[Mapbender-commits] r8568 - in trunk/mapbender/http: classes php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Sat Feb 23 12:51:56 PST 2013
Author: armin11
Date: 2013-02-23 12:51:55 -0800 (Sat, 23 Feb 2013)
New Revision: 8568
Added:
   trunk/mapbender/http/classes/class_ckan.php
   trunk/mapbender/http/classes/class_ckanApi.php
   trunk/mapbender/http/php/mod_exportMapbenderLayer2CkanObjects.php
   trunk/mapbender/http/php/mod_syncCkan.php
Initial commit for push api to ckan instance. Tested with ckan 1.8.1b. Uses different api versions (also action api is supported). Not yet ready! It syncs mapbender layer objects to a ckan datamodel. A central group is defined for the mapbender instance. Well be further developed next week.
Added: trunk/mapbender/http/classes/class_ckan.php
--- trunk/mapbender/http/classes/class_ckan.php	                        (rev 0)
+++ trunk/mapbender/http/classes/class_ckan.php	2013-02-23 20:51:55 UTC (rev 8568)
@@ -0,0 +1,77 @@
+<?php
+# http://www.mapbender.org/index.php/class_ckanPackage.php
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../../core/globalSettings.php");
+class ckanPackage {
+	var $id;
+	var $name;
+	var $title;
+	var $resources;
+	var $author;
+	var $maintainer;
+	var $maintainer_email;
+	var $licence_id;
+	var $tags;
+	var $notes;
+	var $extras;
+	function __construct() {
+		//initialize empty ckanPackage object
+		//attributes which are handled by ckan itself
+		//$this->id = "";
+		//attributes which are handled by external datasources
+		$this->name = "";
+		$this->title = "";
+		$this->resources = array();
+		$this->author = "";
+		$this->author_email = "";
+		$this->maintainer = "";
+		$this->maintainer_email = "";
+		$this->licence_id = "";
+		$this->tags = "";//list
+		$this->notes = "";
+		$this->extras = "";//{ Name-String: String, ... } }
+	public function toSomething ($xml) {
+		return $xml;
+class ckanGroup {
+	var $id;
+	var $name;
+	var $title;
+	var $packages;
+		//initialize empty ckanGroup object
+		//$this->id = "";
+		$this->name = "";
+		$this->packages = "";//list of datasets(packages)
+		return $xml;
Added: trunk/mapbender/http/classes/class_ckanApi.php
--- trunk/mapbender/http/classes/class_ckanApi.php	                        (rev 0)
+++ trunk/mapbender/http/classes/class_ckanApi.php	2013-02-23 20:51:55 UTC (rev 8568)
@@ -0,0 +1,932 @@
+<?php
+ * Copyright (c) 2010 Jeffrey Barke <http://jeffreybarke.net/>
+ * Permission is hereby granted, free of charge, to any person obtaining
+ * a copy of this software and associated documentation files (the
+ * "Software"), to deal in the Software without restriction, including
+ * without limitation the rights to use, copy, modify, merge, publish,
+ * distribute, sublicense, and/or sell copies of the Software, and to
+ * permit persons to whom the Software is furnished to do so, subject to
+ * the following conditions:
+ * The above copyright notice and this permission notice shall be
+ * included in all copies or substantial portions of the Software.
+ * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
+ * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF
+ * MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND
+ * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE
+ * LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION
+ * OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION
+ * WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
+ * Based on following software:
+ * A PHP client for the CKAN (Comprehensive Knowledge Archive Network) API.
+ * For details and documentation, please see http://github.com/jeffreybarke/Ckan_client-PHP
+ * @author		Jeffrey Barke
+ * @copyright	Copyright 2010 Jeffrey Barke
+ * @license		http://github.com/jeffreybarke/Ckan_client-PHP/blob/master/LICENSE
+ * @link		http://github.com/jeffreybarke/Ckan_client-PHP
+require_once(dirname(__FILE__) . "/../../core/globalSettings.php");
+class ckanApi
+	// Properties ---------------------------------------------------------
+	 * Client's API key. Required for any PUT or POST methods.
+	 * @link	http://knowledgeforge.net/ckan/doc/ckan/api.html#ckan-api-keys
+	public $api_key = FALSE;
+	 * Servers Host IP. Required for any PUT or POST methods.
+	public $host_name = FALSE;
+	 * Version of the CKAN API we're using.
+	 * @var		string
+	 * @link	http://knowledgeforge.net/ckan/doc/ckan/api.html#api-versions
+	private $api_version = '2';
+	 * URI to the CKAN web service.
+	 * @var		string
+	public $base_url = 'http://ckan.net/api/%d/';
+	 * Internal cURL object.
+	private $ch = FALSE;
+	 * cURL headers.
+	private $ch_headers;
+	 * Standard HTTP status codes.
+	 * @var		array
+	private $http_status_codes = array(
+		'200' => 'OK',
+		'201' => 'OK - package created successfully!',
+		'301' => 'Moved Permanently',
+		'400' => 'Bad Request',
+		'403' => 'Not Authorized',
+		'404' => 'Not Found',
+		'409' => 'Conflict (e.g. name already exists)',
+		'500' => 'Service Error'
+	 * Array of CKAN resources and their URI fragment.
+	 * @var		array
+	 * @link	http://knowledgeforge.net/ckan/doc/ckan/api.html#ckan-model-api
+	private $resources = array(
+		'package_register' => 'rest/package',
+		'package_entity' => 'rest/package',
+		'group_register' => 'rest/group',
+		'group_entity' => 'rest/group',
+		'tag_register' => 'rest/tag',
+		'tag_entity' => 'rest/tag',
+		'rating_register' => 'rest/rating',
+		'rating_entity' => 'rest/rating',
+		'revision_register' => 'rest/revision',
+		'revision_entity' => 'rest/revision',
+		'license_list' => 'rest/licenses',
+		'package_search' => 'search/package'
+	 * @var		array
+	private $actionList = array(
+		'package_create'  => 'action/package_create',
+		'package_show' => 'action/package_show',
+		'package_update' => 'action/package_update',
+		'package_delete' => 'action/package_delete',
+		'resource_create' => 'action/resource_create',
+		'resource_show' => 'action/resource_show',
+		'resource_update' => 'action/resource_update',
+		'resource_delete' => 'action/resource_delete',
+		'organization_create' => 'action/organization_create',
+		'organization_show' => 'action/organization_show',
+		'organization_update' => 'action/organization_update',
+		'organization_delete' => 'action/organization_delete',
+		'group_create' => 'action/group_create',
+		'group_update' => 'action/group_update',
+		'group_delete' => 'action/group_delete',
+		'group_show' => 'action/group_show',
+		'group_package_show' => 'action/group_package_show',
+		'member_create' => 'action/member_create',
+		'roles_show' => 'action/roles_show',
+		'member_delete' => 'action/member_delete',
+		'package_owner_org_update' => 'package_owner_org_update',
+		'group_list_authz' => 'action/group_list_authz'
+	 * ckanApi user agent string.
+	 * @var		string
+	private $user_agent = CONNECTION_USERAGENT;
+	// Magic methods ------------------------------------------------------
+	 * Constructor
+	 * Calls the API key, base URI and user agent setters.
+	 * Initializes the internal cURL object.
+	 * @param	string	CKAN API key.
+	public function __construct($api_key = FALSE,$host_name = FALSE)
+		// If provided, set the API key.
+		if ($api_key)
+			$this->set_api_key($api_key);
+		// If provided, set the Name of host to call - needed for decide if proxy should be used.
+		if ($host_name)
+			$e = new mb_exception($host_name);
+			$this->set_host_name($host_name);
+		// Set base URI and Ckan_client user agent string.
+		$this->set_base_url();
+		$this->set_user_agent();
+		// Create cURL object.
+		$this->ch = curl_init();
+		$e = new mb_exception($this->host_name);
+	    	$NOT_PROXY_HOSTS_array = explode(",", NOT_PROXY_HOSTS);
+		if(CONNECTION_PROXY != "" AND (in_array($this->host_name, $NOT_PROXY_HOSTS_array)!= true)){
+			curl_setopt($this->ch, CURLOPT_PROXY,CONNECTION_PROXY.":".CONNECTION_PORT);
+			$e = new mb_notice("class_ckanApi.php: Proxy will be used!");
+			if(CONNECTION_PASSWORD != ""){
+				curl_setopt ($this->ch, CURLOPT_PROXYUSERPWD, CONNECTION_USER.':'.CONNECTION_PASSWORD);
+		} else {
+			$e = new mb_notice("class_ckanApi.php: Proxy will not be used!");
+		// Follow any Location: headers that the server sends.
+		curl_setopt($this->ch, CURLOPT_FOLLOWLOCATION, TRUE);
+		// However, don't follow more than five Location: headers.
+		curl_setopt($this->ch, CURLOPT_MAXREDIRS, 5);
+		// Automatically set the Referer: field in requests
+		// following a Location: redirect.
+		curl_setopt($this->ch, CURLOPT_AUTOREFERER, TRUE);
+		// Return the transfer as a string instead of dumping to screen.
+		curl_setopt($this->ch, CURLOPT_RETURNTRANSFER, TRUE);
+		// If it takes more than 45 seconds, fail
+		curl_setopt($this->ch, CURLOPT_TIMEOUT, 45);
+		// We don't want the header (use curl_getinfo())
+		curl_setopt($this->ch, CURLOPT_HEADER, FALSE);
+		// Set user agent to Ckan_client
+		curl_setopt($this->ch, CURLOPT_USERAGENT, $this->user_agent);
+		// Track the handle's request string
+		curl_setopt($this->ch, CURLINFO_HEADER_OUT, TRUE);
+		// Attempt to retrieve the modification date of the remote document.
+		curl_setopt($this->ch, CURLOPT_FILETIME, TRUE);
+		// Initialize cURL headers
+		$this->set_headers();
+		// Include PHP Markdown library
+		//require_once('lib/php_markdown/markdown.php');
+	 * Destructor
+	 * Since it's possible to leave cURL open, this is the last chance to
+	 * close it.
+	public function __destruct()
+		// Cleanup
+		if ($this->ch)
+			curl_close($this->ch);
+			unset($this->ch);
+	// Setters ------------------------------------------------------------
+	 * Sets the CKAN API key.
+	 * @access	public
+	 * @return	void
+	public function set_api_key($api_key)
+		$this->api_key = $api_key;
+	 * Sets the Host IP.
+	 * @access	public
+	 * @param	string	HOST IP / Name.
+	 * @return	void
+	public function set_host_name($host_name)
+		$this->host_name = $host_name;
+	 * Sets the CKAN API base URI.
+	 * @access	private
+	 * @return	void
+	public function set_base_url()
+		// Append the CKAN API version to the base URI.
+		$this->base_url = sprintf($this->base_url, $this->api_version);
+	 * Sets the custom cURL headers.
+	 * @access	private
+	 * @return	void
+	private function set_headers()
+		$date = new DateTime(NULL, new DateTimeZone('UTC'));
+		$this->ch_headers = array(
+			'Date: ' . $date->format('D, d M Y H:i:s') . ' GMT', // RFC 1123
+			'Accept: application/json;q=1.0, application/xml;q=0.5, */*;q=0.0',
+			'Accept-Charset: utf-8',
+			'Accept-Encoding: gzip',
+			'content-type: application/json'
+	 * Sets the Ckan_client user agent string.
+	 * @access	private
+	 * @return	void
+	private function set_user_agent()
+		if ('80' === @$_SERVER['SERVER_PORT'])
+			$server_name = 'http://' . $_SERVER['SERVER_NAME'];
+		else
+			$server_name = '';
+		$this->user_agent = sprintf($this->user_agent, $this->version) .
+			' (' . $server_name . $_SERVER['PHP_SELF'] . ')';
+	// Public action API methods -----------------------------------------------
+	// package show
+	 * @access	public
+	 * @param  	string  id or name of the dataset
+	 * @return	the dataset as dictionary
+	 * @link	http://docs.ckan.org/en/latest/apiv3.html#ckan.logic.action.get.package_show
+	public function action_package_show($id)
+		return $this->make_request('POST',
+			$this->actionList['package_show'],
+			$id);
+	// package create
+	 * @access	public
+	 * @param  	string  package
+	 * @return	the newly created dataset as dictionary
+	 * @link	http://docs.ckan.org/en/latest/apiv3.html#ckan.logic.action.create.package_create
+	public function action_package_create($data)
+			$this->actionList['package_create'],
+			$data);
+	// package update
+	 * @access	public
+	 * @return	the updated dataset as dictionary
+	 * @link	http://docs.ckan.org/en/latest/apiv3.html#ckan.logic.action.update.package_update
+	public function action_package_update($data)
+			$this->actionList['package_update'],
+			$data);
+	// package delete
+	 * @access	public
+	 * @return	?
+	 * @link	http://docs.ckan.org/en/latest/apiv3.html#ckan.logic.action.delete.package_delete
+	public function action_package_delete($id)
+			$this->actionList['package_delete'],
+			$id);
+	// group create
+	 * @access	public
+	 * @param  	string  group
+	 * @return	the newly created group as dictionary
+	 * @link	http://docs.ckan.org/en/latest/apiv3.html#ckan.logic.action.create.group_create
+	public function action_group_create($data)
+			$this->actionList['group_create'],
+			$data);
+	// group show
+	 * @access	public
+	public function action_group_show($id)
+			$this->actionList['group_show'],
+			$id);
+	// group delete
+	 * @access	public
+	public function action_group_delete($id)
+			$this->actionList['group_delete'],
+			$id);
+	// group update
+	 * @access	public
+	 * @return	the updated group as dictionary
+	public function action_group_update($data)
+			$this->actionList['group_update'],
+			$data);
+	//group_package_show
+	 * @access	public
+	 * @return	the packages of a group dictionaries
+	public function action_group_package_show($id)
+			$this->actionList['group_package_show'],
+			$id);
+	// Public (API) methods -----------------------------------------------
+	// package register resource
+	 * @access	public
+	 * @return	array	An array of all package IDs.
+	public function get_package_register()
+		return $this->make_request('GET', $this->resources['package_register']);
+	 * @access	public
+	 * @return	bool
+	 * @link	http://knowledgeforge.net/ckan/doc/ckan/api.html#model-api-data-formats
+	public function post_package_register($id, $data)
+			$this->resources['package_register']. "/" . $id ,
+			$data);
+	* @access  public
+	* @return  bool
+	* @since  Version 0.1.0
+	* doc: https://github.com/luizsoliveira/Ckan_client-PHP/commit/patch-1
+	public function post_package_update($data)
+		$json = json_decode($data, TRUE);
+		$this->resources['package_register'] . "/" . $json['name'],
+		$data);
+	// package entity resouce
+	 * @access	public
+	 * @param	string	package ID
+	 * @return	object	package
+	public function get_package_entity($package)
+		$e = new mb_exception($this->resources['package_entity'] . '/' . urlencode($package));
+			$this->resources['package_entity'] . '/' . urlencode($package));
+	 * @access	public
+	 * @param	string	Packing
+	 * @return	bool
+	public function put_package_entity($packageName, $data)
+		return $this->make_request('PUT',
+			$this->resources['package_entity'] . '/' . urlencode($packageName),
+			$data);
+	//Following function is not allowed - it seems to be only possible to delete one package if version 3 of the api is used (action api)
+	/*public function delete_package_entity($package)
+		return $this->make_request('DELETE',
+	public function delete_package_entity($data)
+		$e = new mb_exception("post: ".$data);
+			'../action/package_delete',
+			$data);
+	// package utility alias
+	 * CKAN package GET utility alias.
+	 * @see		get_package_register(), get_package_entity()
+	 * @access	public
+	public function get_package($package = FALSE)
+		if ($package)
+			return $this->get_package_entity($package);
+		else
+			return $this->get_package_register();
+	// Group register resource
+	 * @access	public
+	 * @return	array	An array of all group IDs.
+	public function get_group_register()
+		return $this->make_request('GET', $this->resources['group_register']);
+	// Group entity resource
+	 * @access	public
+	 * @param	string	Group ID
+	 * @return	object	Group
+	public function get_group_entity($group)
+			$this->resources['group_entity'] . '/' . urlencode($group));
+	// Group utility alias
+	 * CKAN group GET utility alias.
+	 * @see		get_group_register(), get_group_entity()
+	 * @access	public
+	public function get_group($group = FALSE)
+		if ($group)
+			return $this->get_group_entity($group);
+		else
+			return $this->get_group_register();
+	// Tag register resource
+	 * @access	public
+	public function get_tag_register()
+		return $this->make_request('GET', $this->resources['tag_register']);
+	// Tag entity resource
+	 * @access	public
+	public function get_tag_entity($tag)
+		return $this->make_request('GET', $this->resources['tag_entity'] .
+			'/' . urlencode($tag));
+	// Tag utility alias
+	 * @access	public
+	public function get_tag($tag = FALSE)
+		if ($tag)
+			return $this->get_tag_entity($tag);
+		else
+			return $this->get_tag_register();
+	// Revision register resource
+	 * @access	public
+	public function get_revision_register()
+			$this->resources['revision_register']);
+	// Revision entity resource
+	 * @access	public
+	public function get_revision_entity($revision)
+			$this->resources['revision_entity'] . '/' . urlencode($revision));
+	// Revision utility alias
+	 * @access	public
+	public function get_revision($revision = FALSE)
+		if ($revision)
+			return $this->get_revision_entity($revision);
+		else
+			return $this->get_revision_register();
+	// License list resource
+	 * @access	public
+	public function get_license_list()
+		return $this->make_request('GET', $this->resources['license_list']);
+	// License utility alias
+	public function get_license()
+		return $this->get_license_list();
+	// Search API
+	 * Searches CKAN packages.
+	 * @access public
+	 * @param	string	Keywords to search for
+	 * @param	array	Optional. Search options.
+	 * @return	mixed	If success, search object. On fail, false.
+	public function search_package($keywords, $opts = array())
+		// Gots to have keywords or there's nothing to search for.
+		// Also, $opts better be an array
+		if (0 === strlen(trim($keywords)) || FALSE === is_array($opts))
+			throw new Exception('We need keywords, yo!');
+		$q = '';
+		// Set querystring based on $opts param.
+		$q .= '&order_by=' . ((isset($opts['order_by']))
+			? urlencode($opts['order_by']) : 'rank');
+		$q .= '&offset=' . ((isset($opts['offset']))
+			? urlencode($opts['offset']) : '0');
+		$q .= '&limit=' . ((isset($opts['limit']))
+			? urlencode($opts['limit']) : '20');
+		$q .= '&filter_by_openness=' . ((isset($opts['openness']))
+			? urlencode($opts['openness']) : '0');
+		$q .= '&filter_by_downloadable=' . ((isset($opts['downloadable']))
+			? urlencode($opts['downloadable']) : '0');
+		return $data = $this->make_request('GET',
+			$this->resources['package_search'] . '?q=' .
+			urlencode($keywords) . $q);
+	 * CKAN package search utility alias, since it's most likely ppl just
+	 * want to search the packages.
+	 * @see		search_package()
+	 * @access	public
+	public function search($keywords, $opts = array())
+		return $this->search_package($keywords, $opts);
+	// Public methods -----------------------------------------------------
+	 * Helper function to ease the display of search results.
+	 * Outputs directly to screen.
+	 * @access	public
+	 * @param	object	Result from search() or search_package()
+	 * @param	array	Optional. An array of formatting options.
+	 * @return	void
+	public function search_display($data, $opts = array())
+		if ($data)
+			// Set vars based on $opts param.
+			$search_term = (isset($opts['search_term'])) ?
+				$opts['search_term'] : '';
+			$title_tag = '<' .
+				((isset($opts['title_tag'])) ? $opts['title_tag'] : 'h2') . '>';
+			$title_close_tag = str_replace('<', '</', $title_tag);
+			$result_list_tag = (isset($opts['result_list_tag']))
+				? $opts['result_list_tag'] : 'ul';
+			if (strlen(trim($result_list_tag)))
+				$result_list_close_tag = '</' . $result_list_tag . '>';
+				$result_list_tag = '<' . $result_list_tag . '>';
+			else
+				$result_list_close_tag = '';
+			$show_notes = (isset($opts['show_notes']))
+				? $opts['show_notes'] : FALSE;
+			$format_notes = (isset($opts['format_notes']))
+				? $opts['format_notes'] : FALSE;
+			// Set search title string
+			// is|are, count, ''|s, ''|search_term, .|:
+			printf($title_tag . 'There %s %d result%s%s%s' . $title_close_tag,
+				(($data->count === 1) ? 'is' : 'are'),
+				$data->count,
+				(($data->count === 1) ? '' : 's'),
+				(strlen(trim($search_term))
+					? ' for “' . $search_term . '”' : ''),
+				(($data->count === 0) ? '.' : ':'));
+			if ($data->count > 0)
+				print $result_list_tag;
+				foreach ($data->results as $val)
+					$package = $this->get_package_entity($val);
+					printf('<li><a href="%s">%s</a>',
+						$package->ckan_url,
+						$package->title);
+					if (isset($package->notes) && $package->notes &&
+						$show_notes)
+						print ': ';
+						if (TRUE === $format_notes)
+							print $package->notes;
+						elseif (FALSE === $format_notes)
+						else
+							print strip_tags($package->notes,
+								$format_notes);
+					print '</li>';
+				print $result_list_close_tag;
+	// Private methods ----------------------------------------------------
+	 * Make a request to the CKAN API.
+	 * @access	private
+	 * @param	string	HTTP method (GET, PUT, POST).
+	 * @param	string	URI fragment to CKAN resource.
+	 * @param	string	Optional. String in JSON-format that will be in request body.
+	 * @return	mixed	If success, either an array or object. Otherwise FALSE.
+	private function make_request($method, $url, $data = FALSE)
+		// Set cURL method.
+		curl_setopt($this->ch, CURLOPT_CUSTOMREQUEST, strtoupper($method));
+		// Set cURL URI.
+		$e = new mb_exception($this->base_url . $url);
+		$curlUrl = $this->base_url . $url;
+		curl_setopt($this->ch, CURLOPT_URL, $curlUrl);
+		// If POST or PUT, add Authorization: header and request body
+		if ($method === 'POST' || $method === 'PUT')
+			// We needs a key and some data, yo!
+			$e = new mb_exception("method: ".$method." new url: ".$this->base_url . $url." data: ".$data);
+			if ( ! ($this->api_key && $data))
+				// throw exception
+				throw new Exception('Missing either an API key or POST data.');
+			else
+				// Add Authorization: header.
+				$this->ch_headers[] = 'Authorization: ' . $this->api_key;
+				$e = new mb_exception("added following to headers: ".'Authorization: ' . $this->api_key);
+				// Add data to request body.
+				curl_setopt($this->ch, CURLOPT_POSTFIELDS, $data);
+		else
+			// Since we can't use HTTPS,
+			 // if it's in there, remove Authorization: header
+			$key = array_search('Authorization: ' . $this->api_key,
+				$this->ch_headers);
+			if ($key !== FALSE)
+				unset($this->ch_headers[$key]);
+			curl_setopt($this->ch, CURLOPT_POSTFIELDS, NULL);
+		// Set headers.
+		curl_setopt($this->ch, CURLOPT_HTTPHEADER, $this->ch_headers);
+		// Execute request and get response headers.
+		$response = curl_exec($this->ch);
+		$info = curl_getinfo($this->ch);
+		// Check HTTP response code
+		if ($info['http_code'] !== 200)
+			throw new Exception($info['http_code'] . ': ' .
+				$this->http_status_codes[$info['http_code']]);
+		} else {
+			$e = new mb_exception("Returned 200 - OK");
+			$e = new mb_exception($response);
+		// Determine how to parse
+		if (isset($info['content_type']) && $info['content_type'])
+			$content_type = str_replace('application/', '',
+				substr($info['content_type'], 0,
+				strpos($info['content_type'], ';')));
+			//return $response;
+			return $this->parse_response($response, $content_type);
+		else
+			throw new Exception('Unknown content type.');
+	 * Parse the response from the CKAN API.
+	 * @access	private
+	 * @param	string	Data returned from the CKAN API.
+	 * @param	string	Format of data returned from the CKAN API.
+	private function parse_response($data = FALSE, $format = FALSE)
+		if ($data)
+			if ('json' === $format)
+				return json_decode($data);
+			else
+				throw new Exception('Unable to parse this data format.');
+		return FALSE;
Added: trunk/mapbender/http/php/mod_exportMapbenderLayer2CkanObjects.php
--- trunk/mapbender/http/php/mod_exportMapbenderLayer2CkanObjects.php	                        (rev 0)
+++ trunk/mapbender/http/php/mod_exportMapbenderLayer2CkanObjects.php	2013-02-23 20:51:55 UTC (rev 8568)
@@ -0,0 +1,279 @@
+<?php
+//mod_exportMapbenderLayer2CkanObjects.php
+require_once(dirname(__FILE__).'/../../conf/ckan.conf');
+//metadata columns of wms table
+/*contactorganization
+contactperson
+address
+city
+postcode
+contactvoicetelephone
+contactelectronicmailaddress*/
+//select open data information from mapbenders database
+$sql = <<<SQL
+select wms_id, layer_id, layer.uuid as uuid, wms_title || ':' || layer_title as title, wms_abstract || ':' || layer_abstract as notes, tou_licence_title, tou_licence_url, tou_licence_id, isopen, to_timestamp(wms_timestamp) as wms_timestamp, to_timestamp(wms_timestamp_create) as wms_timestamp_create, wms_owner as service_owner, fkey_mb_group_id as service_group, contactperson, address, city, postcode, contactvoicetelephone, contactelectronicmailaddress from (select termsofuse_id, description as tou_licence_title, descriptionlink as tou_licence_url, wms_tou.name as tou_licence_id, wms_tou.isopen as isopen, wms_id, wms_title, wms_timestamp, wms_timestamp_create, wms.wms_abstract, wms.wms_owner, wms.fkey_mb_group_id, contactperson, address, city, postcode, contactvoicetelephone, contactelectronicmailaddress from (select * from termsofuse inner join wms_termsofuse on termsofuse.termsofuse_id = wms_termsofuse.fkey_termsofuse_id and termsofuse.termsofuse_id in (2,3,4,5)) as wms_tou
  inner join wms on wms_tou.fkey_wms_id = wms.wms_id) as wms_tou2 inner join layer on wms_tou2.wms_id = layer.fkey_wms_id and layer_searchable=1;
+SQL;
+$result = db_query($sql);
+//initialize result array
+$sqlTable = array();
+while ($row = db_fetch_array($result)) {
+	$sqlTable['name'][] = $row['uuid'];
+	$sqlTable['title'][] = $row['title'];
+	$sqlTable['service_id'][] = $row['wms_id'];
+	$sqlTable['resource_type'][] = "Kartenebene";
+	$sqlTable['resource_id'][] = $row['layer_id'];
+	$sqlTable['service_group'][] = $row['service_group'];
+	$sqlTable['service_owner'][] = $row['service_owner'];
+	$sqlTable['service_person'][] = $row['contactperson'];
+	$sqlTable['service_address'][] = $row['address'];
+	$sqlTable['service_city'][] = $row['city'];
+	$sqlTable['service_postcode'][] = $row['postcode'];
+	$sqlTable['service_phone'][] = $row['contactvoicetelephone'];
+	$sqlTable['service_email'][] = $row['contactelectronicmailaddress'];
+	$sqlTable['notes'][] = $row['notes'];
+	$sqlTable['tou_licence_title'][] = $row['tou_licence_title'];
+	$sqlTable['tou_licence_id'][] = $row['tou_licence_id'];
+	$sqlTable['tou_licence_url'][] = $row['tou_licence_url'];
+	$sqlTable['isopen'][] = $row['isopen'];
+	$sqlTable['temporal_coverage_to'][] = $row['wms_timestamp'];
+	$sqlTable['temporal_coverage_from'][] = $row['wms_timestamp_create'];
+$groupOwnerArray = array();
+$groupOwnerArray[0] = $sqlTable['service_group'];
+$groupOwnerArray[1] = $sqlTable['service_owner'];
+//get orga information
+$groupOwnerArray = getOrganizationInfoForServices($groupOwnerArray);
+//push information from groupOwnerArray to sqlTable
+$sqlTable['organization'] = $groupOwnerArray[3];
+$sqlTable['userId'] = $groupOwnerArray[2];
+$sqlTable['orgaId'] = $groupOwnerArray[11];
+$sqlTable['group_title'] = $groupOwnerArray[4];
+$sqlTable['group_address'] = $groupOwnerArray[5];
+$sqlTable['group_email'] = $groupOwnerArray[6];
+$sqlTable['group_telephone'] = $groupOwnerArray[7];
+$sqlTable['group_postcode'] = $groupOwnerArray[8];
+$sqlTable['group_city'] = $groupOwnerArray[9];
+$sqlTable['group_logo'] = $groupOwnerArray[10];
+$sqlTable['group_homepage'] = $groupOwnerArray[12];
+//echo "test";
+//test output
+/*for ($i=0; $i < count($sqlTable['name']); $i++){
+		echo $sqlTable['name'][$i]." - ".$sqlTable['title'][$i]." - ".$sqlTable['service_id'][$i]." - ".$sqlTable['resource_id'][$i]." - ".$sqlTable['organization'][$i]." - ".$sqlTable['orgaId'][$i]."<br>";
+$transpSqlTable = array_transpose($sqlTable);
+/*echo "<br>".$test[0]['name']."<br>";
+$test2 = $test[0];
+echo "<br>".$test2['name']." - ".$test2['title']."<br>";
+echo "<br>".$sqlTable['name'][0]."<br>";*/
+$ckanPackages = new stdClass();
+$ckanPackages->result = array();
+for ($i=0; $i < count($sqlTable['name']); $i++){
+	$ckanPackages->result[] = buildCkanPackage($transpSqlTable[$i]);
+header('Content-Type: application/json; charset='.CHARSET);
+echo json_encode($ckanPackages);
+//build json objects!
+function buildCkanPackage ($mbArray) {
+	//example package and mapping
+	$package->maintainer = $mbArray['group_title']; //mb_group.mb_group_name
+	$package->point_of_contact = $mbArray['group_title'];//"Andreas Becker"; //mb_user.mb_user_name - owner
+	$package->point_of_contact_free_address = $mbArray['group_address']."- test - ". $mbArray['group_postcode']." ".$mbArray['group_city']."\n".$mbArray['group_telephone'];//"Ferdinand-Sauerbruch-Straße 15"; //mb_group.mb_group_address
+	$package->point_of_contact_email = $mbArray['group_email'];//"poststelle at lvermgeo.rlp"; //mb_group.mb_group_email
+	$package->license = $mbArray['tou_licence_title'];//"Datenlizenz Deutschland – Namensnennung – nicht kommerziell"; // termsofuse.description
+	$package->author = $mbArray['mb_user_id'];//""; //mb_group.mb_group_name
+	$package->download_url = "http://www.geoportal.rlp.de/mapbender/php/wms.php?layer_id=".$mbArray['resource_id']."&REQUEST=GetCapabilities&VERSION=1.1.1&SERVICE=WMS";//$mbArray['mb_user_id'];//"http://www.geoportal.rlp.de/portal/karten.html?LAYER[zoom]=1&LAYER[id]=36699"; //
+	$package->version = "";//$mbArray['mb_user_id'];//""; //
+	$package->groups = array();
+	//for v1/v2 - only $package->groups[0] = "gdi-rp"; //constant
+	//$package->groups[0] = CKAN_GROUP_NAME;
+	//for v3:
+	$package->groups[0]->name = CKAN_GROUP_NAME; //constant
+	$package->name = $mbArray['name'];// $datasetName; //layer.uuid
+	$package->notes = $mbArray['notes'];//"Die (Digitale) Topographische Karte 1:100 000 ermöglicht aufgrund der abgebildeten Fläche die Darstellung großräumige Gebiete."; //wms.wms_abstract || layer.layer_abstract
+	$package->title = $mbArray['title'];//"Topographische Karte Rheinland-Pfalz 1:100.000"; //wms.wms_title || layer.layer_title - OK
+	$package->other_terms_of_use = "other terms of use";//$mbArray['mb_user_id'];// "test tou"; //null or ""
+	//TODO: problem date format
+	//$package->temporal_coverage_to = $mbArray['temporal_coverage_to'];// "2012-01-01"; // last update ? wms.wms_timestamp - OK
+	//$package->temporal_coverage_from = $mbArray['temporal_coverage_from'];// "2011-01-01"; // last update ? wms.wms_timestamp_create - OK
+	$package->temporal_coverage_to = "2012-01-01"; // last update ? wms.wms_timestamp - OK
+	$package->temporal_coverage_from = "2011-01-01"; // last update ? wms.wms_timestamp_create - OK
+	$package->content_type = $mbArray['resource_type'];// "testcontenttype"; //constant: Service
+	if ($mbArray['isopen'] == 1) {
+		$package->isopen = true;//true; //termsofuse.isopen - OK
+	} else {
+		$package->isopen = false;
+	$package->resources = array();
+	$package->resources[0]->description = "Anzeige im GeoPortal.rlp";//$mbArray['mb_user_id'];// "Link zur WMS-Darstellung im GeoPortal.rlp, die Darstellung erfolgt ab einem Maßstab 1:500.000"; //fix: "".id.id?
+	$package->resources[0]->format = "Kartenviewer"; //constant
+	$package->resources[0]->url = "http://www.geoportal.rlp.de/mapbender/php/wms.php?layer_id=".$mbArray['resource_id']."&REQUEST=GetCapabilities&VERSION=1.1.1&SERVICE=WMS";// "http://www.geoportal.rlp.de/portal/karten.html?LAYER[zoom]=1&LAYER[id]=36699"; //constant .. ids
+	$package->resources[0]->resource_type = "visualization"; //constant
+	$package->resources[1]->description = "WMS Capabilities Link zur Integration in GIS oder Webapplikationen";//$mbArray['mb_user_id'];// "Link zur WMS-Darstellung im GeoPortal.rlp, die Darstellung erfolgt ab einem Maßstab 1:500.000"; //fix: "".id.id?
+	$package->resources[1]->format = "WMS"; //constant
+	$package->resources[1]->url = "http://www.geoportal.rlp.de/mapbender/php/wms.php?layer_id=".$mbArray['resource_id']."&REQUEST=GetCapabilities&VERSION=1.1.1&SERVICE=WMS";// "http://www.geoportal.rlp.de/portal/karten.html?LAYER[zoom]=1&LAYER[id]=36699"; //constant .. ids
+	$package->resources[1]->resource_type = "visualization"; //constant
+	$package->resources[2]->description = "Metadaten zur WMS Kartenebene";//$mbArray['mb_user_id'];// "Link zur WMS-Darstellung im GeoPortal.rlp, die Darstellung erfolgt ab einem Maßstab 1:500.000"; //fix: "".id.id?
+	$package->resources[2]->format = "html"; //constant
+	$package->resources[2]->url = "http://www.geoportal.rlp.de/mapbender/php/mod_showMetadata.php?languageCode=de&resource=layer&layout=tabs&id=".$mbArray['resource_id'];// "http://www.geoportal.rlp.de/portal/karten.html?LAYER[zoom]=1&LAYER[id]=36699"; //constant .. ids
+	$package->resources[2]->resource_type = "metadata"; //constant
+	$package->author_address->url = $mbArray['mb_user_id'];// null; //null
+	$package->author_address->email = $mbArray['mb_user_id'];// ""; // ""
+	$package->maintainer_address->url = $mbArray['group_homepage'];//$mbArray['service_address'];// null; //mb_group.mb_group_homepage
+	$package->maintainer_address->email = $mbArray['service_email'];// ""; //mb_group.mb_group_email
+	$package->maintainer_address->free_address = $mbArray['service_address'].'\n'.$mbArray['service_postcode'];// null; //mb_group.mb_group_address - more things with \r\n mb_group_voicetelephone, ...
+	$package->terms_of_use->license_id = $mbArray['tou_licence_id'];// "ger-name-nc"; //termsofuse.name - OK
+	$package->terms_of_use->license_title = $mbArray['tou_licence_title'];// "Datenlizenz Deutschland – Namensnennung – nicht kommerziell"; //termsofuse.description OK
+	$package->terms_of_use->license_url = $mbArray['tou_licence_url'];// null; //termsofuse.descriptionlink OK
+	$package->terms_of_use->other = "test licence";//$mbArray['mb_user_id'];// null; // null?
+	$package->extras->sector = "Öffentlicher Sektor";
+	$package->extras->is_free_of_charge = false;
+	$package->extras->tag_thesauri = array();
+	$package->extras->tag_sources = array();
+	$package->extras->geographical_coverage = "Rheinland-Pfalz";
+	$package->extras->geographical_granularity = "Land";
+	$package->extras->content_type = "Datensatz";
+	$package->extras->used_datasets = array();*/
+	return $package;
+//other functions
+function getOrganizationInfoForServices($groupOwnerArray) {
+	//split array into two lists which are requested in two separate sqls
+	$listGroupIds = array();
+	$listOwnerIds = array();
+	//echo "<br>count groupOwnerArray: ".count($groupOwnerArray[0]);
+	for ($i=0; $i < count($groupOwnerArray[0]); $i++){
+		$key = $i;
+		if (!isset($groupOwnerArray[0][$i]) || is_null($groupOwnerArray[0][$i]) || $groupOwnerArray[0][$i] == 0){
+			$listOwnerIds[$key] = $groupOwnerArray[1][$i];
+		} else {
+			$listGroupIds[$key] = $groupOwnerArray[0][$i];
+	//for ownerList
+	$metadataContactArray = array();
+	$metadataContact = array();
+	$listGroupIdsKeys =  array_keys($listGroupIds);
+	$listOwnerIdsKeys =  array_keys($listOwnerIds);
+	$listOwnerIdsString = implode(",",$listOwnerIds);
+	$listGroupIdsString = implode(",",$listGroupIds);
+	//do the database requests
+	if ($listOwnerIdsString != "") {
+		$sql = "SELECT mb_group_name as metadatapointofcontactorgname, mb_group_title as metadatapointofcontactorgtitle, mb_group_id, mb_group_logo_path  as metadatapointofcontactorglogo, mb_group_address as metadatapointofcontactorgaddress, mb_group_email as metadatapointofcontactorgemail, mb_group_postcode as metadatapointofcontactorgpostcode, mb_group_city as metadatapointofcontactorgcity, mb_group_voicetelephone as metadatapointofcontactorgtelephone, mb_group_facsimiletelephone as metadatapointofcontactorgfax , mb_group_homepage, b.mb_user_id as mb_user_id FROM mb_group AS a, mb_user AS b, mb_user_mb_group AS c WHERE b.mb_user_id IN (".$listOwnerIdsString.") AND b.mb_user_id = c.fkey_mb_user_id AND c.fkey_mb_group_id = a.mb_group_id AND c.mb_user_mb_group_type=2";
+		$resultOrgaOwner = db_query($sql);
+		$index  = 0;
+		while ($row = db_fetch_array($resultOrgaOwner)) {
+			//push information into metadataContactArray
+			$metadataContactOwnerArray[$index]['metadatapointofcontactorgname'] = $row['metadatapointofcontactorgname'];
+			$metadataContactOwnerArray[$index]['metadatapointofcontactorgtitle'] = $row['metadatapointofcontactorgtitle'];
+			$metadataContactOwnerArray[$index]['metadatapointofcontactorgaddress'] = $row['metadatapointofcontactorgaddress'];
+			$metadataContactOwnerArray[$index]['metadatapointofcontactorgemail'] = $row['metadatapointofcontactorgemail'];
+			$metadataContactOwnerArray[$index]['metadatapointofcontactorgtelephone'] = $row['metadatapointofcontactorgtelephone'];
+			$metadataContactOwnerArray[$index]['metadatapointofcontactorgpostcode'] = $row['metadatapointofcontactorgpostcode'];
+			$metadataContactOwnerArray[$index]['metadatapointofcontactorgcity'] = $row['metadatapointofcontactorgcity'];
+			$metadataContactOwnerArray[$index]['metadatapointofcontactorglogo'] = $row['metadatapointofcontactorglogo'];
+			$metadataContactOwnerArray[$index]['mb_group_homepage'] = $row['mb_group_homepage'];
+			$metadataContactOwnerArray[$index]['mb_user_id'] = $row['mb_user_id'];
+			$metadataContactOwnerArray[$index]['orga_id'] = $row['mb_group_id'];
+			$index++;
+		$index = 0;
+		//push information directly into $groupOwnerArray at indizes from
+		for ($i=0; $i < count($listOwnerIds); $i++){
+			//find index of user with special id in array $metadataContactOwnerArray['user_id']
+			$index = findIndexInMultiDimArray($metadataContactOwnerArray, $listOwnerIds[$i], 'mb_user_id');
+			$groupOwnerArray[2][$listOwnerIdsKeys[$i]] = $metadataContactOwnerArray[$index]['user_id']; //user_id - 2
+			$groupOwnerArray[3][$listOwnerIdsKeys[$i]] = $metadataContactOwnerArray[$index]['metadatapointofcontactorgname']; //orga_name - 3
+			$groupOwnerArray[4][$listOwnerIdsKeys[$i]] = $metadataContactOwnerArray[$index]['metadatapointofcontactorgtitle']; //title - 4
+			$groupOwnerArray[5][$listOwnerIdsKeys[$i]] = $metadataContactOwnerArray[$index]['metadatapointofcontactorgaddress']; //address - 5
+			$groupOwnerArray[6][$listOwnerIdsKeys[$i]] = $metadataContactOwnerArray[$index]['metadatapointofcontactorgemail']; //email - 6
+			$groupOwnerArray[7][$listOwnerIdsKeys[$i]] = $metadataContactOwnerArray[$index]['metadatapointofcontactorgtelephone']; //telephone - 7
+			$groupOwnerArray[8][$listOwnerIdsKeys[$i]] = $metadataContactOwnerArray[$index]['metadatapointofcontactorgpostcode']; //postcode - 8
+			$groupOwnerArray[9][$listOwnerIdsKeys[$i]] = $metadataContactOwnerArray[$index]['metadatapointofcontactorgcity']; //city - 9
+			$groupOwnerArray[10][$listOwnerIdsKeys[$i]] = $metadataContactOwnerArray[$index]['metadatapointofcontactorglogo']; //logo - 10
+			$groupOwnerArray[11][$listOwnerIdsKeys[$i]] = $metadataContactOwnerArray[$index]['orga_id'];
+			$groupOwnerArray[12][$listOwnerIdsKeys[$i]] = $metadataContactOwnerArray[$index]['mb_group_homepage'];
+	//for groupList
+	if ($listGroupIdsString != "") {
+		$sql = "SELECT mb_group_name as metadatapointofcontactorgname, mb_group_title as metadatapointofcontactorgtitle, mb_group_id, mb_group_logo_path  as metadatapointofcontactorglogo, mb_group_address as metadatapointofcontactorgaddress, mb_group_email as metadatapointofcontactorgemail, mb_group_postcode as metadatapointofcontactorgpostcode, mb_group_city as metadatapointofcontactorgcity, mb_group_voicetelephone as metadatapointofcontactorgtelephone, mb_group_facsimiletelephone as metadatapointofcontactorgfax, mb_group_homepage, mb_group_id FROM mb_group WHERE mb_group_id IN (".$listGroupIdsString.")";
+		$resultOrgaGroup = db_query($sql);
+		$index  = 0;
+		while ($row = db_fetch_array($resultOrgaGroup)) {
+			$metadataContactGroupArray[$index]['metadatapointofcontactorgname'] = $row['metadatapointofcontactorgname'];
+			$metadataContactGroupArray[$index]['metadatapointofcontactorgtitle'] = $row['metadatapointofcontactorgtitle'];
+			$metadataContactGroupArray[$index]['metadatapointofcontactorgaddress'] = $row['metadatapointofcontactorgaddress'];
+			$metadataContactGroupArray[$index]['metadatapointofcontactorgemail'] = $row['metadatapointofcontactorgemail'];
+			$metadataContactGroupArray[$index]['metadatapointofcontactorgtelephone'] = $row['metadatapointofcontactorgtelephone'];
+			$metadataContactGroupArray[$index]['metadatapointofcontactorgpostcode'] = $row['metadatapointofcontactorgpostcode'];
+			$metadataContactGroupArray[$index]['metadatapointofcontactorgcity'] = $row['metadatapointofcontactorgcity'];
+			$metadataContactGroupArray[$index]['metadatapointofcontactorglogo'] = $row['metadatapointofcontactorglogo'];
+			$metadataContactGroupArray[$index]['mb_group_homepage'] = $row['mb_group_homepage'];
+			$metadataContactGroupArray[$index]['mb_user_id'] = $row['mb_user_id'];
+			$metadataContactGroupArray[$index]['orga_id'] = $row['mb_group_id'];
+			$index++;
+		$index = 0;
+		for ($i=0; $i < count($listGroupIds); $i++){
+			//find index of user with special id in array $metadataContactGroupArray['user_id']
+			$index = findIndexInMultiDimArray($metadataContactGroupArray, $listGroupIds[$i], 'mb_user_id');
+			$groupOwnerArray[2][$listGroupIdsKeys[$i]] = $metadataContactGroupArray[$index]['mb_user_id']; //user_id - 2
+			$groupOwnerArray[3][$listGroupIdsKeys[$i]] = $metadataContactGroupArray[$index]['metadatapointofcontactorgname']; //orga_name - 3
+			$groupOwnerArray[4][$listGroupIdsKeys[$i]] = $metadataContactGroupArray[$index]['metadatapointofcontactorgtitle']; //title - 4
+			$groupOwnerArray[5][$listGroupIdsKeys[$i]] = $metadataContactGroupArray[$index]['metadatapointofcontactorgaddress']; //address - 5
+			$groupOwnerArray[6][$listGroupIdsKeys[$i]] = $metadataContactGroupArray[$index]['metadatapointofcontactorgemail']; //email - 6
+			$groupOwnerArray[7][$listGroupIdsKeys[$i]] = $metadataContactGroupArray[$index]['metadatapointofcontactorgtelephone']; //telephone - 7
+			$groupOwnerArray[8][$listGroupIdsKeys[$i]] = $metadataContactGroupArray[$index]['metadatapointofcontactorgpostcode']; //postcode - 8
+			$groupOwnerArray[9][$listGroupIdsKeys[$i]] = $metadataContactGroupArray[$index]['metadatapointofcontactorgcity']; //city - 9
+			$groupOwnerArray[10][$listGroupIdsKeys[$i]] = $metadataContactGroupArray[$index]['metadatapointofcontactorglogo']; //logo - 10
+			$groupOwnerArray[11][$listGroupIdsKeys[$i]] = $metadataContactGroupArray[$index]['orga_id'];
+			$groupOwnerArray[12][$listGroupIdsKeys[$i]] = $metadataContactGroupArray[$index]['mb_group_homepage'];
+	return $groupOwnerArray;
+function array_transpose($array, $selectKey = false) {
+    if (!is_array($array)) return false;
+    $return = array();
+    foreach($array as $key => $value) {
+        if (!is_array($value)) return $array;
+        if ($selectKey) {
+            if (isset($value[$selectKey])) $return[] = $value[$selectKey];
+        } else {
+            foreach ($value as $key2 => $value2) {
+                $return[$key2][$key] = $value2;
+    return $return;
+function findIndexInMultiDimArray($multiDimArray, $needle, $columnName) {
+    foreach($multiDimArray as $index => $object) {
+        if($object[$columnName] == $needle) return $index;
+    return FALSE;
Added: trunk/mapbender/http/php/mod_syncCkan.php
--- trunk/mapbender/http/php/mod_syncCkan.php	                        (rev 0)
+++ trunk/mapbender/http/php/mod_syncCkan.php	2013-02-23 20:51:55 UTC (rev 8568)
@@ -0,0 +1,470 @@
+<?php
+// Display errors for demo
+//@ini_set('error_reporting', E_ALL);
+//@ini_set('display_errors', 'stdout');
+// Include class_ckanApi.php
+require_once(dirname(__FILE__).'/../classes/class_ckanApi.php');
+require_once(dirname(__FILE__).'/../classes/class_ckan.php');
+require_once(dirname(__FILE__).'/../classes/class_connector.php');
+// Create CKAN object
+// Takes optional API key parameter. Required for POST and PUT methods.
+$apiKey = API_KEY;
+$serverIp = CKAN_SERVER_IP;
+//initial instantiation of api class
+$ckan = new ckanApi($apiKey, $serverIp);
+$ckan->base_url='http://'.$serverIp.':5000/api/';
+//echo "API-key: ".$ckan->api_key."<br>";
+//echo "API-baseUrl: ".$ckan->base_url;
+//parse request parameters
+if (isset($_REQUEST["action"]) & $_REQUEST["action"] != "") {
+	$testMatch = $_REQUEST["action"];
+ 	if (!($testMatch == 'package_delete' or $testMatch == 'package_create' or $testMatch == 'package_show' or $testMatch == 'group_create' or $testMatch == 'group_delete' or $testMatch == 'group_package_show' or $testMatch == 'delete_all_packages_by_group' or $testMatch == 'group_show')){
+		echo 'action: <b>'.$testMatch.'</b> is not valid.<br/>';
+		die();
+	$action = $testMatch;
+	$testMatch = NULL;
+//get json objects from mapbender json interface
+/*$mapbenderCkanUrl = "http://localhost/mapbender_trunk/php/mod_exportMapbenderLayer2CkanObjects.php";
+$ckanObjectConnector = new connector($mapbenderCkanUrl);
+$ckanObjects = json_decode($ckanObjectConnector->file);
+echo json_encode($ckanObjects);
+//get current dataset names from mapbenders ckan object interface
+$mapbenderCkanUrl = "http://localhost/mapbender_trunk/php/mod_exportMapbenderLayer2CkanObjects.php";
+foreach ($ckanObjects->result as $dataset) {
+	$mbDatasetArray[] =  $dataset->name;
+print "<b>Mapbender datasets:</b><br>";
+if (count($mbDatasetArray) == 0) {
+	$mbDatasetArray = false;
+if ($mbDatasetArray) {
+	foreach ($mbDatasetArray as $dataset) {
+		print $dataset."<br>";
+print "<b>ckan datasets:</b><br>";
+//get old package names for defined group in ckan.conf file
+//thru action api
+$ckanDatasetArray = get_packages_by_group(CKAN_GROUP_NAME);
+if ($ckanDatasetArray) {
+	//debug output
+	foreach ($ckanDatasetArray as $dataset) {
+//compare the arrays
+//first those which can be deleted
+if ($ckanDatasetArray && $mbDatasetArray) {
+	$datasetToDelete = array_diff($ckanDatasetArray, $mbDatasetArray);
+} else {
+	if (!$ckanDatasetArray) {
+		$datasetToDelete = false;
+	if (!$mbDatasetArray) {
+		$datasetToDelete = $ckanDatasetArray;
+//show datasets to be deleted:
+if ($datasetToDelete) {
+	print "<b>ckan datasets to be deleted:</b><br>";
+	//debug output
+	foreach ($datasetToDelete as $dataset) {
+//check datasets to be updated:
+if (!$ckanDatasetArray) {
+	$datasetToUpdate = false;
+} else {
+	//get identical datasets
+	$datasetToUpdate = array_intersect($mbDatasetArray,$ckanDatasetArray);
+if ($datasetToUpdate) {
+	print "<b>ckan datasets to update:</b><br>";
+	foreach ($datasetToUpdate as $dataset) {
+} else {
+	print "<b>No datasets to update!</b><br>";
+//get datasets to be created
+	$datasetToCreate = array_diff($mbDatasetArray, $ckanDatasetArray);
+} else {
+		$datasetToCreate = $mbDatasetArray;
+		$datasetToCreate = false;
+if ($datasetToCreate) {
+	print "<b>Mapbender datasets to be created for the first time:</b><br>";
+	foreach ($datasetToCreate as $dataset) {
+	print "<br>";
+} else {
+	print "<b>No datasets to create!</b><br>";
+//identify which are identical and which are new and which are lost
+//first delete the orphaned
+foreach ($datasetToDelete as $datasetName) {
+	$result = package_delete($datasetName,CKAN_API_UPDATE);
+	if ($result) {
+		print "Package ".$datasetName." deleted successfully!<br>";
+	} else {
+		print "Package ".$datasetName." could not be deleted!<br>";
+	print "<b>Update of datasets</b><br>";
+//second update the identical ones
+foreach ($datasetToUpdate as $datasetName) {
+	//get dataset from object
+	$index = array_search($datasetName,$mbDatasetArray);
+	if (is_int($index)) {
+		$newPackage = $ckanObjects->result[$index];
+		//change group field if not the action api is requested!
+		if (CKAN_API_UPDATE == 2 || CKAN_API_UPDATE == 1) {
+			for ($i=0;$i < count($newPackage->groups);$i++) {
+				$newPackage->groups[$i] = $newPackage->groups[$i]->name;
+		//update it with action api
+		$result = package_update ($newPackage,CKAN_API_UPDATE);
+		if ($result) {
+			print "Dataset ".$datasetName." successfully updated!<br>";
+			//print json_encode($result);
+		} else {
+			print "Could not update dataset ".$datasetName."!<br>";
+//second create the new ones
+foreach ($datasetToCreate as $datasetName) {
+		//create it with action api
+		$result = package_create ($newPackage,CKAN_API_CREATE);
+		if ($result) {
+			print "Dataset ".$datasetName." successfully created!<br>";
+		} else {
+			print "Could not create dataset ".$datasetName."!<br>";
+$datasetName = $_REQUEST["name"];
+print time()."<br>";
+die();
+switch ($action) {
+	case 'package_show':
+		$result = package_get ($_REQUEST["name"]);
+		if ($result) {
+			print json_encode($result);
+		} else {
+			print "Dataset with name ".$_REQUEST["name"]." not found!";
+	break;
+	case 'package_create':
+		$result = package_create ($newDataset,3);
+		if ($result) {
+		} else {
+			print "Dataset could not be created!";
+	break;
+//functions for interacting with ckan apis
+function package_get ($packageName) {
+	try {
+		$ckan = new ckanApi(API_KEY,CKAN_SERVER_IP);
+		$ckan->base_url='http://'.CKAN_SERVER_IP.':5000/api/';
+		$idArray = array ('id'=>$packageName);
+		$resultDataset = $ckan->action_package_show(json_encode($idArray));
+		if ($resultDataset->success) {
+			return $resultDataset->result;
+		} else {
+			return false;
+	catch (Exception $e)
+		$error = new mb_exception('mod_syncCkan.php: Caught exception: '.$e->getMessage());
+		return false;
+function package_update ($package, $apiVersion) {
+	//check if package already exists
+	$existingPackage = package_get ($package->name);
+	if ($existingPackage) {
+		switch ($apiVersion) {
+			case 3:
+				//update it ;-)
+				try {
+					$result = $ckan->action_package_update(json_encode($package));
+				catch (Exception $e) {
+					$error = new mb_exception('mod_syncCkan.php: update dataset http_code:'.$e->getMessage());
+				if ($result->success) {
+					$result = $result->result;
+				} else {
+					$error = new mb_exception('mod_syncCkan.php: error when trying to update dataset!');
+					$result = false;
+				return $result;
+			break;
+			case 1:
+				//update it with api v1 ;-)
+				$ckan->base_url='http://'.CKAN_SERVER_IP.':5000/api/1/';
+				try {
+					$result = $ckan->put_package_entity($package->name,json_encode($package));
+					return false;
+				return $result;
+			break;
+			case 2:
+				//update it with api v2 ;-)
+				$ckan->base_url='http://'.CKAN_SERVER_IP.':5000/api/2/';
+				$error = new mb_exception('mod_syncCkan.php: '.$package->groups[0]);
+				try {
+					$result = $ckan->post_package_register($existingPackage->id,json_encode($package));
+					return false;
+				return $result;
+			break;
+	} else {
+		$error = new mb_exception('mod_syncCkan.php: No package found to update!');
+		return false;
+function package_create ($package,$apiVersion) {
+		//check if existing was deleted
+		$error = new mb_exception('mod_syncCkan.php: There is already an existing package with name: '.$package->name);
+		if ($existingPackage->status == 'deleted') {
+			$error = new mb_exception('mod_syncCkan.php: with status \'deleted\'');
+		} else {
+			$error = new mb_exception('mod_syncCkan.php: with status \'active\'');
+		return false;
+	} else {
+		//package insertion
+			case 1:
+				try {
+					$resultDataset = $ckan->post_package_register(json_encode($package));
+						$result = $resultDataset->result;
+					} else {
+						$error = new mb_exception('mod_syncCkan.php: error when trying to create dataset!');
+						$result = false;
+					$error = new mb_exception('mod_syncCkan.php: http_code:'.$e->getMessage());
+					$result = $e->getMessage();
+			break;
+			case 3:
+				try {
+					$resultDataset = $ckan->action_package_create(json_encode($package));
+					} else {
+						$result = false;
+			break;
+		if ($result) {
+			return $result;
+		} else {
+			return false;
+function get_packages_by_group($groupname) {
+	$datasetNames = array();
+	try {
+		$groupArray = array ('id'=>$groupname);
+		$result = $ckan->action_group_package_show(json_encode($groupArray));
+			foreach ($result->result as $dataset) {
+				$datasetNames[] = $dataset->name;
+		} else {
+			return false;
+		$error = new mb_exception('mod_syncCkan.php: get_packages_by_group: http_code:'.$e->getMessage());
+	return $datasetNames;
+function package_delete($packageName,$apiVersion) {
+	$existingPackage = package_get ($packageName);
+		$error = new mb_exception('mod_syncCkan.php: Following package will be deleted: '.$package->name);
+		if ($existingPackage->state == 'deleted') {
+			$error = new mb_exception('mod_syncCkan.php: package was deleted already nothing to be done!');
+			return true;
+		} else {
+			$error = new mb_exception('mod_syncCkan.php: Start deleting it!');
+				case 3:
+					//update the name and status of package to delete:
+					$existingPackage->state = "deleted";
+					$existingPackage->name = $existingPackage->name."_".time();
+					//some special elements for rhineland palatinate dataset validation:
+					/*Validation error: "{'__type': 'Validation Error', 'point_of_contact': [u'Missing value'], 'content_type': [u'Missing value'], 'point_of_contact_free_address': [u'At least one value must be specified'], 'point_of_contact_email': [u'At least one value must be specified'], 'other_terms_of_use': [u'Missing value'], 'point_of_contact_url': [u'At least one value must be specified']}"*/
+					//- don't help delete it with api 2
+					//$existingPackage->point_of_contact = "dummy";
+					//$existingPackage->content_type = "dummy";
+					//$existingPackage->point_of_contact_free_address = "dummy";
+					//$existingPackage->point_of_contact_email = "dummy";
+					//$existingPackage->other_terms_of_use = "dummy";
+					//$existingPackage->point_of_contact_url = "http://www.geoportal.rlp.de";
+					try {
+						$result = $ckan->action_package_update(json_encode($existingPackage));
+						return true;
+					} else {
+						return false;
+				break;
+				case 2:
+					//the existing package was called by action api therefor group will be defined as dict and be flattened before update
+					//TODO: check if api 2 uses dict for group or not!
+					for ($i=0;$i < count($existingPackage->groups);$i++) {
+						$error = new mb_exception('mod_syncCkan.php: groups['.$i.']->name old:'.$existingPackage->groups[$i]->name);
+						$existingPackage->groups[$i] = $existingPackage->groups[$i]->name;
+						$error = new mb_exception('mod_syncCkan.php: groups['.$i.'] new:'.$existingPackage->groups[$i]);
+					try {
+						$result = $ckan->post_package_register($existingPackage->id,json_encode($existingPackage));
+						return false;
+					return $result;
+				break;
+				case 1:
+					//some rp specials for deleting non conformant datasets - which maybe generated by hand!
+					/*2013-02-23 21:37:57,704 ERROR [ckan.controllers.api] Validation error: "{'point_of_contact': [u'Missing value'], 'content_type': [u'Missing value'], 'point_of_contact_free_address': [u'At least one value must be specified'], 'point_of_contact_email': [u'At least one value must be specified'], 'point_of_contact_url': [u'At least one value must be specified']}"*/
+					$existingPackage->point_of_contact = "dummy";
+					$existingPackage->content_type = "dummy";
+					$existingPackage->point_of_contact_free_address = "dummy";
+					$existingPackage->point_of_contact_email = "dummy at dummy.de";
+					$existingPackage->point_of_contact_url = "http://test.de";
+					try {
+						$result = $ckan->put_package_entity($packageName,json_encode($existingPackage));
+						return false;
+					return $result;
+				break;
+	} else {
+		$error = new mb_exception('mod_syncCkan.php: No existing package found, deleting not needed!');
+		return true;
More information about the Mapbender_commits mailing list
