[Mapbender-commits] r6920 - trunk/mapbender/test/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Sep 20 09:38:55 EDT 2010
Author: christoph
Date: 2010-09-20 13:38:54 +0000 (Mon, 20 Sep 2010)
New Revision: 6920
Removed:
   trunk/mapbender/test/http/classes/GroupTest.php
   trunk/mapbender/test/http/classes/MbNoticeTest.php
   trunk/mapbender/test/http/classes/MbWarningTest.php
   trunk/mapbender/test/http/classes/UserTest.php
obsolete tests
Deleted: trunk/mapbender/test/http/classes/GroupTest.php
--- trunk/mapbender/test/http/classes/GroupTest.php	2010-09-20 13:28:06 UTC (rev 6919)
+++ trunk/mapbender/test/http/classes/GroupTest.php	2010-09-20 13:38:54 UTC (rev 6920)
@@ -1,61 +0,0 @@
-<?php
-require_once 'PHPUnit/Framework.php';
-require_once dirname(__FILE__) . "/../../../http/classes/class_group.php";
-class GroupTest extends PHPUnit_Framework_TestCase
-    var $someGroup_name = "demo";
-    var $someGroup_description = "Demo Group zum Test";
-	public function testCreate()
-      $group = new Group(null);
-      $group->name = $this->someGroup_name;
-      $group->description = $this->someGroup_description;
-      $this->assertNotNull($group);
-      try{
-        $create_result = $group->create();
-      catch(Exception $E)
-        $this->assertEquals($E->getMessage(), 'Could not insert new group');
-      $this->assertNotNull($create_result);
-      $change_result = $group->change(null);
-      $this->assertTrue($change_result);
-      try{
-        $commit_result =  $group->commit();
-        $this->assertEquals($E->getMessage(), 'Database error updating Group');
-      $this->assertTrue($commit_result);
-    * @depends testCreate
-    public function testDelete()
-      $group = Group::byName($this->someGroup_name);
-      $remove_result = $group->remove();
-      $this->assertTrue($remove_result);
-      $group = null;
-      $this->assertNull($group);
Deleted: trunk/mapbender/test/http/classes/MbNoticeTest.php
--- trunk/mapbender/test/http/classes/MbNoticeTest.php	2010-09-20 13:28:06 UTC (rev 6919)
+++ trunk/mapbender/test/http/classes/MbNoticeTest.php	2010-09-20 13:38:54 UTC (rev 6920)
@@ -1,35 +0,0 @@
-<?php
-require_once dirname(__FILE__) . "/../../../http/classes/class_mb_log.php";
-class MbNoticeTest extends PHPUnit_Framework_TestCase
-	var $someNotice;
-	public function setUp () {
-		$this->someNotice = new mb_notice("unit test");
-	public function tearDown () {
-		unset($this->someNotice);
-	 * Notice was created
-	public function testNoticeCreated()
-	//TODO: check if logfile is really created
-		$this->assertNotNull($this->someNotice);
-	 * Notice was Successful
-	public function testNoticeSuccessful()
-		$this->assertEquals("Successful.", $this->someNotice->message);
Deleted: trunk/mapbender/test/http/classes/MbWarningTest.php
--- trunk/mapbender/test/http/classes/MbWarningTest.php	2010-09-20 13:28:06 UTC (rev 6919)
+++ trunk/mapbender/test/http/classes/MbWarningTest.php	2010-09-20 13:38:54 UTC (rev 6920)
@@ -1,35 +0,0 @@
-<?php
-class MbWarningTest extends PHPUnit_Framework_TestCase
-	var $someNotice;
-		$this->someWarning = new mb_warning("unit test");
-		unset($this->someWarning);
-	public function testWarningCreated()
-		$this->assertNotNull($this->someWarning);
-	public function testWarningSuccessful()
-		$this->assertEquals("Successful.", $this->someWarning->message);
Deleted: trunk/mapbender/test/http/classes/UserTest.php
--- trunk/mapbender/test/http/classes/UserTest.php	2010-09-20 13:28:06 UTC (rev 6919)
+++ trunk/mapbender/test/http/classes/UserTest.php	2010-09-20 13:38:54 UTC (rev 6920)
@@ -1,61 +0,0 @@
-<?php
-require_once dirname(__FILE__) . '/../../../http/classes/class_user.php';
-class UserTest extends PHPUnit_Framework_TestCase
-    var $someUser_name = "demo";
-    var $someUser_description = "Demo User zum Testen";
-      $user = new User(null);
-      $user->name = $this->someUser_name;
-      $user->description = $this->someUser_description;
-      $user->public = 1;
-      $this->assertNotNull($user);
-      try{
-        $create_result = $user->create();
-        $this->assertEquals($E->getMessage(), 'Could not set initial values of new User');
-      $change_result = $user->change(null);
-      try{
-        $commit_result =  $user->commit();
-        $this->assertEquals($E->getMessage(), 'Database error updating User');
-      $user = User::byName($this->someUser_name);
-      $remove_result = $user->remove();
-      $user = null;
-      $this->assertNull($user);
More information about the Mapbender_commits mailing list
