[Mapbender-commits] r8449 - trunk/mapbender/http/geoportal
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Aug 6 00:45:08 PDT 2012
Author: armin11
Date: 2012-08-06 00:45:08 -0700 (Mon, 06 Aug 2012)
New Revision: 8449
   trunk/mapbender/http/geoportal/gaz_geom_mobile.php
bugfix
Modified: trunk/mapbender/http/geoportal/gaz_geom_mobile.php
--- trunk/mapbender/http/geoportal/gaz_geom_mobile.php	2012-07-23 14:24:40 UTC (rev 8448)
+++ trunk/mapbender/http/geoportal/gaz_geom_mobile.php	2012-08-06 07:45:08 UTC (rev 8449)
@@ -84,6 +84,8 @@
 	$searchThruWeb = true;
+$e = new mb_exception("maxResults: ".$maxResults);
 $con = pg_connect("host=".GEOMDB_HOST." port=".GEOMDB_PORT." dbname=".GEOMDB_NAME." user=".GEOMDB_USER." password=".GEOMDB_PASSWORD)
 or die('Verbindungsaufbau fehlgeschlagen: ' . pg_last_error());
@@ -245,7 +247,8 @@
 		$sql = "SELECT DISTINCT * FROM (SELECT DISTINCT gem_schl_neu, gemeinde_neu AS gem FROM gemeinden ";
 		$sql .= "WHERE gemeinde_upper LIKE $1";
 		$sql .= "UNION SELECT DISTINCT gem_schl_neu, gemeinde_gem_teile AS gem FROM wohnplatz ";
-		$sql .= "WHERE gemeinde_gem_teile_upper LIKE $2) AS str";
+		$sql .= "WHERE ewz_int IS NOT NULL AND  gemeinde_gem_teile_upper LIKE $2";
+		$sql .= ") AS str";
 		$res = db_prep_query($sql,$v,$t);
 		while($row = db_fetch_array($res)){
 			array_push($ckeys, $row['gem_schl_neu']);
@@ -255,9 +258,10 @@
 		$v = array($b, $b);
 		$t = array('s', 's');
-		$sql .= "WHERE gemeinde_upper LIKE $1";
+		$sql .= "WHERE gemeinde_upper LIKE $1 ";
@@ -333,9 +337,10 @@
 		$v = array($a, $a);
+		$sql .=") AS str";
More information about the Mapbender_commits mailing list
