[Mapbender-commits] r5381 - trunk/mapbender/http/print
svn_mapbender at osgeo.org
Wed Jan 20 11:00:52 EST 2010
Author: christoph
Date: 2010-01-20 11:00:52 -0500 (Wed, 20 Jan 2010)
New Revision: 5381
Removed:
trunk/mapbender/http/print/mod_printPDF_div.js
trunk/mapbender/http/print/printbox.js
Deleted: trunk/mapbender/http/print/mod_printPDF_div.js
--- trunk/mapbender/http/print/mod_printPDF_div.js 2010-01-20 16:00:32 UTC (rev 5380)
+++ trunk/mapbender/http/print/mod_printPDF_div.js 2010-01-20 16:00:52 UTC (rev 5381)
@@ -1,444 +0,0 @@
- * Package: printPDF
- * Description:
- * Mapbender print PDF with PDF templates module.
- * Files:
- * - http/print/mod_printPDF_div.js
- * - http/print/classes
- * - http/print/printFactory.php
- * - http/print/printPDF_download.php
- * - http/print/printbox.js
- * SQL:
- * > INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui2','printPDF',2,1,'pdf print','Print','div','','',1,1,2,2,5,'','<div id="printPDF_working_bg"></div>
- * > <div id="printPDF_working">
- * > <img src="../img/indicator_wheel.gif" style="padding:10px 0 0 10px">
- * > Generating PDF
- * > </div>
- * > <div id="printPDF_input">
- * > <form id="printPDF_form" action="../print/printFactory.php">
- * > <div id="printPDF_selector"></div>
- * > <div class="print_option">
- * > <input type="hidden" id="map_url" name="map_url" value=""/>
- * > <input type="hidden" id="overview_url" name="overview_url" value=""/>
- * > <input type="hidden" name="measured_x_values" />
- * > <input type="hidden" name="measured_y_values" /><br />
- * > </div>
- * > <div class="print_option" id="printPDF_formsubmit">
- * > <input id="submit" type="submit" value="Print"><br />
- * > </div>
- * > </form>
- * > <div id="printPDF_result">
- * > </div>
- * > </div>','div','../print/mod_printPDF_div.js','','mapframe1','','http://www.mapbender.org/index.php/Print');
- * > INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'printPDF', 'mbPrintConfigFilenames', '["testConfigTemplate.json"]', '' ,'var');
- * > INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'printPDF', 'mbPrintConfigTitles', '["Standard"]', '' ,'var');
- * Help:
- * http://www.mapbender.org/PrintPDF_with_template
- * Maintainer:
- * http://www.mapbender.org/User:Michael_Schulz
- * Parameters:
- * mbPrintConfigFilenames - *[optional]* JSON string array / filenames of the json configuration files
- * mbPrintConfigTitles - *[optional]* JSON string array / title of the template to be shown in a select box in a mapbender application
- * License:
- * Copyright (c) 2009, Open Source Geospatial Foundation
- * This program is dual licensed under the GNU General Public License
- * and Simplified BSD license.
- * http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
-var myTarget = options.target ? options.target[0] : "mapframe1";
-var myId = options ? options.id : "printPDF";
-/* the array of json print config files */
-if (typeof mbPrintConfigFilenames === "undefined") {
- mbPrintConfigFilenames = ["mapbender_template.json"];
-if (typeof mbPrintConfigTitles === "undefined") {
- mbPrintConfigTitles = ["Default"];
-var mbPrintConfigPath = "../print/";
-/* ------------- printbox addition ------------- */
-var PrintPDF = function (options) {
- var that = this;
- * Property: actualConfig
- * object, holds the actual configuration after loading the json file
- var actualConfig;
- * constructor
- eventInit.register(function () {
- mod_printPDF_init();
- * Property: printBox
- * the movable printframe
- var printBox = null;
- eventAfterMapRequest.register(function () {
- if (printBox !== null) {
- printBox.repaint();
- * Method: createPrintBox
- * creates a printBox in the current view, calculates the scale
- * (tbd. if not set from the config) so that the printbox fits in the mapframe.
- * Width and height are taken from the configuration.
- this.createPrintBox = function () {
- size = "A4";
- //document.form1.size.value = size;
- format = "portrait";
- var w, h;
- //validate();
- var map = getMapObjByName(myTarget);
- var map_el = map.getDomElement();
- var jqForm = $("#"+myId+"_form");
- var $scaleInput = $("#scale");
- printBox.destroy();
- printBox = null;
- jqForm[0].scale.value = "";
- jqForm[0].coordinates.value = "";
- jqForm[0].angle.value = "";
- else {
- printBox = createBox({
- target : myTarget,
- printWidth : getPDFMapSize("width")/10,
- printHeight : getPDFMapSize("height")/10,
- scale : $scaleInput.size() > 0 && !isNaN(parseInt($scaleInput.val(), 10)) ?
- parseInt($scaleInput.val(), 10) :
- Math.pow(10, Math.floor(Math.log(map.getScale())/Math.LN10)),
- afterChangeAngle : function (obj) {
- if (typeof(obj) == "object") {
- if (typeof(obj.angle) == "number") {
- jqForm[0].angle.value = obj.angle;
- if (obj.coordinates) {
- jqForm[0].coordinates.value = String(obj.coordinates);
- afterChangeSize : function (obj) {
- if (obj.scale) {
- jqForm[0].scale.value = parseInt(obj.scale / 100, 10) * 100;
- * Method: getPDFMapSize
- * checks the actual config for the size w/h values.
- * Parameters:
- * key - string, the key which value to retrieve (currently width or height)
- var getPDFMapSize = function (key) {
- for (var page in actualConfig.pages) {
- for (var pageElement in actualConfig.pages[page].elements) {
- if (actualConfig.pages[page].elements[pageElement].type == "map") {
- return actualConfig.pages[page].elements[pageElement][key];
- * Method: destroyPrintBox
- * removes an existing printBox.
- var destroyPrintBox = function () {
- if (printBox) {
- * Method: mod_printPDF_init
- * initializes the print modules, generates template chooser and loads first configuration.
- var mod_printPDF_init = function () {
- /* first we'd need to build the configuration selection */
- buildConfigSelector();
- /* second we'd need to read the json configuration */
- that.loadConfig(mbPrintConfigFilenames[0]);
- * Method: loadConfig
- * GETs the config, build corresponding form, remove an existing printBox
- this.loadConfig = function (configFilename, callback) {
- $.get(mbPrintConfigPath + configFilename, function(json, status){
- actualConfig = $.parseJSON(json);
- buildForm();
- hookForm();
- if (typeof callback === "function") {
- printBox = null;
- callback();
- destroyPrintBox();
- * Method: hookForm
- * utility method to connect the form plugin to the print form.
- var hookForm = function () {
- var options = {
- url: '../print/printFactory.php',
- type: 'post',
- dataType: 'json',
- beforeSubmit: validate,
- success: showResult
- $("#"+myId+"_form").ajaxForm(options);
- * Change status of the working elements. These should begin with "$myId_working"
- * @param {String} newStatus either "hide or "show"
- var showHideWorking = function (newStatus) {
- if (newStatus=="hide") {
- $("[id^='"+myId+"_working']").hide();
- else {
- $("[id^='"+myId+"_working']").show();
- * update form values helper function
- var updateFormField = function (formData, key, value) {
- for(var j=0; j < formData.length; j++){
- if (formData[j].name == key) {
- formData[j].value = value;
- break;
- * Validates and updates form data values.
- * Adds the elements before the submit button.
- * @see jquery.forms#beforeSubmitHandler
- var validate = function (formData, jqForm, options) {
- showHideWorking("show");
- // map urls
- var ind = getMapObjIndexByName(myTarget);
- var f = jqForm[0];
- f.map_url.value = '';
- f.overview_url.value = '';
- for(var i=0; i < mb_mapObj[ind].wms.length; i++){
- if(mb_mapObj[ind].wms[i].gui_wms_visible > 0){
- if(mb_mapObj[ind].wms[i].mapURL != false && mb_mapObj[ind].wms[i].mapURL != 'false' && mb_mapObj[ind].wms[i].mapURL != ''){
- if(f.map_url.value != ""){
- f.map_url.value += '___';
- f.map_url.value += mb_mapObj[ind].wms[i].mapURL;
- updateFormField(formData, "map_url", f.map_url.value);
- //overview_url
- var ind_overview = getMapObjIndexByName('overview');
- if(mb_mapObj[ind_overview].mapURL != false ){
- f.overview_url.value = mb_mapObj[ind_overview].mapURL;
- updateFormField(formData, "overview_url", f.overview_url.value);
- updateFormField(formData, "map_scale", mb_getScale(myTarget));
- // write the measured coordinates
- if (typeof(mod_measure_RX) !== "undefined") {
- var tmp_x = '';
- var tmp_y = '';
- for(i = 0; i < mod_measure_RX.length; i++) {
- if(tmp_x != '') {
- tmp_x += ',';
- tmp_x += mod_measure_RX[i];
- for(i = 0; i < mod_measure_RY.length; i++) {
- if(tmp_y != '') {
- tmp_y += ',';
- tmp_y += mod_measure_RY[i];
- updateFormField(formData, "measured_x_values", tmp_x);
- updateFormField(formData, "measured_y_values", tmp_y);
- if (f.map_url.value!="") {
- //return true;
- } else {
- showHideWorking("hide");
- return false;
- * Method: showResult
- * load the generated PDF from the returned URL as an attachment,
- * that triggers a download popup or is displayed in PDF plugin.
- var showResult = function (res, text) {
- if (text == 'success') {
- var $downloadFrame = $("#" + myId + "_frame");
- if ($downloadFrame.size() === 0) {
- $downloadFrame = $(
- "<iframe id='" + myId + "_frame' name='" +
- myId + "_frame' width='0' height='0' style='display:none'></iframe>"
- ).appendTo("body");
- if ($.browser.msie && $.browser.version === "6.0") {
- var newWin = window.open(stripslashes(res.outputFileName), "Druckausgabe", "width=200,height=200,left=700,top=200,resizable=yes");
- else {
- window.frames[myId + "_frame"].location.href =
- stripslashes(res.outputFileName);
- else {
- /* something went wrong */
- $("#"+myId+"_result").html(text);
- * Generates form elements as specified in the config controls object.
- * @param {Object} json the config object in json
- var buildForm = function () {
- $(".print_option_dyn").remove();
- var str = "";
- for (var item in actualConfig.controls) {
- var element = actualConfig.controls[item];
- var element_id = myId + "_" + element.id;
- if (element.type != "hidden") {
- str += '<div class="print_option_dyn">\n';
- str += '<label class="print_label" for="'+element.id+'">'+element.label+'</label>\n';
- } else {
- str += '<div class="print_option_dyn" style="display:none;">\n';
- switch (element.type) {
- case "text":
- str += '<input type="'+element.type+'" name="'+element.id+'" id="'+element.id+'" size="'+element.size+'"><br>\n';
- break;
- case "hidden":
- str += '<input type="'+element.type+'" name="'+element.id+'" id="'+element.id+'">\n';
- break;
- case "textarea":
- str += '<textarea id="'+element.id+'" name="'+element.id+'" size="'+element.size+'"></textarea><br>\n';
- break;
- case "select":
- str += '<select id="'+element.id+'" name="'+element.id+'" size="1">\n';
- for (var option_index in element.options) {
- option = element.options[option_index];
- str += '<option value="'+option.value+'">'+option.label+'</option>\n';
- str += '</select><br>\n';
- break;
- str += '</div>\n';
- if (str) {
- $("#" + myId + "_formsubmit").before(str);
- $("#scale").keydown(function (e) {
- if (e.keyCode !== 13) {
- return;
- var scale = parseInt(this.value, 10);
- if (isNaN(scale) || typeof printBox === "undefined") {
- return false;
- printBox.setScale(scale);
- return false;
- * Generates the configuration select element from the gui element vars
- * mbPrintConfigFilenames and mbPrintConfigTitles
- var buildConfigSelector = function () {
- var str = "";
- str += '<label class="print_label" for="printPDF_template">Vorlage</label>\n';
- str += '<select id="printPDF_template" name="printPDF_template" size="1" onchange="printObj.loadConfig(mbPrintConfigFilenames[this.selectedIndex], function () {printObj.createPrintBox()});">\n';
- for (var i = 0; i < mbPrintConfigFilenames.length; i++) {
- str += '<option value="'+mbPrintConfigFilenames[i]+'">'+mbPrintConfigTitles[i]+'</option>\n';
- str += '</select><img src="../print/img/shape_handles.png" onclick="try{printObj.createPrintBox();}catch(exc){alert(printObj);}" title="Use printbox">\n';
- if (str) {
- $("#printPDF_selector").append(str);
- $("#printPDF_working").bgiframe({
- src: "BLOCKED SCRIPT'<html></html>';",
- width: 200,
- height: 200
- var stripslashes = function ( str ) {
- return (str+'').replace(/\0/g, '0').replace(/\\([\\'"])/g, '$1');
-var printObj = new PrintPDF();
Deleted: trunk/mapbender/http/print/printbox.js
--- trunk/mapbender/http/print/printbox.js 2010-01-20 16:00:32 UTC (rev 5380)
+++ trunk/mapbender/http/print/printbox.js 2010-01-20 16:00:52 UTC (rev 5381)
@@ -1,709 +0,0 @@
-function createBox (options) {
- myPrintBox = new PrintBox(options);
- myPrintBox.paintPoints();
- myPrintBox.paintBox();
- return myPrintBox;
-function PrintBox (options) {
- if (!options) {
- options = {};
- var target = options.target || "mapframe1";
- var map = getMapObjByName(target);
-// var map = Mapbender.modules[target];
- // Default is portrait, A4, unit seems to be cm
- var printWidth = options.printWidth || 21;
- var printHeight = options.printHeight || 29.7;
- // initialised in setScale()
- var boxWidth, boxHeight;
- var scale = options.scale || 100000;
- // behaviour
- var afterChangeAngle = options.afterChangeAngle || function (obj) {};
- var afterChangeSize = options.afterChangeSize || function (obj) {};
- // styles
- var opacity = options.boxOpacity || 0.6;
- var boxColour = options.boxColour || "#9999FF";
- var frameColour = options.frameColour || "#000000";
- var pointColour = options.pointColour || "#DD0000";
- var circleColour = options.circleColour || "#DD0000";
- var circleWidth = options.circleWidth || 4;
- // attributes
- this.id = "printbox";
- var angle = 0;
- var totalAngle = 0;
- // the four points of the box as pixel coordinates (incl rotation),
- // with (0,0) as center. This is important for angle calculations.
- var pointArray = [];
- // The pointArray is moved by the center vector.
- // default: place box in the center of the map
- var center = options.center || new Point(map.width/2,map.height/2);
- // the center in real world coordinates
- var centerMap = null;
- // the four points of the box as pixel coordinates (NO ROTATION)
- var startPointPixArray = [];
- // the four points of the box as real world coordinates (NO ROTATION)
- var startPointMapArray = [];
- var that = this;
- // if the box is smaller than this, the circle will not be drawn
- var MIN_BOX_WIDTH_OR_HEIGHT = 10;
- // if the box is larger than this, the box will not be filled
- var MAX_BOX_WIDTH_OR_HEIGHT = 800;
- this.toString = function () {
- var str = "";
- str += "Center: " + getCenter() + "\n";
- str += "Radius: " + radius + "\n";
- str += "StartRadius: " + startRadius + "\n";
- str += "Pixelpos: " + String(pointArray) + "\n";
- str += "StartPixelpos: " + String(startPointPixArray) + "\n";
- str += "Mappos: " + String(startPointMapArray) + "\n";
- return str;
- var initBehaviour = function () {
- initMoveBehaviour();
- initResizeBehaviour();
- initRotateBehaviour();
- var initRotateBehaviour = function () {
- $circleCanvas.css("z-index", "110").mousedown(function (e) {
- circleCanvas.clear();
- var newCenter = getCenter();
- var mouseMoveStart = map.getMousePos(e);
- var vectorA = pointArray[0].minus(newCenter);
- var currentPos = map.getMousePos(e);
- var vectorCurrent = currentPos.minus(newCenter);
- angle = Math.ceil(getAngle(vectorA, vectorCurrent));
- $(document).mousemove(function (e) {
- var currentAngle = Math.ceil(getAngle(vectorA, vectorCurrent));
- var diffAngle = currentAngle - angle;
- if (Math.abs(diffAngle) >= 1) {
- angle = currentAngle;
- totalAngle = ((totalAngle + diffAngle) +360 )% 360;
- that.rotate(totalAngle);
- return false;
- }).mouseup(function (e) {
- angle = 0;
- $(document).unbind("mousemove");
- $(document).unbind("mouseup");
- afterChangeAngle({
- angle: totalAngle,
- coordinates: that.getStartCoordinates()
- that.paintBox();
- return false;
- return false;
- }).css("cursor", "move");
- var initMoveBehaviour = function () {
- $boxCanvas.mousedown(function (e) {
- var containerStart = new Point(
- parseInt($container.css("left"), 10),
- parseInt($container.css("top"), 10)
- var diff;
- diff = (map.getMousePos(e)).minus(mouseMoveStart);
- $container.css({
- "top": (containerStart.y + diff.y) + "px",
- "left": (containerStart.x + diff.x) + "px"
- return false;
- recalculateMapPositions();
- that.paintBox();
- return false;
- return false;
- var initResizeBehaviour = function () {
- $pointCanvas.css("z-index", "120").mousedown(function (e) {
- var vectorA = getCenter();
- resizeRatio = 1;
- mouseMoveStart = map.getMousePos(e);
- var newRadius = vectorA.dist(map.getMousePos(e));
- var resizeRatio = newRadius / radius;
- if (resizeRatio < 0.98 || resizeRatio > 1.02) {
- for (var i = 0; i < pointArray.length; i++) {
- pointArray[i].x *= resizeRatio;
- pointArray[i].y *= resizeRatio;
- startPointPixArray[i].x *= resizeRatio;
- startPointPixArray[i].y *= resizeRatio;
- radius *= resizeRatio;
- that.paintPoints();
- return false;
- $(document).mouseup(function (e) {
- recalculatePixPositions();
- afterChangeSize({
- scale: that.getScale(),
- that.paintBox();
- return false;
- return false;
- var setCenter = function (inputCenter) {
- center = inputCenter.minus(
- new Point(
- var getCenter = function () {
- var c = center.plus(
- new Point(
- return c;
- * Calculates the angle (-180 < angle <= 180) between two vectors.
- * @param {Point} a
- * @param {Point} b
- var getAngle = function (a, b) {
- var undirectedAngle = 180 * Math.acos(
- (a.x * b.x + a.y * b.y)
- Math.sqrt(
- a.x * a.x
- a.y * a.y
- Math.sqrt(
- b.x * b.x
- b.y * b.y
- ) / Math.PI;
- if ((a.x*b.y - a.y*b.x) > 0) {
- return -1 * undirectedAngle;
- return undirectedAngle;
- * To be replaced by the map objects native getMousePosition
- * @param {Event} e
- var getMousePos = function (e) {
- if ($.msie) {
- return new Point(event.clientX, event.clientY);
- return new Point(e.pageX, e.pageY);
- var recalculateMapPositions = function () {
- startPointMapArray[i] = convertPixelToMap(startPointPixArray[i].plus(getCenter()));
- centerMap = convertPixelToMap(getCenter());
- var recalculatePixPositions = function () {
- setCenter(convertMapToPixel(centerMap));
- for (var i = 0; i < startPointMapArray.length; i++) {
- pointArray[i] = convertMapToPixel(startPointMapArray[i]).minus(getCenter());
- startPointPixArray[i] = convertMapToPixel(startPointMapArray[i]).minus(getCenter());
- radius = pointArray[0].dist(new Point(0,0));
- startRadius = radius;
- boxWidth = pointArray[2].x - pointArray[0].x;
- boxHeight = pointArray[0].y - pointArray[2].y;
- var initPoints = function () {
- var w = parseInt((boxWidth/2), 10);
- var h = parseInt((boxHeight/2), 10);
- pointArray[0] = new Point(-w, h);
- pointArray[1] = new Point( w, h);
- pointArray[2] = new Point( w, -h);
- pointArray[3] = new Point(-w, -h);
- startPointPixArray[0] = (new Point(-w, h));
- startPointPixArray[1] = (new Point( w, h));
- startPointPixArray[2] = (new Point( w, -h));
- startPointPixArray[3] = (new Point(-w, -h));
- scale = that.getScale();
- var switchBoxDimensions = function () {
- setBoxDimensions(boxHeight, boxWidth);
- afterChangeSize({
- this.setPortrait = function () {
- this.setAngle(0);
- if (boxWidth > boxHeight) {
- switchBoxDimensions();
- this.setLandscape = function () {
- this.setAngle(0);
- if (boxWidth < boxHeight) {
- this.setPrintWidthAndHeight = function (width, height) {
- var currentScale = this.getScale();
- printWidth = width;
- printHeight = height;
- this.setScale(currentScale);
- var convertMapToPixel = function (aPoint) {
- var pArray = makeRealWorld2mapPos(map.elementName, aPoint.x, aPoint.y);
- return new Point(pArray[0], pArray[1]);
- var convertPixelToMap = function (aPoint) {
- var pArray = makeClickPos2RealWorldPos(map.elementName, aPoint.x, aPoint.y);
- * Sets the box width and box height (calculated in setScale)
- * @param {Integer} inputWidth
- * @param {Integer} inputHeight
- var setBoxDimensions = function (inputWidth, inputHeight) {
- boxWidth = inputWidth;
- boxHeight = inputHeight;
- initPoints();
- afterChangeSize({
- that.paintBox();
- * Returns an array of two points, the lower left and upper right of the initial box
- this.getStartCoordinates = function () {
- var a = startPointMapArray[0];
- var b = startPointMapArray[2];
- if (!a || !b) {
- return null;
- var returnString = a.x + "," + a.y + "," + b.x + "," + b.y;
- return returnString;
- * Returns the current scale of the print box
- this.getScale = function () {
- var coords = this.getStartCoordinates();
- var coordsArray = coords.split(",");
- var ext = mapObj.getExtentInfos();
- var extMinX = ext.minx;
- var extMaxX = ext.maxx;
- var x = (ext.minx + ext.maxx)/2;
- var y = (ext.miny + ext.maxy)/2;
- var scale1 = (x - coordsArray[0]) * (mb_resolution * 100 *2) / mapObj.width;
- var scale2 = (coordsArray[2] - x) * (mb_resolution * 100 *2) / mapObj.width;
- scale = Math.round(scale1/2 + scale2/2);
- return scale;
- xtentx = coordsArray[2] - coordsArray[0];
- scale = parseInt(Math.ceil(xtentx / (printWidth / 100)), 10);
- return scale;
- * Repaints the Box with the current scale. Can be called from outside,
- * for example after zoom in.
- this.repaint = function () {
- this.rotate(totalAngle);
- this.paintBox();
- * Sets the current scale, and repaints the box
- * @param {Integer} inputScale
- this.setScale = function (inputScale) {
- if (typeof(inputScale) == "number") {
- var arrayBBox = mapObj.extent.split(",");
- x = parseFloat(arrayBBox[0]) + ((parseFloat(arrayBBox[2]) - parseFloat(arrayBBox[0]))/2);
- y = parseFloat(arrayBBox[1]) + ((parseFloat(arrayBBox[3]) - parseFloat(arrayBBox[1]))/2);
- var minx = parseFloat(x) - (mapObj.width / (mb_resolution * 100 *2) * inputScale);
- var miny = parseFloat(y) - (mapObj.height / (mb_resolution * 100 *2) * inputScale);
- var maxx = parseFloat(x) + (mapObj.width / (mb_resolution * 100 *2) * inputScale);
- var maxy = parseFloat(y) + (mapObj.height / (mb_resolution * 100 *2) * inputScale);
- var newMinPos = makeRealWorld2mapPos(mapObj.frameName, minx, miny);
- var newMaxPos = makeRealWorld2mapPos(mapObj.frameName, maxx, maxy);
- var newBoxWidth = newMaxPos[0] - newMinPos[0];
- var newBoxHeight = newBoxWidth * (printHeight / printWidth);
- var mapWidthInM = printWidth / 100;
- var realWidthInM = inputScale * mapWidthInM;
- var mapHeightInM = printHeight / 100;
- var realHeightInM = inputScale * mapHeightInM;
- if (coords !== null) {
- var oldMin = new Point(parseFloat(coordsArray[0]), parseFloat(coordsArray[1]));
- var oldMax = new Point(parseFloat(coordsArray[2]), parseFloat(coordsArray[3]));
- centerMap = (oldMin.times(0.5)).plus(oldMax.times(0.5));
- else {
- var newMin = new Point(centerMap.x - 0.5 * realWidthInM, centerMap.y - 0.5 * realHeightInM);
- var newMax = new Point(centerMap.x + 0.5 * realWidthInM, centerMap.y + 0.5 * realHeightInM);
- startPointMapArray[0] = new Point(newMin.x, newMin.y);
- startPointMapArray[1] = new Point(newMax.x, newMin.y);
- startPointMapArray[2] = new Point(newMax.x, newMax.y);
- startPointMapArray[3] = new Point(newMin.x, newMax.y);
- this.getStartCoordinates();
- var newMinPos = convertMapToPixel(newMin);
- var newMaxPos = convertMapToPixel(newMax);
- boxWidth = newMaxPos.x - newMinPos.x;
- boxHeight = newMinPos.y - newMaxPos.y;
- var w = parseInt(0.5 * boxWidth, 10);
- var h = parseInt(0.5 * boxHeight, 10);
- afterChangeSize({
- that.paintBox();
- return true;
- return false;
- * Sets the angle of the box to a specific angle.
- * @param {Integer} angle
- this.setAngle = function (angle) {
- if (typeof(angle) == "number" && angle >= -360) {
- totalAngle = (360 + angle) % 360;
- this.paintBox();
- return true;
- return false;
- // VIEW
- * Rotates the box by a given degree (0 <= degree < 360),
- * and paints the corner points.
- * @param {Integer} degree
- this.rotate = function (degree) {
- var rotationAngle = (Math.PI * parseFloat(degree))/180;
- var resizeRatio = radius / startRadius;
- var p = (convertMapToPixel(startPointMapArray[i])).minus(getCenter());
- var newx = p.x * Math.cos(rotationAngle) + p.y * Math.sin(rotationAngle);
- var newy = p.x * -Math.sin(rotationAngle) + p.y * Math.cos(rotationAngle);
- pointArray[i] = (new Point(newx, newy)).times(resizeRatio);
- angle: degree,
- coordinates: this.getStartCoordinates()
- this.paintPoints();
- * Paints the four corner points of the print box.
- this.paintPoints = function () {
- switchActiveCanvas();
- var c = center;
- activeCanvas.fillEllipse(
- pointArray[i].x + c.x - 4,
- pointArray[i].y + c.y - 4,
- 8,
- 8
- activeCanvas.paint();
- passiveCanvas.clear();
- var boxTooBig = function () {
- if (boxWidth > MAX_BOX_WIDTH_OR_HEIGHT || boxHeight > MAX_BOX_WIDTH_OR_HEIGHT) {
- return true;
- return false;
- var boxTooSmall = function () {
- if (boxWidth < MIN_BOX_WIDTH_OR_HEIGHT || boxHeight < MIN_BOX_WIDTH_OR_HEIGHT) {
- return true;
- return false;
- * Paints the box itself. Plus the circle.
- this.paintBox = function () {
- var r = Math.round(0.75 * radius);
- var c = center;
- if (!boxTooSmall() && !boxTooBig()) {
- circleCanvas.drawEllipse(c.x-r, c.y-r, 2*r, 2*r);
- else {
- new Mb_warning("The print box is too small or too big. The rotate circle is not shown.");
- circleCanvas.paint();
- boxCanvas.clear();
- if (!boxTooBig()) {
- boxCanvas.fillPolygon([
- pointArray[0].x + c.x,
- pointArray[1].x + c.x,
- pointArray[2].x + c.x,
- pointArray[3].x + c.x
- pointArray[0].y + c.y,
- pointArray[1].y + c.y,
- pointArray[2].y + c.y,
- pointArray[3].y + c.y
- else {
- new Mb_warning("The print box is too big. The box is not filled.");
- // frame
- boxCanvas.setColor(frameColour);
- var indexA = i % 4;
- var a = pointArray[indexA].plus(center);
- var indexB = (i + 1) % 4;
- var b = pointArray[indexB].plus(center);
- boxCanvas.drawLine(a.x, a.y, b.x, b.y);
- boxCanvas.setColor(boxColour);
- boxCanvas.paint();
- * Clears all canvases, to be performed onunload.
- this.destroy = function () {
- activeCanvas.clear();
- $("#" + this.id).remove();
- var switchActiveCanvas = function () {
- if (canvasNr == 1) {
- canvasNr = 2;
- activeCanvas = jg[2];
- passiveCanvas = jg[1];
- else {
- canvasNr = 1;
- activeCanvas = jg[1];
- passiveCanvas = jg[2];
- var $container = $("<div id='" + this.id + "' style='position:relative;top:0px;left:0px;" +
- "'></div>");
- var $superContainer = $("<div id='container_" + this.id + "' style='position:absolute;z-index:1000;'></div>");
- $superContainer.append($container);
- //$("#"+map.elementName).append($superContainer);
- $(map_el).append($superContainer);
- var canvasName = [
- this.id + "_canvas_box",
- this.id + "_canvas_points1",
- this.id + "_canvas_points2",
- this.id + "_canvas_circle"
- var jg = [];
- var canvasNr = 1;
- for (var i = 0; i < canvasName.length; i++) {
- $container.append(
- $("<div id='" + canvasName[i] + "'></div>")
- jg[i] = new jsGraphics(canvasName[i]);
- $circleCanvas = $("#" + canvasName[3]);
- $pointCanvas = $("#" + canvasName[1] + ", #" + canvasName[2]);
- $boxCanvas = $("#" + canvasName[0]);
- $boxCanvas.css({
- "opacity" : opacity,
- "filter" : "alpha(opacity=" + (opacity * 100) + ")"
- var boxCanvas = jg[0];
- var activeCanvas = jg[1];
- activeCanvas.setColor(pointColour);
- var passiveCanvas = jg[2];
- passiveCanvas.setColor(pointColour);
- var circleCanvas = jg[3];
- circleCanvas.setColor(circleColour);
- circleCanvas.setStroke(circleWidth);
- var mouseMoveStart = [];
- var radius = 0;
- var startRadius = 0;
- // "constructor" functions
- initBehaviour();
- this.setScale(scale);
- mb_registerPanSubElement($superContainer.get(0).id);
\ No newline at end of file
More information about the Mapbender_commits
