[Mapbender-commits] r7887 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org
Mon Jun 27 09:31:39 EDT 2011
Author: armin11
Date: 2011-06-27 06:31:39 -0700 (Mon, 27 Jun 2011)
New Revision: 7887
trunk/mapbender/http/plugins/mb_metadata_server.php
Bugfix. Stores now the metadata xml to tmp folder before parsing it. But there is a further problem: Some metadata can be parsed, other cannot :-(
Modified: trunk/mapbender/http/plugins/mb_metadata_server.php
--- trunk/mapbender/http/plugins/mb_metadata_server.php 2011-06-24 08:43:03 UTC (rev 7886)
+++ trunk/mapbender/http/plugins/mb_metadata_server.php 2011-06-27 13:31:39 UTC (rev 7887)
@@ -746,19 +746,35 @@
$metadataConnector = new connector();
$metadataConnector->set("timeOut", "5");
$metaData = $metadataConnector->load($link);
+ //$e = new mb_exception($metaData);
if (!$metaData) {
- $ajaxResponse->setSuccess(false);
- $ajaxResponse->setMessage("Could not load data via resolving link location!");
- break;
+ abort(_mb("Could not load metadata from source url!"));
+ //write metadata to temporary file:
+ $randomFileId = new Uuid();
+ $tmpMetadataFile = fopen(TMPDIR.'/link_metadata_file_'.$randomFileId.'.xml', 'w');
+ fwrite($tmpMetadataFile, $metaData);
+ fclose($tmpMetadataFile);
+ $e = new mb_exception("File which has been written: link_metadata_file_".$randomFileId.".xml");
+ //read out objects from xml structure
+ if (file_exists(TMPDIR.'/link_metadata_file_'.$randomFileId.'.xml')) {
+ $iso19139Xml=simplexml_load_file(TMPDIR.'/link_metadata_file_'.$randomFileId.'.xml');
+ //$metaData = file_get_contents(TMPDIR.'/link_metadata_file_'.$randomFileId.'.xml');
+ } else {
+ abort(_mb("Temporary file could not be parsed!"));
//$metaData = $metadataConnector->file;
//parse metadata
- try {
+ /*try {
$iso19139Xml = new SimpleXMLElement($metaData);
catch (Exception $e) {
abort(_mb("Parsing ISO19139 XML failed!"));
if ($iso19139Xml != false) {
//get elements for database from xml by using xpath
//uuid
@@ -779,11 +795,11 @@
if (isset($codeSpace[0]) && isset($code[0]) && $codeSpace[0] != '' && $code[0] != '') {
$datasetid = $codeSpace[0]."#".$code[0];
- $e = new mb_notice("class_wms.php: datasetid: ".$datasetid);
+ $e = new mb_exception("class_wms.php: datasetid: ".$datasetid);
} else {
$datasetid = 'undefined';# in sense of INSPIRE TODO control MD_Identifier too!
//abstract
$abstract = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:abstract/gco:CharacterString');
@@ -821,6 +837,7 @@
} else {
+ abort(_mb("Problem with parsing the XML structure with SimpleXML! Record was not inserted into database! Ask your administrator."));
//give back error message - cause parsing has problems
} else { //fill only links into db - do not try to load data
More information about the Mapbender_commits
