[Mapbender-commits] r9034 - trunk/mapbender/conf
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Aug 6 07:15:17 PDT 2014
Author: armin11
Date: 2014-08-06 07:15:17 -0700 (Wed, 06 Aug 2014)
New Revision: 9034
   trunk/mapbender/conf/atomFeedClient.conf-dist
Bugfix
Modified: trunk/mapbender/conf/atomFeedClient.conf-dist
--- trunk/mapbender/conf/atomFeedClient.conf-dist	2014-08-06 14:10:34 UTC (rev 9033)
+++ trunk/mapbender/conf/atomFeedClient.conf-dist	2014-08-06 14:15:17 UTC (rev 9034)
@@ -18,5 +18,5 @@
 //metadata layer
 $metadataPolygonLayer = "var wms222 = new OpenLayers.Layer.WMS( \"Exterior polygon from metadata\",
-               \"http://localhost/cgi-bin/mapserv?map=/home/armin/GDI-RP/Geoportal/devel/mapbender_trunk/tools/wms_extent/extents.map&metadata_uuid=\"+$('#dataset_identifier_link').attr('uuid'), {layers: 'metadata_polygon',transparent: \"true\",format: \"image/png\"}, {singleTile: true, isBaseLayer: false});";
+               \"http://".$_SERVER['HTTP_HOST']."/cgi-bin/mapserv?map=/data/mapbender/tools/wms_extent/extents.map&metadata_uuid=\"+$('#dataset_identifier_link').attr('uuid'), {layers: 'metadata_polygon',transparent: \"true\",format: \"image/png\"}, {singleTile: true, isBaseLayer: false});";
More information about the Mapbender_commits mailing list
