[Mapbender-commits] r8509 - in trunk/mapbender/http: classes img php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Nov 21 23:23:03 PST 2012
Author: verenadiewald
Date: 2012-11-21 23:23:03 -0800 (Wed, 21 Nov 2012)
New Revision: 8509
Added:
   trunk/mapbender/http/img/link_edit.png
   trunk/mapbender/http/php/mb_getWmsData.php
   trunk/mapbender/http/classes/class_wms.php
   trunk/mapbender/http/php/mod_updateWMS.php
new "compare layer names" function for module updateWMS
Modified: trunk/mapbender/http/classes/class_wms.php
--- trunk/mapbender/http/classes/class_wms.php	2012-11-20 15:09:00 UTC (rev 8508)
+++ trunk/mapbender/http/classes/class_wms.php	2012-11-22 07:23:03 UTC (rev 8509)
@@ -1019,6 +1019,20 @@
 			return true;
+	function getLayerInfo() {
+	    $resultArray = array();
+	    for($i=0; $i<count($this->objLayer); $i++){
+	        $resultArray[] = array (
+                //"id" => $this->objLayer[$i]->layer_id,
+                "pos" => $this->objLayer[$i]->layer_pos,
+                //"parent"   => $this->objLayer[$i]->layer_parent,
+                "name"   => $this->objLayer[$i]->layer_name
+                //"title"   => $this->objLayer[$i]->layer_title
+	    return $resultArray;
 	 * private function
@@ -2480,9 +2494,9 @@
-	function updateObjInDB($myWMS,$updateMetadataOnly=false){ //TODO give return true or false to allow feedback to user!!!
+	function updateObjInDB($myWMS,$updateMetadataOnly=false,$changedLayers=null){ //TODO give return true or false to allow feedback to user!!!
+        $this->wms_id = $myWMS;
 		//get some things out from database if not already given thru metadata editor: wms_network_access, wms_max_imagesize, inspire_download (on layer level)
 		//they don't come from the capabilities!
 		if (!$updateMetadataOnly) {
@@ -2536,7 +2550,7 @@
 		$res = db_prep_query($sql,$v,$t);
 		if(!$res){
-			db_rollback();
+			db_rollback();
 		if($this->overwrite == true){
@@ -2608,6 +2622,24 @@
 			# update gui_wms
 			$this->update_gui_wms($myWMS);
+		//NEW 2012-11: Check for changed layer names with options $changedLayersObj
+        for($i=0; $i<count($changedLayers); $i++){
+            if(trim($changedLayers[$i]["oldLayerName"]) != trim($changedLayers[$i]["newLayerName"])) {
+                $sql = "UPDATE layer SET layer_name = $1 WHERE fkey_wms_id = $2 AND layer_name = $3";
+    			$v = array(trim($changedLayers[$i]["newLayerName"]), $myWMS, trim($changedLayers[$i]["oldLayerName"]));
+    			$t = array('s','i','s');
+    			$res = db_prep_query($sql,$v,$t);
+    			new mb_notice("update oldLayerName to newLayerName :". $changedLayers[$i]["oldLayerName"]."----->".$changedLayers[$i]["newLayerName"]);
+    			if(!$res){
+    				db_rollback();
+		    #new mb_notice("oldLayerName ==================". $changedLayers[$i]["oldLayerName"]);
+		    #new mb_notice("newLayerName ==================". $changedLayers[$i]["newLayerName"]);
 		# update TABLE layer
 		$oldLayerNameArray = array();
 		$v = array($myWMS);
Added: trunk/mapbender/http/img/link_edit.png
(Binary files differ)
Property changes on: trunk/mapbender/http/img/link_edit.png
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Added: trunk/mapbender/http/php/mb_getWmsData.php
--- trunk/mapbender/http/php/mb_getWmsData.php	                        (rev 0)
+++ trunk/mapbender/http/php/mb_getWmsData.php	2012-11-22 07:23:03 UTC (rev 8509)
@@ -0,0 +1,128 @@
+<?php
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+require_once(dirname(__FILE__)."/../classes/class_json.php");
+require_once(dirname(__FILE__)."/../classes/class_wms.php");
+require_once(dirname(__FILE__)."/../classes/class_administration.php");
+$command = $_REQUEST["command"];
+if ($command == "getWmsData") {
+	$wms = $_POST["wmsId"];
+	$url = $_POST["wmsUrl"];
+	//get existing DB wms information
+    $sql = "SELECT * from layer WHERE fkey_wms_id = $1 ORDER BY layer_id";
+    $v = array ($wms);
+    $t = array ('i');
+    $res = db_prep_query($sql, $v, $t);
+    $dbObj = array();
+	while ($row = db_fetch_array($res)) {
+        $dbObj[] = array (
+            //"id" => $row["layer_id"],
+            "pos" => $row["layer_pos"],
+            "parent"   => $row["layer_parent"],
+            "name"   => $row["layer_name"]
+            //"title"   => $row["layer_title"]
+    //get xml wms information
+	$updateWms = new wms();
+	$xml = $updateWms->createObjFromXML($url);
+	if($xml == "") {
+	    echo "WMS could not be loaded, no valid XML. Please check WMS GetCapabilities";
+	    die();
+	$updateWms->optimizeWMS();
+	$xmlObj = $updateWms->getLayerInfo();
+	$resultObj = array(
+	    "dbObj" => $dbObj,
+	    "xmlObj" =>  $xmlObj
+	$layerJson = json_encode($resultObj);
+    header("Content-type:application/json; charset=utf-8");
+    echo $layerJson;
+else if($command == "updateWMS") {
+    $myWMS = $_POST["wmsId"];
+	$changedLayerArray = array();
+	for ($i=0; $i<count($_POST['dbOldNames']); $i++) {
+	    $changedLayerArray[] = array(
+	        "oldLayerName" => $_POST['dbOldNames'][$i],
+	        "newLayerName" => $_POST['dbCurrentNames'][$i]
+	#$changedLayerObj = json_encode($changedLayerArray);
+    $mywms = new wms();
+	$mywms->createObjFromXML($url);
+	$mywms->optimizeWMS();
+	echo "<br />";
+	if (!MD_OVERWRITE) {
+		$mywms->overwrite=false;
+	//possibility to see update information in georss and/or twitter channel
+	if(empty($_POST['twitter_news'])) {
+		$mywms->twitterNews = false;
+	if(empty($_POST['rss_news'])) {
+		$mywms->setGeoRss = false;
+	$mywms->updateObjInDB($myWMS,false, $changedLayerArray);
+	$mywms->displayWMS();
+	// start (owners of the updated wms will be notified by email)
+	if ($use_php_mailing) {
+		$owner_ids = $admin->getOwnerByWms($myWMS);
+		if ($owner_ids && count($owner_ids)>0) {
+			$owner_mail_addresses = array();
+			$j=0;
+			for ($i=0; $i<count($owner_ids); $i++) {
+				$adr_tmp = $admin->getEmailByUserId($owner_ids[$i]);
+				if (!in_array($adr_tmp, $owner_mail_addresses) && $adr_tmp) {
+					$owner_mail_addresses[$j] = $adr_tmp;
+					$j++;
+			$replyto = $admin->getEmailByUserId(Mapbender::session()->get("mb_user_id"));
+			$from = $replyto;
+			$pathArray = explode("http/php/", $_SERVER["PATH_TRANSLATED"]);
+			$path = $pathArray[0];
+			$body = "WMS '" . $admin->getWmsTitleByWmsId($myWMS) . "' has been updated. \n\nServer name:  " . $_SERVER["SERVER_NAME"] . "\nInstallation Path: " . $path . "\n\nYou may want to check the changes as you are an owner of this WMS.";
+			$error_msg = "";
+			for ($i=0; $i<count($owner_mail_addresses); $i++) {
+				if (!$admin->sendEmail($replyto, $from, $owner_mail_addresses[$i], $owner_mail_addresses[$i], "[Mapbender] A user has updated one of your WMS", $body, $error)) {
+					if ($error){
+						$error_msg .= $error . " ";
+			if (!$error_msg) {
+				echo "<script language='javascript'>";
+				echo "alert('Other owners of this WMS have been informed about the changes!');";
+				echo "</script>";
+			else {
+				echo "alert('When notifying the owners of this WMS about your changes, an error occured: ' + '" . $error_msg . "');";
+				echo "</script>";
+	// end (owners of the updated wms will be notified by email)
+else {
+	echo "please enter a valid command.";
\ No newline at end of file
Modified: trunk/mapbender/http/php/mod_updateWMS.php
--- trunk/mapbender/http/php/mod_updateWMS.php	2012-11-20 15:09:00 UTC (rev 8508)
+++ trunk/mapbender/http/php/mod_updateWMS.php	2012-11-22 07:23:03 UTC (rev 8509)
@@ -38,18 +38,237 @@
 echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
 <title>updateWMS</title>
+<style type="text/css">
+  	body{
+      background-color: #ffffff;
+  		font-family: Arial, Helvetica, sans-serif;
+  		font-size : 12px;
+  		color: #808080
+  	.list_guis{
+  		font-size : 12px;
+  		color: #808080;
+  	a:link{
+  		font-size : 12px;
+  		text-decoration : none;
+  		color: #808080;
+  	a:visited {
+  		color: #808080;
+  		font-size : 12px;
+  	a:active {
+  		color: #808080;
+  		font-size : 12px;
+  	table {
+  		color: #000000;
+  		font-size : 12px;
+  	table.layerNames{
+  		font-size : 14px;
+  		color: #000000;
+  	#updateResult{
+  		color: #000000;
+</style>
+<link rel="stylesheet" href="../extensions/jquery-ui-1.7.2.custom/css/smoothness/jquery-ui-1.7.2.custom.css" />
 <?php
 include '../include/dyn_css.php';
+<script type='text/javascript' src='../extensions/jquery-ui-1.8.1.custom/js/jquery-1.4.2.min.js'></script>
+<script type='text/javascript' src='../extensions/jquery-ui-1.8.16.custom/js/jquery-ui-1.8.16.custom.min.js'></script>
 <script type='text/javascript'>
+function updateWms() {
+	$("#updateResult").remove();
+	var dbOldNameArray = [];
+	var dbCurrentNameArray = [];
+	$(".dbOldName").each(function(index) {
+	    dbOldNameArray.push($(this).val());
+	$(".dbCurrentName").each(function(index) {
+		dbCurrentNameArray.push($(this).val());
+	var updateParams = {
+		"command": "updateWMS",
+		"wmsId": $("#myWMS").val(),
+		"wmsUrl" : $("#myURL").val(),
+		"publishRss" : $("#rss_news").attr("checked"),
+		"publishTwitter" : $("#twitter_news").attr("checked"),
+		"dbOldNames": dbOldNameArray,
+		"dbCurrentNames": dbCurrentNameArray
+	$.post("../php/mb_getWmsData.php", updateParams, function (jscode, status) {
+		if (status == 'success') {
+			if(jscode == "") {
+				alert("Error updating WMS.");
+			//$("select[name='selWMS'] option:selected").removeAttr("selected");
+			$("select[name='selWMS']").attr('selectedIndex', '-1').find("option:selected").removeAttr("selected");
+			$("input[name='capURL']").val("");
+			$("input[name='myURL']").val("");
+			$("#compare_dialog").removeAttr("checked");
+			$("#metadatalink").attr("href", "");
+			$("#metadatatext").html("no WMS selected");
+			$("#form1").append("<div id='updateResult'>" + jscode + "</div>");
+			return true;
+		else {
+			return false;
 function validate(){
 	var ind = document.form1.selWMS.selectedIndex;
 	if(ind < 0){
 		alert("No WMS selected!");
 		return;
+	else if($("#myURL").val() == ""){
+		alert("No link to WMS Capabilities URL given.");
+		return;
 	else{
-		document.form1.submit();
+		if($("#compare_dialog").attr("checked")) {
+			if (typeof $compareDialog == 'object') {
+                $compareDialog.dialog("destroy");
+			var params = {
+				command:"getWmsData",
+			$.post("../php/mb_getWmsData.php", params, function (json, status) {
+					if(json) {
+						if(typeof json == "object") {
+							var xmlWmsHtml = "<fieldset style='float:left;width:45%;'>";
+							xmlWmsHtml += "<legend>XML WMS</legend>";
+							xmlWmsHtml += "<table class='layerNames'>";
+							xmlWmsHtml += "<tr>";
+							//xmlWmsHtml += "<th>ID</th>";
+							xmlWmsHtml += "<th>Pos</th>";
+							xmlWmsHtml += "<th>Layer Name</th>";
+							//xmlWmsHtml += "<th>Title</th>";
+							xmlWmsHtml += "</tr>";
+							var selectboxOptions = "<option value=''>---</option>";
+							for (var i = 0; i < json.xmlObj.length; i++) {
+								//xmlWmsHtml += "<td>" + json.xmlObj[i].id + "</td>";
+								xmlWmsHtml += "<td>" + json.xmlObj[i].pos + "</td>";
+								xmlWmsHtml += "<td>";
+								xmlWmsHtml += "<input type='text' readonly id='xmlCurrentName' value='"+ json.xmlObj[i].name +"'>";
+								xmlWmsHtml += "</td>";
+								//xmlWmsHtml += "<td>" + json.xmlObj[i].title + "</td>";
+								selectboxOptions += '<option value=\"' + json.xmlObj[i].name + '\">' + json.xmlObj[i].name + '</option>';
+							xmlWmsHtml += "</table>";
+							xmlWmsHtml += "</fieldset>";
+							var dbWmsHtml = "<fieldset style='float:left;width:45%;'>";
+							dbWmsHtml += "<legend>DB WMS</legend>";
+							dbWmsHtml += "<table class='layerNames'>";
+							dbWmsHtml += "<tr>";
+							//dbWmsHtml += "<th>ID</th>";
+							dbWmsHtml += "<th>Pos</th>";
+							dbWmsHtml += "<th>Layer Name</th>";
+							//bWmsHtml += "<th>Title</th>";
+							dbWmsHtml += "</tr>";
+							for (var i = 0; i < json.dbObj.length; i++) {
+								//dbWmsHtml += "<td>" + json.dbObj[i].id + "</td>";
+								dbWmsHtml += "<td>" + json.dbObj[i].pos + "</td>";
+								dbWmsHtml += "<td>";
+								dbWmsHtml += "<input class='dbCurrentName' type='text' readonly id='dbCurrentName_"+i+"' value='" + json.dbObj[i].name + "'>";
+								dbWmsHtml += "<input class='dbOldName' type='hidden' id='dbOldName_"+i+"' value='" + json.dbObj[i].name + "'>";
+								dbWmsHtml += "<img title='select matching layer from XML' class='linkDialog' id='linkDialog_"+i+"' style='cursor:pointer;width:16px;height:16px;' src='../img/link_edit.png'/>";
+								dbWmsHtml += "</td>";
+								//dbWmsHtml += "<td>" + json.dbObj[i].title + "</td>";
+							dbWmsHtml += "</table>";
+							dbWmsHtml += "</fieldset>";
+							var dialogHtml = "<div id='compareDialog'>" + xmlWmsHtml + dbWmsHtml + "</div>";
+							$compareDialog = $(dialogHtml).dialog({
+								title : "Compare WMS XML layers with DB layers",
+								width : "600px",
+								buttons: {
+									"Close": function() {
+										$(this).dialog("destroy").remove();
+									"Update WMS": function() {
+										updateWms();
+							$(".linkDialog").click(function () {
+								var fieldId = $(this).attr("id");
+								$selectLayerDialog = $("<div><select id='xmlLayerSelect'>" + selectboxOptions + "</select></div>").dialog({
+									title : "Select layer",
+									buttons: {
+										"Select": function() {
+											if($("#xmlLayerSelect").val() != "") {
+												var cntArray = fieldId.split('_');
+												$("#dbCurrentName_"+cntArray[1]).val($("#xmlLayerSelect").val());
+												if($("#dbCurrentName_"+cntArray[1]).val() != $("#dbOldName_"+cntArray[1]).val()) {
+													$("#dbCurrentName_"+cntArray[1]).css("background-color","orange");
+												else {
+													$("#dbCurrentName_"+cntArray[1]).css("background-color","");
+						else {
+							alert(json);
+					else {
+						alert("Error getting layer information.");
+				else {
+		else {
+			document.form1.submit();
 function sel(){
@@ -66,7 +285,7 @@
 </script>
 </head>
 <body>
-<form name='form1' action='<?php echo $self; ?>' method='POST'>
+<form name='form1' id='form1' action='<?php echo $self; ?>' method='POST'>
 <?php
@@ -112,19 +331,20 @@
 <?php
 	echo "Link to the last uploaded Online Resource URL:<br><input type='text' size='120' name='capURL'><br />";
-	echo "<input type='hidden' name='myWMS' value=''><br>";
+	echo "<input type='hidden' name='myWMS' id='myWMS' value=''><br>";
 	echo "Add the following REQUEST to the Online Resource URL to obtain the Capabilities document:<br>";
 	echo "<i>(Triple click to select and copy)</i><br>";
 	echo "REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1<br>";
 	echo "REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.0<br>";
 	echo "REQUEST=capabilities&WMTVER=1.0.0<br><br>";
-	echo "Link to new WMS Capabilities URL:<br><input size='120' type='text' name='myURL'><br>";
+	echo "Link to new WMS Capabilities URL:<br><input size='120' type='text' name='myURL' id='myURL'><br>";
 	if (defined("TWITTER_NEWS") && TWITTER_NEWS == true) {
-		echo"<input type='checkbox' name='twitter_news' checked='checked'>Publish via Twitter<br>";
+		echo"<input type='checkbox' name='twitter_news' id='twitter_news' checked='checked'>Publish via Twitter<br>";
 	if (defined("GEO_RSS_FILE") &&  GEO_RSS_FILE != "") {
-		echo"<input type='checkbox' name='rss_news' checked='checked'>Publish via RSS<br>";
+		echo"<input type='checkbox' name='rss_news' id='rss_news' checked='checked'>Publish via RSS<br>";
+	echo"<input type='checkbox' name='compare_dialog' id='compare_dialog'><label for='compare_dialog'>Use compare dialog</label><br>";
 	echo "<input type='button' value='Preview Capabilities' onclick='window.open(this.form.myURL.value,\"\",\"\")'> ";
 	echo "<input type='button' value='Upload Capabilities' onclick='validate()'><br>";
@@ -132,7 +352,13 @@
 if(isset($myURL) && $myURL != ''){
 	$mywms = new wms();
-	$mywms->createObjFromXML($myURL);
+	$xml = $mywms->createObjFromXML($myURL);
+	if($xml == "") {
+	    echo "<br>WMS could not be loaded, no valid XML. Please check WMS GetCapabilities";
+	    die();
 	echo "<br />";
@@ -145,9 +371,12 @@
-	$mywms->updateObjInDB($myWMS);
+	$updateObj = $mywms->updateObjInDB($myWMS);
+	echo "<div id='updateResult'>";
+    echo "</div>";
More information about the Mapbender_commits mailing list
