[Mapbender-commits] r5460 - trunk/mapbender/resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Jan 29 10:30:11 EST 2010
Author: christoph
Date: 2010-01-29 10:30:10 -0500 (Fri, 29 Jan 2010)
New Revision: 5460
   trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql	2010-01-29 13:46:46 UTC (rev 5459)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql	2010-01-29 15:30:10 UTC (rev 5460)
@@ -1174,4 +1174,6 @@
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'jq_ui_effects', 'scale', '0', '1 = effect active', 'php_var');
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'jq_ui_effects', 'shake', '0', '1 = effect active', 'php_var');
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'jq_ui_effects', 'slide', '0', '1 = effect active', 'php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'jq_ui_effects', 'transfer', '1', '1 = effect active', 'php_var');
\ No newline at end of file
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'jq_ui_effects', 'transfer', '1', '1 = effect active', 'php_var');
+INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('toolbox_jquery', 1, 'owner');
More information about the Mapbender_commits mailing list
