[Mapbender-commits] r5365 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Jan 20 08:01:37 EST 2010
Author: christoph
Date: 2010-01-20 08:01:35 -0500 (Wed, 20 Jan 2010)
New Revision: 5365
   trunk/mapbender/http/javascripts/map_obj.js
do not animate map after the srs has changed
Modified: trunk/mapbender/http/javascripts/map_obj.js
--- trunk/mapbender/http/javascripts/map_obj.js	2010-01-20 11:25:30 UTC (rev 5364)
+++ trunk/mapbender/http/javascripts/map_obj.js	2010-01-20 13:01:35 UTC (rev 5365)
@@ -23,6 +23,7 @@
     var mapMsgObj;
 	var extentHasChanged = false;
+	var srsHasChanged = false;
     eventLocalize.register(function(){
         localizeMap();
@@ -369,6 +370,7 @@
             this.epsg = options.srs;
+		srsHasChanged = true;
         return this.calculateExtent(options.extent);
@@ -1136,7 +1138,7 @@
 		// show new map
-		if (doAnimation && extentHasChanged) {
+		if (doAnimation && extentHasChanged && !srsHasChanged) {
 			var previousRequest = $("#" + that.elementName + "_request_" + (index-1));
 			var wasPanned = parseInt(previousRequest.css("top"), 10) !== 0 ||
 				parseInt(previousRequest.css("left"), 10) !== 0;
@@ -1298,6 +1300,7 @@
 		this.history.forward(false);
+		srsHasChanged = false;
     var getLayerHtmlCode = function(ii, extent, width, height, top, left, requestCnt){
More information about the Mapbender_commits mailing list
