[Mapbender-commits] r7888 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org
Mon Jun 27 13:30:02 EDT 2011
Author: marc
Date: 2011-06-27 10:30:02 -0700 (Mon, 27 Jun 2011)
New Revision: 7888
trunk/mapbender/http/classes/class_gui.php
#846
Modified: trunk/mapbender/http/classes/class_gui.php
--- trunk/mapbender/http/classes/class_gui.php 2011-06-27 13:31:39 UTC (rev 7887)
+++ trunk/mapbender/http/classes/class_gui.php 2011-06-27 17:30:02 UTC (rev 7888)
@@ -437,6 +437,10 @@
array_push($v, array($newGuiName, $guiList));
array_push($t, array("s", "s"));
+ array_push($sql, "INSERT INTO sld_user_layer (fkey_mb_user_id,fkey_layer_id,fkey_gui_id,sld_xml,use_sld) SELECT fkey_mb_user_id,fkey_layer_id, $1,sld_xml,use_sld FROM sld_user_layer WHERE fkey_gui_id = $2;");
+ array_push($v, array($newGuiName, $guiList));
+ array_push($t, array("s", "s"));
if ($withUsers == true) {
/* group of original gui is copied as well */
array_push($sql, "INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id, mb_group_type) SELECT $1, fkey_mb_group_id, mb_group_type FROM gui_mb_group WHERE fkey_gui_id = $2;");
More information about the Mapbender_commits
