+0057 W
+!58 U+0058 X
+!59 U+0059 Y
+!5A U+005A Z
+!5B U+005B bracketleft
+!5C U+005C backslash
+!5D U+005D bracketright
+!5E U+005E asciicircum
+!5F U+005F underscore
+!60 U+0060 grave
+!61 U+0061 a
+!62 U+0062 b
+!63 U+0063 c
+!64 U+0064 d
+!65 U+0065 e
+!66 U+0066 f
+!67 U+0067 g
+!68 U+0068 h
+!69 U+0069 i
+!6A U+006A j
+!6B U+006B k
+!6C U+006C l
+!6D U+006D m
+!6E U+006E n
+!6F U+006F o
+!70 U+0070 p
+!71 U+0071 q
+!72 U+0072 r
+!73 U+0073 s
+!74 U+0074 t
+!75 U+0075 u
+!76 U+0076 v
+!77 U+0077 w
+!78 U+0078 x
+!79 U+0079 y
+!7A U+007A z
+!7B U+007B braceleft
+!7C U+007C bar
+!7D U+007D braceright
+!7E U+007E asciitilde
+!7F U+007F .notdef
+!80 U+20AC Euro
+!82 U+201A quotesinglbase
+!84 U+201E quotedblbase
+!85 U+2026 ellipsis
+!86 U+2020 dagger
+!87 U+2021 daggerdbl
+!89 U+2030 perthousand
+!8A U+0160 Scaron
+!8B U+2039 guilsinglleft
+!8C U+015A Sacute
+!8D U+0164 Tcaron
+!8E U+017D Zcaron
+!8F U+0179 Zacute
+!91 U+2018 quoteleft
+!92 U+2019 quoteright
+!93 U+201C quotedblleft
+!94 U+201D quotedblright
+!95 U+2022 bullet
+!96 U+2013 endash
+!97 U+2014 emdash
+!99 U+2122 trademark
+!9A U+0161 scaron
+!9B U+203A guilsinglright
+!9C U+015B sacute
+!9D U+0165 tcaron
+!9E U+017E zcaron
+!9F U+017A zacute
+!A0 U+00A0 space
+!A1 U+02C7 caron
+!A2 U+02D8 breve
+!A3 U+0141 Lslash
+!A4 U+00A4 currency
+!A5 U+0104 Aogonek
+!A6 U+00A6 brokenbar
+!A7 U+00A7 section
+!A8 U+00A8 dieresis
+!A9 U+00A9 copyright
+!AA U+015E Scedilla
+!AB U+00AB guillemotleft
+!AC U+00AC logicalnot
+!AD U+00AD hyphen
+!AE U+00AE registered
+!AF U+017B Zdotaccent
+!B0 U+00B0 degree
+!B1 U+00B1 plusminus
+!B2 U+02DB ogonek
+!B3 U+0142 lslash
+!B4 U+00B4 acute
+!B5 U+00B5 mu
+!B6 U+00B6 paragraph
+!B7 U+00B7 periodcentered
+!B8 U+00B8 cedilla
+!B9 U+0105 aogonek
+!BA U+015F scedilla
+!BB U+00BB guillemotright
+!BC U+013D Lcaron
+!BD U+02DD hungarumlaut
+!BE U+013E lcaron
+!BF U+017C zdotaccent
+!C0 U+0154 Racute
+!C1 U+00C1 Aacute
+!C2 U+00C2 Acircumflex
+!C3 U+0102 Abreve
+!C4 U+00C4 Adieresis
+!C5 U+0139 Lacute
+!C6 U+0106 Cacute
+!C7 U+00C7 Ccedilla
+!C8 U+010C Ccaron
+!C9 U+00C9 Eacute
+!CA U+0118 Eogonek
+!CB U+00CB Edieresis
+!CC U+011A Ecaron
+!CD U+00CD Iacute
+!CE U+00CE Icircumflex
+!CF U+010E Dcaron
+!D0 U+0110 Dcroat
+!D1 U+0143 Nacute
+!D2 U+0147 Ncaron
+!D3 U+00D3 Oacute
+!D4 U+00D4 Ocircumflex
+!D5 U+0150 Ohungarumlaut
+!D6 U+00D6 Odieresis
+!D7 U+00D7 multiply
+!D8 U+0158 Rcaron
+!D9 U+016E Uring
+!DA U+00DA Uacute
+!DB U+0170 Uhungarumlaut
+!DC U+00DC Udieresis
+!DD U+00DD Yacute
+!DE U+0162 Tcommaaccent
+!DF U+00DF germandbls
+!E0 U+0155 racute
+!E1 U+00E1 aacute
+!E2 U+00E2 acircumflex
+!E3 U+0103 abreve
+!E4 U+00E4 adieresis
+!E5 U+013A lacute
+!E6 U+0107 cacute
+!E7 U+00E7 ccedilla
+!E8 U+010D ccaron
+!E9 U+00E9 eacute
+!EA U+0119 eogonek
+!EB U+00EB edieresis
+!EC U+011B ecaron
+!ED U+00ED iacute
+!EE U+00EE icircumflex
+!EF U+010F dcaron
+!F0 U+0111 dcroat
+!F1 U+0144 nacute
+!F2 U+0148 ncaron
+!F3 U+00F3 oacute
+!F4 U+00F4 ocircumflex
+!F5 U+0151 ohungarumlaut
+!F6 U+00F6 odieresis
+!F7 U+00F7 divide
+!F8 U+0159 rcaron
+!F9 U+016F uring
+!FA U+00FA uacute
+!FB U+0171 uhungarumlaut
+!FC U+00FC udieresis
+!FD U+00FD yacute
+!FE U+0163 tcommaaccent
+!FF U+02D9 dotaccent
Added: trunk/mapbender/http/extensions/fpdf/font/makefont/cp1251.map
--- trunk/mapbender/http/extensions/fpdf/font/makefont/cp1251.map	                        (rev 0)
+++ trunk/mapbender/http/extensions/fpdf/font/makefont/cp1251.map	2010-01-19 23:07:49 UTC (rev 5359)
@@ -0,0 +1,255 @@
+!00 U+0000 .notdef
+!01 U+0001 .notdef
+!02 U+0002 .notdef
+!03 U+0003 .notdef
+!04 U+0004 .notdef
+!05 U+0005 .notdef
+!06 U+0006 .notdef
+!07 U+0007 .notdef
+!08 U+0008 .notdef
+!09 U+0009 .notdef
+!0A U+000A .notdef
+!0B U+000B .notdef
+!0C U+000C .notdef
+!0D U+000D .notdef
+!0E U+000E .notdef
+!0F U+000F .notdef
+!10 U+0010 .notdef
+!11 U+0011 .notdef
+!12 U+0012 .notdef
+!13 U+0013 .notdef
+!14 U+0014 .notdef
+!15 U+0015 .notdef
+!16 U+0016 .notdef
+!17 U+0017 .notdef
+!18 U+0018 .notdef
+!19 U+0019 .notdef
+!1A U+001A .notdef
+!1B U+001B .notdef
+!1C U+001C .notdef
+!1D U+001D .notdef
+!1E U+001E .notdef
+!1F U+001F .notdef
+!20 U+0020 space
+!21 U+0021 exclam
+!24 U+0024 dollar
+!25 U+0025 percent
+!2B U+002B plus
+!2C U+002C comma
+!2D U+002D hyphen
+!2E U+002E period
+!2F U+002F slash
+!30 U+0030 zero
+!31 U+0031 one
+!32 U+0032 two
+!33 U+0033 three
+!34 U+0034 four
+!35 U+0035 five
+!36 U+0036 six
+!37 U+0037 seven
+!38 U+0038 eight
+!39 U+0039 nine
+!3A U+003A colon
+!3C U+003C less
+!3D U+003D equal
+!3E U+003E greater
+!40 U+0040 at
+!41 U+0041 A
+!42 U+0042 B
+!43 U+0043 C
+!44 U+0044 D
+!45 U+0045 E
+!46 U+0046 F
+!47 U+0047 G
+!48 U+0048 H
+!49 U+0049 I
+!4A U+004A J
+!4B U+004B K
+!4C U+004C L
+!4D U+004D M
+!4E U+004E N
+!4F U+004F O
+!50 U+0050 P
+!51 U+0051 Q
+!52 U+0052 R
+!53 U+0053 S
+!54 U+0054 T
+!55 U+0055 U
+!56 U+0056 V
+!57 U+0057 W
+!58 U+0058 X
+!59 U+0059 Y
+!5A U+005A Z
+!60 U+0060 grave
+!61 U+0061 a
+!62 U+0062 b
+!63 U+0063 c
+!64 U+0064 d
+!65 U+0065 e
+!66 U+0066 f
+!67 U+0067 g
+!68 U+0068 h
+!69 U+0069 i
+!6A U+006A j
+!6B U+006B k
+!6C U+006C l
+!6D U+006D m
+!6E U+006E n
+!6F U+006F o
+!70 U+0070 p
+!71 U+0071 q
+!72 U+0072 r
+!73 U+0073 s
+!74 U+0074 t
+!75 U+0075 u
+!76 U+0076 v
+!77 U+0077 w
+!78 U+0078 x
+!79 U+0079 y
+!7A U+007A z
+!7C U+007C bar
+!7F U+007F .notdef
+!80 U+0402 afii10051
+!81 U+0403 afii10052
+!83 U+0453 afii10100
+!86 U+2020 dagger
+!88 U+20AC Euro
+!8A U+0409 afii10058
+!8C U+040A afii10059
+!8D U+040C afii10061
+!8E U+040B afii10060
+!8F U+040F afii10145
+!90 U+0452 afii10099
+!95 U+2022 bullet
+!96 U+2013 endash
+!97 U+2014 emdash
+!9A U+0459 afii10106
+!9C U+045A afii10107
+!9D U+045C afii10109
+!9E U+045B afii10108
+!9F U+045F afii10193
+!A0 U+00A0 space
+!A1 U+040E afii10062
+!A2 U+045E afii10110
+!A3 U+0408 afii10057
+!A5 U+0490 afii10050
+!A7 U+00A7 section
+!A8 U+0401 afii10023
+!AA U+0404 afii10053
+!AD U+00AD hyphen
+!AF U+0407 afii10056
+!B0 U+00B0 degree
+!B2 U+0406 afii10055
+!B3 U+0456 afii10103
+!B4 U+0491 afii10098
+!B5 U+00B5 mu
+!B8 U+0451 afii10071
+!B9 U+2116 afii61352
+!BA U+0454 afii10101
+!BC U+0458 afii10105
+!BD U+0405 afii10054
+!BE U+0455 afii10102
+!BF U+0457 afii10104
+!C0 U+0410 afii10017
+!C1 U+0411 afii10018
+!C2 U+0412 afii10019
+!C3 U+0413 afii10020
+!C4 U+0414 afii10021
+!C5 U+0415 afii10022
+!C6 U+0416 afii10024
+!C7 U+0417 afii10025
+!C8 U+0418 afii10026
+!C9 U+0419 afii10027
+!CA U+041A afii10028
+!CB U+041B afii10029
+!CC U+041C afii10030
+!CD U+041D afii10031
+!CE U+041E afii10032
+!CF U+041F afii10033
+!D0 U+0420 afii10034
+!D1 U+0421 afii10035
+!D2 U+0422 afii10036
+!D3 U+0423 afii10037
+!D4 U+0424 afii10038
+!D5 U+0425 afii10039
+!D6 U+0426 afii10040
+!D7 U+0427 afii10041
+!D8 U+0428 afii10042
+!D9 U+0429 afii10043
+!DA U+042A afii10044
+!DB U+042B afii10045
+!DC U+042C afii10046
+!DD U+042D afii10047
+!DE U+042E afii10048
+!DF U+042F afii10049
+!E0 U+0430 afii10065
+!E1 U+0431 afii10066
+!E2 U+0432 afii10067
+!E3 U+0433 afii10068
+!E4 U+0434 afii10069
+!E5 U+0435 afii10070
+!E6 U+0436 afii10072
+!E7 U+0437 afii10073
+!E8 U+0438 afii10074
+!E9 U+0439 afii10075
+!EA U+043A afii10076
+!EB U+043B afii10077
+!EC U+043C afii10078
+!ED U+043D afii10079
+!EE U+043E afii10080
+!EF U+043F afii10081
+!F0 U+0440 afii10082
+!F1 U+0441 afii10083
+!F2 U+0442 afii10084
+!F3 U+0443 afii10085
+!F4 U+0444 afii10086
+!F5 U+0445 afii10087
+!F6 U+0446 afii10088
+!F7 U+0447 afii10089
+!F8 U+0448 afii10090
+!F9 U+0449 afii10091
+!FA U+044A afii10092
+!FB U+044B afii10093
+!FC U+044C afii10094
+!FD U+044D afii10095
+!FE U+044E afii10096
+!FF U+044F afii10097
Added: trunk/mapbender/http/extensions/fpdf/font/makefont/cp1252.map
--- trunk/mapbender/http/extensions/fpdf/font/makefont/cp1252.map	                        (rev 0)
+++ trunk/mapbender/http/extensions/fpdf/font/makefont/cp1252.map	2010-01-19 23:07:49 UTC (rev 5359)
@@ -0,0 +1,251 @@
+!00 U+0000 .notdef
+!01 U+0001 .notdef
+!02 U+0002 .notdef
+!03 U+0003 .notdef
+!04 U+0004 .notdef
+!05 U+0005 .notdef
+!06 U+0006 .notdef
+!07 U+0007 .notdef
+!08 U+0008 .notdef
+!09 U+0009 .notdef
+!0A U+000A .notdef
+!0B U+000B .notdef
+!0C U+000C .notdef
+!0D U+000D .notdef
+!0E U+000E .notdef
+!0F U+000F .notdef
+!10 U+0010 .notdef
+!11 U+0011 .notdef
+!12 U+0012 .notdef
+!13 U+0013 .notdef
+!14 U+0014 .notdef
+!15 U+0015 .notdef
+!16 U+0016 .notdef
+!17 U+0017 .notdef
+!18 U+0018 .notdef
+!19 U+0019 .notdef
+!1A U+001A .notdef
+!1B U+001B .notdef
+!1C U+001C .notdef
+!1D U+001D .notdef
+!1E U+001E .notdef
+!1F U+001F .notdef
+!20 U+0020 space
+!21 U+0021 exclam
+!24 U+0024 dollar
+!25 U+0025 percent
+!2B U+002B plus
+!2C U+002C comma
+!2D U+002D hyphen
+!2E U+002E period
+!2F U+002F slash
+!30 U+0030 zero
+!31 U+0031 one
+!32 U+0032 two
+!33 U+0033 three
+!34 U+0034 four
+!35 U+0035 five
+!36 U+0036 six
+!37 U+0037 seven
+!38 U+0038 eight
+!39 U+0039 nine
+!3A U+003A colon
+!3C U+003C less
+!3D U+003D equal
+!3E U+003E greater
+!40 U+0040 at
+!41 U+0041 A
+!42 U+0042 B
+!43 U+0043 C
+!44 U+0044 D
+!45 U+0045 E
+!46 U+0046 F
+!47 U+0047 G
+!48 U+0048 H
+!49 U+0049 I
+!4A U+004A J
+!4B U+004B K
+!4C U+004C L
+!4D U+004D M
+!4E U+004E N
+!4F U+004F O
+!50 U+0050 P
+!51 U+0051 Q
+!52 U+0052 R
+!53 U+0053 S
+!54 U+0054 T
+!55 U+0055 U
+!56 U+0056 V
+!57 U+0057 W
+!58 U+0058 X
+!59 U+0059 Y
+!5A U+005A Z
+!60 U+0060 grave
+!61 U+0061 a
+!62 U+0062 b
+!63 U+0063 c
+!64 U+0064 d
+!65 U+0065 e
+!66 U+0066 f
+!67 U+0067 g
+!68 U+0068 h
+!69 U+0069 i
+!6A U+006A j
+!6B U+006B k
+!6C U+006C l
+!6D U+006D m
+!6E U+006E n
+!6F U+006F o
+!70 U+0070 p
+!71 U+0071 q
+!72 U+0072 r
+!73 U+0073 s
+!74 U+0074 t
+!75 U+0075 u
+!76 U+0076 v
+!77 U+0077 w
+!78 U+0078 x
+!79 U+0079 y
+!7A U+007A z
+!7C U+007C bar
+!7F U+007F .notdef
+!80 U+20AC Euro
+!83 U+0192 florin
+!86 U+2020 dagger
+!88 U+02C6 circumflex
+!8A U+0160 Scaron
+!8C U+0152 OE
+!8E U+017D Zcaron
+!95 U+2022 bullet
+!96 U+2013 endash
+!97 U+2014 emdash
+!98 U+02DC tilde
+!9A U+0161 scaron
+!9C U+0153 oe
+!9E U+017E zcaron
+!9F U+0178 Ydieresis
+!A0 U+00A0 space
+!A1 U+00A1 exclamdown
+!A2 U+00A2 cent
+!A3 U+00A3 sterling
+!A5 U+00A5 yen
+!A7 U+00A7 section
+!AA U+00AA ordfeminine
+!AD U+00AD hyphen
+!AF U+00AF macron
+!B0 U+00B0 degree
+!B2 U+00B2 twosuperior
+!B3 U+00B3 threesuperior
+!B4 U+00B4 acute
+!B5 U+00B5 mu
+!B8 U+00B8 cedilla
+!B9 U+00B9 onesuperior
+!BA U+00BA ordmasculine
+!BC U+00BC onequarter
+!BD U+00BD onehalf
+!BE U+00BE threequarters
+!BF U+00BF questiondown
+!C0 U+00C0 Agrave
+!C1 U+00C1 Aacute
+!C3 U+00C3 Atilde
+!C5 U+00C5 Aring
+!C6 U+00C6 AE
+!C8 U+00C8 Egrave
+!C9 U+00C9 Eacute
+!CA U+00CA Ecircumflex
+!CC U+00CC Igrave
+!CD U+00CD Iacute
+!CF U+00CF Idieresis
+!D0 U+00D0 Eth
+!D1 U+00D1 Ntilde
+!D2 U+00D2 Ograve
+!D3 U+00D3 Oacute
+!D5 U+00D5 Otilde
+!D8 U+00D8 Oslash
+!D9 U+00D9 Ugrave
+!DA U+00DA Uacute
+!DB U+00DB Ucircumflex
+!DD U+00DD Yacute
+!DE U+00DE Thorn
+!E0 U+00E0 agrave
+!E1 U+00E1 aacute
+!E3 U+00E3 atilde
+!E5 U+00E5 aring
+!E6 U+00E6 ae
+!E8 U+00E8 egrave
+!E9 U+00E9 eacute
+!EA U+00EA ecircumflex
+!EC U+00EC igrave
+!ED U+00ED iacute
+!EF U+00EF idieresis
+!F0 U+00F0 eth
+!F1 U+00F1 ntilde
+!F2 U+00F2 ograve
+!F3 U+00F3 oacute
+!F5 U+00F5 otilde
+!F7 U+00F7 divide
+!F8 U+00F8 oslash
+!F9 U+00F9 ugrave
+!FA U+00FA uacute
+!FB U+00FB ucircumflex
+!FD U+00FD yacute
+!FE U+00FE thorn
+!FF U+00FF ydieresis
Added: trunk/mapbender/http/extensions/fpdf/font/makefont/cp1253.map
--- trunk/mapbender/http/extensions/fpdf/font/makefont/cp1253.map	                        (rev 0)
+++ trunk/mapbender/http/extensions/fpdf/font/makefont/cp1253.map	2010-01-19 23:07:49 UTC (rev 5359)
@@ -0,0 +1,239 @@
+!00 U+0000 .notdef
+!01 U+0001 .notdef
+!02 U+0002 .notdef
+!03 U+0003 .notdef
+!04 U+0004 .notdef
+!05 U+0005 .notdef
+!06 U+0006 .notdef
+!07 U+0007 .notdef
+!08 U+0008 .notdef
+!09 U+0009 .notdef
+!0A U+000A .notdef
+!0B U+000B .notdef
+!0C U+000C .notdef
+!0D U+000D .notdef
+!0E U+000E .notdef
+!0F U+000F .notdef
+!10 U+0010 .notdef
+!11 U+0011 .notdef
+!12 U+0012 .notdef
+!13 U+0013 .notdef
+!14 U+0014 .notdef
+!15 U+0015 .notdef
+!16 U+0016 .notdef
+!17 U+0017 .notdef
+!18 U+0018 .notdef
+!19 U+0019 .notdef
+!1A U+001A .notdef
+!1B U+001B .notdef
+!1C U+001C .notdef
+!1D U+001D .notdef
+!1E U+001E .notdef
+!1F U+001F .notdef
+!20 U+0020 space
+!21 U+0021 exclam
+!24 U+0024 dollar
+!25 U+0025 percent
+!2B U+002B plus
+!2C U+002C comma
+!2D U+002D hyphen
+!2E U+002E period
+!2F U+002F slash
+!30 U+0030 zero
+!31 U+0031 one
+!32 U+0032 two
+!33 U+0033 three
+!34 U+0034 four
+!35 U+0035 five
+!36 U+0036 six
+!37 U+0037 seven
+!38 U+0038 eight
+!39 U+0039 nine
+!3A U+003A colon
+!3C U+003C less
+!3D U+003D equal
+!3E U+003E greater
+!40 U+0040 at
+!41 U+0041 A
+!42 U+0042 B
+!43 U+0043 C
+!44 U+0044 D
+!45 U+0045 E
+!46 U+0046 F
+!47 U+0047 G
+!48 U+0048 H
+!49 U+0049 I
+!4A U+004A J
+!4B U+004B K
+!4C U+004C L
+!4D U+004D M
+!4E U+004E N
+!4F U+004F O
+!50 U+0050 P
+!51 U+0051 Q
+!52 U+0052 R
+!53 U+0053 S
+!54 U+0054 T
+!55 U+0055 U
+!56 U+0056 V
+!57 U+0057 W
+!58 U+0058 X
+!59 U+0059 Y
+!5A U+005A Z
+!60 U+0060 grave
+!61 U+0061 a
+!62 U+0062 b
+!63 U+0063 c
+!64 U+0064 d
+!65 U+0065 e
+!66 U+0066 f
+!67 U+0067 g
+!68 U+0068 h
+!69 U+0069 i
+!6A U+006A j
+!6B U+006B k
+!6C U+006C l
+!6D U+006D m
+!6E U+006E n
+!6F U+006F o
+!70 U+0070 p
+!71 U+0071 q
+!72 U+0072 r
+!73 U+0073 s
+!74 U+0074 t
+!75 U+0075 u
+!76 U+0076 v
+!77 U+0077 w
+!78 U+0078 x
+!79 U+0079 y
+!7A U+007A z
+!7C U+007C bar
+!7F U+007F .notdef
+!80 U+20AC Euro
+!83 U+0192 florin
+!86 U+2020 dagger
+!95 U+2022 bullet
+!96 U+2013 endash
+!97 U+2014 emdash
+!A0 U+00A0 space
+!A1 U+0385 dieresistonos
+!A2 U+0386 Alphatonos
+!A5 U+00A5 yen
+!A7 U+00A7 section
+!AD U+00AD hyphen
+!AF U+2015 afii00208
+!B0 U+00B0 degree
+!B4 U+0384 tonos
+!B5 U+00B5 mu
+!B8 U+0388 Epsilontonos
+!B9 U+0389 Etatonos
+!BA U+038A Iotatonos
+!BC U+038C Omicrontonos
+!BD U+00BD onehalf
+!BE U+038E Upsilontonos
+!BF U+038F Omegatonos
+!C0 U+0390 iotadieresistonos
+!C1 U+0391 Alpha
+!C2 U+0392 Beta
+!C3 U+0393 Gamma
+!C4 U+0394 Delta
+!C5 U+0395 Epsilon
+!C6 U+0396 Zeta
+!C7 U+0397 Eta
+!C8 U+0398 Theta
+!C9 U+0399 Iota
+!CA U+039A Kappa
+!CB U+039B Lambda
+!CC U+039C Mu
+!CD U+039D Nu
+!CE U+039E Xi
+!CF U+039F Omicron
+!D0 U+03A0 Pi
+!D1 U+03A1 Rho
+!D3 U+03A3 Sigma
+!D4 U+03A4 Tau
+!D5 U+03A5 Upsilon
+!D6 U+03A6 Phi
+!D7 U+03A7 Chi
+!D8 U+03A8 Psi
+!D9 U+03A9 Omega
+!DA U+03AA Iotadieresis
+!DB U+03AB Upsilondieresis
+!DC U+03AC alphatonos
+!DD U+03AD epsilontonos
+!DE U+03AE etatonos
+!DF U+03AF iotatonos
+!E0 U+03B0 upsilondieresistonos
+!E1 U+03B1 alpha
+!E2 U+03B2 beta
+!E3 U+03B3 gamma
+!E4 U+03B4 delta
+!E5 U+03B5 epsilon
+!E6 U+03B6 zeta
+!E7 U+03B7 eta
+!E8 U+03B8 theta
+!E9 U+03B9 iota
+!EA U+03BA kappa
+!EB U+03BB lambda
+!EC U+03BC mu
+!ED U+03BD nu
+!EE U+03BE xi
+!EF U+03BF omicron
+!F0 U+03C0 pi
+!F1 U+03C1 rho
+!F2 U+03C2 sigma1
+!F3 U+03C3 sigma
+!F4 U+03C4 tau
+!F5 U+03C5 upsilon
+!F6 U+03C6 phi
+!F7 U+03C7 chi
+!F8 U+03C8 psi
+!F9 U+03C9 omega
+!FA U+03CA iotadieresis
+!FB U+03CB upsilondieresis
+!FC U+03CC omicrontonos
+!FD U+03CD upsilontonos
+!FE U+03CE omegatonos
Added: trunk/mapbender/http/extensions/fpdf/font/makefont/cp1254.map
--- trunk/mapbender/http/extensions/fpdf/font/makefont/cp1254.map	                        (rev 0)
+++ trunk/mapbender/http/extensions/fpdf/font/makefont/cp1254.map	2010-01-19 23:07:49 UTC (rev 5359)
@@ -0,0 +1,249 @@
+!00 U+0000 .notdef
+!01 U+0001 .notdef
+!02 U+0002 .notdef
+!03 U+0003 .notdef
+!04 U+0004 .notdef
+!05 U+0005 .notdef
+!06 U+0006 .notdef
+!07 U+0007 .notdef
+!08 U+0008 .notdef
+!09 U+0009 .notdef
+!0A U+000A .notdef
+!0B U+000B .notdef
+!0C U+000C .notdef
+!0D U+000D .notdef
+!0E U+000E .notdef
+!0F U+000F .notdef
+!10 U+0010 .notdef
+!11 U+0011 .notdef
+!12 U+0012 .notdef
+!13 U+0013 .notdef
+!14 U+0014 .notdef
+!15 U+0015 .notdef
+!16 U+0016 .notdef
+!17 U+0017 .notdef
+!18 U+0018 .notdef
+!19 U+0019 .notdef
+!1A U+001A .notdef
+!1B U+001B .notdef
+!1C U+001C .notdef
+!1D U+001D .notdef
+!1E U+001E .notdef
+!1F U+001F .notdef
+!20 U+0020 space
+!21 U+0021 exclam
+!24 U+0024 dollar
+!25 U+0025 percent
+!2B U+002B plus
+!2C U+002C comma
+!2D U+002D hyphen
+!2E U+002E period
+!2F U+002F slash
+!30 U+0030 zero
+!31 U+0031 one
+!32 U+0032 two
+!33 U+0033 three
+!34 U+0034 four
+!35 U+0035 five
+!36 U+0036 six
+!37 U+0037 seven
+!38 U+0038 eight
+!39 U+0039 nine
+!3A U+003A colon
+!3C U+003C less
+!3D U+003D equal
+!3E U+003E greater
+!40 U+0040 at
+!41 U+0041 A
+!42 U+0042 B
+!43 U+0043 C
+!44 U+0044 D
+!45 U+0045 E
+!46 U+0046 F
+!47 U+0047 G
+!48 U+0048 H
+!49 U+0049 I
+!4A U+004A J
+!4B U+004B K
+!4C U+004C L
+!4D U+004D M
+!4E U+004E N
+!4F U+004F O
+!50 U+0050 P
+!51 U+0051 Q
+!52 U+0052 R
+!53 U+0053 S
+!54 U+0054 T
+!55 U+0055 U
+!56 U+0056 V
+!57 U+0057 W
+!58 U+0058 X
+!59 U+0059 Y
+!5A U+005A Z
+!60 U+0060 grave
+!61 U+0061 a
+!62 U+0062 b
+!63 U+0063 c
+!64 U+0064 d
+!65 U+0065 e
+!66 U+0066 f
+!67 U+0067 g
+!68 U+0068 h
+!69 U+0069 i
+!6A U+006A j
+!6B U+006B k
+!6C U+006C l
+!6D U+006D m
+!6E U+006E n
+!6F U+006F o
+!70 U+0070 p
+!71 U+0071 q
+!72 U+0072 r
+!73 U+0073 s
+!74 U+0074 t
+!75 U+0075 u
+!76 U+0076 v
+!77 U+0077 w
+!78 U+0078 x
+!79 U+0079 y
+!7A U+007A z
+!7C U+007C bar
+!7F U+007F .notdef
+!80 U+20AC Euro
+!83 U+0192 florin
+!86 U+2020 dagger
+!8A U+0160 Scaron
+!8C U+0152 OE
+!95 U+2022 bullet
+!96 U+2013 endash
+!97 U+2014 emdash
+!98 U+02DC tilde
+!9A U+0161 scaron
+!9C U+0153 oe
+!A0 U+00A0 space
+!A2 U+00A2 cent
+!A5 U+00A5 yen
+!A7 U+00A7 section
+!AD U+00AD hyphen
+!AF U+00AF macron
+!B0 U+00B0 degree
+!B4 U+00B4 acute
+!B5 U+00B5 mu
+!B8 U+00B8 cedilla
+!BD U+00BD onehalf
+!C0 U+00C0 Agrave
+!C1 U+00C1 Aacute
+!C3 U+00C3 Atilde
+!C5 U+00C5 Aring
+!C6 U+00C6 AE
+!C8 U+00C8 Egrave
+!C9 U+00C9 Eacute
+!CC U+00CC Igrave
+!CD U+00CD Iacute
+!D0 U+011E Gbreve
+!D1 U+00D1 Ntilde
+!D2 U+00D2 Ograve
+!D3 U+00D3 Oacute
+!D5 U+00D5 Otilde
+!D8 U+00D8 Oslash
+!D9 U+00D9 Ugrave
+!DA U+00DA Uacute
+!DD U+0130 Idotaccent
+!DE U+015E Scedilla
+!E0 U+00E0 agrave
+!E1 U+00E1 aacute
+!E3 U+00E3 atilde
+!E5 U+00E5 aring
+!E6 U+00E6 ae
+!E8 U+00E8 egrave
+!E9 U+00E9 eacute
+!EC U+00EC igrave
+!ED U+00ED iacute
+!F0 U+011F gbreve
+!F1 U+00F1 ntilde
+!F2 U+00F2 ograve
+!F3 U+00F3 oacute
+!F5 U+00F5 otilde
+!F7 U+00F7 divide
+!F8 U+00F8 oslash
+!F9 U+00F9 ugrave
+!FA U+00FA uacute
+!FD U+0131 dotlessi
+!FE U+015F scedilla
Added: trunk/mapbender/http/extensions/fpdf/font/makefont/cp1255.map
--- trunk/mapbender/http/extensions/fpdf/font/makefont/cp1255.map	                        (rev 0)
+++ trunk/mapbender/http/extensions/fpdf/font/makefont/cp1255.map	2010-01-19 23:07:49 UTC (rev 5359)
@@ -0,0 +1,233 @@
+!00 U+0000 .notdef
+!01 U+0001 .notdef
+!02 U+0002 .notdef
+!03 U+0003 .notdef
+!04 U+0004 .notdef
+!05 U+0005 .notdef
+!06 U+0006 .notdef
+!07 U+0007 .notdef
+!08 U+0008 .notdef
+!09 U+0009 .notdef
+!0A U+000A .notdef
+!0B U+000B .notdef
+!0C U+000C .notdef
+!0D U+000D .notdef
+!0E U+000E .notdef
+!0F U+000F .notdef
+!10 U+0010 .notdef
+!11 U+0011 .notdef
+!12 U+0012 .notdef
+!13 U+0013 .notdef
+!14 U+0014 .notdef
+!15 U+0015 .notdef
+!16 U+0016 .notdef
+!17 U+0017 .notdef
+!18 U+0018 .notdef
+!19 U+0019 .notdef
+!1A U+001A .notdef
+!1B U+001B .notdef
+!1C U+001C .notdef
+!1D U+001D .notdef
+!1E U+001E .notdef
+!1F U+001F .notdef
+!20 U+0020 space
+!21 U+0021 exclam
+!24 U+0024 dollar
+!25 U+0025 percent
+!2B U+002B plus
+!2C U+002C comma
+!2D U+002D hyphen
+!2E U+002E period
+!2F U+002F slash
+!30 U+0030 zero
+!31 U+0031 one
+!32 U+0032 two
+!33 U+0033 three
+!34 U+0034 four
+!35 U+0035 five
+!36 U+0036 six
+!37 U+0037 seven
+!38 U+0038 eight
+!39 U+0039 nine
+!3A U+003A colon
+!3C U+003C less
+!3D U+003D equal
+!3E U+003E greater
+!40 U+0040 at
+!41 U+0041 A
+!42 U+0042 B
+!43 U+0043 C
+!44 U+0044 D
+!45 U+0045 E
+!46 U+0046 F
+!47 U+0047 G
+!48 U+0048 H
+!49 U+0049 I
+!4A U+004A J
+!4B U+004B K
+!4C U+004C L
+!4D U+004D M
+!4E U+004E N
+!4F U+004F O
+!50 U+0050 P
+!51 U+0051 Q
+!52 U+0052 R
+!53 U+0053 S
+!54 U+0054 T
+!55 U+0055 U
+!56 U+0056 V
+!57 U+0057 W
+!58 U+0058 X
+!59 U+0059 Y
+!5A U+005A Z
+!60 U+0060 grave
+!61 U+0061 a
+!62 U+0062 b
+!63 U+0063 c
+!64 U+0064 d
+!65 U+0065 e
+!66 U+0066 f
+!67 U+0067 g
+!68 U+0068 h
+!69 U+0069 i
+!6A U+006A j
+!6B U+006B k
+!6C U+006C l
+!6D U+006D m
+!6E U+006E n
+!6F U+006F o
+!70 U+0070 p
+!71 U+0071 q
+!72 U+0072 r
+!73 U+0073 s
+!74 U+0074 t
+!75 U+0075 u
+!76 U+0076 v
+!77 U+0077 w
+!78 U+0078 x
+!79 U+0079 y
+!7A U+007A z
+!7C U+007C bar
+!7F U+007F .notdef
+!80 U+20AC Euro
+!83 U+0192 florin
+!86 U+2020 dagger
+!95 U+2022 bullet
+!96 U+2013 endash
+!97 U+2014 emdash
+!98 U+02DC tilde
+!A0 U+00A0 space
+!A2 U+00A2 cent
+!A4 U+20AA afii57636
+!A5 U+00A5 yen
+!A7 U+00A7 section
+!AA U+00D7 multiply
+!AD U+00AD sfthyphen
+!AF U+00AF macron
+!B0 U+00B0 degree
+!B4 U+00B4 acute
+!B5 U+00B5 mu
+!B7 U+00B7 middot
+!B8 U+00B8 cedilla
+!BA U+00F7 divide
+!BD U+00BD onehalf
+!C0 U+05B0 afii57799
+!C1 U+05B1 afii57801
+!C2 U+05B2 afii57800
+!C3 U+05B3 afii57802
+!C4 U+05B4 afii57793
+!C5 U+05B5 afii57794
+!C6 U+05B6 afii57795
+!C7 U+05B7 afii57798
+!C8 U+05B8 afii57797
+!C9 U+05B9 afii57806
+!CB U+05BB afii57796
+!CC U+05BC afii57807
+!CD U+05BD afii57839
+!CE U+05BE afii57645
+!CF U+05BF afii57841
+!D0 U+05C0 afii57842
+!D1 U+05C1 afii57804
+!D2 U+05C2 afii57803
+!D3 U+05C3 afii57658
+!D4 U+05F0 afii57716
+!D5 U+05F1 afii57717
+!D6 U+05F2 afii57718
+!D7 U+05F3 gereshhebrew
+!D8 U+05F4 gershayimhebrew
+!E0 U+05D0 afii57664
+!E1 U+05D1 afii57665
+!E2 U+05D2 afii57666
+!E3 U+05D3 afii57667
+!E4 U+05D4 afii57668
+!E5 U+05D5 afii57669
+!E6 U+05D6 afii57670
+!E7 U+05D7 afii57671
+!E8 U+05D8 afii57672
+!E9 U+05D9 afii57673
+!EA U+05DA afii57674
+!EB U+05DB afii57675
+!EC U+05DC afii57676
+!ED U+05DD afii57677
+!EE U+05DE afii57678
+!EF U+05DF afii57679
+!F0 U+05E0 afii57680
+!F1 U+05E1 afii57681
+!F2 U+05E2 afii57682
+!F3 U+05E3 afii57683
+!F4 U+05E4 afii57684
+!F5 U+05E5 afii57685
+!F6 U+05E6 afii57686
+!F7 U+05E7 afii57687
+!F8 U+05E8 afii57688
+!F9 U+05E9 afii57689
+!FA U+05EA afii57690
+!FD U+200E afii299
+!FE U+200F afii300
Added: trunk/mapbender/http/extensions/fpdf/font/makefont/cp1257.map
--- trunk/mapbender/http/extensions/fpdf/font/makefont/cp1257.map	                        (rev 0)
+++ trunk/mapbender/http/extensions/fpdf/font/makefont/cp1257.map	2010-01-19 23:07:49 UTC (rev 5359)
@@ -0,0 +1,244 @@
+!00 U+0000 .notdef
+!01 U+0001 .notdef
+!02 U+0002 .notdef
+!03 U+0003 .notdef
+!04 U+0004 .notdef
+!05 U+0005 .notdef
+!06 U+0006 .notdef
+!07 U+0007 .notdef
+!08 U+0008 .notdef
+!09 U+0009 .notdef
+!0A U+000A .notdef
+!0B U+000B .notdef
+!0C U+000C .notdef
+!0D U+000D .notdef
+!0E U+000E .notdef
+!0F U+000F .notdef
+!10 U+0010 .notdef
+!11 U+0011 .notdef
+!12 U+0012 .notdef
+!13 U+0013 .notdef
+!14 U+0014 .notdef
+!15 U+0015 .notdef
+!16 U+0016 .notdef
+!17 U+0017 .notdef
+!18 U+0018 .notdef
+!19 U+0019 .notdef
+!1A U+001A .notdef
+!1B U+001B .notdef
+!1C U+001C .notdef
+!1D U+001D .notdef
+!1E U+001E .notdef
+!1F U+001F .notdef
+!20 U+0020 space
+!21 U+0021 exclam
+!24 U+0024 dollar
+!25 U+0025 percent
+!2B U+002B plus
+!2C U+002C comma
+!2D U+002D hyphen
+!2E U+002E period
+!2F U+002F slash
+!30 U+0030 zero
+!31 U+0031 one
+!32 U+0032 two
+!33 U+0033 three
+!34 U+0034 four
+!35 U+0035 five
+!36 U+0036 six
+!37 U+0037 seven
+!38 U+0038 eight
+!39 U+0039 nine
+!3A U+003A colon
+!3C U+003C less
+!3D U+003D equal
+!3E U+003E greater
+!40 U+0040 at
+!41 U+0041 A
+!42 U+0042 B
+!43 U+0043 C
+!44 U+0044 D
+!45 U+0045 E
+!46 U+0046 F
+!47 U+0047 G
+!48 U+0048 H
+!49 U+0049 I
+!4A U+004A J
+!4B U+004B K
+!4C U+004C L
+!4D U+004D M
+!4E U+004E N
+!4F U+004F O
+!50 U+0050 P
+!51 U+0051 Q
+!52 U+0052 R
+!53 U+0053 S
+!54 U+0054 T
+!55 U+0055 U
+!56 U+0056 V
+!57 U+0057 W
+!58 U+0058 X
+!59 U+0059 Y
+!5A U+005A Z
+!60 U+0060 grave
+!61 U+0061 a
+!62 U+0062 b
+!63 U+0063 c
+!64 U+0064 d
+!65 U+0065 e
+!66 U+0066 f
+!67 U+0067 g
+!68 U+0068 h
+!69 U+0069 i
+!6A U+006A j
+!6B U+006B k
+!6C U+006C l
+!6D U+006D m
+!6E U+006E n
+!6F U+006F o
+!70 U+0070 p
+!71 U+0071 q
+!72 U+0072 r
+!73 U+0073 s
+!74 U+0074 t
+!75 U+0075 u
+!76 U+0076 v
+!77 U+0077 w
+!78 U+0078 x
+!79 U+0079 y
+!7A U+007A z
+!7C U+007C bar
+!7F U+007F .notdef
+!80 U+20AC Euro
+!86 U+2020 dagger
+!8D U+00A8 dieresis
+!8E U+02C7 caron
+!8F U+00B8 cedilla
+!95 U+2022 bullet
+!96 U+2013 endash
+!97 U+2014 emdash
+!9D U+00AF macron
+!9E U+02DB ogonek
+!A0 U+00A0 space
+!A2 U+00A2 cent
+!A7 U+00A7 section
+!A8 U+00D8 Oslash
+!AA U+0156 Rcommaaccent
+!AD U+00AD hyphen
+!AF U+00C6 AE
+!B0 U+00B0 degree
+!B4 U+00B4 acute
+!B5 U+00B5 mu
+!B8 U+00F8 oslash
+!BA U+0157 rcommaaccent
+!BD U+00BD onehalf
+!BF U+00E6 ae
+!C0 U+0104 Aogonek
+!C1 U+012E Iogonek
+!C2 U+0100 Amacron
+!C3 U+0106 Cacute
+!C5 U+00C5 Aring
+!C6 U+0118 Eogonek
+!C7 U+0112 Emacron
+!C8 U+010C Ccaron
+!C9 U+00C9 Eacute
+!CA U+0179 Zacute
+!CB U+0116 Edotaccent
+!CC U+0122 Gcommaaccent
+!CD U+0136 Kcommaaccent
+!CE U+012A Imacron
+!CF U+013B Lcommaaccent
+!D0 U+0160 Scaron
+!D1 U+0143 Nacute
+!D2 U+0145 Ncommaaccent
+!D3 U+00D3 Oacute
+!D4 U+014C Omacron
+!D5 U+00D5 Otilde
+!D8 U+0172 Uogonek
+!D9 U+0141 Lslash
+!DA U+015A Sacute
+!DB U+016A Umacron
+!DD U+017B Zdotaccent
+!DE U+017D Zcaron
+!E0 U+0105 aogonek
+!E1 U+012F iogonek
+!E2 U+0101 amacron
+!E3 U+0107 cacute
+!E5 U+00E5 aring
+!E6 U+0119 eogonek
+!E7 U+0113 emacron
+!E8 U+010D ccaron
+!E9 U+00E9 eacute
+!EA U+017A zacute
+!EB U+0117 edotaccent
+!EC U+0123 gcommaaccent
+!ED U+0137 kcommaaccent
+!EE U+012B imacron
+!EF U+013C lcommaaccent
+!F0 U+0161 scaron
+!F1 U+0144 nacute
+!F2 U+0146 ncommaaccent
+!F3 U+00F3 oacute
+!F4 U+014D omacron
+!F5 U+00F5 otilde
+!F7 U+00F7 divide
+!F8 U+0173 uogonek
+!F9 U+0142 lslash
+!FA U+015B sacute
+!FB U+016B umacron
+!FD U+017C zdotaccent
+!FE U+017E zcaron
Added: trunk/mapbender/http/extensions/fpdf/font/makefont/cp1258.map
--- trunk/mapbender/http/extensions/fpdf/font/makefont/cp1258.map	                        (rev 0)
+++ trunk/mapbender/http/extensions/fpdf/font/makefont/cp1258.map	2010-01-19 23:07:49 UTC (rev 5359)
@@ -0,0 +1,247 @@
+!00 U+0000 .notdef
+!01 U+0001 .notdef
+!02 U+0002 .notdef
+!03 U+0003 .notdef
+!04 U+0004 .notdef
+!05 U+0005 .notdef
+!06 U+0006 .notdef
+!07 U+0007 .notdef
+!08 U+0008 .notdef
+!09 U+0009 .notdef
+!0A U+000A .notdef
+!0B U+000B .notdef
+!0C U+000C .notdef
+!0D U+000D .notdef
+!0E U+000E .notdef
+!0F U+000F .notdef
+!10 U+0010 .notdef
+!11 U+0011 .notdef
+!12 U+0012 .notdef
+!13 U+0013 .notdef
+!14 U+0014 .notdef
+!15 U+0015 .notdef
+!16 U+0016 .notdef
+!17 U+0017 .notdef
+!18 U+0018 .notdef
+!19 U+0019 .notdef
+!1A U+001A .notdef
+!1B U+001B .notdef
+!1C U+001C .notdef
+!1D U+001D .notdef
+!1E U+001E .notdef
+!1F U+001F .notdef
+!20 U+0020 space
+!21 U+0021 exclam
+!24 U+0024 dollar
+!25 U+0025 percent
+!2B U+002B plus
+!2C U+002C comma
+!2D U+002D hyphen
+!2E U+002E period
+!2F U+002F slash
+!30 U+0030 zero
+!31 U+0031 one
+!32 U+0032 two
+!33 U+0033 three
+!34 U+0034 four
+!35 U+0035 five
+!36 U+0036 six
+!37 U+0037 seven
+!38 U+0038 eight
+!39 U+0039 nine
+!3A U+003A colon
+!3C U+003C less
+!3D U+003D equal
+!3E U+003E greater
+!40 U+0040 at
+!41 U+0041 A
+!42 U+0042 B
+!43 U+0043 C
+!44 U+0044 D
+!45 U+0045 E
+!46 U+0046 F
+!47 U+0047 G
+!48 U+0048 H
+!49 U+0049 I
+!4A U+004A J
+!4B U+004B K
+!4C U+004C L
+!4D U+004D M
+!4E U+004E N
+!4F U+004F O
+!50 U+0050 P
+!51 U+0051 Q
+!52 U+0052 R
+!53 U+0053 S
+!54 U+0054 T
+!55 U+0055 U
+!56 U+0056 V
+!57 U+0057 W
+!58 U+0058 X
+!59 U+0059 Y
+!5A U+005A Z
+!60 U+0060 grave
+!61 U+0061 a
+!62 U+0062 b
+!63 U+0063 c
+!64 U+0064 d
+!65 U+0065 e
+!66 U+0066 f
+!67 U+0067 g
+!68 U+0068 h
+!69 U+0069 i
+!6A U+006A j
+!6B U+006B k
+!6C U+006C l
+!6D U+006D m
+!6E U+006E n
+!6F U+006F o
+!70 U+0070 p
+!71 U+0071 q
+!72 U+0072 r
+!73 U+0073 s
+!74 U+0074 t
+!75 U+0075 u
+!76 U+0076 v
+!77 U+0077 w
+!78 U+0078 x
+!79 U+0079 y
+!7A U+007A z
+!7C U+007C bar
+!7F U+007F .notdef
+!80 U+20AC Euro
+!83 U+0192 florin
+!86 U+2020 dagger
+!8C U+0152 OE
+!95 U+2022 bullet
+!96 U+2013 endash
+!97 U+2014 emdash
+!98 U+02DC tilde
+!9C U+0153 oe
+!A0 U+00A0 space
+!A2 U+00A2 cent
+!A5 U+00A5 yen
+!A7 U+00A7 section
+!AD U+00AD hyphen
+!AF U+00AF macron
+!B0 U+00B0 degree
+!B4 U+00B4 acute
+!B5 U+00B5 mu
+!B8 U+00B8 cedilla
+!BD U+00BD onehalf
+!C0 U+00C0 Agrave
+!C1 U+00C1 Aacute
+!C3 U+0102 Abreve
+!C5 U+00C5 Aring
+!C6 U+00C6 AE
+!C8 U+00C8 Egrave
+!C9 U+00C9 Eacute
+!CC U+0300 gravecomb
+!CD U+00CD Iacute
+!D0 U+0110 Dcroat
+!D1 U+00D1 Ntilde
+!D2 U+0309 hookabovecomb
+!D3 U+00D3 Oacute
+!D5 U+01A0 Ohorn
+!D8 U+00D8 Oslash
+!D9 U+00D9 Ugrave
+!DA U+00DA Uacute
+!DD U+01AF Uhorn
+!DE U+0303 tildecomb
+!E0 U+00E0 agrave
+!E1 U+00E1 aacute
+!E3 U+0103 abreve
+!E5 U+00E5 aring
+!E6 U+00E6 ae
+!E8 U+00E8 egrave
+!E9 U+00E9 eacute
+!EC U+0301 acutecomb
+!ED U+00ED iacute
+!F0 U+0111 dcroat
+!F1 U+00F1 ntilde
+!F2 U+0323 dotbelowcomb
+!F3 U+00F3 oacute
+!F5 U+01A1 ohorn
+!F7 U+00F7 divide
+!F8 U+00F8 oslash
+!F9 U+00F9 ugrave
+!FA U+00FA uacute
+!FD U+01B0 uhorn
+!FE U+20AB dong
Added: trunk/mapbender/http/extensions/fpdf/font/makefont/cp874.map
--- trunk/mapbender/http/extensions/fpdf/font/makefont/cp874.map	                        (rev 0)
+++ trunk/mapbender/http/extensions/fpdf/font/makefont/cp874.map	2010-01-19 23:07:49 UTC (rev 5359)
@@ -0,0 +1,225 @@
+!00 U+0000 .notdef
+!01 U+0001 .notdef
+!02 U+0002 .notdef
+!03 U+0003 .notdef
+!04 U+0004 .notdef
+!05 U+0005 .notdef
+!06 U+0006 .notdef
+!07 U+0007 .notdef
+!08 U+0008 .notdef
+!09 U+0009 .notdef
+!0A U+000A .notdef
+!0B U+000B .notdef
+!0C U+000C .notdef
+!0D U+000D .notdef
+!0E U+000E .notdef
+!0F U+000F .notdef
+!10 U+0010 .notdef
+!11 U+0011 .notdef
+!12 U+0012 .notdef
+!13 U+0013 .notdef
+!14 U+0014 .notdef
+!15 U+0015 .notdef
+!16 U+0016 .notdef
+!17 U+0017 .notdef
+!18 U+0018 .notdef
+!19 U+0019 .notdef
+!1A U+001A .notdef
+!1B U+001B .notdef
+!1C U+001C .notdef
+!1D U+001D .notdef
+!1E U+001E .notdef
+!1F U+001F .notdef
+!20 U+0020 space
+!21 U+0021 exclam
+!24 U+0024 dollar
+!25 U+0025 percent
+!2B U+002B plus
+!2C U+002C comma
+!2D U+002D hyphen
+!2E U+002E period
+!2F U+002F slash
+!30 U+0030 zero
+!31 U+0031 one
+!32 U+0032 two
+!33 U+0033 three
+!34 U+0034 four
+!35 U+0035 five
+!36 U+0036 six
+!37 U+0037 seven
+!38 U+0038 eight
+!39 U+0039 nine
+!3A U+003A colon
+!3C U+003C less
+!3D U+003D equal
+!3E U+003E greater
+!40 U+0040 at
+!41 U+0041 A
+!42 U+0042 B
+!43 U+0043 C
+!44 U+0044 D
+!45 U+0045 E
+!46 U+0046 F
+!47 U+0047 G
+!48 U+0048 H
+!49 U+0049 I
+!4A U+004A J
+!4B U+004B K
+!4C U+004C L
+!4D U+004D M
+!4E U+004E N
+!4F U+004F O
+!50 U+0050 P
+!51 U+0051 Q
+!52 U+0052 R
+!53 U+0053 S
+!54 U+0054 T
+!55 U+0055 U
+!56 U+0056 V
+!57 U+0057 W
+!58 U+0058 X
+!59 U+0059 Y
+!5A U+005A Z
+!60 U+0060 grave
+!61 U+0061 a
+!62 U+0062 b
+!63 U+0063 c
+!64 U+0064 d
+!65 U+0065 e
+!66 U+0066 f
+!67 U+0067 g
+!68 U+0068 h
+!69 U+0069 i
+!6A U+006A j
+!6B U+006B k
+!6C U+006C l
+!6D U+006D m
+!6E U+006E n
+!6F U+006F o
+!70 U+0070 p
+!71 U+0071 q
+!72 U+0072 r
+!73 U+0073 s
+!74 U+0074 t
+!75 U+0075 u
+!76 U+0076 v
+!77 U+0077 w
+!78 U+0078 x
+!79 U+0079 y
+!7A U+007A z
+!7C U+007C bar
+!7F U+007F .notdef
+!80 U+20AC Euro
+!95 U+2022 bullet
+!96 U+2013 endash
+!97 U+2014 emdash
+!A0 U+00A0 space
+!A1 U+0E01 kokaithai
+!A2 U+0E02 khokhaithai
+!A3 U+0E03 khokhuatthai
+!A4 U+0E04 khokhwaithai
+!A5 U+0E05 khokhonthai
+!A6 U+0E06 khorakhangthai
+!A7 U+0E07 ngonguthai
+!A8 U+0E08 chochanthai
+!A9 U+0E09 chochingthai
+!AA U+0E0A chochangthai
+!AB U+0E0B sosothai
+!AC U+0E0C chochoethai
+!AD U+0E0D yoyingthai
+!AE U+0E0E dochadathai
+!AF U+0E0F topatakthai
+!B0 U+0E10 thothanthai
+!B1 U+0E11 thonangmonthothai
+!B2 U+0E12 thophuthaothai
+!B3 U+0E13 nonenthai
+!B4 U+0E14 dodekthai
+!B5 U+0E15 totaothai
+!B6 U+0E16 thothungthai
+!B7 U+0E17 thothahanthai
+!B8 U+0E18 thothongthai
+!B9 U+0E19 nonuthai
+!BA U+0E1A bobaimaithai
+!BB U+0E1B poplathai
+!BC U+0E1C phophungthai
+!BD U+0E1D fofathai
+!BE U+0E1E phophanthai
+!BF U+0E1F fofanthai
+!C0 U+0E20 phosamphaothai
+!C1 U+0E21 momathai
+!C2 U+0E22 yoyakthai
+!C3 U+0E23 roruathai
+!C4 U+0E24 ruthai
+!C5 U+0E25 lolingthai
+!C6 U+0E26 luthai
+!C7 U+0E27 wowaenthai
+!C8 U+0E28 sosalathai
+!C9 U+0E29 sorusithai
+!CA U+0E2A sosuathai
+!CB U+0E2B hohipthai
+!CC U+0E2C lochulathai
+!CD U+0E2D oangthai
+!CE U+0E2E honokhukthai
+!CF U+0E2F paiyannoithai
+!D0 U+0E30 saraathai
+!D1 U+0E31 maihanakatthai
+!D2 U+0E32 saraaathai
+!D3 U+0E33 saraamthai
+!D4 U+0E34 saraithai
+!D5 U+0E35 saraiithai
+!D6 U+0E36 sarauethai
+!D7 U+0E37 saraueethai
+!D8 U+0E38 sarauthai
+!D9 U+0E39 sarauuthai
+!DA U+0E3A phinthuthai
+!DF U+0E3F bahtthai
+!E0 U+0E40 saraethai
+!E1 U+0E41 saraaethai
+!E2 U+0E42 saraothai
+!E3 U+0E43 saraaimaimuanthai
+!E4 U+0E44 saraaimaimalaithai
+!E5 U+0E45 lakkhangyaothai
+!E6 U+0E46 maiyamokthai
+!E7 U+0E47 maitaikhuthai
+!E8 U+0E48 maiekthai
+!E9 U+0E49 maithothai
+!EA U+0E4A maitrithai
+!EB U+0E4B maichattawathai
+!EC U+0E4C thanthakhatthai
+!ED U+0E4D nikhahitthai
+!EE U+0E4E yamakkanthai
+!EF U+0E4F fongmanthai
+!F0 U+0E50 zerothai
+!F1 U+0E51 onethai
+!F2 U+0E52 twothai
+!F3 U+0E53 threethai
+!F4 U+0E54 fourthai
+!F5 U+0E55 fivethai
+!F6 U+0E56 sixthai
+!F7 U+0E57 seventhai
+!F8 U+0E58 eightthai
+!F9 U+0E59 ninethai
+!FA U+0E5A angkhankhuthai
+!FB U+0E5B khomutthai
Added: trunk/mapbender/http/extensions/fpdf/font/makefont/iso-8859-1.map
--- trunk/mapbender/http/extensions/fpdf/font/makefont/iso-8859-1.map	                        (rev 0)
+++ trunk/mapbender/http/extensions/fpdf/font/makefont/iso-8859-1.map	2010-01-19 23:07:49 UTC (rev 5359)
@@ -0,0 +1,256 @@
+!00 U+0000 .notdef
+!01 U+0001 .notdef
+!02 U+0002 .notdef
+!03 U+0003 .notdef
+!04 U+0004 .notdef
+!05 U+0005 .notdef
+!06 U+0006 .notdef
+!07 U+0007 .notdef
+!08 U+0008 .notdef
+!09 U+0009 .notdef
+!0A U+000A .notdef
+!0B U+000B .notdef
+!0C U+000C .notdef
+!0D U+000D .notdef
+!0E U+000E .notdef
+!0F U+000F .notdef
+!10 U+0010 .notdef
+!11 U+0011 .notdef
+!12 U+0012 .notdef
+!13 U+0013 .notdef
+!14 U+0014 .notdef
+!15 U+0015 .notdef
+!16 U+0016 .notdef
+!17 U+0017 .notdef
+!18 U+0018 .notdef
+!19 U+0019 .notdef
+!1A U+001A .notdef
+!1B U+001B .notdef
+!1C U+001C .notdef
+!1D U+001D .notdef
+!1E U+001E .notdef
+!1F U+001F .notdef
+!20 U+0020 space
+!21 U+0021 exclam
+!24 U+0024 dollar
+!25 U+0025 percent
+!2B U+002B plus
+!2C U+002C comma
+!2D U+002D hyphen
+!2E U+002E period
+!2F U+002F slash
+!30 U+0030 zero
+!31 U+0031 one
+!32 U+0032 two
+!33 U+0033 three
+!34 U+0034 four
+!35 U+0035 five
+!36 U+0036 six
+!37 U+0037 seven
+!38 U+0038 eight
+!39 U+0039 nine
+!3A U+003A colon
+!3C U+003C less
+!3D U+003D equal
+!3E U+003E greater
+!40 U+0040 at
+!41 U+0041 A
+!42 U+0042 B
+!43 U+0043 C
+!44 U+0044 D
+!45 U+0045 E
+!46 U+0046 F
+!47 U+0047 G
+!48 U+0048 H
+!49 U+0049 I
+!4A U+004A J
+!4B U+004B K
+!4C U+004C L
+!4D U+004D M
+!4E U+004E N
+!4F U+004F O
+!50 U+0050 P
+!51 U+0051 Q
+!52 U+0052 R
+!53 U+0053 S
+!54 U+0054 T
+!55 U+0055 U
+!56 U+0056 V
+!57 U+0057 W
+!58 U+0058 X
+!59 U+0059 Y
+!5A U+005A Z
+!60 U+0060 grave
+!61 U+0061 a
+!62 U+0062 b
+!63 U+0063 c
+!64 U+0064 d
+!65 U+0065 e
+!66 U+0066 f
+!67 U+0067 g
+!68 U+0068 h
+!69 U+0069 i
+!6A U+006A j
+!6B U+006B k
+!6C U+006C l
+!6D U+006D m
+!6E U+006E n
+!6F U+006F o
+!70 U+0070 p
+!71 U+0071 q
+!72 U+0072 r
+!73 U+0073 s
+!74 U+0074 t
+!75 U+0075 u
+!76 U+0076 v
+!77 U+0077 w
+!78 U+0078 x
+!79 U+0079 y
+!7A U+007A z
+!7C U+007C bar
+!7F U+007F .notdef
+!80 U+0080 .notdef
+!81 U+0081 .notdef
+!82 U+0082 .notdef
+!83 U+0083 .notdef
+!84 U+0084 .notdef
+!85 U+0085 .notdef
+!86 U+0086 .notdef
+!87 U+0087 .notdef
+!88 U+0088 .notdef
+!89 U+0089 .notdef
+!8A U+008A .notdef
+!8B U+008B .notdef
+!8C U+008C .notdef
+!8D U+008D .notdef
+!8E U+008E .notdef
+!8F U+008F .notdef
+!90 U+0090 .notdef
+!91 U+0091 .notdef
+!92 U+0092 .notdef
+!93 U+0093 .notdef
+!94 U+0094 .notdef
+!95 U+0095 .notdef
+!96 U+0096 .notdef
+!97 U+0097 .notdef
+!98 U+0098 .notdef
+!99 U+0099 .notdef
+!9A U+009A .notdef
+!9B U+009B .notdef
+!9C U+009C .notdef
+!9D U+009D .notdef
+!9E U+009E .notdef
+!9F U+009F .notdef
+!A0 U+00A0 space
+!A2 U+00A2 cent
+!A5 U+00A5 yen
+!A7 U+00A7 section
+!AD U+00AD hyphen
+!AF U+00AF macron
+!B0 U+00B0 degree
+!B4 U+00B4 acute
+!B5 U+00B5 mu
+!B8 U+00B8 cedilla
+!BD U+00BD onehalf
+!C0 U+00C0 Agrave
+!C1 U+00C1 Aacute
+!C3 U+00C3 Atilde
+!C5 U+00C5 Aring
+!C6 U+00C6 AE
+!C8 U+00C8 Egrave
+!C9 U+00C9 Eacute
+!CC U+00CC Igrave
+!CD U+00CD Iacute
+!D0 U+00D0 Eth
+!D1 U+00D1 Ntilde
+!D2 U+00D2 Ograve
+!D3 U+00D3 Oacute
+!D5 U+00D5 Otilde
+!D8 U+00D8 Oslash
+!D9 U+00D9 Ugrave
+!DA U+00DA Uacute
+!DD U+00DD Yacute
+!DE U+00DE Thorn
+!E0 U+00E0 agrave
+!E1 U+00E1 aacute
+!E3 U+00E3 atilde
+!E5 U+00E5 aring
+!E6 U+00E6 ae
+!E8 U+00E8 egrave
+!E9 U+00E9 eacute
+!EC U+00EC igrave
+!ED U+00ED iacute
+!F0 U+00F0 eth
+!F1 U+00F1 ntilde
+!F2 U+00F2 ograve
+!F3 U+00F3 oacute
+!F5 U+00F5 otilde
+!F7 U+00F7 divide
+!F8 U+00F8 oslash
+!F9 U+00F9 ugrave
+!FA U+00FA uacute
+!FD U+00FD yacute
+!FE U+00FE thorn
Added: trunk/mapbender/http/extensions/fpdf/font/makefont/iso-8859-11.map
--- trunk/mapbender/http/extensions/fpdf/font/makefont/iso-8859-11.map	                        (rev 0)
+++ trunk/mapbender/http/extensions/fpdf/font/makefont/iso-8859-11.map	2010-01-19 23:07:49 UTC (rev 5359)
@@ -0,0 +1,248 @@
+!00 U+0000 .notdef
+!01 U+0001 .notdef
+!02 U+0002 .notdef
+!03 U+0003 .notdef
+!04 U+0004 .notdef
+!05 U+0005 .notdef
+!06 U+0006 .notdef
+!07 U+0007 .notdef
+!08 U+0008 .notdef
+!09 U+0009 .notdef
+!0A U+000A .notdef
+!0B U+000B .notdef
+!0C U+000C .notdef
+!0D U+000D .notdef
+!0E U+000E .notdef
+!0F U+000F .notdef
+!10 U+0010 .notdef
+!11 U+0011 .notdef
+!12 U+0012 .notdef
+!13 U+0013 .notdef
+!14 U+0014 .notdef
+!15 U+0015 .notdef
+!16 U+0016 .notdef
+!17 U+0017 .notdef
+!18 U+0018 .notdef
+!19 U+0019 .notdef
+!1A U+001A .notdef
+!1B U+001B .notdef
+!1C U+001C .notdef
+!1D U+001D .notdef
+!1E U+001E .notdef
+!1F U+001F .notdef
+!20 U+0020 space
+!21 U+0021 exclam
+!24 U+0024 dollar
+!25 U+0025 percent
+!2B U+002B plus
+!2C U+002C comma
+!2D U+002D hyphen
+!2E U+002E period
+!2F U+002F slash
+!30 U+0030 zero
+!31 U+0031 one
+!32 U+0032 two
+!33 U+0033 three
+!34 U+0034 four
+!35 U+0035 five
+!36 U+0036 six
+!37 U+0037 seven
+!38 U+0038 eight
+!39 U+0039 nine
+!3A U+003A colon
+!3C U+003C less
+!3D U+003D equal
+!3E U+003E greater
+!40 U+0040 at
+!41 U+0041 A
+!42 U+0042 B
+!43 U+0043 C
+!44 U+0044 D
+!45 U+0045 E
+!46 U+0046 F
+!47 U+0047 G
+!48 U+0048 H
+!49 U+0049 I
+!4A U+004A J
+!4B U+004B K
+!4C U+004C L
+!4D U+004D M
+!4E U+004E N
+!4F U+004F O
+!50 U+0050 P
+!51 U+0051 Q
+!52 U+0052 R
+!53 U+0053 S
+!54 U+0054 T
+!55 U+0055 U
+!56 U+0056 V
+!57 U+0057 W
+!58 U+0058 X
+!59 U+0059 Y
+!5A U+005A Z
+!60 U+0060 grave
+!61 U+0061 a
+!62 U+0062 b
+!63 U+0063 c
+!64 U+0064 d
+!65 U+0065 e
+!66 U+0066 f
+!67 U+0067 g
+!68 U+0068 h
+!69 U+0069 i
+!6A U+006A j
+!6B U+006B k
+!6C U+006C l
+!6D U+006D m
+!6E U+006E n
+!6F U+006F o
+!70 U+0070 p
+!71 U+0071 q
+!72 U+0072 r
+!73 U+0073 s
+!74 U+0074 t
+!75 U+0075 u
+!76 U+0076 v
+!77 U+0077 w
+!78 U+0078 x
+!79 U+0079 y
+!7A U+007A z
+!7C U+007C bar
+!7F U+007F .notdef
+!80 U+0080 .notdef
+!81 U+0081 .notdef
+!82 U+0082 .notdef
+!83 U+0083 .notdef
+!84 U+0084 .notdef
+!85 U+0085 .notdef
+!86 U+0086 .notdef
+!87 U+0087 .notdef
+!88 U+0088 .notdef
+!89 U+0089 .notdef
+!8A U+008A .notdef
+!8B U+008B .notdef
+!8C U+008C .notdef
+!8D U+008D .notdef
+!8E U+008E .notdef
+!8F U+008F .notdef
+!90 U+0090 .notdef
+!91 U+0091 .notdef
+!92 U+0092 .notdef
+!93 U+0093 .notdef
+!94 U+0094 .notdef
+!95 U+0095 .notdef
+!96 U+0096 .notdef
+!97 U+0097 .notdef
+!98 U+0098 .notdef
+!99 U+0099 .notdef
+!9A U+009A .notdef
+!9B U+009B .notdef
+!9C U+009C .notdef
+!9D U+009D .notdef
+!9E U+009E .notdef
+!9F U+009F .notdef
+!A0 U+00A0 space
+!C4 U+0E24 ruthai
+!C6 U+0E26 luthai
+!F1 U+0E51 onethai
+!F2 U+0E52 twothai
+!F6 U+0E56 sixthai
Added: trunk/mapbender/http/extensions/fpdf/font/makefont/iso-8859-15.map
--- trunk/mapbender/http/extensions/fpdf/font/makefont/iso-8859-15.map	                        (rev 0)
+++ trunk/mapbender/http/extensions/fpdf/font/makefont/iso-8859-15.map	2010-01-19 23:07:49 UTC (rev 5359)
@@ -0,0 +1,256 @@
+!00 U+0000 .notdef
+!01 U+0001 .notdef
+!02 U+0002 .notdef
+!03 U+0003 .notdef
+!04 U+0004 .notdef
+!05 U+0005 .notdef
+!06 U+0006 .notdef
+!07 U+0007 .notdef
+!08 U+0008 .notdef
+!09 U+0009 .notdef
+!0A U+000A .notdef
+!0B U+000B .notdef
+!0C U+000C .notdef
+!0D U+000D .notdef
+!0E U+000E .notdef
+!0F U+000F .notdef
+!10 U+0010 .notdef
+!11 U+0011 .notdef
+!12 U+0012 .notdef
+!13 U+0013 .notdef
+!14 U+0014 .notdef
+!15 U+0015 .notdef
+!16 U+0016 .notdef
+!17 U+0017 .notdef
+!18 U+0018 .notdef
+!19 U+0019 .notdef
+!1A U+001A .notdef
+!1B U+001B .notdef
+!1C U+001C .notdef
+!1D U+001D .notdef
+!1E U+001E .notdef
+!1F U+001F .notdef
+!20 U+0020 space
+!21 U+0021 exclam
+!24 U+0024 dollar
+!25 U+0025 percent
+!2B U+002B plus
+!2C U+002C comma
+!2D U+002D hyphen
+!2E U+002E period
+!2F U+002F slash
+!30 U+0030 zero
+!31 U+0031 one
+!32 U+0032 two
+!33 U+0033 three
+!34 U+0034 four
+!35 U+0035 five
+!36 U+0036 six
+!37 U+0037 seven
+!38 U+0038 eight
+!39 U+0039 nine
+!3A U+003A colon
+!3C U+003C less
+!3D U+003D equal
+!3E U+003E greater
+!40 U+0040 at
+!41 U+0041 A
+!42 U+0042 B
+!43 U+0043 C
+!44 U+0044 D
+!45 U+0045 E
+!46 U+0046 F
+!47 U+0047 G
+!48 U+0048 H
+!49 U+0049 I
+!4A U+004A J
+!4B U+004B K
+!4C U+004C L
+!4D U+004D M
+!4E U+004E N
+!4F U+004F O
+!50 U+0050 P
+!51 U+0051 Q
+!52 U+0052 R
+!53 U+0053 S
+!54 U+0054 T
+!55 U+0055 U
+!56 U+0056 V
+!57 U+0057 W
+!58 U+0058 X
+!59 U+0059 Y
+!5A U+005A Z
+!60 U+0060 grave
+!61 U+0061 a
+!62 U+0062 b
+!63 U+0063 c
+!64 U+0064 d
+!65 U+0065 e
+!66 U+0066 f
+!67 U+0067 g
+!68 U+0068 h
+!69 U+0069 i
+!6A U+006A j
+!6B U+006B k
+!6C U+006C l
+!6D U+006D m
+!6E U+006E n
+!6F U+006F o
+!70 U+0070 p
+!71 U+0071 q
+!72 U+0072 r
+!73 U+0073 s
+!74 U+0074 t
+!75 U+0075 u
+!76 U+0076 v
+!77 U+0077 w
+!78 U+0078 x
+!79 U+0079 y
+!7A U+007A z
+!7C U+007C bar
+!7F U+007F .notdef
+!80 U+0080 .notdef
+!81 U+0081 .notdef
+!82 U+0082 .notdef
+!83 U+0083 .notdef
+!84 U+0084 .notdef
+!85 U+0085 .notdef
+!86 U+0086 .notdef
+!87 U+0087 .notdef
+!88 U+0088 .notdef
+!89 U+0089 .notdef
+!8A U+008A .notdef
+!8B U+008B .notdef
+!8C U+008C .notdef
+!8D U+008D .notdef
+!8E U+008E .notdef
+!8F U+008F .notdef
+!90 U+0090 .notdef
+!91 U+0091 .notdef
+!92 U+0092 .notdef
+!93 U+0093 .notdef
+!94 U+0094 .notdef
+!95 U+0095 .notdef
+!96 U+0096 .notdef
+!97 U+0097 .notdef
+!98 U+0098 .notdef
+!99 U+0099 .notdef
+!9A U+009A .notdef
+!9B U+009B .notdef
+!9C U+009C .notdef
+!9D U+009D .notdef
+!9E U+009E .notdef
+!9F U+009F .notdef
+!A0 U+00A0 space
+!A2 U+00A2 cent
+!A4 U+20AC Euro
+!A5 U+00A5 yen
+!A6 U+0160 Scaron
+!A7 U+00A7 section
+!A8 U+0161 scaron
+!AD U+00AD hyphen
+!AF U+00AF macron
+!B0 U+00B0 degree
+!B4 U+017D Zcaron
+!B5 U+00B5 mu
+!B8 U+017E zcaron
+!BC U+0152 OE
+!BD U+0153 oe
+!BE U+0178 Ydieresis
+!C0 U+00C0 Agrave
+!C1 U+00C1 Aacute
+!C3 U+00C3 Atilde
+!C5 U+00C5 Aring
+!C6 U+00C6 AE
+!C8 U+00C8 Egrave
+!C9 U+00C9 Eacute
+!CC U+00CC Igrave
+!CD U+00CD Iacute
+!D0 U+00D0 Eth
+!D1 U+00D1 Ntilde
+!D2 U+00D2 Ograve
+!D3 U+00D3 Oacute
+!D5 U+00D5 Otilde
+!D8 U+00D8 Oslash
+!D9 U+00D9 Ugrave
+!DA U+00DA Uacute
+!DD U+00DD Yacute
+!DE U+00DE Thorn
+!E0 U+00E0 agrave
+!E1 U+00E1 aacute
+!E3 U+00E3 atilde
+!E5 U+00E5 aring
+!E6 U+00E6 ae
+!E8 U+00E8 egrave
+!E9 U+00E9 eacute
+!EC U+00EC igrave
+!ED U+00ED iacute
+!F0 U+00F0 eth
+!F1 U+00F1 ntilde
+!F2 U+00F2 ograve
+!F3 U+00F3 oacute
+!F5 U+00F5 otilde
+!F7 U+00F7 divide
+!F8 U+00F8 oslash
+!F9 U+00F9 ugrave
+!FA U+00FA uacute
+!FD U+00FD yacute
+!FE U+00FE thorn
Added: trunk/mapbender/http/extensions/fpdf/font/makefont/iso-8859-16.map
--- trunk/mapbender/http/extensions/fpdf/font/makefont/iso-8859-16.map	                        (rev 0)
+++ trunk/mapbender/http/extensions/fpdf/font/makefont/iso-8859-16.map	2010-01-19 23:07:49 UTC (rev 5359)
@@ -0,0 +1,256 @@
+!00 U+0000 .notdef
+!01 U+0001 .notdef
+!02 U+0002 .notdef
+!03 U+0003 .notdef
+!04 U+0004 .notdef
+!05 U+0005 .notdef
+!06 U+0006 .notdef
+!07 U+0007 .notdef
+!08 U+0008 .notdef
+!09 U+0009 .notdef
+!0A U+000A .notdef
+!0B U+000B .notdef
+!0C U+000C .notdef
+!0D U+000D .notdef
+!0E U+000E .notdef
+!0F U+000F .notdef
+!10 U+0010 .notdef
+!11 U+0011 .notdef
+!12 U+0012 .notdef
+!13 U+0013 .notdef
+!14 U+0014 .notdef
+!15 U+0015 .notdef
+!16 U+0016 .notdef
+!17 U+0017 .notdef
+!18 U+0018 .notdef
+!19 U+0019 .notdef
+!1A U+001A .notdef
+!1B U+001B .notdef
+!1C U+001C .notdef
+!1D U+001D .notdef
+!1E U+001E .notdef
+!1F U+001F .notdef
+!20 U+0020 space
+!21 U+0021 exclam
+!24 U+0024 dollar
+!25 U+0025 percent
+!2B U+002B plus
+!2C U+002C comma
+!2D U+002D hyphen
+!2E U+002E period
+!2F U+002F slash
+!30 U+0030 zero
+!31 U+0031 one
+!32 U+0032 two
+!33 U+0033 three
+!34 U+0034 four
+!35 U+0035 five
+!36 U+0036 six
+!37 U+0037 seven
+!38 U+0038 eight
+!39 U+0039 nine
+!3A U+003A colon
+!3C U+003C less
+!3D U+003D equal
+!3E U+003E greater
+!40 U+0040 at
+!41 U+0041 A
+!42 U+0042 B
+!43 U+0043 C
+!44 U+0044 D
+!45 U+0045 E
+!46 U+0046 F
+!47 U+0047 G
+!48 U+0048 H
+!49 U+0049 I
+!4A U+004A J
+!4B U+004B K
+!4C U+004C L
+!4D U+004D M
+!4E U+004E N
+!4F U+004F O
+!50 U+0050 P
+!51 U+0051 Q
+!52 U+0052 R
+!53 U+0053 S
+!54 U+0054 T
+!55 U+0055 U
+!56 U+0056 V
+!57 U+0057 W
+!58 U+0058 X
+!59 U+0059 Y
+!5A U+005A Z
+!60 U+0060 grave
+!61 U+0061 a
+!62 U+0062 b
+!63 U+0063 c
+!64 U+0064 d
+!65 U+0065 e
+!66 U+0066 f
+!67 U+0067 g
+!68 U+0068 h
+!69 U+0069 i
+!6A U+006A j
+!6B U+006B k
+!6C U+006C l
+!6D U+006D m
+!6E U+006E n
+!6F U+006F o
+!70 U+0070 p
+!71 U+0071 q
+!72 U+0072 r
+!73 U+0073 s
+!74 U+0074 t
+!75 U+0075 u
+!76 U+0076 v
+!77 U+0077 w
+!78 U+0078 x
+!79 U+0079 y
+!7A U+007A z
+!7C U+007C bar
+!7F U+007F .notdef
+!80 U+0080 .notdef
+!81 U+0081 .notdef
+!82 U+0082 .notdef
+!83 U+0083 .notdef
+!84 U+0084 .notdef
+!85 U+0085 .notdef
+!86 U+0086 .notdef
+!87 U+0087 .notdef
+!88 U+0088 .notdef
+!89 U+0089 .notdef
+!8A U+008A .notdef
+!8B U+008B .notdef
+!8C U+008C .notdef
+!8D U+008D .notdef
+!8E U+008E .notdef
+!8F U+008F .notdef
+!90 U+0090 .notdef
+!91 U+0091 .notdef
+!92 U+0092 .notdef
+!93 U+0093 .notdef
+!94 U+0094 .notdef
+!95 U+0095 .notdef
+!96 U+0096 .notdef
+!97 U+0097 .notdef
+!98 U+0098 .notdef
+!99 U+0099 .notdef
+!9A U+009A .notdef
+!9B U+009B .notdef
+!9C U+009C .notdef
+!9D U+009D .notdef
+!9E U+009E .notdef
+!9F U+009F .notdef
+!A0 U+00A0 space
+!A1 U+0104 Aogonek
+!A2 U+0105 aogonek
+!A3 U+0141 Lslash
+!A4 U+20AC Euro
+!A5 U+201E quotedblbase
+!A6 U+0160 Scaron
+!A7 U+00A7 section
+!A8 U+0161 scaron
+!AA U+0218 Scommaaccent
+!AC U+0179 Zacute
+!AD U+00AD hyphen
+!AE U+017A zacute
+!B0 U+00B0 degree
+!B2 U+010C Ccaron
+!B3 U+0142 lslash
+!B4 U+017D Zcaron
+!B5 U+201D quotedblright
+!B8 U+017E zcaron
+!B9 U+010D ccaron
+!BA U+0219 scommaaccent
+!BC U+0152 OE
+!BD U+0153 oe
+!C0 U+00C0 Agrave
+!C1 U+00C1 Aacute
+!C3 U+0102 Abreve
+!C5 U+0106 Cacute
+!C6 U+00C6 AE
+!C8 U+00C8 Egrave
+!C9 U+00C9 Eacute
+!CC U+00CC Igrave
+!CD U+00CD Iacute
+!D0 U+0110 Dcroat
+!D1 U+0143 Nacute
+!D2 U+00D2 Ograve
+!D3 U+00D3 Oacute
+!D7 U+015A Sacute
+!D8 U+0170 Uhungarumlaut
+!D9 U+00D9 Ugrave
+!DA U+00DA Uacute
+!DD U+0118 Eogonek
+!DE U+021A Tcommaaccent
+!E0 U+00E0 agrave
+!E1 U+00E1 aacute
+!E3 U+0103 abreve
+!E5 U+0107 cacute
+!E6 U+00E6 ae
+!E8 U+00E8 egrave
+!E9 U+00E9 eacute
+!EC U+00EC igrave
+!ED U+00ED iacute
+!F0 U+0111 dcroat
+!F1 U+0144 nacute
+!F2 U+00F2 ograve
+!F3 U+00F3 oacute
+!F7 U+015B sacute
+!F8 U+0171 uhungarumlaut
+!F9 U+00F9 ugrave
+!FA U+00FA uacute
+!FD U+0119 eogonek
+!FE U+021B tcommaaccent
Added: trunk/mapbender/http/extensions/fpdf/font/makefont/iso-8859-2.map
--- trunk/mapbender/http/extensions/fpdf/font/makefont/iso-8859-2.map	                        (rev 0)
+++ trunk/mapbender/http/extensions/fpdf/font/makefont/iso-8859-2.map	2010-01-19 23:07:49 UTC (rev 5359)
@@ -0,0 +1,256 @@
+!00 U+0000 .notdef
+!01 U+0001 .notdef
+!02 U+0002 .notdef
+!03 U+0003 .notdef
+!04 U+0004 .notdef
+!05 U+0005 .notdef
+!06 U+0006 .notdef
+!07 U+0007 .notdef
+!08 U+0008 .notdef
+!09 U+0009 .notdef
+!0A U+000A .notdef
+!0B U+000B .notdef
+!0C U+000C .notdef
+!0D U+000D .notdef
+!0E U+000E .notdef
+!0F U+000F .notdef
+!10 U+0010 .notdef
+!11 U+0011 .notdef
+!12 U+0012 .notdef
+!13 U+0013 .notdef
+!14 U+0014 .notdef
+!15 U+0015 .notdef
+!16 U+0016 .notdef
+!17 U+0017 .notdef
+!18 U+0018 .notdef
+!19 U+0019 .notdef
+!1A U+001A .notdef
+!1B U+001B .notdef
+!1C U+001C .notdef
+!1D U+001D .notdef
+!1E U+001E .notdef
+!1F U+001F .notdef
+!20 U+0020 space
+!21 U+0021 exclam
+!24 U+0024 dollar
+!25 U+0025 percent
+!2B U+002B plus
+!2C U+002C comma
+!2D U+002D hyphen
+!2E U+002E period
+!2F U+002F slash
+!30 U+0030 zero
+!31 U+0031 one
+!32 U+0032 two
+!33 U+0033 three
+!34 U+0034 four
+!35 U+0035 five
+!36 U+0036 six
+!37 U+0037 seven
+!38 U+0038 eight
+!39 U+0039 nine
+!3A U+003A colon
+!3C U+003C less
+!3D U+003D equal
+!3E U+003E greater
+!40 U+0040 at
+!41 U+0041 A
+!42 U+0042 B
+!43 U+0043 C
+!44 U+0044 D
+!45 U+0045 E
+!46 U+0046 F
+!47 U+0047 G
+!48 U+0048 H
+!49 U+0049 I
+!4A U+004A J
+!4B U+004B K
+!4C U+004C L
+!4D U+004D M
+!4E U+004E N
+!4F U+004F O
+!50 U+0050 P
+!51 U+0051 Q
+!52 U+0052 R
+!53 U+0053 S
+!54 U+0054 T
+!55 U+0055 U
+!56 U+0056 V
+!57 U+0057 W
+!58 U+0058 X
+!59 U+0059 Y
+!5A U+005A Z
+!60 U+0060 grave
+!61 U+0061 a
+!62 U+0062 b
+!63 U+0063 c
+!64 U+0064 d
+!65 U+0065 e
+!66 U+0066 f
+!67 U+0067 g
+!68 U+0068 h
+!69 U+0069 i
+!6A U+006A j
+!6B U+006B k
+!6C U+006C l
+!6D U+006D m
+!6E U+006E n
+!6F U+006F o
+!70 U+0070 p
+!71 U+0071 q
+!72 U+0072 r
+!73 U+0073 s
+!74 U+0074 t
+!75 U+0075 u
+!76 U+0076 v
+!77 U+0077 w
+!78 U+0078 x
+!79 U+0079 y
+!7A U+007A z
+!7C U+007C bar
+!7F U+007F .notdef
+!80 U+0080 .notdef
+!81 U+0081 .notdef
+!82 U+0082 .notdef
+!83 U+0083 .notdef
+!84 U+0084 .notdef
+!85 U+0085 .notdef
+!86 U+0086 .notdef
+!87 U+0087 .notdef
+!88 U+0088 .notdef
+!89 U+0089 .notdef
+!8A U+008A .notdef
+!8B U+008B .notdef
+!8C U+008C .notdef
+!8D U+008D .notdef
+!8E U+008E .notdef
+!8F U+008F .notdef
+!90 U+0090 .notdef
+!91 U+0091 .notdef
+!92 U+0092 .notdef
+!93 U+0093 .notdef
+!94 U+0094 .notdef
+!95 U+0095 .notdef
+!96 U+0096 .notdef
+!97 U+0097 .notdef
+!98 U+0098 .notdef
+!99 U+0099 .notdef
+!9A U+009A .notdef
+!9B U+009B .notdef
+!9C U+009C .notdef
+!9D U+009D .notdef
+!9E U+009E .notdef
+!9F U+009F .notdef
+!A0 U+00A0 space
+!A1 U+0104 Aogonek
+!A2 U+02D8 breve
+!A3 U+0141 Lslash
+!A5 U+013D Lcaron
+!A6 U+015A Sacute
+!A7 U+00A7 section
+!A9 U+0160 Scaron
+!AB U+0164 Tcaron
+!AC U+0179 Zacute
+!AD U+00AD hyphen
+!AE U+017D Zcaron
+!B0 U+00B0 degree
+!B1 U+0105 aogonek
+!B2 U+02DB ogonek
+!B3 U+0142 lslash
+!B4 U+00B4 acute
+!B5 U+013E lcaron
+!B6 U+015B sacute
+!B7 U+02C7 caron
+!B8 U+00B8 cedilla
+!B9 U+0161 scaron
+!BB U+0165 tcaron
+!BC U+017A zacute
+!BE U+017E zcaron
+!C0 U+0154 Racute
+!C1 U+00C1 Aacute
+!C3 U+0102 Abreve
+!C5 U+0139 Lacute
+!C6 U+0106 Cacute
+!C8 U+010C Ccaron
+!C9 U+00C9 Eacute
+!CA U+0118 Eogonek
+!CC U+011A Ecaron
+!CD U+00CD Iacute
+!CF U+010E Dcaron
+!D0 U+0110 Dcroat
+!D1 U+0143 Nacute
+!D2 U+0147 Ncaron
+!D3 U+00D3 Oacute
+!D8 U+0158 Rcaron
+!D9 U+016E Uring
+!DA U+00DA Uacute
+!DD U+00DD Yacute
+!E0 U+0155 racute
+!E1 U+00E1 aacute
+!E3 U+0103 abreve
+!E5 U+013A lacute
+!E6 U+0107 cacute
+!E8 U+010D ccaron
+!E9 U+00E9 eacute
+!EA U+0119 eogonek
+!EC U+011B ecaron
+!ED U+00ED iacute
+!EF U+010F dcaron
+!F0 U+0111 dcroat
+!F1 U+0144 nacute
+!F2 U+0148 ncaron
+!F3 U+00F3 oacute
+!F7 U+00F7 divide
+!F8 U+0159 rcaron
+!F9 U+016F uring
+!FA U+00FA uacute
+!FD U+00FD yacute
Added: trunk/mapbender/http/extensions/fpdf/font/makefont/iso-8859-4.map
--- trunk/mapbender/http/extensions/fpdf/font/makefont/iso-8859-4.map	                        (rev 0)
+++ trunk/mapbender/http/extensions/fpdf/font/makefont/iso-8859-4.map	2010-01-19 23:07:49 UTC (rev 5359)
@@ -0,0 +1,256 @@
+!00 U+0000 .notdef
+!01 U+0001 .notdef
+!02 U+0002 .notdef
+!03 U+0003 .notdef
+!04 U+0004 .notdef
+!05 U+0005 .notdef
+!06 U+0006 .notdef
+!07 U+0007 .notdef
+!08 U+0008 .notdef
+!09 U+0009 .notdef
+!0A U+000A .notdef
+!0B U+000B .notdef
+!0C U+000C .notdef
+!0D U+000D .notdef
+!0E U+000E .notdef
+!0F U+000F .notdef
+!10 U+0010 .notdef
+!11 U+0011 .notdef
+!12 U+0012 .notdef
+!13 U+0013 .notdef
+!14 U+0014 .notdef
+!15 U+0015 .notdef
+!16 U+0016 .notdef
+!17 U+0017 .notdef
+!18 U+0018 .notdef
+!19 U+0019 .notdef
+!1A U+001A .notdef
+!1B U+001B .notdef
+!1C U+001C .notdef
+!1D U+001D .notdef
+!1E U+001E .notdef
+!1F U+001F .notdef
+!20 U+0020 space
+!21 U+0021 exclam
+!24 U+0024 dollar
+!25 U+0025 percent
+!2B U+002B plus
+!2C U+002C comma
+!2D U+002D hyphen
+!2E U+002E period
+!2F U+002F slash
+!30 U+0030 zero
+!31 U+0031 one
+!32 U+0032 two
+!33 U+0033 three
+!34 U+0034 four
+!35 U+0035 five
+!36 U+0036 six
+!37 U+0037 seven
+!38 U+0038 eight
+!39 U+0039 nine
+!3A U+003A colon
+!3C U+003C less
+!3D U+003D equal
+!3E U+003E greater
+!40 U+0040 at
+!41 U+0041 A
+!42 U+0042 B
+!43 U+0043 C
+!44 U+0044 D
+!45 U+0045 E
+!46 U+0046 F
+!47 U+0047 G
+!48 U+0048 H
+!49 U+0049 I
+!4A U+004A J
+!4B U+004B K
+!4C U+004C L
+!4D U+004D M
+!4E U+004E N
+!4F U+004F O
+!50 U+0050 P
+!51 U+0051 Q
+!52 U+0052 R
+!53 U+0053 S
+!54 U+0054 T
+!55 U+0055 U
+!56 U+0056 V
+!57 U+0057 W
+!58 U+0058 X
+!59 U+0059 Y
+!5A U+005A Z
+!60 U+0060 grave
+!61 U+0061 a
+!62 U+0062 b
+!63 U+0063 c
+!64 U+0064 d
+!65 U+0065 e
+!66 U+0066 f
+!67 U+0067 g
+!68 U+0068 h
+!69 U+0069 i
+!6A U+006A j
+!6B U+006B k
+!6C U+006C l
+!6D U+006D m
+!6E U+006E n
+!6F U+006F o
+!70 U+0070 p
+!71 U+0071 q
+!72 U+0072 r
+!73 U+0073 s
+!74 U+0074 t
+!75 U+0075 u
+!76 U+0076 v
+!77 U+0077 w
+!78 U+0078 x
+!79 U+0079 y
+!7A U+007A z
+!7C U+007C bar
+!7F U+007F .notdef
+!80 U+0080 .notdef
+!81 U+0081 .notdef
+!82 U+0082 .notdef
+!83 U+0083 .notdef
+!84 U+0084 .notdef
+!85 U+0085 .notdef
+!86 U+0086 .notdef
+!87 U+0087 .notdef
+!88 U+0088 .notdef
+!89 U+0089 .notdef
+!8A U+008A .notdef
+!8B U+008B .notdef
+!8C U+008C .notdef
+!8D U+008D .notdef
+!8E U+008E .notdef
+!8F U+008F .notdef
+!90 U+0090 .notdef
+!91 U+0091 .notdef
+!92 U+0092 .notdef
+!93 U+0093 .notdef
+!94 U+0094 .notdef
+!95 U+0095 .notdef
+!96 U+0096 .notdef
+!97 U+0097 .notdef
+!98 U+0098 .notdef
+!99 U+0099 .notdef
+!9A U+009A .notdef
+!9B U+009B .notdef
+!9C U+009C .notdef
+!9D U+009D .notdef
+!9E U+009E .notdef
+!9F U+009F .notdef
+!A0 U+00A0 space
+!A1 U+0104 Aogonek
+!A2 U+0138 kgreenlandic
+!A3 U+0156 Rcommaaccent
+!A5 U+0128 Itilde
+!A6 U+013B Lcommaaccent
+!A7 U+00A7 section
+!A9 U+0160 Scaron
+!AA U+0112 Emacron
+!AB U+0122 Gcommaaccent
+!AC U+0166 Tbar
+!AD U+00AD hyphen
+!AE U+017D Zcaron
+!AF U+00AF macron
+!B0 U+00B0 degree
+!B1 U+0105 aogonek
+!B2 U+02DB ogonek
+!B3 U+0157 rcommaaccent
+!B4 U+00B4 acute
+!B5 U+0129 itilde
+!B6 U+013C lcommaaccent
+!B7 U+02C7 caron
+!B8 U+00B8 cedilla
+!B9 U+0161 scaron
+!BA U+0113 emacron
+!BB U+0123 gcommaaccent
+!BC U+0167 tbar
+!BD U+014A Eng
+!BE U+017E zcaron
+!BF U+014B eng
+!C0 U+0100 Amacron
+!C1 U+00C1 Aacute
+!C3 U+00C3 Atilde
+!C5 U+00C5 Aring
+!C6 U+00C6 AE
+!C7 U+012E Iogonek
+!C8 U+010C Ccaron
+!C9 U+00C9 Eacute
+!CA U+0118 Eogonek
+!CC U+0116 Edotaccent
+!CD U+00CD Iacute
+!CF U+012A Imacron
+!D0 U+0110 Dcroat
+!D1 U+0145 Ncommaaccent
+!D2 U+014C Omacron
+!D3 U+0136 Kcommaaccent
+!D5 U+00D5 Otilde
+!D8 U+00D8 Oslash
+!D9 U+0172 Uogonek
+!DA U+00DA Uacute
+!DD U+0168 Utilde
+!DE U+016A Umacron
+!E0 U+0101 amacron
+!E1 U+00E1 aacute
+!E3 U+00E3 atilde
+!E5 U+00E5 aring
+!E6 U+00E6 ae
+!E7 U+012F iogonek
+!E8 U+010D ccaron
+!E9 U+00E9 eacute
+!EA U+0119 eogonek
+!EC U+0117 edotaccent
+!ED U+00ED iacute
+!EF U+012B imacron
+!F0 U+0111 dcroat
+!F1 U+0146 ncommaaccent
+!F2 U+014D omacron
+!F3 U+0137 kcommaaccent
+!F5 U+00F5 otilde
+!F7 U+00F7 divide
+!F8 U+00F8 oslash
+!F9 U+0173 uogonek
+!FA U+00FA uacute
+!FD U+0169 utilde
+!FE U+016B umacron
Added: trunk/mapbender/http/extensions/fpdf/font/makefont/iso-8859-5.map
--- trunk/mapbender/http/extensions/fpdf/font/makefont/iso-8859-5.map	                        (rev 0)
+++ trunk/mapbender/http/extensions/fpdf/font/makefont/iso-8859-5.map	2010-01-19 23:07:49 UTC (rev 5359)
@@ -0,0 +1,256 @@
+!00 U+0000 .notdef
+!01 U+0001 .notdef
+!02 U+0002 .notdef
+!03 U+0003 .notdef
+!04 U+0004 .notdef
+!05 U+0005 .notdef
+!06 U+0006 .notdef
+!07 U+0007 .notdef
+!08 U+0008 .notdef
+!09 U+0009 .notdef
+!0A U+000A .notdef
+!0B U+000B .notdef
+!0C U+000C .notdef
+!0D U+000D .notdef
+!0E U+000E .notdef
+!0F U+000F .notdef
+!10 U+0010 .notdef
+!11 U+0011 .notdef
+!12 U+0012 .notdef
+!13 U+0013 .notdef
+!14 U+0014 .notdef
+!15 U+0015 .notdef
+!16 U+0016 .notdef
+!17 U+0017 .notdef
+!18 U+0018 .notdef
+!19 U+0019 .notdef
+!1A U+001A .notdef
+!1B U+001B .notdef
+!1C U+001C .notdef
+!1D U+001D .notdef
+!1E U+001E .notdef
+!1F U+001F .notdef
+!20 U+0020 space
+!21 U+0021 exclam
+!24 U+0024 dollar
+!25 U+0025 percent
+!2B U+002B plus
+!2C U+002C comma
+!2D U+002D hyphen
+!2E U+002E period
+!2F U+002F slash
+!30 U+0030 zero
+!31 U+0031 one
+!32 U+0032 two
+!33 U+0033 three
+!34 U+0034 four
+!35 U+0035 five
+!36 U+0036 six
+!37 U+0037 seven
+!38 U+0038 eight
+!39 U+0039 nine
+!3A U+003A colon
+!3C U+003C less
+!3D U+003D equal
+!3E U+003E greater
+!40 U+0040 at
+!41 U+0041 A
+!42 U+0042 B
+!43 U+0043 C
+!44 U+0044 D
+!45 U+0045 E
+!46 U+0046 F
+!47 U+0047 G
+!48 U+0048 H
+!49 U+0049 I
+!4A U+004A J
+!4B U+004B K
+!4C U+004C L
+!4D U+004D M
+!4E U+004E N
+!4F U+004F O
+!50 U+0050 P
+!51 U+0051 Q
+!52 U+0052 R
+!53 U+0053 S
+!54 U+0054 T
+!55 U+0055 U
+!56 U+0056 V
+!57 U+0057 W
+!58 U+0058 X
+!59 U+0059 Y
+!5A U+005A Z
+!60 U+0060 grave
+!61 U+0061 a
+!62 U+0062 b
+!63 U+0063 c
+!64 U+0064 d
+!65 U+0065 e
+!66 U+0066 f
+!67 U+0067 g
+!68 U+0068 h
+!69 U+0069 i
+!6A U+006A j
+!6B U+006B k
+!6C U+006C l
+!6D U+006D m
+!6E U+006E n
+!6F U+006F o
+!70 U+0070 p
+!71 U+0071 q
+!72 U+0072 r
+!73 U+0073 s
+!74 U+0074 t
+!75 U+0075 u
+!76 U+0076 v
+!77 U+0077 w
+!78 U+0078 x
+!79 U+0079 y
+!7A U+007A z
+!7C U+007C bar
+!7F U+007F .notdef
+!80 U+0080 .notdef
+!81 U+0081 .notdef
+!82 U+0082 .notdef
+!83 U+0083 .notdef
+!84 U+0084 .notdef
+!85 U+0085 .notdef
+!86 U+0086 .notdef
+!87 U+0087 .notdef
+!88 U+0088 .notdef
+!89 U+0089 .notdef
+!8A U+008A .notdef
+!8B U+008B .notdef
+!8C U+008C .notdef
+!8D U+008D .notdef
+!8E U+008E .notdef
+!8F U+008F .notdef
+!90 U+0090 .notdef
+!91 U+0091 .notdef
+!92 U+0092 .notdef
+!93 U+0093 .notdef
+!94 U+0094 .notdef
+!95 U+0095 .notdef
+!96 U+0096 .notdef
+!97 U+0097 .notdef
+!98 U+0098 .notdef
+!99 U+0099 .notdef
+!9A U+009A .notdef
+!9B U+009B .notdef
+!9C U+009C .notdef
+!9D U+009D .notdef
+!9E U+009E .notdef
+!9F U+009F .notdef
+!A0 U+00A0 space
+!A1 U+0401 afii10023
+!A2 U+0402 afii10051
+!A3 U+0403 afii10052
+!A4 U+0404 afii10053
+!A5 U+0405 afii10054
+!A6 U+0406 afii10055
+!A7 U+0407 afii10056
+!A8 U+0408 afii10057
+!A9 U+0409 afii10058
+!AA U+040A afii10059
+!AB U+040B afii10060
+!AC U+040C afii10061
+!AD U+00AD hyphen
+!AE U+040E afii10062
+!AF U+040F afii10145
+!B0 U+0410 afii10017
+!B1 U+0411 afii10018
+!B2 U+0412 afii10019
+!B3 U+0413 afii10020
+!B4 U+0414 afii10021
+!B5 U+0415 afii10022
+!B6 U+0416 afii10024
+!B7 U+0417 afii10025
+!B8 U+0418 afii10026
+!B9 U+0419 afii10027
+!BA U+041A afii10028
+!BB U+041B afii10029
+!BC U+041C afii10030
+!BD U+041D afii10031
+!BE U+041E afii10032
+!BF U+041F afii10033
+!C0 U+0420 afii10034
+!C1 U+0421 afii10035
+!C2 U+0422 afii10036
+!C3 U+0423 afii10037
+!C4 U+0424 afii10038
+!C5 U+0425 afii10039
+!C6 U+0426 afii10040
+!C7 U+0427 afii10041
+!C8 U+0428 afii10042
+!C9 U+0429 afii10043
+!CA U+042A afii10044
+!CB U+042B afii10045
+!CC U+042C afii10046
+!CD U+042D afii10047
+!CE U+042E afii10048
+!CF U+042F afii10049
+!D0 U+0430 afii10065
+!D1 U+0431 afii10066
+!D2 U+0432 afii10067
+!D3 U+0433 afii10068
+!D4 U+0434 afii10069
+!D5 U+0435 afii10070
+!D6 U+0436 afii10072
+!D7 U+0437 afii10073
+!D8 U+0438 afii10074
+!D9 U+0439 afii10075
+!DA U+043A afii10076
+!DB U+043B afii10077
+!DC U+043C afii10078
+!DD U+043D afii10079
+!DE U+043E afii10080
+!DF U+043F afii10081
+!E0 U+0440 afii10082
+!E1 U+0441 afii10083
+!E2 U+0442 afii10084
+!E3 U+0443 afii10085
+!E4 U+0444 afii10086
+!E5 U+0445 afii10087
+!E6 U+0446 afii10088
+!E7 U+0447 afii10089
+!E8 U+0448 afii10090
+!E9 U+0449 afii10091
+!EA U+044A afii10092
+!EB U+044B afii10093
+!EC U+044C afii10094
+!ED U+044D afii10095
+!EE U+044E afii10096
+!EF U+044F afii10097
+!F0 U+2116 afii61352
+!F1 U+0451 afii10071
+!F2 U+0452 afii10099
+!F3 U+0453 afii10100
+!F4 U+0454 afii10101
+!F5 U+0455 afii10102
+!F6 U+0456 afii10103
+!F7 U+0457 afii10104
+!F8 U+0458 afii10105
+!F9 U+0459 afii10106
+!FA U+045A afii10107
+!FB U+045B afii10108
+!FC U+045C afii10109
+!FD U+00A7 section
+!FE U+045E afii10110
+!FF U+045F afii10193
Added: trunk/mapbender/http/extensions/fpdf/font/makefont/iso-8859-7.map
--- trunk/mapbender/http/extensions/fpdf/font/makefont/iso-8859-7.map	                        (rev 0)
+++ trunk/mapbender/http/extensions/fpdf/font/makefont/iso-8859-7.map	2010-01-19 23:07:49 UTC (rev 5359)
@@ -0,0 +1,250 @@
+!00 U+0000 .notdef
+!01 U+0001 .notdef
+!02 U+0002 .notdef
+!03 U+0003 .notdef
+!04 U+0004 .notdef
+!05 U+0005 .notdef
+!06 U+0006 .notdef
+!07 U+0007 .notdef
+!08 U+0008 .notdef
+!09 U+0009 .notdef
+!0A U+000A .notdef
+!0B U+000B .notdef
+!0C U+000C .notdef
+!0D U+000D .notdef
+!0E U+000E .notdef
+!0F U+000F .notdef
+!10 U+0010 .notdef
+!11 U+0011 .notdef
+!12 U+0012 .notdef
+!13 U+0013 .notdef
+!14 U+0014 .notdef
+!15 U+0015 .notdef
+!16 U+0016 .notdef
+!17 U+0017 .notdef
+!18 U+0018 .notdef
+!19 U+0019 .notdef
+!1A U+001A .notdef
+!1B U+001B .notdef
+!1C U+001C .notdef
+!1D U+001D .notdef
+!1E U+001E .notdef
+!1F U+001F .notdef
+!20 U+0020 space
+!21 U+0021 exclam
+!22 U+0022 quotedbl
+!23 U+0023 numbersign
+!24 U+0024 dollar
+!25 U+0025 percent
+!26 U+0026 ampersand
+!27 U+0027 quotesingle
+!28 U+0028 parenleft
+!29 U+0029 parenright
+!2A U+002A asterisk
+!2B U+002B plus
+!2C U+002C comma
+!2D U+002D hyphen
+!2E U+002E period
+!2F U+002F slash
+!30 U+0030 zero
+!31 U+0031 one
+!32 U+0032 two
+!33 U+0033 three
+!34 U+0034 four
+!35 U+0035 five
+!36 U+0036 six
+!37 U+0037 seven
+!38 U+0038 eight
+!39 U+0039 nine
+!3A U+003A colon
+!3B U+003B semicolon
+!3C U+003C less
+!3D U+003D equal
+!3E U+003E greater
+!3F U+003F question
+!40 U+0040 at
+!41 U+0041 A
+!42 U+0042 B
+!43 U+0043 C
+!44 U+0044 D
+!45 U+0045 E
+!46 U+0046 F
+!47 U+0047 G
+!48 U+0048 H
+!49 U+0049 I
+!4A U+004A J
+!4B U+004B K
+!4C U+004C L
+!4D U+004D M
+!4E U+004E N
+!4F U+004F O
+!50 U+0050 P
+!51 U+0051 Q
+!52 U+0052 R
+!53 U+0053 S
+!54 U+0054 T
+!55 U+0055 U
+!56 U+0056 V
+!57 U+0057 W
+!58 U+0058 X
+!59 U+0059 Y
+!5A U+005A Z
+!5B U+005B bracketleft
+!5C U+005C backslash
+!5D U+005D bracketright
+!5E U+005E asciicircum
+!5F U+005F underscore
+!60 U+0060 grave
+!61 U+0061 a
+!62 U+0062 b
+!63 U+0063 c
+!64 U+0064 d
+!65 U+0065 e
+!66 U+0066 f
+!67 U+0067 g
+!68 U+0068 h
+!69 U+0069 i
+!6A U+006A j
+!6B U+006B k
+!6C U+006C l
+!6D U+006D m
+!6E U+006E n
+!6F U+006F o
+!70 U+0070 p
+!71 U+0071 q
+!72 U+0072 r
+!73 U+0073 s
+!74 U+0074 t
+!75 U+0075 u
+!76 U+0076 v
+!77 U+0077 w
+!78 U+0078 x
+!79 U+0079 y
+!7A U+007A z
+!7B U+007B braceleft
+!7C U+007C bar
+!7D U+007D braceright
+!7E U+007E asciitilde
+!7F U+007F .notdef
+!80 U+0080 .notdef
+!81 U+0081 .notdef
+!82 U+0082 .notdef
+!83 U+0083 .notdef
+!84 U+0084 .notdef
+!85 U+0085 .notdef
+!86 U+0086 .notdef
+!87 U+0087 .notdef
+!88 U+0088 .notdef
+!89 U+0089 .notdef
+!8A U+008A .notdef
+!8B U+008B .notdef
+!8C U+008C .notdef
+!8D U+008D .notdef
+!8E U+008E .notdef
+!8F U+008F .notdef
+!90 U+0090 .notdef
+!91 U+0091 .notdef
+!92 U+0092 .notdef
+!93 U+0093 .notdef
+!94 U+0094 .notdef
+!95 U+0095 .notdef
+!96 U+0096 .notdef
+!97 U+0097 .notdef
+!98 U+0098 .notdef
+!99 U+0099 .notdef
+!9A U+009A .notdef
+!9B U+009B .notdef
+!9C U+009C .notdef
+!9D U+009D .notdef
+!9E U+009E .notdef
+!9F U+009F .notdef
+!A0 U+00A0 space
+!A1 U+2018 quoteleft
+!A2 U+2019 quoteright
+!A6 U+00A6 brokenbar
+!A7 U+00A7 section
+!A8 U+00A8 dieresis
+!A9 U+00A9 copyright
+!AB U+00AB guillemotleft
+!AC U+00AC logicalnot
+!AD U+00AD hyphen
+!B0 U+00B0 degree
+!B1 U+00B1 plusminus
+!B4 U+0384 tonos
+!B5 U+0385 dieresistonos
+!B6 U+0386 Alphatonos
+!B7 U+00B7 periodcentered
+!BB U+00BB guillemotright
+!BD U+00BD onehalf
+!C1 U+0391 Alpha
+!C2 U+0392 Beta
+!C3 U+0393 Gamma
+!C4 U+0394 Delta
+!C5 U+0395 Epsilon
+!C6 U+0396 Zeta
+!C7 U+0397 Eta
+!C8 U+0398 Theta
+!C9 U+0399 Iota
+!CA U+039A Kappa
+!CB U+039B Lambda
+!CC U+039C Mu
+!CD U+039D Nu
+!CE U+039E Xi
+!CF U+039F Omicron
+!D0 U+03A0 Pi
+!D1 U+03A1 Rho
+!D3 U+03A3 Sigma
+!D4 U+03A4 Tau
+!D5 U+03A5 Upsilon
+!D6 U+03A6 Phi
+!D7 U+03A7 Chi
+!D8 U+03A8 Psi
+!D9 U+03A9 Omega
+!E1 U+03B1 alpha
+!E2 U+03B2 beta
+!E3 U+03B3 gamma
+!E4 U+03B4 delta
+!E5 U+03B5 epsilon
+!E6 U+03B6 zeta
+!E7 U+03B7 eta
+!E8 U+03B8 theta
+!E9 U+03B9 iota
+!EA U+03BA kappa
+!EB U+03BB lambda
+!EC U+03BC mu
+!ED U+03BD nu
+!EE U+03BE xi
+!EF U+03BF omicron
+!F0 U+03C0 pi
+!F1 U+03C1 rho
+!F2 U+03C2 sigma1
+!F3 U+03C3 sigma
+!F4 U+03C4 tau
+!F5 U+03C5 upsilon
+!F6 U+03C6 phi
+!F7 U+03C7 chi
+!F8 U+03C8 psi
+!F9 U+03C9 omega
Added: trunk/mapbender/http/extensions/fpdf/font/makefont/iso-8859-9.map
--- trunk/mapbender/http/extensions/fpdf/font/makefont/iso-8859-9.map	                        (rev 0)
+++ trunk/mapbender/http/extensions/fpdf/font/makefont/iso-8859-9.map	2010-01-19 23:07:49 UTC (rev 5359)
@@ -0,0 +1,256 @@
+!00 U+0000 .notdef
+!01 U+0001 .notdef
+!02 U+0002 .notdef
+!03 U+0003 .notdef
+!04 U+0004 .notdef
+!05 U+0005 .notdef
+!06 U+0006 .notdef
+!07 U+0007 .notdef
+!08 U+0008 .notdef
+!09 U+0009 .notdef
+!0A U+000A .notdef
+!0B U+000B .notdef
+!0C U+000C .notdef
+!0D U+000D .notdef
+!0E U+000E .notdef
+!0F U+000F .notdef
+!10 U+0010 .notdef
+!11 U+0011 .notdef
+!12 U+0012 .notdef
+!13 U+0013 .notdef
+!14 U+0014 .notdef
+!15 U+0015 .notdef
+!16 U+0016 .notdef
+!17 U+0017 .notdef
+!18 U+0018 .notdef
+!19 U+0019 .notdef
+!1A U+001A .notdef
+!1B U+001B .notdef
+!1C U+001C .notdef
+!1D U+001D .notdef
+!1E U+001E .notdef
+!1F U+001F .notdef
+!20 U+0020 space
+!21 U+0021 exclam
+!24 U+0024 dollar
+!25 U+0025 percent
+!2B U+002B plus
+!2C U+002C comma
+!2D U+002D hyphen
+!2E U+002E period
+!2F U+002F slash
+!30 U+0030 zero
+!31 U+0031 one
+!32 U+0032 two
+!33 U+0033 three
+!34 U+0034 four
+!35 U+0035 five
+!36 U+0036 six
+!37 U+0037 seven
+!38 U+0038 eight
+!39 U+0039 nine
+!3A U+003A colon
+!3C U+003C less
+!3D U+003D equal
+!3E U+003E greater
+!40 U+0040 at
+!41 U+0041 A
+!42 U+0042 B
+!43 U+0043 C
+!44 U+0044 D
+!45 U+0045 E
+!46 U+0046 F
+!47 U+0047 G
+!48 U+0048 H
+!49 U+0049 I
+!4A U+004A J
+!4B U+004B K
+!4C U+004C L
+!4D U+004D M
+!4E U+004E N
+!4F U+004F O
+!50 U+0050 P
+!51 U+0051 Q
+!52 U+0052 R
+!53 U+0053 S
+!54 U+0054 T
+!55 U+0055 U
+!56 U+0056 V
+!57 U+0057 W
+!58 U+0058 X
+!59 U+0059 Y
+!5A U+005A Z
+!60 U+0060 grave
+!61 U+0061 a
+!62 U+0062 b
+!63 U+0063 c
+!64 U+0064 d
+!65 U+0065 e
+!66 U+0066 f
+!67 U+0067 g
+!68 U+0068 h
+!69 U+0069 i
+!6A U+006A j
+!6B U+006B k
+!6C U+006C l
+!6D U+006D m
+!6E U+006E n
+!6F U+006F o
+!70 U+0070 p
+!71 U+0071 q
+!72 U+0072 r
+!73 U+0073 s
+!74 U+0074 t
+!75 U+0075 u
+!76 U+0076 v
+!77 U+0077 w
+!78 U+0078 x
+!79 U+0079 y
+!7A U+007A z
+!7C U+007C bar
+!7F U+007F .notdef
+!80 U+0080 .notdef
+!81 U+0081 .notdef
+!82 U+0082 .notdef
+!83 U+0083 .notdef
+!84 U+0084 .notdef
+!85 U+0085 .notdef
+!86 U+0086 .notdef
+!87 U+0087 .notdef
+!88 U+0088 .notdef
+!89 U+0089 .notdef
+!8A U+008A .notdef
+!8B U+008B .notdef
+!8C U+008C .notdef
+!8D U+008D .notdef
+!8E U+008E .notdef
+!8F U+008F .notdef
+!90 U+0090 .notdef
+!91 U+0091 .notdef
+!92 U+0092 .notdef
+!93 U+0093 .notdef
+!94 U+0094 .notdef
+!95 U+0095 .notdef
+!96 U+0096 .notdef
+!97 U+0097 .notdef
+!98 U+0098 .notdef
+!99 U+0099 .notdef
+!9A U+009A .notdef
+!9B U+009B .notdef
+!9C U+009C .notdef
+!9D U+009D .notdef
+!9E U+009E .notdef
+!9F U+009F .notdef
+!A0 U+00A0 space
+!A2 U+00A2 cent
+!A4 U+00A4 currency
+!A5 U+00A5 yen
+!A7 U+00A7 section
+!AD U+00AD hyphen
+!AE U+00AE registered
+!AF U+00AF macron
+!B0 U+00B0 degree
+!B4 U+00B4 acute
+!B5 U+00B5 mu
+!B6 U+00B6 paragraph
+!B8 U+00B8 cedilla
+!BD U+00BD onehalf
+!C0 U+00C0 Agrave
+!C1 U+00C1 Aacute
+!C2 U+00C2 Acircumflex
+!C3 U+00C3 Atilde
+!C4 U+00C4 Adieresis
+!C5 U+00C5 Aring
+!C6 U+00C6 AE
+!C7 U+00C7 Ccedilla
+!C8 U+00C8 Egrave
+!C9 U+00C9 Eacute
+!CB U+00CB Edieresis
+!CC U+00CC Igrave
+!CD U+00CD Iacute
+!CE U+00CE Icircumflex
+!D0 U+011E Gbreve
+!D1 U+00D1 Ntilde
+!D2 U+00D2 Ograve
+!D3 U+00D3 Oacute
+!D4 U+00D4 Ocircumflex
+!D5 U+00D5 Otilde
+!D6 U+00D6 Odieresis
+!D7 U+00D7 multiply
+!D8 U+00D8 Oslash
+!D9 U+00D9 Ugrave
+!DA U+00DA Uacute
+!DC U+00DC Udieresis
+!DF U+00DF germandbls
+!E0 U+00E0 agrave
+!E1 U+00E1 aacute
+!E2 U+00E2 acircumflex
+!E3 U+00E3 atilde
+!E4 U+00E4 adieresis
+!E5 U+00E5 aring
+!E6 U+00E6 ae
+!E7 U+00E7 ccedilla
+!E8 U+00E8 egrave
+!E9 U+00E9 eacute
+!EB U+00EB edieresis
+!EC U+00EC igrave
+!ED U+00ED iacute
+!EE U+00EE icircumflex
+!F0 U+011F gbreve
+!F1 U+00F1 ntilde
+!F2 U+00F2 ograve
+!F3 U+00F3 oacute
+!F4 U+00F4 ocircumflex
+!F5 U+00F5 otilde
+!F6 U+00F6 odieresis
+!F7 U+00F7 divide
+!F8 U+00F8 oslash
+!F9 U+00F9 ugrave
+!FA U+00FA uacute
+!FC U+00FC udieresis
Added: trunk/mapbender/http/extensions/fpdf/font/makefont/koi8-r.map
--- trunk/mapbender/http/extensions/fpdf/font/makefont/koi8-r.map	                        (rev 0)
+++ trunk/mapbender/http/extensions/fpdf/font/makefont/koi8-r.map	2010-01-19 23:07:49 UTC (rev 5359)
@@ -0,0 +1,256 @@
+!00 U+0000 .notdef
+!01 U+0001 .notdef
+!02 U+0002 .notdef
+!03 U+0003 .notdef
+!04 U+0004 .notdef
+!05 U+0005 .notdef
+!06 U+0006 .notdef
+!07 U+0007 .notdef
+!08 U+0008 .notdef
+!09 U+0009 .notdef
+!0A U+000A .notdef
+!0B U+000B .notdef
+!0C U+000C .notdef
+!0D U+000D .notdef
+!0E U+000E .notdef
+!0F U+000F .notdef
+!10 U+0010 .notdef
+!11 U+0011 .notdef
+!12 U+0012 .notdef
+!13 U+0013 .notdef
+!14 U+0014 .notdef
+!15 U+0015 .notdef
+!16 U+0016 .notdef
+!17 U+0017 .notdef
+!18 U+0018 .notdef
+!19 U+0019 .notdef
+!1A U+001A .notdef
+!1B U+001B .notdef
+!1C U+001C .notdef
+!1D U+001D .notdef
+!1E U+001E .notdef
+!1F U+001F .notdef
+!20 U+0020 space
+!21 U+0021 exclam
+!24 U+0024 dollar
+!25 U+0025 percent
+!2B U+002B plus
+!2C U+002C comma
+!2D U+002D hyphen
+!2E U+002E period
+!2F U+002F slash
+!30 U+0030 zero
+!31 U+0031 one
+!32 U+0032 two
+!33 U+0033 three
+!34 U+0034 four
+!35 U+0035 five
+!36 U+0036 six
+!37 U+0037 seven
+!38 U+0038 eight
+!39 U+0039 nine
+!3A U+003A colon
+!3C U+003C less
+!3D U+003D equal
+!3E U+003E greater
+!40 U+0040 at
+!41 U+0041 A
+!42 U+0042 B
+!43 U+0043 C
+!44 U+0044 D
+!45 U+0045 E
+!46 U+0046 F
+!47 U+0047 G
+!48 U+0048 H
+!49 U+0049 I
+!4A U+004A J
+!4B U+004B K
+!4C U+004C L
+!4D U+004D M
+!4E U+004E N
+!4F U+004F O
+!50 U+0050 P
+!51 U+0051 Q
+!52 U+0052 R
+!53 U+0053 S
+!54 U+0054 T
+!55 U+0055 U
+!56 U+0056 V
+!57 U+0057 W
+!58 U+0058 X
+!59 U+0059 Y
+!5A U+005A Z
+!60 U+0060 grave
+!61 U+0061 a
+!62 U+0062 b
+!63 U+0063 c
+!64 U+0064 d
+!65 U+0065 e
+!66 U+0066 f
+!67 U+0067 g
+!68 U+0068 h
+!69 U+0069 i
+!6A U+006A j
+!6B U+006B k
+!6C U+006C l
+!6D U+006D m
+!6E U+006E n
+!6F U+006F o
+!70 U+0070 p
+!71 U+0071 q
+!72 U+0072 r
+!73 U+0073 s
+!74 U+0074 t
+!75 U+0075 u
+!76 U+0076 v
+!77 U+0077 w
+!78 U+0078 x
+!79 U+0079 y
+!7A U+007A z
+!7C U+007C bar
+!7F U+007F .notdef
+!80 U+2500 SF100000
+!81 U+2502 SF110000
+!82 U+250C SF010000
+!83 U+2510 SF030000
+!84 U+2514 SF020000
+!85 U+2518 SF040000
+!86 U+251C SF080000
+!87 U+2524 SF090000
+!88 U+252C SF060000
+!89 U+2534 SF070000
+!8A U+253C SF050000
+!8B U+2580 upblock
+!8C U+2584 dnblock
+!8D U+2588 block
+!8E U+258C lfblock
+!8F U+2590 rtblock
+!90 U+2591 ltshade
+!91 U+2592 shade
+!92 U+2593 dkshade
+!93 U+2320 integraltp
+!94 U+25A0 filledbox
+!95 U+2219 periodcentered
+!96 U+221A radical
+!97 U+2248 approxequal
+!98 U+2264 lessequal
+!99 U+2265 greaterequal
+!9A U+00A0 space
+!9B U+2321 integralbt
+!9C U+00B0 degree
+!9D U+00B2 twosuperior
+!9E U+00B7 periodcentered
+!9F U+00F7 divide
+!A0 U+2550 SF430000
+!A1 U+2551 SF240000
+!A2 U+2552 SF510000
+!A3 U+0451 afii10071
+!A4 U+2553 SF520000
+!A5 U+2554 SF390000
+!A6 U+2555 SF220000
+!A7 U+2556 SF210000
+!A8 U+2557 SF250000
+!A9 U+2558 SF500000
+!AA U+2559 SF490000
+!AB U+255A SF380000
+!AC U+255B SF280000
+!AD U+255C SF270000
+!AE U+255D SF260000
+!AF U+255E SF360000
+!B0 U+255F SF370000
+!B1 U+2560 SF420000
+!B2 U+2561 SF190000
+!B3 U+0401 afii10023
+!B4 U+2562 SF200000
+!B5 U+2563 SF230000
+!B6 U+2564 SF470000
+!B7 U+2565 SF480000
+!B8 U+2566 SF410000
+!B9 U+2567 SF450000
+!BA U+2568 SF460000
+!BB U+2569 SF400000
+!BC U+256A SF540000
+!BD U+256B SF530000
+!BE U+256C SF440000
+!BF U+00A9 copyright
+!C0 U+044E afii10096
+!C1 U+0430 afii10065
+!C2 U+0431 afii10066
+!C3 U+0446 afii10088
+!C4 U+0434 afii10069
+!C5 U+0435 afii10070
+!C6 U+0444 afii10086
+!C7 U+0433 afii10068
+!C8 U+0445 afii10087
+!C9 U+0438 afii10074
+!CA U+0439 afii10075
+!CB U+043A afii10076
+!CC U+043B afii10077
+!CD U+043C afii10078
+!CE U+043D afii10079
+!CF U+043E afii10080
+!D0 U+043F afii10081
+!D1 U+044F afii10097
+!D2 U+0440 afii10082
+!D3 U+0441 afii10083
+!D4 U+0442 afii10084
+!D5 U+0443 afii10085
+!D7 U+0432 afii10067
+!D8 U+044C afii10094
+!D9 U+044B afii10093
+!DA U+0437 afii10073
+!DB U+0448 afii10090
+!DC U+044D afii10095
+!DD U+0449 afii10091
+!DE U+0447 afii10089
+!DF U+044A afii10092
+!E0 U+042E afii10048
+!E1 U+0410 afii10017
+!E2 U+0411 afii10018
+!E3 U+0426 afii10040
+!E4 U+0414 afii10021
+!E5 U+0415 afii10022
+!E6 U+0424 afii10038
+!E7 U+0413 afii10020
+!E8 U+0425 afii10039
+!E9 U+0418 afii10026
+!EA U+0419 afii10027
+!EB U+041A afii10028
+!EC U+041B afii10029
+!ED U+041C afii10030
+!EE U+041D afii10031
+!EF U+041E afii10032
+!F0 U+041F afii10033
+!F1 U+042F afii10049
+!F2 U+0420 afii10034
+!F3 U+0421 afii10035
+!F4 U+0422 afii10036
+!F5 U+0423 afii10037
+!F6 U+0416 afii10024
+!F7 U+0412 afii10019
+!F8 U+042C afii10046
+!F9 U+042B afii10045
+!FA U+0417 afii10025
+!FB U+0428 afii10042
+!FC U+042D afii10047
+!FD U+0429 afii10043
+!FE U+0427 afii10041
+!FF U+042A afii10044
Added: trunk/mapbender/http/extensions/fpdf/font/makefont/koi8-u.map
--- trunk/mapbender/http/extensions/fpdf/font/makefont/koi8-u.map	                        (rev 0)
+++ trunk/mapbender/http/extensions/fpdf/font/makefont/koi8-u.map	2010-01-19 23:07:49 UTC (rev 5359)
@@ -0,0 +1,256 @@
+!00 U+0000 .notdef
+!01 U+0001 .notdef
+!02 U+0002 .notdef
+!03 U+0003 .notdef
+!04 U+0004 .notdef
+!05 U+0005 .notdef
+!06 U+0006 .notdef
+!07 U+0007 .notdef
+!08 U+0008 .notdef
+!09 U+0009 .notdef
+!0A U+000A .notdef
+!0B U+000B .notdef
+!0C U+000C .notdef
+!0D U+000D .notdef
+!0E U+000E .notdef
+!0F U+000F .notdef
+!10 U+0010 .notdef
+!11 U+0011 .notdef
+!12 U+0012 .notdef
+!13 U+0013 .notdef
+!14 U+0014 .notdef
+!15 U+0015 .notdef
+!16 U+0016 .notdef
+!17 U+0017 .notdef
+!18 U+0018 .notdef
+!19 U+0019 .notdef
+!1A U+001A .notdef
+!1B U+001B .notdef
+!1C U+001C .notdef
+!1D U+001D .notdef
+!1E U+001E .notdef
+!1F U+001F .notdef
+!20 U+0020 space
+!21 U+0021 exclam
+!24 U+0024 dollar
+!25 U+0025 percent
+!2B U+002B plus
+!2C U+002C comma
+!2D U+002D hyphen
+!2E U+002E period
+!2F U+002F slash
+!30 U+0030 zero
+!31 U+0031 one
+!32 U+0032 two
+!33 U+0033 three
+!34 U+0034 four
+!35 U+0035 five
+!36 U+0036 six
+!37 U+0037 seven
+!38 U+0038 eight
+!39 U+0039 nine
+!3A U+003A colon
+!3C U+003C less
+!3D U+003D equal
+!3E U+003E greater
+!40 U+0040 at
+!41 U+0041 A
+!42 U+0042 B
+!43 U+0043 C
+!44 U+0044 D
+!45 U+0045 E
+!46 U+0046 F
+!47 U+0047 G
+!48 U+0048 H
+!49 U+0049 I
+!4A U+004A J
+!4B U+004B K
+!4C U+004C L
+!4D U+004D M
+!4E U+004E N
+!4F U+004F O
+!50 U+0050 P
+!51 U+0051 Q
+!52 U+0052 R
+!53 U+0053 S
+!54 U+0054 T
+!55 U+0055 U
+!56 U+0056 V
+!57 U+0057 W
+!58 U+0058 X
+!59 U+0059 Y
+!5A U+005A Z
+!60 U+0060 grave
+!61 U+0061 a
+!62 U+0062 b
+!63 U+0063 c
+!64 U+0064 d
+!65 U+0065 e
+!66 U+0066 f
+!67 U+0067 g
+!68 U+0068 h
+!69 U+0069 i
+!6A U+006A j
+!6B U+006B k
+!6C U+006C l
+!6D U+006D m
+!6E U+006E n
+!6F U+006F o
+!70 U+0070 p
+!71 U+0071 q
+!72 U+0072 r
+!73 U+0073 s
+!74 U+0074 t
+!75 U+0075 u
+!76 U+0076 v
+!77 U+0077 w
+!78 U+0078 x
+!79 U+0079 y
+!7A U+007A z
+!7C U+007C bar
+!7F U+007F .notdef
+!8B U+2580 upblock
+!8C U+2584 dnblock
+!8D U+2588 block
+!8E U+258C lfblock
+!8F U+2590 rtblock
+!90 U+2591 ltshade
+!91 U+2592 shade
+!92 U+2593 dkshade
+!95 U+2022 bullet
+!96 U+221A radical
+!9A U+00A0 space
+!9C U+00B0 degree
+!9F U+00F7 divide
+!A4 U+0454 afii10101
+!A6 U+0456 afii10103
+!A7 U+0457 afii10104
+!AD U+0491 afii10098
+!B4 U+0404 afii10053
+!B6 U+0406 afii10055
+!B7 U+0407 afii10056
+!BD U+0490 afii10050
Added: trunk/mapbender/http/extensions/fpdf/font/makefont/makefont.php
--- trunk/mapbender/http/extensions/fpdf/font/makefont/makefont.php	                        (rev 0)
+++ trunk/mapbender/http/extensions/fpdf/font/makefont/makefont.php	2010-01-19 23:07:49 UTC (rev 5359)
@@ -0,0 +1,419 @@
+<?php
+* Utility to generate font definition files                                    *
+* Version: 1.14        *
+* Date:    2008-08-03                                                          *
+* Author:  Olivier PLATHEY                                                     *
+function ReadMap($enc)
+	//Read a map file
+	$file=dirname(__FILE__).'/'.strtolower($enc).'.map';
+	$a=file($file);
+	if(empty($a))
+		die('<b>Error:</b> encoding not found: '.$enc);
+	$cc2gn=array();
+	foreach($a as $l)
+		if($l[0]=='!')
+			$e=preg_split('/[ \\t]+/',rtrim($l));
+			$cc=hexdec(substr($e[0],1));
+			$gn=$e[2];
+			$cc2gn[$cc]=$gn;
+	for($i=0;$i<=255;$i++)
+		if(!isset($cc2gn[$i]))
+			$cc2gn[$i]='.notdef';
+	return $cc2gn;
+function ReadAFM($file, &$map)
+	//Read a font metric file
+	$a=file($file);
+	if(empty($a))
+		die('File not found');
+	$widths=array();
+	$fm=array();
+	$fix=array('Edot'=>'Edotaccent','edot'=>'edotaccent','Idot'=>'Idotaccent','Zdot'=>'Zdotaccent','zdot'=>'zdotaccent',
+		'Odblacute'=>'Ohungarumlaut','odblacute'=>'ohungarumlaut','Udblacute'=>'Uhungarumlaut','udblacute'=>'uhungarumlaut',
+		'Gcedilla'=>'Gcommaaccent','gcedilla'=>'gcommaaccent','Kcedilla'=>'Kcommaaccent','kcedilla'=>'kcommaaccent',
+		'Lcedilla'=>'Lcommaaccent','lcedilla'=>'lcommaaccent','Ncedilla'=>'Ncommaaccent','ncedilla'=>'ncommaaccent',
+		'Rcedilla'=>'Rcommaaccent','rcedilla'=>'rcommaaccent','Scedilla'=>'Scommaaccent','scedilla'=>'scommaaccent',
+		'Tcedilla'=>'Tcommaaccent','tcedilla'=>'tcommaaccent','Dslash'=>'Dcroat','dslash'=>'dcroat','Dmacron'=>'Dcroat','dmacron'=>'dcroat',
+		'combininggraveaccent'=>'gravecomb','combininghookabove'=>'hookabovecomb','combiningtildeaccent'=>'tildecomb',
+		'combiningacuteaccent'=>'acutecomb','combiningdotbelow'=>'dotbelowcomb','dongsign'=>'dong');
+	foreach($a as $l)
+		$e=explode(' ',rtrim($l));
+		if(count($e)<2)
+			continue;
+		$code=$e[0];
+		$param=$e[1];
+		if($code=='C')
+			//Character metrics
+			$cc=(int)$e[1];
+			$w=$e[4];
+			$gn=$e[7];
+			if(substr($gn,-4)=='20AC')
+				$gn='Euro';
+			if(isset($fix[$gn]))
+				//Fix incorrect glyph name
+				foreach($map as $c=>$n)
+					if($n==$fix[$gn])
+						$map[$c]=$gn;
+			if(empty($map))
+				//Symbolic font: use built-in encoding
+				$widths[$cc]=$w;
+			else
+				$widths[$gn]=$w;
+				if($gn=='X')
+					$fm['CapXHeight']=$e[13];
+			if($gn=='.notdef')
+				$fm['MissingWidth']=$w;
+		elseif($code=='FontName')
+			$fm['FontName']=$param;
+		elseif($code=='Weight')
+			$fm['Weight']=$param;
+		elseif($code=='ItalicAngle')
+			$fm['ItalicAngle']=(double)$param;
+		elseif($code=='Ascender')
+			$fm['Ascender']=(int)$param;
+		elseif($code=='Descender')
+			$fm['Descender']=(int)$param;
+		elseif($code=='UnderlineThickness')
+			$fm['UnderlineThickness']=(int)$param;
+		elseif($code=='UnderlinePosition')
+			$fm['UnderlinePosition']=(int)$param;
+		elseif($code=='IsFixedPitch')
+			$fm['IsFixedPitch']=($param=='true');
+		elseif($code=='FontBBox')
+			$fm['FontBBox']=array($e[1],$e[2],$e[3],$e[4]);
+		elseif($code=='CapHeight')
+			$fm['CapHeight']=(int)$param;
+		elseif($code=='StdVW')
+			$fm['StdVW']=(int)$param;
+	if(!isset($fm['FontName']))
+		die('FontName not found');
+	if(!empty($map))
+		if(!isset($widths['.notdef']))
+			$widths['.notdef']=600;
+		if(!isset($widths['Delta']) && isset($widths['increment']))
+			$widths['Delta']=$widths['increment'];
+		//Order widths according to map
+			if(!isset($widths[$map[$i]]))
+				echo '<b>Warning:</b> character '.$map[$i].' is missing<br>';
+				$widths[$i]=$widths['.notdef'];
+			else
+				$widths[$i]=$widths[$map[$i]];
+	$fm['Widths']=$widths;
+	return $fm;
+function MakeFontDescriptor($fm, $symbolic)
+	//Ascent
+	$asc=(isset($fm['Ascender']) ? $fm['Ascender'] : 1000);
+	$fd="array('Ascent'=>".$asc;
+	//Descent
+	$desc=(isset($fm['Descender']) ? $fm['Descender'] : -200);
+	$fd.=",'Descent'=>".$desc;
+	//CapHeight
+	if(isset($fm['CapHeight']))
+		$ch=$fm['CapHeight'];
+	elseif(isset($fm['CapXHeight']))
+		$ch=$fm['CapXHeight'];
+	else
+		$ch=$asc;
+	$fd.=",'CapHeight'=>".$ch;
+	//Flags
+	$flags=0;
+	if(isset($fm['IsFixedPitch']) && $fm['IsFixedPitch'])
+		$flags+=1<<0;
+	if($symbolic)
+		$flags+=1<<2;
+	if(!$symbolic)
+		$flags+=1<<5;
+	if(isset($fm['ItalicAngle']) && $fm['ItalicAngle']!=0)
+		$flags+=1<<6;
+	$fd.=",'Flags'=>".$flags;
+	//FontBBox
+	if(isset($fm['FontBBox']))
+		$fbb=$fm['FontBBox'];
+	else
+		$fbb=array(0,$desc-100,1000,$asc+100);
+	$fd.=",'FontBBox'=>'[".$fbb[0].' '.$fbb[1].' '.$fbb[2].' '.$fbb[3]."]'";
+	//ItalicAngle
+	$ia=(isset($fm['ItalicAngle']) ? $fm['ItalicAngle'] : 0);
+	$fd.=",'ItalicAngle'=>".$ia;
+	//StemV
+	if(isset($fm['StdVW']))
+		$stemv=$fm['StdVW'];
+	elseif(isset($fm['Weight']) && preg_match('/bold|black/i',$fm['Weight']))
+		$stemv=120;
+	else
+		$stemv=70;
+	$fd.=",'StemV'=>".$stemv;
+	//MissingWidth
+	if(isset($fm['MissingWidth']))
+		$fd.=",'MissingWidth'=>".$fm['MissingWidth'];
+	$fd.=')';
+	return $fd;
+function MakeWidthArray($fm)
+	//Make character width array
+	$s="array(\n\t";
+	$cw=$fm['Widths'];
+		if(chr($i)=="'")
+			$s.="'\\''";
+		elseif(chr($i)=="\\")
+			$s.="'\\\\'";
+		elseif($i>=32 && $i<=126)
+			$s.="'".chr($i)."'";
+		else
+			$s.="chr($i)";
+		$s.='=>'.$fm['Widths'][$i];
+		if($i<255)
+			$s.=',';
+		if(($i+1)%22==0)
+			$s.="\n\t";
+	$s.=')';
+	return $s;
+function MakeFontEncoding($map)
+	//Build differences from reference encoding
+	$ref=ReadMap('cp1252');
+	$s='';
+	$last=0;
+	for($i=32;$i<=255;$i++)
+		if($map[$i]!=$ref[$i])
+			if($i!=$last+1)
+				$s.=$i.' ';
+			$last=$i;
+			$s.='/'.$map[$i].' ';
+	return rtrim($s);
+function SaveToFile($file, $s, $mode)
+	$f=fopen($file,'w'.$mode);
+	if(!$f)
+		die('Can\'t write to file '.$file);
+	fwrite($f,$s,strlen($s));
+	fclose($f);
+function ReadShort($f)
+	$a=unpack('n1n',fread($f,2));
+	return $a['n'];
+function ReadLong($f)
+	$a=unpack('N1N',fread($f,4));
+	return $a['N'];
+function CheckTTF($file)
+	//Check if font license allows embedding
+	$f=fopen($file,'rb');
+	if(!$f)
+		die('<b>Error:</b> Can\'t open '.$file);
+	//Extract number of tables
+	fseek($f,4,SEEK_CUR);
+	$nb=ReadShort($f);
+	fseek($f,6,SEEK_CUR);
+	//Seek OS/2 table
+	$found=false;
+	for($i=0;$i<$nb;$i++)
+		if(fread($f,4)=='OS/2')
+			$found=true;
+			break;
+		fseek($f,12,SEEK_CUR);
+	if(!$found)
+		fclose($f);
+		return;
+	$offset=ReadLong($f);
+	fseek($f,$offset,SEEK_SET);
+	//Extract fsType flags
+	fseek($f,8,SEEK_CUR);
+	$fsType=ReadShort($f);
+	$rl=($fsType & 0x02)!=0;
+	$pp=($fsType & 0x04)!=0;
+	$e=($fsType & 0x08)!=0;
+	fclose($f);
+	if($rl && !$pp && !$e)
+		echo '<b>Warning:</b> font license does not allow embedding';
+* fontfile: path to TTF file (or empty string if not to be embedded)           *
+* afmfile:  path to AFM file                                                   *
+* enc:      font encoding (or empty string for symbolic fonts)                 *
+* patch:    optional patch for encoding                                        *
+* type:     font type if fontfile is empty                                     *
+function MakeFont($fontfile, $afmfile, $enc='cp1252', $patch=array(), $type='TrueType')
+	//Generate a font definition file
+	if(get_magic_quotes_runtime())
+		@set_magic_quotes_runtime(0);
+	ini_set('auto_detect_line_endings','1');
+	if($enc)
+		$map=ReadMap($enc);
+		foreach($patch as $cc=>$gn)
+			$map[$cc]=$gn;
+	else
+		$map=array();
+	if(!file_exists($afmfile))
+		die('<b>Error:</b> AFM file not found: '.$afmfile);
+	$fm=ReadAFM($afmfile,$map);
+	if($enc)
+		$diff=MakeFontEncoding($map);
+	else
+		$diff='';
+	$fd=MakeFontDescriptor($fm,empty($map));
+	//Find font type
+	if($fontfile)
+		$ext=strtolower(substr($fontfile,-3));
+		if($ext=='ttf')
+			$type='TrueType';
+		elseif($ext=='pfb')
+			$type='Type1';
+		else
+			die('<b>Error:</b> unrecognized font file extension: '.$ext);
+	else
+		if($type!='TrueType' && $type!='Type1')
+			die('<b>Error:</b> incorrect font type: '.$type);
+	//Start generation
+	$s='<?php'."\n";
+	$s.='$type=\''.$type."';\n";
+	$s.='$name=\''.$fm['FontName']."';\n";
+	$s.='$desc='.$fd.";\n";
+	if(!isset($fm['UnderlinePosition']))
+		$fm['UnderlinePosition']=-100;
+	if(!isset($fm['UnderlineThickness']))
+		$fm['UnderlineThickness']=50;
+	$s.='$up='.$fm['UnderlinePosition'].";\n";
+	$s.='$ut='.$fm['UnderlineThickness'].";\n";
+	$w=MakeWidthArray($fm);
+	$s.='$cw='.$w.";\n";
+	$s.='$enc=\''.$enc."';\n";
+	$s.='$diff=\''.$diff."';\n";
+	$basename=substr(basename($afmfile),0,-4);
+	if($fontfile)
+		//Embedded font
+		if(!file_exists($fontfile))
+			die('<b>Error:</b> font file not found: '.$fontfile);
+		if($type=='TrueType')
+			CheckTTF($fontfile);
+		$f=fopen($fontfile,'rb');
+		if(!$f)
+			die('<b>Error:</b> Can\'t open '.$fontfile);
+		$file=fread($f,filesize($fontfile));
+		fclose($f);
+		if($type=='Type1')
+			//Find first two sections and discard third one
+			$header=(ord($file[0])==128);
+			if($header)
+				//Strip first binary header
+				$file=substr($file,6);
+			$pos=strpos($file,'eexec');
+			if(!$pos)
+				die('<b>Error:</b> font file does not seem to be valid Type1');
+			$size1=$pos+6;
+			if($header && ord($file[$size1])==128)
+				//Strip second binary header
+				$file=substr($file,0,$size1).substr($file,$size1+6);
+			$pos=strpos($file,'00000000');
+			if(!$pos)
+			$size2=$pos-$size1;
+			$file=substr($file,0,$size1+$size2);
+		if(function_exists('gzcompress'))
+			$cmp=$basename.'.z';
+			SaveToFile($cmp,gzcompress($file),'b');
+			$s.='$file=\''.$cmp."';\n";
+			echo 'Font file compressed ('.$cmp.')<br>';
+		else
+			$s.='$file=\''.basename($fontfile)."';\n";
+			echo '<b>Notice:</b> font file could not be compressed (zlib extension not available)<br>';
+			$s.='$size1='.$size1.";\n";
+			$s.='$size2='.$size2.";\n";
+		else
+			$s.='$originalsize='.filesize($fontfile).";\n";
+	else
+		//Not embedded font
+		$s.='$file='."'';\n";
+	$s.="?>\n";
+	SaveToFile($basename.'.php',$s,'t');
+	echo 'Font definition file generated ('.$basename.'.php'.')<br>';
Added: trunk/mapbender/http/extensions/fpdf/font/symbol.php
--- trunk/mapbender/http/extensions/fpdf/font/symbol.php	                        (rev 0)
+++ trunk/mapbender/http/extensions/fpdf/font/symbol.php	2010-01-19 23:07:49 UTC (rev 5359)
@@ -0,0 +1,15 @@
+<?php
+$fpdf_charwidths['symbol']=array(
+	chr(0)=>250,chr(1)=>250,chr(2)=>250,chr(3)=>250,chr(4)=>250,chr(5)=>250,chr(6)=>250,chr(7)=>250,chr(8)=>250,chr(9)=>250,chr(10)=>250,chr(11)=>250,chr(12)=>250,chr(13)=>250,chr(14)=>250,chr(15)=>250,chr(16)=>250,chr(17)=>250,chr(18)=>250,chr(19)=>250,chr(20)=>250,chr(21)=>250,
+	chr(22)=>250,chr(23)=>250,chr(24)=>250,chr(25)=>250,chr(26)=>250,chr(27)=>250,chr(28)=>250,chr(29)=>250,chr(30)=>250,chr(31)=>250,' '=>250,'!'=>333,'"'=>713,'#'=>500,'$'=>549,'%'=>833,'&'=>778,'\''=>439,'('=>333,')'=>333,'*'=>500,'+'=>549,
+	','=>250,'-'=>549,'.'=>250,'/'=>278,'0'=>500,'1'=>500,'2'=>500,'3'=>500,'4'=>500,'5'=>500,'6'=>500,'7'=>500,'8'=>500,'9'=>500,':'=>278,';'=>278,'<'=>549,'='=>549,'>'=>549,'?'=>444,'@'=>549,'A'=>722,
+	'B'=>667,'C'=>722,'D'=>612,'E'=>611,'F'=>763,'G'=>603,'H'=>722,'I'=>333,'J'=>631,'K'=>722,'L'=>686,'M'=>889,'N'=>722,'O'=>722,'P'=>768,'Q'=>741,'R'=>556,'S'=>592,'T'=>611,'U'=>690,'V'=>439,'W'=>768,
+	'X'=>645,'Y'=>795,'Z'=>611,'['=>333,'\\'=>863,']'=>333,'^'=>658,'_'=>500,'`'=>500,'a'=>631,'b'=>549,'c'=>549,'d'=>494,'e'=>439,'f'=>521,'g'=>411,'h'=>603,'i'=>329,'j'=>603,'k'=>549,'l'=>549,'m'=>576,
+	'n'=>521,'o'=>549,'p'=>549,'q'=>521,'r'=>549,'s'=>603,'t'=>439,'u'=>576,'v'=>713,'w'=>686,'x'=>493,'y'=>686,'z'=>494,'{'=>480,'|'=>200,'}'=>480,'~'=>549,chr(127)=>0,chr(128)=>0,chr(129)=>0,chr(130)=>0,chr(131)=>0,
+	chr(132)=>0,chr(133)=>0,chr(134)=>0,chr(135)=>0,chr(136)=>0,chr(137)=>0,chr(138)=>0,chr(139)=>0,chr(140)=>0,chr(141)=>0,chr(142)=>0,chr(143)=>0,chr(144)=>0,chr(145)=>0,chr(146)=>0,chr(147)=>0,chr(148)=>0,chr(149)=>0,chr(150)=>0,chr(151)=>0,chr(152)=>0,chr(153)=>0,
+	chr(154)=>0,chr(155)=>0,chr(156)=>0,chr(157)=>0,chr(158)=>0,chr(159)=>0,chr(160)=>750,chr(161)=>620,chr(162)=>247,chr(163)=>549,chr(164)=>167,chr(165)=>713,chr(166)=>500,chr(167)=>753,chr(168)=>753,chr(169)=>753,chr(170)=>753,chr(171)=>1042,chr(172)=>987,chr(173)=>603,chr(174)=>987,chr(175)=>603,
+	chr(176)=>400,chr(177)=>549,chr(178)=>411,chr(179)=>549,chr(180)=>549,chr(181)=>713,chr(182)=>494,chr(183)=>460,chr(184)=>549,chr(185)=>549,chr(186)=>549,chr(187)=>549,chr(188)=>1000,chr(189)=>603,chr(190)=>1000,chr(191)=>658,chr(192)=>823,chr(193)=>686,chr(194)=>795,chr(195)=>987,chr(196)=>768,chr(197)=>768,
+	chr(198)=>823,chr(199)=>768,chr(200)=>768,chr(201)=>713,chr(202)=>713,chr(203)=>713,chr(204)=>713,chr(205)=>713,chr(206)=>713,chr(207)=>713,chr(208)=>768,chr(209)=>713,chr(210)=>790,chr(211)=>790,chr(212)=>890,chr(213)=>823,chr(214)=>549,chr(215)=>250,chr(216)=>713,chr(217)=>603,chr(218)=>603,chr(219)=>1042,
+	chr(220)=>987,chr(221)=>603,chr(222)=>987,chr(223)=>603,chr(224)=>494,chr(225)=>329,chr(226)=>790,chr(227)=>790,chr(228)=>786,chr(229)=>713,chr(230)=>384,chr(231)=>384,chr(232)=>384,chr(233)=>384,chr(234)=>384,chr(235)=>384,chr(236)=>494,chr(237)=>494,chr(238)=>494,chr(239)=>494,chr(240)=>0,chr(241)=>329,
+	chr(242)=>274,chr(243)=>686,chr(244)=>686,chr(245)=>686,chr(246)=>384,chr(247)=>384,chr(248)=>384,chr(249)=>384,chr(250)=>384,chr(251)=>384,chr(252)=>494,chr(253)=>494,chr(254)=>494,chr(255)=>0);
Added: trunk/mapbender/http/extensions/fpdf/font/times.php
--- trunk/mapbender/http/extensions/fpdf/font/times.php	                        (rev 0)
+++ trunk/mapbender/http/extensions/fpdf/font/times.php	2010-01-19 23:07:49 UTC (rev 5359)
@@ -0,0 +1,15 @@
+<?php
+$fpdf_charwidths['times']=array(
+	chr(22)=>250,chr(23)=>250,chr(24)=>250,chr(25)=>250,chr(26)=>250,chr(27)=>250,chr(28)=>250,chr(29)=>250,chr(30)=>250,chr(31)=>250,' '=>250,'!'=>333,'"'=>408,'#'=>500,'$'=>500,'%'=>833,'&'=>778,'\''=>180,'('=>333,')'=>333,'*'=>500,'+'=>564,
+	','=>250,'-'=>333,'.'=>250,'/'=>278,'0'=>500,'1'=>500,'2'=>500,'3'=>500,'4'=>500,'5'=>500,'6'=>500,'7'=>500,'8'=>500,'9'=>500,':'=>278,';'=>278,'<'=>564,'='=>564,'>'=>564,'?'=>444,'@'=>921,'A'=>722,
+	'B'=>667,'C'=>667,'D'=>722,'E'=>611,'F'=>556,'G'=>722,'H'=>722,'I'=>333,'J'=>389,'K'=>722,'L'=>611,'M'=>889,'N'=>722,'O'=>722,'P'=>556,'Q'=>722,'R'=>667,'S'=>556,'T'=>611,'U'=>722,'V'=>722,'W'=>944,
+	'X'=>722,'Y'=>722,'Z'=>611,'['=>333,'\\'=>278,']'=>333,'^'=>469,'_'=>500,'`'=>333,'a'=>444,'b'=>500,'c'=>444,'d'=>500,'e'=>444,'f'=>333,'g'=>500,'h'=>500,'i'=>278,'j'=>278,'k'=>500,'l'=>278,'m'=>778,
+	'n'=>500,'o'=>500,'p'=>500,'q'=>500,'r'=>333,'s'=>389,'t'=>278,'u'=>500,'v'=>500,'w'=>722,'x'=>500,'y'=>500,'z'=>444,'{'=>480,'|'=>200,'}'=>480,'~'=>541,chr(127)=>350,chr(128)=>500,chr(129)=>350,chr(130)=>333,chr(131)=>500,
+	chr(132)=>444,chr(133)=>1000,chr(134)=>500,chr(135)=>500,chr(136)=>333,chr(137)=>1000,chr(138)=>556,chr(139)=>333,chr(140)=>889,chr(141)=>350,chr(142)=>611,chr(143)=>350,chr(144)=>350,chr(145)=>333,chr(146)=>333,chr(147)=>444,chr(148)=>444,chr(149)=>350,chr(150)=>500,chr(151)=>1000,chr(152)=>333,chr(153)=>980,
+	chr(154)=>389,chr(155)=>333,chr(156)=>722,chr(157)=>350,chr(158)=>444,chr(159)=>722,chr(160)=>250,chr(161)=>333,chr(162)=>500,chr(163)=>500,chr(164)=>500,chr(165)=>500,chr(166)=>200,chr(167)=>500,chr(168)=>333,chr(169)=>760,chr(170)=>276,chr(171)=>500,chr(172)=>564,chr(173)=>333,chr(174)=>760,chr(175)=>333,
+	chr(176)=>400,chr(177)=>564,chr(178)=>300,chr(179)=>300,chr(180)=>333,chr(181)=>500,chr(182)=>453,chr(183)=>250,chr(184)=>333,chr(185)=>300,chr(186)=>310,chr(187)=>500,chr(188)=>750,chr(189)=>750,chr(190)=>750,chr(191)=>444,chr(192)=>722,chr(193)=>722,chr(194)=>722,chr(195)=>722,chr(196)=>722,chr(197)=>722,
+	chr(198)=>889,chr(199)=>667,chr(200)=>611,chr(201)=>611,chr(202)=>611,chr(203)=>611,chr(204)=>333,chr(205)=>333,chr(206)=>333,chr(207)=>333,chr(208)=>722,chr(209)=>722,chr(210)=>722,chr(211)=>722,chr(212)=>722,chr(213)=>722,chr(214)=>722,chr(215)=>564,chr(216)=>722,chr(217)=>722,chr(218)=>722,chr(219)=>722,
+	chr(220)=>722,chr(221)=>722,chr(222)=>556,chr(223)=>500,chr(224)=>444,chr(225)=>444,chr(226)=>444,chr(227)=>444,chr(228)=>444,chr(229)=>444,chr(230)=>667,chr(231)=>444,chr(232)=>444,chr(233)=>444,chr(234)=>444,chr(235)=>444,chr(236)=>278,chr(237)=>278,chr(238)=>278,chr(239)=>278,chr(240)=>500,chr(241)=>500,
+	chr(242)=>500,chr(243)=>500,chr(244)=>500,chr(245)=>500,chr(246)=>500,chr(247)=>564,chr(248)=>500,chr(249)=>500,chr(250)=>500,chr(251)=>500,chr(252)=>500,chr(253)=>500,chr(254)=>500,chr(255)=>500);
Added: trunk/mapbender/http/extensions/fpdf/font/timesb.php
--- trunk/mapbender/http/extensions/fpdf/font/timesb.php	                        (rev 0)
+++ trunk/mapbender/http/extensions/fpdf/font/timesb.php	2010-01-19 23:07:49 UTC (rev 5359)
@@ -0,0 +1,15 @@
+<?php
+$fpdf_charwidths['timesB']=array(
+	chr(22)=>250,chr(23)=>250,chr(24)=>250,chr(25)=>250,chr(26)=>250,chr(27)=>250,chr(28)=>250,chr(29)=>250,chr(30)=>250,chr(31)=>250,' '=>250,'!'=>333,'"'=>555,'#'=>500,'$'=>500,'%'=>1000,'&'=>833,'\''=>278,'('=>333,')'=>333,'*'=>500,'+'=>570,
+	','=>250,'-'=>333,'.'=>250,'/'=>278,'0'=>500,'1'=>500,'2'=>500,'3'=>500,'4'=>500,'5'=>500,'6'=>500,'7'=>500,'8'=>500,'9'=>500,':'=>333,';'=>333,'<'=>570,'='=>570,'>'=>570,'?'=>500,'@'=>930,'A'=>722,
+	'B'=>667,'C'=>722,'D'=>722,'E'=>667,'F'=>611,'G'=>778,'H'=>778,'I'=>389,'J'=>500,'K'=>778,'L'=>667,'M'=>944,'N'=>722,'O'=>778,'P'=>611,'Q'=>778,'R'=>722,'S'=>556,'T'=>667,'U'=>722,'V'=>722,'W'=>1000,
+	'X'=>722,'Y'=>722,'Z'=>667,'['=>333,'\\'=>278,']'=>333,'^'=>581,'_'=>500,'`'=>333,'a'=>500,'b'=>556,'c'=>444,'d'=>556,'e'=>444,'f'=>333,'g'=>500,'h'=>556,'i'=>278,'j'=>333,'k'=>556,'l'=>278,'m'=>833,
+	'n'=>556,'o'=>500,'p'=>556,'q'=>556,'r'=>444,'s'=>389,'t'=>333,'u'=>556,'v'=>500,'w'=>722,'x'=>500,'y'=>500,'z'=>444,'{'=>394,'|'=>220,'}'=>394,'~'=>520,chr(127)=>350,chr(128)=>500,chr(129)=>350,chr(130)=>333,chr(131)=>500,
+	chr(132)=>500,chr(133)=>1000,chr(134)=>500,chr(135)=>500,chr(136)=>333,chr(137)=>1000,chr(138)=>556,chr(139)=>333,chr(140)=>1000,chr(141)=>350,chr(142)=>667,chr(143)=>350,chr(144)=>350,chr(145)=>333,chr(146)=>333,chr(147)=>500,chr(148)=>500,chr(149)=>350,chr(150)=>500,chr(151)=>1000,chr(152)=>333,chr(153)=>1000,
+	chr(154)=>389,chr(155)=>333,chr(156)=>722,chr(157)=>350,chr(158)=>444,chr(159)=>722,chr(160)=>250,chr(161)=>333,chr(162)=>500,chr(163)=>500,chr(164)=>500,chr(165)=>500,chr(166)=>220,chr(167)=>500,chr(168)=>333,chr(169)=>747,chr(170)=>300,chr(171)=>500,chr(172)=>570,chr(173)=>333,chr(174)=>747,chr(175)=>333,
+	chr(176)=>400,chr(177)=>570,chr(178)=>300,chr(179)=>300,chr(180)=>333,chr(181)=>556,chr(182)=>540,chr(183)=>250,chr(184)=>333,chr(185)=>300,chr(186)=>330,chr(187)=>500,chr(188)=>750,chr(189)=>750,chr(190)=>750,chr(191)=>500,chr(192)=>722,chr(193)=>722,chr(194)=>722,chr(195)=>722,chr(196)=>722,chr(197)=>722,
+	chr(198)=>1000,chr(199)=>722,chr(200)=>667,chr(201)=>667,chr(202)=>667,chr(203)=>667,chr(204)=>389,chr(205)=>389,chr(206)=>389,chr(207)=>389,chr(208)=>722,chr(209)=>722,chr(210)=>778,chr(211)=>778,chr(212)=>778,chr(213)=>778,chr(214)=>778,chr(215)=>570,chr(216)=>778,chr(217)=>722,chr(218)=>722,chr(219)=>722,
+	chr(220)=>722,chr(221)=>722,chr(222)=>611,chr(223)=>556,chr(224)=>500,chr(225)=>500,chr(226)=>500,chr(227)=>500,chr(228)=>500,chr(229)=>500,chr(230)=>722,chr(231)=>444,chr(232)=>444,chr(233)=>444,chr(234)=>444,chr(235)=>444,chr(236)=>278,chr(237)=>278,chr(238)=>278,chr(239)=>278,chr(240)=>500,chr(241)=>556,
+	chr(242)=>500,chr(243)=>500,chr(244)=>500,chr(245)=>500,chr(246)=>500,chr(247)=>570,chr(248)=>500,chr(249)=>556,chr(250)=>556,chr(251)=>556,chr(252)=>556,chr(253)=>500,chr(254)=>556,chr(255)=>500);
Added: trunk/mapbender/http/extensions/fpdf/font/timesbi.php
--- trunk/mapbender/http/extensions/fpdf/font/timesbi.php	                        (rev 0)
+++ trunk/mapbender/http/extensions/fpdf/font/timesbi.php	2010-01-19 23:07:49 UTC (rev 5359)
@@ -0,0 +1,15 @@
+<?php
+$fpdf_charwidths['timesBI']=array(
+	chr(22)=>250,chr(23)=>250,chr(24)=>250,chr(25)=>250,chr(26)=>250,chr(27)=>250,chr(28)=>250,chr(29)=>250,chr(30)=>250,chr(31)=>250,' '=>250,'!'=>389,'"'=>555,'#'=>500,'$'=>500,'%'=>833,'&'=>778,'\''=>278,'('=>333,')'=>333,'*'=>500,'+'=>570,
+	','=>250,'-'=>333,'.'=>250,'/'=>278,'0'=>500,'1'=>500,'2'=>500,'3'=>500,'4'=>500,'5'=>500,'6'=>500,'7'=>500,'8'=>500,'9'=>500,':'=>333,';'=>333,'<'=>570,'='=>570,'>'=>570,'?'=>500,'@'=>832,'A'=>667,
+	'B'=>667,'C'=>667,'D'=>722,'E'=>667,'F'=>667,'G'=>722,'H'=>778,'I'=>389,'J'=>500,'K'=>667,'L'=>611,'M'=>889,'N'=>722,'O'=>722,'P'=>611,'Q'=>722,'R'=>667,'S'=>556,'T'=>611,'U'=>722,'V'=>667,'W'=>889,
+	'X'=>667,'Y'=>611,'Z'=>611,'['=>333,'\\'=>278,']'=>333,'^'=>570,'_'=>500,'`'=>333,'a'=>500,'b'=>500,'c'=>444,'d'=>500,'e'=>444,'f'=>333,'g'=>500,'h'=>556,'i'=>278,'j'=>278,'k'=>500,'l'=>278,'m'=>778,
+	'n'=>556,'o'=>500,'p'=>500,'q'=>500,'r'=>389,'s'=>389,'t'=>278,'u'=>556,'v'=>444,'w'=>667,'x'=>500,'y'=>444,'z'=>389,'{'=>348,'|'=>220,'}'=>348,'~'=>570,chr(127)=>350,chr(128)=>500,chr(129)=>350,chr(130)=>333,chr(131)=>500,
+	chr(132)=>500,chr(133)=>1000,chr(134)=>500,chr(135)=>500,chr(136)=>333,chr(137)=>1000,chr(138)=>556,chr(139)=>333,chr(140)=>944,chr(141)=>350,chr(142)=>611,chr(143)=>350,chr(144)=>350,chr(145)=>333,chr(146)=>333,chr(147)=>500,chr(148)=>500,chr(149)=>350,chr(150)=>500,chr(151)=>1000,chr(152)=>333,chr(153)=>1000,
+	chr(154)=>389,chr(155)=>333,chr(156)=>722,chr(157)=>350,chr(158)=>389,chr(159)=>611,chr(160)=>250,chr(161)=>389,chr(162)=>500,chr(163)=>500,chr(164)=>500,chr(165)=>500,chr(166)=>220,chr(167)=>500,chr(168)=>333,chr(169)=>747,chr(170)=>266,chr(171)=>500,chr(172)=>606,chr(173)=>333,chr(174)=>747,chr(175)=>333,
+	chr(176)=>400,chr(177)=>570,chr(178)=>300,chr(179)=>300,chr(180)=>333,chr(181)=>576,chr(182)=>500,chr(183)=>250,chr(184)=>333,chr(185)=>300,chr(186)=>300,chr(187)=>500,chr(188)=>750,chr(189)=>750,chr(190)=>750,chr(191)=>500,chr(192)=>667,chr(193)=>667,chr(194)=>667,chr(195)=>667,chr(196)=>667,chr(197)=>667,
+	chr(198)=>944,chr(199)=>667,chr(200)=>667,chr(201)=>667,chr(202)=>667,chr(203)=>667,chr(204)=>389,chr(205)=>389,chr(206)=>389,chr(207)=>389,chr(208)=>722,chr(209)=>722,chr(210)=>722,chr(211)=>722,chr(212)=>722,chr(213)=>722,chr(214)=>722,chr(215)=>570,chr(216)=>722,chr(217)=>722,chr(218)=>722,chr(219)=>722,
+	chr(220)=>722,chr(221)=>611,chr(222)=>611,chr(223)=>500,chr(224)=>500,chr(225)=>500,chr(226)=>500,chr(227)=>500,chr(228)=>500,chr(229)=>500,chr(230)=>722,chr(231)=>444,chr(232)=>444,chr(233)=>444,chr(234)=>444,chr(235)=>444,chr(236)=>278,chr(237)=>278,chr(238)=>278,chr(239)=>278,chr(240)=>500,chr(241)=>556,
+	chr(242)=>500,chr(243)=>500,chr(244)=>500,chr(245)=>500,chr(246)=>500,chr(247)=>570,chr(248)=>500,chr(249)=>556,chr(250)=>556,chr(251)=>556,chr(252)=>556,chr(253)=>444,chr(254)=>500,chr(255)=>444);
Added: trunk/mapbender/http/extensions/fpdf/font/timesi.php
--- trunk/mapbender/http/extensions/fpdf/font/timesi.php	                        (rev 0)
+++ trunk/mapbender/http/extensions/fpdf/font/timesi.php	2010-01-19 23:07:49 UTC (rev 5359)
@@ -0,0 +1,15 @@
+<?php
+$fpdf_charwidths['timesI']=array(
+	chr(22)=>250,chr(23)=>250,chr(24)=>250,chr(25)=>250,chr(26)=>250,chr(27)=>250,chr(28)=>250,chr(29)=>250,chr(30)=>250,chr(31)=>250,' '=>250,'!'=>333,'"'=>420,'#'=>500,'$'=>500,'%'=>833,'&'=>778,'\''=>214,'('=>333,')'=>333,'*'=>500,'+'=>675,
+	','=>250,'-'=>333,'.'=>250,'/'=>278,'0'=>500,'1'=>500,'2'=>500,'3'=>500,'4'=>500,'5'=>500,'6'=>500,'7'=>500,'8'=>500,'9'=>500,':'=>333,';'=>333,'<'=>675,'='=>675,'>'=>675,'?'=>500,'@'=>920,'A'=>611,
+	'B'=>611,'C'=>667,'D'=>722,'E'=>611,'F'=>611,'G'=>722,'H'=>722,'I'=>333,'J'=>444,'K'=>667,'L'=>556,'M'=>833,'N'=>667,'O'=>722,'P'=>611,'Q'=>722,'R'=>611,'S'=>500,'T'=>556,'U'=>722,'V'=>611,'W'=>833,
+	'X'=>611,'Y'=>556,'Z'=>556,'['=>389,'\\'=>278,']'=>389,'^'=>422,'_'=>500,'`'=>333,'a'=>500,'b'=>500,'c'=>444,'d'=>500,'e'=>444,'f'=>278,'g'=>500,'h'=>500,'i'=>278,'j'=>278,'k'=>444,'l'=>278,'m'=>722,
+	'n'=>500,'o'=>500,'p'=>500,'q'=>500,'r'=>389,'s'=>389,'t'=>278,'u'=>500,'v'=>444,'w'=>667,'x'=>444,'y'=>444,'z'=>389,'{'=>400,'|'=>275,'}'=>400,'~'=>541,chr(127)=>350,chr(128)=>500,chr(129)=>350,chr(130)=>333,chr(131)=>500,
+	chr(132)=>556,chr(133)=>889,chr(134)=>500,chr(135)=>500,chr(136)=>333,chr(137)=>1000,chr(138)=>500,chr(139)=>333,chr(140)=>944,chr(141)=>350,chr(142)=>556,chr(143)=>350,chr(144)=>350,chr(145)=>333,chr(146)=>333,chr(147)=>556,chr(148)=>556,chr(149)=>350,chr(150)=>500,chr(151)=>889,chr(152)=>333,chr(153)=>980,
+	chr(154)=>389,chr(155)=>333,chr(156)=>667,chr(157)=>350,chr(158)=>389,chr(159)=>556,chr(160)=>250,chr(161)=>389,chr(162)=>500,chr(163)=>500,chr(164)=>500,chr(165)=>500,chr(166)=>275,chr(167)=>500,chr(168)=>333,chr(169)=>760,chr(170)=>276,chr(171)=>500,chr(172)=>675,chr(173)=>333,chr(174)=>760,chr(175)=>333,
+	chr(176)=>400,chr(177)=>675,chr(178)=>300,chr(179)=>300,chr(180)=>333,chr(181)=>500,chr(182)=>523,chr(183)=>250,chr(184)=>333,chr(185)=>300,chr(186)=>310,chr(187)=>500,chr(188)=>750,chr(189)=>750,chr(190)=>750,chr(191)=>500,chr(192)=>611,chr(193)=>611,chr(194)=>611,chr(195)=>611,chr(196)=>611,chr(197)=>611,
+	chr(198)=>889,chr(199)=>667,chr(200)=>611,chr(201)=>611,chr(202)=>611,chr(203)=>611,chr(204)=>333,chr(205)=>333,chr(206)=>333,chr(207)=>333,chr(208)=>722,chr(209)=>667,chr(210)=>722,chr(211)=>722,chr(212)=>722,chr(213)=>722,chr(214)=>722,chr(215)=>675,chr(216)=>722,chr(217)=>722,chr(218)=>722,chr(219)=>722,
+	chr(220)=>722,chr(221)=>556,chr(222)=>611,chr(223)=>500,chr(224)=>500,chr(225)=>500,chr(226)=>500,chr(227)=>500,chr(228)=>500,chr(229)=>500,chr(230)=>667,chr(231)=>444,chr(232)=>444,chr(233)=>444,chr(234)=>444,chr(235)=>444,chr(236)=>278,chr(237)=>278,chr(238)=>278,chr(239)=>278,chr(240)=>500,chr(241)=>500,
+	chr(242)=>500,chr(243)=>500,chr(244)=>500,chr(245)=>500,chr(246)=>500,chr(247)=>675,chr(248)=>500,chr(249)=>500,chr(250)=>500,chr(251)=>500,chr(252)=>500,chr(253)=>444,chr(254)=>500,chr(255)=>444);
Added: trunk/mapbender/http/extensions/fpdf/fpdf.php
--- trunk/mapbender/http/extensions/fpdf/fpdf.php	                        (rev 0)
+++ trunk/mapbender/http/extensions/fpdf/fpdf.php	2010-01-19 23:07:49 UTC (rev 5359)
@@ -0,0 +1,1732 @@
+<?php
+* FPDF        *
+* Version: 1.6        *
+define('FPDF_VERSION','1.6');
+class FPDF
+var $page;               //current page number
+var $n;                  //current object number
+var $offsets;            //array of object offsets
+var $buffer;             //buffer holding in-memory PDF
+var $pages;              //array containing pages
+var $state;              //current document state
+var $compress;           //compression flag
+var $k;                  //scale factor (number of points in user unit)
+var $DefOrientation;     //default orientation
+var $CurOrientation;     //current orientation
+var $PageFormats;        //available page formats
+var $DefPageFormat;      //default page format
+var $CurPageFormat;      //current page format
+var $PageSizes;          //array storing non-default page sizes
+var $wPt,$hPt;           //dimensions of current page in points
+var $w,$h;               //dimensions of current page in user unit
+var $lMargin;            //left margin
+var $tMargin;            //top margin
+var $rMargin;            //right margin
+var $bMargin;            //page break margin
+var $cMargin;            //cell margin
+var $x,$y;               //current position in user unit
+var $lasth;              //height of last printed cell
+var $LineWidth;          //line width in user unit
+var $CoreFonts;          //array of standard font names
+var $fonts;              //array of used fonts
+var $FontFiles;          //array of font files
+var $diffs;              //array of encoding differences
+var $FontFamily;         //current font family
+var $FontStyle;          //current font style
+var $underline;          //underlining flag
+var $CurrentFont;        //current font info
+var $FontSizePt;         //current font size in points
+var $FontSize;           //current font size in user unit
+var $DrawColor;          //commands for drawing color
+var $FillColor;          //commands for filling color
+var $TextColor;          //commands for text color
+var $ColorFlag;          //indicates whether fill and text colors are different
+var $ws;                 //word spacing
+var $images;             //array of used images
+var $PageLinks;          //array of links in pages
+var $links;              //array of internal links
+var $AutoPageBreak;      //automatic page breaking
+var $PageBreakTrigger;   //threshold used to trigger page breaks
+var $InHeader;           //flag set when processing header
+var $InFooter;           //flag set when processing footer
+var $ZoomMode;           //zoom display mode
+var $LayoutMode;         //layout display mode
+var $title;              //title
+var $subject;            //subject
+var $author;             //author
+var $keywords;           //keywords
+var $creator;            //creator
+var $AliasNbPages;       //alias for total number of pages
+var $PDFVersion;         //PDF version number
+*                               Public methods                                 *
+function FPDF($orientation='P', $unit='mm', $format='A4')
+	//Some checks
+	$this->_dochecks();
+	//Initialization of properties
+	$this->page=0;
+	$this->n=2;
+	$this->buffer='';
+	$this->pages=array();
+	$this->PageSizes=array();
+	$this->state=0;
+	$this->fonts=array();
+	$this->FontFiles=array();
+	$this->diffs=array();
+	$this->images=array();
+	$this->links=array();
+	$this->InHeader=false;
+	$this->InFooter=false;
+	$this->lasth=0;
+	$this->FontFamily='';
+	$this->FontStyle='';
+	$this->FontSizePt=12;
+	$this->underline=false;
+	$this->DrawColor='0 G';
+	$this->FillColor='0 g';
+	$this->TextColor='0 g';
+	$this->ColorFlag=false;
+	$this->ws=0;
+	//Standard fonts
+	$this->CoreFonts=array('courier'=>'Courier', 'courierB'=>'Courier-Bold', 'courierI'=>'Courier-Oblique', 'courierBI'=>'Courier-BoldOblique',
+		'helvetica'=>'Helvetica', 'helveticaB'=>'Helvetica-Bold', 'helveticaI'=>'Helvetica-Oblique', 'helveticaBI'=>'Helvetica-BoldOblique',
+		'times'=>'Times-Roman', 'timesB'=>'Times-Bold', 'timesI'=>'Times-Italic', 'timesBI'=>'Times-BoldItalic',
+		'symbol'=>'Symbol', 'zapfdingbats'=>'ZapfDingbats');
+	//Scale factor
+	if($unit=='pt')
+		$this->k=1;
+	elseif($unit=='mm')
+		$this->k=72/25.4;
+	elseif($unit=='cm')
+		$this->k=72/2.54;
+	elseif($unit=='in')
+		$this->k=72;
+	else
+		$this->Error('Incorrect unit: '.$unit);
+	//Page format
+	$this->PageFormats=array('a3'=>array(841.89,1190.55), 'a4'=>array(595.28,841.89), 'a5'=>array(420.94,595.28),
+		'letter'=>array(612,792), 'legal'=>array(612,1008));
+	if(is_string($format))
+		$format=$this->_getpageformat($format);
+	$this->DefPageFormat=$format;
+	$this->CurPageFormat=$format;
+	//Page orientation
+	$orientation=strtolower($orientation);
+	if($orientation=='p' || $orientation=='portrait')
+		$this->DefOrientation='P';
+		$this->w=$this->DefPageFormat[0];
+		$this->h=$this->DefPageFormat[1];
+	elseif($orientation=='l' || $orientation=='landscape')
+		$this->DefOrientation='L';
+		$this->w=$this->DefPageFormat[1];
+		$this->h=$this->DefPageFormat[0];
+	else
+		$this->Error('Incorrect orientation: '.$orientation);
+	$this->CurOrientation=$this->DefOrientation;
+	$this->wPt=$this->w*$this->k;
+	$this->hPt=$this->h*$this->k;
+	//Page margins (1 cm)
+	$margin=28.35/$this->k;
+	$this->SetMargins($margin,$margin);
+	//Interior cell margin (1 mm)
+	$this->cMargin=$margin/10;
+	//Line width (0.2 mm)
+	$this->LineWidth=.567/$this->k;
+	//Automatic page break
+	$this->SetAutoPageBreak(true,2*$margin);
+	//Full width display mode
+	$this->SetDisplayMode('fullwidth');
+	//Enable compression
+	$this->SetCompression(true);
+	//Set default PDF version number
+	$this->PDFVersion='1.3';
+function SetMargins($left, $top, $right=null)
+	//Set left, top and right margins
+	$this->lMargin=$left;
+	$this->tMargin=$top;
+	if($right===null)
+		$right=$left;
+	$this->rMargin=$right;
+function SetLeftMargin($margin)
+	//Set left margin
+	$this->lMargin=$margin;
+	if($this->page>0 && $this->x<$margin)
+		$this->x=$margin;
+function SetTopMargin($margin)
+	//Set top margin
+	$this->tMargin=$margin;
+function SetRightMargin($margin)
+	//Set right margin
+	$this->rMargin=$margin;
+function SetAutoPageBreak($auto, $margin=0)
+	//Set auto page break mode and triggering margin
+	$this->AutoPageBreak=$auto;
+	$this->bMargin=$margin;
+	$this->PageBreakTrigger=$this->h-$margin;
+function SetDisplayMode($zoom, $layout='continuous')
+	//Set display mode in viewer
+	if($zoom=='fullpage' || $zoom=='fullwidth' || $zoom=='real' || $zoom=='default' || !is_string($zoom))
+		$this->ZoomMode=$zoom;
+	else
+		$this->Error('Incorrect zoom display mode: '.$zoom);
+	if($layout=='single' || $layout=='continuous' || $layout=='two' || $layout=='default')
+		$this->LayoutMode=$layout;
+	else
+		$this->Error('Incorrect layout display mode: '.$layout);
+function SetCompression($compress)
+	//Set page compression
+		$this->compress=$compress;
+	else
+		$this->compress=false;
+function SetTitle($title, $isUTF8=false)
+	//Title of document
+	if($isUTF8)
+		$title=$this->_UTF8toUTF16($title);
+	$this->title=$title;
+function SetSubject($subject, $isUTF8=false)
+	//Subject of document
+	if($isUTF8)
+		$subject=$this->_UTF8toUTF16($subject);
+	$this->subject=$subject;
+function SetAuthor($author, $isUTF8=false)
+	//Author of document
+	if($isUTF8)
+		$author=$this->_UTF8toUTF16($author);
+	$this->author=$author;
+function SetKeywords($keywords, $isUTF8=false)
+	//Keywords of document
+	if($isUTF8)
+		$keywords=$this->_UTF8toUTF16($keywords);
+	$this->keywords=$keywords;
+function SetCreator($creator, $isUTF8=false)
+	//Creator of document
+	if($isUTF8)
+		$creator=$this->_UTF8toUTF16($creator);
+	$this->creator=$creator;
+function AliasNbPages($alias='{nb}')
+	//Define an alias for total number of pages
+	$this->AliasNbPages=$alias;
+function Error($msg)
+	//Fatal error
+	die('<b>FPDF error:</b> '.$msg);
+function Open()
+	//Begin document
+	$this->state=1;
+function Close()
+	//Terminate document
+	if($this->state==3)
+		return;
+	if($this->page==0)
+		$this->AddPage();
+	//Page footer
+	$this->InFooter=true;
+	$this->Footer();
+	//Close page
+	$this->_endpage();
+	//Close document
+	$this->_enddoc();
+function AddPage($orientation='', $format='')
+	//Start a new page
+	if($this->state==0)
+		$this->Open();
+	$family=$this->FontFamily;
+	$style=$this->FontStyle.($this->underline ? 'U' : '');
+	$size=$this->FontSizePt;
+	$lw=$this->LineWidth;
+	$dc=$this->DrawColor;
+	$fc=$this->FillColor;
+	$tc=$this->TextColor;
+	$cf=$this->ColorFlag;
+	if($this->page>0)
+		//Page footer
+		$this->Footer();
+		//Close page
+	//Start new page
+	$this->_beginpage($orientation,$format);
+	//Set line cap style to square
+	$this->_out('2 J');
+	//Set line width
+	$this->LineWidth=$lw;
+	$this->_out(sprintf('%.2F w',$lw*$this->k));
+	//Set font
+	if($family)
+		$this->SetFont($family,$style,$size);
+	//Set colors
+	$this->DrawColor=$dc;
+	if($dc!='0 G')
+		$this->_out($dc);
+	$this->FillColor=$fc;
+	if($fc!='0 g')
+		$this->_out($fc);
+	$this->TextColor=$tc;
+	$this->ColorFlag=$cf;
+	//Page header
+	$this->InHeader=true;
+	$this->Header();
+	//Restore line width
+	if($this->LineWidth!=$lw)
+	//Restore font
+	if($family)
+	//Restore colors
+	if($this->DrawColor!=$dc)
+		$this->_out($dc);
+	if($this->FillColor!=$fc)
+		$this->_out($fc);
+function Header()
+	//To be implemented in your own inherited class
+function Footer()
+function PageNo()
+	//Get current page number
+	return $this->page;
+function SetDrawColor($r, $g=null, $b=null)
+	//Set color for all stroking operations
+	if(($r==0 && $g==0 && $b==0) || $g===null)
+		$this->DrawColor=sprintf('%.3F G',$r/255);
+	else
+		$this->DrawColor=sprintf('%.3F %.3F %.3F RG',$r/255,$g/255,$b/255);
+	if($this->page>0)
+		$this->_out($this->DrawColor);
+function SetFillColor($r, $g=null, $b=null)
+	//Set color for all filling operations
+		$this->FillColor=sprintf('%.3F g',$r/255);
+	else
+		$this->FillColor=sprintf('%.3F %.3F %.3F rg',$r/255,$g/255,$b/255);
+	$this->ColorFlag=($this->FillColor!=$this->TextColor);
+	if($this->page>0)
+		$this->_out($this->FillColor);
+function SetTextColor($r, $g=null, $b=null)
+	//Set color for text
+		$this->TextColor=sprintf('%.3F g',$r/255);
+	else
+		$this->TextColor=sprintf('%.3F %.3F %.3F rg',$r/255,$g/255,$b/255);
+function GetStringWidth($s)
+	//Get width of a string in the current font
+	$s=(string)$s;
+	$cw=&$this->CurrentFont['cw'];
+	$w=0;
+	$l=strlen($s);
+	for($i=0;$i<$l;$i++)
+		$w+=$cw[$s[$i]];
+	return $w*$this->FontSize/1000;
+function SetLineWidth($width)
+	//Set line width
+	$this->LineWidth=$width;
+	if($this->page>0)
+		$this->_out(sprintf('%.2F w',$width*$this->k));
+function Line($x1, $y1, $x2, $y2)
+	//Draw a line
+	$this->_out(sprintf('%.2F %.2F m %.2F %.2F l S',$x1*$this->k,($this->h-$y1)*$this->k,$x2*$this->k,($this->h-$y2)*$this->k));
+function Rect($x, $y, $w, $h, $style='')
+	//Draw a rectangle
+	if($style=='F')
+		$op='f';
+	elseif($style=='FD' || $style=='DF')
+		$op='B';
+	else
+		$op='S';
+	$this->_out(sprintf('%.2F %.2F %.2F %.2F re %s',$x*$this->k,($this->h-$y)*$this->k,$w*$this->k,-$h*$this->k,$op));
+function AddFont($family, $style='', $file='')
+	//Add a TrueType or Type1 font
+	$family=strtolower($family);
+	if($file=='')
+		$file=str_replace(' ','',$family).strtolower($style).'.php';
+	if($family=='arial')
+		$family='helvetica';
+	$style=strtoupper($style);
+	if($style=='IB')
+		$style='BI';
+	$fontkey=$family.$style;
+	if(isset($this->fonts[$fontkey]))
+		return;
+	include($this->_getfontpath().$file);
+	if(!isset($name))
+		$this->Error('Could not include font definition file');
+	$i=count($this->fonts)+1;
+	$this->fonts[$fontkey]=array('i'=>$i, 'type'=>$type, 'name'=>$name, 'desc'=>$desc, 'up'=>$up, 'ut'=>$ut, 'cw'=>$cw, 'enc'=>$enc, 'file'=>$file);
+	if($diff)
+		//Search existing encodings
+		$d=0;
+		$nb=count($this->diffs);
+		for($i=1;$i<=$nb;$i++)
+			if($this->diffs[$i]==$diff)
+				$d=$i;
+				break;
+		if($d==0)
+			$d=$nb+1;
+			$this->diffs[$d]=$diff;
+		$this->fonts[$fontkey]['diff']=$d;
+	if($file)
+			$this->FontFiles[$file]=array('length1'=>$originalsize);
+		else
+			$this->FontFiles[$file]=array('length1'=>$size1, 'length2'=>$size2);
+function SetFont($family, $style='', $size=0)
+	//Select a font; size given in points
+	global $fpdf_charwidths;
+	if($family=='')
+	elseif($family=='symbol' || $family=='zapfdingbats')
+		$style='';
+	if(strpos($style,'U')!==false)
+		$this->underline=true;
+		$style=str_replace('U','',$style);
+	else
+	if($style=='IB')
+		$style='BI';
+	if($size==0)
+	//Test if font is already selected
+	if($this->FontFamily==$family && $this->FontStyle==$style && $this->FontSizePt==$size)
+		return;
+	//Test if used for the first time
+	if(!isset($this->fonts[$fontkey]))
+		//Check if one of the standard fonts
+		if(isset($this->CoreFonts[$fontkey]))
+			if(!isset($fpdf_charwidths[$fontkey]))
+				//Load metric file
+				$file=$family;
+				if($family=='times' || $family=='helvetica')
+					$file.=strtolower($style);
+				include($this->_getfontpath().$file.'.php');
+					$this->Error('Could not include font metric file');
+			$name=$this->CoreFonts[$fontkey];
+			$cw=$fpdf_charwidths[$fontkey];
+			$this->fonts[$fontkey]=array('i'=>$i, 'type'=>'core', 'name'=>$name, 'up'=>-100, 'ut'=>50, 'cw'=>$cw);
+		else
+			$this->Error('Undefined font: '.$family.' '.$style);
+	//Select it
+	$this->FontFamily=$family;
+	$this->FontStyle=$style;
+	$this->FontSizePt=$size;
+	$this->FontSize=$size/$this->k;
+	$this->CurrentFont=&$this->fonts[$fontkey];
+	if($this->page>0)
+		$this->_out(sprintf('BT /F%d %.2F Tf ET',$this->CurrentFont['i'],$this->FontSizePt));
+function SetFontSize($size)
+	//Set font size in points
+	if($this->FontSizePt==$size)
+		return;
+	if($this->page>0)
+function AddLink()
+	//Create a new internal link
+	$n=count($this->links)+1;
+	$this->links[$n]=array(0, 0);
+	return $n;
+function SetLink($link, $y=0, $page=-1)
+	//Set destination of internal link
+	if($y==-1)
+		$y=$this->y;
+	if($page==-1)
+		$page=$this->page;
+	$this->links[$link]=array($page, $y);
+function Link($x, $y, $w, $h, $link)
+	//Put a link on the page
+	$this->PageLinks[$this->page][]=array($x*$this->k, $this->hPt-$y*$this->k, $w*$this->k, $h*$this->k, $link);
+function Text($x, $y, $txt)
+	//Output a string
+	$s=sprintf('BT %.2F %.2F Td (%s) Tj ET',$x*$this->k,($this->h-$y)*$this->k,$this->_escape($txt));
+	if($this->underline && $txt!='')
+		$s.=' '.$this->_dounderline($x,$y,$txt);
+	if($this->ColorFlag)
+		$s='q '.$this->TextColor.' '.$s.' Q';
+	$this->_out($s);
+function AcceptPageBreak()
+	//Accept automatic page break or not
+	return $this->AutoPageBreak;
+function Cell($w, $h=0, $txt='', $border=0, $ln=0, $align='', $fill=false, $link='')
+	//Output a cell
+	$k=$this->k;
+	if($this->y+$h>$this->PageBreakTrigger && !$this->InHeader && !$this->InFooter && $this->AcceptPageBreak())
+		$x=$this->x;
+		$ws=$this->ws;
+		if($ws>0)
+			$this->ws=0;
+			$this->_out('0 Tw');
+		$this->AddPage($this->CurOrientation,$this->CurPageFormat);
+		$this->x=$x;
+		if($ws>0)
+			$this->ws=$ws;
+			$this->_out(sprintf('%.3F Tw',$ws*$k));
+	if($w==0)
+		$w=$this->w-$this->rMargin-$this->x;
+	$s='';
+	if($fill || $border==1)
+		if($fill)
+			$op=($border==1) ? 'B' : 'f';
+		else
+			$op='S';
+		$s=sprintf('%.2F %.2F %.2F %.2F re %s ',$this->x*$k,($this->h-$this->y)*$k,$w*$k,-$h*$k,$op);
+	if(is_string($border))
+		$x=$this->x;
+		$y=$this->y;
+		if(strpos($border,'L')!==false)
+			$s.=sprintf('%.2F %.2F m %.2F %.2F l S ',$x*$k,($this->h-$y)*$k,$x*$k,($this->h-($y+$h))*$k);
+		if(strpos($border,'T')!==false)
+			$s.=sprintf('%.2F %.2F m %.2F %.2F l S ',$x*$k,($this->h-$y)*$k,($x+$w)*$k,($this->h-$y)*$k);
+		if(strpos($border,'R')!==false)
+			$s.=sprintf('%.2F %.2F m %.2F %.2F l S ',($x+$w)*$k,($this->h-$y)*$k,($x+$w)*$k,($this->h-($y+$h))*$k);
+		if(strpos($border,'B')!==false)
+			$s.=sprintf('%.2F %.2F m %.2F %.2F l S ',$x*$k,($this->h-($y+$h))*$k,($x+$w)*$k,($this->h-($y+$h))*$k);
+	if($txt!=='')
+		if($align=='R')
+			$dx=$w-$this->cMargin-$this->GetStringWidth($txt);
+		elseif($align=='C')
+			$dx=($w-$this->GetStringWidth($txt))/2;
+		else
+			$dx=$this->cMargin;
+			$s.='q '.$this->TextColor.' ';
+		$txt2=str_replace(')','\\)',str_replace('(','\\(',str_replace('\\','\\\\',$txt)));
+		$s.=sprintf('BT %.2F %.2F Td (%s) Tj ET',($this->x+$dx)*$k,($this->h-($this->y+.5*$h+.3*$this->FontSize))*$k,$txt2);
+		if($this->underline)
+			$s.=' '.$this->_dounderline($this->x+$dx,$this->y+.5*$h+.3*$this->FontSize,$txt);
+			$s.=' Q';
+		if($link)
+			$this->Link($this->x+$dx,$this->y+.5*$h-.5*$this->FontSize,$this->GetStringWidth($txt),$this->FontSize,$link);
+	if($s)
+		$this->_out($s);
+	$this->lasth=$h;
+	if($ln>0)
+		//Go to next line
+		$this->y+=$h;
+		if($ln==1)
+			$this->x=$this->lMargin;
+	else
+		$this->x+=$w;
+function MultiCell($w, $h, $txt, $border=0, $align='J', $fill=false)
+	//Output text with automatic or explicit line breaks
+	if($w==0)
+	$wmax=($w-2*$this->cMargin)*1000/$this->FontSize;
+	$s=str_replace("\r",'',$txt);
+	$nb=strlen($s);
+	if($nb>0 && $s[$nb-1]=="\n")
+		$nb--;
+	$b=0;
+	if($border)
+		if($border==1)
+			$border='LTRB';
+			$b='LRT';
+			$b2='LR';
+		else
+			$b2='';
+				$b2.='L';
+				$b2.='R';
+			$b=(strpos($border,'T')!==false) ? $b2.'T' : $b2;
+	$sep=-1;
+	$i=0;
+	$j=0;
+	$l=0;
+	$ns=0;
+	$nl=1;
+	while($i<$nb)
+		//Get next character
+		$c=$s[$i];
+		if($c=="\n")
+			//Explicit line break
+			if($this->ws>0)
+				$this->ws=0;
+			$this->Cell($w,$h,substr($s,$j,$i-$j),$b,2,$align,$fill);
+			$i++;
+			$sep=-1;
+			$j=$i;
+			$l=0;
+			$ns=0;
+			$nl++;
+			if($border && $nl==2)
+				$b=$b2;
+			continue;
+		if($c==' ')
+			$sep=$i;
+			$ls=$l;
+			$ns++;
+		$l+=$cw[$c];
+		if($l>$wmax)
+			//Automatic line break
+			if($sep==-1)
+				if($i==$j)
+					$i++;
+				if($this->ws>0)
+					$this->ws=0;
+			else
+				if($align=='J')
+					$this->ws=($ns>1) ? ($wmax-$ls)/1000*$this->FontSize/($ns-1) : 0;
+					$this->_out(sprintf('%.3F Tw',$this->ws*$this->k));
+				$this->Cell($w,$h,substr($s,$j,$sep-$j),$b,2,$align,$fill);
+				$i=$sep+1;
+			$sep=-1;
+			$j=$i;
+			$l=0;
+			$ns=0;
+			$nl++;
+				$b=$b2;
+		else
+			$i++;
+	//Last chunk
+	if($this->ws>0)
+		$this->ws=0;
+	if($border && strpos($border,'B')!==false)
+		$b.='B';
+function Write($h, $txt, $link='')
+	//Output text in flowing mode
+	$nb=strlen($s);
+	$sep=-1;
+	$i=0;
+	$j=0;
+	$l=0;
+	$nl=1;
+	while($i<$nb)
+		$c=$s[$i];
+		if($c=="\n")
+			$this->Cell($w,$h,substr($s,$j,$i-$j),0,2,'',0,$link);
+			$i++;
+			$sep=-1;
+			$j=$i;
+			$l=0;
+			if($nl==1)
+			$nl++;
+			continue;
+		if($c==' ')
+			$sep=$i;
+		$l+=$cw[$c];
+		if($l>$wmax)
+			if($sep==-1)
+				if($this->x>$this->lMargin)
+					//Move to next line
+					$this->y+=$h;
+					$i++;
+					$nl++;
+					continue;
+				if($i==$j)
+					$i++;
+			else
+				$this->Cell($w,$h,substr($s,$j,$sep-$j),0,2,'',0,$link);
+				$i=$sep+1;
+			$sep=-1;
+			$j=$i;
+			$l=0;
+			if($nl==1)
+			$nl++;
+		else
+			$i++;
+	//Last chunk
+	if($i!=$j)
+		$this->Cell($l/1000*$this->FontSize,$h,substr($s,$j),0,0,'',0,$link);
+function Ln($h=null)
+	//Line feed; default value is last cell height
+	if($h===null)
+		$this->y+=$this->lasth;
+	else
+		$this->y+=$h;
+function Image($file, $x=null, $y=null, $w=0, $h=0, $type='', $link='')
+	//Put an image on the page
+	if(!isset($this->images[$file]))
+		//First use of this image, get info
+		if($type=='')
+			$pos=strrpos($file,'.');
+			if(!$pos)
+				$this->Error('Image file has no extension and no type was specified: '.$file);
+			$type=substr($file,$pos+1);
+		$type=strtolower($type);
+		if($type=='jpeg')
+			$type='jpg';
+		$mtd='_parse'.$type;
+		if(!method_exists($this,$mtd))
+			$this->Error('Unsupported image type: '.$type);
+		$info=$this->$mtd($file);
+		$info['i']=count($this->images)+1;
+		$this->images[$file]=$info;
+	else
+		$info=$this->images[$file];
+	//Automatic width and height calculation if needed
+	if($w==0 && $h==0)
+		//Put image at 72 dpi
+		$w=$info['w']/$this->k;
+		$h=$info['h']/$this->k;
+	elseif($w==0)
+		$w=$h*$info['w']/$info['h'];
+	elseif($h==0)
+		$h=$w*$info['h']/$info['w'];
+	//Flowing mode
+	if($y===null)
+			$x2=$this->x;
+			$this->x=$x2;
+		$y=$this->y;
+		$this->y+=$h;
+	if($x===null)
+		$x=$this->x;
+	$this->_out(sprintf('q %.2F 0 0 %.2F %.2F %.2F cm /I%d Do Q',$w*$this->k,$h*$this->k,$x*$this->k,($this->h-($y+$h))*$this->k,$info['i']));
+	if($link)
+		$this->Link($x,$y,$w,$h,$link);
+function GetX()
+	//Get x position
+	return $this->x;
+function SetX($x)
+	//Set x position
+	if($x>=0)
+		$this->x=$x;
+	else
+		$this->x=$this->w+$x;
+function GetY()
+	//Get y position
+	return $this->y;
+function SetY($y)
+	//Set y position and reset x
+	if($y>=0)
+		$this->y=$y;
+	else
+		$this->y=$this->h+$y;
+function SetXY($x, $y)
+	//Set x and y positions
+	$this->SetY($y);
+	$this->SetX($x);
+function Output($name='', $dest='')
+	//Output PDF to some destination
+	if($this->state<3)
+		$this->Close();
+	$dest=strtoupper($dest);
+	if($dest=='')
+		if($name=='')
+			$name='doc.pdf';
+			$dest='I';
+		else
+			$dest='F';
+	switch($dest)
+		case 'I':
+			//Send to standard output
+			if(ob_get_length())
+				$this->Error('Some data has already been output, can\'t send PDF file');
+			if(php_sapi_name()!='cli')
+				//We send to a browser
+				header('Content-Type: application/pdf');
+				if(headers_sent())
+				header('Content-Length: '.strlen($this->buffer));
+				header('Content-Disposition: inline; filename="'.$name.'"');
+				header('Cache-Control: private, max-age=0, must-revalidate');
+				header('Pragma: public');
+				ini_set('zlib.output_compression','0');
+			echo $this->buffer;
+			break;
+		case 'D':
+			//Download file
+			header('Content-Type: application/x-download');
+			header('Content-Disposition: attachment; filename="'.$name.'"');
+			break;
+		case 'F':
+			//Save to local file
+			$f=fopen($name,'wb');
+			if(!$f)
+				$this->Error('Unable to create output file: '.$name);
+			fwrite($f,$this->buffer,strlen($this->buffer));
+			fclose($f);
+			break;
+		case 'S':
+			//Return as a string
+			return $this->buffer;
+		default:
+			$this->Error('Incorrect output destination: '.$dest);
+	return '';
+*                              Protected methods                               *
+function _dochecks()
+	//Check availability of %F
+	if(sprintf('%.1F',1.0)!='1.0')
+		$this->Error('This version of PHP is not supported');
+	//Check mbstring overloading
+	if(ini_get('mbstring.func_overload') & 2)
+		$this->Error('mbstring overloading must be disabled');
+	//Disable runtime magic quotes
+function _getpageformat($format)
+	$format=strtolower($format);
+	if(!isset($this->PageFormats[$format]))
+		$this->Error('Unknown page format: '.$format);
+	$a=$this->PageFormats[$format];
+	return array($a[0]/$this->k, $a[1]/$this->k);
+function _getfontpath()
+	if(!defined('FPDF_FONTPATH') && is_dir(dirname(__FILE__).'/font'))
+		define('FPDF_FONTPATH',dirname(__FILE__).'/font/');
+	return defined('FPDF_FONTPATH') ? FPDF_FONTPATH : '';
+function _beginpage($orientation, $format)
+	$this->page++;
+	$this->pages[$this->page]='';
+	$this->state=2;
+	$this->y=$this->tMargin;
+	//Check page size
+	if($orientation=='')
+		$orientation=$this->DefOrientation;
+	else
+		$orientation=strtoupper($orientation[0]);
+	if($format=='')
+		$format=$this->DefPageFormat;
+	else
+	if($orientation!=$this->CurOrientation || $format[0]!=$this->CurPageFormat[0] || $format[1]!=$this->CurPageFormat[1])
+		//New size
+		if($orientation=='P')
+			$this->w=$format[0];
+			$this->h=$format[1];
+		else
+			$this->w=$format[1];
+			$this->h=$format[0];
+		$this->PageBreakTrigger=$this->h-$this->bMargin;
+		$this->CurOrientation=$orientation;
+	if($orientation!=$this->DefOrientation || $format[0]!=$this->DefPageFormat[0] || $format[1]!=$this->DefPageFormat[1])
+		$this->PageSizes[$this->page]=array($this->wPt, $this->hPt);
+function _endpage()
+	$this->state=1;
+function _escape($s)
+	//Escape special characters in strings
+	$s=str_replace('\\','\\\\',$s);
+	$s=str_replace('(','\\(',$s);
+	$s=str_replace(')','\\)',$s);
+	$s=str_replace("\r",'\\r',$s);
+	return $s;
+function _textstring($s)
+	//Format a text string
+	return '('.$this->_escape($s).')';
+function _UTF8toUTF16($s)
+	//Convert UTF-8 to UTF-16BE with BOM
+	$res="\xFE\xFF";
+	$nb=strlen($s);
+	$i=0;
+	while($i<$nb)
+		$c1=ord($s[$i++]);
+		if($c1>=224)
+			//3-byte character
+			$c2=ord($s[$i++]);
+			$c3=ord($s[$i++]);
+			$res.=chr((($c1 & 0x0F)<<4) + (($c2 & 0x3C)>>2));
+			$res.=chr((($c2 & 0x03)<<6) + ($c3 & 0x3F));
+		elseif($c1>=192)
+			//2-byte character
+			$res.=chr(($c1 & 0x1C)>>2);
+			$res.=chr((($c1 & 0x03)<<6) + ($c2 & 0x3F));
+		else
+			//Single-byte character
+			$res.="\0".chr($c1);
+	return $res;
+function _dounderline($x, $y, $txt)
+	//Underline text
+	$up=$this->CurrentFont['up'];
+	$ut=$this->CurrentFont['ut'];
+	$w=$this->GetStringWidth($txt)+$this->ws*substr_count($txt,' ');
+	return sprintf('%.2F %.2F %.2F %.2F re f',$x*$this->k,($this->h-($y-$up/1000*$this->FontSize))*$this->k,$w*$this->k,-$ut/1000*$this->FontSizePt);
+function _parsejpg($file)
+	//Extract info from a JPEG file
+	$a=GetImageSize($file);
+	if(!$a)
+		$this->Error('Missing or incorrect image file: '.$file);
+	if($a[2]!=2)
+		$this->Error('Not a JPEG file: '.$file);
+	if(!isset($a['channels']) || $a['channels']==3)
+		$colspace='DeviceRGB';
+	elseif($a['channels']==4)
+		$colspace='DeviceCMYK';
+	else
+		$colspace='DeviceGray';
+	$bpc=isset($a['bits']) ? $a['bits'] : 8;
+	//Read whole file
+	$data='';
+	while(!feof($f))
+		$data.=fread($f,8192);
+	fclose($f);
+	return array('w'=>$a[0], 'h'=>$a[1], 'cs'=>$colspace, 'bpc'=>$bpc, 'f'=>'DCTDecode', 'data'=>$data);
+function _parsepng($file)
+	//Extract info from a PNG file
+	if(!$f)
+		$this->Error('Can\'t open image file: '.$file);
+	//Check signature
+	if($this->_readstream($f,8)!=chr(137).'PNG'.chr(13).chr(10).chr(26).chr(10))
+		$this->Error('Not a PNG file: '.$file);
+	//Read header chunk
+	$this->_readstream($f,4);
+	if($this->_readstream($f,4)!='IHDR')
+		$this->Error('Incorrect PNG file: '.$file);
+	$w=$this->_readint($f);
+	$h=$this->_readint($f);
+	$bpc=ord($this->_readstream($f,1));
+	if($bpc>8)
+		$this->Error('16-bit depth not supported: '.$file);
+	$ct=ord($this->_readstream($f,1));
+	if($ct==0)
+	elseif($ct==2)
+	elseif($ct==3)
+		$colspace='Indexed';
+	else
+		$this->Error('Alpha channel not supported: '.$file);
+	if(ord($this->_readstream($f,1))!=0)
+		$this->Error('Unknown compression method: '.$file);
+		$this->Error('Unknown filter method: '.$file);
+		$this->Error('Interlacing not supported: '.$file);
+	$parms='/DecodeParms <</Predictor 15 /Colors '.($ct==2 ? 3 : 1).' /BitsPerComponent '.$bpc.' /Columns '.$w.'>>';
+	//Scan chunks looking for palette, transparency and image data
+	$pal='';
+	$trns='';
+	$data='';
+	do
+		$n=$this->_readint($f);
+		$type=$this->_readstream($f,4);
+		if($type=='PLTE')
+			//Read palette
+			$pal=$this->_readstream($f,$n);
+		elseif($type=='tRNS')
+			//Read transparency info
+			$t=$this->_readstream($f,$n);
+			if($ct==0)
+				$trns=array(ord(substr($t,1,1)));
+			elseif($ct==2)
+				$trns=array(ord(substr($t,1,1)), ord(substr($t,3,1)), ord(substr($t,5,1)));
+			else
+				$pos=strpos($t,chr(0));
+				if($pos!==false)
+					$trns=array($pos);
+		elseif($type=='IDAT')
+			//Read image data block
+			$data.=$this->_readstream($f,$n);
+		elseif($type=='IEND')
+			break;
+		else
+			$this->_readstream($f,$n+4);
+	while($n);
+	if($colspace=='Indexed' && empty($pal))
+		$this->Error('Missing palette in '.$file);
+	fclose($f);
+	return array('w'=>$w, 'h'=>$h, 'cs'=>$colspace, 'bpc'=>$bpc, 'f'=>'FlateDecode', 'parms'=>$parms, 'pal'=>$pal, 'trns'=>$trns, 'data'=>$data);
+function _readstream($f, $n)
+	//Read n bytes from stream
+	$res='';
+	while($n>0 && !feof($f))
+		$s=fread($f,$n);
+		if($s===false)
+			$this->Error('Error while reading stream');
+		$n-=strlen($s);
+		$res.=$s;
+	if($n>0)
+		$this->Error('Unexpected end of stream');
+	return $res;
+function _readint($f)
+	//Read a 4-byte integer from stream
+	$a=unpack('Ni',$this->_readstream($f,4));
+	return $a['i'];
+function _parsegif($file)
+	//Extract info from a GIF file (via PNG conversion)
+	if(!function_exists('imagepng'))
+		$this->Error('GD extension is required for GIF support');
+	if(!function_exists('imagecreatefromgif'))
+		$this->Error('GD has no GIF read support');
+	$im=imagecreatefromgif($file);
+	if(!$im)
+	imageinterlace($im,0);
+	$tmp=tempnam('.','gif');
+	if(!$tmp)
+		$this->Error('Unable to create a temporary file');
+	if(!imagepng($im,$tmp))
+		$this->Error('Error while saving to temporary file');
+	imagedestroy($im);
+	$info=$this->_parsepng($tmp);
+	unlink($tmp);
+	return $info;
+function _newobj()
+	//Begin a new object
+	$this->n++;
+	$this->offsets[$this->n]=strlen($this->buffer);
+	$this->_out($this->n.' 0 obj');
+function _putstream($s)
+	$this->_out('stream');
+	$this->_out($s);
+	$this->_out('endstream');
+function _out($s)
+	//Add a line to the document
+	if($this->state==2)
+		$this->pages[$this->page].=$s."\n";
+	else
+		$this->buffer.=$s."\n";
+function _putpages()
+	$nb=$this->page;
+	if(!empty($this->AliasNbPages))
+		//Replace number of pages
+		for($n=1;$n<=$nb;$n++)
+			$this->pages[$n]=str_replace($this->AliasNbPages,$nb,$this->pages[$n]);
+	if($this->DefOrientation=='P')
+		$wPt=$this->DefPageFormat[0]*$this->k;
+		$hPt=$this->DefPageFormat[1]*$this->k;
+	else
+		$wPt=$this->DefPageFormat[1]*$this->k;
+		$hPt=$this->DefPageFormat[0]*$this->k;
+	$filter=($this->compress) ? '/Filter /FlateDecode ' : '';
+		//Page
+		$this->_newobj();
+		$this->_out('<</Type /Page');
+		$this->_out('/Parent 1 0 R');
+		if(isset($this->PageSizes[$n]))
+			$this->_out(sprintf('/MediaBox [0 0 %.2F %.2F]',$this->PageSizes[$n][0],$this->PageSizes[$n][1]));
+		$this->_out('/Resources 2 0 R');
+		if(isset($this->PageLinks[$n]))
+			//Links
+			$annots='/Annots [';
+			foreach($this->PageLinks[$n] as $pl)
+				$rect=sprintf('%.2F %.2F %.2F %.2F',$pl[0],$pl[1],$pl[0]+$pl[2],$pl[1]-$pl[3]);
+				$annots.='<</Type /Annot /Subtype /Link /Rect ['.$rect.'] /Border [0 0 0] ';
+				if(is_string($pl[4]))
+					$annots.='/A <</S /URI /URI '.$this->_textstring($pl[4]).'>>>>';
+				else
+					$l=$this->links[$pl[4]];
+					$h=isset($this->PageSizes[$l[0]]) ? $this->PageSizes[$l[0]][1] : $hPt;
+					$annots.=sprintf('/Dest [%d 0 R /XYZ 0 %.2F null]>>',1+2*$l[0],$h-$l[1]*$this->k);
+			$this->_out($annots.']');
+		$this->_out('/Contents '.($this->n+1).' 0 R>>');
+		$this->_out('endobj');
+		//Page content
+		$p=($this->compress) ? gzcompress($this->pages[$n]) : $this->pages[$n];
+		$this->_newobj();
+		$this->_out('<<'.$filter.'/Length '.strlen($p).'>>');
+		$this->_putstream($p);
+	//Pages root
+	$this->offsets[1]=strlen($this->buffer);
+	$this->_out('1 0 obj');
+	$this->_out('<</Type /Pages');
+	$kids='/Kids [';
+		$kids.=(3+2*$i).' 0 R ';
+	$this->_out($kids.']');
+	$this->_out('/Count '.$nb);
+	$this->_out(sprintf('/MediaBox [0 0 %.2F %.2F]',$wPt,$hPt));
+	$this->_out('>>');
+function _putfonts()
+	$nf=$this->n;
+	foreach($this->diffs as $diff)
+		//Encodings
+		$this->_newobj();
+		$this->_out('<</Type /Encoding /BaseEncoding /WinAnsiEncoding /Differences ['.$diff.']>>');
+	foreach($this->FontFiles as $file=>$info)
+		//Font file embedding
+		$this->_newobj();
+		$this->FontFiles[$file]['n']=$this->n;
+		$font='';
+		$f=fopen($this->_getfontpath().$file,'rb',1);
+		if(!$f)
+			$this->Error('Font file not found');
+		while(!feof($f))
+			$font.=fread($f,8192);
+		fclose($f);
+		$compressed=(substr($file,-2)=='.z');
+		if(!$compressed && isset($info['length2']))
+			$header=(ord($font[0])==128);
+			if($header)
+				$font=substr($font,6);
+			if($header && ord($font[$info['length1']])==128)
+				$font=substr($font,0,$info['length1']).substr($font,$info['length1']+6);
+		$this->_out('<</Length '.strlen($font));
+		if($compressed)
+			$this->_out('/Filter /FlateDecode');
+		$this->_out('/Length1 '.$info['length1']);
+		if(isset($info['length2']))
+			$this->_out('/Length2 '.$info['length2'].' /Length3 0');
+		$this->_putstream($font);
+	foreach($this->fonts as $k=>$font)
+		//Font objects
+		$this->fonts[$k]['n']=$this->n+1;
+		$type=$font['type'];
+		$name=$font['name'];
+		if($type=='core')
+			//Standard font
+			$this->_newobj();
+			$this->_out('<</Type /Font');
+			$this->_out('/BaseFont /'.$name);
+			$this->_out('/Subtype /Type1');
+			if($name!='Symbol' && $name!='ZapfDingbats')
+				$this->_out('/Encoding /WinAnsiEncoding');
+		elseif($type=='Type1' || $type=='TrueType')
+			//Additional Type1 or TrueType font
+			$this->_newobj();
+			$this->_out('/Subtype /'.$type);
+			$this->_out('/FirstChar 32 /LastChar 255');
+			$this->_out('/Widths '.($this->n+1).' 0 R');
+			$this->_out('/FontDescriptor '.($this->n+2).' 0 R');
+			if($font['enc'])
+				if(isset($font['diff']))
+					$this->_out('/Encoding '.($nf+$font['diff']).' 0 R');
+				else
+			//Widths
+			$this->_newobj();
+			$cw=&$font['cw'];
+			$s='[';
+				$s.=$cw[chr($i)].' ';
+			$this->_out($s.']');
+			//Descriptor
+			$this->_newobj();
+			$s='<</Type /FontDescriptor /FontName /'.$name;
+			foreach($font['desc'] as $k=>$v)
+				$s.=' /'.$k.' '.$v;
+			$file=$font['file'];
+			if($file)
+				$s.=' /FontFile'.($type=='Type1' ? '' : '2').' '.$this->FontFiles[$file]['n'].' 0 R';
+			$this->_out($s.'>>');
+		else
+			//Allow for additional types
+			$mtd='_put'.strtolower($type);
+				$this->Error('Unsupported font type: '.$type);
+			$this->$mtd($font);
+function _putimages()
+	reset($this->images);
+	while(list($file,$info)=each($this->images))
+		$this->_newobj();
+		$this->images[$file]['n']=$this->n;
+		$this->_out('<</Type /XObject');
+		$this->_out('/Subtype /Image');
+		$this->_out('/Width '.$info['w']);
+		$this->_out('/Height '.$info['h']);
+		if($info['cs']=='Indexed')
+			$this->_out('/ColorSpace [/Indexed /DeviceRGB '.(strlen($info['pal'])/3-1).' '.($this->n+1).' 0 R]');
+		else
+			$this->_out('/ColorSpace /'.$info['cs']);
+			if($info['cs']=='DeviceCMYK')
+				$this->_out('/Decode [1 0 1 0 1 0 1 0]');
+		$this->_out('/BitsPerComponent '.$info['bpc']);
+		if(isset($info['f']))
+			$this->_out('/Filter /'.$info['f']);
+		if(isset($info['parms']))
+			$this->_out($info['parms']);
+		if(isset($info['trns']) && is_array($info['trns']))
+			$trns='';
+			for($i=0;$i<count($info['trns']);$i++)
+				$trns.=$info['trns'][$i].' '.$info['trns'][$i].' ';
+			$this->_out('/Mask ['.$trns.']');
+		$this->_out('/Length '.strlen($info['data']).'>>');
+		$this->_putstream($info['data']);
+		unset($this->images[$file]['data']);
+		//Palette
+			$this->_newobj();
+			$pal=($this->compress) ? gzcompress($info['pal']) : $info['pal'];
+			$this->_out('<<'.$filter.'/Length '.strlen($pal).'>>');
+			$this->_putstream($pal);
+function _putxobjectdict()
+	foreach($this->images as $image)
+		$this->_out('/I'.$image['i'].' '.$image['n'].' 0 R');
+function _putresourcedict()
+	$this->_out('/ProcSet [/PDF /Text /ImageB /ImageC /ImageI]');
+	$this->_out('/Font <<');
+	foreach($this->fonts as $font)
+		$this->_out('/F'.$font['i'].' '.$font['n'].' 0 R');
+	$this->_out('/XObject <<');
+	$this->_putxobjectdict();
+function _putresources()
+	$this->_putfonts();
+	$this->_putimages();
+	//Resource dictionary
+	$this->offsets[2]=strlen($this->buffer);
+	$this->_out('2 0 obj');
+	$this->_out('<<');
+	$this->_putresourcedict();
+function _putinfo()
+	$this->_out('/Producer '.$this->_textstring('FPDF '.FPDF_VERSION));
+	if(!empty($this->title))
+		$this->_out('/Title '.$this->_textstring($this->title));
+	if(!empty($this->subject))
+		$this->_out('/Subject '.$this->_textstring($this->subject));
+	if(!empty($this->author))
+		$this->_out('/Author '.$this->_textstring($this->author));
+	if(!empty($this->keywords))
+		$this->_out('/Keywords '.$this->_textstring($this->keywords));
+	if(!empty($this->creator))
+		$this->_out('/Creator '.$this->_textstring($this->creator));
+	$this->_out('/CreationDate '.$this->_textstring('D:'. at date('YmdHis')));
+function _putcatalog()
+	$this->_out('/Type /Catalog');
+	$this->_out('/Pages 1 0 R');
+	if($this->ZoomMode=='fullpage')
+		$this->_out('/OpenAction [3 0 R /Fit]');
+	elseif($this->ZoomMode=='fullwidth')
+		$this->_out('/OpenAction [3 0 R /FitH null]');
+	elseif($this->ZoomMode=='real')
+		$this->_out('/OpenAction [3 0 R /XYZ null null 1]');
+	elseif(!is_string($this->ZoomMode))
+		$this->_out('/OpenAction [3 0 R /XYZ null null '.($this->ZoomMode/100).']');
+	if($this->LayoutMode=='single')
+		$this->_out('/PageLayout /SinglePage');
+	elseif($this->LayoutMode=='continuous')
+		$this->_out('/PageLayout /OneColumn');
+	elseif($this->LayoutMode=='two')
+		$this->_out('/PageLayout /TwoColumnLeft');
+function _putheader()
+	$this->_out('%PDF-'.$this->PDFVersion);
+function _puttrailer()
+	$this->_out('/Size '.($this->n+1));
+	$this->_out('/Root '.$this->n.' 0 R');
+	$this->_out('/Info '.($this->n-1).' 0 R');
+function _enddoc()
+	$this->_putheader();
+	$this->_putpages();
+	$this->_putresources();
+	//Info
+	$this->_newobj();
+	$this->_putinfo();
+	//Catalog
+	$this->_newobj();
+	$this->_putcatalog();
+	//Cross-ref
+	$o=strlen($this->buffer);
+	$this->_out('xref');
+	$this->_out('0 '.($this->n+1));
+	$this->_out('0000000000 65535 f ');
+	for($i=1;$i<=$this->n;$i++)
+		$this->_out(sprintf('%010d 00000 n ',$this->offsets[$i]));
+	//Trailer
+	$this->_out('trailer');
+	$this->_puttrailer();
+	$this->_out('startxref');
+	$this->_out($o);
+	$this->_out('%%EOF');
+	$this->state=3;
+//End of class
+//Handle special IE contype request
+if(isset($_SERVER['HTTP_USER_AGENT']) && $_SERVER['HTTP_USER_AGENT']=='contype')
+	exit;
Added: trunk/mapbender/http/extensions/fpdf/fpdf_tpl.php
--- trunk/mapbender/http/extensions/fpdf/fpdf_tpl.php	                        (rev 0)
+++ trunk/mapbender/http/extensions/fpdf/fpdf_tpl.php	2010-01-19 23:07:49 UTC (rev 5359)
@@ -0,0 +1,399 @@
+<?php
+//  FPDF_TPL - Version 1.1.2
+//    Copyright 2004-2008 Setasign - Jan Slabon
+//  Licensed under the Apache License, Version 2.0 (the "License");
+//  you may not use this file except in compliance with the License.
+//  You may obtain a copy of the License at
+//      http://www.apache.org/licenses/LICENSE-2.0
+//  Unless required by applicable law or agreed to in writing, software
+//  distributed under the License is distributed on an "AS IS" BASIS,
+//  WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
+//  See the License for the specific language governing permissions and
+//  limitations under the License.
+require_once("fpdf.php");
+class FPDF_TPL extends FPDF {
+     * Array of Tpl-Data
+     * @var array
+    var $tpls = array();
+     * Current Template-ID
+     * @var int
+    var $tpl = 0;
+     * "In Template"-Flag
+     * @var boolean
+    var $_intpl = false;
+     * Nameprefix of Templates used in Resources-Dictonary
+     * @var string A String defining the Prefix used as Template-Object-Names. Have to beginn with an /
+    var $tplprefix = "/TPL";
+     * Resources used By Templates and Pages
+     * @var array
+    var $_res = array();
+     * Start a Template
+     * This method starts a template. You can give own coordinates to build an own sized
+     * Template. Pay attention, that the margins are adapted to the new templatesize.
+     * If you want to write outside the template, for example to build a clipped Template,
+     * you have to set the Margins and "Cursor"-Position manual after beginTemplate-Call.
+     * If no parameter is given, the template uses the current page-size.
+     * The Method returns an ID of the current Template. This ID is used later for using this template.
+     * Warning: A created Template is used in PDF at all events. Still if you don't use it after creation!
+     * @param int $x The x-coordinate given in user-unit
+     * @param int $y The y-coordinate given in user-unit
+     * @param int $w The width given in user-unit
+     * @param int $h The height given in user-unit
+     * @return int The ID of new created Template
+    function beginTemplate($x=null, $y=null, $w=null, $h=null) {
+        if ($this->page <= 0)
+            $this->error("You have to add a page to fpdf first!");
+        if ($x == null)
+            $x = 0;
+        if ($y == null)
+            $y = 0;
+        if ($w == null)
+            $w = $this->w;
+        if ($h == null)
+            $h = $this->h;
+        // Save settings
+        $this->tpl++;
+        $tpl =& $this->tpls[$this->tpl];
+        $tpl = array(
+            'o_x' => $this->x,
+            'o_y' => $this->y,
+            'o_AutoPageBreak' => $this->AutoPageBreak,
+            'o_bMargin' => $this->bMargin,
+            'o_tMargin' => $this->tMargin,
+            'o_lMargin' => $this->lMargin,
+            'o_rMargin' => $this->rMargin,
+            'o_h' => $this->h,
+            'o_w' => $this->w,
+            'buffer' => '',
+            'x' => $x,
+            'y' => $y,
+            'w' => $w,
+            'h' => $h
+        $this->SetAutoPageBreak(false);
+        // Define own high and width to calculate possitions correct
+        $this->h = $h;
+        $this->w = $w;
+        $this->_intpl = true;
+        $this->SetXY($x+$this->lMargin, $y+$this->tMargin);
+        $this->SetRightMargin($this->w-$w+$this->rMargin);
+        return $this->tpl;
+     * End Template
+     * This method ends a template and reset initiated variables on beginTemplate.
+     * @return mixed If a template is opened, the ID is returned. If not a false is returned.
+    function endTemplate() {
+        if ($this->_intpl) {
+            $this->_intpl = false;
+            $this->SetXY($tpl['o_x'], $tpl['o_y']);
+            $this->tMargin = $tpl['o_tMargin'];
+            $this->lMargin = $tpl['o_lMargin'];
+            $this->rMargin = $tpl['o_rMargin'];
+            $this->h = $tpl['o_h'];
+            $this->w = $tpl['o_w'];
+            $this->SetAutoPageBreak($tpl['o_AutoPageBreak'], $tpl['o_bMargin']);
+        } else {
+            return false;
+     * Use a Template in current Page or other Template
+     * You can use a template in a page or in another template.
+     * You can give the used template a new size like you use the Image()-method.
+     * All parameters are optional. The width or height is calculated automaticaly
+     * if one is given. If no parameter is given the origin size as defined in
+     * beginTemplate() is used.
+     * The calculated or used width and height are returned as an array.
+     * @param int $tplidx A valid template-Id
+     * @param int $_x The x-position
+     * @param int $_y The y-position
+     * @param int $_w The new width of the template
+     * @param int $_h The new height of the template
+     * @retrun array The height and width of the template
+    function useTemplate($tplidx, $_x=null, $_y=null, $_w=0, $_h=0) {
+        if (!isset($this->tpls[$tplidx]))
+            $this->error("Template does not exist!");
+            $this->_res['tpl'][$this->tpl]['tpls'][$tplidx] =& $this->tpls[$tplidx];
+        $tpl =& $this->tpls[$tplidx];
+        $x = $tpl['x'];
+        $y = $tpl['y'];
+        $w = $tpl['w'];
+        $h = $tpl['h'];
+        if ($_x == null)
+            $_x = $x;
+        if ($_y == null)
+            $_y = $y;
+        $wh = $this->getTemplateSize($tplidx, $_w, $_h);
+        $_w = $wh['w'];
+        $_h = $wh['h'];
+        $this->_out(sprintf("q %.4f 0 0 %.4f %.2f %.2f cm", ($_w/$w), ($_h/$h), $_x*$this->k, ($this->h-($_y+$_h))*$this->k)); // Translate
+        $this->_out($this->tplprefix.$tplidx." Do Q");
+        return array("w" => $_w, "h" => $_h);
+     * Get The calculated Size of a Template
+     * If one size is given, this method calculates the other one.
+     * @param int $_w The width of the template
+     * @param int $_h The height of the template
+     * @return array The height and width of the template
+    function getTemplateSize($tplidx, $_w=0, $_h=0) {
+        if (!$this->tpls[$tplidx])
+            return false;
+        $w = $tpl['w'];
+        $h = $tpl['h'];
+        if ($_w == 0 and $_h == 0) {
+            $_w = $w;
+            $_h = $h;
+    	if($_w==0)
+    		$_w = $_h*$w/$h;
+    	if($_h==0)
+    		$_h = $_w*$h/$w;
+     * See FPDF-Documentation ;-)
+    function SetFont($family, $style='', $size=0) {
+         * force the resetting of font changes in a template
+            $this->FontFamily = '';
+        parent::SetFont($family, $style, $size);
+        $fontkey = $this->FontFamily.$this->FontStyle;
+            $this->_res['tpl'][$this->tpl]['fonts'][$fontkey] =& $this->fonts[$fontkey];
+        } else {
+            $this->_res['page'][$this->page]['fonts'][$fontkey] =& $this->fonts[$fontkey];
+     * See FPDF/TCPDF-Documentation ;-)
+    function Image($file, $x, $y, $w=0, $h=0, $type='', $link='', $align='', $resize=false, $dpi=300) {
+        if (!is_subclass_of($this, 'TCPDF') && func_num_args() > 7) {
+            $this->Error('More than 7 arguments for the Image method are only available in TCPDF.');
+        parent::Image($file, $x, $y, $w, $h, $type, $link, $align, $resize, $dpi);
+            $this->_res['tpl'][$this->tpl]['images'][$file] =& $this->images[$file];
+        } else {
+            $this->_res['page'][$this->page]['images'][$file] =& $this->images[$file];
+     * AddPage is not available when you're "in" a template.
+    function AddPage($orientation='', $format='') {
+            $this->Error('Adding pages in templates isn\'t possible!');
+        parent::AddPage($orientation, $format);
+     * Preserve adding Links in Templates ...won't work
+    function Link($x, $y, $w, $h, $link) {
+            $this->Error('Using links in templates aren\'t possible!');
+        parent::Link($x, $y, $w, $h, $link);
+    function AddLink() {
+            $this->Error('Adding links in templates aren\'t possible!');
+        return parent::AddLink();
+    function SetLink($link, $y=0, $page=-1) {
+            $this->Error('Setting links in templates aren\'t possible!');
+        parent::SetLink($link, $y, $page);
+     * Private Method that writes the form xobjects
+    function _putformxobjects() {
+	    reset($this->tpls);
+        foreach($this->tpls AS $tplidx => $tpl) {
+            $p=($this->compress) ? gzcompress($tpl['buffer']) : $tpl['buffer'];
+    		$this->_newobj();
+    		$this->tpls[$tplidx]['n'] = $this->n;
+    		$this->_out('<<'.$filter.'/Type /XObject');
+            $this->_out('/Subtype /Form');
+            $this->_out('/FormType 1');
+            $this->_out(sprintf('/BBox [%.2f %.2f %.2f %.2f]',$tpl['x']*$this->k, ($tpl['h']-$tpl['y'])*$this->k, $tpl['w']*$this->k, ($tpl['h']-$tpl['y']-$tpl['h'])*$this->k));
+            $this->_out('/Resources ');
+            $this->_out('<</ProcSet [/PDF /Text /ImageB /ImageC /ImageI]');
+        	if (isset($this->_res['tpl'][$tplidx]['fonts']) && count($this->_res['tpl'][$tplidx]['fonts'])) {
+                foreach($this->_res['tpl'][$tplidx]['fonts'] as $font)
+        	if(isset($this->_res['tpl'][$tplidx]['images']) && count($this->_res['tpl'][$tplidx]['images']) ||
+        	   isset($this->_res['tpl'][$tplidx]['tpls']) && count($this->_res['tpl'][$tplidx]['tpls']))
+                if (isset($this->_res['tpl'][$tplidx]['images']) && count($this->_res['tpl'][$tplidx]['images'])) {
+                    foreach($this->_res['tpl'][$tplidx]['images'] as $image)
+                if (isset($this->_res['tpl'][$tplidx]['tpls']) && count($this->_res['tpl'][$tplidx]['tpls'])) {
+                    foreach($this->_res['tpl'][$tplidx]['tpls'] as $i => $tpl)
+                        $this->_out($this->tplprefix.$i.' '.$tpl['n'].' 0 R');
+        	$this->_out('/Length '.strlen($p).' >>');
+     * Private Method
+    function _putresources() {
+        if (!is_subclass_of($this, 'TCPDF')) {
+        	$this->_putformxobjects();
+        } else {
+        	$this->_putextgstates();
+    		$this->_putocg();
+    	  	$this->_putshaders();
+    		$this->_putjavascript();
+    		$this->_putbookmarks();
+    		// encryption
+    		if ($this->encrypted) {
+    			$this->_newobj();
+    			$this->enc_obj_id = $this->n;
+    			$this->_putencryption();
+    function _putxobjectdict() {
+        parent::_putxobjectdict();
+        if (count($this->tpls)) {
+            foreach($this->tpls as $tplidx => $tpl) {
+                $this->_out($this->tplprefix.$tplidx.' '.$tpl['n'].' 0 R');
+     * Private Method
+    function _out($s) {
+        if ($this->state==2 && $this->_intpl) {
+            $this->tpls[$this->tpl]['buffer'] .= $s."\n";
+        } else {
+            parent::_out($s);
Added: trunk/mapbender/http/extensions/fpdf/fpdi.php
--- trunk/mapbender/http/extensions/fpdf/fpdi.php	                        (rev 0)
+++ trunk/mapbender/http/extensions/fpdf/fpdi.php	2010-01-19 23:07:49 UTC (rev 5359)
@@ -0,0 +1,500 @@
+<?php
+//  FPDI - Version 1.2.1
+define('FPDI_VERSION','1.2.1');
+// Check for TCPDF and remap TCPDF to FPDF
+if (class_exists('TCPDF')) {
+    require_once('fpdi2tcpdf_bridge.php');
+require_once("fpdf_tpl.php");
+require_once("fpdi_pdf_parser.php");
+class FPDI extends FPDF_TPL {
+     * Actual filename
+     * @var string
+    var $current_filename;
+     * Parser-Objects
+     * @var array
+    var $parsers;
+     * Current parser
+     * @var object
+    var $current_parser;
+     * object stack
+     * @var array
+    var $_obj_stack;
+     * done object stack
+     * @var array
+    var $_don_obj_stack;
+     * Current Object Id.
+     * @var integer
+    var $_current_obj_id;
+     * The name of the last imported page box
+     * @var string
+    var $lastUsedPageBox;
+    var $_importedPages = array();
+     * Set a source-file
+     * @param string $filename a valid filename
+     * @return int number of available pages
+    function setSourceFile($filename) {
+        $this->current_filename = $filename;
+        $fn =& $this->current_filename;
+        if (!isset($this->parsers[$fn]))
+            $this->parsers[$fn] =& new fpdi_pdf_parser($fn,$this);
+        $this->current_parser =& $this->parsers[$fn];
+        return $this->parsers[$fn]->getPageCount();
+     * Import a page
+     * @param int $pageno pagenumber
+     * @return int Index of imported page - to use with fpdf_tpl::useTemplate()
+    function importPage($pageno, $boxName='/CropBox') {
+            return $this->error("Please import the desired pages before creating a new template.");
+        // check if page already imported
+        $pageKey = $fn.((int)$pageno).$boxName;
+        if (isset($this->_importedPages[$pageKey]))
+            return $this->_importedPages[$pageKey];
+        $parser =& $this->parsers[$fn];
+        $parser->setPageno($pageno);
+        $this->tpl++;
+        $this->tpls[$this->tpl] = array();
+        $tpl['parser'] =& $parser;
+        $tpl['resources'] = $parser->getPageResources();
+        $tpl['buffer'] = $parser->getContent();
+        if (!in_array($boxName, $parser->availableBoxes))
+            return $this->Error(sprintf("Unknown box: %s", $boxName));
+        $pageboxes = $parser->getPageBoxes($pageno);
+         * MediaBox
+         * CropBox: Default -> MediaBox
+         * BleedBox: Default -> CropBox
+         * TrimBox: Default -> CropBox
+         * ArtBox: Default -> CropBox
+        if (!isset($pageboxes[$boxName]) && ($boxName == "/BleedBox" || $boxName == "/TrimBox" || $boxName == "/ArtBox"))
+            $boxName = "/CropBox";
+        if (!isset($pageboxes[$boxName]) && $boxName == "/CropBox")
+            $boxName = "/MediaBox";
+        if (!isset($pageboxes[$boxName]))
+            return false;
+        $this->lastUsedPageBox = $boxName;
+        $box = $pageboxes[$boxName];
+        $tpl['box'] = $box;
+        // To build an array that can be used by PDF_TPL::useTemplate()
+        $this->tpls[$this->tpl] = array_merge($this->tpls[$this->tpl],$box);
+        // An imported page will start at 0,0 everytime. Translation will be set in _putformxobjects()
+        $tpl['x'] = 0;
+        $tpl['y'] = 0;
+        $page =& $parser->pages[$parser->pageno];
+        // fix for rotated pages
+        $rotation = $parser->getPageRotation($pageno);
+        if (isset($rotation[1]) && ($angle = $rotation[1] % 360) != 0) {
+            $steps = $angle / 90;
+            $_w = $tpl['w'];
+            $_h = $tpl['h'];
+            $tpl['w'] = $steps % 2 == 0 ? $_w : $_h;
+            $tpl['h'] = $steps % 2 == 0 ? $_h : $_w;
+            if ($steps % 2 != 0) {
+                $x = $y = ($steps == 1 || $steps == -3) ? $tpl['h'] : $tpl['w'];
+            } else {
+                $x = $tpl['w'];
+                $y = $tpl['h'];
+            $cx=($x/2+$tpl['box']['x'])*$this->k;
+            $cy=($y/2+$tpl['box']['y'])*$this->k;
+            $angle*=-1;
+            $angle*=M_PI/180;
+            $c=cos($angle);
+            $s=sin($angle);
+            $tpl['buffer'] = sprintf('q %.5f %.5f %.5f %.5f %.2f %.2f cm 1 0 0 1 %.2f %.2f cm %s Q',$c,$s,-$s,$c,$cx,$cy,-$cx,-$cy, $tpl['buffer']);
+        $this->_importedPages[$pageKey] = $this->tpl;
+    function getLastUsedPageBox() {
+        return $this->lastUsedPageBox;
+        $this->_out('q 0 J 1 w 0 j 0 G 0 g'); // reset standard values
+        $s = parent::useTemplate($tplidx, $_x, $_y, $_w, $_h);
+        $this->_out('Q');
+        return $s;
+     * Private method, that rebuilds all needed objects of source files
+    function _putimportedobjects() {
+        if (is_array($this->parsers) && count($this->parsers) > 0) {
+            foreach($this->parsers AS $filename => $p) {
+                $this->current_parser =& $this->parsers[$filename];
+                if (isset($this->_obj_stack[$filename]) && is_array($this->_obj_stack[$filename])) {
+                    while($n = key($this->_obj_stack[$filename])) {
+                        $nObj = $this->current_parser->pdf_resolve_object($this->current_parser->c,$this->_obj_stack[$filename][$n][1]);
+                        $this->_newobj($this->_obj_stack[$filename][$n][0]);
+                        if ($nObj[0] == PDF_TYPE_STREAM) {
+							$this->pdf_write_value ($nObj);
+                        } else {
+                            $this->pdf_write_value ($nObj[1]);
+                        $this->_obj_stack[$filename][$n] = null; // free memory
+                        unset($this->_obj_stack[$filename][$n]);
+                        reset($this->_obj_stack[$filename]);
+     * Put resources
+            $this->_putimportedobjects();
+        } else { // TCPDF - Part
+    		$this->_putocg();
+    		// encryption
+    			$this->_newobj();
+    		$this->_newobj();
+    		$cN = $this->n; // TCPDF/Protection: rem current "n"
+                ($tpl['x'] + (isset($tpl['box']['x'])?$tpl['box']['x']:0))*$this->k,
+                ($tpl['h'] + (isset($tpl['box']['y'])?$tpl['box']['y']:0) - $tpl['y'])*$this->k,
+                ($tpl['w'] + (isset($tpl['box']['x'])?$tpl['box']['x']:0))*$this->k,
+                ($tpl['h'] + (isset($tpl['box']['y'])?$tpl['box']['y']:0) - $tpl['y']-$tpl['h'])*$this->k)
+            if (isset($tpl['box']))
+                $this->_out(sprintf('/Matrix [1 0 0 1 %.5f %.5f]',-$tpl['box']['x']*$this->k, -$tpl['box']['y']*$this->k));
+            if (isset($tpl['resources'])) {
+                $this->current_parser =& $tpl['parser'];
+                $this->pdf_write_value($tpl['resources']); // "n" will be changed
+            } else {
+            $nN = $this->n; // TCPDF: rem new "n"
+            $this->n = $cN; // TCPDF: reset to current "n"
+    		$this->n = $nN; // TCPDF: reset to new "n"
+     * Rewritten to handle existing own defined objects
+    function _newobj($obj_id=false,$onlynewobj=false) {
+        if (!$obj_id) {
+            $obj_id = ++$this->n;
+        if (!$onlynewobj) {
+            $this->offsets[$obj_id] = strlen($this->buffer);
+            $this->_out($obj_id.' 0 obj');
+            $this->_current_obj_id = $obj_id; // for later use with encryption
+     * Writes a value
+     * Needed to rebuild the source document
+     * @param mixed $value A PDF-Value. Structure of values see cases in this method
+    function pdf_write_value(&$value)
+        if (is_subclass_of($this, 'TCPDF')) {
+            parent::pdf_write_value($value);
+        switch ($value[0]) {
+    		case PDF_TYPE_NUMERIC :
+    		case PDF_TYPE_TOKEN :
+    		case PDF_TYPE_REAL :
+                // A numeric value or a token.
+    			// Simply output them
+                $this->_out($value[1]." ", false);
+    			break;
+    		case PDF_TYPE_ARRAY :
+    			// An array. Output the proper
+    			// structure and move on.
+    			$this->_out("[",false);
+                for ($i = 0; $i < count($value[1]); $i++) {
+    				$this->pdf_write_value($value[1][$i]);
+    			$this->_out("]");
+    			break;
+    		case PDF_TYPE_DICTIONARY :
+    			// A dictionary.
+    			$this->_out("<<",false);
+    			reset ($value[1]);
+    			while (list($k, $v) = each($value[1])) {
+    				$this->_out($k . " ",false);
+    				$this->pdf_write_value($v);
+    			$this->_out(">>");
+    			break;
+    		case PDF_TYPE_OBJREF :
+    			// An indirect object reference
+    			// Fill the object stack if needed
+    			$cpfn =& $this->current_parser->filename;
+    			if (!isset($this->_don_obj_stack[$cpfn][$value[1]])) {
+                    $this->_newobj(false,true);
+                    $this->_obj_stack[$cpfn][$value[1]] = array($this->n, $value);
+                    $this->_don_obj_stack[$cpfn][$value[1]] = array($this->n, $value); // Value is maybee obsolete!!!
+                $objid = $this->_don_obj_stack[$cpfn][$value[1]][0];
+    			$this->_out("{$objid} 0 R");
+    			break;
+    		case PDF_TYPE_STRING :
+    			// A string.
+                $this->_out('('.$value[1].')');
+    			break;
+    		case PDF_TYPE_STREAM :
+    			// A stream. First, output the
+    			// stream dictionary, then the
+    			// stream data itself.
+                $this->pdf_write_value($value[1]);
+    			$this->_out("stream");
+    			$this->_out($value[2][1]);
+    			$this->_out("endstream");
+    			break;
+            case PDF_TYPE_HEX :
+                $this->_out("<".$value[1].">");
+                break;
+            case PDF_TYPE_BOOLEAN :
+    		    $this->_out($value[1] ? 'true ' : 'false ', false);
+    		    break;
+    		case PDF_TYPE_NULL :
+                // The null object.
+    			$this->_out("null");
+    			break;
+     * Modified so not each call will add a newline to the output.
+    function _out($s, $ln=true) {
+        if ($this->state==2) {
+            if (!$this->_intpl) {
+                if (is_subclass_of($this, 'TCPDF') && isset($this->footerlen[$this->page]) AND ($this->footerlen[$this->page] > 0)) {
+					// puts data before page footer
+					$page = substr($this->pages[$this->page], 0, -$this->footerlen[$this->page]);
+					$footer = substr($this->pages[$this->page], -$this->footerlen[$this->page]);
+					$this->pages[$this->page] = $page." ".$s."\n".$footer;
+				} else {
+                    $this->pages[$this->page] .= $s.($ln == true ? "\n" : '');
+            } else
+                $this->tpls[$this->tpl]['buffer'] .= $s.($ln == true ? "\n" : '');
+        } else {
+	 	    $this->buffer.=$s.($ln == true ? "\n" : '');
+     * rewritten to close opened parsers
+    function _enddoc() {
+        parent::_enddoc();
+        $this->_closeParsers();
+     * close all files opened by parsers
+    function _closeParsers() {
+        if ($this->state > 2 && count($this->parsers) > 0) {
+          	foreach ($this->parsers as $k => $_){
+            	$this->parsers[$k]->closeFile();
+            	$this->parsers[$k] = null;
+            	unset($this->parsers[$k]);
+            return true;
+        return false;
\ No newline at end of file
Added: trunk/mapbender/http/extensions/fpdf/fpdi2tcpdf_bridge.php
--- trunk/mapbender/http/extensions/fpdf/fpdi2tcpdf_bridge.php	                        (rev 0)
+++ trunk/mapbender/http/extensions/fpdf/fpdi2tcpdf_bridge.php	2010-01-19 23:07:49 UTC (rev 5359)
@@ -0,0 +1,134 @@
+<?php
+ * This class is used as a bridge between TCPDF and FPDI
+ * and will create the possibility to use both FPDF and TCPDF
+ * via one FPDI version.
+ * We'll simply remap TCPDF to FPDF again.
+ * It'll be loaded and extended by FPDF_TPL.
+class FPDF extends TCPDF {
+     * Missing in TCPDF
+     * @var string
+    var $padding;
+    function __get($name) {
+        switch ($name) {
+            case 'PDFVersion':
+                return $this->PDFVersion;
+            case 'k':
+                return $this->k;
+            case 'lastUsedPageBox':
+            default:
+                // Error handling
+                $this->Error('Cannot access protected property '.get_class($this).':$'.$name.' / Undefined property: '.get_class($this).'::$'.$name);
+    function __set($name, $value) {
+        switch ($name) {
+                $this->PDFVersion = $value;
+                break;
+            default:
+                // Error handling
+     * Encryption of imported data by FPDI
+     * @param array $value
+    function pdf_write_value(&$value) {
+				    $value[1] = $this->_unescape($value[1]);
+                    $value[1] = $this->_RC4($this->_objectkey($this->_current_obj_id), $value[1]);
+                 	$value[1] = $this->_escape($value[1]);
+    			break;
+			        $value[2][1] = $this->_RC4($this->_objectkey($this->_current_obj_id), $value[2][1]);
+                break;
+                	$value[1] = $this->hex2str($value[1]);
+                	// remake hexstring of encrypted string
+    				$value[1] = $this->str2hex($value[1]);
+                break;
+     * Unescapes a PDF string
+     * @param string $s
+     * @return string
+    function _unescape($s) {
+        return strtr($s, array(
+            '\\f' => chr(0x0C),
+            '\\b' => chr(0x08),
+            '\\t' => chr(0x09),
+            '\\r' => chr(0x0D),
+            '\\n' => chr(0x0A),
+     * Hexadecimal to string
+     * @param string $hex
+     * @return string
+    function hex2str($hex) {
+    	return pack("H*", str_replace(array("\r", "\n", " "), "", $hex));
+     * String to hexadecimal
+     * @param string $str
+     * @return string
+    function str2hex($str) {
+        return current(unpack("H*", $str));
Added: trunk/mapbender/http/extensions/fpdf/fpdi_pdf_parser.php
--- trunk/mapbender/http/extensions/fpdf/fpdi_pdf_parser.php	                        (rev 0)
+++ trunk/mapbender/http/extensions/fpdf/fpdi_pdf_parser.php	2010-01-19 23:07:49 UTC (rev 5359)
@@ -0,0 +1,380 @@
+<?php
+require_once("pdf_parser.php");
+class fpdi_pdf_parser extends pdf_parser {
+     * Pages
+     * Index beginns at 0
+     * @var array
+    var $pages;
+     * Page count
+     * @var integer
+    var $page_count;
+     * actual page number
+     * @var integer
+    var $pageno;
+     * PDF Version of imported Document
+     * @var string
+    var $pdfVersion;
+     * FPDI Reference
+     * @var object
+    var $fpdi;
+     * Available BoxTypes
+     * @var array
+    var $availableBoxes = array("/MediaBox","/CropBox","/BleedBox","/TrimBox","/ArtBox");
+     * Constructor
+     * @param string $filename  Source-Filename
+     * @param object $fpdi      Object of type fpdi
+    function fpdi_pdf_parser($filename,&$fpdi) {
+        $this->fpdi =& $fpdi;
+		$this->filename = $filename;
+        parent::pdf_parser($filename);
+        // resolve Pages-Dictonary
+        $pages = $this->pdf_resolve_object($this->c, $this->root[1][1]['/Pages']);
+        // Read pages
+        $this->read_pages($this->c, $pages, $this->pages);
+        // count pages;
+        $this->page_count = count($this->pages);
+     * Overwrite parent::error()
+     * @param string $msg  Error-Message
+    function error($msg) {
+    	$this->fpdi->error($msg);
+     * Get pagecount from sourcefile
+     * @return int
+    function getPageCount() {
+        return $this->page_count;
+     * Set pageno
+     * @param int $pageno Pagenumber to use
+    function setPageno($pageno) {
+        $pageno = ((int) $pageno) - 1;
+        if ($pageno < 0 || $pageno >= $this->getPageCount()) {
+            $this->fpdi->error("Pagenumber is wrong!");
+        $this->pageno = $pageno;
+     * Get page-resources from current page
+     * @return array
+    function getPageResources() {
+        return $this->_getPageResources($this->pages[$this->pageno]);
+     * Get page-resources from /Page
+     * @param array $obj Array of pdf-data
+    function _getPageResources ($obj) { // $obj = /Page
+    	$obj = $this->pdf_resolve_object($this->c, $obj);
+        // If the current object has a resources
+    	// dictionary associated with it, we use
+    	// it. Otherwise, we move back to its
+    	// parent object.
+        if (isset ($obj[1][1]['/Resources'])) {
+    		$res = $this->pdf_resolve_object($this->c, $obj[1][1]['/Resources']);
+    		if ($res[0] == PDF_TYPE_OBJECT)
+                return $res[1];
+            return $res;
+    	} else {
+    		if (!isset ($obj[1][1]['/Parent'])) {
+    			return false;
+    		} else {
+                $res = $this->_getPageResources($obj[1][1]['/Parent']);
+                    return $res[1];
+                return $res;
+     * Get content of current page
+     * If more /Contents is an array, the streams are concated
+     * @return string
+    function getContent() {
+        $buffer = "";
+        if (isset($this->pages[$this->pageno][1][1]['/Contents'])) {
+            $contents = $this->_getPageContent($this->pages[$this->pageno][1][1]['/Contents']);
+            foreach($contents AS $tmp_content) {
+                $buffer .= $this->_rebuildContentStream($tmp_content).' ';
+        return $buffer;
+     * Resolve all content-objects
+     * @param array $content_ref
+     * @return array
+    function _getPageContent($content_ref) {
+        $contents = array();
+        if ($content_ref[0] == PDF_TYPE_OBJREF) {
+            $content = $this->pdf_resolve_object($this->c, $content_ref);
+            if ($content[1][0] == PDF_TYPE_ARRAY) {
+                $contents = $this->_getPageContent($content[1]);
+            } else {
+                $contents[] = $content;
+        } else if ($content_ref[0] == PDF_TYPE_ARRAY) {
+            foreach ($content_ref[1] AS $tmp_content_ref) {
+                $contents = array_merge($contents,$this->_getPageContent($tmp_content_ref));
+        return $contents;
+     * Rebuild content-streams
+     * @return string
+    function _rebuildContentStream($obj) {
+        $filters = array();
+        if (isset($obj[1][1]['/Filter'])) {
+            $_filter = $obj[1][1]['/Filter'];
+            if ($_filter[0] == PDF_TYPE_TOKEN) {
+                $filters[] = $_filter;
+            } else if ($_filter[0] == PDF_TYPE_ARRAY) {
+                $filters = $_filter[1];
+        $stream = $obj[2][1];
+        foreach ($filters AS $_filter) {
+            switch ($_filter[1]) {
+                case "/FlateDecode":
+                    if (function_exists('gzuncompress')) {
+                        $stream = (strlen($stream) > 0) ? @gzuncompress($stream) : '';
+                    } else {
+                        $this->fpdi->error(sprintf("To handle %s filter, please compile php with zlib support.",$_filter[1]));
+                    if ($stream === false) {
+                        $this->fpdi->error("Error while decompressing stream.");
+                break;
+                case null:
+                    $stream = $stream;
+                break;
+                default:
+                    if (preg_match("/^\/[a-z85]*$/i", $_filter[1], $filterName) && @include_once('decoders'.$_filter[1].'.php')) {
+                        $filterName = substr($_filter[1],1);
+                        if (class_exists($filterName)) {
+    	                	$decoder =& new $filterName($this->fpdi);
+    	                    $stream = $decoder->decode(trim($stream));
+                        } else {
+                        	$this->fpdi->error(sprintf("Unsupported Filter: %s",$_filter[1]));
+                    } else {
+        return $stream;
+     * Get a Box from a page
+     * Arrayformat is same as used by fpdf_tpl
+     * @param array $page a /Page
+     * @param string $box_index Type of Box @see $availableBoxes
+     * @return array
+    function getPageBox($page, $box_index) {
+        $page = $this->pdf_resolve_object($this->c,$page);
+        $box = null;
+        if (isset($page[1][1][$box_index]))
+            $box =& $page[1][1][$box_index];
+        if (!is_null($box) && $box[0] == PDF_TYPE_OBJREF) {
+            $tmp_box = $this->pdf_resolve_object($this->c,$box);
+            $box = $tmp_box[1];
+        if (!is_null($box) && $box[0] == PDF_TYPE_ARRAY) {
+            $b =& $box[1];
+            return array("x" => $b[0][1]/$this->fpdi->k,
+                         "y" => $b[1][1]/$this->fpdi->k,
+                         "w" => abs($b[0][1]-$b[2][1])/$this->fpdi->k,
+                         "h" => abs($b[1][1]-$b[3][1])/$this->fpdi->k);
+        } else if (!isset ($page[1][1]['/Parent'])) {
+            return false;
+        } else {
+            return $this->getPageBox($this->pdf_resolve_object($this->c, $page[1][1]['/Parent']), $box_index);
+    function getPageBoxes($pageno) {
+        return $this->_getPageBoxes($this->pages[$pageno-1]);
+     * Get all Boxes from /Page
+     * @param array a /Page
+     * @return array
+    function _getPageBoxes($page) {
+        $boxes = array();
+        foreach($this->availableBoxes AS $box) {
+            if ($_box = $this->getPageBox($page,$box)) {
+                $boxes[$box] = $_box;
+        return $boxes;
+     * Get the page rotation by pageno
+     * @param integer $pageno
+     * @return array
+    function getPageRotation($pageno) {
+        return $this->_getPageRotation($this->pages[$pageno-1]);
+    function _getPageRotation ($obj) { // $obj = /Page
+    	if (isset ($obj[1][1]['/Rotate'])) {
+    		$res = $this->pdf_resolve_object($this->c, $obj[1][1]['/Rotate']);
+                return $res[1];
+            return $res;
+    	} else {
+    			return false;
+    		} else {
+                $res = $this->_getPageRotation($obj[1][1]['/Parent']);
+                    return $res[1];
+                return $res;
+     * Read all /Page(es)
+     * @param object pdf_context
+     * @param array /Pages
+     * @param array the result-array
+    function read_pages (&$c, &$pages, &$result) {
+        // Get the kids dictionary
+    	$kids = $this->pdf_resolve_object ($c, $pages[1][1]['/Kids']);
+        if (!is_array($kids))
+            $this->fpdi->Error("Cannot find /Kids in current /Page-Dictionary");
+        foreach ($kids[1] as $v) {
+    		$pg = $this->pdf_resolve_object ($c, $v);
+            if ($pg[1][1]['/Type'][1] === '/Pages') {
+                // If one of the kids is an embedded
+    			// /Pages array, resolve it as well.
+                $this->read_pages ($c, $pg, $result);
+    		} else {
+    			$result[] = $pg;
+     * Get PDF-Version
+     * And reset the PDF Version used in FPDI if needed
+    function getPDFVersion() {
+        parent::getPDFVersion();
+        $this->fpdi->PDFVersion = max($this->fpdi->PDFVersion, $this->pdfVersion);
Added: trunk/mapbender/http/extensions/fpdf/license.txt
--- trunk/mapbender/http/extensions/fpdf/license.txt	                        (rev 0)
+++ trunk/mapbender/http/extensions/fpdf/license.txt	2010-01-19 23:07:49 UTC (rev 5359)
@@ -0,0 +1,6 @@
+Permission is hereby granted, free of charge, to any person obtaining a copy
+of this software to use, copy, modify, distribute, sublicense, and/or sell
+copies of the software, and to permit persons to whom the software is furnished
+to do so.
+THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED.
Added: trunk/mapbender/http/extensions/fpdf/mb_fpdi.php
--- trunk/mapbender/http/extensions/fpdf/mb_fpdi.php	                        (rev 0)
+++ trunk/mapbender/http/extensions/fpdf/mb_fpdi.php	2010-01-19 23:07:49 UTC (rev 5359)
@@ -0,0 +1,529 @@
+<?php
+require_once(dirname(__FILE__)."/fpdi.php");
+class mb_fpdi extends FPDI {
+    function mb_fpdi($orientation='L',$unit='mm',$format='A4') {
+        parent::FPDI($orientation,$unit,$format);
+	// Image with png alpha extension
+	//Private properties
+	var $tmpFiles = array();
+	*                               Public methods                                 *
+	function Image($file,$x,$y,$w=0,$h=0,$type='',$link='', $isMask=false, $maskImg=0, $align='', $angle=0)
+	        //First use of image, get info
+	        if($type=='')
+	            if(!$pos)
+	        $mqr=get_magic_quotes_runtime();
+	        set_magic_quotes_runtime(0);
+	        if($type=='jpg' || $type=='jpeg')
+	            $info=$this->_parsejpg($file);
+	        elseif($type=='png'){
+	            $info=$this->_parsepng($file);
+	            if ($info=='alpha') return $this->ImagePngWithAlpha($file,$x,$y,$w,$h,$link);
+	        else
+	            //Allow for additional formats
+	        set_magic_quotes_runtime($mqr);
+	        if ($isMask){
+	      $info['cs']="DeviceGray"; // try to force grayscale (instead of indexed)
+	        if ($maskImg>0) $info['masked'] = $maskImg;###
+	    else
+	    if($w==0)
+	    if($h==0)
+	    $x_rot = $x;
+    	$y_rot = $y;
+	    switch ($align) {
+			case 1:
+		        break;
+		    case 2:
+		        $x=$x-$w/2;
+		        break;
+		    case 3:
+		        $x=$x-$w;
+		        break;
+		    case 4:
+		        $y=$y-$h/2;
+		        break;
+		    case 5:
+		        $x=$x-$w/2;
+		        $y=$y-$h/2;
+		        break;
+		    case 6:
+		        $x=$x-$w;
+		        $y=$y-$h/2;
+		        break;
+		    case 7:
+		        $y=$y-$h;
+		        break;
+		    case 8:
+		        $x=$x-$w/2;
+		        $y=$y-$h;
+		        break;
+		    case 9:
+		        $x=$x-$w;
+		        $y=$y-$h;
+		        break;
+		    default:
+		        break;
+	    if ($isMask) $x = $this->fwPt + 10; // embed hidden, ouside the canvas
+    	if($angle!=0){
+      		$this->_out('q');
+      		$this->Rotation($angle, $x_rot, $y_rot);
+      		$this->_out(sprintf('q %.2f 0 0 %.2f %.2f %.2f cm /I%d Do Q',$w*$this->k,$h*$this->k,$x*$this->k,($this->h-($y+$h))*$this->k,$info['i']));
+      		$this->_out('Q');
+    	else {  $this->_out(sprintf('q %.2f 0 0 %.2f %.2f %.2f cm /I%d Do Q',$w*$this->k,$h*$this->k,$x*$this->k,($this->h-($y+$h))*$this->k,$info['i']));}
+	    #$this->_out(sprintf('q %.2f 0 0 %.2f %.2f %.2f cm /I%d Do Q',$w*$this->k,$h*$this->k,$x*$this->k,($this->h-($y+$h))*$this->k,$info['i']));
+	    if($link)
+	    return $info['i'];
+	// needs GD 2.x extension
+	// pixel-wise operation, not very fast
+	function ImagePngWithAlpha($file,$x,$y,$w=0,$h=0,$link='')
+	    $tmp_alpha = tempnam('.', 'mska');
+	    $this->tmpFiles[] = $tmp_alpha;
+	    $tmp_plain = tempnam('.', 'mskp');
+	    $this->tmpFiles[] = $tmp_plain;
+	    list($wpx, $hpx) = getimagesize($file);
+	    $img = imagecreatefrompng($file);
+	    $alpha_img = imagecreate( $wpx, $hpx );
+	    // generate gray scale pallete
+	    for($c=0;$c<256;$c++) ImageColorAllocate($alpha_img, $c, $c, $c);
+	    // extract alpha channel
+	    $xpx=0;
+	    while ($xpx<$wpx){
+	        $ypx = 0;
+	        while ($ypx<$hpx){
+	            $color_index = imagecolorat($img, $xpx, $ypx);
+	            $col = imagecolorsforindex($img, $color_index);
+	            imagesetpixel($alpha_img, $xpx, $ypx, $this->_gamma( (127-$col['alpha'])*255/127)  );
+	        ++$ypx;
+	        ++$xpx;
+	    imagepng($alpha_img, $tmp_alpha);
+	    imagedestroy($alpha_img);
+	    // extract image without alpha channel
+	    $plain_img = imagecreatetruecolor ( $wpx, $hpx );
+	    imagecopy ($plain_img, $img, 0, 0, 0, 0, $wpx, $hpx );
+	    imagepng($plain_img, $tmp_plain);
+	    imagedestroy($plain_img);
+	    //first embed mask image (w, h, x, will be ignored)
+	    $maskImg = $this->Image($tmp_alpha, 0,0,0,0, 'PNG', '', true);
+	    //embed image, masked with previously embedded mask
+	    $this->Image($tmp_plain,$x,$y,$w,$h,'PNG',$link, false, $maskImg);
+	function Close()
+	    parent::Close();
+	    // clean up tmp files
+	    foreach($this->tmpFiles as $tmp) @unlink($tmp);
+	*                               Private methods                                *
+	function _putimages()
+	        $this->_newobj();
+	        if (isset($info["masked"])) $this->_out('/SMask '.($this->n-1).' 0 R'); ###
+	        else
+	            $trns='';
+	        //Palette
+	            $this->_newobj();
+	// GD seems to use a different gamma, this method is used to correct it again
+	function _gamma($v){
+	    return pow ($v/255, 2.2) * 255;
+     function _parsegif($file)
+	//Function by Jerome Fenal
+	require_once(BASECLASSES.'/fpdi/gif.php'); //GIF class in pure PHP from Yamasoft (formerly at http://www.yamasoft.com)
+	$h=0;
+	$w=0;
+	$gif=new CGIF();
+	if (!$gif->loadFile($file, 0))
+		$this->Error("GIF parser: unable to open file $file");
+	if($gif->m_img->m_gih->m_bLocalClr) {
+		$nColors = $gif->m_img->m_gih->m_nTableSize;
+		$pal = $gif->m_img->m_gih->m_colorTable->toString();
+		if($bgColor != -1) {
+			$bgColor = $gif->m_img->m_gih->m_colorTable->colorIndex($bgColor);
+	} elseif($gif->m_gfh->m_bGlobalClr) {
+		$nColors = $gif->m_gfh->m_nTableSize;
+		$pal = $gif->m_gfh->m_colorTable->toString();
+			$bgColor = $gif->m_gfh->m_colorTable->colorIndex($bgColor);
+	} else {
+		$nColors = 0;
+		$bgColor = -1;
+		$pal='';
+	$trns='';
+	if($gif->m_img->m_bTrans && ($nColors > 0)) {
+		$trns=array($gif->m_img->m_nTrans);
+	$data=$gif->m_img->m_data;
+	$w=$gif->m_gfh->m_nWidth;
+	$h=$gif->m_gfh->m_nHeight;
+	if($colspace=='Indexed' and empty($pal))
+	if ($this->compress) {
+		$data=gzcompress($data);
+		return array( 'w'=>$w, 'h'=>$h, 'cs'=>$colspace, 'bpc'=>8, 'f'=>'FlateDecode', 'pal'=>$pal, 'trns'=>$trns, 'data'=>$data);
+	} else {
+		return array( 'w'=>$w, 'h'=>$h, 'cs'=>$colspace, 'bpc'=>8, 'pal'=>$pal, 'trns'=>$trns, 'data'=>$data);
+	// this method overwriing the original version is only needed to make the Image method support PNGs with alpha channels.
+	// if you only use the ImagePngWithAlpha method for such PNGs, you can remove it from this script.
+	function _parsepng($file)
+	    $f=fopen($file,'rb');
+	    if(!$f)
+	    //Check signature
+	    if(fread($f,8)!=chr(137).'PNG'.chr(13).chr(10).chr(26).chr(10))
+	    fread($f,4);
+	    if(fread($f,4)!='IHDR')
+	    $bpc=ord(fread($f,1));
+	    if($bpc>8)
+	    $ct=ord(fread($f,1));
+	    if($ct==0)
+	    elseif($ct==2)
+	    elseif($ct==3)
+	    else {
+	        fclose($f);      // the only changes are
+	        return 'alpha';  // made in those 2 lines
+	    if(ord(fread($f,1))!=0)
+	    fread($f,4);
+	    $pal='';
+	    $trns='';
+	    $data='';
+	    do
+	        $type=fread($f,4);
+	        if($type=='PLTE')
+	            //Read palette
+	            $pal=fread($f,$n);
+	            fread($f,4);
+	            $t=fread($f,$n);
+	            if($ct==0)
+	            elseif($ct==2)
+	                $trns=array(ord(substr($t,1,1)),ord(substr($t,3,1)),ord(substr($t,5,1)));
+	            else
+	                if($pos!==false)
+	            fread($f,4);
+	            $data.=fread($f,$n);
+	            fread($f,4);
+	            break;
+	        else
+	            fread($f,$n+4);
+	    while($n);
+	    fclose($f);
+	    return array('w'=>$w,'h'=>$h,'cs'=>$colspace,'bpc'=>$bpc,'f'=>'FlateDecode','parms'=>$parms,'pal'=>$pal,'trns'=>$trns,'data'=>$data);
+	var $angle=0;
+	function Rotate($angle, $x=-1, $y=-1)
+	    if($x==-1)
+	        $x=$this->x;
+	    if($y==-1)
+	        $y=$this->y;
+	    if($this->angle!=0)
+	        $this->_out('Q');
+	    $this->angle=$angle;
+	    if($angle!=0)
+	        $angle*=M_PI/180;
+	        $c=cos($angle);
+	        $s=sin($angle);
+	        $cx=$x*$this->k;
+	        $cy=($this->h-$y)*$this->k;
+	        $this->_out(sprintf('q %.5f %.5f %.5f %.5f %.2f %.2f cm 1 0 0 1 %.2f %.2f cm', $c, $s, -$s, $c, $cx, $cy, -$cx, -$cy));
+	function _endpage()
+	        $this->angle=0;
+	        $this->_out('Q');
+	    parent::_endpage();
+	function RotatedText($x, $y, $txt, $angle)
+	    //Text rotated around its origin
+	    $this->Rotate($angle, $x, $y);
+	    $this->Text($x, $y, $txt);
+	    $this->Rotate(0);
+	function Polygon($points, $style='D')
+    	//Draw a polygon
+    	if($style=='F')
+    	    $op='f';
+    	elseif($style=='FD' or $style=='DF')
+        	$op='b';
+    	else
+        	$op='s';
+    	$h = $this->h;
+    	$k = $this->k;
+    	$points_string = '';
+    	for($i=0; $i<count($points); $i+=2){
+        	$points_string .= sprintf('%.2f %.2f', $points[$i]*$k, ($h-$points[$i+1])*$k);
+        	if($i==0)
+            	$points_string .= ' m ';
+        	else
+            	$points_string .= ' l ';
+    	$this->_out($points_string . $op);
+    function ClippingText($x, $y, $txt, $outline=false)
+        $op=$outline ? 5 : 7;
+        $this->_out(sprintf('q BT %.2f %.2f Td %d Tr (%s) Tj 0 Tr ET',
+            $x*$this->k,
+            ($this->h-$y)*$this->k,
+            $op,
+            $this->_escape($txt)));
+    function ClippingRect($x, $y, $w, $h, $outline=false)
+        $op=$outline ? 'S' : 'n';
+        $this->_out(sprintf('q %.2f %.2f %.2f %.2f re W %s',
+            $x*$this->k,
+            $w*$this->k, -$h*$this->k,
+            $op));
+    function ClippingEllipse($x, $y, $rx, $ry, $outline=false)
+        $lx=4/3*(M_SQRT2-1)*$rx;
+        $ly=4/3*(M_SQRT2-1)*$ry;
+        $k=$this->k;
+        $h=$this->h;
+        $this->_out(sprintf('q %.2f %.2f m %.2f %.2f %.2f %.2f %.2f %.2f c',
+            ($x+$rx)*$k, ($h-$y)*$k,
+            ($x+$rx)*$k, ($h-($y-$ly))*$k,
+            ($x+$lx)*$k, ($h-($y-$ry))*$k,
+            $x*$k, ($h-($y-$ry))*$k));
+        $this->_out(sprintf('%.2f %.2f %.2f %.2f %.2f %.2f c',
+            ($x-$lx)*$k, ($h-($y-$ry))*$k,
+            ($x-$rx)*$k, ($h-($y-$ly))*$k,
+            ($x-$rx)*$k, ($h-$y)*$k));
+            ($x-$rx)*$k, ($h-($y+$ly))*$k,
+            ($x-$lx)*$k, ($h-($y+$ry))*$k,
+            $x*$k, ($h-($y+$ry))*$k));
+        $this->_out(sprintf('%.2f %.2f %.2f %.2f %.2f %.2f c W %s',
+            ($x+$lx)*$k, ($h-($y+$ry))*$k,
+            ($x+$rx)*$k, ($h-($y+$ly))*$k,
+            $op));
+    function UnsetClipping()
+        $this->_out('Q');
+    function ClippedCell($w, $h=0, $txt='', $border=0, $ln=0, $align='', $fill=0, $link='')
+        if($border || $fill || $this->y+$h>$this->PageBreakTrigger)
+            $this->Cell($w, $h, '', $border, 0, '', $fill);
+            $this->x-=$w;
+        $this->ClippingRect($this->x, $this->y, $w, $h);
+        $this->Cell($w, $h, $txt, '', $ln, $align, 0, $link);
+        $this->UnsetClipping();
+    function Rotation($grad, $x = '', $y = ''){
+      if ($x === '') $x = $this->x;
+      if ($y === '') $y = $this->y;
+      $y = ($this->h-$y) * $this->k;
+      $x *= $this->k;
+      $tm[0] = cos(deg2rad($grad));
+      $tm[1] = sin(deg2rad($grad));
+      $tm[2] = -$tm[1];
+      $tm[3] = $tm[0];
+      $tm[4] = $x+$tm[1]*$y-$tm[0]*$x;
+      $tm[5] = $y-$tm[0]*$y-$tm[1]*$x;
+      $this->_out(sprintf('%.3f %.3f %.3f %.3f %.3f %.3f cm', $tm[0],$tm[1],$tm[2],$tm[3],$tm[4],$tm[5]));
Added: trunk/mapbender/http/extensions/fpdf/pdf_context.php
--- trunk/mapbender/http/extensions/fpdf/pdf_context.php	                        (rev 0)
+++ trunk/mapbender/http/extensions/fpdf/pdf_context.php	2010-01-19 23:07:49 UTC (rev 5359)
@@ -0,0 +1,82 @@
+<?php
+class pdf_context {
+	var $file;
+	var $buffer;
+	var $offset;
+	var $length;
+	var $stack;
+	// Constructor
+	function pdf_context($f) {
+		$this->file = $f;
+		$this->reset();
+	// Optionally move the file
+	// pointer to a new location
+	// and reset the buffered data
+	function reset($pos = null, $l = 100) {
+		if (!is_null ($pos)) {
+			fseek ($this->file, $pos);
+		$this->buffer = $l > 0 ? fread($this->file, $l) : '';
+		$this->length = strlen($this->buffer);
+		if ($this->length < $l)
+            $this->increase_length($l - $this->length);
+		$this->offset = 0;
+		$this->stack = array();
+	// Make sure that there is at least one
+	// character beyond the current offset in
+	// the buffer to prevent the tokenizer
+	// from attempting to access data that does
+	// not exist
+	function ensure_content() {
+		if ($this->offset >= $this->length - 1) {
+			return $this->increase_length();
+		} else {
+			return true;
+	// Forcefully read more data into the buffer
+	function increase_length($l=100) {
+		if (feof($this->file)) {
+			return false;
+		} else {
+			$totalLength = $this->length + $l;
+		    do {
+                $this->buffer .= fread($this->file, $totalLength-$this->length);
+            } while ((($this->length = strlen($this->buffer)) != $totalLength) && !feof($this->file));
+			return true;
Added: trunk/mapbender/http/extensions/fpdf/pdf_parser.php
--- trunk/mapbender/http/extensions/fpdf/pdf_parser.php	                        (rev 0)
+++ trunk/mapbender/http/extensions/fpdf/pdf_parser.php	2010-01-19 23:07:49 UTC (rev 5359)
@@ -0,0 +1,690 @@
+<?php
+if (!defined ('PDF_TYPE_NULL'))
+    define ('PDF_TYPE_NULL', 0);
+if (!defined ('PDF_TYPE_NUMERIC'))
+    define ('PDF_TYPE_NUMERIC', 1);
+if (!defined ('PDF_TYPE_TOKEN'))
+    define ('PDF_TYPE_TOKEN', 2);
+if (!defined ('PDF_TYPE_HEX'))
+    define ('PDF_TYPE_HEX', 3);
+if (!defined ('PDF_TYPE_STRING'))
+    define ('PDF_TYPE_STRING', 4);
+if (!defined ('PDF_TYPE_DICTIONARY'))
+    define ('PDF_TYPE_DICTIONARY', 5);
+if (!defined ('PDF_TYPE_ARRAY'))
+    define ('PDF_TYPE_ARRAY', 6);
+if (!defined ('PDF_TYPE_OBJDEC'))
+    define ('PDF_TYPE_OBJDEC', 7);
+if (!defined ('PDF_TYPE_OBJREF'))
+    define ('PDF_TYPE_OBJREF', 8);
+if (!defined ('PDF_TYPE_OBJECT'))
+    define ('PDF_TYPE_OBJECT', 9);
+if (!defined ('PDF_TYPE_STREAM'))
+    define ('PDF_TYPE_STREAM', 10);
+if (!defined ('PDF_TYPE_BOOLEAN'))
+    define ('PDF_TYPE_BOOLEAN', 11);
+if (!defined ('PDF_TYPE_REAL'))
+    define ('PDF_TYPE_REAL', 12);
+require_once("pdf_context.php");
+require_once("wrapper_functions.php");
+class pdf_parser {
+     * Filename
+     * @var string
+    var $filename;
+     * File resource
+     * @var resource
+    var $f;
+     * PDF Context
+     * @var object pdf_context-Instance
+    var $c;
+     * xref-Data
+     * @var array
+    var $xref;
+     * root-Object
+     * @var array
+    var $root;
+     * PDF version of the loaded document
+     * @var string
+    var $pdfVersion;
+     * Constructor
+	function pdf_parser($filename) {
+        $this->f = @fopen($this->filename, "rb");
+        if (!$this->f)
+            $this->error(sprintf("Cannot open %s !", $filename));
+        $this->getPDFVersion();
+        $this->c =& new pdf_context($this->f);
+        // Read xref-Data
+        $this->pdf_read_xref($this->xref, $this->pdf_find_xref());
+        // Check for Encryption
+        $this->getEncryption();
+        // Read root
+        $this->pdf_read_root();
+     * Close the opened file
+    function closeFile() {
+    	if (isset($this->f)) {
+    	    fclose($this->f);
+    		unset($this->f);
+     * Print Error and die
+    	die("<b>PDF-Parser Error:</b> ".$msg);
+     * Check Trailer for Encryption
+    function getEncryption() {
+        if (isset($this->xref['trailer'][1]['/Encrypt'])) {
+            $this->error("File is encrypted!");
+     * Find/Return /Root
+     * @return array
+    function pdf_find_root() {
+        if ($this->xref['trailer'][1]['/Root'][0] != PDF_TYPE_OBJREF) {
+            $this->error("Wrong Type of Root-Element! Must be an indirect reference");
+        return $this->xref['trailer'][1]['/Root'];
+     * Read the /Root
+    function pdf_read_root() {
+        // read root
+        $this->root = $this->pdf_resolve_object($this->c, $this->pdf_find_root());
+     * Get PDF-Version
+        fseek($this->f, 0);
+        preg_match("/\d\.\d/",fread($this->f,16),$m);
+        if (isset($m[0]))
+            $this->pdfVersion = $m[0];
+        return $this->pdfVersion;
+     * Find the xref-Table
+    function pdf_find_xref() {
+       	$toRead = 1500;
+        $stat = fseek ($this->f, -$toRead, SEEK_END);
+        if ($stat === -1) {
+            fseek ($this->f, 0);
+       	$data = fread($this->f, $toRead);
+        $pos = strlen($data) - strpos(strrev($data), strrev('startxref'));
+        $data = substr($data, $pos);
+        if (!preg_match('/\s*(\d+).*$/s', $data, $matches)) {
+            $this->error("Unable to find pointer to xref table");
+    	return (int) $matches[1];
+     * Read xref-table
+     * @param array $result Array of xref-table
+     * @param integer $offset of xref-table
+    function pdf_read_xref(&$result, $offset) {
+        fseek($this->f, $o_pos = $offset-20); // set some bytes backwards to fetch errorious docs
+        $data = fread($this->f, 100);
+        $xrefPos = strpos($data, 'xref');
+        if ($xrefPos === false) {
+            $this->error('Unable to find xref table.');
+        if (!isset($result['xref_location'])) {
+            $result['xref_location'] = $o_pos+$xrefPos;
+            $result['max_object'] = 0;
+    	$cylces = -1;
+        $bytesPerCycle = 100;
+    	fseek($this->f, $o_pos = $o_pos+$xrefPos+4); // set the handle directly after the "xref"-keyword
+        $data = fread($this->f, $bytesPerCycle);
+        while (($trailerPos = strpos($data, 'trailer', max($bytesPerCycle*$cylces++, 0))) === false && !feof($this->f)) {
+            $data .= fread($this->f, $bytesPerCycle);
+        if ($trailerPos === false) {
+            $this->error('Trailer keyword not found after xref table');
+        $data = substr($data, 0, $trailerPos);
+        // get Line-Ending
+        preg_match_all("/(\r\n|\n|\r)/", substr($data, 0, 100), $m); // check the first 100 bytes for linebreaks
+        $differentLineEndings = count(array_unique($m[0]));
+        if ($differentLineEndings > 1) {
+            $lines = preg_split("/(\r\n|\n|\r)/", $data, -1, PREG_SPLIT_NO_EMPTY);
+        } else {
+            $lines = explode($m[0][1], $data);
+        $data = $differentLineEndings = $m = null;
+        unset($data, $differentLineEndings, $m);
+        $linesCount = count($lines);
+        $start = 1;
+        for ($i = 0; $i < $linesCount; $i++) {
+            $line = trim($lines[$i]);
+            if ($line) {
+                $pieces = explode(" ", $line);
+                $c = count($pieces);
+                switch($c) {
+                    case 2:
+                        $start = (int)$pieces[0];
+                        $end   = $start+(int)$pieces[1];
+                        if ($end > $result['max_object'])
+                            $result['max_object'] = $end;
+                        break;
+                    case 3:
+                        if (!isset($result['xref'][$start]))
+                            $result['xref'][$start] = array();
+                        if (!array_key_exists($gen = (int) $pieces[1], $result['xref'][$start])) {
+                	        $result['xref'][$start][$gen] = $pieces[2] == 'n' ? (int) $pieces[0] : null;
+                        $start++;
+                        break;
+                    default:
+                        $this->error('Unexpected data in xref table');
+        $lines = $pieces = $line = $start = $end = $gen = null;
+        unset($lines, $pieces, $line, $start, $end, $gen);
+        fseek($this->f, $o_pos+$trailerPos+7);
+        $c =&  new pdf_context($this->f);
+	    $trailer = $this->pdf_read_value($c);
+	    $c = null;
+	    unset($c);
+	    if (!isset($result['trailer'])) {
+            $result['trailer'] = $trailer;
+	    if (isset($trailer[1]['/Prev'])) {
+	    	$this->pdf_read_xref($result, $trailer[1]['/Prev'][1]);
+	    $trailer = null;
+	    unset($trailer);
+        return true;
+     * Reads an Value
+     * @param object $c pdf_context
+     * @param string $token a Token
+     * @return mixed
+    function pdf_read_value(&$c, $token = null) {
+    	if (is_null($token)) {
+    	    $token = $this->pdf_read_token($c);
+        if ($token === false) {
+    	    return false;
+       	switch ($token) {
+            case	'<':
+    			// This is a hex string.
+    			// Read the value, then the terminator
+                $pos = $c->offset;
+    			while(1) {
+                    $match = strpos ($c->buffer, '>', $pos);
+    				// If you can't find it, try
+    				// reading more data from the stream
+    				if ($match === false) {
+    					if (!$c->increase_length()) {
+    						return false;
+    					} else {
+                        	continue;
+    				$result = substr ($c->buffer, $c->offset, $match - $c->offset);
+    				$c->offset = $match + 1;
+    				return array (PDF_TYPE_HEX, $result);
+                break;
+    		case	'<<':
+    			// This is a dictionary.
+    			$result = array();
+    			// Recurse into this function until we reach
+    			// the end of the dictionary.
+    			while (($key = $this->pdf_read_token($c)) !== '>>') {
+    				if ($key === false) {
+    					return false;
+    				if (($value =   $this->pdf_read_value($c)) === false) {
+    					return false;
+                    $result[$key] = $value;
+    			return array (PDF_TYPE_DICTIONARY, $result);
+    		case	'[':
+    			// This is an array.
+    			// the end of the array.
+    			while (($token = $this->pdf_read_token($c)) !== ']') {
+    					return false;
+    				if (($value = $this->pdf_read_value($c, $token)) === false) {
+                        return false;
+    				$result[] = $value;
+                return array (PDF_TYPE_ARRAY, $result);
+    		case	'('		:
+                // This is a string
+                $openBrackets = 1;
+    			do {
+                    for (; $openBrackets != 0 && $pos < $c->length; $pos++) {
+                        switch (ord($c->buffer[$pos])) {
+                            case 0x28: // '('
+                                $openBrackets++;
+                                break;
+                            case 0x29: // ')'
+                                $openBrackets--;
+                                break;
+                            case 0x5C: // backslash
+                                $pos++;
+    			} while($openBrackets != 0 && $c->increase_length());
+    			$result = substr($c->buffer, $c->offset, $pos - $c->offset - 1);
+    			$c->offset = $pos;
+    			return array (PDF_TYPE_STRING, $result);
+            case "stream":
+            	$o_pos = ftell($c->file)-strlen($c->buffer);
+		        $o_offset = $c->offset;
+		        $c->reset($startpos = $o_pos + $o_offset);
+		        $e = 0; // ensure line breaks in front of the stream
+		        if ($c->buffer[0] == chr(10) || $c->buffer[0] == chr(13))
+		        	$e++;
+		        if ($c->buffer[1] == chr(10) && $c->buffer[0] != chr(10))
+		        	$e++;
+		        if ($this->actual_obj[1][1]['/Length'][0] == PDF_TYPE_OBJREF) {
+		        	$tmp_c =& new pdf_context($this->f);
+		        	$tmp_length = $this->pdf_resolve_object($tmp_c,$this->actual_obj[1][1]['/Length']);
+		        	$length = $tmp_length[1][1];
+		        } else {
+		        	$length = $this->actual_obj[1][1]['/Length'][1];
+		        if ($length > 0) {
+    		        $c->reset($startpos+$e,$length);
+    		        $v = $c->buffer;
+		        } else {
+		            $v = '';
+		        $c->reset($startpos+$e+$length+9); // 9 = strlen("endstream")
+		        return array(PDF_TYPE_STREAM, $v);
+	        case '%':
+	            // this is a comment - just jump over it
+    			while(1) {
+    			    // PHP 4.3.3 required
+                    #$match = preg_match("/(\r\n|\r|\n)/", $c->buffer, $m, PREG_OFFSET_CAPTURE, $pos);
+                    // alternative
+                    $match = preg_match("/(\r\n|\r|\n)/", substr($c->buffer, $pos), $m);
+    						return false;
+    					} else {
+                        	continue;
+                    #$c->offset = $m[0][1]+strlen($m[0][0]);
+    				// alternative
+                    $c->offset = strpos($c->buffer, $m[0], $pos)+strlen($m[0]);
+    				return $this->pdf_read_value($c);
+    		default	:
+            	if (is_numeric ($token)) {
+                    // A numeric token. Make sure that
+    				// it is not part of something else.
+    				if (($tok2 = $this->pdf_read_token ($c)) !== false) {
+                        if (is_numeric ($tok2)) {
+    						// Two numeric tokens in a row.
+    						// In this case, we're probably in
+    						// front of either an object reference
+    						// or an object specification.
+    						// Determine the case and return the data
+    						if (($tok3 = $this->pdf_read_token ($c)) !== false) {
+                                switch ($tok3) {
+    								case	'obj'	:
+                                        return array (PDF_TYPE_OBJDEC, (int) $token, (int) $tok2);
+    								case	'R'		:
+    									return array (PDF_TYPE_OBJREF, (int) $token, (int) $tok2);
+    							// If we get to this point, that numeric value up
+    							// there was just a numeric value. Push the extra
+    							// tokens back into the stack and return the value.
+    							array_push ($c->stack, $tok3);
+    					array_push ($c->stack, $tok2);
+    				if ($token === (string)((int)$token))
+        				return array (PDF_TYPE_NUMERIC, (int)$token);
+    				else
+    					return array (PDF_TYPE_REAL, (float)$token);
+    			} else if ($token == 'true' || $token == 'false') {
+                    return array (PDF_TYPE_BOOLEAN, $token == 'true');
+    			} else {
+                    // Just a token. Return it.
+    				return array (PDF_TYPE_TOKEN, $token);
+     * Resolve an object
+     * @param array $obj_spec The object-data
+     * @param boolean $encapsulate Must set to true, cause the parsing and fpdi use this method only without this para
+    function pdf_resolve_object(&$c, $obj_spec, $encapsulate = true) {
+        // Exit if we get invalid data
+    	if (!is_array($obj_spec)) {
+            return false;
+    	if ($obj_spec[0] == PDF_TYPE_OBJREF) {
+    		// This is a reference, resolve it
+    		if (isset($this->xref['xref'][$obj_spec[1]][$obj_spec[2]])) {
+    			// Save current file position
+    			// This is needed if you want to resolve
+    			// references while you're reading another object
+    			// (e.g.: if you need to determine the length
+    			// of a stream)
+    			$old_pos = ftell($c->file);
+    			// Reposition the file pointer and
+    			// load the object header.
+    			$c->reset($this->xref['xref'][$obj_spec[1]][$obj_spec[2]]);
+    			$header = $this->pdf_read_value($c,null,true);
+    			if ($header[0] != PDF_TYPE_OBJDEC || $header[1] != $obj_spec[1] || $header[2] != $obj_spec[2]) {
+    				$this->error("Unable to find object ({$obj_spec[1]}, {$obj_spec[2]}) at expected location");
+    			// If we're being asked to store all the information
+    			// about the object, we add the object ID and generation
+    			// number for later use
+				$this->actual_obj =& $result;
+    			if ($encapsulate) {
+    				$result = array (
+    					PDF_TYPE_OBJECT,
+    					'obj' => $obj_spec[1],
+    					'gen' => $obj_spec[2]
+    			} else {
+    			// Now simply read the object data until
+    			// we encounter an end-of-object marker
+    			while(1) {
+                    $value = $this->pdf_read_value($c);
+					if ($value === false || count($result) > 4) {
+						// in this case the parser coudn't find an endobj so we break here
+						break;
+    				if ($value[0] == PDF_TYPE_TOKEN && $value[1] === 'endobj') {
+    					break;
+    			$c->reset($old_pos);
+                if (isset($result[2][0]) && $result[2][0] == PDF_TYPE_STREAM) {
+                    $result[0] = PDF_TYPE_STREAM;
+    			return $result;
+    	} else {
+    		return $obj_spec;
+     * Reads a token from the file
+     * @return mixed
+    function pdf_read_token(&$c)
+    	// If there is a token available
+    	// on the stack, pop it out and
+    	// return it.
+    	if (count($c->stack)) {
+    		return array_pop($c->stack);
+    	// Strip away any whitespace
+    	do {
+    		if (!$c->ensure_content()) {
+    			return false;
+    		$c->offset += _strspn($c->buffer, " \n\r\t", $c->offset);
+    	} while ($c->offset >= $c->length - 1);
+    	// Get the first character in the stream
+    	$char = $c->buffer[$c->offset++];
+    	switch ($char) {
+    		case '['	:
+    		case ']'	:
+    		case '('	:
+    		case ')'	:
+    			// This is either an array or literal string
+    			// delimiter, Return it
+    			return $char;
+    		case '<'	:
+    		case '>'	:
+    			// This could either be a hex string or
+    			// dictionary delimiter. Determine the
+    			// appropriate case and return the token
+    			if ($c->buffer[$c->offset] == $char) {
+    				    return false;
+    				$c->offset++;
+    				return $char . $char;
+    			} else {
+    				return $char;
+    		default		:
+    			// This is "another" type of token (probably
+    			// a dictionary entry or a numeric value)
+    			// Find the end and return it.
+    				return false;
+    			while(1) {
+    				// Determine the length of the token
+    				$pos = _strcspn($c->buffer, " []<>()\r\n\t/", $c->offset);
+    				if ($c->offset + $pos <= $c->length - 1) {
+    					break;
+    				} else {
+    					// If the script reaches this point,
+    					// the token may span beyond the end
+    					// of the current buffer. Therefore,
+    					// we increase the size of the buffer
+    					// and try again--just to be safe.
+    					$c->increase_length();
+    			$result = substr($c->buffer, $c->offset - 1, $pos + 1);
+    			$c->offset += $pos;
+    			return $result;
Added: trunk/mapbender/http/extensions/fpdf/wrapper_functions.php
--- trunk/mapbender/http/extensions/fpdf/wrapper_functions.php	                        (rev 0)
+++ trunk/mapbender/http/extensions/fpdf/wrapper_functions.php	2010-01-19 23:07:49 UTC (rev 5359)
@@ -0,0 +1,70 @@
+<?php
+if (!defined("PHP_VER_LOWER43"))
+	define("PHP_VER_LOWER43", version_compare(PHP_VERSION, "4.3", "<"));
+ * ensure that strspn works correct if php-version < 4.3
+function _strspn($str1, $str2, $start=null, $length=null) {
+    $numargs = func_num_args();
+    if (PHP_VER_LOWER43 == 1) {
+        if (isset($length)) {
+            $str1 = substr($str1, $start, $length);
+        } else {
+            $str1 = substr($str1, $start);
+    if ($numargs == 2 || PHP_VER_LOWER43 == 1) {
+        return strspn($str1, $str2);
+    } else if ($numargs == 3) {
+        return strspn($str1, $str2, $start);
+    } else {
+        return strspn($str1, $str2, $start, $length);
+ * ensure that strcspn works correct if php-version < 4.3
+function _strcspn($str1, $str2, $start=null, $length=null) {
+        } else {
+        return strcspn($str1, $str2);
+        return strcspn($str1, $str2, $start);
+    } else {
+        return strcspn($str1, $str2, $start, $length);
More information about the Mapbender_commits mailing list
