[Mapbender-commits] r6921 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org
Mon Sep 20 09:55:50 EDT 2010
Author: christoph
Date: 2010-09-20 13:55:49 +0000 (Mon, 20 Sep 2010)
New Revision: 6921
trunk/mapbender/http/javascripts/initWmcObj.php
code conventions
refactoring according to v0.2.3 http://www.mapbender.org/index.php?title=GET-Parameter&oldid=16902
Modified: trunk/mapbender/http/javascripts/initWmcObj.php
--- trunk/mapbender/http/javascripts/initWmcObj.php 2010-09-20 13:38:54 UTC (rev 6920)
+++ trunk/mapbender/http/javascripts/initWmcObj.php 2010-09-20 13:55:49 UTC (rev 6921)
@@ -11,7 +11,8 @@
//check if session contains a wmc, otherwise create a new wmc from application
if (!Mapbender::session()->get("mb_wmc")) {
- $e = new mb_notice("wmc not set, generating from app: " . Mapbender::session()->get("mb_user_gui"));
+ $e = new mb_notice("wmc not set, generating from app: " .
+ Mapbender::session()->get("mb_user_gui"));
$wmc->createFromApplication(Mapbender::session()->get("mb_user_gui"));
else {
@@ -67,7 +68,10 @@
if (array_key_exists('application', $multipleAssocArray) &&
array_key_exists('id', $multipleAssocArray)) {
$currentWms = new wms();
- $currentWms->createObjFromDB($multipleAssocArray['application'], $multipleAssocArray['id']);
+ $currentWms->createObjFromDB(
+ $multipleAssocArray['application'],
+ $multipleAssocArray['id']
//get WMS by URL
elseif (array_key_exists('url', $multipleAssocArray)) {
@@ -79,11 +83,13 @@
array_push($wmsArray, $currentWms);
- if($multipleAssocArray['visible'] && $multipleAssocArray['visible'] != "") {
- $options['visible'] = $multipleAssocArray['visible'] === "true" ? true : false;
+ if($multipleAssocArray['visible']) {
+ $options['visible'] = $multipleAssocArray['visible'] === 1 ?
+ true : false;
- if($multipleAssocArray['zoom'] && $multipleAssocArray['zoom'] != "") {
- $options['zoom'] = $multipleAssocArray['zoom'] === "true" ? true : false;
+ if($multipleAssocArray['zoom']) {
+ $options['zoom'] = $multipleAssocArray['zoom'] === 1 ?
+ true : false;
$wmc->mergeWmsArray($wmsArray, $options);
@@ -115,14 +121,19 @@
if (array_key_exists('application', $singleAssocArray) &&
array_key_exists('id', $singleAssocArray)) {
- $currentWms->createObjFromDB($singleAssocArray['application'], $singleAssocArray['id']);
+ $singleAssocArray['application'],
+ $singleAssocArray['id']
- if($singleAssocArray['visible'] && $singleAssocArray['visible'] != "") {
- $options['visible'] = $singleAssocArray['visible'] === "true" ? true : false;
+ if($singleAssocArray['visible']) {
+ $options['visible'] = $singleAssocArray['visible'] === 1 ?
+ true : false;
if($singleAssocArray['zoom'] && $singleAssocArray['zoom'] != "") {
- $options['zoom'] = $singleAssocArray['zoom'] === "true" ? true : false;
+ $options['zoom'] = $singleAssocArray['zoom'] === 1 ?
+ true : false;
$wmsArray = array();
@@ -133,11 +144,13 @@
$currentWms->createObjFromXML($singleAssocArray['url']);
+ true : false;
- if($singleAssocArray['zoom'] && $singleAssocArray['zoom'] != "") {
+ if($singleAssocArray['zoom']) {
+ true : false;
@@ -170,7 +183,8 @@
$wmc->generalExtensionArray['WFSCONFIDSTRING'] = implode(",", array_merge(
$wmc->generalExtensionArray['WFSCONFIDSTRING'] ?
- explode(",", $wmc->generalExtensionArray['WFSCONFIDSTRING']) : array(),
+ explode(",", $wmc->generalExtensionArray['WFSCONFIDSTRING']) :
+ array(),
$wfsConfIds
@@ -186,7 +200,8 @@
//workaround for zoom to WMS
$extent = $wmc->mainMap->getExtent();
-Mapbender::session()->set("mb_myBBOX", $extent->min->x . "," . $extent->min->y . "," . $extent->max->x . "," . $extent->max->y);
+Mapbender::session()->set("mb_myBBOX", $extent->min->x . "," .
+ $extent->min->y . "," . $extent->max->x . "," . $extent->max->y);
$outputString = "";
for ($i = 0; $i < count($output); $i++) {
More information about the Mapbender_commits
