[Mapbender-commits] r8796 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Mar 6 07:32:21 PST 2014
Author: armin11
Date: 2014-03-06 07:32:21 -0800 (Thu, 06 Mar 2014)
New Revision: 8796
   trunk/mapbender/http/javascripts/map_obj.js
   trunk/mapbender/http/javascripts/mod_featureInfo.php
Possibility to allow switching between featureInfo on layer and service level  based on element_var featureInfoCollectLayers. If only one layer/wms is active not interims window will be shown any longer.
Modified: trunk/mapbender/http/javascripts/map_obj.js
--- trunk/mapbender/http/javascripts/map_obj.js	2014-03-05 08:03:13 UTC (rev 8795)
+++ trunk/mapbender/http/javascripts/map_obj.js	2014-03-06 15:32:21 UTC (rev 8796)
@@ -966,7 +966,7 @@
      * @type string[]
-    this.getFeatureInfoRequestsForLayers = function(clickPoint, ignoreWms, epsg, realWorldPoint){
+    this.getFeatureInfoRequestsForLayers = function(clickPoint, ignoreWms, epsg, realWorldPoint, featureInfoCollectLayers){
         var allRequests = [];
         //loop through all wms to get the FeatureInfoRequests
         for (var i = 0; i < this.wms.length; i++) {
@@ -981,42 +981,95 @@
             if (!ignoreThisWms) {
-		//get all layers for this wms which have activated featureInfo Button
-		//loop over all layers of this wms
-	 	for (var j = 0; j < this.wms[i].objLayer.length; j++) {
-			if (this.wms[i].objLayer[j].gui_layer_querylayer == 1 && this.wms[i].objLayer[j].gui_layer_queryable == 1) {
-				var featureInfoObj = {};
-                   		featureInfoObj.title = this.wms[i].objLayer[j].gui_layer_title;
-				//pull featureinfo request
-				var featureInfoRequest = this.wms[i].getFeatureInfoRequest(this, clickPoint);
-				//exchange layer parameter with current layer name
-				if (typeof(featureInfoRequest) !== 'undefined' && featureInfoRequest !== "" && featureInfoRequest !== false) {
-					featureInfoRequest = changeURLParameterValue(featureInfoRequest,"LAYERS", this.wms[i].objLayer[j].layer_name);
-					featureInfoRequest = changeURLParameterValue(featureInfoRequest,"QUERY_LAYERS", this.wms[i].objLayer[j].layer_name);
+		//switch for service based featureInfo od layer based one
+		if (featureInfoCollectLayers) {
+			//instantiate return object
+			var featureInfoObj = {};
+			featureInfoObj.title = "";
+			featureInfoObj.names = "";
+			featureInfoObj.legendurl = "";
+			var featureInfoRequest = this.wms[i].getFeatureInfoRequest(this, clickPoint);
+			//check if featureinfo for this service is available - push only those into return object
+			if (typeof(featureInfoRequest) !== 'undefined' && featureInfoRequest !== "" && featureInfoRequest !== false) {
+				//iterate over all layers to select those which are queryable and active which lie in the region
+				for (var j = 0; j < this.wms[i].objLayer.length; j++) {
+					if (this.wms[i].objLayer[j].gui_layer_querylayer == 1 && this.wms[i].objLayer[j].gui_layer_queryable == 1) {
+						var bbox = this.objectFindByKey(this.wms[i].objLayer[j].layer_epsg, "epsg", epsg);
+						if (bbox) {
+							//check if clicked point is in bbox of layer
+							featureInfoObj.inBbox = this.isPointInBbox(realWorldPoint, bbox);
+						} else {
+							featureInfoObj.inBbox = true;
+						if (featureInfoObj.inBbox) {
+							featureInfoObj.title += this.wms[i].objLayer[j].gui_layer_title+", ";
+							featureInfoObj.names += this.wms[i].objLayer[j].layer_name+",";
+							//get url to legend
+							if (typeof(this.wms[i].objLayer[j].layer_style[0]) !=='undefined' && typeof(this.wms[i].objLayer[j].layer_style[0].legendurl) !== 'undefined') {
+								featureInfoObj.legendurl += this.wms[i].objLayer[j].layer_style[0].legendurl+",";
+							} else {
+								featureInfoObj.legendurl += "empty"+",";
+				//do following things only, if some name exists!
+				if (featureInfoObj.names !=='') {
+					//exchange trailing ","
+					featureInfoObj.names = featureInfoObj.names.replace(/,+$/, "");
+					featureInfoObj.title = featureInfoObj.title.replace(/, +$/, "");
+					//check for length of title - if length is > 1 use wms title, cause window is too small!
+					/*if(featureInfoObj.title.split(",").length > 1) {
+						featureInfoObj.title = this.wms[i].wms_title;
+					featureInfoObj.legendurl = featureInfoObj.legendurl.replace(/,+$/, "");
+					//remove wrong layers from getFeatureInfo request
+					featureInfoRequest = changeURLParameterValue(featureInfoRequest,"LAYERS", featureInfoObj.names);
+					featureInfoRequest = changeURLParameterValue(featureInfoRequest,"QUERY_LAYERS", featureInfoObj.names);
 					featureInfoObj.request = featureInfoRequest;
-					var bbox = this.objectFindByKey(this.wms[i].objLayer[j].layer_epsg, "epsg", epsg);
-					if (bbox) {
-						//check if clicked point is in bbox of layer
-						featureInfoObj.inBbox = this.isPointInBbox(realWorldPoint, bbox);
+					//give back objects
+					allRequests.push(featureInfoObj);
+		} else {
+			//get all layers for this wms which have activated featureInfo Button
+			//loop over all layers of this wms
+                   			featureInfoObj.title = this.wms[i].objLayer[j].gui_layer_title;
+					//pull featureinfo request
+					//exchange layer parameter with current layer name
+						featureInfoRequest = changeURLParameterValue(featureInfoRequest,"LAYERS", this.wms[i].objLayer[j].layer_name);
+						featureInfoRequest = changeURLParameterValue(featureInfoRequest,"QUERY_LAYERS", this.wms[i].objLayer[j].layer_name);
+						featureInfoObj.request = featureInfoRequest;
+						if (bbox) {
+						} else {
 					} else {
-						featureInfoObj.inBbox = true;
+						featureInfoObj.request = "empty";
+						featureInfoObj.inBbox = false;
-				} else {
-					featureInfoObj.request = "empty";
-					featureInfoObj.inBbox = false;
-				//get url to legend
-				if (typeof(this.wms[i].objLayer[j].layer_style[0]) !=='undefined' && typeof(this.wms[i].objLayer[j].layer_style[0].legendurl) !== 'undefined') {
-					featureInfoObj.legendurl = this.wms[i].objLayer[j].layer_style[0].legendurl;
-				} else {
-					featureInfoObj.legendurl = "empty";
-				//return new request!
-		    		allRequests.push(featureInfoObj);
+						featureInfoObj.legendurl = this.wms[i].objLayer[j].layer_style[0].legendurl;
+					} else {
+						featureInfoObj.legendurl = "empty";
+					//return new request!
+				} //end queryable condition
+			} //end for layer loop
+		} //end layer or wms based featureInfo
+            } //end ignore wms condition
+        } //end for wms loop
         if (allRequests.length > 0) {
             return allRequests;
Modified: trunk/mapbender/http/javascripts/mod_featureInfo.php
--- trunk/mapbender/http/javascripts/mod_featureInfo.php	2014-03-05 08:03:13 UTC (rev 8795)
+++ trunk/mapbender/http/javascripts/mod_featureInfo.php	2014-03-06 15:32:21 UTC (rev 8796)
@@ -38,6 +38,8 @@
 	var featureInfoDrawClick = false;
 if(typeof(featureInfoCircleColor)==='undefined')
 	var featureInfoCircleColor = '#ff0000';
+if(typeof(featureInfoCollectLayers)==='undefined')
+	var featureInfoCollectLayers = false;
 var mod_featureInfo_elName = "<?php echo $e_id;?>";
 var mod_featureInfo_frameName = "";
@@ -165,30 +167,75 @@
 		if (featureInfoLayerPreselect) {
 			$("#featureInfo_preselect").remove();
 			//build list of possible featureInfo requests
-			urls = mod_featureInfo_mapObj.getFeatureInfoRequestsForLayers(point, ignoreWms, Mapbender.modules[options.target].getSRS(), realWorldPoint);
+			urls = mod_featureInfo_mapObj.getFeatureInfoRequestsForLayers(point, ignoreWms, Mapbender.modules[options.target].getSRS(), realWorldPoint, featureInfoCollectLayers);
 			if (urls.length == 0 || typeof urls.length =='undefined') {
 				alert("<?php echo _mb("Please enable some layer to be requestable");?>!");
 				return false;
+			if (urls.length == 1) {
+				//don't show interims window!
+				//open featureInfo directly
+				if(featureInfoLayerPopup == 'true'){
+					$("<div><iframe frameborder='0' height='100%' width='100%' id='featureInfo' title='<?php echo _mb("Information");?>' src='" + urls[0].request + "'></iframe></div>").dialog({
+						bgiframe: true,
+						autoOpen: true,
+						modal: false,
+						title: '<?php echo _mb("Information");?>',
+						width:parseInt(featureInfoPopupWidth, 10),
+						height:parseInt(featureInfoPopupHeight, 10),
+						position:dialogPosition,
+						buttons: {
+							"Ok": function(){
+								$(this).dialog('close').remove();
+					}).parent().css({position:"fixed"});
+					return false;
+				} else {
+					window.open(urls[0].request, "" , "width="+featureInfoPopupWidth+",height="+featureInfoPopupHeight+",scrollbars=yes,resizable=yes");
+					return false;
 			featureInfoList = "<table border='1'>";
 			if (reverseInfo == "true") {
 				for(var i=0;i<urls.length;i++){
-					if (urls[i].inBbox) {
-						if (urls[i].legendurl !== "empty" ) {
-							featureInfoList += "<tr><td valign='top'><a style='text-decoration:  underline' href='"+urls[i].request+"' target='_blank'>"+urls[i].title+"</a></td><td><img src='"+urls[i].legendurl+"' alt='<?php echo _mb("No legend available");?>!'/></td></tr>";
-						} else {
-							featureInfoList += "<tr><td valign='top'><a style='text-decoration:  underline' href='"+urls[i].request+"' target='_blank'>"+urls[i].title+"</a></td><td><img src='' alt='<?php echo _mb("No legend available");?>!'/></td></tr>";
+						featureInfoList += "<tr><td valign='top'><a style='text-decoration:  underline' href='"+urls[i].request+"' target='_blank'>"+urls[i].title+"</a></td><td>";
+						//get legend urls if available
+						var legend = urls[i].legendurl.split(",");
+						for(var k=0;k<legend.length;k++){
+							featureInfoList +="<img src='"+legend[k]+"' alt='<?php echo _mb("No legend available");?>!'/><br>";
+						featureInfoList += "</td></tr>";
+					} else {
+						if (urls[i].inBbox) {
+							if (urls[i].legendurl !== "empty" ) {
+								featureInfoList += "<tr><td valign='top'><a style='text-decoration:  underline' href='"+urls[i].request+"' target='_blank'>"+urls[i].title+"</a></td><td><img src='"+urls[i].legendurl+"' alt='<?php echo _mb("No legend available");?>!'/></td></tr>";
+							} else {
+								featureInfoList += "<tr><td valign='top'><a style='text-decoration:  underline' href='"+urls[i].request+"' target='_blank'>"+urls[i].title+"</a></td><td><img src='' alt='<?php echo _mb("No legend available");?>!'/></td></tr>";
 			} else {
 				for(var i=urls.length-1; i>=0; i--){
-						} else {
+					} else {
+							} else {
More information about the Mapbender_commits mailing list
