[Mapbender-commits] r8559 - in trunk/mapbender: http_auth/http	owsproxy/http
    svn_mapbender at osgeo.org
    Thu Feb  7 06:07:38 PST 2013
Author: armin11
Date: 2013-02-07 06:07:37 -0800 (Thu, 07 Feb 2013)
New Revision: 8559
   trunk/mapbender/http_auth/http/index.php
   trunk/mapbender/owsproxy/http/index.php
Fix a problem with legendgraphics thru owsproxy and http_auth proxy. Sometimes only the request part of the legendurl is stored in layer_style table. This may be done if getlegendgraphics is supported by the wms. In this case the url for capturing the legend have to be combined by the proxy ;-) .
Modified: trunk/mapbender/http_auth/http/index.php
--- trunk/mapbender/http_auth/http/index.php	2013-02-07 12:40:39 UTC (rev 8558)
+++ trunk/mapbender/http_auth/http/index.php	2013-02-07 14:07:37 UTC (rev 8559)
@@ -1,564 +1,580 @@
-<?php
-require(dirname(__FILE__) . "/../../conf/mapbender.conf");
-require(dirname(__FILE__) . "/../../http/classes/class_administration.php");
-require(dirname(__FILE__) . "/../../http/classes/class_connector.php");
-require_once(dirname(__FILE__) . "/../../http/classes/class_mb_exception.php");
-require(dirname(__FILE__) . "/../../owsproxy/http/classes/class_QueryHandler.php");
-//database connection
-$db = db_connect($DBSERVER,$OWNER,$PW);
-db_select_db(DB,$db);
-$imageformats = array("image/png","image/gif","image/jpeg", "image/jpg");
-//control if digest auth is set, if not set, generate the challenge with getNonce()
-if (empty($_SERVER['PHP_AUTH_DIGEST'])) {
-    header('HTTP/1.1 401 Unauthorized');
-    header('WWW-Authenticate: Digest realm="'.REALM.
-           '",qop="auth",nonce="'.getNonce().'",opaque="'.md5(REALM).'"');
-    die('Text to send if user hits Cancel button');
-//read out the header in an array
-$requestHeaderArray = http_digest_parse($_SERVER['PHP_AUTH_DIGEST']);
-//error if header could not be read
-if (!($requestHeaderArray)) {
-	echo 'Following Header information cannot be validated - check your clientsoftware!<br>';
-	echo $_SERVER['PHP_AUTH_DIGEST'].'<br>';
-	die();
-//get mb_username and email out of http_auth username string
-$userIdentification = explode(';',$requestHeaderArray['username']);
-$mbUsername = $userIdentification[0];
-$mbEmail = $userIdentification[1];
-$userInformation = getUserInfo($mbUsername,$mbEmail);
-if ($userInformation[0] == '-1') {
-	die('User with name: '.$mbUsername.' and email: '.$mbEmail.' not known to security proxy!');
-if ($userInformation[1]=='') { //check if digest exists in db - if no digest exists it should be a null string!
-	die('User with name: '.$mbUsername.' and email: '.$mbEmail.' has no digest - please set a new password and try again!');
-//first check the stale!
-if($requestHeaderArray['nonce'] == getNonce()) {
-                        // Up-to-date nonce received
-                        $stale = false;
-                    } else {
-                        // Stale nonce received (probably more than x seconds old)
-                        $stale = true;
-			//give another chance to authenticate
-    			header('WWW-Authenticate: Digest realm="'.REALM.'",qop="auth",nonce="'.getNonce().'",opaque="'.md5(REALM).'" ,stale=true');
-// generate the valid response to check the request of the client
-$A1 = $userInformation[1];
-$A2 = md5($_SERVER['REQUEST_METHOD'].':'.$requestHeaderArray['uri']);
-$valid_response = $A1.':'.getNonce().':'.$requestHeaderArray['nc'];
-$valid_response .= ':'.$requestHeaderArray['cnonce'].':'.$requestHeaderArray['qop'].':'.$A2;
-$valid_response=md5($valid_response);
-if ($requestHeaderArray['response'] != $valid_response) {//the user have to authenticate new - cause something in the authentication went wrong
-    die('Authentication failed - sorry, you have to authenticate once more!');
-//if we are here - authentication has been done well!
-//let's do the proxy things (came from owsproxy.php):
-$postdata = $HTTP_RAW_POST_DATA;
-$layerId = $_REQUEST['layer_id'];
-$query = new QueryHandler();
-// an array with keys and values toLoserCase -> caseinsensitiv
-$reqParams = $query->getRequestParams();
-$n = new administration();
-$wmsId = getWmsIdByLayerId($layerId);
-$owsproxyString = $n->getWMSOWSstring($wmsId);
-if (!$owsproxyString) {
-	die('The requested resource does not exists or the routing through mapbenders owsproxy is not activated!');
-//get authentication infos if they are available in wms table! if not $auth = false
-$auth = $n->getAuthInfoOfWMS($wmsId);
-if ($auth['auth_type']==''){
-	unset($auth);
-$e = new mb_exception("REQUEST to HTTP_AUTH: ".strtolower($reqParams['request']));
-//what the proxy does
-switch (strtolower($reqParams['request'])) {
-	case 'getcapabilities':
-		$arrayOnlineresources = checkWmsPermission($wmsId,$userInformation[0]);
-		$query->setOnlineResource($arrayOnlineresources['wms_getcapabilities']);
-		//$request = preg_replace("/(.*)frames\/login.php/", "$1php/wms.php?layer_id=".$layerId, LOGIN);
-		if (isset($_SERVER["HTTPS"])){
-			$urlPrefix = "https://";
-		} else {
-			$urlPrefix = "http://";
-		if (defined("MAPBENDER_PATH") && MAPBENDER_PATH != '') {
-			$request = MAPBENDER_PATH."/php/wms.php?layer_id=".$layerId;
-		} else {
-			$request = $urlPrefix.$_SERVER['HTTP_HOST']."/mapbender/php/wms.php?layer_id=".$layerId;
-		$requestFull .= $request.'&REQUEST=GetCapabilities&VERSION=1.1.1&SERVICE=WMS';
-		if(isset($auth)){
-			getCapabilities($request,$requestFull,$auth);
-		else {
-			getCapabilities($request,$requestFull);
-		break;
-	case 'getfeatureinfo':
-		$query->setOnlineResource($arrayOnlineresources['wms_getfeatureinfo']);
-		$layers = checkLayerPermission($wmsId,$reqParams['layers'],$userInformation[0]);
-		if ($layers == '' ) {
-		throwE("GetFeatureInfo permission denied on layer with id".$layerId);
-		die();
-		$request = $query->getRequest();
-		if(isset($auth)){
-			getFeatureInfo($request,$auth);
-		else {
-			getFeatureInfo($request);
-		break;
-	case 'getmap':
-		$query->setOnlineResource($arrayOnlineresources['wms_getmap']);
-			throwE("GetMap permission denied on layer with id ".$layerId);
-		die();
-		$query->setParam("layers",urldecode($layers));
-		#log proxy requests
-		if($n->getWmsLogTag($wmsId)==1) {
-			#do log to db
-			#TODO read out size of bbox and calculate price
-		        #get price out of db
-			$price=intval($n->getWmsPrice($wmsId));
-			$n->logWmsProxyRequest($wmsId,$userInformation[0],$request,$price);
-		if(isset($auth)){
-			getImage($request,$auth);
-		else {
-			getImage($request);
-		break;
-	case 'getlegendgraphic':
-		$url = getLegendUrl($wmsId);
-		$e = new mb_exception("URL for getlegendgraphic: ");
-		if(isset($auth)){
-			getImage($url,$auth);
-		else {
-			getImage($url);
-		break;
-	default:
-echo 'Your are logged in as: <b>' .$requestHeaderArray['username'].'</b> and requested the layer with id=<b>'.$layerId.'</b> but your request is not a valid OWS request';
-//functions for http_auth
-// function to parse the http auth header
-function http_digest_parse($txt)
-    // protect against missing data
-    $needed_parts = array('nonce'=>1, 'nc'=>1, 'cnonce'=>1, 'qop'=>1, 'username'=>1, 'uri'=>1, 'response'=>1);
-    $data = array();
-    $keys = implode('|', array_keys($needed_parts));
-    preg_match_all('@(' . $keys . ')=(?:([\'"])([^\2]+?)\2|([^\s,]+))@', $txt, $matches, PREG_SET_ORDER);
-    foreach ($matches as $m) {
-        $data[$m[1]] = $m[3] ? $m[3] : $m[4];
-        unset($needed_parts[$m[1]]);
-    return $needed_parts ? false : $data;
-// function to get relevant user information from mb db
-function getUserInfo($mbUsername,$mbEmail) {
-	$result = array();
-	$sql = "SELECT mb_user_id, mb_user_digest FROM mb_user where mb_user_name = $1 AND mb_user_email= $2";
-	$v = array($mbUsername, $mbEmail);
-	$t = array("s","s");
-	$res = db_prep_query($sql, $v, $t);
-	if(!($row = db_fetch_array($res))){
-		$result[0] = "-1";
-	else {
-		$result[0] = $row['mb_user_id'];
-		$result[1] = $row['mb_user_digest'];
-	return $result;
-function getNonce() {
-	global $nonceLife;
-	$time = ceil(time() / $nonceLife) * $nonceLife;
-	return md5(date('Y-m-d H:i', $time).':'.$_SERVER['REMOTE_ADDR'].':'.NONCEKEY);
-//functions of owsproxy/http/index.php
-function throwE($e){
-	global $reqParams, $imageformats;
-	if(in_array($reqParams['format'],$imageformats)){
-		throwImage($e);
-	else{
-		throwText($e);
-function throwImage($e){
-	global $reqParams;
-	if (!$reqParams['width'] || !$reqParams['height']) { //width or height are not set by ows request - maybe for legendgraphics
-		$width = 300;
-		$height = 20;
-	$image = imagecreate($width,$height);
-	$transparent = ImageColorAllocate($image,155,155,155);
-	ImageFilledRectangle($image,0,0,$width,$height,$transparent);
-	imagecolortransparent($image, $transparent);
-	$text_color = ImageColorAllocate ($image, 233, 14, 91);
-	for($i=0; $i<count($e); $i++){
-		ImageString ($image, 3, 5, $i*20, $e[$i], $text_color);
-	responseImage($image);
-function throwText($e){
-	echo join(" ", $e);
-function responseImage($im){
-	$format = $reqParams['format'];
-	if($format == 'image/png'){header("Content-Type: image/png");}
-	if($format == 'image/jpeg' || $format == 'image/jpg'){header("Content-Type: image/jpeg");}
-	if($format == 'image/gif'){header("Content-Type: image/gif");}
-	if($format == 'image/png'){imagepng($im);}
-	if($format == 'image/jpeg' || $format == 'image/jpg'){imagejpeg($im);}
-	if($format == 'image/gif'){imagegif($im);}
-function completeURL($url){
-	$mykeys = array_keys($reqParams);
-	for($i=0; $i<count($mykeys);$i++){
-		if($i > 0){ $url .= "&"; }
-		$url .= $mykeys[$i]."=".urlencode($reqParams[$mykeys[$i]]);
-	return $url;
- * fetch and returns an image to client
- * @param string the original url of the image to send
-function getImage($or){
-	header("Content-Type: ".$reqParams['format']);
-	if (func_num_args() == 2) { //new for HTTP Authentication
-		$auth = func_get_arg(1);
-		echo getDocumentContent($or,$auth);
-	else
-		echo getDocumentContent($or);
- * fetchs and returns the content of the FeatureInfo Response
- * @param string the url of the FeatureInfoRequest
- * @return string the content of the FeatureInfo document
-function getFeatureInfo($url){
-	$e = new mb_exception("owsproxy: Try to fetch FeatureInfoRequest: ".$url);
-	header("Content-Type: ".$reqParams['info_format']);
-		echo getDocumentContent($url,$auth);
-	else
-		echo getDocumentContent($url);
-function matchUrls($content){
-	if(!session_is_registered("owsproxyUrls")){
-		$_SESSION["owsproxyUrls"] = array();
-		$_SESSION["owsproxyUrls"]["id"] = array();
-		$_SESSION["owsproxyUrls"]["url"] = array();
-	$pattern = "/[\"|\'](https*:\/\/[^\"|^\']*)[\"|\']/";
-	preg_match_all($pattern,$content,$matches);
-	for($i=0; $i<count($matches[1]); $i++){
-		$req = $matches[1][$i];
-		$e = new mb_exception("Gefundene URL ".$i.": ".$req);
-		#$notice = new mb_notice("owsproxy id:".$req);
-		$id = registerURL($req);
-		$extReq = setExternalRequest($id);
-		$e = new mb_exception("MD5 URL ".$id."-Externer Link: ".$extReq);
-		$content = str_replace($req,$extReq,$content);
-	return $content;
-function setExternalRequest($id){
-	global $reqParams,$query;
-	$extReq = "http://".$_SESSION['HTTP_HOST'] ."/owsproxy/". $reqParams['sid'] ."/".$id."?request=external";
-	return $extReq;
-function getExternalRequest($id){
-	for($i=0; $i<count($_SESSION["owsproxyUrls"]["url"]); $i++){
-		if($id == $_SESSION["owsproxyUrls"]["id"][$i]){
-			$cUrl = $_SESSION["owsproxyUrls"]["url"][$i];
-			$query_string = removeOWSGetParams($_SERVER["QUERY_STRING"]);
-			if($query_string != ''){
-				$cUrl .= getConjunctionCharacter($cUrl).$query_string;
-			$metainfo = get_headers($cUrl,1);
-			// just for the stupid InternetExplorer
-			header('Pragma: private');
-			header('Cache-control: private, must-revalidate');
-			header("Content-Type: ".$metainfo['Content-Type']);
-			$content = getDocumentContent($cUrl,false);
-			#$content = matchUrls($content); //In the case of http_auth - this is not possible cause we cannot save them in the header - maybe we could create a special session to do so later on?
-			echo $content;
-function removeOWSGetParams($query_string){
-	$r = preg_replace("/.*request=external&/","",$query_string);
-	#return $r;
-	return "";
-function getConjunctionCharacter($url){
-	if(strpos($url,"?")){
-		if(strpos($url,"?") == strlen($url)){
-			$cchar = "";
-		}else if(strpos($url,"&") == strlen($url)){
-			$cchar = "";
-		}else{
-			$cchar = "&";
-	if(strpos($url,"?") === false){
-		$cchar = "?";
-	return $cchar;
-function registerUrl($url){
-	if(!in_array($url,$_SESSION["owsproxyUrls"]["url"])){
-		$e = new mb_exception("Is noch net drin!");
-		$id = md5($url);
-		$e = new mb_exception("ID: ".$id."  URL: ".$url." will be written to session");
-		array_push($_SESSION["owsproxyUrls"]["url"],$url);
-		array_push($_SESSION["owsproxyUrls"]["id"], $id);
-	else{
-		$e = new mb_exception("It was found! Search content and return ID!");
-		$e = new mb_exception("Content ".$i." : proxyurl:".$_SESSION["owsproxyUrls"]["url"][$i]." - new: ".$url);
-		if($url == $_SESSION["owsproxyUrls"]["url"][$i]){
-			$e = new mb_exception("Identical! ID:".$_SESSION["owsproxyUrls"]["id"][$i]." will be used");
-			$id = $_SESSION["owsproxyUrls"]["id"][$i];
-	return $id;
-function getCapabilities($request,$requestFull){
-	global $arrayOnlineresources;
-	global $layerId;
-	header("Content-Type: application/xml");
-	if (func_num_args() == 3) { //new for HTTP Authentication
-		$auth = func_get_arg(2);
-		$content = getDocumentContent($requestFull,$auth);
-	else
-		$content = getDocumentContent($requestFull);
-	//show temporal content fo capabilities
-	$e = new mb_notice("content from wms.php fascade after going thru curl: ".$content);
-	//loading as xml
-	libxml_use_internal_errors(true);
-	try {
-		$capFromFascadeXmlObject = simplexml_load_string($content);
-		if ( $capFromFascadeXmlObject === false) {
-			foreach(libxml_get_errors() as $error) {
-        			$err = new mb_exception("http_auth/index.php: ".$error->message);
-			throw new Exception("http_auth/index.php: ".'Cannot parse Metadata XML!');
-			echo "<error>http_auth/index.php: Cannot parse Capabilities XML!</error>";
-			die();
-	catch (Exception $e) {
-    		$err = new mb_exception("http_auth/index.php: ".$e->getMessage());
-		echo "<error>http_auth/index.php: ".$e->getMessage()."</error>";
-		die();
-	//exchanging urls in some special fields
-	//GetCapabilities, GetMap, GetFeatureInfo, GetLegendGraphics, ...
-	$capFromFascadeXmlObject->registerXPathNamespace("xlink", "http://www.w3.org/1999/xlink");
-	//Mapping of urls for wms 1.1.1 which should be exchanged
-	$urlsToChange = array(
-		'/WMT_MS_Capabilities/Capability/Request/GetCapabilities/DCPType/HTTP/Get/OnlineResource/@xlink:href',
-		'/WMT_MS_Capabilities/Capability/Request/GetCapabilities/DCPType/HTTP/Post/OnlineResource/@xlink:href',
-		'/WMT_MS_Capabilities/Capability/Request/GetMap/DCPType/HTTP/Get/OnlineResource/@xlink:href',
-		'/WMT_MS_Capabilities/Capability/Request/GetMap/DCPType/HTTP/Post/OnlineResource/@xlink:href',
-		'/WMT_MS_Capabilities/Capability/Request/GetFeatureInfo/DCPType/HTTP/Get/OnlineResource/@xlink:href',
-		'/WMT_MS_Capabilities/Capability/Request/GetFeatureInfo/DCPType/HTTP/Post/OnlineResource/@xlink:href',
-		'/WMT_MS_Capabilities/Capability/Layer/Layer/Style/LegendURL/OnlineResource/@xlink:href'
-	foreach($urlsToChange as $xpath) {
-		$href = $capFromFascadeXmlObject->xpath($xpath);
-		$e = new mb_notice("old href: ".$href[0]);
-		$e = new mb_notice("href replaced: ".replaceOwsUrls($href[0], $layerId));
-		$href[0][0] = replaceOwsUrls($href[0], $layerId);
-	echo $capFromFascadeXmlObject->asXML();
-function replaceOwsUrls($owsUrl, $layerId) {
-	$new = "http_auth/". $layerId."?";
-        $pattern = "#owsproxy/[a-z0-9]{32}\/[a-z0-9]{32}\?#m";
-	$httpAuthUrl = preg_replace($pattern,$new,$owsUrl);
-	return $httpAuthUrl;
- * gets the original url of the requested legend graphic
- * @param string owsproxy md5
- * @return string url to legend graphic
-function getLegendUrl($wmsId){
-	//get the url
-	$sql = "SELECT layer_style.legendurl ";
-	$sql .= "FROM layer_style JOIN layer ";
-	$sql .= "ON layer_style.fkey_layer_id = layer.layer_id ";
-	$sql .= "WHERE layer.layer_name = $2 AND layer.fkey_wms_id = $1 ";
-	$sql .= "AND layer_style.name = $3 AND layer_style.legendurlformat = $4";
-	if ($reqParams['style'] == ''){
-		$style = 'default';
-	} else {
-		$style = $reqParams['style'];
-	$v = array($wmsId, $reqParams['layer'], $style, $reqParams['format']);
-	$t = array("i", "s", "s", "s");
-	if($row = db_fetch_array($res)) {
-		return $row["legendurl"];
-	} else {
-		throwE(array("No legendurl available."));
-		die();
- * validated access permission on requested wms
- * @param wmsId integer, userId - integer
- * @return array array with detailed information about requested wms
-function checkWmsPermission($wmsId,$userId){
-	global $con, $n;
-	$myguis = $n->getGuisByPermission($userId,true);
-	$mywms = $n->getWmsByOwnGuis($myguis);
-	$sql = "SELECT * FROM wms WHERE wms_id = $1";
-	$v = array($wmsId);
-	$t = array("s");
-	$service = array();
-	if($row = db_fetch_array($res)){
-		$service["wms_id"] = $row["wms_id"];
-		$service["wms_getcapabilities"] = $row["wms_getcapabilities"];
-		$service["wms_getmap"] = $row["wms_getmap"];
-		$service["wms_getfeatureinfo"] = $row["wms_getfeatureinfo"];
-		$service["wms_getcapabilities_doc"] = $row["wms_getcapabilities_doc"];
-	if(!$row || count($mywms) == 0){
-		throwE(array("No wms data available."));
-		die();
-	if(!in_array($service["wms_id"], $mywms)){
-		throwE(array("Permission denied."," -> ".$service["wms_id"], implode(",", $mywms)));
-		die();
-	return $service;
-function checkLayerPermission($wms_id,$l,$userId){
-	global $n, $owsproxyService;
-	$e = new mb_notice("owsproxy: checkLayerpermission: wms: ".$wms_id.", layer: ".$l.' user_id: '.$userId);
-	$myl = split(",",$l);
-	$r = array();
-	foreach($myl as $mysl){
-		if($n->getLayerPermission($wms_id, $mysl, $userId) === true){
-			array_push($r, $mysl);
-	$ret = implode(",",$r);
-	return $ret;
-function getDocumentContent($url){
-		$d = new connector($url, $auth);
-	else {
-		$d = new connector($url);
-	return $d->file;
-//extra functions TODO: push them in class_administration.php
-     * selects the wms id for a given layer id.
-     * @param <integer> the layer id
-     * @return <string|boolean> either the id of the wms as integer or false when none exists
-	function getWmsIdByLayerId($id){
-		$sql = "SELECT fkey_wms_id FROM layer WHERE layer_id = $1";
-		$v = array($id);
-		$t = array('i');
-		$res = db_prep_query($sql,$v,$t);
-		$row = db_fetch_array($res);
-		if ($row) return $row["fkey_wms_id"]; else return false;
+<?php
+require(dirname(__FILE__) . "/../../conf/mapbender.conf");
+require(dirname(__FILE__) . "/../../http/classes/class_administration.php");
+require(dirname(__FILE__) . "/../../http/classes/class_connector.php");
+require_once(dirname(__FILE__) . "/../../http/classes/class_mb_exception.php");
+require(dirname(__FILE__) . "/../../owsproxy/http/classes/class_QueryHandler.php");
+//database connection
+$db = db_connect($DBSERVER,$OWNER,$PW);
+db_select_db(DB,$db);
+$imageformats = array("image/png","image/gif","image/jpeg", "image/jpg");
+//control if digest auth is set, if not set, generate the challenge with getNonce()
+if (empty($_SERVER['PHP_AUTH_DIGEST'])) {
+    header('HTTP/1.1 401 Unauthorized');
+    header('WWW-Authenticate: Digest realm="'.REALM.
+           '",qop="auth",nonce="'.getNonce().'",opaque="'.md5(REALM).'"');
+    die('Text to send if user hits Cancel button');
+//read out the header in an array
+$requestHeaderArray = http_digest_parse($_SERVER['PHP_AUTH_DIGEST']);
+//error if header could not be read
+if (!($requestHeaderArray)) {
+	echo 'Following Header information cannot be validated - check your clientsoftware!<br>';
+	echo $_SERVER['PHP_AUTH_DIGEST'].'<br>';
+	die();
+//get mb_username and email out of http_auth username string
+$userIdentification = explode(';',$requestHeaderArray['username']);
+$mbUsername = $userIdentification[0];
+$mbEmail = $userIdentification[1];
+$userInformation = getUserInfo($mbUsername,$mbEmail);
+if ($userInformation[0] == '-1') {
+	die('User with name: '.$mbUsername.' and email: '.$mbEmail.' not known to security proxy!');
+if ($userInformation[1]=='') { //check if digest exists in db - if no digest exists it should be a null string!
+	die('User with name: '.$mbUsername.' and email: '.$mbEmail.' has no digest - please set a new password and try again!');
+//first check the stale!
+if($requestHeaderArray['nonce'] == getNonce()) {
+                        // Up-to-date nonce received
+                        $stale = false;
+                    } else {
+                        // Stale nonce received (probably more than x seconds old)
+                        $stale = true;
+			//give another chance to authenticate
+    			header('WWW-Authenticate: Digest realm="'.REALM.'",qop="auth",nonce="'.getNonce().'",opaque="'.md5(REALM).'" ,stale=true');
+// generate the valid response to check the request of the client
+$A1 = $userInformation[1];
+$A2 = md5($_SERVER['REQUEST_METHOD'].':'.$requestHeaderArray['uri']);
+$valid_response = $A1.':'.getNonce().':'.$requestHeaderArray['nc'];
+$valid_response .= ':'.$requestHeaderArray['cnonce'].':'.$requestHeaderArray['qop'].':'.$A2;
+$valid_response=md5($valid_response);
+if ($requestHeaderArray['response'] != $valid_response) {//the user have to authenticate new - cause something in the authentication went wrong
+    die('Authentication failed - sorry, you have to authenticate once more!');
+//if we are here - authentication has been done well!
+//let's do the proxy things (came from owsproxy.php):
+$postdata = $HTTP_RAW_POST_DATA;
+$layerId = $_REQUEST['layer_id'];
+$query = new QueryHandler();
+// an array with keys and values toLoserCase -> caseinsensitiv
+$reqParams = $query->getRequestParams();
+$n = new administration();
+$wmsId = getWmsIdByLayerId($layerId);
+$owsproxyString = $n->getWMSOWSstring($wmsId);
+if (!$owsproxyString) {
+	die('The requested resource does not exists or the routing through mapbenders owsproxy is not activated!');
+//get authentication infos if they are available in wms table! if not $auth = false
+$auth = $n->getAuthInfoOfWMS($wmsId);
+if ($auth['auth_type']==''){
+	unset($auth);
+$e = new mb_exception("REQUEST to HTTP_AUTH: ".strtolower($reqParams['request']));
+//what the proxy does
+switch (strtolower($reqParams['request'])) {
+	case 'getcapabilities':
+		$arrayOnlineresources = checkWmsPermission($wmsId,$userInformation[0]);
+		$query->setOnlineResource($arrayOnlineresources['wms_getcapabilities']);
+		//$request = preg_replace("/(.*)frames\/login.php/", "$1php/wms.php?layer_id=".$layerId, LOGIN);
+		if (isset($_SERVER["HTTPS"])){
+			$urlPrefix = "https://";
+		} else {
+			$urlPrefix = "http://";
+		if (defined("MAPBENDER_PATH") && MAPBENDER_PATH != '') {
+			$request = MAPBENDER_PATH."/php/wms.php?layer_id=".$layerId;
+		} else {
+			$request = $urlPrefix.$_SERVER['HTTP_HOST']."/mapbender/php/wms.php?layer_id=".$layerId;
+		$requestFull .= $request.'&REQUEST=GetCapabilities&VERSION=1.1.1&SERVICE=WMS';
+		if(isset($auth)){
+			getCapabilities($request,$requestFull,$auth);
+		else {
+			getCapabilities($request,$requestFull);
+		break;
+	case 'getfeatureinfo':
+		$query->setOnlineResource($arrayOnlineresources['wms_getfeatureinfo']);
+		$layers = checkLayerPermission($wmsId,$reqParams['layers'],$userInformation[0]);
+		if ($layers == '' ) {
+		throwE("GetFeatureInfo permission denied on layer with id".$layerId);
+		die();
+		$request = $query->getRequest();
+		if(isset($auth)){
+			getFeatureInfo($request,$auth);
+		else {
+			getFeatureInfo($request);
+		break;
+	case 'getmap':
+		$query->setOnlineResource($arrayOnlineresources['wms_getmap']);
+			throwE("GetMap permission denied on layer with id ".$layerId);
+		die();
+		$query->setParam("layers",urldecode($layers));
+		#log proxy requests
+		if($n->getWmsLogTag($wmsId)==1) {
+			#do log to db
+			#TODO read out size of bbox and calculate price
+		        #get price out of db
+			$price=intval($n->getWmsPrice($wmsId));
+			$n->logWmsProxyRequest($wmsId,$userInformation[0],$request,$price);
+		if(isset($auth)){
+			getImage($request,$auth);
+		else {
+			getImage($request);
+		break;
+	case 'getlegendgraphic':
+		$url = getLegendUrl($wmsId);
+		$e = new mb_exception("URL for getlegendgraphic: ");
+		if(isset($auth)){
+			getImage($url,$auth);
+		else {
+			getImage($url);
+		break;
+	default:
+echo 'Your are logged in as: <b>' .$requestHeaderArray['username'].'</b> and requested the layer with id=<b>'.$layerId.'</b> but your request is not a valid OWS request';
+//functions for http_auth
+// function to parse the http auth header
+function http_digest_parse($txt)
+    // protect against missing data
+    $needed_parts = array('nonce'=>1, 'nc'=>1, 'cnonce'=>1, 'qop'=>1, 'username'=>1, 'uri'=>1, 'response'=>1);
+    $data = array();
+    $keys = implode('|', array_keys($needed_parts));
+    preg_match_all('@(' . $keys . ')=(?:([\'"])([^\2]+?)\2|([^\s,]+))@', $txt, $matches, PREG_SET_ORDER);
+    foreach ($matches as $m) {
+        $data[$m[1]] = $m[3] ? $m[3] : $m[4];
+        unset($needed_parts[$m[1]]);
+    return $needed_parts ? false : $data;
+// function to get relevant user information from mb db
+function getUserInfo($mbUsername,$mbEmail) {
+	$result = array();
+	$sql = "SELECT mb_user_id, mb_user_digest FROM mb_user where mb_user_name = $1 AND mb_user_email= $2";
+	$v = array($mbUsername, $mbEmail);
+	$t = array("s","s");
+	$res = db_prep_query($sql, $v, $t);
+	if(!($row = db_fetch_array($res))){
+		$result[0] = "-1";
+	else {
+		$result[0] = $row['mb_user_id'];
+		$result[1] = $row['mb_user_digest'];
+	return $result;
+function getNonce() {
+	global $nonceLife;
+	$time = ceil(time() / $nonceLife) * $nonceLife;
+	return md5(date('Y-m-d H:i', $time).':'.$_SERVER['REMOTE_ADDR'].':'.NONCEKEY);
+//functions of owsproxy/http/index.php
+function throwE($e){
+	global $reqParams, $imageformats;
+	if(in_array($reqParams['format'],$imageformats)){
+		throwImage($e);
+	else{
+		throwText($e);
+function throwImage($e){
+	global $reqParams;
+	if (!$reqParams['width'] || !$reqParams['height']) { //width or height are not set by ows request - maybe for legendgraphics
+		$width = 300;
+		$height = 20;
+	$image = imagecreate($width,$height);
+	$transparent = ImageColorAllocate($image,155,155,155);
+	ImageFilledRectangle($image,0,0,$width,$height,$transparent);
+	imagecolortransparent($image, $transparent);
+	$text_color = ImageColorAllocate ($image, 233, 14, 91);
+	for($i=0; $i<count($e); $i++){
+		ImageString ($image, 3, 5, $i*20, $e[$i], $text_color);
+	responseImage($image);
+function throwText($e){
+	echo join(" ", $e);
+function responseImage($im){
+	$format = $reqParams['format'];
+	if($format == 'image/png'){header("Content-Type: image/png");}
+	if($format == 'image/jpeg' || $format == 'image/jpg'){header("Content-Type: image/jpeg");}
+	if($format == 'image/gif'){header("Content-Type: image/gif");}
+	if($format == 'image/png'){imagepng($im);}
+	if($format == 'image/jpeg' || $format == 'image/jpg'){imagejpeg($im);}
+	if($format == 'image/gif'){imagegif($im);}
+function completeURL($url){
+	$mykeys = array_keys($reqParams);
+	for($i=0; $i<count($mykeys);$i++){
+		if($i > 0){ $url .= "&"; }
+		$url .= $mykeys[$i]."=".urlencode($reqParams[$mykeys[$i]]);
+	return $url;
+ * fetch and returns an image to client
+ * @param string the original url of the image to send
+function getImage($or){
+	header("Content-Type: ".$reqParams['format']);
+	if (func_num_args() == 2) { //new for HTTP Authentication
+		$auth = func_get_arg(1);
+		echo getDocumentContent($or,$auth);
+	else
+		echo getDocumentContent($or);
+ * fetchs and returns the content of the FeatureInfo Response
+ * @param string the url of the FeatureInfoRequest
+ * @return string the content of the FeatureInfo document
+function getFeatureInfo($url){
+	$e = new mb_exception("owsproxy: Try to fetch FeatureInfoRequest: ".$url);
+	header("Content-Type: ".$reqParams['info_format']);
+		echo getDocumentContent($url,$auth);
+	else
+		echo getDocumentContent($url);
+function matchUrls($content){
+	if(!session_is_registered("owsproxyUrls")){
+		$_SESSION["owsproxyUrls"] = array();
+		$_SESSION["owsproxyUrls"]["id"] = array();
+		$_SESSION["owsproxyUrls"]["url"] = array();
+	$pattern = "/[\"|\'](https*:\/\/[^\"|^\']*)[\"|\']/";
+	preg_match_all($pattern,$content,$matches);
+	for($i=0; $i<count($matches[1]); $i++){
+		$req = $matches[1][$i];
+		$e = new mb_exception("Gefundene URL ".$i.": ".$req);
+		#$notice = new mb_notice("owsproxy id:".$req);
+		$id = registerURL($req);
+		$extReq = setExternalRequest($id);
+		$e = new mb_exception("MD5 URL ".$id."-Externer Link: ".$extReq);
+		$content = str_replace($req,$extReq,$content);
+	return $content;
+function setExternalRequest($id){
+	global $reqParams,$query;
+	$extReq = "http://".$_SESSION['HTTP_HOST'] ."/owsproxy/". $reqParams['sid'] ."/".$id."?request=external";
+	return $extReq;
+function getExternalRequest($id){
+	for($i=0; $i<count($_SESSION["owsproxyUrls"]["url"]); $i++){
+		if($id == $_SESSION["owsproxyUrls"]["id"][$i]){
+			$cUrl = $_SESSION["owsproxyUrls"]["url"][$i];
+			$query_string = removeOWSGetParams($_SERVER["QUERY_STRING"]);
+			if($query_string != ''){
+				$cUrl .= getConjunctionCharacter($cUrl).$query_string;
+			$metainfo = get_headers($cUrl,1);
+			// just for the stupid InternetExplorer
+			header('Pragma: private');
+			header('Cache-control: private, must-revalidate');
+			header("Content-Type: ".$metainfo['Content-Type']);
+			$content = getDocumentContent($cUrl,false);
+			#$content = matchUrls($content); //In the case of http_auth - this is not possible cause we cannot save them in the header - maybe we could create a special session to do so later on?
+			echo $content;
+function removeOWSGetParams($query_string){
+	$r = preg_replace("/.*request=external&/","",$query_string);
+	#return $r;
+	return "";
+function getConjunctionCharacter($url){
+	if(strpos($url,"?")){
+		if(strpos($url,"?") == strlen($url)){
+			$cchar = "";
+		}else if(strpos($url,"&") == strlen($url)){
+			$cchar = "";
+		}else{
+			$cchar = "&";
+	if(strpos($url,"?") === false){
+		$cchar = "?";
+	return $cchar;
+function registerUrl($url){
+	if(!in_array($url,$_SESSION["owsproxyUrls"]["url"])){
+		$e = new mb_exception("Is noch net drin!");
+		$id = md5($url);
+		$e = new mb_exception("ID: ".$id."  URL: ".$url." will be written to session");
+		array_push($_SESSION["owsproxyUrls"]["url"],$url);
+		array_push($_SESSION["owsproxyUrls"]["id"], $id);
+	else{
+		$e = new mb_exception("It was found! Search content and return ID!");
+		$e = new mb_exception("Content ".$i." : proxyurl:".$_SESSION["owsproxyUrls"]["url"][$i]." - new: ".$url);
+		if($url == $_SESSION["owsproxyUrls"]["url"][$i]){
+			$e = new mb_exception("Identical! ID:".$_SESSION["owsproxyUrls"]["id"][$i]." will be used");
+			$id = $_SESSION["owsproxyUrls"]["id"][$i];
+	return $id;
+function getCapabilities($request,$requestFull){
+	global $arrayOnlineresources;
+	global $layerId;
+	header("Content-Type: application/xml");
+	if (func_num_args() == 3) { //new for HTTP Authentication
+		$auth = func_get_arg(2);
+		$content = getDocumentContent($requestFull,$auth);
+	else
+		$content = getDocumentContent($requestFull);
+	//show temporal content fo capabilities
+	$e = new mb_notice("content from wms.php fascade after going thru curl: ".$content);
+	//loading as xml
+	libxml_use_internal_errors(true);
+	try {
+		$capFromFascadeXmlObject = simplexml_load_string($content);
+		if ( $capFromFascadeXmlObject === false) {
+			foreach(libxml_get_errors() as $error) {
+        			$err = new mb_exception("http_auth/index.php: ".$error->message);
+			throw new Exception("http_auth/index.php: ".'Cannot parse Metadata XML!');
+			echo "<error>http_auth/index.php: Cannot parse Capabilities XML!</error>";
+			die();
+	catch (Exception $e) {
+    		$err = new mb_exception("http_auth/index.php: ".$e->getMessage());
+		echo "<error>http_auth/index.php: ".$e->getMessage()."</error>";
+		die();
+	//exchanging urls in some special fields
+	//GetCapabilities, GetMap, GetFeatureInfo, GetLegendGraphics, ...
+	$capFromFascadeXmlObject->registerXPathNamespace("xlink", "http://www.w3.org/1999/xlink");
+	//Mapping of urls for wms 1.1.1 which should be exchanged
+	$urlsToChange = array(
+		'/WMT_MS_Capabilities/Capability/Request/GetCapabilities/DCPType/HTTP/Get/OnlineResource/@xlink:href',
+		'/WMT_MS_Capabilities/Capability/Request/GetCapabilities/DCPType/HTTP/Post/OnlineResource/@xlink:href',
+		'/WMT_MS_Capabilities/Capability/Request/GetMap/DCPType/HTTP/Get/OnlineResource/@xlink:href',
+		'/WMT_MS_Capabilities/Capability/Request/GetMap/DCPType/HTTP/Post/OnlineResource/@xlink:href',
+		'/WMT_MS_Capabilities/Capability/Request/GetFeatureInfo/DCPType/HTTP/Get/OnlineResource/@xlink:href',
+		'/WMT_MS_Capabilities/Capability/Request/GetFeatureInfo/DCPType/HTTP/Post/OnlineResource/@xlink:href',
+		'/WMT_MS_Capabilities/Capability/Layer/Layer/Style/LegendURL/OnlineResource/@xlink:href'
+	foreach($urlsToChange as $xpath) {
+		$href = $capFromFascadeXmlObject->xpath($xpath);
+		$e = new mb_notice("old href: ".$href[0]);
+		$e = new mb_notice("href replaced: ".replaceOwsUrls($href[0], $layerId));
+		$href[0][0] = replaceOwsUrls($href[0], $layerId);
+	echo $capFromFascadeXmlObject->asXML();
+function replaceOwsUrls($owsUrl, $layerId) {
+	$new = "http_auth/". $layerId."?";
+        $pattern = "#owsproxy/[a-z0-9]{32}\/[a-z0-9]{32}\?#m";
+	$httpAuthUrl = preg_replace($pattern,$new,$owsUrl);
+	return $httpAuthUrl;
+ * gets the original url of the requested legend graphic
+ * @param string owsproxy md5
+ * @return string url to legend graphic
+function getLegendUrl($wmsId){
+	//get wms_getlegendurl
+	$sql = "SELECT wms_getlegendurl FROM wms WHERE wms_id = $1";
+	$v = array($wmsId);
+	$t = array("i");
+	if($row = db_fetch_array($res)) {
+		$getLegendUrl = $row["wms_getlegendurl"];
+	} else {
+		throwE(array("No wms data available."));
+		die();
+	//get the url
+	$sql = "SELECT layer_style.legendurl ";
+	$sql .= "FROM layer_style JOIN layer ";
+	$sql .= "ON layer_style.fkey_layer_id = layer.layer_id ";
+	$sql .= "WHERE layer.layer_name = $2 AND layer.fkey_wms_id = $1 ";
+	$sql .= "AND layer_style.name = $3 AND layer_style.legendurlformat = $4";
+	if ($reqParams['style'] == ''){
+		$style = 'default';
+	} else {
+		$style = $reqParams['style'];
+	$v = array($wmsId, $reqParams['layer'], $style, $reqParams['format']);
+	$t = array("i", "s", "s", "s");
+		if (strpos($row["legendurl"],'http') !== 0) {
+			$e = new mb_notice("combine legendurls!");
+			return $getLegendUrl.$row["legendurl"];
+		return $row["legendurl"];
+	} else {
+		throwE(array("No legendurl available."));
+		die();
+ * validated access permission on requested wms
+ * @param wmsId integer, userId - integer
+ * @return array array with detailed information about requested wms
+function checkWmsPermission($wmsId,$userId){
+	global $con, $n;
+	$myguis = $n->getGuisByPermission($userId,true);
+	$mywms = $n->getWmsByOwnGuis($myguis);
+	$sql = "SELECT * FROM wms WHERE wms_id = $1";
+	$t = array("s");
+	$service = array();
+	if($row = db_fetch_array($res)){
+		$service["wms_id"] = $row["wms_id"];
+		$service["wms_getcapabilities"] = $row["wms_getcapabilities"];
+		$service["wms_getmap"] = $row["wms_getmap"];
+		$service["wms_getfeatureinfo"] = $row["wms_getfeatureinfo"];
+		$service["wms_getcapabilities_doc"] = $row["wms_getcapabilities_doc"];
+	if(!$row || count($mywms) == 0){
+		die();
+	if(!in_array($service["wms_id"], $mywms)){
+		throwE(array("Permission denied."," -> ".$service["wms_id"], implode(",", $mywms)));
+		die();
+	return $service;
+function checkLayerPermission($wms_id,$l,$userId){
+	global $n, $owsproxyService;
+	$e = new mb_notice("owsproxy: checkLayerpermission: wms: ".$wms_id.", layer: ".$l.' user_id: '.$userId);
+	$myl = split(",",$l);
+	$r = array();
+	foreach($myl as $mysl){
+		if($n->getLayerPermission($wms_id, $mysl, $userId) === true){
+			array_push($r, $mysl);
+	$ret = implode(",",$r);
+	return $ret;
+function getDocumentContent($url){
+		$d = new connector($url, $auth);
+	else {
+		$d = new connector($url);
+	return $d->file;
+//extra functions TODO: push them in class_administration.php
+     * selects the wms id for a given layer id.
+     * @param <integer> the layer id
+     * @return <string|boolean> either the id of the wms as integer or false when none exists
+	function getWmsIdByLayerId($id){
+		$sql = "SELECT fkey_wms_id FROM layer WHERE layer_id = $1";
+		$v = array($id);
+		$t = array('i');
+		$res = db_prep_query($sql,$v,$t);
+		$row = db_fetch_array($res);
+		if ($row) return $row["fkey_wms_id"]; else return false;
Modified: trunk/mapbender/owsproxy/http/index.php
--- trunk/mapbender/owsproxy/http/index.php	2013-02-07 12:40:39 UTC (rev 8558)
+++ trunk/mapbender/owsproxy/http/index.php	2013-02-07 14:07:37 UTC (rev 8559)
@@ -1,728 +1,733 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/Owsproxy
-# Module maintainer Uli
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__)."/../../core/globalSettings.php");
-require_once(dirname(__FILE__) . "/../../http/classes/class_administration.php");
-require_once(dirname(__FILE__) . "/../../http/classes/class_connector.php");
-require_once(dirname(__FILE__) . "/./classes/class_QueryHandler.php");
-/***** conf *****/
-$width = 400;
-$height = 400;
-/***** conf *****/
-$owsproxyService = $_REQUEST['wms']; //ToDo: change this to 'service' in the apache url-rewriting
-// an array with keys and values toLowerCase -> caseinsensitiv
-$e = new mb_notice("incoming request: ".OWSPROXY."/".$_REQUEST['sid']."/".$_REQUEST['wms'].$query->getRequest());
-$e = new mb_notice("owsproxy requested from: ".$_SERVER["REMOTE_ADDR"]);
-//check if proxy request came from grabbing whitelist - for grabbing
-if (!defined("OWSPROXY_SESSION_GRABBING_WHITELIST")){
-	$grabbingAllowed = true;
-if (defined("OWSPROXY_SESSION_GRABBING_WHITELIST")) {
-	$whiteListArray = explode(",", OWSPROXY_SESSION_GRABBING_WHITELIST);
-	if (in_array($_SERVER["REMOTE_ADDR"], $whiteListArray)) {
-		$e = new mb_notice("Grabbing allowed for IP: ".$_SERVER["REMOTE_ADDR"]);
-	} else {
-		$grabbingAllowed = false;
-		$e = new mb_notice("Grabbing not allowed for IP: ".$_SERVER["REMOTE_ADDR"]."!");
-//check session
-//session_regenerate_id(TRUE);
-$e = new mb_notice("Initial session_id: ".session_id());
-//The session can be set by a given cookie value or was newly created by core/globalSettings.php
-//either empty (without mb_user_id value) - when the corresponding session file was lost or timed out
-//or filled, when there was an actual mapbender session before
-//check if mb_user_id is given and is an string with an integer:
-if(!$_SESSION['mb_user_id'] && !is_int($_SESSION['mb_user_id'])){
-	$e = new mb_notice("Newly initialized session - no logged in mapbender user!");
-//Possibility to grap an existing session:
-if (defined("OWSPROXY_ALLOW_SESSION_GRABBING") && OWSPROXY_ALLOW_SESSION_GRABBING == true) {
-	if ($grabbingAllowed) {
-		//first check is to find out if a session with the current sid exists! If so use this one, if not use the current one which was generated from globalSettings.php
-		if (file_exists(ini_get('session.save_path')."/sess_".$_REQUEST["sid"]) && session_id() !== $_REQUEST["sid"]) {
-			//there is a current session for the requested url
-			$e = new mb_notice("A current session exists for this url and will be used!");
-			$oldsessionId = session_id();
-			$tmpSessionFile = ini_get('session.save_path')."/sess_".session_id();
-			//do the following only, if a user is in this session - maybe it is a session which was generated from an external application and therefor it is empty!
-			session_id($_REQUEST["sid"]);
-			$e = new mb_notice("Grabbed session with id: ".session_id());
-			//kill dynamical session
-			//@unlink($tmpSessionFile);
-			$e = new mb_notice("Following user was found and will be used for authorization: ".Mapbender::session()->get('mb_user_id'));
-			$foundUserId = Mapbender::session()->get('mb_user_id');
-			if (!isset($foundUserId) || $foundUserId =='') {
-				$e = new mb_notice("No user found in the existing session - switch to the old one!");
-				session_id($oldsessionId);
-			} else {
-				//delete session as it will not be needed any longer
-				$e = new mb_notice("Following no longer needed session will be deleted: ".$tmpSessionFile);
-				@unlink($tmpSessionFile);
-//check if current session has the same id as the session which is requested in the owsproxy url
-//exchange them, if they differ and redirect to an new one with the current session
-if (session_id() !== $_REQUEST["sid"]) {
-	//get all request params which are original
-	//build reuquest
-	$redirectUrl = OWSPROXY."/".session_id()."/".$_REQUEST['wms'].$query->getRequest();
-	$e = new mb_notice("IDs differ - redirect to new owsproxy url: ".$redirectUrl);
-	header("Location: ".$redirectUrl);
-	die();
-} else {
-	$e = new mb_notice("Current session_id() identical to requested SID!");
-//this is the request which may have been redirected
-//check for given user session with user_id which can be tested again the authorization
-if(!$_SESSION['mb_user_id']){
-	$e = new mb_notice("user_id not found in session");
-	//if configured in mapbender.conf, create guest session so that also proxied service can be watched in external applications when they are available to the anonymous user
-	//only possible for webapplications - in case of desktop applications the user have to use his credentials and http_auth module
-	if (defined("OWSPROXY_ALLOW_PUBLIC_USER") && OWSPROXY_ALLOW_PUBLIC_USER && defined("PUBLIC_USER") && PUBLIC_USER != "") {
-		//setSession();
-  		Mapbender::session()->set("mb_user_id",PUBLIC_USER);
-		Mapbender::session()->set("external_proxy_user",true);
-		Mapbender::session()->set("mb_user_ip",$_SERVER['REMOTE_ADDR']);
-		//Define name of temporal session file. This file can be deleted after the request was successful. It will be generated every time again.
-		$e = new mb_notice("Permission allowed for public user with id: ".PUBLIC_USER);
-	} else {
-		$e = new mb_notice("Permission denied - public user not allowed to access ressource!");
-		//kill actual session file
-		$e = new mb_notice("delete temporary session file: ".$tmpSessionFile);
-		throwE(array("Permission denied"," - no current session found and ","public user not allowed to access ressource!"));
-		die();
-} else {
-	$e= new mb_notice("mb_user_id found in session: ".$_SESSION['mb_user_id']);
-//start the session to be able to write urls to it - for
-session_start();//maybe it was started by globalSettings.php
-$n = new administration;
-//Extra security - IP check
-if (defined("OWSPROXY_BIND_IP") && OWSPROXY_BIND_IP == true) {
-	if($_SESSION['mb_user_ip'] != $_SERVER['REMOTE_ADDR']){
-		throwE(array("Session not identified.","Permission denied.","Please authenticate."));
-		die();
-$e = new mb_notice("user id for authorization test: ".$_SESSION['mb_user_id']);
-$wmsId = $n->getWmsIdFromOwsproxyString($query->getOwsproxyServiceId());
-	unset($auth);
-/*************  workflow ************/
-		$arrayOnlineresources = checkWmsPermission($query->getOwsproxyServiceId());
-		if(isset($auth)){
-			getCapabilities($request,$auth);
-			#$mb_exception = new mb_exception("auth: ".$auth['auth_type']);
-		else {
-			getCapabilities($request);
-		break;
-		if(isset($auth)){
-		else {
-		break;
-	case 'getmap':
-		$arrayOnlineresources = checkWmsPermission($owsproxyService);
-		$layers = checkLayerPermission($arrayOnlineresources['wms_id'],$reqParams['layers']);
-		if($layers===""){
-			throwE("Permission denied");
-			die();
-		$query->setParam("layers",urldecode($layers));//the decoding of layernames dont make problems - but not really good names will be requested also ;-)
-		if($n->getWmsLogTag($arrayOnlineresources['wms_id'])==1) {
-			#do log to db
-			$price=intval($n->getWmsPrice($arrayOnlineresources['wms_id']));
-			$n->logWmsProxyRequest($arrayOnlineresources['wms_id'],$_SESSION['mb_user_id'],$request,$price);
-		if(isset($auth)){
-		else {
-		break;
-	case 'map':
-		if($layers===""){
-			die();
-		if(isset($auth)){
-		else {
-			getImage($url);
-		break;
-		$url = getLegendUrl($query->getOwsproxyServiceId());
-		if (isset ($reqParams['sld']) && $reqParams['sld'] != "") {
-			$url = $url . getConjunctionCharacter($url) . "SLD=".$reqParams['sld'];
-		if(isset($auth)){
-		else {
-			getImage($url);
-		break;
-	case 'external':
-		getExternalRequest($query->getOwsproxyServiceId());
-		break;
-	case 'getfeature':
-		$arrayFeatures = array($reqParams['typename']);
-		$arrayOnlineresources = checkWfsPermission($query->getOwsproxyServiceId(), $arrayFeatures);
-		$query->setOnlineResource($arrayOnlineresources['wfs_getfeature']);
-		$request = stripslashes($request);
-		getFeature($request);
-		break;
-	// case wfs transaction (because of raw POST the request param is empty)
-	case '':
-		$arrayFeatures = getWfsFeaturesFromTransaction($HTTP_RAW_POST_DATA);
-		$query->setOnlineResource($arrayOnlineresources['wfs_transaction']);
-		doTransaction($request, $HTTP_RAW_POST_DATA);
-		break;
-	default:
-if (isset($tmpSessionFile) && file_exists($tmpSessionFile)) {
-	$e = new mb_exception("Following no longer needed session will be deleted: ".$tmpSessionFile);
-		throwImage($e);
-	else{
-		throwText($e);
-	global $width,$height;
-	if (count($e) > 1){
-			$imageString = $e[$i];
-			ImageString ($image, 3, 5, $i*20, $imageString, $text_color);
-	} else {
-		if (is_array($e)) {
-			$imageString = $e[0];
-		} else {
-			$imageString = $e;
-		if ($imageString == "") {
-			$imageString = "An unknown error occured!";
-	$format="image/gif";
-	return $url;
-	#log the image_requests to database
-	#log the following to table mb_proxy_log
-	#timestamp,user_id,getmaprequest,amount pixel,price - but do this only for wms to log - therefor first get log tag out of wms!
-	else
-	//$e = new mb_notice("owsproxy: Try to fetch FeatureInfoRequest: ".$url);
-		$content = getDocumentContent($url,$auth);
-	else {
-		$content = getDocumentContent($url);
-	$content = matchUrls($content);
-	echo $content;
- * fetchs and returns the content of WFS GetFeature response
- * @param string the url of the GetFeature request
- * @return echo the content of the GetFeature document
-function getFeature($url){
-	echo $content;
- * simulates a post request to host
- * @param string host to send the request to
- * @param string port of host to send the request to
- * @param string method to send data (should be "POST")
- * @param string path on host
- * @param string data to send to host
- * @return string hosts response
-function sendToHost($host,$port,$method,$path,$data){
-	$buf = '';
-    if (empty($method)) $method = 'POST';
-    $method = mb_strtoupper($method);
-    $fp = fsockopen($host, $port);
-    fputs($fp, "$method $path HTTP/1.1\r\n");
-    fputs($fp, "Host: $host\r\n");
-    fputs($fp,"Content-type: application/xml\r\n");
-    fputs($fp, "Content-length: " . strlen($data) . "\r\n");
-    fputs($fp, "Connection: close\r\n\r\n");
-    if ($method == 'POST') fputs($fp, $data);
-    while (!feof($fp)) $buf .= fgets($fp,4096);
-    fclose($fp);
-    return $buf;
- * get wfs featurenames that are touched by a tansaction request defined in XML $data
- * @param string XML that contains the tansaction request
- * @return array array of touched feature names
-function getWfsFeaturesFromTransaction($data){
-	new mb_notice("owsproxy.getWfsFeaturesFromTransaction.data: ".$data);
-	if(!$data || $data == ""){
-		return false;
-	$features = array();
-	$values = NULL;
-	$tags = NULL;
-	$parser = xml_parser_create();
-	xml_parser_set_option($parser,XML_OPTION_CASE_FOLDING,0);
-	xml_parser_set_option($parser,XML_OPTION_SKIP_WHITE,1);
-	xml_parse_into_struct($parser,$data,$values,$tags);
-	$code = xml_get_error_code ($parser);
-	if ($code) {
-		$line = xml_get_current_line_number($parser);
-		$col = xml_get_current_column_number($parser);
-		$mb_exception = new mb_exception("OWSPROXY invalid Tansaction XML: ".xml_error_string($code) .  " in line " . $line. " at character ". $col);
-		die();
-	xml_parser_free($parser);
-	$insert = false;
-	$insertlevel = 0;
-	foreach ($values as $element) {
-		//features touched by insert
-		if(strtoupper($element[tag]) == "WFS:INSERT" && $element[type] == "open"){
-			$insert = true;
-			$insertlevel = $element[level];
-		if($insert && $element[level] == $insertlevel + 1 && $element[type] == "open"){
-			array_push($features, $element[tag]);
-		if(strtoupper($element[tag]) == "WFS:INSERT" && $element[type] == "close"){
-			$insert = false;
-		//updated features
-		if(strtoupper($element[tag]) == "WFS:UPDATE" && $element[type] == "open"){
-			array_push($features, $element[attributes]["typeName"]);
-		//deleted features
-		if(strtoupper($element[tag]) == "WFS:DELETE" && $element[type] == "open"){
-	return $features;
- * sends the data of WFS Transaction and echos the response
- *  @param string url to send the WFS Transaction to
- *  @param string WFS Transaction data
-function doTransaction($url, $data){
-	$arURL = parse_url($url);
-	$host = $arURL["host"];
-	$port = $arURL["port"];
-	if($port == '') $port = 80;
-	$path = $arURL["path"];
-	$method = "POST";
-	$result = sendToHost($host,$port,$method,html_entity_decode($path),$data);
-	//delete header from result
-	$result = mb_eregi_replace("^[^<]*", "", $result);
-	$result = mb_eregi_replace("[^>]*$", "", $result);
-	echo $result;
-	if(!session_is_registered("owsproxyUrls")){ //TODO: exchange function, because it is deprecated and will not longer be supported by php 5.4!
-		$notice = new mb_notice("owsproxy found URL ".$i.": ".$req);
-		$notice = new mb_notice("MD5 URL ".$id." - external link: ".$extReq);
-	return $content;
-//	$extReq = "http://".$_SESSION['HTTP_HOST'] ."/owsproxy/". $reqParams['sid'] ."/".$id."?request=external";
-	$extReq = OWSPROXY ."/". $reqParams['sid'] ."/".$id."?request=external";
-	return $extReq;
-			$content = getDocumentContent($cUrl);
-			echo $content;
-	#return $r;
-	return "";
-			$cchar = "";
-			$cchar = "";
-		}else{
-			$cchar = "&";
-		$cchar = "?";
-	return $cchar;
-		$id = md5($url);
-	else{
-	return $id;
-function getCapabilities($url){
-	global $sid,$wms;
-	$t = array(htmlentities($arrayOnlineresources["wms_getcapabilities"]),htmlentities($arrayOnlineresources["wms_getmap"]),htmlentities($arrayOnlineresources["wms_getfeatureinfo"]));
-	$new = OWSPROXY ."/". $sid ."/".$wms."?";
-	$r = str_replace($t,$new,$arrayOnlineresources["wms_getcapabilities_doc"]);
-	echo $r;
-function getLegendUrl($wms){
-	//get wms id
-	$sql = "SELECT * FROM wms WHERE wms_owsproxy = $1";
-	$v = array($wms);
-	$t = array("s");
-		$wmsid = $row["wms_id"];
-	} else {
-		die();
-	//get the url
-	$v = array($wmsid, $reqParams['layer'], $reqParams['style'], $reqParams['format']);
-	else{
-		throwE(array("No legend available."));
-		die();
- * @param string OWSPROXY md5
-function checkWmsPermission($wms){
-	global $con, $n;
-	$myguis = $n->getGuisByPermission($_SESSION["mb_user_id"],true);
-	$v = array($wms);
-	$t = array("s");
-		die();
-		die();
-	return $service;
- * validates the access permission by getting the appropriate wfs_conf
- * to each feature requested and check the wfs_conf permission
- * @param array array of requested featuretype names
- * @return array array with detailed information on reqested wfs
-function checkWfsPermission($wfsOws, $features){
-	global $con, $n;
-	$myconfs = $n->getWfsConfByPermission($_SESSION["mb_user_id"]);
-	//check if we know the features requested
-	if(count($features) == 0){
-		throwE(array("No wfs_feature data available."));
-		die();
-	//get wfs
-	$sql = "SELECT * FROM wfs WHERE wfs_owsproxy = $1";
-	$v = array($wfsOws);
-	$t = array("s");
-		$service["wfs_id"] = $row["wfs_id"];
-		$service["wfs_getcapabilities"] = $row["wfs_getcapabilities"];
-		$service["wfs_getfeature"] = $row["wfs_getfeature"];
-		$service["wfs_describefeaturetype"] = $row["wfs_describefeaturetype"];
-		$service["wfs_transaction"] = $row["wfs_transaction"];
-		$service["wfs_getcapabilities_doc"] = $row["wfs_getcapabilities_doc"];
-	else{
-		throwE(array("No wfs data available."));
-		die();
-	foreach($features as $feature){
-		//get appropriate wfs_conf
-		$sql = "SELECT wfs_conf.wfs_conf_id FROM wfs_conf ";
-		$sql.= "JOIN wfs_featuretype ";
-		$sql.= "ON wfs_featuretype.featuretype_id = wfs_conf.fkey_featuretype_id ";
-		$sql.= "WHERE wfs_featuretype.featuretype_name = $2 ";
-		$sql.= "AND wfs_featuretype.fkey_wfs_id = $1";
-		$v = array($service["wfs_id"], $feature);
-		$t = array("i","s");
-			$notice = new mb_notice("Permissioncheck failed no wfs conf for wfs ".$service["wfs_id"]." with feturetype ".$feature);
-			throwE(array("No wfs_conf data for featuretype ".$feature));
-			die();
-		$conf_id = $row["wfs_conf_id"];
-		//check permission
-		if(!in_array($conf_id, $myconfs)){
-			$notice = new mb_notice("Permissioncheck failed:".$conf_id." not in ".implode(",", $myconfs));
-			throwE(array("Permission denied."," -> ".$conf_id, implode(",", $myconfs)));
-			die();
-	return $service;
-function checkLayerPermission($wms_id,$l){
-//	$notice = new mb_notice("owsproxy: checkLayerpermission: wms: ".$wms_id.", layer: ".$l);
-	$r = array();
-		if($n->getLayerPermission($wms_id, $mysl, $_SESSION["mb_user_id"]) === true){
-	return $ret;
-	else {
-	return $d->file;
+<?php
+# $Id$
+# http://www.mapbender.org/index.php/Owsproxy
+# Module maintainer Uli
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../../core/globalSettings.php");
+require_once(dirname(__FILE__) . "/../../http/classes/class_administration.php");
+require_once(dirname(__FILE__) . "/../../http/classes/class_connector.php");
+require_once(dirname(__FILE__) . "/./classes/class_QueryHandler.php");
+/***** conf *****/
+$width = 400;
+$height = 400;
+/***** conf *****/
+$owsproxyService = $_REQUEST['wms']; //ToDo: change this to 'service' in the apache url-rewriting
+// an array with keys and values toLowerCase -> caseinsensitiv
+$e = new mb_notice("incoming request: ".OWSPROXY."/".$_REQUEST['sid']."/".$_REQUEST['wms'].$query->getRequest());
+$e = new mb_notice("owsproxy requested from: ".$_SERVER["REMOTE_ADDR"]);
+//check if proxy request came from grabbing whitelist - for grabbing
+if (!defined("OWSPROXY_SESSION_GRABBING_WHITELIST")){
+	$grabbingAllowed = true;
+if (defined("OWSPROXY_SESSION_GRABBING_WHITELIST")) {
+	$whiteListArray = explode(",", OWSPROXY_SESSION_GRABBING_WHITELIST);
+	if (in_array($_SERVER["REMOTE_ADDR"], $whiteListArray)) {
+		$e = new mb_notice("Grabbing allowed for IP: ".$_SERVER["REMOTE_ADDR"]);
+	} else {
+		$grabbingAllowed = false;
+		$e = new mb_notice("Grabbing not allowed for IP: ".$_SERVER["REMOTE_ADDR"]."!");
+//check session
+//session_regenerate_id(TRUE);
+$e = new mb_notice("Initial session_id: ".session_id());
+//The session can be set by a given cookie value or was newly created by core/globalSettings.php
+//either empty (without mb_user_id value) - when the corresponding session file was lost or timed out
+//or filled, when there was an actual mapbender session before
+//check if mb_user_id is given and is an string with an integer:
+if(!$_SESSION['mb_user_id'] && !is_int($_SESSION['mb_user_id'])){
+	$e = new mb_notice("Newly initialized session - no logged in mapbender user!");
+//Possibility to grap an existing session:
+if (defined("OWSPROXY_ALLOW_SESSION_GRABBING") && OWSPROXY_ALLOW_SESSION_GRABBING == true) {
+	if ($grabbingAllowed) {
+		//first check is to find out if a session with the current sid exists! If so use this one, if not use the current one which was generated from globalSettings.php
+		if (file_exists(ini_get('session.save_path')."/sess_".$_REQUEST["sid"]) && session_id() !== $_REQUEST["sid"]) {
+			//there is a current session for the requested url
+			$e = new mb_notice("A current session exists for this url and will be used!");
+			$oldsessionId = session_id();
+			$tmpSessionFile = ini_get('session.save_path')."/sess_".session_id();
+			//do the following only, if a user is in this session - maybe it is a session which was generated from an external application and therefor it is empty!
+			session_id($_REQUEST["sid"]);
+			$e = new mb_notice("Grabbed session with id: ".session_id());
+			//kill dynamical session
+			//@unlink($tmpSessionFile);
+			$e = new mb_notice("Following user was found and will be used for authorization: ".Mapbender::session()->get('mb_user_id'));
+			$foundUserId = Mapbender::session()->get('mb_user_id');
+			if (!isset($foundUserId) || $foundUserId =='') {
+				$e = new mb_notice("No user found in the existing session - switch to the old one!");
+				session_id($oldsessionId);
+			} else {
+				//delete session as it will not be needed any longer
+				$e = new mb_notice("Following no longer needed session will be deleted: ".$tmpSessionFile);
+				@unlink($tmpSessionFile);
+//check if current session has the same id as the session which is requested in the owsproxy url
+//exchange them, if they differ and redirect to an new one with the current session
+if (session_id() !== $_REQUEST["sid"]) {
+	//get all request params which are original
+	//build reuquest
+	$redirectUrl = OWSPROXY."/".session_id()."/".$_REQUEST['wms'].$query->getRequest();
+	$e = new mb_notice("IDs differ - redirect to new owsproxy url: ".$redirectUrl);
+	header("Location: ".$redirectUrl);
+	die();
+} else {
+	$e = new mb_notice("Current session_id() identical to requested SID!");
+//this is the request which may have been redirected
+//check for given user session with user_id which can be tested again the authorization
+if(!$_SESSION['mb_user_id']){
+	$e = new mb_notice("user_id not found in session");
+	//if configured in mapbender.conf, create guest session so that also proxied service can be watched in external applications when they are available to the anonymous user
+	//only possible for webapplications - in case of desktop applications the user have to use his credentials and http_auth module
+	if (defined("OWSPROXY_ALLOW_PUBLIC_USER") && OWSPROXY_ALLOW_PUBLIC_USER && defined("PUBLIC_USER") && PUBLIC_USER != "") {
+		//setSession();
+  		Mapbender::session()->set("mb_user_id",PUBLIC_USER);
+		Mapbender::session()->set("external_proxy_user",true);
+		Mapbender::session()->set("mb_user_ip",$_SERVER['REMOTE_ADDR']);
+		//Define name of temporal session file. This file can be deleted after the request was successful. It will be generated every time again.
+		$e = new mb_notice("Permission allowed for public user with id: ".PUBLIC_USER);
+	} else {
+		$e = new mb_notice("Permission denied - public user not allowed to access ressource!");
+		//kill actual session file
+		$e = new mb_notice("delete temporary session file: ".$tmpSessionFile);
+		throwE(array("Permission denied"," - no current session found and ","public user not allowed to access ressource!"));
+		die();
+} else {
+	$e= new mb_notice("mb_user_id found in session: ".$_SESSION['mb_user_id']);
+//start the session to be able to write urls to it - for
+session_start();//maybe it was started by globalSettings.php
+$n = new administration;
+//Extra security - IP check
+if (defined("OWSPROXY_BIND_IP") && OWSPROXY_BIND_IP == true) {
+	if($_SESSION['mb_user_ip'] != $_SERVER['REMOTE_ADDR']){
+		throwE(array("Session not identified.","Permission denied.","Please authenticate."));
+		die();
+$e = new mb_notice("user id for authorization test: ".$_SESSION['mb_user_id']);
+$wmsId = $n->getWmsIdFromOwsproxyString($query->getOwsproxyServiceId());
+	unset($auth);
+/*************  workflow ************/
+		$arrayOnlineresources = checkWmsPermission($query->getOwsproxyServiceId());
+		if(isset($auth)){
+			getCapabilities($request,$auth);
+			#$mb_exception = new mb_exception("auth: ".$auth['auth_type']);
+		else {
+			getCapabilities($request);
+		break;
+		if(isset($auth)){
+		else {
+		break;
+	case 'getmap':
+		$arrayOnlineresources = checkWmsPermission($owsproxyService);
+		$layers = checkLayerPermission($arrayOnlineresources['wms_id'],$reqParams['layers']);
+		if($layers===""){
+			throwE("Permission denied");
+			die();
+		$query->setParam("layers",urldecode($layers));//the decoding of layernames dont make problems - but not really good names will be requested also ;-)
+		if($n->getWmsLogTag($arrayOnlineresources['wms_id'])==1) {
+			#do log to db
+			$price=intval($n->getWmsPrice($arrayOnlineresources['wms_id']));
+			$n->logWmsProxyRequest($arrayOnlineresources['wms_id'],$_SESSION['mb_user_id'],$request,$price);
+		if(isset($auth)){
+		else {
+		break;
+	case 'map':
+		if($layers===""){
+			die();
+		if(isset($auth)){
+		else {
+			getImage($url);
+		break;
+		$url = getLegendUrl($query->getOwsproxyServiceId());
+		if (isset ($reqParams['sld']) && $reqParams['sld'] != "") {
+			$url = $url . getConjunctionCharacter($url) . "SLD=".$reqParams['sld'];
+		if(isset($auth)){
+		else {
+			getImage($url);
+		break;
+	case 'external':
+		getExternalRequest($query->getOwsproxyServiceId());
+		break;
+	case 'getfeature':
+		$arrayFeatures = array($reqParams['typename']);
+		$arrayOnlineresources = checkWfsPermission($query->getOwsproxyServiceId(), $arrayFeatures);
+		$query->setOnlineResource($arrayOnlineresources['wfs_getfeature']);
+		$request = stripslashes($request);
+		getFeature($request);
+		break;
+	// case wfs transaction (because of raw POST the request param is empty)
+	case '':
+		$arrayFeatures = getWfsFeaturesFromTransaction($HTTP_RAW_POST_DATA);
+		$query->setOnlineResource($arrayOnlineresources['wfs_transaction']);
+		doTransaction($request, $HTTP_RAW_POST_DATA);
+		break;
+	default:
+if (isset($tmpSessionFile) && file_exists($tmpSessionFile)) {
+	$e = new mb_exception("Following no longer needed session will be deleted: ".$tmpSessionFile);
+		throwImage($e);
+	else{
+		throwText($e);
+	global $width,$height;
+	if (count($e) > 1){
+			$imageString = $e[$i];
+			ImageString ($image, 3, 5, $i*20, $imageString, $text_color);
+	} else {
+		if (is_array($e)) {
+			$imageString = $e[0];
+		} else {
+			$imageString = $e;
+		if ($imageString == "") {
+			$imageString = "An unknown error occured!";
+	$format="image/gif";
+	return $url;
+	#log the image_requests to database
+	#log the following to table mb_proxy_log
+	#timestamp,user_id,getmaprequest,amount pixel,price - but do this only for wms to log - therefor first get log tag out of wms!
+	else
+	//$e = new mb_notice("owsproxy: Try to fetch FeatureInfoRequest: ".$url);
+		$content = getDocumentContent($url,$auth);
+	else {
+		$content = getDocumentContent($url);
+	$content = matchUrls($content);
+	echo $content;
+ * fetchs and returns the content of WFS GetFeature response
+ * @param string the url of the GetFeature request
+ * @return echo the content of the GetFeature document
+function getFeature($url){
+	echo $content;
+ * simulates a post request to host
+ * @param string host to send the request to
+ * @param string port of host to send the request to
+ * @param string method to send data (should be "POST")
+ * @param string path on host
+ * @param string data to send to host
+ * @return string hosts response
+function sendToHost($host,$port,$method,$path,$data){
+	$buf = '';
+    if (empty($method)) $method = 'POST';
+    $method = mb_strtoupper($method);
+    $fp = fsockopen($host, $port);
+    fputs($fp, "$method $path HTTP/1.1\r\n");
+    fputs($fp, "Host: $host\r\n");
+    fputs($fp,"Content-type: application/xml\r\n");
+    fputs($fp, "Content-length: " . strlen($data) . "\r\n");
+    fputs($fp, "Connection: close\r\n\r\n");
+    if ($method == 'POST') fputs($fp, $data);
+    while (!feof($fp)) $buf .= fgets($fp,4096);
+    fclose($fp);
+    return $buf;
+ * get wfs featurenames that are touched by a tansaction request defined in XML $data
+ * @param string XML that contains the tansaction request
+ * @return array array of touched feature names
+function getWfsFeaturesFromTransaction($data){
+	new mb_notice("owsproxy.getWfsFeaturesFromTransaction.data: ".$data);
+	if(!$data || $data == ""){
+		return false;
+	$features = array();
+	$values = NULL;
+	$tags = NULL;
+	$parser = xml_parser_create();
+	xml_parser_set_option($parser,XML_OPTION_CASE_FOLDING,0);
+	xml_parser_set_option($parser,XML_OPTION_SKIP_WHITE,1);
+	xml_parse_into_struct($parser,$data,$values,$tags);
+	$code = xml_get_error_code ($parser);
+	if ($code) {
+		$line = xml_get_current_line_number($parser);
+		$col = xml_get_current_column_number($parser);
+		$mb_exception = new mb_exception("OWSPROXY invalid Tansaction XML: ".xml_error_string($code) .  " in line " . $line. " at character ". $col);
+		die();
+	xml_parser_free($parser);
+	$insert = false;
+	$insertlevel = 0;
+	foreach ($values as $element) {
+		//features touched by insert
+		if(strtoupper($element[tag]) == "WFS:INSERT" && $element[type] == "open"){
+			$insert = true;
+			$insertlevel = $element[level];
+		if($insert && $element[level] == $insertlevel + 1 && $element[type] == "open"){
+			array_push($features, $element[tag]);
+		if(strtoupper($element[tag]) == "WFS:INSERT" && $element[type] == "close"){
+			$insert = false;
+		//updated features
+		if(strtoupper($element[tag]) == "WFS:UPDATE" && $element[type] == "open"){
+			array_push($features, $element[attributes]["typeName"]);
+		//deleted features
+		if(strtoupper($element[tag]) == "WFS:DELETE" && $element[type] == "open"){
+	return $features;
+ * sends the data of WFS Transaction and echos the response
+ *  @param string url to send the WFS Transaction to
+ *  @param string WFS Transaction data
+function doTransaction($url, $data){
+	$arURL = parse_url($url);
+	$host = $arURL["host"];
+	$port = $arURL["port"];
+	if($port == '') $port = 80;
+	$path = $arURL["path"];
+	$method = "POST";
+	$result = sendToHost($host,$port,$method,html_entity_decode($path),$data);
+	//delete header from result
+	$result = mb_eregi_replace("^[^<]*", "", $result);
+	$result = mb_eregi_replace("[^>]*$", "", $result);
+	echo $result;
+	if(!session_is_registered("owsproxyUrls")){ //TODO: exchange function, because it is deprecated and will not longer be supported by php 5.4!
+		$notice = new mb_notice("owsproxy found URL ".$i.": ".$req);
+		$notice = new mb_notice("MD5 URL ".$id." - external link: ".$extReq);
+	return $content;
+//	$extReq = "http://".$_SESSION['HTTP_HOST'] ."/owsproxy/". $reqParams['sid'] ."/".$id."?request=external";
+	$extReq = OWSPROXY ."/". $reqParams['sid'] ."/".$id."?request=external";
+	return $extReq;
+			$content = getDocumentContent($cUrl);
+			echo $content;
+	#return $r;
+	return "";
+			$cchar = "";
+			$cchar = "";
+		}else{
+			$cchar = "&";
+		$cchar = "?";
+	return $cchar;
+		$id = md5($url);
+	else{
+	return $id;
+function getCapabilities($url){
+	global $sid,$wms;
+	$t = array(htmlentities($arrayOnlineresources["wms_getcapabilities"]),htmlentities($arrayOnlineresources["wms_getmap"]),htmlentities($arrayOnlineresources["wms_getfeatureinfo"]));
+	$new = OWSPROXY ."/". $sid ."/".$wms."?";
+	$r = str_replace($t,$new,$arrayOnlineresources["wms_getcapabilities_doc"]);
+	echo $r;
+function getLegendUrl($wms){
+	//get wms id
+	$sql = "SELECT * FROM wms WHERE wms_owsproxy = $1";
+	$v = array($wms);
+	$t = array("s");
+		$wmsid = $row["wms_id"];
+	} else {
+		die();
+	//get the url
+	$v = array($wmsid, $reqParams['layer'], $reqParams['style'], $reqParams['format']);
+	} else {
+		throwE(array("No legend available."));
+		die();
+ * @param string OWSPROXY md5
+function checkWmsPermission($wms){
+	global $con, $n;
+	$myguis = $n->getGuisByPermission($_SESSION["mb_user_id"],true);
+	$v = array($wms);
+	$t = array("s");
+		die();
+		die();
+	return $service;
+ * validates the access permission by getting the appropriate wfs_conf
+ * to each feature requested and check the wfs_conf permission
+ * @param array array of requested featuretype names
+ * @return array array with detailed information on reqested wfs
+function checkWfsPermission($wfsOws, $features){
+	global $con, $n;
+	$myconfs = $n->getWfsConfByPermission($_SESSION["mb_user_id"]);
+	//check if we know the features requested
+	if(count($features) == 0){
+		throwE(array("No wfs_feature data available."));
+		die();
+	//get wfs
+	$sql = "SELECT * FROM wfs WHERE wfs_owsproxy = $1";
+	$v = array($wfsOws);
+	$t = array("s");
+		$service["wfs_id"] = $row["wfs_id"];
+		$service["wfs_getcapabilities"] = $row["wfs_getcapabilities"];
+		$service["wfs_getfeature"] = $row["wfs_getfeature"];
+		$service["wfs_describefeaturetype"] = $row["wfs_describefeaturetype"];
+		$service["wfs_transaction"] = $row["wfs_transaction"];
+		$service["wfs_getcapabilities_doc"] = $row["wfs_getcapabilities_doc"];
+	else{
+		throwE(array("No wfs data available."));
+		die();
+	foreach($features as $feature){
+		//get appropriate wfs_conf
+		$sql = "SELECT wfs_conf.wfs_conf_id FROM wfs_conf ";
+		$sql.= "JOIN wfs_featuretype ";
+		$sql.= "ON wfs_featuretype.featuretype_id = wfs_conf.fkey_featuretype_id ";
+		$sql.= "WHERE wfs_featuretype.featuretype_name = $2 ";
+		$sql.= "AND wfs_featuretype.fkey_wfs_id = $1";
+		$v = array($service["wfs_id"], $feature);
+		$t = array("i","s");
+			$notice = new mb_notice("Permissioncheck failed no wfs conf for wfs ".$service["wfs_id"]." with feturetype ".$feature);
+			throwE(array("No wfs_conf data for featuretype ".$feature));
+			die();
+		$conf_id = $row["wfs_conf_id"];
+		//check permission
+		if(!in_array($conf_id, $myconfs)){
+			$notice = new mb_notice("Permissioncheck failed:".$conf_id." not in ".implode(",", $myconfs));
+			throwE(array("Permission denied."," -> ".$conf_id, implode(",", $myconfs)));
+			die();
+	return $service;
+function checkLayerPermission($wms_id,$l){
+//	$notice = new mb_notice("owsproxy: checkLayerpermission: wms: ".$wms_id.", layer: ".$l);
+	$r = array();
+		if($n->getLayerPermission($wms_id, $mysl, $_SESSION["mb_user_id"]) === true){
+	return $ret;
+	else {
+	return $d->file;
More information about the Mapbender_commits
