[Mapbender-commits] r8512 - trunk/mapbender/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Nov 26 12:36:16 PST 2012
Author: armin11
Date: 2012-11-26 12:36:14 -0800 (Mon, 26 Nov 2012)
New Revision: 8512
Added:
   trunk/mapbender/http/php/mod_inspireAtomFeedISOMetadata.php
   trunk/mapbender/http/php/mod_dataLinkDownloadISOMetadata.php
   trunk/mapbender/http/php/mod_inspireDownloadFeed.php
   trunk/mapbender/http/php/mod_showMetadata.php
Some further adoptions for INSPIRE download services - iso19139 records
Modified: trunk/mapbender/http/php/mod_dataLinkDownloadISOMetadata.php
--- trunk/mapbender/http/php/mod_dataLinkDownloadISOMetadata.php	2012-11-26 10:23:38 UTC (rev 8511)
+++ trunk/mapbender/http/php/mod_dataLinkDownloadISOMetadata.php	2012-11-26 20:36:14 UTC (rev 8512)
@@ -23,7 +23,7 @@
 require_once(dirname(__FILE__) . "/../../core/globalSettings.php");
 require_once(dirname(__FILE__) . "/../classes/class_connector.php");
 require_once(dirname(__FILE__) . "/../classes/class_administration.php");
+require_once(dirname(__FILE__) . "/../classes/class_Uuid.php");
 $con = db_connect(DBSERVER,OWNER,PW);
 db_select_db(DB,$con);
@@ -38,14 +38,16 @@
 	$_REQUEST[strtoupper($key)] = $val;
 //validate request params
+//TODO: validate s.th. like uuid or else
 if (isset($_REQUEST['ID']) & $_REQUEST['ID'] != "") {
-	//validate integer
+	//validate uuid or other identifiers - which?
 	$testMatch = $_REQUEST["ID"];
-	$pattern = '/^[\d]*$/';
- 	if (!preg_match($pattern,$testMatch)){
-		echo 'Id: <b>'.$testMatch.'</b> is not valid.<br/>';
+	$uuid = new Uuid($testMatch);
+	$isUuid = $uuid->isValid();
+	if (!$isUuid) {
+		echo 'Id: <b>'.$testMatch.'</b> is not a valid uuid (12-4-4-4-8)!<br/>';
 		die();
 	$recordId = $testMatch;
 	$testMatch = NULL;
Added: trunk/mapbender/http/php/mod_inspireAtomFeedISOMetadata.php
--- trunk/mapbender/http/php/mod_inspireAtomFeedISOMetadata.php	                        (rev 0)
+++ trunk/mapbender/http/php/mod_inspireAtomFeedISOMetadata.php	2012-11-26 20:36:14 UTC (rev 8512)
@@ -0,0 +1,1310 @@
+<?php
+//http://www.geoportal.rlp.de/mapbender/php/mod_inspireAtomFeedISOMetadata.php?outputFormat=iso19139&Id=assdasbdassa&generateFrom=wfs
+// $Id: mod_dataLinkDownloadISOMetadata.php 235
+// http://www.mapbender.org/index.php/
+// Copyright (C) 2002 CCGIS
+// This program is free software; you can redistribute it and/or modify
+// it under the terms of the GNU General Public License as published by
+// the Free Software Foundation; either version 2, or (at your option)
+// any later version.
+// This program is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+// GNU General Public License for more details.
+// You should have received a copy of the GNU General Public License
+// along with this program; if not, write to the Free Software
+// Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+//Script to generate a conformant ISO19139 service metadata record for a wms layers dataurl attribut which is registrated in the mapbender database. It works as a webservice
+//The record will be fulfill the demands of the INSPIRE metadata regulation from 03.12.2008 and the iso19139
+require_once(dirname(__FILE__) . "/../../core/globalSettings.php");
+require_once(dirname(__FILE__) . "/../classes/class_connector.php");
+require_once(dirname(__FILE__) . "/../classes/class_administration.php");
+$con = db_connect(DBSERVER,OWNER,PW);
+db_select_db(DB,$con);
+$admin = new administration();
+//pull the needed things from tables datalink, md_metadata, layer, wms
+//parse request parameter
+//make all parameters available as upper case
+foreach($_REQUEST as $key => $val) {
+	$_REQUEST[strtoupper($key)] = $val;
+//validate request params
+if (isset($_REQUEST['ID']) & $_REQUEST['ID'] != "") {
+	$testMatch = $_REQUEST["ID"];
+	if (!$isUuid) {
+		die();
+	$recordId = $testMatch;
+	$testMatch = NULL;
+if ($_REQUEST['OUTPUTFORMAT'] == "iso19139") {
+	//Initialize XML document
+	$iso19139Doc = new DOMDocument('1.0');
+	$iso19139Doc->encoding = 'UTF-8';
+} else {
+	echo 'outputFormat: <b>'.$_REQUEST['OUTPUTFORMAT'].'</b> is not set or valid.<br/>';
+	die();
+//if validation is requested
+if (isset($_REQUEST['VALIDATE']) and $_REQUEST['VALIDATE'] != "true") {
+	echo 'validate: <b>'.$_REQUEST['VALIDATE'].'</b> is not valid.<br/>';
+	die();
+if (!isset($_REQUEST['GENERATEFROM']) || $_REQUEST['GENERATEFROM'] == "") {
+	echo '<b>Mandatory parameter GENERATEFROM is not set!</b><br>Please set GENERATEFROM to <b>wmslayer</b>, <b>dataurl</b> or <b>wfs</b> ';
+	die();
+if (isset($_REQUEST['GENERATEFROM']) & $_REQUEST['GENERATEFROM'] != "") {
+	//validate type
+	$testMatch = $_REQUEST["GENERATEFROM"];
+ 	if ($testMatch != 'wmslayer' && $testMatch != 'dataurl'  && $testMatch != 'wfs'){
+		echo 'GENERATEFROM: <b>'.$testMatch.'</b> is not valid.<br/>';
+		die();
+	$generateFrom = $testMatch;
+if ($generateFrom == "wfs") {
+	//check if wfsId is set too
+	if (isset($_REQUEST['WFSID']) & $_REQUEST['WFSID'] != "") {
+		$testMatch = $_REQUEST["WFSID"];
+		$pattern = '/^[\d]*$/';
+ 		if (!preg_match($pattern,$testMatch)){
+			echo 'WFSID must be an integer: <b>'.$testMatch.'</b> is not valid.<br/>';
+			die();
+		$wfsId = $testMatch;
+	} else {
+		echo 'Mandatory request parameter <b>WFSID</b> must be set if download service should be generated by using a Web Feature Service!';
+		die();
+//some needfull functions to pull metadata out of the database!
+function fillISO19139($iso19139, $recordId) {
+	global $admin, $generateFrom, $wfsId;
+	//Pull download options for specific dataset from mapbender database and show them
+	$downloadOptionsConnector = new connector("http://localhost".$_SERVER['SCRIPT_NAME']."/../mod_getDownloadOptions.php?id=".$recordId);
+	//echo "http://localhost".$_SERVER['SCRIPT_NAME']."/../mod_getDownloadOptions.php?id=".$recordId;
+	$downloadOptions = json_decode($downloadOptionsConnector->file);
+	//var_dump($downloadOptions);
+	//switch for generateFrom
+	if ($downloadOptions == null) {
+		echo "<error>No downloadable options for this metadatarecord found!</error>";
+		die();
+	switch ($generateFrom) {
+		case "dataurl":
+	        /*given information:
+		wms_id, layer_id
+		needed information:
+		mb_metadata.title,
+		mb_metadata.abstract,
+		layer inspireidentifiziert - read later,
+		layer_extent - layer_epsg,
+		(mb_metadata.tmp_reference_1 , mb_metadata.tmp_reference_2) || wms.wms_timestamp - eher,
+		(where 4326),
+		scale hints? nicht für downloaddienste,
+		wms.wms_department,
+		(mb_group.mb_group_title),
+		mb_metadata.ref_system,
+		wms.owner,
+		wms.fkey_group_id,
+		wms.uuid,
+		dataset identifier*/
+		foreach ($downloadOptions->{$recordId}->option as $option) {
+			if ($option->type == "wmslayerdataurl") {
+				$mapbenderMetadata['mdFileIdentifier'] = $recordId;
+				$mapbenderMetadata['serviceId'] = $option->serviceId;
+				$mapbenderMetadata['resourceId'] = $option->resourceId;
+			} else {
+				echo "<error>No option for downloading service via dataurl found in database</error>";
+				die();
+		//check if entries are filled
+		//read information from metadata table
+		$sql = <<<SQL
+			select mb_metadata.title, mb_metadata.abstract, mb_metadata.ref_system, mb_metadata.datasetid, mb_metadata.origin from mb_metadata where mb_metadata.uuid = $1;
+SQL;
+		$v = array($recordId);
+		$t = array('s');
+		$res = db_prep_query($sql,$v,$t);
+		$mbMetadata = db_fetch_array($res);
+		$mapbenderMetadata['mdTitle'] = $mbMetadata['title'];
+		$mapbenderMetadata['mdAbstract'] = $mbMetadata['abstract'];
+		$mapbenderMetadata['mdRefSystem'] = $mbMetadata['ref_sytem'];
+		$mapbenderMetadata['datasetId'] = $mbMetadata['datasetid'];
+		$mapbenderMetadata['mdOrigin'] = $mbMetadata['origin'];
+		//read information for layer/layer_epsg/wms/layer classification - 'inspireidentifiziert'?
+		$sql = <<<SQL
+			select * from (select layer.layer_id, layer.layer_minscale, layer.layer_maxscale, wms.wms_timestamp, wms.wms_owner, wms.fkey_mb_group_id, wms.contactorganization, wms.uuid, wms.contactelectronicmailaddress, wms.wms_timestamp_create, wms.fees, wms.accessconstraints from layer inner join wms on layer.fkey_wms_id = wms.wms_id where layer.layer_id = $1) as wms_layer, layer_epsg where wms_layer.layer_id = layer_epsg.fkey_layer_id and layer_epsg.epsg = 'EPSG:4326';
+SQL;
+		$v = array((integer)$mapbenderMetadata['resourceId']);
+		$t = array('i');
+		$mapbenderMetadata['serviceUuid'] = $mbMetadata['uuid'];
+		$mapbenderMetadata['serviceTimestamp'] = $mbMetadata['wms_timestamp'];
+		$mapbenderMetadata['serviceTimestampCreate'] = $mbMetadata['wms_timestamp_create'];
+		$mapbenderMetadata['serviceDepartment'] = $mbMetadata['contactorganization'];
+		$mapbenderMetadata['serviceDepartmentMail'] = $mbMetadata['contactelectronicmailaddress'];
+		$mapbenderMetadata['serviceGroupId'] = $mbMetadata['fkey_mb_group_id'];
+		$mapbenderMetadata['serviceOwnerId'] = $mbMetadata['wms_owner'];
+		$mapbenderMetadata['serviceAccessConstraints'] = $mbMetadata['accessconstraints'];
+		$mapbenderMetadata['serviceFees'] = $mbMetadata['fees'];
+		$mapbenderMetadata['minScale'] = $mbMetadata['layer_minscale'];
+		$mapbenderMetadata['maxScale'] = $mbMetadata['layer_maxscale'];
+		$mapbenderMetadata['minx'] = $mbMetadata['minx'];
+		$mapbenderMetadata['miny'] = $mbMetadata['miny'];
+		$mapbenderMetadata['maxx'] = $mbMetadata['maxx'];
+		$mapbenderMetadata['maxy'] = $mbMetadata['maxy'];
+		break;
+		case "wmslayer":
+		wms_id, layer_id
+		(where 4326),
+		wms.owner,
+		wms.uuid,
+			if ($option->type == "wmslayergetmap") {
+			} else {
+				echo "<error>No option for downloading service via wmslayer found in database</error>";
+				die();
+		$sql = <<<SQL
+SQL;
+		$t = array('s');
+		$sql = <<<SQL
+SQL;
+		$t = array('i');
+		break;
+		case "wfs":
+		wfs_id
+		featuretypes inspireidentifiziert - read later,
+		featuretypes_extent - featuretype_latlon_bbox,
+		(mb_metadata.tmp_reference_1 , mb_metadata.tmp_reference_2) || wfs.wfs_timestamp - eher,
+		(where 4326), - see latlonbbox
+		wfs.providername,
+		wfs.wfs_owner,
+		wfs.fkey_group_id,
+		wfs.uuid,
+			if ($option->type == "wfsrequest") {
+				if ($option->serviceId == $wfsId) {
+					//generate array of featuretypes
+					$ft = array();
+					foreach ($option->featureType as $featuretype) {
+						$ft[] = $featuretype;
+					$mapbenderMetadata['featureTypes'] = $ft;
+					break;
+		if (!isset($mapbenderMetadata['serviceId']) ||  $mapbenderMetadata['serviceId'] == '') {
+			echo "<error>No specific option for downloading service via wfsrequest found in database</error>";
+			die();
+		$sql = <<<SQL
+SQL;
+		$t = array('s');
+		//Problem multiple featuretypes maybe included to serve a dataset!!!
+		//We have to compute a general bbox, and?
+		//$downloadOptions->{$idList[$i]}->option[$j]->featureType[0] = $row['resource_id'];
+		//read information for ft/ft_epsg/wfs/ft classification - 'inspireidentifiziert'?
+		//first only read service information!!
+		$sql = <<<SQL
+			select wfs_id, uuid, wfs_timestamp, providername, fkey_mb_group_id, wfs_owner, electronicmailaddress, wfs_timestamp_create, fees, accessconstraints from wfs where wfs_id = $1;
+SQL;
+		$t = array('i');
+		$mapbenderMetadata['serviceTimestamp'] = $mbMetadata['wfs_timestamp'];
+		$mapbenderMetadata['serviceTimestampCreate'] = $mbMetadata['wfs_timestamp_create'];
+		$mapbenderMetadata['serviceDepartment'] = $mbMetadata['providername'];
+		$mapbenderMetadata['serviceDepartmentMail'] = $mbMetadata['electronicmailaddress'];
+		$mapbenderMetadata['serviceOwnerId'] = $mbMetadata['wfs_owner'];
+		//select bboxes for relevant featuretypes:
+		$sql = <<<SQL
+			select featuretype_latlon_bbox from wfs_featuretype where featuretype_id in ( $1 );
+SQL;
+		$v = array(implode(',',$mapbenderMetadata['featureTypes']));
+		$t = array('s');
+		//get enclosure of bboxes of the different featuretypes
+		while (  $row  =  db_fetch_array($res) )  {
+  			$bbox = explode(',',$row['featuretype_latlon_bbox']);
+			if (!isset($mapbenderMetadata['minx']) || (float)$mapbenderMetadata['minx'] <  (float)$bbox[0] ) {
+				$mapbenderMetadata['minx'] = $bbox[0];
+			if (!isset($mapbenderMetadata['miny']) || (float)$mapbenderMetadata['miny'] <  (float)$bbox[1] ) {
+				$mapbenderMetadata['miny'] = $bbox[1];
+			if (!isset($mapbenderMetadata['maxx']) || (float)$mapbenderMetadata['maxx'] <  (float)$bbox[2] ) {
+				$mapbenderMetadata['maxx'] = $bbox[2];
+			if (!isset($mapbenderMetadata['maxy']) || (float)$mapbenderMetadata['maxy'] <  (float)$bbox[3] ) {
+				$mapbenderMetadata['maxy'] = $bbox[3];
+		break;
+	//infos about the registrating department, check first if a special metadata point of contact is defined in the service table - function from mod_showMetadata - TODO: should be defined in admin class
+	if (!isset($mapbenderMetadata['serviceGroupId']) or is_null($mapbenderMetadata['serviceGroupId']) or $mapbenderMetadata['serviceGroupId'] == 0){
+		$e = new mb_exception("mod_dataLinkDownloadISOMetadata.php: fkey_mb_group_id not found!");
+		//Get information about owning user of the relation mb_user_mb_group - alternatively the defined fkey_mb_group_id from the service must be used!
+		$sqlDep = "SELECT mb_group_name, mb_group_title, mb_group_id, mb_group_logo_path, mb_group_address, mb_group_email, mb_group_postcode, mb_group_city, mb_group_voicetelephone, mb_group_facsimiletelephone FROM mb_group AS a, mb_user AS b, mb_user_mb_group AS c WHERE b.mb_user_id = $1  AND b.mb_user_id = c.fkey_mb_user_id AND c.fkey_mb_group_id = a.mb_group_id AND c.mb_user_mb_group_type=2 LIMIT 1";
+		$vDep = array($mapbenderMetadata['serviceOwnerId']);
+		$tDep = array('i');
+		$resDep = db_prep_query($sqlDep, $vDep, $tDep);
+		$departmentMetadata = db_fetch_array($resDep);
+	} else {
+		$e = new mb_exception("mod_dataLinkDownloadISOMetadata.php: fkey_mb_group_id found!");
+		$sqlDep = "SELECT mb_group_name , mb_group_title, mb_group_id, mb_group_logo_path , mb_group_address, mb_group_email, mb_group_postcode, mb_group_city, mb_group_voicetelephone, mb_group_facsimiletelephone FROM mb_group WHERE mb_group_id = $1 LIMIT 1";
+		$vDep = array($mapbenderMetadata['serviceGroupId']);
+	//infos about the owner of the service - he is the man who administrate the metadata - register the service
+	$sql = "SELECT mb_user_email ";
+	$sql .= "FROM mb_user WHERE mb_user_id = $1";
+	$v = array((integer)$mapbenderMetadata['serviceOwnerId']);
+	$t = array('i');
+	$userMetadata = db_fetch_array($res);
+	//check if resource is freely available to anonymous user - which are all users who search thru metadata catalogues:
+	//$hasPermission=$admin->getLayerPermission($mapbenderMetadata['serviceId'],$mapbenderMetadata['layer_name'],PUBLIC_USER);
+	$hasPermission = true;//Is always true for ATOM Service Feeds!
+	//Creating the central "MD_Metadata" node
+	$MD_Metadata = $iso19139->createElementNS('http://www.isotc211.org/2005/gmd', 'gmd:MD_Metadata');
+	$MD_Metadata = $iso19139->appendChild($MD_Metadata);
+	$MD_Metadata->setAttribute("xmlns:srv", "http://www.isotc211.org/2005/srv");
+	$MD_Metadata->setAttribute("xmlns:gml", "http://www.opengis.net/gml");
+	$MD_Metadata->setAttribute("xmlns:gco", "http://www.isotc211.org/2005/gco");
+	$MD_Metadata->setAttribute("xmlns:xlink", "http://www.w3.org/1999/xlink");
+	$MD_Metadata->setAttribute("xmlns:xsi", "http://www.w3.org/2001/XMLSchema-instance");
+	$MD_Metadata->setAttribute("xsi:schemaLocation", "http://www.isotc211.org/2005/gmd ./xsd/gmd/gmd.xsd http://www.isotc211.org/2005/srv ./xsd/srv/srv.xsd");
+	//generate identifier part
+	$identifier = $iso19139->createElement("gmd:fileIdentifier");
+	$identifierString = $iso19139->createElement("gco:CharacterString");
+	//How to generate UUIDs for INSPIRE Download Service Metadata records (not really needed for INSPIRE!!! See DB Metadaten)
+	//12-4-4-4-8
+	//dataurl
+	//WMS uuid (12-4), Type (4) - 0001, MD uuid (4-8)
+	//wfs
+	//WFS uuid (12-4), MD uuid (4-4-8)
+	//wmsgetmap
+	//WMS uuid (12-4), Type (4) - 0002, MD uuid (4-8)
+	if (isset($mapbenderMetadata['serviceUuid']) && $mapbenderMetadata['serviceUuid'] != '' ) {
+		$servicePart = explode('-',$mapbenderMetadata['serviceUuid']);
+		$mdPart = explode('-',$recordId);
+			case "wmslayer":
+				$dlsFileIdentifier = $servicePart[0]."-".$servicePart[1]."-"."0002"."-".$mdPart[3]."-".$mdPart[4];
+			break;
+			case "dataurl":
+				$dlsFileIdentifier = $servicePart[0]."-".$servicePart[1]."-"."0001"."-".$mdPart[3]."-".$mdPart[4];
+			break;
+			case "wfs":
+				$dlsFileIdentifier = $servicePart[0]."-".$servicePart[1]."-".$mdPart[2]."-".$mdPart[3]."-".$mdPart[4];
+			break;
+		$identifierText = $iso19139->createTextNode($dlsFileIdentifier);
+	} else {
+		$identifierText = $iso19139->createTextNode("no id found - please check if services have uuids or generate new ones!");
+	$identifierString->appendChild($identifierText);
+	$identifier->appendChild($identifierString);
+	$MD_Metadata->appendChild($identifier);
+	//generate language part B 10.3 (if available) of the inspire metadata regulation
+	$language = $iso19139->createElement("gmd:language");
+	$languagecode = $iso19139->createElement("gmd:LanguageCode");
+	$languagecode->setAttribute("codeList", "http://standards.iso.org/ittf/PubliclyAvailableStandards/ISO_19139_Schemas/resources/Codelist/ML_gmxCodelists.xml#LanguageCode");
+	if (isset($mapbenderMetadata['metadata_language'])) {
+		$languageText = $iso19139->createTextNode($mapbenderMetadata['metadata_language']);
+		$languagecode->setAttribute("codeListValue", $mapbenderMetadata['metadata_language']);
+	else {
+		$languageText = $iso19139->createTextNode("ger");
+		$languagecode->setAttribute("codeListValue", "ger");
+	$languagecode->appendChild($languageText);
+	$language ->appendChild($languagecode);
+	$language = $MD_Metadata->appendChild($language);
+	//generate characterset part - first it should be utf8 ;-)
+	$characterSet = $iso19139->createElement("gmd:characterSet");
+	$characterSetCode = $iso19139->createElement("gmd:MD_CharacterSetCode");
+	$characterSetCode->setAttribute("codeList", "http://www.loc.gov/standards/iso639-2");
+	$characterSetCode->setAttribute("codeListValue", "utf8");
+	$characterSet->appendChild($characterSetCode);
+	$characterSet = $MD_Metadata->appendChild($characterSet);
+	//generate MD_Scope part B 1.3 (if available)
+	$hierarchyLevel = $iso19139->createElement("gmd:hierarchyLevel");
+	$scopecode = $iso19139->createElement("gmd:MD_ScopeCode");
+	$scopecode->setAttribute("codeList", "http://standards.iso.org/ittf/PubliclyAvailableStandards/ISO_19139_Schemas/resources/Codelist/ML_gmxCodelists.xml#MD_ScopeCode");
+	$scopecode->setAttribute("codeListValue", "service");
+	$scopeText = $iso19139->createTextNode("service");
+	$scopecode->appendChild($scopeText);
+	$hierarchyLevel->appendChild($scopecode);
+	$hierarchyLevel=$MD_Metadata->appendChild($hierarchyLevel);
+	//iso19139 demands a hierachyLevelName object
+	$hierarchyLevelName = $iso19139->createElement("gmd:hierarchyLevelName");
+	$hierarchyLevelNameString = $iso19139->createElement("gco:CharacterString");
+	$hierarchyLevelNameText = $iso19139->createTextNode('Downloaddienst');
+	$hierarchyLevelName->appendChild($hierarchyLevelNameString);
+	$hierarchyLevelNameString->appendChild($hierarchyLevelNameText);
+	$hierarchyLevelName=$MD_Metadata->appendChild($hierarchyLevelName);
+	//Part B 10.1 responsible party for the resource
+	$contact=$iso19139->createElement("gmd:contact");
+	$CI_ResponsibleParty=$iso19139->createElement("gmd:CI_ResponsibleParty");
+	$organisationName=$iso19139->createElement("gmd:organisationName");
+	$organisationName_cs=$iso19139->createElement("gco:CharacterString");
+	if (isset($departmentMetadata['mb_group_name'])) {
+		$organisationNameText = $iso19139->createTextNode($departmentMetadata['mb_group_name']);
+	else
+		$organisationNameText=$iso19139->createTextNode('department not known');
+	$contactInfo=$iso19139->createElement("gmd:contactInfo");
+	$CI_Contact=$iso19139->createElement("gmd:CI_Contact");
+	$address=$iso19139->createElement("gmd:address");
+	$CI_Address=$iso19139->createElement("gmd:CI_Address");
+	$electronicMailAddress=$iso19139->createElement("gmd:electronicMailAddress");
+	$electronicMailAddress_cs=$iso19139->createElement("gco:CharacterString");
+	if (isset($userMetadata['mb_user_email'])) {
+		//get email address from ows service metadata out of mapbender database
+		$electronicMailAddressText=$iso19139->createTextNode($userMetadata['mb_user_email']);
+	else
+		$electronicMailAddressText=$iso19139->createTextNode('email not yet given');
+	$role=$iso19139->createElement("gmd:role");
+	$CI_RoleCode=$iso19139->createElement("gmd:CI_RoleCode");
+	$CI_RoleCode->setAttribute("codeList", "http://standards.iso.org/ittf/PubliclyAvailableStandards/ISO_19139_Schemas/resources/Codelist/ML_gmxCodelists.xml#CI_RoleCode");
+	$CI_RoleCode->setAttribute("codeListValue", "pointOfContact");
+	$CI_RoleCodeText=$iso19139->createTextNode("pointOfContact");
+	//create xml tree
+	$organisationName_cs->appendChild($organisationNameText);
+	$organisationName->appendChild($organisationName_cs);
+	$CI_ResponsibleParty->appendChild($organisationName);
+	$electronicMailAddress_cs->appendChild($electronicMailAddressText);
+	$electronicMailAddress->appendChild($electronicMailAddress_cs);
+	$CI_Address->appendChild($electronicMailAddress);
+	$address->appendChild($CI_Address);
+	$CI_Contact->appendChild($address);
+	$contactInfo->appendChild($CI_Contact);
+	$CI_RoleCode->appendChild($CI_RoleCodeText);
+	$role->appendChild($CI_RoleCode);
+	$CI_ResponsibleParty->appendChild($contactInfo);
+	$CI_ResponsibleParty->appendChild($role);
+	$contact->appendChild($CI_ResponsibleParty);
+	$MD_Metadata->appendChild($contact);
+	//generate dateStamp part B 10.2 (if available)
+	$dateStamp = $iso19139->createElement("gmd:dateStamp");
+	$mddate = $iso19139->createElement("gco:Date");
+	if (isset($mapbenderMetadata['serviceTimestamp'])) {
+		$mddateText = $iso19139->createTextNode(date("Y-m-d",$mapbenderMetadata['serviceTimestamp']));
+	else {
+		$mddateText = $iso19139->createTextNode("2000-01-01");
+	$mddate->appendChild($mddateText);
+	$dateStamp->appendChild($mddate);
+	$dateStamp=$MD_Metadata->appendChild($dateStamp);
+	//standard definition - for ows everytime the same ;-) but for feeds?
+	$metadataStandardName = $iso19139->createElement("gmd:metadataStandardName");
+	$metadataStandardVersion = $iso19139->createElement("gmd:metadataStandardVersion");
+	$metadataStandardNameText = $iso19139->createElement("gco:CharacterString");
+	$metadataStandardVersionText = $iso19139->createElement("gco:CharacterString");
+	$metadataStandardNameTextString = $iso19139->createTextNode("ISO19119");
+	$metadataStandardVersionTextString = $iso19139->createTextNode("2005/PDAM 1");
+	$metadataStandardNameText->appendChild($metadataStandardNameTextString);
+	$metadataStandardVersionText->appendChild($metadataStandardVersionTextString);
+	$metadataStandardName->appendChild($metadataStandardNameText);
+	$metadataStandardVersion->appendChild($metadataStandardVersionText);
+	$MD_Metadata->appendChild($metadataStandardName);
+	$MD_Metadata->appendChild($metadataStandardVersion);
+	//do the things for identification
+	//create nodes
+	$identificationInfo=$iso19139->createElement("gmd:identificationInfo");
+	$SV_ServiceIdentification=$iso19139->createElement("srv:SV_ServiceIdentification");
+	//TODO: add attribut if really needed
+	//$SV_ServiceIdentification->setAttribute("id", "dataId");
+	$citation=$iso19139->createElement("gmd:citation");
+	$CI_Citation=$iso19139->createElement("gmd:CI_Citation");
+	//create nodes for things which are defined - howto do the multiplicities? Ask Martin!
+	//Create Resource title element B 1.1
+	$title=$iso19139->createElement("gmd:title");
+	$title_cs=$iso19139->createElement("gco:CharacterString");
+	if (isset($mapbenderMetadata['mdTitle'])) {
+		$titleText = $iso19139->createTextNode("INSPIRE Download Service (predefined ATOM) für Datensatz ".$mapbenderMetadata['mdTitle']);
+	else {
+		$titleText = $iso19139->createTextNode("INSPIRE Download Service (predefined ATOM)");
+	$title_cs->appendChild($titleText);
+	$title->appendChild($title_cs);
+	$CI_Citation->appendChild($title);
+	//Create date elements B5.2-5.4 - format will be only a date - no dateTime given
+	//Do things for B 5.2 date of publication
+	if (isset($mapbenderMetadata['serviceTimestampCreate'])) {
+		$date1=$iso19139->createElement("gmd:date");
+		$CI_Date=$iso19139->createElement("gmd:CI_Date");
+		$date2=$iso19139->createElement("gmd:date");
+		$gcoDate=$iso19139->createElement("gco:Date");
+		$dateType=$iso19139->createElement("gmd:dateType");
+		$dateTypeCode=$iso19139->createElement("gmd:CI_DateTypeCode");
+		$dateTypeCode->setAttribute("codeList", "http://standards.iso.org/ittf/PubliclyAvailableStandards/ISO_19139_Schemas/resources/Codelist/ML_gmxCodelists.xml#CI_DateTypeCode");
+		$dateTypeCode->setAttribute("codeListValue", "publication");
+		$dateTypeCodeText=$iso19139->createTextNode('publication');
+		$dateText= $iso19139->createTextNode(date('Y-m-d',$mapbenderMetadata['serviceTimestampCreate']));
+		$dateTypeCode->appendChild($dateTypeCodeText);
+		$dateType->appendChild($dateTypeCode);
+		$gcoDate->appendChild($dateText);
+		$date2->appendChild($gcoDate);
+		$CI_Date->appendChild($date2);
+		$CI_Date->appendChild($dateType);
+		$date1->appendChild($CI_Date);
+		$CI_Citation->appendChild($date1);
+	//Do things for B 5.3 date of revision
+		$dateTypeCode->setAttribute("codeListValue", "revision");
+		$dateTypeCodeText=$iso19139->createTextNode('revision');
+		$dateText= $iso19139->createTextNode(date('Y-m-d',$mapbenderMetadata['serviceTimestamp']));
+	//Do things for B 5.4 date of creation
+	/*if (isset($mapbenderMetadata['serviceTimestampCreate'])) {
+		$dateTypeCode->setAttribute("codeListValue", "creation");
+		$dateTypeCodeText=$iso19139->createTextNode('creation');
+	$citation->appendChild($CI_Citation);
+	$SV_ServiceIdentification->appendChild($citation);
+	//Create part for abstract B 1.2
+	$abstract=$iso19139->createElement("gmd:abstract");
+	$abstract_cs=$iso19139->createElement("gco:CharacterString");
+	if (isset($mapbenderMetadata['mdAbstract']) or isset($mapbenderMetadata['mdAbstract'])) {
+			case "wmslayer":
+				$generatorText = "Get Map Aufrufen eines WMS Interfaces";
+			break;
+			case "dataurl":
+				$generatorText = "einem DataURL Link eines WMS Layers";
+			break;
+			case "wfs":
+				$generatorText = "GetFeature Anfragen an einen WFS 1.1.0";
+			break;
+		$abstractText = $iso19139->createTextNode("Beschreibung des INSPIRE Download Service (predefined Atom): ".$mapbenderMetadata['mdAbstract']." - Der/die Link(s) für das Herunterladen der Datensätze wird/werden dynamisch aus ".$generatorText." generiert");
+	else {
+		$abstractText = $iso19139->createTextNode("not yet defined");
+	$abstract_cs->appendChild($abstractText);
+	$abstract->appendChild($abstract_cs);
+	$SV_ServiceIdentification->appendChild($abstract);
+	//Create part for point of contact for service identification
+	//Define relevant objects
+	$pointOfContact=$iso19139->createElement("gmd:pointOfContact");
+	$orgaName_cs=$iso19139->createElement("gco:CharacterString");
+	$address_1=$iso19139->createElement("gmd:address");
+	$email_cs=$iso19139->createElement("gco:CharacterString");
+	$CI_RoleCode->setAttribute("codeListValue", "publisher");
+	if (isset($mapbenderMetadata['serviceDepartment'])) {
+		$resOrgaText = $iso19139->createTextNode($mapbenderMetadata['serviceDepartment']);
+	else {
+		$resOrgaText= $iso19139->createTextNode("not yet defined");
+	if (isset($mapbenderMetadata['serviceDepartmentMail'])) {
+		$resMailText = $iso19139->createTextNode($mapbenderMetadata['serviceDepartmentMail']);
+	else {
+		$resMailText = $iso19139->createTextNode("kontakt at geoportal.rlp.de");
+	$resRoleText = $iso19139->createTextNode("publisher");
+	$orgaName_cs->appendChild($resOrgaText);
+	$organisationName->appendChild($orgaName_cs);
+	$email_cs->appendChild($resMailText);
+	$electronicMailAddress->appendChild($email_cs);
+	$address_1->appendChild($CI_Address);
+	$CI_Contact->appendChild($address_1);
+	$CI_RoleCode->appendChild($resRoleText);
+	$pointOfContact->appendChild($CI_ResponsibleParty);
+	$SV_ServiceIdentification->appendChild($pointOfContact);
+	//generate graphical overview part
+	//only if generated from WMS datasource!!
+	if ($generateFrom == "wmslayer") {
+		$sql = "SELECT layer_preview.layer_map_preview_filename FROM layer_preview WHERE layer_preview.fkey_layer_id=$1";
+		$v = array((integer)$mapbenderMetadata["resourceId"]);
+		$t = array('i');
+		$row = db_fetch_array($res);
+		//use the example version of bavaria
+		if (file_exists(PREVIEW_DIR."/".$mapbenderMetadata['layer_id']."_layer_map_preview.jpg")) {	//TODO
+			$graphicOverview=$iso19139->createElement("gmd:graphicOverview");
+			$MD_BrowseGraphic=$iso19139->createElement("gmd:MD_BrowseGraphic");
+			$fileName=$iso19139->createElement("gmd:fileName");
+			$fileName_cs=$iso19139->createElement("gco:CharacterString");
+			$previewFilenameText = $iso19139->createTextNode("http://www.geoportal.rlp.de/mapbender/geoportal/preview/".$mapbenderMetadata['layer_id']."_layer_map_preview.jpg"); //TODO use constant for absolute path
+			$fileName_cs->appendChild($previewFilenameText);
+			$fileName->appendChild($fileName_cs);
+			$fileDescription=$iso19139->createElement("gmd:fileDescription");
+			$fileDescription_cs=$iso19139->createElement("gco:CharacterString");
+			$fileDescription_text=$iso19139->createTextNode("Thumbnail");
+			$fileDescription_cs->appendChild($fileDescription_text);
+			$fileDescription->appendChild($fileDescription_cs);
+			$fileType=$iso19139->createElement("gmd:fileType");
+			$fileType_cs=$iso19139->createElement("gco:CharacterString");
+			$fileType_text=$iso19139->createTextNode("JPEG");
+			$fileType_cs->appendChild($fileType_text);
+			$fileType->appendChild($fileType_cs);
+			$MD_BrowseGraphic->appendChild($fileName);
+			$MD_BrowseGraphic->appendChild($fileDescription);
+			$MD_BrowseGraphic->appendChild($fileType);
+			$graphicOverview->appendChild($MD_BrowseGraphic);
+			$SV_ServiceIdentification->appendChild($graphicOverview);
+	//TODO: switch classification for featuretypes and layer!!!
+	//generate keyword part - for services the inspire themes are not applicable!!! Nor the topic cats are! See regulation metadata
+	//pull also special keywords from custom categories - classification "inspireidentifiziert", "ngdb", "..."
+	$descriptiveKeywords=$iso19139->createElement("gmd:descriptiveKeywords");
+	$MD_Keywords=$iso19139->createElement("gmd:MD_Keywords");
+	//read keywords for resource out of the database:
+	if ($generateFrom == 'wfs') {
+		$sql = <<<SQL
+			SELECT keyword.keyword as keyword FROM keyword, wfs_featuretype_keyword WHERE wfs_featuretype_keyword.fkey_featuretype_id IN $1 AND wfs_featuretype_keyword.fkey_keyword_id=keyword.keyword_id union
+SELECT custom_category.custom_category_key as keyword FROM custom_category, wfs_featuretype_custom_category WHERE wfs_featuretype_custom_category.fkey_featuretype_id IN $1 AND wfs_featuretype_custom_category.fkey_custom_category_id =  custom_category.custom_category_id AND custom_category_hidden = 0;
+SQL;
+		//get keywords for all featuretypes
+		//$mapbenderMetadata['featureTypes'] - array of ft ids
+		$t = array('s');
+			$keyword=$iso19139->createElement("gmd:keyword");
+			$keyword_cs=$iso19139->createElement("gco:CharacterString");
+			$keywordText = $iso19139->createTextNode($row['keyword']);
+			$keyword_cs->appendChild($keywordText);
+			$keyword->appendChild($keyword_cs);
+			$MD_Keywords->appendChild($keyword);
+	} else { //dls is generated from wms for one layer
+		$sql = <<<SQL
+			SELECT keyword.keyword as keyword FROM keyword, layer_keyword WHERE layer_keyword.fkey_layer_id=$1 AND layer_keyword.fkey_keyword_id=keyword.keyword_id union
+SELECT custom_category.custom_category_key as keyword FROM custom_category, layer_custom_category WHERE layer_custom_category.fkey_layer_id = $1 AND layer_custom_category.fkey_custom_category_id =  custom_category.custom_category_id AND custom_category_hidden = 0;
+SQL;
+		$t = array('i');
+		while ($row = db_fetch_array($res)) {
+	//a special keyword for service type wms as INSPIRE likes it ;-) infoMapAccessService or infoFeatureAccessService
+	$keywordText = $iso19139->createTextNode("infoFeatureAccessService");
+	$descriptiveKeywords->appendChild($MD_Keywords);
+	$SV_ServiceIdentification->appendChild($descriptiveKeywords);
+	//Part B 3 INSPIRE Category
+	//do this only if an INSPIRE keyword (Annex I-III) is set - not applicable to services!
+	//Resource Constraints B 8
+	//do a right mapping for fees and accessconstraints to inspire MD Constraints!
+	$resourceConstraints=$iso19139->createElement("gmd:resourceConstraints");
+	$MD_LegalConstraints=$iso19139->createElement("gmd:MD_Constraints");
+	$useLimitation=$iso19139->createElement("gmd:useLimitation");
+	$useLimitation_cs=$iso19139->createElement("gco:CharacterString");
+	if(isset($mapbenderMetadata['accessconstraints'])){
+		$useLimitationText=$iso19139->createTextNode($mapbenderMetadata['accessconstraints']);
+	else
+		$useLimitationText=$iso19139->createTextNode("no conditions apply");
+ 	//TODO: Mapping of constraints between OWS/registry and INSPIRE see View Service Guidance / Draft SDS guidance
+	$useLimitation_cs->appendChild($useLimitationText);
+	$useLimitation->appendChild($useLimitation_cs);
+	$MD_LegalConstraints->appendChild($useLimitation);
+	$resourceConstraints->appendChild($MD_LegalConstraints);
+	$SV_ServiceIdentification->appendChild($resourceConstraints);
+	$MD_LegalConstraints=$iso19139->createElement("gmd:MD_LegalConstraints");
+	$accessConstraints=$iso19139->createElement("gmd:accessConstraints");
+	$MD_RestrictionCode=$iso19139->createElement("gmd:MD_RestrictionCode");
+	$MD_RestrictionCode->setAttribute("codeList", "http://standards.iso.org/ittf/PubliclyAvailableStandards/ISO_19139_Schemas/resources/Codelist/ML_gmxCodelists.xml#MD_RetrictionCode");
+	$MD_RestrictionCode->setAttribute("codeListValue", "otherRestrictions");
+	$MD_RestrictionCodeText=$iso19139->createTextNode("otherRestrictions");
+	$otherConstraints=$iso19139->createElement("gmd:otherConstraints");
+	$otherConstraints_cs=$iso19139->createElement("gco:CharacterString");
+	if (isset($mapbenderMetadata['accessconstraints']) & strtoupper($mapbenderMetadata['accessconstraints']) != 'NONE'){
+			$otherConstraintsText=$iso19139->createTextNode($mapbenderMetadata['accessconstraints']);
+	else {
+			$otherConstraintsText=$iso19139->createTextNode("no constraints");
+	$otherConstraints_cs->appendChild($otherConstraintsText);
+	$otherConstraints->appendChild($otherConstraints_cs);
+	$MD_RestrictionCode->appendChild($MD_RestrictionCodeText);
+	$accessConstraints->appendChild($MD_RestrictionCode);
+	$MD_LegalConstraints->appendChild($accessConstraints);
+	$MD_LegalConstraints->appendChild($otherConstraints);
+	/* example
+	<srv:serviceType>
+    		<gco:LocalName>view</gco:LocalName>
+	</srv:serviceType>*/
+	$serviceType=$iso19139->createElement("srv:serviceType");
+	$localName=$iso19139->createElement("gco:LocalName");
+	$serviceTypeText=$iso19139->createTextNode("download");
+	$localName->appendChild($serviceTypeText);
+	$serviceType->appendChild($localName);
+	$SV_ServiceIdentification->appendChild($serviceType);
+	$serviceTypeVersion=$iso19139->createElement("srv:serviceTypeVersion");
+	$serviceTypeVersion_cs=$iso19139->createElement("gco:CharacterString");
+	$serviceTypeVersionText=$iso19139->createTextNode("predefined ATOM");
+	$serviceTypeVersion_cs->appendChild($serviceTypeVersionText);
+	$serviceTypeVersion->appendChild($serviceTypeVersion_cs);
+	$SV_ServiceIdentification->appendChild($serviceTypeVersion);
+	//Geographical Extent
+	$bbox = array();
+	//initialize if no extent is defined in the database
+	if (!isset($mapbenderMetadata['minx']) || ($mapbenderMetadata['minx'] == '')) {
+		$mapbenderMetadata['minx'] = -180;
+		$mapbenderMetadata['miny'] = -90;
+		$mapbenderMetadata['maxx'] = 180;
+		$mapbenderMetadata['maxy'] = 90;
+	$extent=$iso19139->createElement("srv:extent");
+	$EX_Extent=$iso19139->createElement("gmd:EX_Extent");
+	$geographicElement=$iso19139->createElement("gmd:geographicElement");
+	$EX_GeographicBoundingBox=$iso19139->createElement("gmd:EX_GeographicBoundingBox");
+	$westBoundLongitude=$iso19139->createElement("gmd:westBoundLongitude");
+	$wb_dec=$iso19139->createElement("gco:Decimal");
+	$wb_text=$iso19139->createTextNode($mapbenderMetadata['minx']);
+	$eastBoundLongitude=$iso19139->createElement("gmd:eastBoundLongitude");
+	$eb_dec=$iso19139->createElement("gco:Decimal");
+	$eb_text=$iso19139->createTextNode($mapbenderMetadata['miny']);
+	$southBoundLatitude=$iso19139->createElement("gmd:southBoundLatitude");
+	$sb_dec=$iso19139->createElement("gco:Decimal");
+	$sb_text=$iso19139->createTextNode($mapbenderMetadata['maxx']);
+	$northBoundLatitude=$iso19139->createElement("gmd:northBoundLatitude");
+	$nb_dec=$iso19139->createElement("gco:Decimal");
+	$nb_text=$iso19139->createTextNode($mapbenderMetadata['maxy']);
+	$wb_dec->appendChild($wb_text);
+	$westBoundLongitude->appendChild($wb_dec);
+	$EX_GeographicBoundingBox->appendChild($westBoundLongitude);
+	$eb_dec->appendChild($eb_text);
+	$eastBoundLongitude->appendChild($eb_dec);
+	$EX_GeographicBoundingBox->appendChild($eastBoundLongitude);
+	$sb_dec->appendChild($sb_text);
+	$southBoundLatitude->appendChild($sb_dec);
+	$EX_GeographicBoundingBox->appendChild($southBoundLatitude);
+	$nb_dec->appendChild($nb_text);
+	$northBoundLatitude->appendChild($nb_dec);
+	$EX_GeographicBoundingBox->appendChild($northBoundLatitude);
+	$geographicElement->appendChild($EX_GeographicBoundingBox);
+	$EX_Extent->appendChild($geographicElement);
+	$extent->appendChild($EX_Extent);
+	$SV_ServiceIdentification->appendChild($extent);
+	//coupled resources:
+	//in case of inspire dls, we get one dls for one single metadata record
+	//we only need the metadata uuid (fileIdentifier) and resourceLocator generate the coupling information
+	$couplingType=$iso19139->createElement("srv:couplingType");
+	$SV_CouplingType=$iso19139->createElement("srv:SV_CouplingType");
+	$SV_CouplingType->setAttribute("codeList", "SV_CouplingType");
+	$SV_CouplingType->setAttribute("codeListValue", "tight");
+	$couplingType->appendChild($SV_CouplingType);
+	$SV_ServiceIdentification->appendChild($couplingType);
+	//declare coupling type:
+	/*example from guidance paper:
+<srv:couplingType>
+	<srv:SV_CouplingType codeList="SV_CouplingType" codeListValue="tight"/>
+</srv:couplingType>
+<srv:couplingType gco:nilReason="missing"/>
+<srv:containsOperations gco:nilReason="missing"/>
+<srv:operatesOn xlink:href="http://image2000.jrc.it#image2000_1_nl2_multi"/>*/
+	//to the things which have to be done for integrating the service into a client like portalu ... they have defined another location to put the GetCap URL than INSPIRE does it
+	$containsOperation=$iso19139->createElement("srv:containsOperations");
+	$SV_OperationMetadata=$iso19139->createElement("srv:SV_OperationMetadata");
+	$operationName=$iso19139->createElement("srv:operationName");
+	$operationName_cs=$iso19139->createElement("gco:CharacterString");
+	$operationNameText=$iso19139->createTextNode("Get Download Service Metadata");
+	$operationName_cs->appendChild($operationNameText);
+	$operationName->appendChild($operationName_cs);
+	//srv DCP **************************************
+	$DCP=$iso19139->createElement("srv:DCP");
+	$DCPList=$iso19139->createElement("srv:DCPList");
+	$DCPList->setAttribute("codeList", "DCPList");
+	$DCPList->setAttribute("codeListValue", "WebService");
+	$DCP->appendChild($DCPList);
+	//connectPoint **********************************
+	$connectPoint=$iso19139->createElement("srv:connectPoint");
+	$CI_OnlineResource=$iso19139->createElement("gmd:CI_OnlineResource");
+	$gmd_linkage=$iso19139->createElement("gmd:linkage");
+	$gmd_URL=$iso19139->createElement("gmd:URL");
+	//examples for links to Atom service feeds
+	//http://www.geoportal.rlp.de/mapbender/php/mod_inspireDownloadFeed.php?id=e9d22d13-e045-f0e0-25cc-1f146d681216&type=SERVICE&generateFrom=wfs&wfsid=216
+	//http://www.geoportal.rlp.de/mapbender/php/mod_inspireDownloadFeed.php?id=aaa492a3-0585-e27f-ff56-df9118420560&type=SERVICE&generateFrom=wmslayer&layerid=32566
+		case "wmslayer":
+			$gmd_URLText=$iso19139->createTextNode("http://".$_SERVER['HTTP_HOST']."/mapbender/php/mod_inspireDownloadFeed.php?id=".$recordId."&type=SERVICE&generateFrom=wmslayer&layerid=".$mapbenderMetadata['resourceId']);
+		break;
+		case "dataurl":
+			$gmd_URLText=$iso19139->createTextNode("http://".$_SERVER['HTTP_HOST']."/mapbender/php/mod_inspireDownloadFeed.php?id=".$recordId."&type=SERVICE&generateFrom=dataurl&layerid=".$mapbenderMetadata['resourceId']);
+		break;
+		case "wfs":
+			$gmd_URLText=$iso19139->createTextNode("http://".$_SERVER['HTTP_HOST']."/mapbender/php/mod_inspireDownloadFeed.php?id=".$recordId."&type=SERVICE&generateFrom=wfs&wfsid=".$mapbenderMetadata['serviceId']);
+		break;
+	//Check if anonymous user has rights to access this layer - if not ? which resource should be advertised? TODO
+	/*if ($hasPermission) {
+		$gmd_URLText=$iso19139->createTextNode("http://".$_SERVER['HTTP_HOST']."/mapbender/php/wms.php?inspire=1&layer_id=".$mapbenderMetadata['layer_id']."&REQUEST=GetCapabilities&SERVICE=WMS");
+	else {
+		$serverWithOutPort80 = str_replace(":80","",$_SERVER['HTTP_HOST']);//fix problem when metadata is generated thru curl invocations
+		$gmd_URLText=$iso19139->createTextNode("https://".$serverWithOutPort80."/http_auth/".$mapbenderMetadata['layer_id']."?REQUEST=GetCapabilities&SERVICE=WMS");
+	$gmd_URL->appendChild($gmd_URLText);
+	$gmd_linkage->appendChild($gmd_URL);
+	$CI_OnlineResource->appendChild($gmd_linkage);
+	$connectPoint->appendChild($CI_OnlineResource);
+	$SV_OperationMetadata->appendChild($operationName);
+	$SV_OperationMetadata->appendChild($DCP);
+	$SV_OperationMetadata->appendChild($connectPoint);
+	$containsOperation->appendChild($SV_OperationMetadata);
+	$SV_ServiceIdentification->appendChild($containsOperation);
+	//fill in operatesOn fields with datasetid if given
+	/*INSPIRE example: <srv:operatesOn xlink:href="http://image2000.jrc.it#image2000_1_nl2_multi"/>*/
+	/*INSPIRE demands a href for the metadata record!*/
+	/*TODO: Exchange HTTP_HOST with other baseurl*/
+		//$mapbenderMetadata['mdTitle'] = $mbMetadata['title'];
+		//$mapbenderMetadata['mdAbstract'] = $mbMetadata['abstract'];
+		//$mapbenderMetadata['mdRefSystem'] = $mbMetadata['ref_sytem'];
+		//$mapbenderMetadata['datasetId'] = $mbMetadata['datasetid'];
+		//$mapbenderMetadata['mdOrigin'] = $mbMetadata['origin'];
+	switch ($mapbenderMetadata['mdOrigin']) {
+		case 'capabilities':
+			$operatesOn=$iso19139->createElement("srv:operatesOn");
+			$operatesOn->setAttribute("xlink:href", "http://".$_SERVER['HTTP_HOST']."/mapbender/php/mod_dataISOMetadata.php?outputFormat=iso19139&id=".$recordId);
+			$operatesOn->setAttribute("uuidref", $mapbenderMetadata['datasetId']);
+			$SV_ServiceIdentification->appendChild($operatesOn);
+		break;
+		case 'metador':
+			if (defined('METADATA_DEFAULT_CODESPACE')) {
+				$operatesOn->setAttribute("uuidref", METADATA_DEFAULT_CODESPACE."#".$recordId);
+			} else {
+				$operatesOn->setAttribute("uuidref", "http://www.mapbender.org#".$recordId);
+		break;
+		case 'external':
+			$operatesOn->setAttribute("uuidref", $recordId);
+		break;
+		default:
+		break;
+	$identificationInfo->appendChild($SV_ServiceIdentification);
+	//distributionInfo - is demanded from iso19139
+	$gmd_distributionInfo=$iso19139->createElement("gmd:distributionInfo");
+	$MD_Distribution=$iso19139->createElement("gmd:MD_Distribution");
+	$gmd_distributionFormat=$iso19139->createElement("gmd:distributionFormat");
+	$MD_Format=$iso19139->createElement("gmd:MD_Format");
+	$gmd_name=$iso19139->createElement("gmd:name");
+	$gmd_version=$iso19139->createElement("gmd:version");
+	$gmd_name->setAttribute("gco:nilReason", "inapplicable");
+	$gmd_version->setAttribute("gco:nilReason", "inapplicable");//TODO set DataFormat
+	$gmd_transferOptions=$iso19139->createElement("gmd:transferOptions");
+	$MD_DigitalTransferOptions=$iso19139->createElement("gmd:MD_DigitalTransferOptions");
+	$gmd_onLine=$iso19139->createElement("gmd:onLine");
+		$gmd_URLText=$iso19139->createTextNode($mapbenderMetadata['datalink_url']);
+	else {
+		$gmd_URLText=$iso19139->createTextNode("https://".$_SERVER['HTTP_HOST']."/http_auth/".$mapbenderMetadata['layer_id']."?REQUEST=GetCapabilities&SERVICE=WMS");
+	$gmd_URL->appendChild($gmd_URLText);//same as before
+	//append things which geonetwork needs to invoke service/layer or what else? - Here the name of the layer and the protocol seems to be needed?
+	//a problem will occur, if the link to get map is not the same as the link to get caps? So how can we handle this? It seems to be very silly!
+	$gmdProtocol = $iso19139->createElement("gmd:protocol");
+	$gmdProtocol_cs = $iso19139->createElement("gco:CharacterString");
+	$gmdProtocolText = $iso19139->createTextNode("http-get");//?TODO what to put in here?
+	/*$gmdName=$iso19139->createElement("gmd:name");
+	$gmdName_cs=$iso19139->createElement("gco:CharacterString");
+	$gmdNameText=$iso19139->createTextNode($mapbenderMetadata['layer_name']); //Layername?
+	$gmdDescription = $iso19139->createElement("gmd:description");
+	$gmdDescription_cs = $iso19139->createElement("gco:CharacterString");
+	$gmdDescriptionText = $iso19139->createTextNode($mapbenderMetadata['layer_abstract']);//Layer Abstract -TODO use metadata abstract if given
+	$gmdProtocol_cs->appendChild($gmdProtocolText);
+	$gmdProtocol->appendChild($gmdProtocol_cs);
+	$CI_OnlineResource->appendChild($gmdProtocol);
+	/*$gmdName_cs->appendChild($gmdNameText);
+	$gmdName->appendChild($gmdName_cs);
+	$CI_OnlineResource->appendChild($gmdName);
+	$gmdDescription_cs->appendChild($gmdDescriptionText);
+	$gmdDescription->appendChild($gmdDescription_cs);
+	$CI_OnlineResource->appendChild($gmdDescription);
+	$gmd_onLine->appendChild($CI_OnlineResource);
+	$MD_DigitalTransferOptions->appendChild($gmd_onLine);
+	$gmd_transferOptions->appendChild($MD_DigitalTransferOptions);
+	$MD_Format->appendChild($gmd_name);
+	$MD_Format->appendChild($gmd_version);
+	$gmd_distributionFormat->appendChild($MD_Format);
+	$MD_Distribution->appendChild($gmd_distributionFormat);
+	$MD_Distribution->appendChild($gmd_transferOptions);
+	$gmd_distributionInfo->appendChild($MD_Distribution);
+	//dataQualityInfo
+	$gmd_dataQualityInfo=$iso19139->createElement("gmd:dataQualityInfo");
+	$DQ_DataQuality=$iso19139->createElement("gmd:DQ_DataQuality");
+	$gmd_scope=$iso19139->createElement("gmd:scope");
+	$DQ_Scope=$iso19139->createElement("gmd:DQ_Scope");
+	$gmd_level=$iso19139->createElement("gmd:level");
+	$MD_ScopeCode=$iso19139->createElement("gmd:MD_ScopeCode");
+	$MD_ScopeCodeText=$iso19139->createTextNode("service");
+	$MD_ScopeCode->setAttribute("codeList", "http://standards.iso.org/ittf/PubliclyAvailableStandards/ISO_19139_Schemas/resources/Codelist/ML_gmxCodelists.xml#MD_ScopeCode");
+	$MD_ScopeCode->setAttribute("codeListValue", "service");
+	$MD_ScopeCode->appendChild($MD_ScopeCodeText);
+	$gmd_level->appendChild($MD_ScopeCode);
+	$DQ_Scope->appendChild($gmd_level);
+	$gmd_scope->appendChild($DQ_Scope);
+	$DQ_DataQuality->appendChild($gmd_scope);
+	//gmd:report in dataQualityInfo
+	$gmd_report=$iso19139->createElement("gmd:report");
+	$DQ_DomainConsistency=$iso19139->createElement("gmd:DQ_DomainConsistency");
+	$DQ_DomainConsistency->setAttribute("xsi:type","gmd:DQ_DomainConsistency_Type");
+	$gmd_result=$iso19139->createElement("gmd:result");
+	$DQ_ConformanceResult=$iso19139->createElement("gmd:DQ_ConformanceResult");
+	$gmd_specification=$iso19139->createElement("gmd:specification");
+	$gmd_title=$iso19139->createElement("gmd:title");
+	$gmd_title_cs=$iso19139->createElement("gco:CharacterString");
+	$gmd_titleText=$iso19139->createTextNode("Service Abstract Suite"); //TODO put in the inspire test suites from mb database!
+	$gmd_date=$iso19139->createElement("gmd:date");
+	$gmd_date_2=$iso19139->createElement("gmd:date");
+	$gco_Date=$iso19139->createElement("gco:Date");
+	$gco_DateText=$iso19139->createTextNode("2010-03-10"); //TODO put in the info from database
+	$gmd_dateType=$iso19139->createElement("gmd:dateType");
+	$CI_DateTypeCode=$iso19139->createElement("gmd:CI_DateTypeCode");
+	$CI_DateTypeCode->setAttribute("codeList","http://standards.iso.org/ittf/PubliclyAvailableStandards/ISO_19139_Schemas/resources/Codelist/ML_gmxCodelists.xml#CI_DateTypeCode");
+	$CI_DateTypeCode->setAttribute("codeListValue","publication");
+	$CI_DateTypeCodeText=$iso19139->createTextNode("publication");
+	$gmd_explanation=$iso19139->createElement("gmd:explanation");
+	$gmd_explanation_cs=$iso19139->createElement("gco:CharacterString");
+	$gmd_explanationText=$iso19139->createTextNode("No explanation available");
+	$gmd_pass=$iso19139->createElement("gmd:pass");
+	$gco_Boolean=$iso19139->createElement("gco:Boolean");
+	$gco_BooleanText=$iso19139->createTextNode("true"); //TODO maybe set here a string cause it can be unevaluated!! See Implementing Rules
+	//generate XML objects
+	$gco_Date->appendChild($gco_DateText);
+	$gmd_date->appendChild($gco_Date);
+	$CI_DateTypeCode->appendChild($CI_DateTypeCodeText);
+	$gmd_dateType->appendChild($CI_DateTypeCode);
+	$CI_Date->appendChild($gmd_date);
+	$CI_Date->appendChild($gmd_dateType);
+	$gmd_date_2->appendChild($CI_Date);
+	$gmd_title_cs->appendChild($gmd_titleText);
+	$gmd_title->appendChild($gmd_title_cs);
+	$CI_Citation->appendChild($gmd_title);
+	$CI_Citation->appendChild($gmd_date_2);
+	$gmd_specification->appendChild($CI_Citation);
+	$gmd_explanation_cs->appendChild($gmd_explanationText);
+	$gmd_explanation->appendChild($gmd_explanation_cs);
+	$gco_Boolean->appendChild($gco_BooleanText);
+	$gmd_pass->appendChild($gco_Boolean);
+	$DQ_ConformanceResult->appendChild($gmd_specification);
+	$DQ_ConformanceResult->appendChild($gmd_explanation);
+	$DQ_ConformanceResult->appendChild($gmd_pass);
+	$gmd_result->appendChild($DQ_ConformanceResult);
+	$DQ_DomainConsistency->appendChild($gmd_result);
+	$gmd_report->appendChild($DQ_DomainConsistency);
+	$DQ_DataQuality->appendChild($gmd_report);
+	$gmd_dataQualityInfo->appendChild($DQ_DataQuality);
+	//$MD_ScopeCode->setAttribute("codeListValue", "service");
+	$MD_Metadata->appendChild($identificationInfo);
+	$MD_Metadata->appendChild($gmd_distributionInfo);
+	$MD_Metadata->appendChild($gmd_dataQualityInfo);
+	return $iso19139->saveXML();
+	//function to give away the xml data
+	function pushISO19139($iso19139Doc, $recordId) {
+		//echo $recordId;
+		header("Content-type: application/xhtml+xml; charset=UTF-8");
+		$xml = fillISO19139($iso19139Doc, $recordId);
+		echo $xml;
+		die();
+	//function to validate against the inspire validation service
+	function validateInspireMetadata($iso19139Doc, $recordId){
+		$validatorUrl = 'http://www.inspire-geoportal.eu/INSPIREValidatorService/resources/validation/inspire';
+		//$validatorUrl2 = 'http://localhost/mapbender/x_geoportal/log_requests.php';
+		//send inspire xml to validator and push the result to requesting user
+		$validatorInterfaceObject = new connector();
+		$validatorInterfaceObject->set('httpType','POST');
+		//$validatorInterfaceObject->set('httpContentType','application/xml');
+		$validatorInterfaceObject->set('httpContentType','multipart/form-data'); // maybe given automatically
+		//first test with data from ram - doesn't function
+		$fields = array(
+			'dataFile'=>urlencode($xml)
+		//generate file identifier:
+		$fileId = guid();
+		//generate temporary file under tmp
+		 if($h = fopen(TMPDIR."/".$fileId."iso19139_validate_tmp.xml","w")){
+			if(!fwrite($h,$xml)){
+				$e = new mb_exception("mod_layerISOMetadata: cannot write to file: ".TMPDIR."iso19139_validate_tmp.xml");
+		fclose($h);
+		//send file as post like described under http://www.tecbrat.com/?itemid=13&catid=1
+		$fields['dataFile']='@'.TMPDIR.'/'.$fileId.'iso19139_validate_tmp.xml';
+		//if we give a string with parameters
+		//foreach($fields as $key=>$value) { $fields_string .= $key.'='.$value.'&'; }
+		//rtrim($fields_string,'&');
+		//$postData = $fields_string;
+		$postData = $fields;
+		//$e = new mb_exception("mod_layerISOMetadata: postData: ".$postData['dataFile']);
+		//number of post fields:
+		//curl_setopt($ch,CURLOPT_POST,count($fields));
+		$validatorInterfaceObject->set('httpPostFieldsNumber',count($postData));
+		$validatorInterfaceObject->set('curlSendCustomHeaders',false);
+		//$validatorInterfaceObject->set('httpPostData', $postData);
+		$validatorInterfaceObject->set('httpPostData', $postData); //give an array
+		$validatorInterfaceObject->load($validatorUrl);
+		header("Content-type: text/html; charset=UTF-8");
+		echo $validatorInterfaceObject->file;
+		//delete file in tmp
+		//TODO - this normally done by a cronjob
+		die();
+function getEpsgByLayerId ($layer_id) { // from merge_layer.php
+	$epsg_list = "";
+	$sql = "SELECT DISTINCT epsg FROM layer_epsg WHERE fkey_layer_id = $1";
+	$v = array($layer_id);
+	$t = array('i');
+	$res = db_prep_query($sql, $v, $t);
+	while($row = db_fetch_array($res)){
+		$epsg_list .= $row['epsg'] . " ";
+	return trim($epsg_list);
+function getEpsgArrayByLayerId ($layer_id) { // from merge_layer.php
+	//$epsg_list = "";
+	$epsg_array=array();
+	$t = array('i');
+	$cnt=0;
+		$epsg_array[$cnt] = $row['epsg'];
+		$cnt++;
+	return $epsg_array;
+function guid(){
+    if (function_exists('com_create_guid')){
+        return com_create_guid();
+    }else{
+        mt_srand((double)microtime()*10000);//optional for php 4.2.0 and up.
+        $charid = strtoupper(md5(uniqid(rand(), true)));
+        $hyphen = chr(45);// "-"
+        $uuid = chr(123)// "{"
+                .substr($charid, 0, 8).$hyphen
+                .substr($charid, 8, 4).$hyphen
+                .substr($charid,12, 4).$hyphen
+                .substr($charid,16, 4).$hyphen
+                .substr($charid,20,12)
+                .chr(125);// "}"
+        return $uuid;
+//do all the other things which had to be done ;-)
+if ($_REQUEST['VALIDATE'] == "true"){
+	validateInspireMetadata($iso19139Doc, $recordId);
+} else {
+	pushISO19139($iso19139Doc, $recordId); //throw it out to world!
Modified: trunk/mapbender/http/php/mod_inspireDownloadFeed.php
--- trunk/mapbender/http/php/mod_inspireDownloadFeed.php	2012-11-26 10:23:38 UTC (rev 8511)
+++ trunk/mapbender/http/php/mod_inspireDownloadFeed.php	2012-11-26 20:36:14 UTC (rev 8512)
@@ -130,7 +130,7 @@
-	//check if layerId is set too
@@ -413,7 +413,7 @@
 	//<link href="http://xyz.org/metadata" rel="describedby" type="application/vnd.iso.19139+xml"/>
 	$feedLink = $feedDoc->createElement("link");
 	if ($type == 'SERVICE') {
-		$feedLink->setAttribute("href", $mapbenderPath."php/mod_dataLinkDownloadISOMetadata.php?Id=".$recordId."&outputFormat=iso19139");
+		$feedLink->setAttribute("href", $mapbenderPath."php/mod_inspireAtomFeedISOMetadata.php?Id=".$recordId."&outputFormat=iso19139&generateFrom=".$generateFrom);
 	} else { //DATASET
 		$feedLink->setAttribute("href", $mapbenderPath."php/mod_dataISOMetadata.php?id=".$mapbenderMetadata[$m]->metadata_uuid."&outputFormat=iso19139");
Modified: trunk/mapbender/http/php/mod_showMetadata.php
--- trunk/mapbender/http/php/mod_showMetadata.php	2012-11-26 10:23:38 UTC (rev 8511)
+++ trunk/mapbender/http/php/mod_showMetadata.php	2012-11-26 20:36:14 UTC (rev 8512)
@@ -1070,24 +1070,6 @@
 	$i = 0;
 	$metadataList = "";
 	while ($row = db_fetch_assoc($res)) {
-		//check for existing download options
-		/*$sqlDownload = <<<SQL
-		select count(*) from (select metadata_id as data from (select metadata_id, layer_id from (select fkey_metadata_id, layer_id from layer inner join ows_relation_metadata on layer.layer_id = ows_relation_metadata.fkey_layer_id) as layer_relation
- inner join mb_metadata on layer_relation.fkey_metadata_id = mb_metadata.metadata_id where mb_metadata.uuid = $1) as layer_metadata inner join ows_relation_data on ows_relation_data.fkey_layer_id = layer_metadata.layer_id union select mb_metadata.metadata_id as data from mb_metadata right join ows_relation_metadata on mb_metadata.metadata_id = ows_relation_metadata.fkey_metadata_id where mb_metadata.uuid = $1) as foo
-SQL;*/
-		select count(*) from (select mb_metadata.metadata_id as data from mb_metadata right join ows_relation_metadata on mb_metadata.metadata_id = ows_relation_metadata.fkey_metadata_id where mb_metadata.uuid = $1) as foo
-SQL;*/
-		//TODO: INSPIRE Download: It must be tested, if inspire_download is set to 1!!
-/*		$v = array($row["uuid"]);
-		$t = array('s');
-		$resDownload = db_prep_query($sqlDownload,$v,$t);
-		$rowDownload = db_fetch_assoc($resDownload);
-		$e = new mb_notice($rowDownload['count']);
-		$e = new mb_notice($row['uuid']);*/
-		//$html .= "<li>";
 		switch ($row["origin"]) {
 			case "capabilities" :
 				$metadataList .= "<img src='../img/osgeo_graphics/geosilk/server_map.png' title='".$translation['metadata from capabilities']."'/>";
More information about the Mapbender_commits mailing list
