[Mapbender-commits] r8450 - in trunk/mapbender/http: classes javascripts php plugins
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Aug 8 08:19:06 PDT 2012
Author: armin11
Date: 2012-08-08 08:19:06 -0700 (Wed, 08 Aug 2012)
New Revision: 8450
Added:
   trunk/mapbender/http/javascripts/mb_downloadFeedClient.js
   trunk/mapbender/http/plugins/mb_downloadFeedClient.php
   trunk/mapbender/http/plugins/mb_downloadFeedServer.php
   trunk/mapbender/http/classes/class_georss_geometry.php
   trunk/mapbender/http/classes/class_gml2.php
   trunk/mapbender/http/php/mod_inspireDownloadFeed.php
Prototype for INSPIRE Download Service client based on ATOM Feeds. Not yet ready - some further work needs to be done.
Modified: trunk/mapbender/http/classes/class_georss_geometry.php
--- trunk/mapbender/http/classes/class_georss_geometry.php	2012-08-06 07:45:08 UTC (rev 8449)
+++ trunk/mapbender/http/classes/class_georss_geometry.php	2012-08-08 15:19:06 UTC (rev 8450)
@@ -61,7 +61,7 @@
 		$rssDoc->registerXPathNamespace('xls', 'http://www.opengis.net/xls');
 		$rssDoc->registerXPathNamespace('gml', 'http://www.opengis.net/gml');
 		$rssDoc->registerXPathNamespace('georss', 'http://www.georss.org/georss');
-		#for ingrid - portalu georss
+		//for ingrid - portalu georss
 		$rssDoc->registerXPathNamespace('ingrid', 'http://www.portalu.de/opensearch/extension/1.0');
 		// build feature collection
@@ -265,15 +265,19 @@
 class geoRSSPolygon extends GMLPolygon{
 	var $targetEPSG;
-	public function parsePolygon ($domNode) {
-		$cnt = 0;
-		$y = 0;
-		foreach(explode(' ',$domNode->nodeValue) as $cord){
-			if($cnt % 2)
-				$this->addPoint($cord, $y);
-			$y = $cord;
-			$cnt++;
+	public function parsePolygon ($georssPolygon) {
+		if (gettype == 'object') {
+			//polygon is given as dom node
+			$coordArray = explode(' ',$georssPolygon->nodeValue);
+		} else {
+			//polygon is given as string
+			$coordArray = explode(' ',$georssPolygon);
+		$countCoordPairs = count($coordArray) / 2;
+		//in georss lat/lon is given, in geojson lon lat will be used http://www.georss.org/simple http://www.geojson.org/geojson-spec.html#coordinate-reference-system-objects
+		for ($j=0; $j<=($countCoordPairs-1); $j++) {
+			$this->addPoint($coordArray[$j*2 + 1], $coordArray[$j*2]);
Modified: trunk/mapbender/http/classes/class_gml2.php
--- trunk/mapbender/http/classes/class_gml2.php	2012-08-06 07:45:08 UTC (rev 8449)
+++ trunk/mapbender/http/classes/class_gml2.php	2012-08-08 15:19:06 UTC (rev 8450)
@@ -771,8 +771,10 @@
-	protected function addPoint ($x, $y) {
+	public function addPoint ($x, $y) {
+		//$e = new mb_exception("add point");
 		array_push($this->pointArray, array("x" => $x, "y" => $y));
 	protected function addPointToRing ($i, $x, $y) {
Added: trunk/mapbender/http/javascripts/mb_downloadFeedClient.js
--- trunk/mapbender/http/javascripts/mb_downloadFeedClient.js	                        (rev 0)
+++ trunk/mapbender/http/javascripts/mb_downloadFeedClient.js	2012-08-08 15:19:06 UTC (rev 8450)
@@ -0,0 +1,317 @@
+var mapframe_dataset_list, mapframe_file_list, datasetSelect, file_list, bboxDataset, bboxFiles, formats;
+        function updateFormats() {
+            var in_options = {
+                'internalProjection': mapframe_dataset_list.baseLayer.projection,
+                'externalProjection': new OpenLayers.Projection("EPSG:4326")
+            var out_options = {
+                'externalProjection': new OpenLayers.Projection("EPSG:900913")
+            var gmlOptions = {
+                featureType: "feature",
+                featureNS: "http://example.com/feature"
+            var gmlOptionsIn = OpenLayers.Util.extend(
+                OpenLayers.Util.extend({}, gmlOptions),
+                in_options
+            var gmlOptionsOut = OpenLayers.Util.extend(
+                out_options
+            var kmlOptionsIn = OpenLayers.Util.extend(
+                {extractStyles: true}, in_options);
+            formats = {
+              'in': {
+                wkt: new OpenLayers.Format.WKT(in_options),
+                geojson: new OpenLayers.Format.GeoJSON(in_options),
+                georss: new OpenLayers.Format.GeoRSS(in_options),
+                gml2: new OpenLayers.Format.GML.v2(gmlOptionsIn),
+                gml3: new OpenLayers.Format.GML.v3(gmlOptionsIn),
+                kml: new OpenLayers.Format.KML(kmlOptionsIn),
+                atom: new OpenLayers.Format.Atom(in_options),
+                gpx: new OpenLayers.Format.GPX(in_options)
+              'out': {
+                wkt: new OpenLayers.Format.WKT(out_options),
+                geojson: new OpenLayers.Format.GeoJSON(out_options),
+                georss: new OpenLayers.Format.GeoRSS(out_options),
+                gml2: new OpenLayers.Format.GML.v2(gmlOptionsOut),
+                gml3: new OpenLayers.Format.GML.v3(gmlOptionsOut),
+                kml: new OpenLayers.Format.KML(out_options),
+                atom: new OpenLayers.Format.Atom(out_options),
+                gpx: new OpenLayers.Format.GPX(out_options)
+function init(){
+	//generate 2 Mapframes
+	mapframe_dataset_list = new OpenLayers.Map('mapframe_dataset_list');
+	mapframe_file_list = new OpenLayers.Map('mapframe_file_list');
+	var wms1 = new OpenLayers.Layer.WMS( "OpenLayers WMS",
+                "http://www.gdi-rp-dienste2.rlp.de/cgi-bin/mapserv.fcgi?map=/data/umn/geoportal/karte_rp/rheinland-pfalz-gesamt2.map&", {layers: 'ATKIS-Praes'}, {singleTile: true});
+	var wms2 = new OpenLayers.Layer.WMS( "OpenLayers WMS",
+	bboxDataset = new OpenLayers.Layer.Vector("Dataset bounding boxes");
+	bboxFiles = new OpenLayers.Layer.Vector("File bounding boxes");
+	mapframe_dataset_list.addLayers([wms1, bboxDataset]);
+	mapframe_dataset_list.addControl(new OpenLayers.Control.MousePosition());
+	//mapframe_dataset_list.addControl(new OpenLayers.Control.EditingToolbar(bboxDataset));
+	mapframe_file_list.addLayers([wms2, bboxFiles]);
+	mapframe_file_list.addControl(new OpenLayers.Control.MousePosition());
+	//mapframe_file_list.addControl(new OpenLayers.Control.EditingToolbar(bboxFiles));
+	var options = {
+		hover: true,
+	updateFormats();
+	mapframe_dataset_list.setCenter(new OpenLayers.LonLat(7, 50), 7);
+	mapframe_file_list.setCenter(new OpenLayers.LonLat(7, 50), 7);
+	$(document).ready(function(e) {
+    		$('#download_feed_button').click(function() {
+			method =  "getServiceFeedObjectFromUrl";
+        		data = $("#download_feed_url").val();
+			//data = data.serialize();
+			callServer(data,method);
+	/*$(document).ready(function(e) {
+			method =  "getDatasetFeedObjectFromUrl";
+function callServer(data,method) {
+	$.ajax({
+  		url: '../plugins/mb_downloadFeedServer.php',
+  		type: "post",
+		async: false,
+		data: {url: data, method: method },
+       		dataType: "json",
+  		success: function(result) {
+			if (method == "getServiceFeedObjectFromUrl") {
+				drawMetadataPolygons(result);
+				showDatasetList(result);
+			//alert(result);
+			if (method == "getDatasetFeedObjectFromUrl") {
+				//fill dataset feed
+				//alert("got result");
+				showDatasetEntryList(result);
+				//alert(result);
+	return false;
+function showDatasetEntryList(featureCollection) {
+	if (featureCollection == null) {
+		alert("No parseable content found");
+		return false;
+	//if (typeof(datasetSelect) !== 'undefined'){
+	$('#dataset_representation_select').remove();
+	//delete old entries
+	var datasetEntrySelect =  $(document.createElement('select')).appendTo('#dataset_representation_list');
+	datasetEntrySelect.attr({'id':'dataset_representation_select'});
+	var selectROptions = "";
+	for(var i=0; i<featureCollection.features.length; ++i) {
+		selectROptions = selectROptions+"<option value='"+featureCollection.features[i].properties.datasetFeedLink+"' url='"+featureCollection.features[i].properties.datasetFeedLink+"'>"+featureCollection.features[i].properties.title+"</option>";
+		//var datasetSelectOption =  $(document.createElement('option')).appendTo(datasetSelect);
+		//datasetSelectOption.attr({'value':featureCollection.features[i].id});
+	datasetEntrySelect.append(selectROptions);
+	fillSectionList(featureCollection, 0)
+	$('#dataset_representation_select').bind('change', function() {
+    		//var $this = $(this);
+		//method =  "getDatasetLinkFromUrl";
+        	//data = $this.val();
+		alert("list changed");
+		//callServer(data,method);
+function showDatasetList(featureCollection) {
+		return false;
+	$('#dataset_select').remove();
+	var datasetSelect =  $(document.createElement('select')).appendTo('#dataset_list');
+	datasetSelect.attr({'id':'dataset_select'});
+	var selectOptions = "";
+		//fill in first title, rights and abstract in fields
+//alert(featureCollection.features[i].properties.title);//$('#dataset_title').value = "";
+		if (i == 0) {
+			$('#dataset_title').val(featureCollection.features[i].properties.title);
+			$('#dataset_rights').val(featureCollection.features[i].properties.rights);
+			//$('#dataset_title').val() = featureCollection.features[i].properties.title;
+		selectOptions = selectOptions+"<option value='"+featureCollection.features[i].properties.datasetFeedLink+"' url='"+featureCollection.features[i].properties.datasetFeedLink+"'>"+featureCollection.features[i].properties.title+"</option>";
+	datasetSelect.append(selectOptions);
+	$('#dataset_select').bind('change', function() {
+    		var $this = $(this);
+        	data = $this.val();
+	//call second feed with first entry
+        data = featureCollection.features[0].properties.datasetFeedLink;
+function fillSectionList(featureCollection, k) {
+		//fill graphic
+		//generate features from link list
+		bboxFiles.removeAllFeatures();
+		$('#section_option').remove();
+		//datasetFileSelect =  $(document.createElement('select')).appendTo('#section_select');
+		//datasetFileSelect.attr({'id':'section_file_list'});
+		//datasetFileSelect.attr({'multiple':'multiple'});
+		selectFOptions = "";
+                for (var i = 0; i < featureCollection.features[k].properties.entry[k].link.length; i++) {
+                	ext = featureCollection.features[k].properties.entry[k].link[i]['@attributes'].bbox;
+			extArrayNew = new Array();
+			//extArray = new Array();
+			//alert(extArray[1]);
+			extArray = ext.split(",");
+			extArrayNew[0] = extArray[1];
+			extArrayNew[1] = extArray[0];
+			extArrayNew[2] = extArray[3];
+			extArrayNew[3] = extArray[2];
+                	bound = OpenLayers.Bounds.fromArray(extArrayNew);
+			attributes = {id: i, url:featureCollection.features[k].properties.entry[k].link[i]['@attributes'].href};
+                	box = new OpenLayers.Feature.Vector(bound.toGeometry(),attributes);
+                	bboxFiles.addFeatures(box);
+			selectFOptions = selectFOptions+"<option value='"+i+"' url='"+featureCollection.features[k].properties.entry[k].link[i]['@attributes'].href+"' title='"+featureCollection.features[k].properties.entry[k].link[i]['@attributes'].title+"' onclick='highlightFeatureIndexById("+i+");'>"+featureCollection.features[k].properties.entry[k].link[i]['@attributes'].title+"</option>";
+		//count features of bboxFiles
+		//bboxFiles if not available show error message
+		selectFOptionsObject = $('#section_file_list').append(selectFOptions);
+		selectFOptionsObject.attr({'id':'section_option'});
+		selectFOptionsObject.attr({'width': 300});
+		bound = bboxFiles.getDataExtent();
+		mapframe_file_list.zoomToExtent(bound);
+               // map.addLayers([ol_wms, boxes]);
+              //  map.addControl(new OpenLayers.Control.LayerSwitcher());
+		bboxFiles.events.on({
+   			featureselected: function(event) {
+        			var feature = event.feature;
+        			//var area = feature.geometry.getArea();
+        			var id = feature.attributes.id;
+				var url = feature.attributes.url;
+				$('#section_option option').removeAttr('selected')
+				$("#section_option option[value='"+id+"']").attr('selected',true);
+				window.open(url,'download_window');
+				/*if ($('#multi_select').is(':checked')) {
+					alert("checked");
+				} else {
+					alert("un-checked");
+				alert(url);*/
+        			//var output = "Building: " + id + " Area: " + area.toFixed(2);
+        			//document.getElementById("output-id").innerHTML = output;
+                sf = new OpenLayers.Control.SelectFeature(bboxFiles);
+                mapframe_file_list.addControl(sf);
+                sf.activate();
+function drawMetadataPolygons(featureCollection) {
+	 var type = "geojson";
+         var features = formats['in'][type].read(featureCollection);
+         var bounds;
+         if(features) {
+             if(features.constructor != Array) {
+                 features = [features];
+             for(var i=0; i<features.length; ++i) {
+                 if (!bounds) {
+                     bounds = features[i].geometry.getBounds();
+                 } else {
+                     bounds.extend(features[i].geometry.getBounds());
+	     //delete old features:
+	     bboxDataset.removeAllFeatures();
+             bboxDataset.addFeatures(features);
+             mapframe_dataset_list.zoomToExtent(bounds);
+function highlightFeatureIndexById(id) {
+	var features = bboxFiles.features;
+		if(features[i].attributes.id == id) {
+			index = i;
+			break;
+	//unselect all
+	sf.unselect(bboxFiles.selectedFeatures[0]);
+	sf.select(bboxFiles.features[index]);
+	window.open(bboxFiles.features[index].attributes.url,'download_window');
Modified: trunk/mapbender/http/php/mod_inspireDownloadFeed.php
--- trunk/mapbender/http/php/mod_inspireDownloadFeed.php	2012-08-06 07:45:08 UTC (rev 8449)
+++ trunk/mapbender/http/php/mod_inspireDownloadFeed.php	2012-08-08 15:19:06 UTC (rev 8450)
@@ -26,7 +26,7 @@
 require_once(dirname(__FILE__) . "/../classes/class_connector.php");
 require_once(dirname(__FILE__) . "/../classes/class_administration.php");
 require_once(dirname(__FILE__) . "/../classes/class_Uuid.php");
+//http://www.weichand.de/inspire/dls/verwaltungsgrenzen.xml
 $con = db_connect(DBSERVER,OWNER,PW);
 db_select_db(DB,$con);
@@ -550,7 +550,7 @@
 				$nCols = ceil($diffXPx / floatval($maxImageSize));
 				$e = new mb_exception($nRows.":".$nCols);
 				$bboxWms = array();
-				$bboxWmsWS84 = array();
+				$bboxWmsWGS84 = array();
 				/*echo $diffXPx.":".$diffYPx.",";
 				echo $nRows.":".$nCols.",";
 				echo $minx.":".$miny.",";
@@ -570,6 +570,7 @@
 						//echo "maxyWms: ". $maxyWms .",";
 						$bboxWms[] = $minxWms.",".$minyWms.",".$maxxWms.",".$maxyWms;
 						$bboxWmsWGS84[] = transformBbox($minxWms.",".$minyWms.",".$maxxWms.",".$maxyWms,intval($epsgId[1]),4326);
@@ -680,6 +681,7 @@
 						//transform bbox back to geographic coordinates
 						$lonLatBbox = transformBbox($minxWfs.",".$minyWfs.",".$maxxWfs.",".$maxyWfs,intval($epsgId[1]),4326);
 						$lonLatBbox = explode(',',$lonLatBbox);
+						//georss needs latitude longitude
 						$featureTypeBboxWGS84[] = $lonLatBbox[1].",".$lonLatBbox[0].",".$lonLatBbox[3].",".$lonLatBbox[2];
 						//switch bbox to lat/lon cause inspire demands ist
@@ -847,6 +849,10 @@
 						$furtherLinkTitle[$m] = $ressourceTitle." im CRS ".$mapbenderMetadata[$i]->metadata_ref_system." - ".$mapbenderMetadata[$i]->format." - Teil ".$currentTileIndex." von ".$numberOfTiles."";
 						//$furtherLinkBbox[$m] = $bboxWms[$m];
 						$furtherLinkBbox[$m] = $bboxWmsWGS84[$m];
+						//exchange lon lat with lat long for georss
+						$newBox = explode(',',$furtherLinkBbox[$m]);
+						$newBox = $newBox[1].",".$newBox[0].",".$newBox[3].",".$newBox[2];
 						//generate content link
 						$feedEntryLink = $feedDoc->createElement("link");
 						$feedEntryLink->setAttribute("rel", "section");
@@ -854,7 +860,7 @@
 						$feedEntryLink->setAttribute("type", $furtherLinkType[$m]);
 						$feedEntryLink->setAttribute("hreflang", "de");
 						$feedEntryLink->setAttribute("title", $furtherLinkTitle[$m]);
-						$feedEntryLink->setAttribute("bbox", $furtherLinkBbox[$m]);
+						$feedEntryLink->setAttribute("bbox", $newBox);
 						$feedEntry->appendChild($feedEntryLink);
 				break;
@@ -995,12 +1001,14 @@
 	//$e = new mb_exception(count($arrayBbox));
 	//$e = new mb_exception($arrayBbox[0]);
 	$sql = "select asewkt(transform(GeometryFromText ( 'LINESTRING ( ".$arrayBbox[0]." ".$arrayBbox[1].",".$arrayBbox[2]." ".$arrayBbox[3]." )', $fromCRS ),".intval($toCRS)."))";
+	//$e = new mb_exception("inspireDownload sql transform: ".$sql);
 	//$sql = "select asewkt(transform(GeometryFromText ( 'LINESTRING ( $1 $2, $3 $4 )', $5 ),$6))";
 	//$v = array($arrayBbox[0],$arrayBbox[1],$arrayBbox[2],$arrayBbox[3],$fromCRS,$toCRS);
 	//$t = array('s','s','s','s','i','i');
 	$res = db_query($sql,$v,$t);
 	//read out result
 	$textBbox = db_fetch_row($res);
+	//$e = new mb_exception("inspireDownload sql result: ".$textBbox[0]);
 	$pattern = '~LINESTRING\((.*)\)~i';
 	preg_match($pattern, $textBbox[0], $subpattern);
 	//exchange blancs
Added: trunk/mapbender/http/plugins/mb_downloadFeedClient.php
--- trunk/mapbender/http/plugins/mb_downloadFeedClient.php	                        (rev 0)
+++ trunk/mapbender/http/plugins/mb_downloadFeedClient.php	2012-08-08 15:19:06 UTC (rev 8450)
@@ -0,0 +1,138 @@
+<?php
+	//http://localhost/mapbender_trunk/plugins/mb_downloadFeedClient.php
+	require_once dirname(__FILE__) . "/../../core/globalSettings.php";
+	require_once dirname(__FILE__) . "/../classes/class_user.php";
+<html>
+<head>
+<title>INSPIRE ATOM Feed Client</title>
+<meta name="description" content="INSPIRE ATOM Feed Client" xml:lang="en" />
+<meta name="keywords" content="INSPIRE SDI GDI Download" xml:lang="en" />
+<meta http-equiv="cache-control" content="no-cache">
+<meta http-equiv="pragma" content="no-cache">
+<meta http-equiv="expires" content="0">
+<meta http-equiv="content-language" content="en" />
+<meta http-equiv="content-style-type" content="text/css" />
+<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
+	<link rel="stylesheet" href="../extensions/OpenLayers-2.9.1/theme/default/style.css" type="text/css">
+	<style type="text/css">
+        input, select, textarea {
+            font: 0.9em Verdana, Arial, sans-serif;
+        #leftcol {
+            position: absolute;
+            top: 0;
+            left: 1em;
+            padding: 0;
+            width: 517px;
+        #mapframe_dataset_list {
+            width: 325px;
+            height: 225px;
+            border: 1px solid #ccc;
+        #mapframe_file_list {
+            width: 325px;
+            height: 225px;
+	#section_list {
+		position: relative;
+		top: 0;
+		left: 0;
+		width: 325px;
+            	height: 225px;
+        #input {
+            width: 512px;
+        #text {
+            font-size: 0.85em;
+            margin: 1em 0 1em 0;
+            width: 100%;
+            height: 10em;
+        #info {
+            padding: 2em 0;
+            margin-left: 540px;
+        #output {
+            font-size: 0.8em;
+            width: 100%;
+            height: 512px;
+            border: 0;
+        p {
+            margin: 0;
+            padding: 0.75em 0 0.75em 0;
+    </style>
+    	<!--<script src="../extensions/OpenLayers-2.9.1/OpenLayers.js"></script>-->
+	<script src="http://openlayers.org/api/OpenLayers.js"></script>
+	<script src="../extensions/jquery-ui-1.8.16.custom/js/jquery-1.6.2.min.js"></script>
+	<script src="../extensions/jquery-ui-1.8.16.custom/js/jquery-ui-1.8.16.custom.min.js"></script>
+	<script src="../javascripts/mb_downloadFeedClient.js"></script>
+</head>
+<body onload="init()">
+<fieldset>
+	<legend><?php echo _mb("INSPIRE Download Service ATOM Feed Client");?><img class="help-dialog" title="<?php echo _mb("Help");?>" help="{text:'<?php echo _mb("Client to download INSPIRE data on an easy way.");?>'}" src="../img/questionmark.png" alt="" /></legend>
+	<p>
+		<form id="service_feed_form">
+		<label for="download_feed_url"><?php echo _mb("ATOM Feed url");?></label>
+		<input name="download_feed_url" id="download_feed_url" class="required"/><input type="button" title="Get Feed" id="download_feed_button" value="Get Feed Content"/>
+		</form>
+	</p>
+	<fieldset>
+		<legend><?php echo _mb("Select dataset");?><img class="help-dialog" title="<?php echo _mb("Help");?>" help="{text:'<?php echo _mb("Select single dataset either in list or on map");?>'}" src="../img/questionmark.png" alt="" /></legend>
+		<div id="mapframe_dataset_list"></div>
+		<div id="dataset_list"></div>
+		<!--<label for="dataset_list"><?php echo _mb("List of datasets");?>:</label>
+		<select name="dataset_list" id="dataset_list" onChange="var choosenoption=this.options[this.selectedIndex];display_dataset(choosenoption.value);">
+			<option value="0">...</option>
+		</select>-->
+	</fieldset>
+<fieldset>
+	<legend><?php echo _mb("Dataset Feed entries");?><img class="help-dialog" title="<?php echo _mb("Help");?>" help="{text:'<?php echo _mb("The fieldset shows the content of the INSPIRE Download Service service-feed document. It contains one or more links to different datasets.");?>'}" src="../img/questionmark.png" alt="" /></legend>
+	<p>
+		<label for="dataset_title"><?php echo _mb("Dataset title");?>:</label>
+		<input readonly="readonly" name="dataset_title" id="dataset_title"/>
+	</p>
+	<p>
+		<label for="resource_identifier"><?php echo _mb("Resource identifier");?>:</label>
+		<input readonly="readonly" name="resource_identifier" id="resource_identifier"/>
+	</p>
+	<p>
+		<label for="dataset_rights"><?php echo _mb("Rights");?>:</label>
+		<input readonly="readonly" name="dataset_rights" id="dataset_rights"/>
+	</p>
+	<p>
+		<label for="representations"><?php echo _mb("Available representations");?>:</label>
+		<div id="dataset_representation_list"></div>
+	</p>
+</fieldset>
+<fieldset>
+	<legend><?php echo _mb("Files");?><img class="help-dialog" title="<?php echo _mb("Help");?>" help="{text:'<?php echo _mb("Files which can be downloaded");?>'}" src="../img/questionmark.png" alt="" /></legend>
+	<div>
+		<input id="multi_select" type="checkbox" disabled><?php echo _mb("Select multiple tiles");?></input><br>
+		<label for="mapframe_file_list"><?php echo _mb("Position of files (if available)");?>:</label>
+		<!--<input type="list" id="file_list"/>-->
+		<div id="mapframe_file_list"></div>
+		<label for="section_list"><?php echo _mb("List of files");?>:</label>
+		<div id="section_list">
+			<select id="section_file_list" multiple='multiple'></div>
+		</div>
+	</div>
+	<input type="button" title="Download selected files" value="Download selection"/>
+</fieldset>
+</body>
+</html>
Added: trunk/mapbender/http/plugins/mb_downloadFeedServer.php
--- trunk/mapbender/http/plugins/mb_downloadFeedServer.php	                        (rev 0)
+++ trunk/mapbender/http/plugins/mb_downloadFeedServer.php	2012-08-08 15:19:06 UTC (rev 8450)
@@ -0,0 +1,209 @@
+<?php
+	//http://localhost/mapbender_trunk/plugins/mb_downloadFeedServer.php
+	require_once dirname(__FILE__) . "/../classes/class_connector.php";
+	require_once(dirname(__FILE__)."/../classes/class_json.php");
+	require_once(dirname(__FILE__)."/../classes/class_gml2.php");
+	require_once(dirname(__FILE__)."/../classes/class_georss_geometry.php");
+	require_once(dirname(__FILE__)."/../classes/class_Uuid.php");
+/*	$ajaxResponse = new AjaxResponse($_POST);
+	function abort ($message) {
+		global $ajaxResponse;
+		$ajaxResponse->setSuccess(false);
+		$ajaxResponse->setMessage($message);
+		$ajaxResponse->send();
+		die;
+	function getServiceFeedObjectFromUrl () {
+		//define default resultObj
+		$resultObj = array(
+			"original_layer_title" => "",
+			"original_layer_abstract" => "",
+			"original_layer_keyword" => ""
+		return $resultObj;
+class geoRSSEntry extends Feature{
+	public function parse($entry, $itemsToImport) {
+		$tag = $currentSibling->nodeName;
+		if(in_array($tag, $importItems)){
+			$this->properties[$tag] = $currentSibling->nodeValue;
+		else{
+			switch ($tag) {
+			case "georss:polygon":
+				$this->geometry = new geoRSSPolygon();
+				$this->geometry->targetEPSG = $this->targetEPSG;
+				$this->geometry->parsePolygon($currentSibling);
+				break;
+			default:
+				break;
+switch ($_REQUEST['method']) {
+	case "getServiceFeedObjectFromUrl" :
+		$serviceFeedUrl = $_REQUEST['url'];
+		//test url
+		//get feed from remote server
+		$feedConnector = new connector($serviceFeedUrl);
+		$feedConnector->set("timeOut", "5");
+		$feedFile = $feedConnector->file;
+		//$mbMetadata = $this->createMapbenderMetadataFromXML($xml);
+		//parse content
+		//$e = new mb_exception($feedFile);
+		libxml_use_internal_errors(true);
+		try {
+			$feedXML = simplexml_load_string($feedFile);
+			if ($feedXML === false) {
+				foreach(libxml_get_errors() as $error) {
+        				$err = new mb_exception("downloadFeedServer.php:".$error->message);
+				throw new Exception("downloadFeedServer.php:".'Cannot parse Feed!');
+				return false;
+		catch (Exception $e) {
+    			$err = new mb_exception("downloadFeedServer.php:".$e->getMessage());
+			return false;
+		//$e = new mb_exception($feedXML->file);
+		if ($feedXML != false) {
+			$feedXML->registerXPathNamespace("georss", "http://www.georss.org/georss");
+			$feedXML->registerXPathNamespace("inspire_dls", "http://inspire.ec.europa.eu/schemas/inspire_dls/1.0");
+			$feedXML->registerXPathNamespace("defaultns", "http://www.w3.org/2005/Atom");
+			$title = $feedXML->xpath('/defaultns:feed/defaultns:entry/defaultns:title');
+			$rights = $feedXML->xpath('/defaultns:feed/defaultns:entry/defaultns:rights');
+			$bbox = $feedXML->xpath('/defaultns:feed/defaultns:entry/georss:polygon');
+			$metadataLink = $feedXML->xpath('/defaultns:feed/defaultns:entry/defaultns:link[contains(@rel,\'describedby\')]/@href');
+			$datasetFeedLink = $feedXML->xpath('/defaultns:feed/defaultns:entry/defaultns:link[contains(@rel,\'alternate\')]/@href');
+			//new feature collection
+			$featureCollection = new FeatureCollection;
+			for ($i=0; $i<=(count($title)-1); $i++) {
+				$feature = new Feature;
+				$uuid = new Uuid;
+				$feature->fid = $uuid;
+				$titleArray = (array)$title[$i];
+				$rightsArray = (array)$rights[$i];
+				$bboxArray = (array)$bbox[$i];
+				$mdLinkArray = (array)$metadataLink[$i];
+				$mdLinkArray = $mdLinkArray["@attributes"];
+				$dsLinkArray = (array)$datasetFeedLink[$i];
+				$dsLinkArray = $dsLinkArray["@attributes"];
+				$feature->properties["title"] = $titleArray[0];
+				$feature->properties["rights"] = $rightsArray[0];
+				$feature->properties["metadataLink"] = $mdLinkArray["href"];
+				$feature->properties["datasetFeedLink"] = $dsLinkArray["href"];
+				$feature->geometry = new geoRSSPolygon();
+				$feature->geometry->parsePolygon($bboxArray[0]);
+				//$feature->geometry->targetEPSG = "EPSG:4326";
+				if (isset($feature->geometry) && $feature->geometry!==false) {
+					$featureCollection->addFeature($feature);
+					$e = new mb_notice("Feature added to collection!");
+		echo $featureCollection->toGeoJSON();
+		break;
+	case "getDatasetFeedObjectFromUrl" :
+		$datasetFeedUrl = $_REQUEST['url'];
+		//test url
+		$feedConnector = new connector($datasetFeedUrl);
+		//parse content
+		try {
+				return false;
+			return false;
+			//$link = $feedXML->xpath('/defaultns:feed/defaultns:entry/defaultns:link[contains(@rel,\'section\')]/@bbox');
+			//$datasetFeedLink = $feedXML->xpath('/defaultns:feed/defaultns:entry/defaultns:link[contains(@rel,\'alternate\')]/@href');
+				$uuid = new Uuid;
+				$entry = $feedXML->xpath('/defaultns:feed/defaultns:entry');
+				$feature->properties["entry"] = array();
+				for ($j=0; $j<=(count($entry)-1); $j++) {
+					$feature->properties["entry"][$j] = $entry[$j];
+				$link = $feedXML->xpath('/defaultns:feed/defaultns:entry/defaultns:link[contains(@rel,\'section\')]/@bbox');
+				/*$titleArray = (array)$title[$i];
+				$linkArray = (array)$link[$i];
+				$linkArray = $linkArray["@attributes"];
+				$bbox = $linkArray["bbox"];
+				//$e = new mb_exception($bbox);
+				//$feature->properties["metadataLink"] = $mdLinkArray["href"];
+				//$feature->properties["datasetFeedLink"] = $dsLinkArray["href"];
+				$feature->geometry->parsePolygon($bbox);
+		break;
+	default:
+		echo json_encode("Kein Treffer!");
+		break;
More information about the Mapbender_commits mailing list
