[Mapbender-commits] r8508 - in trunk/mapbender/http: geoportal img/osgeo_graphics/geosilk php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Nov 20 07:09:01 PST 2012
Author: armin11
Date: 2012-11-20 07:09:00 -0800 (Tue, 20 Nov 2012)
New Revision: 8508
Added:
   trunk/mapbender/http/img/osgeo_graphics/geosilk/raster_download.png
   trunk/mapbender/http/img/osgeo_graphics/geosilk/vector_download.png
   trunk/mapbender/http/php/mod_getDownloadOptions.php
   trunk/mapbender/http/geoportal/mod_readCSWResultsDetail.php
   trunk/mapbender/http/php/mod_dataISOMetadata.php
   trunk/mapbender/http/php/mod_getWmcDisclaimer.php
   trunk/mapbender/http/php/mod_showMetadata.php
Some updates for INSPIRE Download Services via mapbender proxy - not yet ready. Bugfixes for INSPIRE validator - changed url!
Modified: trunk/mapbender/http/geoportal/mod_readCSWResultsDetail.php
--- trunk/mapbender/http/geoportal/mod_readCSWResultsDetail.php	2012-11-19 15:23:35 UTC (rev 8507)
+++ trunk/mapbender/http/geoportal/mod_readCSWResultsDetail.php	2012-11-20 15:09:00 UTC (rev 8508)
@@ -106,7 +106,7 @@
 //function to validate against the inspire validation service
 function validateInspireMetadataFromData($iso19139Xml){
-	$validatorUrl = 'http://www.inspire-geoportal.eu/INSPIREValidatorService/resources/validation/inspire';
+	$validatorUrl = 'http://inspire-geoportal.ec.europa.eu/INSPIREValidatorService/resources/validation/inspire';
 	#$validatorUrl2 = 'http://localhost/mapbender/x_geoportal/log_requests.php'; //for debugging purposes
 	//send inspire xml to validator and push the result to requesting user
 	$validatorInterfaceObject = new connector();
Added: trunk/mapbender/http/img/osgeo_graphics/geosilk/raster_download.png
(Binary files differ)
Property changes on: trunk/mapbender/http/img/osgeo_graphics/geosilk/raster_download.png
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Added: trunk/mapbender/http/img/osgeo_graphics/geosilk/vector_download.png
Property changes on: trunk/mapbender/http/img/osgeo_graphics/geosilk/vector_download.png
Modified: trunk/mapbender/http/php/mod_dataISOMetadata.php
--- trunk/mapbender/http/php/mod_dataISOMetadata.php	2012-11-19 15:23:35 UTC (rev 8507)
+++ trunk/mapbender/http/php/mod_dataISOMetadata.php	2012-11-20 15:09:00 UTC (rev 8508)
@@ -1420,7 +1420,7 @@
 	function validateInspireMetadata($iso19139Doc, $recordId){
@@ -1465,7 +1465,7 @@
Added: trunk/mapbender/http/php/mod_getDownloadOptions.php
--- trunk/mapbender/http/php/mod_getDownloadOptions.php	                        (rev 0)
+++ trunk/mapbender/http/php/mod_getDownloadOptions.php	2012-11-20 15:09:00 UTC (rev 8508)
@@ -0,0 +1,113 @@
+<?php
+//2012-11-20-http://localhost/mapbender_trunk/php/mod_getDownloadOptions.php?id=70e0c3e5-707c-f8e1-8037-7b38702176d9&output=xml
+//http://localhost/mapbender_trunk/php/mod_getDownloadOptions.php?id=0a8b7dc8-b198-aac5-9713-79b623a6e651,0395ee4a-f27f-7e71-fc17-65498ffa991c
+// http://www.mapbender.org/index.php/
+// Copyright (C) 2002 CCGIS
+// This program is free software; you can redistribute it and/or modify
+// it under the terms of the GNU General Public License as published by
+// the Free Software Foundation; either version 2, or (at your option)
+// any later version.
+// This program is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+// GNU General Public License for more details.
+// You should have received a copy of the GNU General Public License
+// along with this program; if not, write to the Free Software
+// Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+//Script for pulling all download options for one or more metadataset which are identified by their fileidentifier
+require_once(dirname(__FILE__) . "/../../core/globalSettings.php");
+//require_once(dirname(__FILE__) . "/../classes/class_connector.php");
+//require_once(dirname(__FILE__) . "/../classes/class_administration.php");
+//require_once dirname(__FILE__) . "/../../core/epsg.php";
+require_once(dirname(__FILE__) . "/../classes/class_Uuid.php");
+//make all parameters available as upper case
+foreach($_REQUEST as $key => $val) {
+	$_REQUEST[strtoupper($key)] = $val;
+//validate request params
+if (isset($_REQUEST['ID']) & $_REQUEST['ID'] != "") {
+	//validate cs list of uuids or other identifiers - which?
+	$testMatch = $_REQUEST["ID"];
+	//$uuid = new Uuid($testMatch);
+	//$isUuid = $uuid->isValid();
+	$idList = explode(',',$_REQUEST['ID']);
+	for ($i = 0; $i < count($idList); $i++) {
+		$testMatch = $idList[$i];
+		$uuid = new Uuid($testMatch);
+		$isUuid = $uuid->isValid();
+		if (!$isUuid) {
+			echo 'Id: <b>'.$testMatch.'</b> is not a valid uuid (12-4-4-4-8)!<br/>';
+			die();
+	$testMatch = NULL;
+//define query to pull all download options - actually only the inspire download services based on atom feeds
+$sql = "select service_id, resource_id, resource_type, fkey_datalink_id as datalink from (select fkey_wms_id as service_id, layer_id as resource_id, 'layer' as resource_type from layer inner join (select metadata_id, uuid, fkey_layer_id from mb_metadata inner join ows_relation_metadata on ows_relation_metadata.fkey_metadata_id = mb_metadata.metadata_id) ";
+$sql .= "as metadata_relation on metadata_relation.fkey_layer_id = layer.layer_id where layer.inspire_download = 1 and metadata_relation.uuid = $1) as layer_metadata LEFT OUTER JOIN ows_relation_data ON layer_metadata.resource_id = ows_relation_data.fkey_layer_id union select fkey_wfs_id as service_id, featuretype_id as resource_id, 'wfs' as resource_type, NULL ";
+$sql .= "as datalink from (select wfs_featuretype.featuretype_id ,wfs_featuretype.fkey_wfs_id,  wfs_featuretype.inspire_download from wfs_featuretype WHERE inspire_download = 1 ORDER BY featuretype_id) as featuretype_inspire inner join (select metadata_id, uuid, fkey_featuretype_id from mb_metadata inner join ows_relation_metadata on ";
+$sql .= "ows_relation_metadata.fkey_metadata_id = mb_metadata.metadata_id) as metadata_relation on metadata_relation.fkey_featuretype_id = featuretype_inspire.featuretype_id and metadata_relation.uuid = $1;";
+//initialize array for result
+for ($i = 0; $i < count($idList); $i++) {
+	$v = array($idList[$i]);
+	$t = array('s');
+	$res = db_prep_query($sql,$v,$t);
+	//problem, $res don't give back false if it was not successful!
+	//push rows into associative array
+	$j = 0;
+	while ($row = db_fetch_assoc($res)) {
+		//echo "j: ".$j."<br>";
+		switch ($row['resource_type']) {
+			case "wfs":
+				$serviceIdIndex = false;
+				for ($k = 0; $k < count($downloadOptions->{$idList[$i]}->option); $k++) {
+					//echo "k: ".$k."<br>";
+					//echo "service_id: ".$row['service_id']." - searched Id: ".$downloadOptions->{$idList[$i]}->option[$k]->serviceId."<br>";
+					if ($row['service_id'] == $downloadOptions->{$idList[$i]}->option[$k]->serviceId) {
+						//service_id found at index $k
+						$serviceIdIndex = $k;
+						//echo "Service already found on index: ".$serviceIdIndex."<br>";
+				if ($serviceIdIndex !== false) {
+					//echo "Add featuretype to given service: ".$serviceIdIndex."<br>";
+					//old wfs has been found
+					//get count of current fts
+					$m = count($downloadOptions->{$idList[$i]}->option[$serviceIdIndex]->featureType);
+					//echo "m: ".$m."<br>";
+					$downloadOptions->{$idList[$i]}->option[$serviceIdIndex]->featureType[$m] = $row['resource_id'];
+				} else {
+					$downloadOptions->{$idList[$i]}->option[$j]->type = "wfsrequest";
+					$downloadOptions->{$idList[$i]}->option[$j]->serviceId = $row['service_id'];
+					$downloadOptions->{$idList[$i]}->option[$j]->featureType[0] = $row['resource_id'];
+			break;
+			case "layer":
+				if (!isset($row['datalink'] ) || $row['datalink'] == '') {
+					$downloadOptions->{$idList[$i]}->option[$j]->type = "wmslayergetmap";
+				} else {
+					$downloadOptions->{$idList[$i]}->option[$j]->type = "wmslayerdataurl";
+				$downloadOptions->{$idList[$i]}->option[$j]->resourceId = $row['resource_id'];
+				$downloadOptions->{$idList[$i]}->option[$j]->dataLink = $row['datalink'];
+			break;
+	$j++;
+$result = json_encode($downloadOptions);
+echo $result;
Modified: trunk/mapbender/http/php/mod_getWmcDisclaimer.php
--- trunk/mapbender/http/php/mod_getWmcDisclaimer.php	2012-11-19 15:23:35 UTC (rev 8507)
+++ trunk/mapbender/http/php/mod_getWmcDisclaimer.php	2012-11-20 15:09:00 UTC (rev 8508)
@@ -81,15 +81,6 @@
 		$translation['wfs'] = "Web Feature Service";
 		$translation['noTouInformation'] = 'No informations about terms of use are available!';
 //javascript:openwindow("../php/mod_showMetadata.php?resource=layer&layout=tabs&redirectToMetadataUrl=1&id=20655");
 //Generate wmc document by id
 $wmcFactory = new WmcFactory;
@@ -115,8 +106,8 @@
 for ($i = 0; $i < $countWMS; $i++) {
 	$WMS = $validWMS[$countWMS - ($i+1)];
 	echo $resourceSymbol." <a href='".$mapbenderBaseUrl.$_SERVER['SCRIPT_NAME']."/../mod_showMetadata.php?resource=wms&layout=tabs&id=".$WMS['id']."&languageCode=".$languageCode."'>".$WMS['title']."</a><br>";
-	$touServiceConnector = new connector($mapbenderProtocol."localhost".$_SERVER['SCRIPT_NAME']."/../mod_getServiceDisclaimer.php?type=wms&id=".$WMS['id']."&languageCode=".$languageCode."&asTable=true");
+	//all local connections are without ssl
+	$touServiceConnector = new connector("http://localhost".$_SERVER['SCRIPT_NAME']."/../mod_getServiceDisclaimer.php?type=wms&id=".$WMS['id']."&languageCode=".$languageCode."&asTable=true");
 	$touForWMS = $touServiceConnector->file;
 	if ($touForWMS == ''){
@@ -131,12 +122,9 @@
 //var_dump($validWMS);
 //module to read out all service ids which are stored in mapbender wmc documents and generate a Big Disclaimer for those Docs.
 //It integrates all known disclaimers for the used webservices who are stored in the mapbender registry
 //read out all wms id's
 //read out all wfs id's
 //generate the disclaimer part for wms
 //generate the disclaimer part for wfs
 //push disclaimer to json or html
Modified: trunk/mapbender/http/php/mod_showMetadata.php
--- trunk/mapbender/http/php/mod_showMetadata.php	2012-11-19 15:23:35 UTC (rev 8507)
+++ trunk/mapbender/http/php/mod_showMetadata.php	2012-11-20 15:09:00 UTC (rev 8508)
@@ -200,6 +200,9 @@
 		$translation['Coupled Metadata'] = "Verknüpfte Metadaten";
 		$translation['addLayerToMap'] = "Karte im eigenen Viewer anzeigen";
 		$translation['showMap'] = "Karte anzeigen";
+		$translation['Download GML data from INSPIRE Download Service'] = "Download von GML-Daten über INSPIRE Downloaddienst";
+		$translation['Download raster data from INSPIRE Download Service'] = "Download von Rasterdaten über INSPIRE Downloaddienst";
 		break;
 	case "en":
 		$translation['overview'] = 'Overview';
@@ -274,6 +277,8 @@
 		$translation['Coupled Metadata'] = "Coupled Metadata";
 		$translation['addLayerToMap'] = "Show map in own viewer";
 		$translation['showMap'] = "Show map";
+		$translation['Download GML data from INSPIRE Download Service'] = "Download GML data from INSPIRE Download Service";
+		$translation['Download raster data from INSPIRE Download Service'] = "Download raster data from INSPIRE Download Service";
 		break;
 	case "fr":
 		$translation['overview'] = 'Vue générale';
@@ -348,6 +353,8 @@
 		$translation['Coupled Metadata'] = "Métadonnées couplées";
 		$translation['addLayerToMap'] = "Ouvrir la carte dans sa propre fenêtre";
 		$translation['showMap'] = "Ouvrir la carte";
 		break;
 	default: #to english
@@ -422,6 +429,8 @@
 //Array with infos about the different elements which are shown in the tabs
@@ -1058,26 +1067,25 @@
 	IN('capabilities','external','metador','upload')
 SQL;
 	$res = db_query($sql);
 	$i = 0;
 	$metadataList = "";
 		//check for existing download options
-		$sqlDownload = <<<SQL
+		/*$sqlDownload = <<<SQL
 		select count(*) from (select metadata_id as data from (select metadata_id, layer_id from (select fkey_metadata_id, layer_id from layer inner join ows_relation_metadata on layer.layer_id = ows_relation_metadata.fkey_layer_id) as layer_relation
  inner join mb_metadata on layer_relation.fkey_metadata_id = mb_metadata.metadata_id where mb_metadata.uuid = $1) as layer_metadata inner join ows_relation_data on ows_relation_data.fkey_layer_id = layer_metadata.layer_id union select mb_metadata.metadata_id as data from mb_metadata right join ows_relation_metadata on mb_metadata.metadata_id = ows_relation_metadata.fkey_metadata_id where mb_metadata.uuid = $1) as foo
-SQL;
+SQL;*/
 		select count(*) from (select mb_metadata.metadata_id as data from mb_metadata right join ows_relation_metadata on mb_metadata.metadata_id = ows_relation_metadata.fkey_metadata_id where mb_metadata.uuid = $1) as foo
 SQL;*/
 		//TODO: INSPIRE Download: It must be tested, if inspire_download is set to 1!!
-		$v = array($row["uuid"]);
+/*		$v = array($row["uuid"]);
 		$t = array('s');
 		$resDownload = db_prep_query($sqlDownload,$v,$t);
 		$rowDownload = db_fetch_assoc($resDownload);
 		$e = new mb_notice($rowDownload['count']);
-		$e = new mb_notice($row['uuid']);
+		$e = new mb_notice($row['uuid']);*/
 		//$html .= "<li>";
 		switch ($row["origin"]) {
@@ -1096,10 +1104,26 @@
 			default:
 			break;
+		//Pull download options for specific dataset from mapbender database and show them
+		$downloadOptionsConnector = new connector("http://localhost".$_SERVER['SCRIPT_NAME']."/../mod_getDownloadOptions.php?id=".$row["uuid"]);
+		$downloadOptions = json_decode($downloadOptionsConnector->file);
+		//var_dump($downloadOptions);
 		$metadataList .= "<a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id=".$row["uuid"]."'>".$row["uuid"]."</a> <a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id=".$row["uuid"]."&validate=true'>".$translation['validate']."</a>";
-		if (intval($rowDownload['count']) > 0) {
-			$metadataList .= "<br><a href='../php/mod_inspireDownloadFeed.php?id=".$row["uuid"]."&type=SERVICE&generateFrom=all'>INSPIRE Download Feed</a><br><a href='../plugins/mb_downloadFeedClient.php?url=".urlencode("http://www.geoportal.rlp.de/mapbender/php/mod_inspireDownloadFeed.php?id=".$row["uuid"]."&type=SERVICE&generateFrom=all")."'>INSPIRE Atom feed client prototype</a>";
+		if ($downloadOptions != null) {
+			foreach ($downloadOptions->{$row["uuid"]}->option as $option) {
+				if ($option->type == "wmslayergetmap" || $option->type == "wmslayerdataurl") {
+					//use rastersymbol
+					$metadataList .= "  <a href='../plugins/mb_downloadFeedClient.php?url=".urlencode("http://www.geoportal.rlp.de/mapbender/php/mod_inspireDownloadFeed.php?id=".$row["uuid"]."&type=SERVICE&generateFrom=wmslayer&layerid=".$option->resourceId)."'><img src='../img/osgeo_graphics/geosilk/raster_download.png' title='".$translation['Download raster data from INSPIRE Download Service']."'/></a>";
+				} else {
+					//use vectorsymbol
+					$metadataList .= "  <a href='../plugins/mb_downloadFeedClient.php?url=".urlencode("http://www.geoportal.rlp.de/mapbender/php/mod_inspireDownloadFeed.php?id=".$row["uuid"]."&type=SERVICE&generateFrom=wfs&wfsid=".$option->serviceId)."'><img src='../img/osgeo_graphics/geosilk/vector_download.png' title='".$translation['Download GML data from INSPIRE Download Service']."'/></a>";
 		$metadataList .= "<br>";
 		$i++;
More information about the Mapbender_commits mailing list
