[Mapbender-commits] r9033 - trunk/mapbender/conf
svn_mapbender at osgeo.org
Wed Aug 6 07:10:34 PDT 2014
Author: armin11
Date: 2014-08-06 07:10:34 -0700 (Wed, 06 Aug 2014)
New Revision: 9033
Added:
trunk/mapbender/conf/atomFeedClient.conf-dist
Extract urls from download feed client into new conf file to allow easier handling in different environments
Added: trunk/mapbender/conf/atomFeedClient.conf-dist
--- trunk/mapbender/conf/atomFeedClient.conf-dist (rev 0)
+++ trunk/mapbender/conf/atomFeedClient.conf-dist 2014-08-06 14:10:34 UTC (rev 9033)
@@ -0,0 +1,22 @@
+<?php
+//configuration for the INSPIRE Atom feed client
+//background layers for upper client:
+$backgroundLayer_1 = 'var wms1 = new OpenLayers.Layer.WMS( "OpenLayers WMS",
+ "http://www.gdi-rp-dienste2.rlp.de/cgi-bin/mapserv?map=/data/umn/geoportal/karte_rp/rheinland-pfalz-gesamt2.map&", {layers: "ATKIS-Praes",transparent: "true",format: "image/png"}, {singleTile: true, isBaseLayer: false});';
+$backgroundLayer_2 = 'var wms11 = new OpenLayers.Layer.WMS( "OpenLayers WMS",
+ "http://www2.demis.nl/wms/wms.ashx?wms=WorldMap&", {layers: "Bathymetry,Countries,Topography,Hillshading,Coastlines,Waterbodies,Rivers,Streams,Railroads,Highways,Roads,Borders,Cities,Settlements,Airports"}, {singleTile: true});';
+$addBackgroundLayerUpper = "wms11,wms1";
+//background layers for lower client:
+$backgroundLayer_3 = 'var wms2 = new OpenLayers.Layer.WMS( "OpenLayers WMS",
+$backgroundLayer_4 = 'var wms22 = new OpenLayers.Layer.WMS( "OpenLayers WMS",
+$addBackgroundLayerLower = "wms22,wms2";
+//metadata layer
+$metadataPolygonLayer = "var wms222 = new OpenLayers.Layer.WMS( \"Exterior polygon from metadata\",
+ \"http://localhost/cgi-bin/mapserv?map=/home/armin/GDI-RP/Geoportal/devel/mapbender_trunk/tools/wms_extent/extents.map&metadata_uuid=\"+$('#dataset_identifier_link').attr('uuid'), {layers: 'metadata_polygon',transparent: \"true\",format: \"image/png\"}, {singleTile: true, isBaseLayer: false});";
More information about the Mapbender_commits
