[Mapbender-commits] r8507 - in trunk/mapbender/http: classes php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Nov 19 07:23:35 PST 2012
Author: armin11
Date: 2012-11-19 07:23:35 -0800 (Mon, 19 Nov 2012)
New Revision: 8507
   trunk/mapbender/http/classes/class_metadata_new.php
   trunk/mapbender/http/php/mod_callMetadata.php
   trunk/mapbender/http/php/mod_inspireDownloadFeed.php
   trunk/mapbender/http/php/mod_metadataWrite.php
Extent searchInterface to give an optional parameter for the resource ids (layer,featuretype, wmc). Bugfix for INSPIRE Download Atom feeds.
Modified: trunk/mapbender/http/classes/class_metadata_new.php
--- trunk/mapbender/http/classes/class_metadata_new.php	2012-11-12 14:53:37 UTC (rev 8506)
+++ trunk/mapbender/http/classes/class_metadata_new.php	2012-11-19 15:23:35 UTC (rev 8507)
@@ -57,8 +57,9 @@
 	var $tempFolder;
 	var $orderBy;
 	var $hostName;
+	var $resourceIds;
-	function __construct($userId, $searchId, $searchText, $registratingDepartments, $isoCategories, $inspireThemes, $timeBegin, $timeEnd, $regTimeBegin, $regTimeEnd, $maxResults, $searchBbox, $searchTypeBbox, $accessRestrictions, $languageCode, $searchEPSG, $searchResources, $searchPages, $outputFormat, $resultTarget, $searchURL, $customCategories, $hostName, $orderBy){
+	function __construct($userId, $searchId, $searchText, $registratingDepartments, $isoCategories, $inspireThemes, $timeBegin, $timeEnd, $regTimeBegin, $regTimeEnd, $maxResults, $searchBbox, $searchTypeBbox, $accessRestrictions, $languageCode, $searchEPSG, $searchResources, $searchPages, $outputFormat, $resultTarget, $searchURL, $customCategories, $hostName, $orderBy, $resourceIds){
 		$this->userId = (integer)$userId;
 		$this->searchId = $searchId;
 		$this->searchText = $searchText;
@@ -84,6 +85,7 @@
 		$this->searchURL = $searchURL;
 		$this->hostName = $hostName;
 		$this->orderBy = $orderBy;
+		$this->resourceIds = $resourceIds;
 		//definitions for generating tagClouds
 		$this->maxObjects = 15;
 		$this->maxFontSize = 30;
@@ -992,6 +994,12 @@
 			$dep = " department IN (".$this->registratingDepartments.") ";
 			array_push($whereCondArray, $dep);
+		//resourceId conditions
+		if($this->resourceIds != NULL){
+			$resourceCondition = " ".$this->databaseIdColumnName." IN (".$this->resourceIds.") ";
+			array_push($whereCondArray, $resourceCondition);
 		// Creating the WHERE clause, based on a array
 		if(count($whereCondArray) > 0){
 			$txt_whereCond = "";
Modified: trunk/mapbender/http/php/mod_callMetadata.php
--- trunk/mapbender/http/php/mod_callMetadata.php	2012-11-12 14:53:37 UTC (rev 8506)
+++ trunk/mapbender/http/php/mod_callMetadata.php	2012-11-19 15:23:35 UTC (rev 8507)
@@ -41,6 +41,8 @@
 #$searchResources = "wms,wfs,wmc,georss";
 #$searchResources = "wms";
 $searchPages = "1";
+$resourceIds = NULL; //resourceIds is used to get a comma separated list with ids of the resources - layer - featuretypes - wmc
+//it will be used to filter some results
 $resultTarget = "debug";
 $preDefinedMaxResults = array(5,10,15,20,25,30);
 $searchEPSG = "EPSG:31466";
@@ -56,7 +58,7 @@
 $searchURL = urldecode($searchURL);
 //control if some request variables are not set and set them explicit to NULL
-$checkForNullRequests = array("registratingDepartments","isoCategories","inspireThemes","customCategories","regTimeBegin","regTimeEnd","timeBegin","timeEnd","searchBbox","searchTypeBbox","searchResources","orderBy","hostName");
+$checkForNullRequests = array("registratingDepartments","isoCategories","inspireThemes","customCategories","regTimeBegin","regTimeEnd","timeBegin","timeEnd","searchBbox","searchTypeBbox","searchResources","orderBy","hostName","resourceIds");
 for($i=0; $i < count($checkForNullRequests); $i++){
 	if (!$_REQUEST[$checkForNullRequests[$i]] or $_REQUEST[$checkForNullRequests[$i]] == 'false' or $_REQUEST[$checkForNullRequests[$i]] == 'undefined') {
@@ -96,6 +98,17 @@
 	$registratingDepartments = $testMatch;
 	$testMatch = NULL;
+if (isset($_REQUEST["resourceIds"]) & $_REQUEST["resourceIds"] != "") {
+	//validate to csv integer list
+	$testMatch = $_REQUEST["resourceIds"];
+	$pattern = '/^[\d,]*$/';
+ 	if (!preg_match($pattern,$testMatch)){
+		echo 'resourceIds: <b>'.$testMatch.'</b> is not valid.<br/>';
+		die();
+	$resourceIds = $testMatch;
+	$testMatch = NULL;
 if (isset($_REQUEST["isoCategories"]) & $_REQUEST["isoCategories"] != "") {
 	$testMatch = $_REQUEST["isoCategories"];
@@ -939,6 +952,7 @@
 		$str .= "'".$customCategories."' ";
 		$str .= "'".$hostName."' ";
 		$str .= "'".$orderBy."' ";
+		$str .= "'".$resourceIds."' ";
 		$str .= " & ";
 		$e = new mb_notice($str);
 		exec($str);
@@ -946,7 +960,7 @@
 if ($resultTarget == 'web' or $resultTarget == 'debug' or $resultTarget == 'webclient') {
 	if (count($searchResources) == 1) {
-		$metadata = new searchMetadata($userId, $searchId, $searchText, $registratingDepartments, $isoCategories, $inspireThemes, $timeBegin, $timeEnd, $regTimeBegin, $regTimeEnd, $maxResults, $searchBbox, $searchTypeBbox, $accessRestrictions, $languageCode, $searchEPSG, $searchResources[0], $searchPages[0], $outputFormat, $resultTarget, $searchURL, $customCategories, $hostName, $orderBy);
+		$metadata = new searchMetadata($userId, $searchId, $searchText, $registratingDepartments, $isoCategories, $inspireThemes, $timeBegin, $timeEnd, $regTimeBegin, $regTimeEnd, $maxResults, $searchBbox, $searchTypeBbox, $accessRestrictions, $languageCode, $searchEPSG, $searchResources[0], $searchPages[0], $outputFormat, $resultTarget, $searchURL, $customCategories, $hostName, $orderBy, $resourceIds);
 		#if ($outputFormat == 'xml') {
 		#	header("Content-type: application/xhtml+xml; charset=UTF-8");
Modified: trunk/mapbender/http/php/mod_inspireDownloadFeed.php
--- trunk/mapbender/http/php/mod_inspireDownloadFeed.php	2012-11-12 14:53:37 UTC (rev 8506)
+++ trunk/mapbender/http/php/mod_inspireDownloadFeed.php	2012-11-19 15:23:35 UTC (rev 8507)
@@ -937,7 +937,11 @@
 						$newBox = $newBox[1].",".$newBox[0].",".$newBox[3].",".$newBox[2];
 						//generate content link
 						$feedEntryLink = $feedDoc->createElement("link");
-						$feedEntryLink->setAttribute("rel", "section");
+						if ($numberOfTiles > 1) {
+							$feedEntryLink->setAttribute("rel", "section");
+						} else {
+							$feedEntryLink->setAttribute("rel", "alternate");
 						$feedEntryLink->setAttribute("href", $furtherLink[$m]);
 						$feedEntryLink->setAttribute("type", $furtherLinkType[$m]);
 						$feedEntryLink->setAttribute("hreflang", "de");
@@ -955,6 +959,12 @@
 					$furtherLinkBbox = array();
 					//loop for each featuretype
 					$e = new mb_notice("Count of wfs links: ".count($getFeatureLink));
+					if (count($getFeatureLink) > 1) {
+						$feedEntryContent = $feedDoc->createElement("content");
+						$feedEntryContentText = $feedDoc->createTextNode("Datensatz wird in  in ".count($getFeatureLink)." einzelnen Teilen ausgeliefert.");
+						$feedEntryContent->appendChild($feedEntryContentText);
+						$feedEntry->appendChild($feedEntryContent);
 					for ($m = 0; $m < count($getFeatureLink); $m++ ) {
 						$furtherLink[$m] = $getFeatureLink[$m];//was computed before
 						$furtherLinkType[$m] = "text/xml; subtype=gml/3.1.1";//TODO: set right format for wfs version!
@@ -964,7 +974,11 @@
 						$furtherLinkBbox[$m] = $featureTypeBboxWGS84[$m];
 						//generate content links
+						} else {
Modified: trunk/mapbender/http/php/mod_metadataWrite.php
--- trunk/mapbender/http/php/mod_metadataWrite.php	2012-11-12 14:53:37 UTC (rev 8506)
+++ trunk/mapbender/http/php/mod_metadataWrite.php	2012-11-19 15:23:35 UTC (rev 8507)
@@ -24,6 +24,7 @@
 $customCategories = $_SERVER["argv"][22];
 $hostName = $_SERVER["argv"][23];
 $orderBy = $_SERVER["argv"][24];
+$resourceIds = $_SERVER["argv"][25];
-$metadata = new searchMetadata($userId, $searchId, $searchText, $registratingDepartments, $isoCategories, $inspireThemes, $timeBegin, $timeEnd, $regTimeBegin, $regTimeEnd, $maxResults, $searchBbox, $searchTypeBbox, $accessRestrictions, $languageCode, $searchEPSG, $searchResources, $searchPages, $outputFormat, $resultTarget, $searchURL, $customCategories, $hostName, $orderBy);
+$metadata = new searchMetadata($userId, $searchId, $searchText, $registratingDepartments, $isoCategories, $inspireThemes, $timeBegin, $timeEnd, $regTimeBegin, $regTimeEnd, $maxResults, $searchBbox, $searchTypeBbox, $accessRestrictions, $languageCode, $searchEPSG, $searchResources, $searchPages, $outputFormat, $resultTarget, $searchURL, $customCategories, $hostName, $orderBy, $resourceIds);
More information about the Mapbender_commits mailing list
