[Mapbender-commits] r8797 - in trunk/mapbender: http_auth/http owsproxy/http
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Mar 7 03:28:34 PST 2014
Author: armin11
Date: 2014-03-07 03:28:34 -0800 (Fri, 07 Mar 2014)
New Revision: 8797
   trunk/mapbender/http_auth/http/index.php
   trunk/mapbender/owsproxy/http/index.php
Bugfix for proxys - external links and legends!
Modified: trunk/mapbender/http_auth/http/index.php
--- trunk/mapbender/http_auth/http/index.php	2014-03-06 15:32:21 UTC (rev 8796)
+++ trunk/mapbender/http_auth/http/index.php	2014-03-07 11:28:34 UTC (rev 8797)
@@ -9,8 +9,11 @@
 //database connection
 $db = db_connect($DBSERVER, $OWNER, $PW);
 db_select_db(DB, $db);
+/* * *** conf **** */
 $imageformats = array("image/png", "image/gif", "image/jpeg", "image/jpg");
+$width = 400;
+$height = 400;
 //control if digest auth is set, if not set, generate the challenge with getNonce()
 if (empty($_SERVER['PHP_AUTH_DIGEST'])) {
@@ -168,7 +171,9 @@
         break;
     case 'getlegendgraphic':
         $url = getLegendUrl($wmsId);
-        $e = new mb_exception("URL for getlegendgraphic: ");
+	if (isset($reqParams['sld']) && $reqParams['sld'] != "") {
+            $url = $url . getConjunctionCharacter($url) . "SLD=" . $reqParams['sld'];
         if (isset($auth)) {
             getImage($url, $auth);
         } else {
@@ -234,7 +239,7 @@
-function throwImage($e)
+/*function throwImage($e)
     global $reqParams;
     if (!$reqParams['width'] || !$reqParams['height']) { //width or height are not set by ows request - maybe for legendgraphics
@@ -250,6 +255,33 @@
         ImageString($image, 3, 5, $i * 20, $e[$i], $text_color);
     responseImage($image);
+function throwImage($e)
+    global $width, $height;
+    $image = imagecreate($width, $height);
+    $transparent = ImageColorAllocate($image, 155, 155, 155);
+    ImageFilledRectangle($image, 0, 0, $width, $height, $transparent);
+    imagecolortransparent($image, $transparent);
+    $text_color = ImageColorAllocate($image, 233, 14, 91);
+    if (count($e) > 1) {
+        for ($i = 0; $i < count($e); $i++) {
+            $imageString = $e[$i];
+            ImageString($image, 3, 5, $i * 20, $imageString, $text_color);
+    } else {
+        if (is_array($e)) {
+            $imageString = $e[0];
+        } else {
+            $imageString = $e;
+        if ($imageString == "") {
+            $imageString = "An unknown error occured!";
+    responseImage($image);
 function throwText($e)
@@ -261,6 +293,7 @@
     global $reqParams;
     $format = $reqParams['format'];
+    $format = "image/gif";
     if ($format == 'image/png') {
         header("Content-Type: image/png");
Modified: trunk/mapbender/owsproxy/http/index.php
--- trunk/mapbender/owsproxy/http/index.php	2014-03-06 15:32:21 UTC (rev 8796)
+++ trunk/mapbender/owsproxy/http/index.php	2014-03-07 11:28:34 UTC (rev 8797)
@@ -164,8 +164,11 @@
 $e = new mb_notice("user id for authorization test: " . getUserFromSession());
 $wmsId = $n->getWmsIdFromOwsproxyString($query->getOwsproxyServiceId());
 //get authentication infos if they are available in wms table! if not $auth = false
-$auth = $n->getAuthInfoOfWMS($wmsId);
+if ($reqParams['request'] !== 'external') {
+	$auth = $n->getAuthInfoOfWMS($wmsId);
 if ($auth['auth_type'] == '') {
     unset($auth);
@@ -242,7 +245,6 @@
                 $price);
         if (isset($auth)) {
-            #$mb_exception = new mb_exception("auth: ".$auth['auth_type']);
             getImage($log_id, $request, $auth);
         } else {
             getImage($log_id, $request);
@@ -394,6 +396,7 @@
 function getImage($log_id, $or)
     global $reqParams;
+    $header = "Content-Type: ".$reqParams['format'];
     #log the image_requests to database
     #log the following to table mb_proxy_log
     #timestamp,user_id,getmaprequest,amount pixel,price - but do this only for wms to log - therefor first get log tag out of wms!
@@ -401,9 +404,9 @@
 	if (func_num_args() == 3) { //new for HTTP Authentication
         $auth = func_get_arg(2);
-        getDocumentContent($log_id, $or, $auth);
+        getDocumentContent($log_id, $or, $header, $auth);
     } else {
-        getDocumentContent($log_id, $or);
+        getDocumentContent($log_id, $or, $header);
@@ -418,7 +421,7 @@
     global $reqParams;
-        getDocumentContent($log_id, $url, $auth);
+        getDocumentContent($log_id, $url, false, $auth);
     } else {
         getDocumentContent($log_id, $url);
@@ -551,23 +554,27 @@
 function matchUrls($content)
-    if (!isset($_SESSION["owsproxyUrls"])) {
-        $_SESSION["owsproxyUrls"] = array();
-        $_SESSION["owsproxyUrls"]["id"] = array();
-        $_SESSION["owsproxyUrls"]["url"] = array();
-    $pattern = "/[\"|\'](https*:\/\/[^\"|^\']*)[\"|\']/";
-    preg_match_all($pattern, $content, $matches);
-    for ($i = 0; $i < count($matches[1]); $i++) {
-        $req = $matches[1][$i];
-        $notice = new mb_notice("owsproxy found URL " . $i . ": " . $req);
-        #$notice = new mb_exception("owsproxy id:".$req);
-        $id = registerURL($req);
-        $extReq = setExternalRequest($id);
-        $notice = new mb_notice("MD5 URL " . $id . " - external link: " . $extReq);
-        $content = str_replace($req, $extReq, $content);
-    return $content;
+	//check if isset owsproxyUrls else create
+	$owsproxyUrls = Mapbender::session()->get('owsproxyUrls');
+	if ($owsproxyUrls == false) {
+		$e = new mb_notice("owsproxyUrls does not exist - create it!");
+		$owsproxyUrls = array();
+		$owsproxyUrls['id'] = array();
+		$owsproxyUrls['url'] = array();
+		Mapbender::session()->set('owsproxyUrls',$owsproxyUrls);
+    	$pattern = "/[\"|\'](https*:\/\/[^\"|^\']*)[\"|\']/";
+    	preg_match_all($pattern, $content, $matches);
+    	for ($i = 0; $i < count($matches[1]); $i++) {
+        	$req = $matches[1][$i];
+        	$notice = new mb_notice("owsproxy found URL " . $i . ": " . $req);
+       	 	#$notice = new mb_exception("owsproxy id:".$req);
+        	$id = registerURL($req);
+        	$extReq = setExternalRequest($id);
+        	$notice = new mb_notice("MD5 URL " . $id . " - external link: " . $extReq);
+        	$content = str_replace($req, $extReq, $content);
+    	return $content;
 function setExternalRequest($id)
@@ -580,31 +587,32 @@
 function getExternalRequest($id)
-    for ($i = 0; $i < count($_SESSION["owsproxyUrls"]["url"]); $i++) {
-        if ($id == $_SESSION["owsproxyUrls"]["id"][$i]) {
-            $cUrl = $_SESSION["owsproxyUrls"]["url"][$i];
-            $query_string = removeOWSGetParams($_SERVER["QUERY_STRING"]);
-            if ($query_string != '') {
-                $cUrl .= getConjunctionCharacter($cUrl) . $query_string;
-            $metainfo = get_headers($cUrl, 1);
-            // just for the stupid InternetExplorer
-            header('Pragma: private');
-            header('Cache-control: private, must-revalidate');
-            header("Content-Type: " . $metainfo['Content-Type']);
-            $content = getDocumentContent(false, $cUrl);
-            #$content = matchUrls($content);
-            echo $content;
+	//get owsproxyUrls from session
+	for ($i = 0; $i < count($owsproxyUrls["url"]); $i++) {
+        	if ($id == $owsproxyUrls["id"][$i]) {
+            		$cUrl = $owsproxyUrls["url"][$i];
+            		$query_string = removeOWSGetParams($_SERVER["QUERY_STRING"]);
+            		if ($query_string != '') {
+                		$cUrl .= getConjunctionCharacter($cUrl) . $query_string;
+            		$metainfo = get_headers($cUrl, 1);
+            		// just for the stupid InternetExplorer
+            		header('Pragma: private');
+            		header('Cache-control: private, must-revalidate');
+           		header("Content-Type: " . $metainfo['Content-Type']);
+            		//$content = getDocumentContent(false, $cUrl, headers_list());
+			$content = getDocumentContent(false, $cUrl, $metainfo);
+            		#$content = matchUrls($content);
+        	} else {
+			$e = new mb_exception("owsproxy/http/index.php: No key found for this URL in session!");
 function removeOWSGetParams($query_string)
     $r = preg_replace("/.*request=external&/", "", $query_string);
-    #return $r;
     return "";
@@ -627,18 +635,22 @@
 function registerUrl($url)
-    if (!in_array($url, $_SESSION["owsproxyUrls"]["url"])) {
-        $id = md5($url);
-        array_push($_SESSION["owsproxyUrls"]["url"], $url);
-        array_push($_SESSION["owsproxyUrls"]["id"], $id);
-    } else {
-            if ($url == $_SESSION["owsproxyUrls"]["url"][$i]) {
-                $id = $_SESSION["owsproxyUrls"]["id"][$i];
-    return $id;
+	//get owsproxy urls from session
+    	if (!in_array($url, $owsproxyUrls["url"])) {
+        	$id = md5($url);
+        	array_push($owsproxyUrls["url"], $url);
+        	array_push($owsproxyUrls["id"], $id);
+    	} else {
+            		if ($url == $owsproxyUrls["url"][$i]) {
+                		$id = $owsproxyUrls["id"][$i];
+    	return $id;
 function getCapabilities($url)
@@ -680,7 +692,13 @@
     $sql .= "ON layer_style.fkey_layer_id = layer.layer_id ";
     $sql .= "WHERE layer.layer_name = $2 AND layer.fkey_wms_id = $1 ";
     $sql .= "AND layer_style.name = $3 AND layer_style.legendurlformat = $4";
-    $v = array($wmsid, $reqParams['layer'], $reqParams['style'], $reqParams['format']);
+    if ($reqParams['style'] == '') {
+        $style = 'default';
+    } else {
+        $style = $reqParams['style'];
+    //$v = array($wmsid, $reqParams['layer'], $reqParams['style'], $reqParams['format']);
+    $v = array($wmsid, $reqParams['layer'], $style, $reqParams['format']);
     $t = array("i", "s", "s", "s");
     $res = db_prep_query($sql, $v, $t);
     if ($row = db_fetch_array($res)) {
@@ -813,11 +831,11 @@
     return $ret;
-function getDocumentContent($log_id, $url)
+function getDocumentContent($log_id, $url, $header = false)
     global $reqParams, $n;
-    if (func_num_args() == 3) { //new for HTTP Authentication
-        $auth = func_get_arg(2);
+    if (func_num_args() == 4) { //new for HTTP Authentication
+        $auth = func_get_arg(3);
         $d = new connector($url, $auth);
     } else {
         $d = new connector($url);
@@ -877,7 +895,10 @@
         return true;
     } else {
-        return $content;
+	if (header !== false) {
+		header($header);
+        echo $content;
More information about the Mapbender_commits mailing list
