[Mapbender-commits] r7862 - in trunk/mapbender/http: css geoportal
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Jun 14 07:31:38 EDT 2011
Author: armin11
Date: 2011-06-14 04:31:38 -0700 (Tue, 14 Jun 2011)
New Revision: 7862
Added:
   trunk/mapbender/http/css/allow_publishing_metadata.css
   trunk/mapbender/http/geoportal/mod_allow_publishing_metadata.php
new possibility to allow metadata publishing to other user
Added: trunk/mapbender/http/css/allow_publishing_metadata.css
--- trunk/mapbender/http/css/allow_publishing_metadata.css	                        (rev 0)
+++ trunk/mapbender/http/css/allow_publishing_metadata.css	2011-06-14 11:31:38 UTC (rev 7862)
@@ -0,0 +1,108 @@
+body{
+	background-color : #ffffff;
+	font-family: Verdana, Geneva, Arial, Helvetica, sans-serif;
+select {
+	font-size: 11;
+	width: 200px;
+	font-weight : bold;
+.select_short{
+	width: auto;
+table{
+	font-family:Verdana, Geneva, Arial, Helvetica, sans-serif;
+	font-size:11;
+.wms_button{
+	color: black;
+	border: solid thin;
+	height:22px;
+	width:60px;
+checkbox{
+	background-color : #0066ff;
+.titel{
+	font-family: Arial, Helvetica, sans-serif;
+	font-size: 16;
+.box{
+	font-size : 14;
+.text1{
+	position: absolute;
+	top: 40px;
+	left: 256px;
+.select1{
+	top: 80px;
+	left: 256px;
+	background: #ffffff;
+.filter1{
+	top: 60px;
+	left: 256px;
+	width: 200px;
+.text2{
+	top: 50px;
+	left: 0px;
+.select2{
+	top: 90px;
+	left: 0px;
+.filter2{
+	top: 70px;
+	left: 0px;
+	width: 200px;
+.text3{
+	top: 50px;
+	left: 276px;
+.select3{
+	top: 90px;
+	left: 276px;
+.filter3{
+	top: 70px;
+	left: 276px;
+	width: 200px;
+.button1{
+	left: 205px;
+	top: 180px;
+.button2{
+	left: 205px;
+	top: 240px;
+.text4{
+	top: auto;
+	left: auto;
+	color : Red;
+	font-size : 13;
Added: trunk/mapbender/http/geoportal/mod_allow_publishing_metadata.php
--- trunk/mapbender/http/geoportal/mod_allow_publishing_metadata.php	                        (rev 0)
+++ trunk/mapbender/http/geoportal/mod_allow_publishing_metadata.php	2011-06-14 11:31:38 UTC (rev 7862)
@@ -0,0 +1,322 @@
+<?php
+# $Id: mod_group_user.php 7706 2011-03-15 13:44:54Z armin11 $
+# http://www.mapbender.org/index.php/Administration
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+$e_id = "allowPublishMetadata";
+require_once(dirname(__FILE__)."/../php/mb_validatePermission.php");
+require_once(dirname(__FILE__)."/../../core/globalSettings.php");
+//include variable for registrating departments - this are the php element vars:
+//$authorizeRoleId
+//$adminGroupId
+include '../include/dyn_php.php';
+//group id of the users who have the right to registrate services
+//$adminGroupId = 25;
+//id of the role which will be given to the selected user - here metadata editor
+//$authorizeRoleId = 3;
+//here the primary group of the user is relevant therefor it will be a good idea to show the group names which are primary roles to some registrating user
+//get the selected group as the primary group of the current user!
+//get user id:
+$userId = (integer)$_SESSION["mb_user_id"];
+if (!is_int($userId)) {
+	echo _mb("You have no rights to use this module!");
+	die();
+$sqlGetPrimaryGroup = "SELECT fkey_mb_group_id FROM mb_user_mb_group WHERE fkey_mb_user_id = $1 and mb_user_mb_group_type = 2";
+$v = array($userId);
+$t = array('i');
+$resPrimaryGroup = db_prep_query($sqlGetPrimaryGroup,$v,$t);
+$cntPG = 0;
+while($row = db_fetch_array($resPrimaryGroup)){
+	$selected_group = $row["fkey_mb_group_id"];
+	$cntPG++;
+if ($cntPG > 1) {
+	echo _mb("There are too many primary groups defined for the user with ID: ").$userId;
+	die();
+if ($cntPG == 0) {
+//give an error if now primary_group is defined for the current user
+	echo _mb("You have not yet an primary group. Please contact the central system admin to define a primary group for user with ID: ").$userId;
+	die();
+//get only those users which have the right to registrate and have a primary role defined - they are the metadata publishers in sense of the registry
+ * @security_patch irv done
+//security_patch_log(__FILE__,__LINE__);
+//import_request_variables("PG");
+$postvars = explode(",", "filter2,insert,remove,filter3,remove_user,selected_user");
+foreach ($postvars as $value) {
+   $$value = $_POST[$value];
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<?php
+echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
+<title>Allow departments to publish own metadata</title>
+<?php include '../include/dyn_css.php'; ?>
+<script language="JavaScript">
+function validate(wert){
+	if(wert == "remove"){
+		if(document.forms[0]["remove_user[]"].selectedIndex == -1){
+			document.getElementsByName("remove_user[]")[0].style.backgroundColor = '#ff0000';
+			return;
+		document.form1.remove.value = 'true';
+		document.form1.submit();
+	if(wert == "insert"){
+		if(document.forms[0]["selected_user[]"].selectedIndex == -1){
+			document.getElementsByName("selected_user[]")[0].style.backgroundColor = '#ff0000';
+			return;
+		document.form1.insert.value = 'true';
+ * filter the Userlist by str
+function filterUser(list, all, str){
+	str=str.toLowerCase();
+	var selection=[];
+	var i,j,selected;
+	for(i=0;i<list.options.length;i++){
+		if(list.options[i].selected)
+			selection[selection.length]=list.options[i].value;
+	list.options.length = 0;
+	for(i=0; i<all.length; i++){
+		if(all[i]['name'].toLowerCase().indexOf(str)==-1)
+			continue;
+		selected=false;
+		for(j=0;j<selection.length;j++){
+			if(selection[j]==all[i]['id']){
+				selected=true;
+				break;
+		var newOption = new Option(selected?all[i]['name']+" ("+all[i]['email']+")":all[i]['name'],all[i]['id'],false,selected);
+		newOption.setAttribute("title", all[i]['email']);
+		list.options[list.options.length] = newOption;
+ * add Mail adress on selection
+function updateMail(list, all){
+	var j=0;
+	for(var i=0; i<list.options.length;i++){
+		if(list.options[i].selected){
+			for(j=j;j<all.length;j++){
+				if(all[j]['id']==list.options[i].value){
+					list.options[i].text=all[j]['name']+" ("+all[j]['email']+")";
+					list.options[i].selected = true;
+					break;
+		else{
+					list.options[i].text=all[j]['name'];
+					list.options[i].selected = false;
+					break;
+</script>
+</head>
+<body>
+<?php
+$fieldHeight = 20;
+$cnt_group = 0;
+$cnt_user = 0;
+$cnt_group = 0;
+$cnt_group_user = 0;
+$cnt_group_group = 0;
+$exists = false;
+/*handle remove, update and insert**************************************************************************************/
+if($insert){
+	if(count($selected_user)>0){
+		for($i=0; $i<count($selected_user); $i++){
+			$exists = false;
+			$sql = "SELECT * from mb_user_mb_group where fkey_mb_group_id = $1 AND fkey_mb_user_id = $2 AND mb_user_mb_group_type = $3";
+			$v = array($selected_group,$selected_user[$i],$authorizeRoleId);
+			$t = array('i','i','i');
+			$res_insert = db_prep_query($sql,$v,$t);
+			while(db_fetch_row($res_insert)){$exists = true;}
+			if($exists == false){
+				//allow the user to be a metadata editor
+				$sql = "INSERT INTO mb_user_mb_group(fkey_mb_group_id, fkey_mb_user_id, mb_user_mb_group_type) ";
+				$sql .= "VALUES($1, $2, $3)";
+				$v = array($selected_group,$selected_user[$i], $authorizeRoleId);
+				$res = db_prep_query($sql,$v,$t);
+if($remove){
+	if(count($remove_user)>0){
+		for($i=0; $i<count($remove_user); $i++){
+			$sql_remove = "DELETE FROM mb_user_mb_group WHERE ";
+			$sql_remove .= "fkey_mb_user_id = $1 and fkey_mb_group_id = $2 AND mb_user_mb_group_type = $3";
+			$v = array($remove_user[$i],$selected_group, $authorizeRoleId);
+			db_prep_query($sql_remove,$v,$t);
+			//delete all references from owned services of this user to metadata point of contact
+			$sql_wms_update = "UPDATE wms SET fkey_mb_group_id = 0 WHERE wms_owner = $1 AND fkey_mb_group_id = $2";
+			$v = array($remove_user[$i],$selected_group);
+			$t = array('i','i');
+			db_prep_query($sql_wms_update,$v,$t);
+			$sql_wfs_update = "UPDATE wfs SET fkey_mb_group_id = 0 WHERE wfs_owner = $1 AND fkey_mb_group_id = $2";
+			db_prep_query($sql_wfs_update,$v,$t);
+/*get all user which have the right to load services and have assigned a primary group! **********************************************************************************************/
+$sql_user = "SELECT b.mb_user_id, b.mb_user_name, b.mb_group_name, b.mb_user_email FROM ( ";
+$sql_user .= "SELECT mb_group_name, mb_user_name, mb_user_email, mb_user_id , fkey_mb_group_id FROM ";
+$sql_user .= "(SELECT mb_user.mb_user_id, mb_user.mb_user_name, mb_user.mb_user_email, "; $sql_user .= "mb_user_mb_group.fkey_mb_group_id FROM ";
+$sql_user .= "mb_user_mb_group INNER JOIN mb_user ON ";
+$sql_user .= "mb_user_mb_group.fkey_mb_user_id = mb_user.mb_user_id WHERE ";
+$sql_user .= "mb_user_mb_group.mb_user_mb_group_type = 2 ) as a INNER JOIN ";
+$sql_user .= "mb_group ON mb_group.mb_group_id = a.fkey_mb_group_id  ";
+$sql_user .= ") AS b ";
+$sql_user .= "INNER JOIN mb_user_mb_group ON 	mb_user_mb_group.fkey_mb_user_id = b.mb_user_id WHERE mb_user_mb_group.fkey_mb_group_id = $1 ";
+$v = array($adminGroupId);
+$t = array('i');
+$res_user = db_prep_query($sql_user,$v,$t);
+while($row = db_fetch_array($res_user)){
+	$user_id[$cnt_user] = $row["mb_user_id"];
+	$user_name[$cnt_user] = $row["mb_group_name"]." - ".$row["mb_user_name"];
+	$user_email[$cnt_user] = $row["mb_user_email"];
+	$cnt_user++;
+/*get all user which are metadata editors for my primary group ******************************************************************************/
+$sql_mb_user_mb_group = "SELECT mb_group_name, mb_user_name, mb_user_email, mb_user_id  FROM ";
+$sql_mb_user_mb_group .= "(SELECT  mb_user_name, mb_user_email, mb_user_id, ";
+$sql_mb_user_mb_group .= "mb_user_mb_group.fkey_mb_group_id FROM (SELECT ";
+$sql_mb_user_mb_group .= "mb_user.mb_user_id, mb_user.mb_user_name, mb_user.mb_user_email, ";
+$sql_mb_user_mb_group .= "mb_user_mb_group.fkey_mb_group_id,mb_user_mb_group.mb_user_mb_group_type ";
+$sql_mb_user_mb_group .= "FROM mb_user_mb_group INNER JOIN mb_user ON ";
+$sql_mb_user_mb_group .= "mb_user_mb_group.fkey_mb_user_id = mb_user.mb_user_id ";
+$sql_mb_user_mb_group .= "WHERE (mb_user_mb_group.mb_user_mb_group_type = $2 ) ";
+$sql_mb_user_mb_group .= " AND mb_user_mb_group.fkey_mb_group_id = $1 ";
+$sql_mb_user_mb_group .= ") as a INNER JOIN mb_user_mb_group ON ";
+$sql_mb_user_mb_group .= "mb_user_mb_group.fkey_mb_user_id = a.mb_user_id WHERE ";
+$sql_mb_user_mb_group .= "mb_user_mb_group.mb_user_mb_group_type = 2 ";
+$sql_mb_user_mb_group .= ") as b , mb_group WHERE mb_group.mb_group_id = b.fkey_mb_group_id";
+$v = array($selected_group, $authorizeRoleId);
+$t = array('i','i');
+$res_mb_user_mb_group = db_prep_query($sql_mb_user_mb_group,$v,$t);
+while($row = db_fetch_array($res_mb_user_mb_group)){
+	$user_id_group[$cnt_group_user] = $row["mb_user_id"];
+	$user_name_group[$cnt_group_user] = $row["mb_group_name"]." - ".$row["mb_user_name"];
+	$user_email_group[$cnt_group_user] =  $row["mb_user_email"];
+	$cnt_group_user++;
+/*INSERT HTML*/
+echo "<form name='form1' action='" . $self . "' method='post'>";
+/*filterbox*************************************************************************/
+echo "<input type='text' value='' class='filter2' id='filter2' name='filter2' onkeyup='filterUser(document.getElementById(\"selecteduser\"),user,this.value);'/>";
+/*insert all profiles in selectbox*****************************************************************/
+echo "<div class='text2'>"._mb("Registrating institutions").":</div>";
+echo "<select style='background:#ffffff' onchange='updateMail(this, user)' class='select2' multiple='multiple' id='selecteduser' name='selected_user[]' size='$fieldHeight' >";
+for($i=0; $i<$cnt_user; $i++){
+	echo "<option value='" . $user_id[$i]  . "' title='".$user_email[$i]."'>" . $user_name[$i]  . "</option>";
+echo "</select>";
+/*Button****************************************************************************************************/
+echo "<div class='button1'><input type='button'  value='==>' onClick='validate(\"insert\")'></div>";
+echo "<input type='hidden' name='insert'>";
+echo "<div class='button2'><input type='button' value='<==' onClick='validate(\"remove\")'></div>";
+echo "<input type='hidden' name='remove'>";
+/*filterbox****************************************************************************************/
+echo "<input type='text' value='' class='filter3' id='filter3' name='filter3' onkeyup='filterUser(document.getElementById(\"removeuser\"),groupuser,this.value);'/>";
+/*insert container_profile_dependence and container_group_dependence in selectbox******************/
+echo "<div class='text3'>"._mb("My (metadata-)provider").":</div>";
+echo "<select style='background:#ffffff' onchange='updateMail(this, user)' class='select3' multiple='multiple' name='remove_user[]' id='removeuser' size='$fieldHeight' >";
+for($i=0; $i<$cnt_group_user; $i++){
+	echo "<option value='" . $user_id_group[$i]  . "' title='".$user_email_group[$i]."'>" . $user_name_group[$i]  . "</option>";
+echo "</select>";
+echo "</form>";
+<script type="text/javascript">
+//document.forms[0].selected_group.focus();
+var user=[];
+<?php
+	echo "user[".$i."]=[];\n";
+	echo "user[".$i."]['id']='" . $user_id[$i]  . "';\n";
+	echo "user[".$i."]['name']='" . $user_name[$i]  . "';\n";
+	echo "user[".$i."]['email']='" . $user_email[$i]  . "';\n";
+var groupuser=[];
+<?php
+	echo "groupuser[".$i."]=[];\n";
+	echo "groupuser[".$i."]['id']='" . $user_id_group[$i]  . "';\n";
+	echo "groupuser[".$i."]['name']='" . $user_name_group[$i]  . "';\n";
+	echo "groupuser[".$i."]['email']='" . $user_email_group[$i]  . "';\n";
+</script>
+</body>
+</html>
More information about the Mapbender_commits mailing list
