[Mapbender-commits] r5366 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Jan 20 08:01:56 EST 2010
Author: christoph
Date: 2010-01-20 08:01:56 -0500 (Wed, 20 Jan 2010)
New Revision: 5366
   trunk/mapbender/http/javascripts/mod_changeEPSG.js
Modified: trunk/mapbender/http/javascripts/mod_changeEPSG.js
--- trunk/mapbender/http/javascripts/mod_changeEPSG.js	2010-01-20 13:01:35 UTC (rev 5365)
+++ trunk/mapbender/http/javascripts/mod_changeEPSG.js	2010-01-20 13:01:56 UTC (rev 5366)
@@ -37,233 +37,214 @@
  * http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
-var that = this;
-var exists = false;
+var $changeEpsg = $(this);
-eventAfterMapRequest.register(function () {
-	$("#"+options.id+" option").each(function () {
-		if (this.value == mb_mapObj[0].epsg) {
-			isEPSG = true;
-			$(this).attr("selected", "selected");
-$(this).change(function () {
-	var srsValue = $("#"+options.id).get(0).value;
+$changeEpsg.change(function () {
+	var srsValue = this.value;
 	if (srsValue === "") {
 		return;
-	Mapbender.modules[options.id].setSrs({
-		srs: srsValue
+	$changeEpsg.mapbender(function () {
+		this.setSrs(srsValue);
 var ChangeEpsg = function () {
-	 * Method: setSrs
-	 * Description:
-	 * Sets the SRS for all maps and WMS in the current application.
-	 * The new bounding boxes are calculated with PostGIS!
-	 * After this, the maps are immediately requested in the new SRS.
-	 * Parameters:
-	 * options.srs      - (String) An SRS identifier, for example "EPSG:4326"
-	 * options.callback - (Function) A callback function. Should include the
-	this.setSrs = function (options) {
-		var srsValue;
-		if (typeof options === "object" && typeof options.srs === "string") {
-			srsValue = options.srs;
-		if (typeof srsValue === "undefined") {
-			new Mb_exception("setSrs: must specify an SRS.");
-			return;
-		var recalculateExtentOnly;
-		if (typeof options === "object" && typeof options.recalculateExtentOnly === "object") {
-			recalculateExtentOnly = options.recalculateExtentOnly;
-			if (typeof recalculateExtentOnly.target !== "string") {
-				new Mb_exception("setSrs: must specify a target if recalculateExtentOnly is set.");
-				return;
-			if (typeof recalculateExtentOnly.extent !== "object") {
-				new Mb_exception("setSrs: must specify an extent if recalculateExtentOnly is set.");
-				return;
+	var compileSrsArray = function () {
 		var srsArray = [];
-		if (recalculateExtentOnly) {
-			recalculateExtentOnly.map = Mapbender.modules[recalculateExtentOnly.target];
-			if (typeof recalculateExtentOnly.map !== "object" || recalculateExtentOnly.map === null) {
-				new Mb_exception("setSrs: invalid target set for recalculateExtentOnly.");
-				return;
-			var currentSrs = {
-				"frameName": recalculateExtentOnly.map.elementName,
-				"epsg": srsValue,
-				"extent": recalculateExtentOnly.extent.toString(),
-				"width": recalculateExtentOnly.map.width,
-				"height": recalculateExtentOnly.map.height
-			srsArray.push(currentSrs);
-		// calculate extents for all maps...
-		else {
-			for (var i = 0; i < mb_mapObj.length; i++) {
-					"frameName": mb_mapObj[i].elementName,
-					"epsg": mb_mapObj[i].epsg,
-					"extent": mb_mapObj[i].extent.toString(),
-					"width": mb_mapObj[i].width,
-					"height": mb_mapObj[i].height
-		// ... and all WMS.
-		if (!recalculateExtentOnly) {
-			for (var i = 0; i < wms.length; i++) {
-				var ext = wms[i].getBoundingBoxBySrs(mb_mapObj[0].epsg);
+		var wmsArray = [];
+		// this is kind of inconsistent...for WMS, only the new extent of
+		// the FIRST main map is calculated
+		var mainMap = $(":mainMaps").eq(0).mapbender();
+		$("div:maps").mapbender(function () {
+			srsArray.push({
+				frameName: this.elementName,
+				epsg: this.epsg,
+				extent: this.extent.toString(),
+				width: this.width,
+				height: this.height
+			for (var i = 0; i < this.wms.length; i++) {
+				var wms = this.wms[i];
+				// unique entries only
+				if ($.inArray(wms.wms_id, wmsArray) !== -1) {
+					continue;
+				// only wms with bounding box in current SRS
+				var ext = wms.getBoundingBoxBySrs(this.epsg);
 				if (ext === null) {
 					continue;
-					"wms" : wms[i].wms_id,
-					"epsg" : mb_mapObj[0].epsg,
-					"extent" : ext.toString(),
-					"width" : mb_mapObj[0].width,
-					"height" : mb_mapObj[0].height
+				srsArray.push({
+					wms: wms.wms_id,
+					epsg: mainMap.epsg,
+					extent: ext.toString(),
+					width: mainMap.width,
+					height: mainMap.height
+				wmsArray.push(wms.wms_id);
-		// perform transformation
-		var req = new Mapbender.Ajax.Request({
-			url: "../php/mod_changeEPSG_server.php",
-			method: "changeEpsg",
-			parameters: {
-				srs: srsArray,
-				newSrs: recalculateExtentOnly ? recalculateExtentOnly.map.epsg : srsValue
-			callback: function (obj, success, message) {
-				if (!success) {
-					new Mapbender.Exception(message);
-					return;
+		return srsArray;
+	var setSrsCallback = function (obj, success, message) {
+		if (!success) {
+			new Mapbender.Exception(message);
+			return;
+		var newExtent = obj;
+		var mapObjNames = [];
+		var myTarget = options.target[0];
+		var exists = false;
+		var i, j;
+		for (i = 0; i < newExtent.length; i++) {
+			if (newExtent[i].frameName) {
+				mapObjNames.push("#" + newExtent[i].frameName);
+			if (newExtent[i].wms) {
+				// global wms object is deprecated.
+				// this loop can be removed once the
+				// wms object has been removed.
+				// redundant.
-				var newExtent = obj;
-				var mapObjNames = [];
-				for(var i = 0; i < newExtent.length; i++) {
-					if (newExtent[i].frameName) {
-						mapObjNames.push(newExtent[i].frameName);
+				for (j = 0; j < wms.length; j++) {
+					if (wms[j].wms_id == newExtent[i].wms) {
+						wms[j].setBoundingBoxBySrs(
+							newExtent[i].newSrs,
+							new Extent(
+								parseFloat(newExtent[i].minx),
+								parseFloat(newExtent[i].miny),
+								parseFloat(newExtent[i].maxx),
+								parseFloat(newExtent[i].maxy)
-				for (var i = 0; i < newExtent.length; i++) {
-					if (newExtent[i].wms && !recalculateExtentOnly) {
-						for (var j = 0; j < wms.length; j++) {
-							if (parseInt(wms[j].wms_id, 10) === parseInt(newExtent[i].wms, 10)) {
-								wms[j].setBoundingBoxBySrs(
-									newExtent[i].newSrs,
-									new Extent(
-										parseFloat(newExtent[i].minx),
-										parseFloat(newExtent[i].miny),
-										parseFloat(newExtent[i].maxx),
-										parseFloat(newExtent[i].maxy)
-								for (var k = 0; k < mapObjNames.length; k++) {
-									var map = getMapObjByName(mapObjNames[k]);
-									map.wms[j].setBoundingBoxBySrs(
-										new Extent(
-								break;
-						continue;
-					// use the previous extent of the overview
-					if(!recalculateExtentOnly && newExtent[i].frameName == options.target){
-						var map = Mapbender.modules[options.target];
-						var goback = false;
-						for (var ii = 0; ii < map.mb_MapHistoryObj.length; ii++) {
-							if (map.mb_MapHistoryObj[ii].epsg == newExtent[i].newSrs) {
-								exists = ii;
-								goback = true;
-						if (goback) {
-							map.setSrs({
-								srs: newExtent[i].newSrs,
-								extent: map.mb_MapHistoryObj[exists].extent,
-								displayWarning: false
-						else{
-							map.setSrs({
-								extent: new Mapbender.Extent(
+				$(mapObjNames.join(",")).mapbender(function(){
+					for (j = 0; j < this.wms.length; j++) {
+						if (this.wms[j].wms_id == newExtent[i].wms) {
+							this.wms[j].setBoundingBoxBySrs(
+								new Extent(
+						break;
-					else {
-						var map = Mapbender.modules[newExtent[i].frameName];
-						map.setSrs({
-							displayWarning: true
+			// Overview map
+			if (newExtent[i].frameName === myTarget){
+				var map = $("#" + myTarget).mapbender();
+				for (var ii = 0; ii < map.mb_MapHistoryObj.length; ii++) {
+					if (map.mb_MapHistoryObj[ii].epsg == newExtent[i].newSrs) {
+						exists = ii;
+						var goback = true;
-				if (typeof options.callback === "function") {
-					options.callback();
+				if (goback) {
+					var extArray = map.mb_MapHistoryObj[exists].extent.split(",");
+					var newExt = new Extent(
+						parseFloat(extArray[0]),
+						parseFloat(extArray[1]),
+						parseFloat(extArray[2]),
+						parseFloat(extArray[3])
+					map.setSrs({
+						srs: newExtent[i].newSrs,
+						extent: newExt,
+						displayWarning: false
-					mb_mapObj[i].setMapRequest();
+				else{
+					map.setSrs({
+						extent: new Extent(
+			// Main maps
+			else {
+				$("#" + newExtent[i].frameName).mapbender(function () {
+					this.setSrs({
+						displayWarning: true
+		setTimeout(function () {
+			$(":maps").mapbender(function () {
+				this.setMapRequest();
+		}, 200);
+	this.setSrs = function (val) {
+		var srsArray = compileSrsArray();
+		var req = new Mapbender.Ajax.Request({
+			method: "changeEpsg",
+			url: "../php/mod_changeEPSG_server.php",
+			callback: setSrsCallback,
+			parameters:{
+				srs: srsArray,
+				newSrs: val
 		req.send();
-Mapbender.modules[options.id] = $.extend(new ChangeEpsg(), Mapbender.modules[options.id]);
+	// update epsg in select box after any map request
+	Mapbender.events.init.register(function () {
+		$("div:mainMaps").mapbender(function () {
+			var map = this;
+			map.events.afterMapRequest.register(function () {
+				$changeEpsg.children("option").each(function () {
+					if (this.value === map.epsg) {
+						$(this).attr("selected", "selected");
+$changeEpsg.mapbender(new ChangeEpsg());
More information about the Mapbender_commits mailing list
