[Mapbender-commits] r9023 - trunk/mapbender/tools/wms_extent
svn_mapbender at osgeo.org
Tue Aug 5 02:53:15 PDT 2014
Author: armin11
Date: 2014-08-05 02:53:14 -0700 (Tue, 05 Aug 2014)
New Revision: 9023
trunk/mapbender/tools/wms_extent/extents.map
New layer for visualizing a possibly given surrounding polygon of a registered metadata set. The mapserver accepts the new parameter metadata_uuid which is equivalant to the mb_metadata uuid row.
Modified: trunk/mapbender/tools/wms_extent/extents.map
--- trunk/mapbender/tools/wms_extent/extents.map 2014-08-05 09:13:36 UTC (rev 9022)
+++ trunk/mapbender/tools/wms_extent/extents.map 2014-08-05 09:53:14 UTC (rev 9023)
@@ -28,6 +28,7 @@
'miny' '^[0-9]*\.?[0-9]*$'
'maxx' '^[0-9]*\.?[0-9]*$'
'maxy' '^[0-9]*\.?[0-9]*$'
+ 'metadata_uuid' '^\{?[0-9a-f]{8}\-?[0-9a-f]{4}\-?[0-9a-f]{4}\-?[0-9a-f]{4}\-?[0-9a-f]{12}\}?$'
END
END
@@ -103,5 +104,33 @@
END
+LAYER
+ NAME "metadata_polygon"
+ STATUS ON
+ TYPE POLYGON
+ CONNECTIONTYPE postgis
+ CONNECTION "dbname=mapbender user=postgres port=5432 host=localhost"
+ DATA "bounding_geom from (select bounding_geom , 1 as oid from mb_metadata where uuid = \'%metadata_uuid%\') as foo USING UNIQUE oid USING SRID=4326"
+ METADATA
+ WMS_TITLE "Metadata polygon"
+ WMS_SRS "EPSG:4326"
+ WMS_ABSTRACT "Polygon of a special metadataset from the mapbender registry"
+ include "include_metadata_layer.map"
+ END
+ PROJECTION
+ "init=epsg:4326"
+ END
+ CLASS
+ NAME "Metadata polygon"
+ STYLE
+ OUTLINECOLOR 246 234 41
+ WIDTH 2
+ END
+ END
END
+END
More information about the Mapbender_commits
