[Mapbender-commits] r7692 - in trunk/mapbender: http/classes http/php resources/db
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Mar 10 12:08:43 EST 2011
Author: armin11
Date: 2011-03-10 09:08:43 -0800 (Thu, 10 Mar 2011)
New Revision: 7692
Added:
   trunk/mapbender/http/php/mod_group_user_role.php
   trunk/mapbender/resources/db/new_role_concept.sql
   trunk/mapbender/http/classes/class_user.php
First draft commit of new role concept. To activate all please install the new_role_concept.sql and change the lines after 511 of class_user.php - they are marked.
Modified: trunk/mapbender/http/classes/class_user.php
--- trunk/mapbender/http/classes/class_user.php	2011-03-08 09:21:56 UTC (rev 7691)
+++ trunk/mapbender/http/classes/class_user.php	2011-03-10 17:08:43 UTC (rev 7692)
@@ -508,6 +508,11 @@
 		$mb_user_id = $this->id;
 		$arrayGuis = array();
 		$mb_user_groups = array();
+		//exchange for the new role system - there are roles which don't include permissions explicitly
+		/*$sql_groups = "SELECT fkey_mb_group_id FROM ";
+		$sql_groups .= "(SELECT * from mb_user_mb_group left join mb_role on ";
+		$sql_groups .= " mb_user_mb_group.mb_user_mb_group_type = mb_role.role_id ";
+		$sql_groups .= " WHERE mb_role.role_exclude_auth != 1)  AS mb_user_mb_group WHERE fkey_mb_user_id = $1 ";*/
 		$sql_groups = "SELECT fkey_mb_group_id FROM mb_user_mb_group WHERE fkey_mb_user_id = $1 ";
 		$v = array($mb_user_id);
 		$t = array("i");
Added: trunk/mapbender/http/php/mod_group_user_role.php
--- trunk/mapbender/http/php/mod_group_user_role.php	                        (rev 0)
+++ trunk/mapbender/http/php/mod_group_user_role.php	2011-03-10 17:08:43 UTC (rev 7692)
@@ -0,0 +1,373 @@
+<?php
+# $Id: mod_group_user.php 7276 2010-12-12 10:36:40Z apour $
+# http://www.mapbender.org/index.php/Administration
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+$e_id="Group_User_Role";
+require_once(dirname(__FILE__)."/../classes/class_mb_exception.php");
+require_once(dirname(__FILE__)."/../php/mb_validatePermission.php");
+//require_once(dirname(__FILE__)."/../core/globalSettings.php");
+ * @security_patch irv done
+//security_patch_log(__FILE__,__LINE__);
+//import_request_variables("PG");
+$postvars = explode(",", "selected_group,filter2,insert,remove,filter3,remove_user,selected_user,select_role,alterrole");
+foreach ($postvars as $value) {
+   $$value = $_POST[$value];
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<?php
+echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
+<title>Edit Group Members</title>
+<?php include '../include/dyn_css.php'; ?>
+<script language="JavaScript">
+function validate(wert){
+	if(document.forms[0]["selected_group"].selectedIndex == -1){
+		document.getElementsByName("selected_group")[0].style.backgroundColor = '#ff0000';
+		return;
+	}else{
+		if(wert == "remove"){
+			if(document.forms[0]["remove_user[]"].selectedIndex == -1){
+				document.getElementsByName("remove_user[]")[0].style.backgroundColor = '#ff0000';
+				return;
+			document.form1.remove.value = 'true';
+			document.form1.submit();
+		if(wert == "insert"){
+			if(document.forms[0]["selected_user[]"].selectedIndex == -1){
+				document.getElementsByName("selected_user[]")[0].style.backgroundColor = '#ff0000';
+				return;
+			document.form1.insert.value = 'true';
+		if(wert == "showrole"){
+			document.forms[0]["select_role"].disabled=false;
+			var removeUser = document.forms[0]["remove_user[]"].value;
+			var removeUserArray = removeUser.split("+");
+			//alert(removeUserArray[1]);
+			for(index = 0; index < document.forms[0]["select_role"].length; index++) {
+   				if(document.forms[0]["select_role"][index].value == removeUserArray[1]) {
+     					document.forms[0]["select_role[]"].selectedIndex = index;
+		if(wert == "changerole"){
+			document.form1.alterrole.value = 'true';
+ * filter the Userlist by str
+function filterUser(list, all, str){
+	str=str.toLowerCase();
+	var selection=[];
+	var i,j,selected;
+	for(i=0;i<list.options.length;i++){
+		if(list.options[i].selected)
+			selection[selection.length]=list.options[i].value;
+	list.options.length = 0;
+	for(i=0; i<all.length; i++){
+		if(all[i]['name'].toLowerCase().indexOf(str)==-1)
+			continue;
+		selected=false;
+		for(j=0;j<selection.length;j++){
+			if(selection[j]==all[i]['id']){
+				selected=true;
+				break;
+		var newOption = new Option(selected?all[i]['name']+" ("+all[i]['email']+")":all[i]['name'],all[i]['id'],false,selected);
+		newOption.setAttribute("title", all[i]['email']);
+		list.options[list.options.length] = newOption;
+ * add Mail adress on selection
+function updateMail(list, all){
+	var j=0;
+	for(var i=0; i<list.options.length;i++){
+		if(list.options[i].selected){
+			for(j=j;j<all.length;j++){
+				if(all[j]['id']==list.options[i].value){
+					list.options[i].text=all[j]['name']+" ("+all[j]['email']+")";
+					list.options[i].selected = true;
+					break;
+		else{
+					list.options[i].text=all[j]['name'];
+					list.options[i].selected = false;
+					break;
+function showAvailableRoles(){
+function selectRole(){
+</script>
+</head>
+<body>
+<?php
+$fieldHeight = 20;
+$cnt_group = 0;
+$cnt_user = 0;
+$cnt_group = 0;
+$cnt_group_user = 0;
+$cnt_group_group = 0;
+$cnt_role = 0;
+$exists = false;
+/*handle remove, update and insert**************************************************************************************/
+if($insert){
+	if(count($selected_user)>0){
+		for($i=0; $i<count($selected_user); $i++){
+			$exists = false;
+			//check if a user is already in this group a standard role
+			$sql = "SELECT * from mb_user_mb_group where fkey_mb_group_id = $1 and fkey_mb_user_id = $2 and mb_user_mb_group_type = $3";
+			$v = array($selected_group,$selected_user[$i],1);
+			$t = array('i','i','i');
+			$res_insert = db_prep_query($sql,$v,$t);
+			while(db_fetch_row($res_insert)){$exists = true;}
+			if($exists == false){
+				//add a user without any special role to the selected group
+				$sql = "INSERT INTO mb_user_mb_group(fkey_mb_group_id, fkey_mb_user_id) ";
+				$sql .= "VALUES($1, $2);";
+				$v = array($selected_group,$selected_user[$i]);
+				$t = array('i','i');
+				$res = db_prep_query($sql,$v,$t);
+if($remove){
+	if(count($remove_user)>0){
+		for($i=0; $i<count($remove_user); $i++){
+			$sql_remove = "DELETE FROM mb_user_mb_group WHERE ";
+			$sql_remove .= "fkey_mb_user_id = $1 and fkey_mb_group_id = $2 AND mb_user_mb_group_type = $3";
+			//explode identifier for selected user option
+			$remove_user_explode = explode('+',$remove_user[$i]);
+			$v = array($remove_user_explode[0],$selected_group,$remove_user_explode[1]);
+			db_prep_query($sql_remove,$v,$t);
+if($alterrole){
+	$e = new mb_exception("alterrole send");
+	if(count($remove_user)==1){
+		$e = new mb_exception("only one user selected");
+		//update role of the selected user-role combination - if it doesn't exists at all!
+		//check if combi exists
+		$exists = false;
+		//check if a user is already in this group without that role
+		//explode user-role combi to single elements userId and roleId
+		$remove_user_explode = explode('+',$remove_user[0]);
+		$v = array($selected_group,$remove_user_explode[0],$select_role[0]);
+			//the given one will be updated
+			$e = new mb_exception("Requested combination user_group_role does not exist in database - update will be performed");
+			//change this role
+			$sql_alterrole = "UPDATE mb_user_mb_group SET mb_user_mb_group_type = $1 WHERE ";
+			$sql_alterrole .= "fkey_mb_user_id = $2 and fkey_mb_group_id = $3 AND mb_user_mb_group_type = $4";
+			$e = new mb_exception("select_row: ".$select_row);
+			$v = array($select_role[0],$remove_user_explode[0],$selected_group,$remove_user_explode[1]);
+			$t = array('i','i','i','i');
+			db_prep_query($sql_alterrole,$v,$t);
+		} else {
+			$e = new mb_exception("Combi user_group_role does already exist in the database - it need not to be added again!");
+/*get all group  ********************************************************************************************/
+$sql_group = "SELECT * FROM mb_group ORDER BY mb_group_name";
+$res_group = db_query($sql_group);
+while($row = db_fetch_array($res_group)){
+	$group_id[$cnt_group] = $row["mb_group_id"];
+	$group_name[$cnt_group] = $row["mb_group_name"];
+	$cnt_group++;
+/*get all user **********************************************************************************************/
+$sql_user = "SELECT * FROM mb_user ORDER BY mb_user_name";
+$res_user = db_query($sql_user);
+while($row = db_fetch_array($res_user)){
+	$user_id[$cnt_user] = $row["mb_user_id"];
+	$user_name[$cnt_user] =  $row["mb_user_name"];
+	$user_email[$cnt_user] = $row["mb_user_email"];
+	$cnt_user++;
+/*get all roles **********************************************************************************************/
+$sql_role = "SELECT * FROM mb_role ORDER BY role_name";
+$res_role = db_query($sql_role);
+while($row = db_fetch_array($res_role)){
+	$role_id[$cnt_role] = $row["role_id"];
+	$role_name[$cnt_role] =  $row["role_name"];
+	$role_description[$cnt_role] = $row["role_description"];
+	$role_exclude_auth[$cnt_role] = $row["role_exclude_auth"];
+	$cnt_role++;
+/*get all user from selected group******************************************************************************/
+$sql_mb_user_mb_group = "SELECT mb_user.mb_user_id, mb_user.mb_user_name, "; $sql_mb_user_mb_group .= "mb_user.mb_user_email, mb_user_mb_group.fkey_mb_group_id, "; $sql_mb_user_mb_group .= "mb_user_mb_group.mb_user_mb_group_type, "; $sql_mb_user_mb_group .= "mb_user_mb_group.role_exclude_auth ";
+$sql_mb_user_mb_group .= "FROM (select * from mb_user_mb_group left join mb_role on "; $sql_mb_user_mb_group .= "mb_user_mb_group.mb_user_mb_group_type = mb_role.role_id ) as "; $sql_mb_user_mb_group .= "mb_user_mb_group INNER JOIN mb_user ON  ";
+$sql_mb_user_mb_group .= "mb_user_mb_group.fkey_mb_user_id = mb_user.mb_user_id  ";
+$sql_mb_user_mb_group .= "WHERE mb_user_mb_group.fkey_mb_group_id= $1 ";
+$sql_mb_user_mb_group .= "ORDER BY mb_user.mb_user_name ";
+/*$sql_mb_user_mb_group = "SELECT mb_user.mb_user_id, mb_user.mb_user_name, mb_user.mb_user_email, mb_user_mb_group.fkey_mb_group_id, mb_user_mb_group.mb_user_mb_group_type FROM mb_user_mb_group ";
+$sql_mb_user_mb_group .= "INNER JOIN mb_user ON mb_user_mb_group.fkey_mb_user_id = mb_user.mb_user_id ";
+$sql_mb_user_mb_group .= " ORDER BY mb_user.mb_user_name";
+if(!$selected_group){$v = array($group_id[0]);}
+if($selected_group){$v = array($selected_group);}
+$t = array('i');
+$res_mb_user_mb_group = db_prep_query($sql_mb_user_mb_group,$v,$t);
+while($row = db_fetch_array($res_mb_user_mb_group)){
+	$user_id_group[$cnt_group_user] = $row["mb_user_id"];
+	$user_name_group[$cnt_group_user] =  $row["mb_user_name"];
+	$user_email_group[$cnt_group_user] =  $row["mb_user_email"];
+	$user_group_type_group[$cnt_group_user] =  $row["mb_user_mb_group_type"];
+	$user_role_exclude_auth_group[$cnt_group_user] =  $row["role_exclude_auth"];
+	$cnt_group_user++;
+/*INSERT HTML*/
+echo "<form name='form1' action='" . $self . "' method='post'>";
+/*insert projects in selectbox*************************************************************************************/
+echo "<div class='text1'>GROUP: </div>";
+echo "<select style='background:#ffffff' class='select1' name='selected_group' onChange='submit()' size='10'>";
+for($i=0; $i<$cnt_group; $i++){
+	echo "<option value='" . $group_id[$i] . "' ";
+	if($selected_group && $selected_group == $group_id[$i]){
+		echo "selected";
+	echo ">" . $group_name[$i]  . "</option>";
+echo "</select>";
+/*filterbox****************************************************************************************/
+echo "<input type='text' value='' class='filter2' id='filter2' name='filter2' onkeyup='filterUser(document.getElementById(\"selecteduser\"),user,this.value);'/>";
+/*insert all profiles in selectbox*****************************************************************/
+echo "<div class='text2'>USER:</div>";
+echo "<select style='background:#ffffff' onchange='updateMail(this, user)' class='select2' multiple='multiple' id='selecteduser' name='selected_user[]' size='$fieldHeight' >";
+for($i=0; $i<$cnt_user; $i++){
+	echo "<option value='" . $user_id[$i]  . "' title='".$user_email[$i]."'>" . $user_name[$i]  . "</option>";
+echo "</select>";
+/*Button****************************************************************************************************/
+echo "<div class='button1'><input type='button'  value='==>' onClick='validate(\"insert\")'></div>";
+echo "<input type='hidden' name='insert'>";
+echo "<div class='button2'><input type='button' value='<==' onClick='validate(\"remove\")'></div>";
+echo "<input type='hidden' name='remove'>";
+echo "<input type='hidden' name='alterrole'>";
+echo "<input type='text' value='' class='filter3' id='filter3' name='filter3' onkeyup='filterUser(document.getElementById(\"removeuser\"),groupuser,this.value);'/>";
+/*insert container_profile_dependence and container_group_dependence in selectbox******************/
+echo "<div class='text3'>SELECTED USER:</div>";
+echo "<select style='background:#ffffff' onchange='validate(\"showrole\")' class='select3' name='remove_user[]' id='removeuser' size='$fieldHeight' >";
+for($i=0; $i<$cnt_group_user; $i++){
+	if ($user_role_exclude_auth_group[$i] == 1) {
+		echo "<option value='".$user_id_group[$i]."+".$user_group_type_group[$i]."' title='".$user_email_group[$i]."' style='background-color: Red;'>" . $user_name_group[$i]  . " - " .$user_group_type_group[$i]. "</option>";
+	} else {
+		echo "<option value='".$user_id_group[$i]."+".$user_group_type_group[$i]."' title='".$user_email_group[$i]."'>" . $user_name_group[$i]  . " - " .$user_group_type_group[$i]. "</option>";
+echo "</select>";
+echo "<div class='roleHeader'>SELECTED ROLE:</div>";
+echo "<select style='background:#ffffff' onchange='validate(\"changerole\")' class='selectRole' name='select_role[]' id='select_role' size='1' disabled='true'>";
+//echo "<option value='0' title='no role defined'>no special role defined yet!</option>";
+for($i=0; $i<$cnt_role; $i++){
+	echo "<option value='" . $role_id[$i]  . "' title='".$role_id[$i]." - ".$role_description[$i]."'>".$role_id[$i]." - ". $role_name[$i]  . "</option>";
+echo "</select>";
+echo "<table><tr><td bgcolor=\"#FF0000\">Role has no influence on authorization!</td></tr></table>";
+echo "</form>";
+<script type="text/javascript">
+document.forms[0].selected_group.focus();
+var user=[];
+<?php
+	echo "user[".$i."]=[];\n";
+	echo "user[".$i."]['id']='" . $user_id[$i]  . "';\n";
+	echo "user[".$i."]['name']='" . $user_name[$i]  . "';\n";
+	echo "user[".$i."]['email']='" . $user_email[$i]  . "';\n";
+var groupuser=[];
+<?php
+	echo "groupuser[".$i."]=[];\n";
+	echo "groupuser[".$i."]['id']='" . $user_id_group[$i]  . "';\n";
+	echo "groupuser[".$i."]['name']='" . $user_name_group[$i]  . "';\n";
+	echo "groupuser[".$i."]['email']='" . $user_email_group[$i]  . "';\n";
+	echo "groupuser[".$i."]['group_type']='" . $user_group_type_group[$i]  . "';\n";
+var groupuserrole=[];
+<?php
+	echo "groupuserrole[".$i."]=[];\n";
+	echo "groupuserrole[".$i."]['id']='" . $role_id[$i]  . "';\n";
+	echo "groupuserrole[".$i."]['name']='" . $role_name[$i]  . "';\n";
+	echo "groupuserrole[".$i."]['description']='" . $role_description[$i]  . "';\n";
+</script>
+</body>
+</html>
Added: trunk/mapbender/resources/db/new_role_concept.sql
--- trunk/mapbender/resources/db/new_role_concept.sql	                        (rev 0)
+++ trunk/mapbender/resources/db/new_role_concept.sql	2011-03-10 17:08:43 UTC (rev 7692)
@@ -0,0 +1,63 @@
+--***** new role system - should not influence the normal behaviour
+-- Table: mb_role
+-- DROP TABLE mb_role;
+CREATE TABLE mb_role
+  role_id serial NOT NULL,
+  role_name character varying(50),
+  role_description character varying(255),
+  role_exclude_auth integer NOT NULL DEFAULT 0,
+  CONSTRAINT role_id PRIMARY KEY (role_id)
+WITH (
+  OIDS=FALSE
+ALTER TABLE mb_role OWNER TO postgres;
+--things to be done for mb_user_mb_group table:
+--drop old constraint
+--Allow to be member in a group with different roles
+ALTER TABLE mb_user_mb_group DROP CONSTRAINT pk_fkey_mb_user_mb_group_id;
+UPDATE mb_user_mb_group SET mb_user_mb_group_type = 1 WHERE mb_user_mb_group_type IS NULL OR mb_user_mb_group_type = 0;
+--default to standard role
+ALTER TABLE mb_user_mb_group ALTER COLUMN mb_user_mb_group_type SET DEFAULT 1;
+-- Constraint: pk_fkey_mb_user_mb_group_id
+-- ALTER TABLE mb_user_mb_group DROP CONSTRAINT pk_fkey_mb_user_mb_group_id;
+--create new constraint
+  ADD CONSTRAINT pk_fkey_mb_user_mb_group_id PRIMARY KEY(fkey_mb_user_id, fkey_mb_group_id, mb_user_mb_group_type);
+--things for the role table
+--standard roles:
+INSERT INTO mb_role (role_name,role_description,role_exclude_auth) VALUES ('standard role','No special role - old behaviour.',0);
+INSERT INTO mb_role (role_name,role_description,role_exclude_auth) VALUES ('primary','Primary group for a mapbender user.',0);
+INSERT INTO mb_role (role_name,role_description,role_exclude_auth) VALUES ('metadata editor','Group for which the user can edit and publish metadata.',1);
+--constraint for new role system
+-- ALTER TABLE mb_user_mb_group DROP CONSTRAINT fkey_mb_user_mb_group_role_id;
+  ADD CONSTRAINT fkey_mb_user_mb_group_role_id FOREIGN KEY (mb_user_mb_group_type)
+      REFERENCES mb_role (role_id) MATCH SIMPLE
+      ON UPDATE CASCADE ON DELETE CASCADE;
+--link for admin1
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin1','Group_User_Role',2,1,'allocate groups to user and roles','','a','','href = "../php/mod_group_user_role.php?sessionID&e_id_css=Group_User_Role" target = "AdminFrame" ',10,1234,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none;color: #808080;','GROUP -> USER -> ROLE','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('admin1', 'Group_User_Role', 'file css', '../css/administration_alloc.css', 'file css' ,'file/css');
+--*****end of role concept****
More information about the Mapbender_commits mailing list
