[Mapbender-commits] r7886 - trunk/mapbender/resources/db
svn_mapbender at osgeo.org
Fri Jun 24 04:43:03 EDT 2011
Author: astrid_emde
Date: 2011-06-24 01:43:03 -0700 (Fri, 24 Jun 2011)
New Revision: 7886
Added:
trunk/mapbender/resources/db/Search_extended_DE.sql
took the Application Geoportal-RLP_erwSuche2 and made some modifications - other buttons, white, other css, changed the name. It is planned to take this application to Mapbender 2.7.x. Open: Search script erweiterte-suche.html has to be integrated
Added: trunk/mapbender/resources/db/Search_extended_DE.sql
--- trunk/mapbender/resources/db/Search_extended_DE.sql (rev 0)
+++ trunk/mapbender/resources/db/Search_extended_DE.sql 2011-06-24 08:43:03 UTC (rev 7886)
@@ -0,0 +1,329 @@
+-- SQL laden
+-- WMS in Gui laden z. B. Germany
+-- grau aus gui: ../extensions/jquery-ui-1.7.2.custom/css/smoothness/jquery-ui-1.7.2.custom.css
+-- blau aus gui digi: ../extensions/jquery-ui-1.7.2.custom/css/ui-customized_4_digitize/jquery-ui-1.7.3.custom.css
+-- buttons ersetzen img breite
+-- mapframe1 breiter und etwas schmaler
+-- double click zoom, mousewheel zoom
+-- Probleme GeoRSS Newsfeeds lässt sich nicht wählen (disabled im Geoportal RLP)
+-- bei Suche: Aufruf /portal/nc/servicebereich/erweiterte-suche.html
+---- * hier muss das Suchskrip von Jens angesteuert werden
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('Search_extended_DE',
+'Search_extended_DE','Erweiterte Suche',1);
+insert into gui_mb_user (fkey_gui_id,fkey_mb_user_id,mb_user_type) values ('Search_extended_DE',1,'owner');
+INSERT INTO gui_gui_category (fkey_gui_id, fkey_gui_category_id) VALUES('Search_extended_DE',1);
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','mapframe1',1,1,'Frame for a map','','div','','',10,180,276,182,20,'overflow:hidden;background-color:#ffffff','','div','../plugins/mb_map.js','../../lib/history.js,map_obj.js,map.js,wms.js,wfs_obj.js,initWmcObj.php','','','http://www.mapbender.org/index.php/Mapframe');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Search_extended_DE','mapframe1','skipWmsIfSrsNotSupported','0','if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility','var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Search_extended_DE','mapframe1','slippy','1','1 = Activates an animated, pseudo slippy map','var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','jq_upload',1,1,'','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../plugins/jq_upload.js','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','jq_ui_widget',1,1,'jQuery UI widget','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/jquery.ui.widget.js','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','zoomOut1',1,1,'zoomOut button','','img','../img/button_blue_red/zoomOut2_off.png','',300,200,28,28,20,'','','','mod_zoomOut1.js','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','zoomIn1',1,1,'zoomIn button','','img','../img/button_blue_red/zoomIn2_off.png','',300,171,28,28,20,'','','','mod_zoomIn1.js','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','zoomFull',1,1,'zoom to full extent button','','img','../img/button_blue_red/zoomFull_off.png','',300,258,28,28,20,'','','img','mod_zoomFull.js','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','selArea1',1,1,'zoombox','','img','../img/button_blue_red/selArea_off.png','',300,229,28,28,20,'','','','mod_selArea.js','mod_box1.js','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','body',1,1,'body (obligatory)','','body','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../geoportal/mod_revertGuiSessionSettings.php','','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Search_extended_DE','body','css_class_bg','body{ background-color: #ffffff; }','to define the color of the body','text/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Search_extended_DE','body','css_file_body','../css/mapbender.css','file/css','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Search_extended_DE','body','favicon','../img/favicon.ico','favicon','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Search_extended_DE','body','includeWhileLoading','','show splash screen while the application is loading','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Search_extended_DE','body','jq_ui_theme','../extensions/jquery-ui-1.7.2.custom/css/ui-customized_4_digitize/jquery-ui-1.7.3.custom.css','UI Theme from Themeroller','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Search_extended_DE','body','popupcss','../css/popup.css','file css','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Search_extended_DE','body','tablesortercss','../css/tablesorter.css','file css','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Search_extended_DE','body','use_load_message','false','show splash screen while the application is loading','php_var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','pan1',1,1,'pan','','img','../img/button_blue_red/pan_off.png','',300,287,28,28,20,'','','','mod_pan.js','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','mb_helpDialog',1,1,'Mapbender wrapper for helptexts in jq dialogs','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','','mb_helpDialog.js','','jq_ui, jq_metadata','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','forward',1,1,'History.forward()','','img','../img/button_blue_red/forward_off_disabled.png','',300,316,28,28,20,'','','','mod_forward.php','','mapframe1,overview0','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','i18n',1,1,'Internationalization module, collects data from all elements and sends them to the server in a single POST request. The strings are translated via gettext only.','Internationalization','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_i18n.js','','','','http://www.mapbender.org/Gettext');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','jq_datatables',1,1,'Includes the jQuery plugin datatables, use like this
+$(selector).datatables(options)','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../plugins/jq_datatables.js','../extensions/dataTables-1.5/media/js/jquery.dataTables.min.js','','','http://www.datatables.net/');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Search_extended_DE','jq_datatables','defaultCss','../extensions/dataTables-1.5/media/css/demo_table_jui.css','','file/css');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','jq_metadata',1,1,'jQuery Metadata plugin - selects elements by tag names out of html?','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','','../extensions/jquery.metadata.2.1/jquery.metadata.min.js','','','http://plugins.jquery.com/project/metadata');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','jq_ui',1,1,'jQuery UI core','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/jquery.ui.core.js','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Search_extended_DE','jq_ui','css','../extensions/jquery-ui-1.8.1.custom/css/custom-theme/jquery-ui-1.8.4.custom.css','','file/css');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','dependentDiv',2,0,'displays infos in a sticky div-tag','','div','','',81,-19,1,1,NULL ,'visibility:visible;position:absolute;font-size: 11px;font-family: "Arial", sans-serif;','','div','mod_dependentDiv.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','back',2,1,'History.back()','','img','../img/button_blue_red/back_off_disabled.png','',300,345,28,28,20,'','','','mod_back.php','','mapframe1,overview0','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','doubleclickZoom',2,1,'adds doubleclick zoom to map module (target).
+Deactivates the browser contextmenu!!!','Doubleclick zoom','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','mod_doubleclickZoom.js','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','jq_ui_mouse',2,1,'jQuery UI mouse','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/jquery.ui.mouse.js','','jq_ui_widget','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','jq_ui_position',2,1,'jQuery UI position','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/jquery.ui.position.js','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','loadData',2,0,'IFRAME, um Daten zu laden','','iframe','../html/mod_blank.html','frameborder = "0" ',0,0,1,1,NULL ,'visibility:visible','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','mapbender',2,1,'Mapbender-Logo','','div','','onclick="javascript:window.open(''http://www.mapbender.org'','''','''');"',81,-19,1,1,30,'font-size : 10px;font-weight : bold;font-family: Arial, Helvetica, sans-serif;color:white;cursor:help;','<span>Ma</span><span style="color: blue;">P</span><span style="color: red;">b</span><span>ender</span><script type="text/javascript"> mb_registerSubFunctions("mod_mapbender()"); function mod_mapbender(){ document.getElementById("mapbender").style.left = parseInt(document.getElementById("mapframe1").style.left) + parseInt(document.getElementById("mapframe1").style.width) - 90; document.getElementById("mapbender").style.top = parseInt(document.getElementById("mapframe1").s
tyle.top) + parseInt(document.getElementById("mapframe1").style.height) -1; } </script>','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','mapcheck',2,1,'alert if a map-image fails to load','','div','','',0,0,NULL ,NULL,NULL ,'','','div','','mod_mapcheck.php','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','mb_div_collection1',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_div_collection.js','','mapframe1, zoomIn1,zoomFull,zoomOut1,selArea1,pan1,forward,back,navFrame','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','navFrame',2,1,'navigation mapborder','','div','','',0,0,NULL ,NULL,20,'font-size:1px','','div','mod_navFrame.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','renderGML',2,0,'renders a gml contained in $_SESSION[''GML'']','','div','','',NULL ,NULL,NULL ,NULL,1,'','','div','../javascripts/mod_renderGML.php','mod_highlight.php','overview,mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','sandclock',2,1,'displays a sand clock while waiting for requests','','div','','',80,0,0,0,0,'','','div','mod_sandclock.js','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','spatialBackground',2,0,'background for spatial filter mapbender mapframe - cause this cannot be positioned relativly','','div','','',0,160,704,200,1,'color: #008000;background-color:#e3e3e3;position:absolute','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','spatialFilter',2,1,'Div which shows the spatial filter options for the metadata search','','div','','class=''spatialFilter''',NULL ,NULL,NULL ,NULL,20,'',' <fieldset>
+ <img class="help-dialog" id="helpSpatialFilter" title="Help" help="{text:''Help SpatialFilter''}" src="../img/questionmark.png" align="right"></img>
+ <p>
+ <input type=''checkbox'' name=''searchBbox'' id=''searchBbox''>
+ <label id="labelSpatialFilter" name="labelSpatialFilter">Activate Spatial Filter</label>
+ <legend id="labelSpatialFilterType" name="labelSpatialFilterType">how?</legend>
+ <input type=''radio'' name=''searchTypeBbox'' value=''intersects'' id=''searchTypeBbox''>
+ <label id="labelIntersects" name="labelIntersects" for="bbox">intersects</label>
+ <input type=''radio'' name=''searchTypeBbox'' value=''outside'' id=''searchTypeBbox''>
+ <label id="labelOutside" name="labelOutside">outside</label>
+ <input type=''radio'' name=''searchTypeBbox'' value=''inside'' id=''searchTypeBbox''>
+ <label id="labelInside" name="labelInside">fully inside</label>
+ </p>
+ </fieldset>','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','wholeBackground',2,1,'background for spatial filter mapbender mapframe - cause this cannot be positioned relativly','','div','','',0,0,750,600,NULL ,'color: #008000;background-color:#ffffff;position:absolute','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','provider',3,1,'Div which shows a list of providers for the metadata search','Anbieter','div','','',NULL ,NULL,NULL ,NULL,20,'','<fieldset>
+<legend id="legendDepartment" name="legendDepartment">Provider</legend>
+<img class="help-dialog" id="helpProvider" title="Help" help="{text:''Help Provider''}" src="../img/questionmark.png" align="right"></img>
+ <p>
+ <select class=''selectCat'' size=''5'' name=''registratingDepartments'' id=''registratingDepartments'' multiple ></select>
+ <br><a id="deleteSelection1" name="deleteSelection" href="#" c onclick=''removeListSelections("registratingDepartments");''>Drop current selection</a>
+ </p>
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','button',3,1,'Div for the button to submit extended search module','','div','','class=''button''',500,25,60,40,20,'','<button id="search" name="search" type="button" value="Start Search" onclick="validate();">Start Search</button>
+','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','classifications',3,1,'Put category divs into one div collection','Themen','div','','',NULL ,NULL,NULL ,NULL,20,'','<fieldset>
+ <legend id="classificationsLegend" name="classificationsLegend">Classifications</legend>
+ <div class="inspire">
+ <fieldset>
+ <legend id="legendInspireThemes" name="legendInspireThemes">Inspire Themes</legend>
+ <img class="help-dialog" id="helpInspireThemes" title="Help" help="{text:''Help Inspire Categories''}" src="../img/questionmark.png" align="right"></img>
+<img id="imageInspireThemes" title="Inspire" src="../img/inspire_tr_36.png" align="right"></img>
+ <p>
+ <select class=''selectCat'' size=''5'' name=''inspireThemes'' id=''inspireThemes'' multiple ></select>
+ <br><a id="deleteSelection2" name="deleteSelection" href="#" onclick=''removeListSelections("inspireThemes");''>Drop current selection</a>
+ </p>
+ </fieldset>
+ </div>
+ <div class="iso">
+ <fieldset>
+ <legend id="legendIsoCategories" name="legendIsoCategories">ISO19115 Themes</legend>
+ <img class="help-dialog" id="helpIsoCategories" title="Help" help="{text:''Help ISO Categories''}" src="../img/questionmark.png" align="right"></img>
+ <p>
+ <select class=''selectCat'' size=''5'' name=''isoCategories'' id=''isoCategories'' width="200px" multiple></select>
+ <br><a id="deleteSelection3" name="deleteSelection" href="#" onclick=''removeListSelections("isoCategories");''>Drop current selection</a>
+ </p>
+ </fieldset>
+ </div>
+ <div class="custom">
+ <fieldset>
+ <legend id="legendCustomCategories" name="legendCustomCategories">Other Themes</legend>
+ <img class="help-dialog" id="helpCustomCategories" title="Help" help="{text:''Help Custom Categories''}" src="../img/questionmark.png" align="right"></img>
+ <p>
+ <select class=''selectCat'' size=''5'' name=''customCategories'' id=''customCategories'' multiple></select>
+ <br><a id="deleteSelection4" name="deleteSelection" href="#" onclick=''removeListSelections("customCategories");''>Drop current selection</a>
+ </p>
+ </fieldset>
+ </div>
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','form2',3,1,'Form for the extended mapbender metadata search - this form submits the values as hidden to the search script','','form','','method=''get'' name=''form2'' action=''/portal/nc/servicebereich/erweiterte-suche.html'' target=''_top''',0,250,NULL ,NULL,NULL ,'',' <input type="hidden" value='''' name=''searchText''>
+ <input type="hidden" value='''' name=''registratingDepartments''>
+ <input type="hidden" value='''' name=''isoCategories''>
+ <input type="hidden" value='''' name=''inspireThemes''>
+ <input type="hidden" value='''' name=''customCategories''>
+ <input type="hidden" value='''' name=''regTimeBegin''>
+ <input type="hidden" value='''' name=''regTimeEnd''>
+ <input type="hidden" value='''' name=''timeBegin''>
+ <input type="hidden" value='''' name=''timeEnd''>
+ <input type="hidden" value='''' name=''searchBbox''>
+ <input type="hidden" value='''' name=''searchTypeBbox''>
+ <input type="hidden" value='''' name=''searchResources''>
+ <input type="hidden" value='''' name=''orderBy''> ','form','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','actuality',3,1,'Div which shows the date field for temporal filters for metadata search','Wann?','div','','class=''actuality''',NULL ,NULL,NULL ,NULL,20,'','<fieldset>
+<legend id="legendActuality" name="legendActuality">Actuality</legend>
+ <fieldset>
+ <legend id="legendDateOfPublication" name="legendDateOfPublication">Date of Publication</legend>
+ <img class="help-dialog" id="helpDateOfPublication" title="Help" help="{text:''Help DateOfPublication''}" src="../img/questionmark.png" align="right"></img>
+ <table>
+ <p>
+ <tr>
+ <td><label id="labelDateOfPublicationStart" name="labelDateOfPublicationStart" for="regTimeBegin">Date from</label></td>
+ <td><input class=''hasdatepicker'' type=''text'' size=15 name=''regTimeBegin'' id=''regTimeBegin'' > </td>
+ </tr>
+ <tr>
+ <td><label id="labelDateOfPublicationEnd" name="labelDateOfPublicationEnd" for="regTimeEnd">Date to</label></td>
+ <td><input class=''hasdatepicker'' type=''text'' size=15 name=''regTimeEnd'' id=''regTimeEnd'' > </td>
+ </tr>
+ </p>
+ </table>
+ </fieldset>
+ <fieldset>
+ <legend id="legendDateOfLastRevision" name="legendDateOfLastRevision">Data actuality</legend>
+ <img class="help-dialog" id="helpDateOfLastRevision" title="Help" help="{text:''Help DateOfLastRevision''}" src="../img/questionmark.png" align="right"></img>
+ <table>
+ <p>
+ <tr>
+ <td><label id="labelDateOfLastRevisionStart" name="labelDateOfLastRevisionStart" for="timeBegin" >Date from</label></td>
+ <td><input disabled="disabled" type=''text'' size=15 name=''timeBegin'' id=''timeBegin'' > </td>
+ </tr>
+ <tr>
+ <td><label id="labelDateOfLastRevisionEnd" name="labelDateOfLastRevisionEnd" for="timeEnd">Date to</label></td>
+<td><input disabled="disabled" type=''text'' size=15 name=''timeEnd'' id=''timeEnd'' > </td>
+ </tr>
+ </p>
+ </table>
+ </fieldset>
+</fieldset>
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','classSearchResources',3,1,'Div which shows the different bsearchable resources for metadata search','Was?','div','','',NULL ,NULL,NULL ,NULL,20,'','<fieldset><legend id="legendSearchResources" name="legendSearchResources">Types of Resources</legend>
+ <img class="help-dialog" id="helpSearchResources" title="Help" help="{text:''Help SearchResources''}" src="../img/questionmark.png" align="right"></img>
+ <div id=''searchResources'' name=''searchResources''>
+ <input name=''checkResourcesWms'' id=''checkResourcesWms'' type=''checkbox'' value=''wms''>
+ <label id="labelCheckResourcesWms" name="labelCheckResourcesWms">Viewing Services</label>
+ <input name=''checkResourcesWfs'' id=''checkResourcesWfs'' type=''checkbox'' value=''wfs''>
+ <label id="labelCheckResourcesWfs" name="labelCheckResourcesWfs">Search/Download/Digitize Modules</label>
+ <input name=''checkResourcesWmc'' id=''checkResourcesWmc'' type=''checkbox'' value=''wmc''>
+ <label id="labelCheckResourcesWmc" name="labelCheckResourcesWmc">Map Collections</label>
+ <input disabled="disabled" name=''checkResourcesGeorss'' id=''checkResourcesGeorss'' type=''checkbox'' value=''georss''>
+ <label disabled="disabled" id="labelCheckResourcesGeorss" name="labelCheckResourcesGeorss">GeoRSS Feeds</label>
+ </div>
+</fieldset>','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','orderBy',3,1,'Div which shows orderby options for the metadata search','Order','div','','class=''orderBy''',0,80,480,NULL ,20,'','<fieldset>
+<legend id="legendOrderBy" name="legendOrderBy">Sort by:</legend>
+ <img class="help-dialog" id="helpOrderBy" title="Help" help="{text:''Help OrderBy''}" src="../img/questionmark.png" align="right"></img>
+ <p>
+ <input type=''radio'' name=''orderBy'' value=''rank'' id=''orderBy'' checked >
+ <label id="labelOrderByRank" name="labelOrderByRank">relevance</label>
+ <input type=''radio'' name=''orderBy'' value=''title'' id=''orderBy''>
+ <label id="labelOrderByTitle" name="labelOrderByTitle">title</label>
+ <input type=''radio'' name=''orderBy'' value=''id'' id=''orderBy''>
+ <label id="labelOrderById" name="labelOrderById">identification</label>
+ <input type=''radio'' name=''orderBy'' value=''date'' id=''orderBy''>
+ <label id="labelOrderByDate" name="labelOrderByDate">date</label>
+ </p>
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','searchField',3,1,'Div which shows the search field for the metadata search','','div','','class=''searchField''',0,0,480,NULL ,20,'',' <fieldset>
+ <legend id="legendSearchTextTitle" name="legendSearchTextTitle">Searchterm(s):</legend>
+ <img class="help-dialog" id="helpSearchText" title="Help" help="{text:''Help SearchText''}" src="../img/questionmark.png" align="right"></img>
+ <p>
+ <input type=''text'' size=30 name=''searchText'' id=''searchText''>
+ </p>
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','mb_div_collection2',3,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','Wo?','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_div_collection.js','','spatialFilter,mb_div_collection1,spatialBackground','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','form1',3,1,'Form for the extended mapbender metadata search','','form','','method=''post'' name=''form1''',0,0,400,NULL ,NULL,'','','form','../plugins/mb_div_collection.js','../plugins/mb_extendedSearch.js','searchField,button,orderBy,mb_tabs_horizontal','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','jq_ui_button',4,1,'jQuery UI button','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/jquery.ui.button.js','','jq_ui,jq_ui_widget','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','mb_tabs_horizontal',4,1,'Puts existing elements into horizontal tabs, using jQuery UI tabs. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,200,700,NULL ,NULL,'','<ul></ul><div class=''ui-layout-content''></div>','div','../plugins/mb_tabs_horizontal.js','','mb_div_collection2,actuality,classifications,provider,classSearchResources','jq_ui_tabs','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Search_extended_DE','mb_tabs_horizontal','inputs','[
+ "type": "id",
+ "method": "select",
+ "title": "Select a tab",
+ "linkedTo": [
+ "id": "mb_md_select",
+ "event": "selected",
+ "value": "mb_md_edit"
+] ','','var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','jq_ui_droppable',4,1,'jQuery UI droppable','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/jquery.ui.droppable.js','','jq_ui,jq_ui_widget,jq_ui_mouse,jq_ui_draggable','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','mapframe1_mousewheelZoom',4,1,'adds mousewheel zoom to map module (target)','Mousewheel zoom','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','mod_mousewheelZoom.js','../extensions/jquery.mousewheel.min.js','mapframe1','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Search_extended_DE','mapframe1_mousewheelZoom','factor','2','The factor by which the map is zoomed on each mousewheel unit','var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','jq_ui_datepicker',5,1,'Datepicker from jQuery UI framework','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/jquery.ui.datepicker.js','','jq_ui','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','jq_ui_tabs',5,1,'horizontal tabs from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/jquery.ui.tabs.js','','jq_ui,jq_ui_widget','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','jq_ui_resizable',5,1,'Resizable from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../plugins/jq_ui_resizable.js','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/jquery.ui.resizable.js','','jq_ui,jq_ui_mouse,jq_ui_widget','http://jqueryui.com/demos/resizable/');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','jq_ui_draggable',5,1,'Draggable from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/jquery.ui.draggable.js','','jq_ui,jq_ui_mouse,jq_ui_widget','http://jqueryui.com/demos/draggable/');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','jq_ui_dialog',5,1,'Dialog from jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/jquery.ui.dialog.js','','jq_ui,jq_ui_widget,jq_ui_button,jq_ui_draggable,jq_ui_mouse,jq_ui_position,jq_ui_resizable','');
+-- Load WMS to application
+--WMS demis world gui_wms
+INSERT INTO gui_wms (fkey_gui_id,fkey_wms_id,gui_wms_position,gui_wms_mapformat,
+gui_wms_featureinfoformat,gui_wms_exceptionformat,gui_wms_epsg,gui_wms_visible,gui_wms_opacity,gui_wms_sldurl)
+(SELECT
+'Search_extended_DE', fkey_wms_id, 0,
+gui_wms_mapformat,gui_wms_featureinfoformat,
+gui_wms_exceptionformat,gui_wms_epsg,1 as gui_wms_visible,gui_wms_opacity,gui_wms_sldurl
+FROM gui_wms WHERE fkey_gui_id = 'gui' AND fkey_wms_id = 250);
+-- WMS demis world gui_layer
+INSERT INTO gui_layer (fkey_gui_id,fkey_layer_id,gui_layer_wms_id,gui_layer_status,gui_layer_selectable,
+gui_layer_visible,gui_layer_queryable,gui_layer_querylayer,gui_layer_minscale,gui_layer_maxscale,
+gui_layer_priority,gui_layer_style,gui_layer_wfs_featuretype,gui_layer_title)
+(SELECT
+fkey_layer_id,gui_layer_wms_id ,gui_layer_status,gui_layer_selectable,
+gui_layer_maxscale,gui_layer_priority,gui_layer_style,gui_layer_wfs_featuretype,gui_layer_title
+ FROM gui_layer WHERE fkey_gui_id = 'gui' AND gui_layer_wms_id = 250);
+--WMS germany gui_wms
+(SELECT
+'Search_extended_DE', fkey_wms_id, 1,
+FROM gui_wms WHERE fkey_gui_id = 'gui1' AND fkey_wms_id = 893);
+-- WMS germany gui_layer
+(SELECT
+ FROM gui_layer WHERE fkey_gui_id = 'gui1' AND gui_layer_wms_id = 893);
More information about the Mapbender_commits
