[Mapbender-commits] r6188 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org
Wed May 12 05:17:19 EDT 2010
Author: astrid_emde
Date: 2010-05-12 05:17:18 -0400 (Wed, 12 May 2010)
New Revision: 6188
trunk/mapbender/http/plugins/mb_handleStartUpWmsParams.php
Disable was missing in alerts blocks
Modified: trunk/mapbender/http/plugins/mb_handleStartUpWmsParams.php
--- trunk/mapbender/http/plugins/mb_handleStartUpWmsParams.php 2010-05-12 08:57:15 UTC (rev 6187)
+++ trunk/mapbender/http/plugins/mb_handleStartUpWmsParams.php 2010-05-12 09:17:18 UTC (rev 6188)
@@ -241,10 +241,10 @@
if(apiDisableLayers !== "") {
- var disableLayerNotFound = array_diff(apiDisableLayerArray, checkForVisibleLayerArray);
+ var disableLayerNotFound = array_diff(apiDisableLayerArray, checkForDisableLayerArray);
if(disableLayerNotFound.length > 0) {
- var disableLayerString = visibleLayerNotFound.join(",");
- var disableLayerNotFoundMsg = "Disable Layer: Visible layer " + visibleLayerString + " not found.";
+ var disableLayerString = DisableLayerNotFound.join(",");
+ var disableLayerNotFoundMsg = "Disable Layer: Disable layer " + DisableLayerString + " not found.";
new Mapbender.Notice(disableLayerNotFoundMsg);
//alert(disableLayerNotFoundMsg);
@@ -253,8 +253,8 @@
if(apiDisableQueryLayers !== "") {
var disableQueryLayerNotFound = array_diff(apiDisableQueryLayerArray, checkForDisableQueryLayerArray);
if(disableQueryLayerNotFound.length > 0) {
- var disableQueryLayerString = queryLayerNotFound.join(",");
- var disableQueryLayerNotFoundMsg = "Disable Query Layer: Query layer " + queryLayerString + " not found.";
+ var disableQueryLayerString = disableQueryLayerNotFound.join(",");
+ var disableQueryLayerNotFoundMsg = "Disable Query Layer: Query layer " + disableQueryLayerString + " not found.";
new Mapbender.Notice(disableQueryLayerNotFoundMsg);
//alert(disableQueryLayerNotFoundMsg);
More information about the Mapbender_commits
