[Mapbender-commits] r9024 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Aug 5 06:02:39 PDT 2014
Author: armin11
Date: 2014-08-05 06:02:39 -0700 (Tue, 05 Aug 2014)
New Revision: 9024
   trunk/mapbender/http/plugins/mb_metadata_addon.php
   trunk/mapbender/http/plugins/mb_metadata_server.php
New div to show extent in dataset metadata editor on a map. Also a given polygon should be visualized
Modified: trunk/mapbender/http/plugins/mb_metadata_addon.php
--- trunk/mapbender/http/plugins/mb_metadata_addon.php	2014-08-05 09:53:14 UTC (rev 9023)
+++ trunk/mapbender/http/plugins/mb_metadata_addon.php	2014-08-05 13:02:39 UTC (rev 9024)
@@ -1,12 +1,11 @@
 <?php
 	require_once dirname(__FILE__) . "/../../core/globalSettings.php";
 	require_once(dirname(__FILE__) . "/../../conf/mimetype.conf");
 	function displayCategories ($sql) {
 		if (Mapbender::session()->get("mb_lang") === "de") {
 			$sql = str_replace("category_code_en", "category_code_de", $sql);
 		$str = "";
 		$res = db_query($sql);
 		while ($row = db_fetch_assoc($res)) {
@@ -233,6 +232,10 @@
 			<legend><?php echo _mb("User defined region");?><img class="help-dialog" title="<?php echo _mb("Help");?>" help="{text:'<?php echo _mb("You can define your own bounding box or region if you upload an gml geometry object. Only bbox and polygons are accepted at the moment!");?>'}" src="../img/questionmark.png" alt="" /></legend>
 			<table id='geometryuploadtable' name='geometryuploadtable'><tr><td><img id="uploadgmlimage" name= "uploadgmlimage" onclick='initUploadGmlForm();' src='../img/button_blue_red/up.png' id='uploadImage' title='upload'  /></td><td><?php echo _mb("Upload a surronding geometry for this dataset");?><img class="help-dialog" title="<?php echo _mb("Help");?>" help="{text:'<?php echo _mb("Help for geometry upload possibility");?>'}" src="../img/questionmark.png" alt="" /></td></tr></table>
 		</fieldset>
+		<fieldset>
+			<legend><?php echo _mb("Extent on map");?><img class="help-dialog" title="<?php echo _mb("Help");?>" help="{text:'<?php echo _mb("Here you can see the extent and a possibly given surrounding polygon on an overview map.");?>'}" src="../img/questionmark.png" alt="" /></legend>
+			<img id="extent_preview" src="" title="<?php echo _mb("Preview for Extent - if available");?>" alt="<?php echo _mb("Preview for Extent - if available");?>"/>
+		</fieldset>
 	</div>
 	<div id="tabs-6">
 		<fieldset>
Modified: trunk/mapbender/http/plugins/mb_metadata_server.php
--- trunk/mapbender/http/plugins/mb_metadata_server.php	2014-08-05 09:53:14 UTC (rev 9023)
+++ trunk/mapbender/http/plugins/mb_metadata_server.php	2014-08-05 13:02:39 UTC (rev 9024)
@@ -3,6 +3,7 @@
 require_once dirname(__FILE__) . "/../classes/class_user.php";
 require_once dirname(__FILE__) . "/../classes/class_wms.php";//already includes iso19139!
 require_once dirname(__FILE__) . "/../classes/class_Uuid.php";
+require_once dirname(__FILE__) . "/../../tools/wms_extent/extent_service.conf";
 $ajaxResponse = new AjaxResponse($_POST);
@@ -12,8 +13,19 @@
 	$ajaxResponse->setMessage($message);
 	$ajaxResponse->send();
 	die();
+function DOMNodeListObjectValuesToArray($domNodeList) {
+	$iterator = 0;
+	$array = array();
+	foreach ($domNodeList as $item) {
+    		$array[$iterator] = $item->nodeValue; // this is a DOMNode instance
+    		// you might want to have the textContent of them like this
+    		$iterator++;
+	return $array;
 function getWms ($wmsId = null) {
 	$user = new User(Mapbender::session()->get("mb_user_id"));
 	$wmsIdArray = $user->getOwnedWms();
@@ -39,14 +51,17 @@
 function gml2wkt($gml) {
 	//function to create wkt from given gml multipolygon
+	//DOM
+	$gmlObject = new DOMDocument();
 	libxml_use_internal_errors(true);
 	try {
-		$gmlObject = simplexml_load_string($gml);
+		//$feedXML = simplexml_load_string($feedFile);
+		$gmlObject->loadXML($gml);
 		if ($gmlObject === false) {
 			foreach(libxml_get_errors() as $error) {
         			$err = new mb_exception("mb_metadata_server.php:".$error->message);
-			throw new Exception("mb_metadata_server.php:".'Cannot parse Metadata GML!');
+			throw new Exception("mb_metadata_server.php:".'Cannot parse GML!');
 			return false;
@@ -54,25 +69,62 @@
     		$err = new mb_exception("mb_metadata_server.php:".$e->getMessage());
 		return false;
 	//if parsing was successful
 	if ($gmlObject !== false) {
 		//ST_GeomFromText('MULTIPOLYGON(((235670.354215375 894016.780856,235668.324215375 894025.050856,235681.154215375 894028.210856,235683.184215375 894019.940856,235670.354215375 894016.780856)))', 2805) )
 		//read crs from gml
-		$crs = $gmlObject->xpath('/gml:Polygon/@srsName');
-		$crsId = end(explode(":",$crs[0]));
+		$xpath = new DOMXPath($gmlObject);
+		$xpath->registerNamespace('gml','http://www.opengis.net/gml');
+		$crs = $xpath->query('/gml:Polygon/@srsName');
+		$crsArray = DOMNodeListObjectValuesToArray($crs);
+		$crsId = end(explode(":",$crsArray[0]));
+		if (!isset($crsId) || $crsId =="" || $crsId == NULL) {
+			//set default to lonlat wgs84
+			$crsId = "4326";
 		$wkt = "SRID=".$crsId.";POLYGON(";
-		//$e = new mb_exception("mb_metadata_server.php: crs:".$crs[0]);
-		//for each found polygon
-		$outerPolygons = $gmlObject->xpath('/gml:Polygon/gml:outerBoundaryIs/gml:LinearRing/gml:coordinates');
-		//$e = new mb_exception("mb_metadata_server.php:".gettype($outerPolygons).$outerPolygons);
-		$wkt .= "(".str_replace(";",",",str_replace(","," ",str_replace(" ",";",$outerPolygons[0])))."))";
-		//$wkt .= ")";
-		//$e = new mb_exception("mb_metadata_server.php: wkt: ".$wkt);
+		$outerPolygons = $xpath->query('/gml:Polygon/gml:outerBoundaryIs/gml:LinearRing/gml:coordinates');
+		$outerPolygonsArray = DOMNodeListObjectValuesToArray($outerPolygons);
+		//$e = new mb_exception("mb_metadata_server.php: ".$outerPolygonsArray[0]);
+		$wkt .= "(".str_replace(";",",",str_replace(","," ",str_replace(" ",";",$outerPolygonsArray[0])))."))";
 		return $wkt;
+function getExtentGraphic($layer_4326_box) {
+	$area_4326_box = explode(',',EXTENTSERVICEBBOX);
+	if ($layer_4326_box[0] <= $area_4326_box[0] || $layer_4326_box[2] >= $area_4326_box[2] || $layer_4326_box[1] <= $area_4326_box[1] || $layer_4326_box[3] >= $area_4326_box[3]) {
+		if ($layer_4326_box[0] < $area_4326_box[0]) {
+			$area_4326_box[0] = $layer_4326_box[0];
+		if ($layer_4326_box[2] > $area_4326_box[2]) {
+			$area_4326_box[2] = $layer_4326_box[2];
+		if ($layer_4326_box[1] < $area_4326_box[1]) {
+			$area_4326_box[1] = $layer_4326_box[1];
+		if ($layer_4326_box[3] > $area_4326_box[3]) {
+			$area_4326_box[3] = $layer_4326_box[3];
+		$d_x = $area_4326_box[2] - $area_4326_box[0];
+		$d_y = $area_4326_box[3] - $area_4326_box[1];
+		$new_minx = $area_4326_box[0] - 0.05*($d_x);
+		$new_maxx = $area_4326_box[2] + 0.05*($d_x);
+		$new_miny = $area_4326_box[1] - 0.05*($d_y);
+		$new_maxy = $area_4326_box[3] + 0.05*($d_y);
+		if ($new_minx < -180) $area_4326_box[0] = -180; else $area_4326_box[0] = $new_minx;
+		if ($new_maxx > 180) $area_4326_box[2] = 180; else $area_4326_box[2] = $new_maxx;
+		if ($new_miny < -90) $area_4326_box[1] = -90; else $area_4326_box[1] = $new_miny;
+		if ($new_maxy > 90) $area_4326_box[3] = 90; else $area_4326_box[3] = $new_maxy;
+	$getMapUrl = EXTENTSERVICEURL."VERSION=1.1.1&REQUEST=GetMap&SERVICE=WMS&LAYERS=".EXTENTSERVICELAYER."&STYLES=&SRS=EPSG:4326&BBOX=".$area_4326_box[0].",".$area_4326_box[1].",".$area_4326_box[2].",".$area_4326_box[3]."&WIDTH=120&HEIGHT=120&FORMAT=image/png&BGCOLOR=0xffffff&TRANSPARENT=TRUE&EXCEPTIONS=application/vnd.ogc.se_inimage&minx=".$layer_4326_box[0]."&miny=".$layer_4326_box[1]."&maxx=".$layer_4326_box[2]."&maxy=".$layer_4326_box[3];
+	return $getMapUrl;
 switch ($ajaxResponse->getMethod()) {
 	case "getWms" :
 		$wmsIdArray = getWms();
@@ -1126,22 +1178,41 @@
 			$sql = <<<SQL
 UPDATE mb_metadata SET bounding_geom = $2 WHERE metadata_id = $1
 SQL;
-		$v = array($metadataId, $wktPolygon);
-		$e = new mb_exception($metadataId);
-		$t = array('i','POLYGON');
-		$res = db_prep_query($sql,$v,$t);
-		if (!$res) {
-			abort(_mb("Problem while storing geometry into database!"));
+			$v = array($metadataId, $wktPolygon);
+			$e = new mb_exception($metadataId);
+			$t = array('i','POLYGON');
+			$res = db_prep_query($sql,$v,$t);
+			if (!$res) {
+				abort(_mb("Problem while storing geometry into database!"));
+			} else {
+				//build new preview url if possible and give it back in ajax response
+				$ajaxResponse->setMessage("Stored successfully geometry into database!");
+				$ajaxResponse->setSuccess(true);
 		} else {
-			abort(_mb("Stored successfully geometry into database!"));
-		} else {
 			abort(_mb("Converting GML to WKT failed!"));
 		//parse gml and extract multipolygon to wkt representation
 		//push multipolygon into database
 	break;
+	case "deleteSurroundingGeom" :
+		$metadataId = $ajaxResponse->getParameter("metadataId");
+		$sql = <<<SQL
+UPDATE mb_metadata SET bounding_geom = NULL WHERE metadata_id = $1
+SQL;
+		$v = array($metadataId);
+		//$e = new mb_exception($metadataId);
+		if (!$res) {
+			abort(_mb("Problem while deleting geometry from database!"));
+		} else {
+			$ajaxResponse->setMessage("Deleted surrounding geometry from metadata record!");
+	break;
 	case "importXmlAddon" :
 		//this case is similar to insert the metadata from external link, but came from internal file from tmp folder which has been uploaded before
 		$resourceId = $ajaxResponse->getParameter("resourceId");
More information about the Mapbender_commits mailing list
