[Mapbender-commits] r9015 - trunk/mapbender/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Aug 4 04:59:41 PDT 2014
Author: armin11
Date: 2014-08-04 04:59:41 -0700 (Mon, 04 Aug 2014)
New Revision: 9015
   trunk/mapbender/http/php/mod_getWmcDisclaimer.php
Bugfix for wrong encoding of mod_getWmcDisclaimer.php - added optional html header and integrated gettext translation
Modified: trunk/mapbender/http/php/mod_getWmcDisclaimer.php
--- trunk/mapbender/http/php/mod_getWmcDisclaimer.php	2014-08-01 09:25:09 UTC (rev 9014)
+++ trunk/mapbender/http/php/mod_getWmcDisclaimer.php	2014-08-04 11:59:41 UTC (rev 9015)
@@ -21,6 +21,7 @@
 $hostName = $_SERVER['HTTP_HOST'];
 //$userId = PUBLIC_USER;
 $id = 4373; //dummy id
+$withHeader = false;
 //TODO give requesting hostname to this script
 if (isset($_REQUEST["id"]) & $_REQUEST["id"] != "") {
 	//validate to integer
@@ -33,6 +34,23 @@
 	$id = (integer)$testMatch;
 	$testMatch = NULL;
+if (isset($_REQUEST["withHeader"]) & $_REQUEST["withHeader"] != "") {
+	//validate to wms, wfs
+	$testMatch = $_REQUEST["withHeader"];
+ 	if (!($testMatch == 'true' or $testMatch == 'false')){
+		echo 'languageCode is not a valid boolean.<br/>';
+		die();
+ 	} else {
+		switch ($testMatch) {
+			case "true":
+				$withHeader = true;
+			break;
+	$testMatch = NULL;
 if (isset($_REQUEST["hostName"]) & $_REQUEST["hostName"] != "") {
 	//validate to some hosts
@@ -50,48 +68,59 @@
 $e = new mb_notice("mod_getWmcDisclaimer.php: requested wmc id: ".$_REQUEST["id"]);
+$sessionLang = Mapbender::session()->get("mb_lang");
+if (isset($sessionLang) && ($sessionLang!='')) {
+	$e = new mb_notice("mod_showMetadata.php: language found in session: ".$sessionLang);
+	$language = $sessionLang;
+	$langCode = explode("_", $language);
+	$langCode = $langCode[0]; # Hopefully de or s.th. else
+	$languageCode = $langCode; #overwrite the GET Parameter with the SESSION information
 if (isset($_REQUEST["languageCode"]) & $_REQUEST["languageCode"] != "") {
-	//validate to wms, wfs
-	$testMatch = $_REQUEST["languageCode"];
- 	if (!($testMatch == 'de' or $testMatch == 'en' or  $testMatch == 'fr')){
-		echo 'languageCode is not valid.<br/>';
+	//validate to csv integer list
+	$testMatch = $_REQUEST["languageCode"];
+	if (!($testMatch == 'de' or $testMatch == 'fr' or $testMatch == 'en')){
+		//echo 'languageCode: <b>'.$testMatch.'</b> is not valid.<br/>';
+		echo 'Parameter <b>languageCode</b> is not valid (de,fr,en).<br/>';
 		die();
 	$languageCode = $testMatch;
+	$e = new mb_exception("mod_showMetadata.php: languageCode from GET parameter: ".$languageCode);
 	$testMatch = NULL;
-//Array with translations:
-switch ($languageCode) {
-	case "de":
-		$translation['wmcDisclaimerHeader'] = 'Das vorliegende Dokument enthält Datenquellen von unterschiedlichen Stellen. Diese unterliegen den im folgenden aufgeführten Nutzungsbedingungen:';
-		$translation['wms'] = "Kartendienst";
-		$translation['wfs'] = "Datendienst";
-		$translation['noTouInformation'] = 'Es sind keine Informationen über Nutzungsbedingungen verfügbar!';
-		break;
-	case "en":
-		$translation['wmcDisclaimerHeader'] = 'The document includes data resources from different organizations. The following parapgraph shows the different terms of use for the includes resources:';
-		$translation['wms'] = "Web Map Service";
-		$translation['wfs'] = "Web Feature Service";
-		$translation['noTouInformation'] = 'No informations about terms of use are available!';
-		break;
-	default: #to english
+$localeObj->setCurrentLocale($languageCode);
 //javascript:openwindow("../php/mod_showMetadata.php?resource=layer&layout=tabs&redirectToMetadataUrl=1&id=20655");
 //Generate wmc document by id
 $wmcFactory = new WmcFactory;
 $e = new mb_notice("mod_getWmcDisclaimer.php: wmcid: ".$id);
 $wmcObj = $wmcFactory->createFromDb($id);
+//generate HTML Header
+if ($withHeader){
+		//e.g. tabs and their content
+		$html = '<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="'.$languageCode.'">';
+		$html .= '<body>';
+		$metadataStr .= '<head>' .
+		'<title>'._mb('Use Constraints').'</title>' .
+		'<meta name="description" content="'._mb('Disclaimer').'" xml:lang="'.$languageCode.'" />'.
+		'<meta name="keywords" content="'._mb('Use limitations and access constraints').'" xml:lang="'.$languageCode.'" />'	.
+		'<meta http-equiv="cache-control" content="no-cache">'.
+		'<meta http-equiv="pragma" content="no-cache">'.
+		'<meta http-equiv="expires" content="0">'.
+		'<meta http-equiv="content-language" content="'.$languageCode.'" />'.
+		'<meta http-equiv="content-style-type" content="text/css" />'.
+		'<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">' .
+		'</head>';
+		echo $html.$metadataStr;
 //generate header for disclaimer:
-echo "<b>".$translation['wmcDisclaimerHeader']."</b><br><br>";#
+echo "<b>"._mb('The document includes data resources from different organizations. The following parapgraph shows the different terms of use for the includes resources:')."</b><br><br>";#
 //Part for wms
-$resourceSymbol = "<img src='../img/osgeo_graphics/geosilk/server_map.png' alt='".$translation['wms']." - picture' title='".$translation['wms']."'>";
+$resourceSymbol = "<img src='../img/osgeo_graphics/geosilk/server_map.png' alt='"._mb('Web Map Service')." - picture' title='"._mb('Web Map Service')."'>";
 //read out all wms id's
 $validWMS = $wmcObj->getValidWms();
 if (isset($_SERVER["HTTPS"]) && $_SERVER["HTTPS"] == "on") {
@@ -115,12 +144,15 @@
 	$constraints->returnDirect = false;
 	$touForWMS = $constraints->getDisclaimer();
 	if ($touForWMS == 'free'){
-		$wmstou = $translation['noTouInformation'];
+		$wmstou = _mb('No informations about terms of use are available!');
 	} else {
 		$wmstou = $touForWMS;
 	echo $wmstou."<br>";
+if ($withHeader){
+		echo "</body></html>";
 //var_dump($validWMS);
 //module to read out all service ids which are stored in mapbender wmc documents and generate a Big Disclaimer for those Docs.
 //It integrates all known disclaimers for the used webservices who are stored in the mapbender registry
More information about the Mapbender_commits mailing list
