[Mapbender-commits] r9021 - trunk/mapbender/tools/wms_extent
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Aug 5 01:40:58 PDT 2014
Author: armin11
Date: 2014-08-05 01:40:58 -0700 (Tue, 05 Aug 2014)
New Revision: 9021
   trunk/mapbender/tools/wms_extent/extent_service.conf
Extract hardcoded extent of sdi area which is used to calculate the metadata extent previews into conf file
Modified: trunk/mapbender/tools/wms_extent/extent_service.conf
--- trunk/mapbender/tools/wms_extent/extent_service.conf	2014-08-05 08:40:41 UTC (rev 9020)
+++ trunk/mapbender/tools/wms_extent/extent_service.conf	2014-08-05 08:40:58 UTC (rev 9021)
@@ -2,8 +2,10 @@
 # EXTENTSERVICEURL - Onlineresource to address the WMS to display the Service extent
 # EXTENTSERVICELAYER - definde the Layer to display in the Service extent
+# EXTENTSERVICEBBOX - Define area for which the infrastructure (sdi) is intended. The bbox will be used to calculate extents for previews of the positions of datasets in context to the sdi.
 #DEFINE("EXTENTSERVICEURL","http://".$_SERVER['HTTP_HOST']."/cgi-bin/mapserv?map=/data/mapbender/tools/wms_extent/extents.map&");
 #DEFINE("EXTENTSERVICELAYER","demis,extent");
+#DEFINE("EXTENTSERVICEBBOX","6.05,48.9,8.6,50.96"); #define area for which the infrastructure is intended. E.g. bbox of the Federal German State Rhineland-Platinate
More information about the Mapbender_commits mailing list
