[Mapbender-commits] r5380 - trunk/mapbender/http/extensions
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Jan 20 11:00:32 EST 2010
Author: christoph
Date: 2010-01-20 11:00:32 -0500 (Wed, 20 Jan 2010)
New Revision: 5380
Added:
   trunk/mapbender/http/extensions/jquery.form.min.js
Added: trunk/mapbender/http/extensions/jquery.form.min.js
--- trunk/mapbender/http/extensions/jquery.form.min.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/jquery.form.min.js	2010-01-20 16:00:32 UTC (rev 5380)
@@ -0,0 +1,66 @@
+;(function($){$.fn.ajaxSubmit=function(options){if(!this.length){log('ajaxSubmit: skipping submit process - no element selected');return this;}
+if(typeof options=='function')
+options={success:options};options=$.extend({url:this.attr('action')||window.location.toString(),type:this.attr('method')||'GET'},options||{});var veto={};this.trigger('form-pre-serialize',[this,options,veto]);if(veto.veto){log('ajaxSubmit: submit vetoed via form-pre-serialize trigger');return this;}
+if(options.beforeSerialize&&options.beforeSerialize(this,options)===false){log('ajaxSubmit: submit aborted via beforeSerialize callback');return this;}
+var a=this.formToArray(options.semantic);if(options.data){options.extraData=options.data;for(var n in options.data){if(options.data[n]instanceof Array){for(var k in options.data[n])
+a.push({name:n,value:options.data[n][k]})}
+else
+a.push({name:n,value:options.data[n]});}}
+if(options.beforeSubmit&&options.beforeSubmit(a,this,options)===false){log('ajaxSubmit: submit aborted via beforeSubmit callback');return this;}
+this.trigger('form-submit-validate',[a,this,options,veto]);if(veto.veto){log('ajaxSubmit: submit vetoed via form-submit-validate trigger');return this;}
+var q=$.param(a);if(options.type.toUpperCase()=='GET'){options.url+=(options.url.indexOf('?')>=0?'&':'?')+q;options.data=null;}
+else
+options.data=q;var $form=this,callbacks=[];if(options.resetForm)callbacks.push(function(){$form.resetForm();});if(options.clearForm)callbacks.push(function(){$form.clearForm();});if(!options.dataType&&options.target){var oldSuccess=options.success||function(){};callbacks.push(function(data){$(options.target).html(data).each(oldSuccess,arguments);});}
+else if(options.success)
+callbacks.push(options.success);options.success=function(data,status){for(var i=0,max=callbacks.length;i<max;i++)
+callbacks[i].apply(options,[data,status,$form]);};var files=$('input:file',this).fieldValue();var found=false;for(var j=0;j<files.length;j++)
+if(files[j])
+found=true;if(options.iframe||found){if(options.closeKeepAlive)
+$.get(options.closeKeepAlive,fileUpload);else
+fileUpload();}
+else
+$.ajax(options);this.trigger('form-submit-notify',[this,options]);return this;function fileUpload(){var form=$form[0];if($(':input[name=submit]',form).length){alert('Error: Form elements must not be named "submit".');return;}
+var opts=$.extend({},$.ajaxSettings,options);var s=jQuery.extend(true,{},$.extend(true,{},$.ajaxSettings),opts);var id='jqFormIO'+(new Date().getTime());var $io=$('<iframe id="'+id+'" name="'+id+'" src="about:blank" />');var io=$io[0];$io.css({position:'absolute',top:'-1000px',left:'-1000px'});var xhr={aborted:0,responseText:null,responseXML:null,status:0,statusText:'n/a',getAllResponseHeaders:function(){},getResponseHeader:function(){},setRequestHeader:function(){},abort:function(){this.aborted=1;$io.attr('src','about:blank');}};var g=opts.global;if(g&&!$.active++)$.event.trigger("ajaxStart");if(g)$.event.trigger("ajaxSend",[xhr,opts]);if(s.beforeSend&&s.beforeSend(xhr,s)===false){s.global&&jQuery.active--;return;}
+if(xhr.aborted)
+return;var cbInvoked=0;var timedOut=0;var sub=form.clk;if(sub){var n=sub.name;if(n&&!sub.disabled){options.extraData=options.extraData||{};options.extraData[n]=sub.value;if(sub.type=="image"){options.extraData[name+'.x']=form.clk_x;options.extraData[name+'.y']=form.clk_y;}}}
+setTimeout(function(){var t=$form.attr('target'),a=$form.attr('action');form.setAttribute('target',id);if(form.getAttribute('method')!='POST')
+form.setAttribute('method','POST');if(form.getAttribute('action')!=opts.url)
+form.setAttribute('action',opts.url);if(!options.skipEncodingOverride){$form.attr({encoding:'multipart/form-data',enctype:'multipart/form-data'});}
+if(opts.timeout)
+setTimeout(function(){timedOut=true;cb();},opts.timeout);var extraInputs=[];try{if(options.extraData)
+for(var n in options.extraData)
+extraInputs.push($('<input type="hidden" name="'+n+'" value="'+options.extraData[n]+'" />').appendTo(form)[0]);$io.appendTo('body');io.attachEvent?io.attachEvent('onload',cb):io.addEventListener('load',cb,false);form.submit();}
+finally{form.setAttribute('action',a);t?form.setAttribute('target',t):$form.removeAttr('target');$(extraInputs).remove();}},10);var nullCheckFlag=0;function cb(){if(cbInvoked++)return;io.detachEvent?io.detachEvent('onload',cb):io.removeEventListener('load',cb,false);var ok=true;try{if(timedOut)throw'timeout';var data,doc;doc=io.contentWindow?io.contentWindow.document:io.contentDocument?io.contentDocument:io.document;if((doc.body==null||doc.body.innerHTML=='')&&!nullCheckFlag){nullCheckFlag=1;cbInvoked--;setTimeout(cb,100);return;}
+xhr.responseText=doc.body?doc.body.innerHTML:null;xhr.responseXML=doc.XMLDocument?doc.XMLDocument:doc;xhr.getResponseHeader=function(header){var headers={'content-type':opts.dataType};return headers[header];};if(opts.dataType=='json'||opts.dataType=='script'){var ta=doc.getElementsByTagName('textarea')[0];xhr.responseText=ta?ta.value:xhr.responseText;}
+else if(opts.dataType=='xml'&&!xhr.responseXML&&xhr.responseText!=null){xhr.responseXML=toXml(xhr.responseText);}
+data=$.httpData(xhr,opts.dataType);}
+catch(e){ok=false;$.handleError(opts,xhr,'error',e);}
+if(ok){opts.success(data,'success');if(g)$.event.trigger("ajaxSuccess",[xhr,opts]);}
+if(g)$.event.trigger("ajaxComplete",[xhr,opts]);if(g&&!--$.active)$.event.trigger("ajaxStop");if(opts.complete)opts.complete(xhr,ok?'success':'error');setTimeout(function(){$io.remove();xhr.responseXML=null;},100);};function toXml(s,doc){if(window.ActiveXObject){doc=new ActiveXObject('Microsoft.XMLDOM');doc.async='false';doc.loadXML(s);}
+else
+doc=(new DOMParser()).parseFromString(s,'text/xml');return(doc&&doc.documentElement&&doc.documentElement.tagName!='parsererror')?doc:null;};};};$.fn.ajaxForm=function(options){return this.ajaxFormUnbind().bind('submit.form-plugin',function(){$(this).ajaxSubmit(options);return false;}).each(function(){$(":submit,input:image",this).bind('click.form-plugin',function(e){var form=this.form;form.clk=this;if(this.type=='image'){if(e.offsetX!=undefined){form.clk_x=e.offsetX;form.clk_y=e.offsetY;}else if(typeof $.fn.offset=='function'){var offset=$(this).offset();form.clk_x=e.pageX-offset.left;form.clk_y=e.pageY-offset.top;}else{form.clk_x=e.pageX-this.offsetLeft;form.clk_y=e.pageY-this.offsetTop;}}
+setTimeout(function(){form.clk=form.clk_x=form.clk_y=null;},10);});});};$.fn.ajaxFormUnbind=function(){this.unbind('submit.form-plugin');return this.each(function(){$(":submit,input:image",this).unbind('click.form-plugin');});};$.fn.formToArray=function(semantic){var a=[];if(this.length==0)return a;var form=this[0];var els=semantic?form.getElementsByTagName('*'):form.elements;if(!els)return a;for(var i=0,max=els.length;i<max;i++){var el=els[i];var n=el.name;if(!n)continue;if(semantic&&form.clk&&el.type=="image"){if(!el.disabled&&form.clk==el)
+a.push({name:n+'.x',value:form.clk_x},{name:n+'.y',value:form.clk_y});continue;}
+var v=$.fieldValue(el,true);if(v&&v.constructor==Array){for(var j=0,jmax=v.length;j<jmax;j++)
+a.push({name:n,value:v[j]});}
+else if(v!==null&&typeof v!='undefined')
+a.push({name:n,value:v});}
+if(!semantic&&form.clk){var inputs=form.getElementsByTagName("input");for(var i=0,max=inputs.length;i<max;i++){var input=inputs[i];var n=input.name;if(n&&!input.disabled&&input.type=="image"&&form.clk==input)
+a.push({name:n+'.x',value:form.clk_x},{name:n+'.y',value:form.clk_y});}}
+return a;};$.fn.formSerialize=function(semantic){return $.param(this.formToArray(semantic));};$.fn.fieldSerialize=function(successful){var a=[];this.each(function(){var n=this.name;if(!n)return;var v=$.fieldValue(this,successful);if(v&&v.constructor==Array){for(var i=0,max=v.length;i<max;i++)
+a.push({name:n,value:v[i]});}
+a.push({name:this.name,value:v});});return $.param(a);};$.fn.fieldValue=function(successful){for(var val=[],i=0,max=this.length;i<max;i++){var el=this[i];var v=$.fieldValue(el,successful);if(v===null||typeof v=='undefined'||(v.constructor==Array&&!v.length))
+continue;v.constructor==Array?$.merge(val,v):val.push(v);}
+return val;};$.fieldValue=function(el,successful){var n=el.name,t=el.type,tag=el.tagName.toLowerCase();if(typeof successful=='undefined')successful=true;if(successful&&(!n||el.disabled||t=='reset'||t=='button'||(t=='checkbox'||t=='radio')&&!el.checked||(t=='submit'||t=='image')&&el.form&&el.form.clk!=el||tag=='select'&&el.selectedIndex==-1))
+return null;if(tag=='select'){var index=el.selectedIndex;if(index<0)return null;var a=[],ops=el.options;var one=(t=='select-one');var max=(one?index+1:ops.length);for(var i=(one?index:0);i<max;i++){var op=ops[i];if(op.selected){var v=op.value;if(!v)
+v=(op.attributes&&op.attributes['value']&&!(op.attributes['value'].specified))?op.text:op.value;if(one)return v;a.push(v);}}
+return a;}
+return el.value;};$.fn.clearForm=function(){return this.each(function(){$('input,select,textarea',this).clearFields();});};$.fn.clearFields=$.fn.clearInputs=function(){return this.each(function(){var t=this.type,tag=this.tagName.toLowerCase();if(t=='text'||t=='password'||tag=='textarea')
+this.value='';else if(t=='checkbox'||t=='radio')
+this.checked=false;else if(tag=='select')
+this.selectedIndex=-1;});};$.fn.resetForm=function(){return this.each(function(){if(typeof this.reset=='function'||(typeof this.reset=='object'&&!this.reset.nodeType))
+this.reset();});};$.fn.enable=function(b){if(b==undefined)b=true;return this.each(function(){this.disabled=!b});};$.fn.selected=function(select){if(select==undefined)select=true;return this.each(function(){var t=this.type;if(t=='checkbox'||t=='radio')
+this.checked=select;else if(this.tagName.toLowerCase()=='option'){var $sel=$(this).parent('select');if(select&&$sel[0]&&$sel[0].type=='select-one'){$sel.find('option').selected(false);}
+this.selected=select;}});};function log(){if($.fn.ajaxSubmit.debug&&window.console&&window.console.log)
+window.console.log('[jquery.form] '+Array.prototype.join.call(arguments,''));};})(jQuery);
\ No newline at end of file
More information about the Mapbender_commits mailing list
