[Mapbender-commits] r8820 - in trunk/mapbender: http/plugins http/widgets lib
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed May 7 01:51:46 PDT 2014
Author: hwbllmnn
Date: 2014-05-07 01:51:46 -0700 (Wed, 07 May 2014)
New Revision: 8820
   trunk/mapbender/http/plugins/kmlTree.js
   trunk/mapbender/http/plugins/mb_digitize_widget.php
   trunk/mapbender/http/widgets/w_digitize.js
   trunk/mapbender/lib/mb.ui.displayKmlFeatures.js
initial implementation of digitizing into json object
Modified: trunk/mapbender/http/plugins/kmlTree.js
--- trunk/mapbender/http/plugins/kmlTree.js	2014-05-07 08:47:30 UTC (rev 8819)
+++ trunk/mapbender/http/plugins/kmlTree.js	2014-05-07 08:51:46 UTC (rev 8820)
@@ -66,6 +66,9 @@
 		title = obj.url;
+        if(obj.refreshing) {
+            $KMLfolder.find('ul li[title="' + title + '"]').remove();
 	    abbrevTitle = title.length < 20 ?  title : title.substr(0,17) + "...";
             $kmlEntry = $('<li title="'+ title +'" class="open"><button class="toggle" name="toggle" value="toggle" ></button> <input type="checkbox"'+checked  +'/><button class="digitize-layer" name="digitize-layer" value="digitize-layer"></button><button class="remove" name="remove" value="remove" ></button><a href="#">'+abbrevTitle+'</a></li>');
 		$KMLfolder.children("ul").append($kmlEntry);
Modified: trunk/mapbender/http/plugins/mb_digitize_widget.php
--- trunk/mapbender/http/plugins/mb_digitize_widget.php	2014-05-07 08:47:30 UTC (rev 8819)
+++ trunk/mapbender/http/plugins/mb_digitize_widget.php	2014-05-07 08:51:46 UTC (rev 8820)
@@ -106,16 +106,8 @@
 		digitizeDialog.find(".mb-digitize-perimeter").parent().hide();
 		digitizeDialog.find(".mb-digitize-area").parent().hide();
                 digitizeDialog.find(".mb-digitize-angle").parent().hide();
-	var changeDialogContent = function () {
-		digitizeDialog.html(informationHtml);
-		hideDigitizeData();
-		o.$target.unbind("click", changeDialogContent);
 	var create = function () {
 		// Initialise digitize dialog
@@ -143,132 +135,16 @@
-	var updateCurrentPoint = function (evt, data) {
-		if (data.pos) {
-			var p = data.pos;
-			digitizeDialog.find(".mb-digitize-current-point").text(
-				p.pos.x + " " + p.pos.y
-			).parent().show();
-	var updateClickedPoint = function (evt, data) {
-		if (data.pos) {
-			var p = data.pos;
-			digitizeDialog.find(".mb-digitize-clicked-point").text(
-                        var digitizedX = $('input[name="digitized_x_values"]').val();
-                        if(digitizedX != "") {
-                            digitizedX += ",";
-                        digitizedX += p.pos.x;
-                        $('input[name="digitized_x_values"]').val(digitizedX)
-                        var digitizedY = $('input[name="digitized_y_values"]').val();
-                        if(digitizedY != "") {
-                            digitizedY += ",";
-                        digitizedY += p.pos.y;
-                        $('input[name="digitized_y_values"]').val(digitizedY);
-	var updateCurrentDistance = function (evt, data) {
-		if (data.currentDistance) {
-			var lastDistanceUnit = "m";
-			var displayDistance = data.currentDistance;
-			if (displayDistance > 10000){
-				displayDistance /= 1000;
-				lastDistanceUnit = "km";
-			digitizeDialog.find(".mb-digitize-distance-last-unit").html(lastDistanceUnit);
-			digitizeDialog.find(".mb-digitize-distance-last").text(Math.round(displayDistance*10)/10).parent().show();
-	var updateTotalDistance = function (evt, data) {
-		if (data.totalDistance) {
-			var totalDistanceUnit = "m";
-			var displayTotalDistance = data.totalDistance;
-			if (displayTotalDistance > 10000){
-				displayTotalDistance = displayTotalDistance / 1000;
-				totalDistanceUnit = "km";
-			digitizeDialog.find(".mb-digitize-distance-total-unit").html(totalDistanceUnit);
-			digitizeDialog.find(".mb-digitize-distance-total").text(Math.round(displayTotalDistance*10)/10).parent().show();
-		else {
-			digitizeDialog.find(".mb-digitize-distance-total").parent().hide();
-	var updatePerimeter = function (evt, data) {
-		if (data.perimeter) {
-			var unit = "m";
-			var displayPerimeter = data.perimeter;
-			if (displayPerimeter > 10000){
-				displayPerimeter = displayPerimeter / 1000;
-				unit = "km";
-			digitizeDialog.find(".mb-digitize-perimeter-unit").html(unit);
-			digitizeDialog.find(".mb-digitize-perimeter").text(Math.round(displayPerimeter*10)/10).parent().show();
-		else {
-			//digitizeDialog.find(".mb-digitize-perimeter").parent().hide();
-	var updateArea = function (evt, data) {
-		if (data.area) {
-			var areaUnit = "m&sup2;";
-			var area = data.area;
-			if (area > 10000000){
-				area /= 1000000;
-				areaUnit = "km&sup2;";
-			else if (area > 100000){
-				area /= 10000;
-				areaUnit = "ha";
-			area = Math.round(area*10)/10;
-			digitizeDialog.find(".mb-digitize-area-unit").html(areaUnit);
-			digitizeDialog.find(".mb-digitize-area").text(area).parent().show();
-		else {
-			digitizeDialog.find(".mb-digitize-area").parent().hide();
-        var updateAngle = function (evt, data) {
-        	if (data.currentAngle) {
-			var unit = "°";
-			var displayAngle = data.currentAngle;
-                        digitizeDialog.find(".mb-digitize-angle-unit").html(unit);
-			digitizeDialog.find(".mb-digitize-angle").text(Math.round(displayAngle*10)/10).parent().show();
-		else {
-			//digitizeDialog.find(".mb-digitize-angle").parent().hide();
-	var updateView = function (evt, data) {
-		updateCurrentPoint(evt, data);
-		updateCurrentDistance(evt, data);
-		updateTotalDistance(evt, data);
-		updateArea(evt, data);
-		updatePerimeter(evt, data);
-                updateAngle(evt, data);
 	var finishDigitize = function () {
 		inProgress = false;
 		that.deactivate();
+        // TODO experimental
+        var kml = $('#mapframe1').data('kml');
+        if(kml) {
+            var digit = o.$target.data('mb_digitize');
+            var pts = digit._digitizePoints;
+            kml.addGeometry(pts);
 	var reinitializeDigitize = function () {
@@ -285,11 +161,9 @@
 		if (o.$target.size() > 0) {
 			o.$target
 				.mb_digitize(o)
-				.bind("mb_digitizeupdate", updateView)
-				.bind("mb_digitizepointadded", updateClickedPoint)
+//				.bind("mb_digitizepointadded", newPoint)
 				.bind("mb_digitizelastpointadded", finishDigitize)
-				.bind("mb_digitizereinitialize", reinitializeDigitize)
-				.bind("click", changeDialogContent);
+				.bind("mb_digitizereinitialize", reinitializeDigitize);
 		if (!inProgress) {
 			inProgress = true;
@@ -302,8 +176,7 @@
 	this.destroy = function () {
 			o.$target.mb_digitize("destroy")
-				.unbind("mb_digitizeupdate", updateView)
-				.unbind("mb_digitizepointadded", updateClickedPoint)
+//				.unbind("mb_digitizepointadded", newPoint)
 				.unbind("mb_digitizelastpointadded", finishDigitize)
 				.unbind("mb_digitizereinitialize", reinitializeDigitize);
Modified: trunk/mapbender/http/widgets/w_digitize.js
--- trunk/mapbender/http/widgets/w_digitize.js	2014-05-07 08:47:30 UTC (rev 8819)
+++ trunk/mapbender/http/widgets/w_digitize.js	2014-05-07 08:51:46 UTC (rev 8820)
@@ -19,9 +19,6 @@
 	_digitizePoints: [],
 	_map: undefined,
 	_srs: undefined,
-	_currentDistance: 0,
-        _currentAngle: 0,
-	_totalDistance: 0,
 	_polygonIsInvalid: false,
 	_currentPolygonIsInvalid: false,
 	_canvas: undefined,
@@ -148,63 +145,6 @@
 		return null;
-	// calculate distance
-	_calculateDistanceGeographic: function (a, b) {
-		var lon_from = this._toRad(a.x);
-		var lat_from = this._toRad(a.y);
-		var lon_to = this._toRad(b.x);
-		var lat_to = this._toRad(b.y);
-		return Math.abs(6371229 * Math.acos(
-			Math.sin(lat_from) * Math.sin(lat_to) +
-			Math.cos(lat_from) * Math.cos(lat_to) *
-			Math.cos(lon_from - lon_to)
-	_calculateDistanceMetric: function (a, b) {
-		return Math.abs(Math.sqrt(
-			Math.pow(Math.abs(b.x - a.x), 2) +
-			Math.pow(Math.abs(b.y - a.y), 2)
-	_calculateDistance: function (a, b) {
-		if (a !== null && b !== null) {
-			switch (this._map.getSrs()) {
-				case "EPSG:4326":
-					return this._calculateDistanceGeographic(a, b);
-				default:
-					return this._calculateDistanceMetric(a, b);
-		return null;
-        _calculateAngle: function (a, b, c) {
-		if (a !== null && b !== null && c !== null) {
-                        function angleAt(a,b,c){
-                            var vectorAB = [b.x- a.x,b.y-a.y];
-                            //var vectorBC = [c.x- b.x,c.y-b.y];
-                            var vectorBC = [b.x- c.x,b.y-c.y];
-                            var cosalpha = scalarProduct(vectorAB,vectorBC)/
-                                (vectorlen(vectorAB)*vectorlen(vectorBC));
-                            var acosalpha = Math.acos(cosalpha);
-                            return (acosalpha/Math.PI)*180;
-                        function scalarProduct(va,vb){
-                                return va[0]*vb[0] + va[1]*vb[1];
-                        function vectorlen(v) {
-                                return  Math.sqrt(v[0]*v[0] + v[1]*v[1]);
-                        var angle = angleAt(a,b,c);
-                        return angle;
-		return null;
 	_isPointSnapped: function (p1, p2) {
 		return p1.dist(p2) <= this.options.digitizePointDiameter/2;
@@ -324,60 +264,6 @@
-		var len = this._digitizePoints.length;
-		var previousPoint = len > 0 ?
-			this._digitizePoints[len - 1].pos : null;
-		this._currentDistance = this._calculateDistance(
-			previousPoint,
-			digitizeData.pos.pos
-		// calculate total distance and perimeter
-		if (len > 0) {
-			digitizeData.currentDistance = this._currentDistance;
-			this._totalDistance = this._currentDistance;
-			if (!firstPointSnapped) {
-				digitizeData.totalDistance = this._totalDistance ;
-			if (len > 1) {
-				this._totalDistance = this._digitizePoints[len - 1].totalDistance + this._currentDistance;
-					digitizeData.totalDistance = this._totalDistance;
-				if (!lastPointSnapped) {
-					digitizeData.perimeter = digitizeData.totalDistance + this._calculateDistance(
-						this._digitizePoints[0].pos,
-                                this._currentAngle = this._calculateAngle(
-                                    this._digitizePoints[len-2].pos,
-                                    previousPoint,
-                                digitizeData.currentAngle  = this._currentAngle;
-		// calculate area
-		if (this._isPolygon(this._digitizePoints, digitizeData.pos) && !this._polygonIsInvalid) {
-			this._currentArea = this._calculateArea(digitizeData.pos);
-				digitizeData.area = this._currentArea;
 		this._trigger("update", null, digitizeData);
 		this._draw(digitizeData.pos, {
@@ -412,10 +298,6 @@
-		if (this._totalDistance) {
-			data.pos.totalDistance = this._totalDistance;
 		this._trigger("pointadded", e, data);
 		var firstPointSnapped = this._isFirstPointSnapped(mousePos);
@@ -433,16 +315,13 @@
 				highlightLast: lastPointSnapped,
 				drawPoints: false
-			this._addLastPoint(e);
 			this._digitizePoints.closedPolygon = firstPointSnapped;
 			this._digitizePoints.closedLine = lastPointSnapped;
+			this._addLastPoint(e);
 		else {
 			this._digitizePoints.push(data.pos);
-			this._totalDistance += this._currentDistance;
-			this._currentDistance = 0;
 			lastPointSnapped = this._isLastPointSnapped(mousePos);
 			this._draw(data.pos, {
 				highlightFirst: firstPointSnapped,
Modified: trunk/mapbender/lib/mb.ui.displayKmlFeatures.js
--- trunk/mapbender/lib/mb.ui.displayKmlFeatures.js	2014-05-07 08:47:30 UTC (rev 8819)
+++ trunk/mapbender/lib/mb.ui.displayKmlFeatures.js	2014-05-07 08:51:46 UTC (rev 8820)
@@ -185,6 +185,52 @@
+    addGeometry: function(pts) {
+        var $map = $(this.element).mapbender();
+        var self = this;
+        var tp = pts.closedPolygon ? geomType.polygon : (pts.closedLine ? geomType.line : geomType.point);
+        var itm;
+        // todo select the one that's marked for editing
+        $.each(this._kmls, function(k, v) {
+            itm = v;
+        for(var i in itm.highlightArray){
+            itm.highlightArray[i].hide();
+        $map.setMapRequest();
+        var h = new Highlight([self.element.attr('id')], "mapframe1_" + parseInt(Math.random()*100000,10),{
+            "position":"absolute",
+            "top": "0px",
+            "left": "0px",
+            "z-index": "80" },1);
+        var geom = new Geometry();
+        var multi = new MultiGeometry(tp);
+        for(i = 0; i < pts.length; ++i) {
+            geom.addPoint(pts[i].pos);
+        geom.geomType = tp;
+        multi.add(geom);
+        multi.e = new Wfs_element();
+        var icon = multi.e.getElementValueByName("Mapbender:icon");
+        multi.e.setElement('title', 'title');
+        multi.e.setElement('name', 'name');
+        if(icon == "false" || icon === false){
+            multi.e.setElement("Mapbender:iconOffsetX", -10);
+            multi.e.setElement("Mapbender:iconOffsetY", -34);
+            multi.e.setElement("Mapbender:icon","../img/marker/red.png");
+        h.add(geom);
+        itm.data.features.push(JSON.parse(multi.toString()));
+        this._convertFromJson(itm);
+        this.element.trigger('kml:loaded',{type:"geojson",data:itm.data,url:itm.url,display: itm.display, refreshing: true});
 	_load : function(url){
 		var self = this, o = this.options;
 		var epsg = $(self.element).mapbender().epsg;
@@ -226,11 +272,13 @@
             var kmls = mb_getWmcExtensionData('KMLS');
+        // try{
             if(kmls) {
                 kmls = JSON.parse(kmls);
                 this._kmls = kmls;
                 for(var k in kmls) {
                     kmls[k].loadedOnStartup = true;
+                self._convertFromJson(kmls[k]);
                     self.element.trigger('kml:loaded',kmls[k]);
@@ -242,6 +290,9 @@
             if(kmls) {
                 this.kmlOrder = JSON.parse(kmls);
+        // }catch(e){
+        //     console.log(e)
                     reload: function() {
@@ -309,23 +360,24 @@
-	_display : function(mapitem){
-		var self = this, o = this.options;
-		// getting the mapitem from the events bre
-		mapitem = self._kmls[mapitem.url];
+    _convertFromJson: function(mapitem) {
 		var geojson = mapitem.data;
-		if(typeof(Mapbender) != "undefined"){
+        var self = this;
 			var $map = $(self.element).mapbender();
 			var markers = [];
 			var title = "";
-			if(geojson.features){
 				// we always transform _from_ 4326 KML use this as their default
 				// var projSrc = new Proj4js.Proj('EPSG:4326');
 				// var projDest = new Proj4js.Proj($map.epsg);
 				var markeroptions = {width: "19px", height: "34px"};
 				var g = null;
+        for(var i in mapitem.highlightArray){
+            var h = mapitem.highlightArray[i].hide;
+            if(h) h();
 				mapitem.geomArray = new GeometryArray();
 				mapitem.highlightArray = [];
 				mapitem.geomArray.importGeoJSON(geojson);
@@ -388,13 +440,18 @@
+    _display : function(mapitem){
+        var self = this, o = this.options;
+        // getting the mapitem from the events bre
+        mapitem = self._kmls[mapitem.url];
+        if(typeof(Mapbender) != "undefined"){
+            this._convertFromJson(mapitem);
More information about the Mapbender_commits mailing list
