[Mapbender-commits] r8821 - in trunk/mapbender: http/plugins http/widgets lib
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed May 7 04:06:01 PDT 2014
Author: hwbllmnn
Date: 2014-05-07 04:06:01 -0700 (Wed, 07 May 2014)
New Revision: 8821
   trunk/mapbender/http/plugins/kmlTree.js
   trunk/mapbender/http/widgets/w_digitize.js
   trunk/mapbender/lib/mb.ui.displayKmlFeatures.js
proper indenting, use kml selected for editing only to store features
Modified: trunk/mapbender/http/plugins/kmlTree.js
--- trunk/mapbender/http/plugins/kmlTree.js	2014-05-07 08:51:46 UTC (rev 8820)
+++ trunk/mapbender/http/plugins/kmlTree.js	2014-05-07 11:06:01 UTC (rev 8821)
@@ -1,164 +1,165 @@
-  * Package: kmlTree
-  * Description:
-  * Module to load KML temporary in a tree
-  * Files:
-  *  - mapbender/http/plugins/kmlTree.js
-  *  - mapebnder/lib/mb.ui.displayKmlFeatures.js
-  *  - mapbender/http/css/kmltree.css
-  * SQL:
-  * > INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,
-  * > e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content,
-  * > e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('<app_id>',
-  * > 'kmlTree',2,1,'Displays KML on the map','KML','ul','','',1,1,200,200,NULL ,
-  * > 'visibility:visible','','ul','../plugins/kmlTree.js','../../lib/mb.ui.displayKmlFeatures.js',
-  * > 'mapframe1','jq_ui_widget','http://www.mapbender.org/Loadkml');
-  * > INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'kmlTree',
-  * > 'buffer', '100', '' ,'var');
-  * > VALUES('gui', 'kmlTree', 'styles', '../css/kmltree.css', '' ,'file/css');
-  * Help:
-  * http://www.mapbender.org/Loadkml
-  * Maintainer:
-  * http://www.mapbender.org/User:Armin_Retterath
-  * License:
-  * Copyright (c) 2009, Open Source Geospatial Foundation
-  * This program is dual licensed under the GNU General Public License
-  * and Simplified BSD license.
-  * http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
+ * Package: kmlTree
+ * Description:
+ * Module to load KML temporary in a tree
+ * Files:
+ *  - mapbender/http/plugins/kmlTree.js
+ *  - mapebnder/lib/mb.ui.displayKmlFeatures.js
+ *  - mapbender/http/css/kmltree.css
+ * SQL:
+ * > INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,
+ * > e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content,
+ * > e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('<app_id>',
+ * > 'kmlTree',2,1,'Displays KML on the map','KML','ul','','',1,1,200,200,NULL ,
+ * > 'visibility:visible','','ul','../plugins/kmlTree.js','../../lib/mb.ui.displayKmlFeatures.js',
+ * > 'mapframe1','jq_ui_widget','http://www.mapbender.org/Loadkml');
+ * > INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'kmlTree',
+ * > 'buffer', '100', '' ,'var');
+ * > VALUES('gui', 'kmlTree', 'styles', '../css/kmltree.css', '' ,'file/css');
+ * Help:
+ * http://www.mapbender.org/Loadkml
+ * Maintainer:
+ * http://www.mapbender.org/User:Armin_Retterath
+ * License:
+ * Copyright (c) 2009, Open Source Geospatial Foundation
+ * This program is dual licensed under the GNU General Public License
+ * and Simplified BSD license.
+ * http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
 var $kmlTree = $(this);
 var KmlTree = function(o){
-	$kmlTree.children().remove();
-	$kmlTree.addClass('kmlTree');
-	var $KMLfolder = $('<li class="open kml"><img src="../img/kml_logo.png" /><a href="#">KML</a><ul></ul></li>');
-	$kmlTree.append($KMLfolder);
+    $kmlTree.children().remove();
+    $kmlTree.addClass('kmlTree');
+    var $KMLfolder = $('<li class="open kml"><img src="../img/kml_logo.png" /><a href="#">KML</a><ul></ul></li>');
+    $kmlTree.append($KMLfolder);
-	$addButton = $('<button class="add" name="addkml" value="addkml"></button>');
-	$addButton.click(function(){
-		$('<div ><input class="kmlurl" /></div>').dialog({
-			"title": "KML hinzufügen",
-			"buttons":{
-				"OK": function(){
-					$('#mapframe1').kml({ url: $(this).find('.kmlurl').val()});
-					$(this).dialog('destroy');
-	$KMLfolder.find("a").after($addButton);
+    $addButton = $('<button class="add" name="addkml" value="addkml"></button>');
+    $addButton.click(function(){
+        $('<div ><input class="kmlurl" /></div>').dialog({
+            "title": "KML hinzufügen",
+            "buttons":{
+                "OK": function(){
+                    $('#mapframe1').kml({ url: $(this).find('.kmlurl').val()});
+                    $(this).dialog('destroy');
+    $KMLfolder.find("a").after($addButton);
-	o.$target.bind('kml:loaded',function(e,obj){
-		//console.log(obj);
-		var checked = obj.display ? 'checked="checked"':'';
+    o.$target.bind('kml:loaded',function(e,obj){
+        //console.log(obj);
+        var checked = obj.display ? 'checked="checked"':'';
-		title = obj.url;
+        title = obj.url;
         if(obj.refreshing) {
             $KMLfolder.find('ul li[title="' + title + '"]').remove();
-	    abbrevTitle = title.length < 20 ?  title : title.substr(0,17) + "...";
-            $kmlEntry = $('<li title="'+ title +'" class="open"><button class="toggle" name="toggle" value="toggle" ></button> <input type="checkbox"'+checked  +'/><button class="digitize-layer" name="digitize-layer" value="digitize-layer"></button><button class="remove" name="remove" value="remove" ></button><a href="#">'+abbrevTitle+'</a></li>');
-		$KMLfolder.children("ul").append($kmlEntry);
-		$kmlEntry.find("a").bind("click",(function(jsonFeatureCollection){return function(){
-				var map = o.$target.mapbender();
-				var g = new GeometryArray();
-				g.importGeoJSON(jsonFeatureCollection,false);
+        abbrevTitle = title.length < 20 ?  title : title.substr(0,17) + "...";
+        $kmlEntry = $('<li title="'+ title +'" class="open"><button class="toggle" name="toggle" value="toggle" ></button> <input type="checkbox"'+checked  +'/><button class="digitize-layer" name="digitize-layer" value="digitize-layer"></button><button class="remove" name="remove" value="remove" ></button><a href="#">'+abbrevTitle+'</a></li>');
+        $KMLfolder.children("ul").append($kmlEntry);
+        $kmlEntry.find("a").bind("click",(function(jsonFeatureCollection){return function(){
+        var map = o.$target.mapbender();
+        var g = new GeometryArray();
+        g.importGeoJSON(jsonFeatureCollection,false);
-				var bbox = g.getBBox();
-				var bufferFloat = parseFloat(o.buffer);
-				var buffer = new Point(bufferFloat,bufferFloat);
-				bbox[0] = bbox[0].minus(buffer);
-				bbox[1] = bbox[1].plus(buffer);
+        var bbox = g.getBBox();
+        var bufferFloat = parseFloat(o.buffer);
+        var buffer = new Point(bufferFloat,bufferFloat);
+        bbox[0] = bbox[0].minus(buffer);
+        bbox[1] = bbox[1].plus(buffer);
-				map.calculateExtent(
-				  new Mapbender.Extent(bbox[0], bbox[1])
-				map.setMapRequest();
+        map.calculateExtent(
+        new Mapbender.Extent(bbox[0], bbox[1])
+        map.setMapRequest();
-		})(obj.data));
+        })(obj.data));
-		$featureList = $("<ul />");
-		$kmlEntry.append($featureList);
-		for(var i = 0;i < obj.data.features.length;i++){
+        $featureList = $("<ul />");
+        $kmlEntry.append($featureList);
+        for(var i = 0;i < obj.data.features.length;i++){
-			title = obj.data.features[i].properties.name;
-			$feature = $('<li title="'+ title +'"><a href="#" >'+ abbrevTitle + '</a></li>');
-			$featureList.append($feature);
-			$feature.bind('click',(function(jsonFeature){return function(){
+            title = obj.data.features[i].properties.name;
+            $feature = $('<li title="'+ title +'"><a href="#" >'+ abbrevTitle + '</a></li>');
+            $featureList.append($feature);
+            $feature.bind('click',(function(jsonFeature){return function(){
-				g.importGeoJSON(jsonFeature,false);
-				var feature = g.get(0);
+                                                             g.importGeoJSON(jsonFeature,false);
+                                                             var feature = g.get(0);
-				var bbox = feature.getBBox();
+                                                             var bbox = feature.getBBox();
-			})(obj.data.features[i]));
+                                                        })(obj.data.features[i]));
-			$feature.bind('mouseout',(function(jsonFeature){return function(){
+            $feature.bind('mouseout',(function(jsonFeature){return function(){
-				if(feature.geomType != "point"){
-					var me = $kmlTree.mapbender();
-					me.resultHighlight.clean();
-					me.resultHighlight.paint();
-			}})(obj.data.features[i]));
-			$feature.bind('mouseover',(function(jsonFeature){return function(){
+        if(feature.geomType != "point"){
+        var me = $kmlTree.mapbender();
+        me.resultHighlight.clean();
+        me.resultHighlight.paint();
+                                                            }})(obj.data.features[i]));
+            $feature.bind('mouseover',(function(jsonFeature){return function(){
-					feature = feature.getBBox4();
-					me.resultHighlight = new Highlight(
-							[o.target],
-							"KmlTreeHighlight",
-							{"position":"absolute", "top":"0px", "left":"0px", "z-index":100},
-							2);
+        feature = feature.getBBox4();
+        me.resultHighlight = new Highlight(
+        [o.target],
+        "KmlTreeHighlight",
+        {"position":"absolute", "top":"0px", "left":"0px", "z-index":100},
+        2);
-					me.resultHighlight.add(feature, "#00ff00");
-				else if(feature.geomType == "point"){
+        me.resultHighlight.add(feature, "#00ff00");
+        else if(feature.geomType == "point"){
         $('button.digitize-layer', $kmlEntry).bind('click', function() {
             $(this).toggleClass('active');
@@ -175,38 +176,46 @@
+        // $('#kmlTree > li > ul > li > ul').sortable({
+        //     update: function() {
+        // var kml = $('#mapframe1').data('kml');
+        // var urls = [];
+        // $(this).children('li[title]').each(function(k, v) {
+        //     urls.push($(this).attr('title'));
+        // kml.setOrder(urls);
+        $("*:checkbox",$kmlEntry).bind('click', function(){
+            if($(this).attr('checked')){
+                o.$target.kml('show',obj.url);
+            }else{
+                o.$target.kml('hide',obj.url);
-		$("*:checkbox",$kmlEntry).bind('click', function(){
-			if($(this).attr('checked')){
-				o.$target.kml('show',obj.url);
-			}else{
-				o.$target.kml('hide',obj.url);
+        $("button.toggle",$kmlEntry).bind('click', function(){
+            if($(this).parent().hasClass("open")){
+                $(this).parent().removeClass("open");
+                $(this).parent().addClass("closed");
+            }else{
+                $(this).parent().removeClass("closed");
+                $(this).parent().addClass("open");
-		$("button.toggle",$kmlEntry).bind('click', function(){
-			if($(this).parent().hasClass("open")){
-				$(this).parent().removeClass("open");
-				$(this).parent().addClass("closed");
-			}else{
-				$(this).parent().removeClass("closed");
-				$(this).parent().addClass("open");
+        $("button.remove",$kmlEntry).bind('click', function(){
+            o.$target.kml('remove',obj.url);
+            $(this).parent().remove();
-		$("button.remove",$kmlEntry).bind('click', function(){
-			o.$target.kml('remove',obj.url);
-			$(this).parent().remove();
 Mapbender.events.init.register(function(){
-	$kmlTree.mapbender(new KmlTree(options));
+    $kmlTree.mapbender(new KmlTree(options));
Modified: trunk/mapbender/http/widgets/w_digitize.js
--- trunk/mapbender/http/widgets/w_digitize.js	2014-05-07 08:51:46 UTC (rev 8820)
+++ trunk/mapbender/http/widgets/w_digitize.js	2014-05-07 11:06:01 UTC (rev 8821)
@@ -1,420 +1,421 @@
 $.widget("mapbender.mb_digitize", {
-	options: {
-		opacity: 0.6,
-		digitizePointDiameter: 10,
-		polygonFillSnapped: "#FC3",
-		polygonFillDefault: "#FFF",
-		polygonStrokeWidthDefault: 1,
-		polygonStrokeWidthSnapped: 5,
-		lineStrokeDefault: "#C9F",
-		lineStrokeSnapped: "#F30",
-		lineStrokeWidthDefault: 3,
-		lineStrokeWidthSnapped: 5,
-		pointFillSnapped: "#F90",
-		pointFillDefault: "#CCF",
-                pointStrokeDefault: "#FC3",
-                pointStrokeSnapped: "#F30",
-                pointStrokeWidthDefault: 2
-	_digitizePoints: [],
-	_map: undefined,
-	_srs: undefined,
-	_polygonIsInvalid: false,
-	_currentPolygonIsInvalid: false,
-	_canvas: undefined,
-	_isPolygon: function (pos) {
+    options: {
+        opacity: 0.6,
+        digitizePointDiameter: 10,
+        polygonFillSnapped: "#FC3",
+        polygonFillDefault: "#FFF",
+        polygonStrokeWidthDefault: 1,
+        polygonStrokeWidthSnapped: 5,
+        lineStrokeDefault: "#C9F",
+        lineStrokeSnapped: "#F30",
+        lineStrokeWidthDefault: 3,
+        lineStrokeWidthSnapped: 5,
+        pointFillSnapped: "#F90",
+        pointFillDefault: "#CCF",
+        pointStrokeDefault: "#FC3",
+        pointStrokeSnapped: "#F30",
+        pointStrokeWidthDefault: 2
+    _digitizePoints: [],
+    _map: undefined,
+    _srs: undefined,
+    _polygonIsInvalid: false,
+    _currentPolygonIsInvalid: false,
+    _canvas: undefined,
-		var len = this._digitizePoints.length;
+    _isPolygon: function (pos) {
-		var max = pos ? len - 1 : len - 2;
+        var len = this._digitizePoints.length;
-		if (pos && len < 2 || !pos && len < 3) {
-			return false;
+        var max = pos ? len - 1 : len - 2;
-		var posLocal = pos ? pos : this._digitizePoints[len - 1];
+        if (pos && len < 2 || !pos && len < 3) {
+            return false;
-		var p0 = this._digitizePoints[0].pos;
-		var pn = this._digitizePoints[max].pos;
-		for (var i = 0; i < max; i++)  {
-			var pi = this._digitizePoints[i].pos;
-			var pj = this._digitizePoints[i + 1].pos;
+        var posLocal = pos ? pos : this._digitizePoints[len - 1];
-			if (i > 0 && this._lineIntersect(
-				pi.x, pi.y, pj.x, pj.y,
-				p0.x, p0.y, posLocal.x, posLocal.y)
-				return false;
-			if (this._lineIntersect(
-				pn.x, pn.y, posLocal.x, posLocal.y)
-				this._currentPolygonIsInvalid = true;
-				return false;
-		this._currentPolygonIsInvalid = false;
-		return true;
-	_lineIntersect: function ( x1, y1, x2, y2, x3, y3, x4, y4 ) {
-		var isOnSegment = function (xi, yi, xj, yj, xk, yk) {
-			// changed <= to < so the segments are allowed to touch!
-			 return (xi < xk || xj < xk) &&
-					(xk < xi || xk < xj) &&
-			        (yi < yk || yj < yk) &&
-					(yk < yi || xk < yj);
+        var p0 = this._digitizePoints[0].pos;
+        var pn = this._digitizePoints[max].pos;
+        for (var i = 0; i < max; i++)  {
+            var pi = this._digitizePoints[i].pos;
+            var pj = this._digitizePoints[i + 1].pos;
-		var computeDirection = function (xi, yi, xj, yj, xk, yk) {
-			var a = (xk - xi) * (yj - yi);
-			var b = (xj - xi) * (yk - yi);
-			return a < b ? -1 : a > b ? 1 : 0;
+            if (i > 0 && this._lineIntersect(
+                pi.x, pi.y, pj.x, pj.y,
+                p0.x, p0.y, posLocal.x, posLocal.y)
+                return false;
+            if (this._lineIntersect(
+                pn.x, pn.y, posLocal.x, posLocal.y)
+                this._currentPolygonIsInvalid = true;
+                return false;
+        this._currentPolygonIsInvalid = false;
+        return true;
+    _lineIntersect: function ( x1, y1, x2, y2, x3, y3, x4, y4 ) {
+        var isOnSegment = function (xi, yi, xj, yj, xk, yk) {
+            // changed <= to < so the segments are allowed to touch!
+            return (xi < xk || xj < xk) &&
+                (xk < xi || xk < xj) &&
+                (yi < yk || yj < yk) &&
+                (yk < yi || xk < yj);
-		var e1 = computeDirection(x3, y3, x4, y4, x1, y1);
-		var e2 = computeDirection(x3, y3, x4, y4, x2, y2);
-		var e3 = computeDirection(x1, y1, x2, y2, x3, y3);
-		var e4 = computeDirection(x1, y1, x2, y2, x4, y4);
-		return (((e1 > 0 && e2 < 0) || (e1 < 0 && e2 > 0)) &&
-			((e3 > 0 && e4 < 0) || (e3 < 0 && e4 > 0))) ||
-			(e1 === 0 && isOnSegment(x3, y3, x4, y4, x1, y1)) ||
-			(e2 === 0 && isOnSegment(x3, y3, x4, y4, x2, y2)) ||
-			(e3 === 0 && isOnSegment(x1, y1, x2, y2, x3, y3)) ||
-			(e4 === 0 && isOnSegment(x1, y1, x2, y2, x4, y4));
-	_toRad: function (deg) {
-		return deg * Math.PI/180;
-	// calculate area
-	_calculateAreaMetric: function (pos) {
-		if (this._digitizePoints.length < 2) {
-			return null;
-		this._digitizePoints.push(pos);
-		var part, area = 0;
-		var p0 = this._digitizePoints[0].pos, pi, pj;
-		for (var i = 0; i < this._digitizePoints.length - 1; i++)  {
-			pi = this._digitizePoints[i].pos;
-			pj = this._digitizePoints[i + 1].pos;
-			part = (pi.y + pj.y) * (pi.x - pj.x) / 2;
-			area += part;
-		part = (pj.y + p0.y) * (pj.x - p0.x) / 2;
-		area += part;
-		this._digitizePoints.pop();
-		return Math.abs(area);
-	_calculateAreaGeographic: function (pos) {
-			return null;
+        var computeDirection = function (xi, yi, xj, yj, xk, yk) {
+            var a = (xk - xi) * (yj - yi);
+            var b = (xj - xi) * (yk - yi);
+            return a < b ? -1 : a > b ? 1 : 0;
-		// add current point and first point
-		this._digitizePoints.push({
-			pos: pos
-		this._digitizePoints.push(this._digitizePoints[0]);
+        var e1 = computeDirection(x3, y3, x4, y4, x1, y1);
+        var e2 = computeDirection(x3, y3, x4, y4, x2, y2);
+        var e3 = computeDirection(x1, y1, x2, y2, x3, y3);
+        var e4 = computeDirection(x1, y1, x2, y2, x4, y4);
+        return (((e1 > 0 && e2 < 0) || (e1 < 0 && e2 > 0)) &&
+                ((e3 > 0 && e4 < 0) || (e3 < 0 && e4 > 0))) ||
+            (e1 === 0 && isOnSegment(x3, y3, x4, y4, x1, y1)) ||
+            (e2 === 0 && isOnSegment(x3, y3, x4, y4, x2, y2)) ||
+            (e3 === 0 && isOnSegment(x1, y1, x2, y2, x3, y3)) ||
+            (e4 === 0 && isOnSegment(x1, y1, x2, y2, x4, y4));
+    _toRad: function (deg) {
+        return deg * Math.PI/180;
+    // calculate area
+    _calculateAreaMetric: function (pos) {
+        if (this._digitizePoints.length < 2) {
+            return null;
+        this._digitizePoints.push(pos);
+        var part, area = 0;
+        var p0 = this._digitizePoints[0].pos, pi, pj;
+        for (var i = 0; i < this._digitizePoints.length - 1; i++)  {
+            pi = this._digitizePoints[i].pos;
+            pj = this._digitizePoints[i + 1].pos;
+            part = (pi.y + pj.y) * (pi.x - pj.x) / 2;
+            area += part;
+        part = (pj.y + p0.y) * (pj.x - p0.x) / 2;
+        area += part;
+        this._digitizePoints.pop();
+        return Math.abs(area);
+    _calculateAreaGeographic: function (pos) {
+            return null;
+        // add current point and first point
+        this._digitizePoints.push({
+            pos: pos
+        this._digitizePoints.push(this._digitizePoints[0]);
         var area = 0.0;
         var p1, p2;
         for(var i=0; i<this._digitizePoints.length-1; i++) {
             p1 = this._digitizePoints[i].pos;
             p2 = this._digitizePoints[i+1].pos;
-			var c = this._toRad(p2.x - p1.x) *
-                    (2 + Math.sin(toRad(p1.y)) +
-                    Math.sin(toRad(p2.y)));
+            var c = this._toRad(p2.x - p1.x) *
+                (2 + Math.sin(toRad(p1.y)) +
+                 Math.sin(toRad(p2.y)));
             area += c;
         area = area * 6378137.0 * 6378137.0 / 2.0;
-		// remove current point and first point
+        // remove current point and first point
-	_calculateArea: function (pos) {
-		switch (this._map.getSrs()) {
-			case "EPSG:4326":
-				return this._calculateAreaGeographic(pos);
-			default:
-				return this._calculateAreaMetric(pos);
-		return null;
-	_isPointSnapped: function (p1, p2) {
-		return p1.dist(p2) <= this.options.digitizePointDiameter/2;
-	_isFirstPointSnapped: function (p) {
-		if (this._digitizePoints.length > 0 ) {
-			var pos0 = this._digitizePoints[0].mousePos;
-			if (this._digitizePoints.length > 2 && this._isPointSnapped(pos0, p)) {
-				return true;
-		return false;
-	_isLastPointSnapped: function (p) {
-			var posn = this._digitizePoints[this._digitizePoints.length - 1].mousePos;
-			if (this._digitizePoints.length > 1 && this._isPointSnapped(posn, p)) {
-				return true;
-		return false;
-	_draw: function (pos, drawOptions) {
-		this._canvas.clear();
+    _calculateArea: function (pos) {
+        switch (this._map.getSrs()) {
+            case "EPSG:4326":
+            return this._calculateAreaGeographic(pos);
+            default:
+            return this._calculateAreaMetric(pos);
+        return null;
+    _isPointSnapped: function (p1, p2) {
+        return p1.dist(p2) <= this.options.digitizePointDiameter/2;
+    _isFirstPointSnapped: function (p) {
+        if (this._digitizePoints.length > 0 ) {
+            var pos0 = this._digitizePoints[0].mousePos;
+            if (this._digitizePoints.length > 2 && this._isPointSnapped(pos0, p)) {
+                return true;
+        return false;
+    _isLastPointSnapped: function (p) {
+            var posn = this._digitizePoints[this._digitizePoints.length - 1].mousePos;
+            if (this._digitizePoints.length > 1 && this._isPointSnapped(posn, p)) {
+                return true;
+        return false;
+    _draw: function (pos, drawOptions) {
+        this._canvas.clear();
-		var str_path = "";
+        var str_path = "";
-		if (pos && drawOptions && !drawOptions.highlightFirst) {
+        if (pos && drawOptions && !drawOptions.highlightFirst) {
-		if (len > 0) {
-			for (var k=0; k < len; k++) {
-				var pk = this._digitizePoints[k].pos;
-				var q = this._digitizePoints[k].mousePos;
+        if (len > 0) {
+            for (var k=0; k < len; k++) {
+                var pk = this._digitizePoints[k].pos;
+                var q = this._digitizePoints[k].mousePos;
-				str_path += (k === 0) ? 'M' : 'L';
-				str_path += q.x + ' ' + q.y;
+                str_path += (k === 0) ? 'M' : 'L';
+                str_path += q.x + ' ' + q.y;
-				if (drawOptions.highlightFirst && k === len - 1) {
-					var p0 = this._digitizePoints[0].mousePos;
-					str_path += 'L' + p0.x + ' ' + p0.y;
+                if (drawOptions.highlightFirst && k === len - 1) {
+                    var p0 = this._digitizePoints[0].mousePos;
+                    str_path += 'L' + p0.x + ' ' + p0.y;
-				if (drawOptions && drawOptions.highlightLast && k === len - 1) {
-					continue;
+                if (drawOptions && drawOptions.highlightLast && k === len - 1) {
+                    continue;
-				if (drawOptions && drawOptions.drawPoints &&
-					(k === 0 && !this._polygonIsInvalid || k >= len - 2 && !drawOptions.highlightFirst)) {
+                if (drawOptions && drawOptions.drawPoints &&
+                    (k === 0 && !this._polygonIsInvalid || k >= len - 2 && !drawOptions.highlightFirst)) {
-					var circle = this._canvas.circle(q.x, q.y, this.options.digitizePointDiameter);
+                    var circle = this._canvas.circle(q.x, q.y, this.options.digitizePointDiameter);
-					if (k === 0) {
-						circle.attr({
-							fill: drawOptions && drawOptions.highlightFirst ?
-								this.options.pointFillSnapped : this.options.pointFillDefault,
-                                                        "fill-opacity": this.options.opacity,
-							stroke: drawOptions.highlightFirst || drawOptions.highlightLast ?
-        this.options.pointStrokeSnapped: this.options.pointStrokeDefault,
-                                                        "stroke-width": this.options.pointStrokeWidthDefault
-					else {
-						circle.attr({
-							fill: drawOptions && drawOptions.highlightLast && k === len - 2 ?
+                    if (k === 0) {
+                        circle.attr({
+                            fill: drawOptions && drawOptions.highlightFirst ?
+                                this.options.pointFillSnapped : this.options.pointFillDefault,
+                            "fill-opacity": this.options.opacity,
+                            stroke: drawOptions.highlightFirst || drawOptions.highlightLast ?
+                                this.options.pointStrokeSnapped: this.options.pointStrokeDefault,
+                            "stroke-width": this.options.pointStrokeWidthDefault
+                    else {
+                        circle.attr({
+                            fill: drawOptions && drawOptions.highlightLast && k === len - 2 ?
-		if (this._isPolygon(this._digitizePoints, pos) && drawOptions && !drawOptions.highlightLast && !this.polygonIsInvalid) {
-			var poly = this._canvas.path(str_path + 'Z');
-			poly.attr({
-				fill: drawOptions.highlightFirst ?
-					this.options.polygonFillSnapped : this.options.polygonFillDefault,
-					this.options.lineStrokeSnapped: this.options.lineStrokeDefault,
-				"stroke-width": drawOptions.highlightFirst ?
-					this.options.polygonStrokeWidthSnapped : this.options.polygonStrokeWidthDefault,
-				opacity: this.options.opacity
+        if (this._isPolygon(this._digitizePoints, pos) && drawOptions && !drawOptions.highlightLast && !this.polygonIsInvalid) {
+            var poly = this._canvas.path(str_path + 'Z');
+            poly.attr({
+                fill: drawOptions.highlightFirst ?
+                    this.options.polygonFillSnapped : this.options.polygonFillDefault,
+                    this.options.lineStrokeSnapped: this.options.lineStrokeDefault,
+                "stroke-width": drawOptions.highlightFirst ?
+                    this.options.polygonStrokeWidthSnapped : this.options.polygonStrokeWidthDefault,
+                opacity: this.options.opacity
-		var line = this._canvas.path(str_path);
-		line.attr({
-			stroke: drawOptions && (drawOptions.highlightFirst || drawOptions.highlightLast) ?
-				this.options.lineStrokeSnapped : this.options.lineStrokeDefault,
-			"stroke-width": drawOptions && drawOptions.highlightLast ?
-				this.options.lineStrokeWidthSnapped : this.options.lineStrokeWidthDefault
-		line.toFront();
-	_digitize: function (e) {
-		var mousePos = this._map.getMousePosition(e);
-		var firstPointSnapped = this._isFirstPointSnapped(mousePos)
-			&& !this._polygonIsInvalid;
-		var lastPointSnapped = this._isLastPointSnapped(mousePos);
+        var line = this._canvas.path(str_path);
+        line.attr({
+            stroke: drawOptions && (drawOptions.highlightFirst || drawOptions.highlightLast) ?
+                this.options.lineStrokeSnapped : this.options.lineStrokeDefault,
+            "stroke-width": drawOptions && drawOptions.highlightLast ?
+                this.options.lineStrokeWidthSnapped : this.options.lineStrokeWidthDefault
+        line.toFront();
+    _digitize: function (e) {
+        var mousePos = this._map.getMousePosition(e);
+        var firstPointSnapped = this._isFirstPointSnapped(mousePos)
+                             && !this._polygonIsInvalid;
+        var lastPointSnapped = this._isLastPointSnapped(mousePos);
-		var digitizeData = {
-			pos: {
-				mousePos: mousePos,
-				pos: firstPointSnapped ?
-					this._digitizePoints[0].pos : lastPointSnapped ?
-						this._digitizePoints[this._digitizePoints.length - 1].pos :
-						this._map.convertPixelToReal(mousePos)
+        var digitizeData = {
+            pos: {
+                mousePos: mousePos,
+                pos: firstPointSnapped ?
+                    this._digitizePoints[0].pos : lastPointSnapped ?
+                    this._digitizePoints[this._digitizePoints.length - 1].pos :
+                    this._map.convertPixelToReal(mousePos)
-		this._trigger("update", null, digitizeData);
+        this._trigger("update", null, digitizeData);
-		this._draw(digitizeData.pos, {
-			highlightFirst: firstPointSnapped,
-			highlightLast: lastPointSnapped,
-			drawPoints: true
-	_reinitialize: function (e) {
-		this.element
-			.unbind("click", $.proxy(this, "_reinitialize"))
-		this._trigger("reinitialize", e);
-		return false;
-	_addLastPoint: function (e) {
-		this._trigger("lastpointadded", e);
+        this._draw(digitizeData.pos, {
+            highlightFirst: firstPointSnapped,
+            highlightLast: lastPointSnapped,
+            drawPoints: true
+    _reinitialize: function (e) {
+        this.element
+            .unbind("click", $.proxy(this, "_reinitialize"))
+        this._trigger("reinitialize", e);
+        return false;
+    _addLastPoint: function (e) {
+        this._trigger("lastpointadded", e);
-		this.element.unbind("click", this._addPoint)
-			.unbind("mousemove", this._digitize)
-			.css("cursor", "auto")
-			.bind("click", $.proxy(this, "_reinitialize"));
-	_addPoint: function (e) {
+        this.element.unbind("click", this._addPoint)
+            .unbind("mousemove", this._digitize)
+            .css("cursor", "auto")
+            .bind("click", $.proxy(this, "_reinitialize"));
+    _addPoint: function (e) {
-		var data = {
-			pos: {
-				pos: this._map.convertPixelToReal(mousePos)
+        var data = {
+            pos: {
+                pos: this._map.convertPixelToReal(mousePos)
-		this._trigger("pointadded", e, data);
+        this._trigger("pointadded", e, data);
-		var firstPointSnapped = this._isFirstPointSnapped(mousePos);
+        var firstPointSnapped = this._isFirstPointSnapped(mousePos);
-		this._isPolygon(this._digitizePoints, data.pos);
-		if (this._currentPolygonIsInvalid) {
-			this._polygonIsInvalid = true;
+        this._isPolygon(this._digitizePoints, data.pos);
+        if (this._currentPolygonIsInvalid) {
+            this._polygonIsInvalid = true;
-		if (lastPointSnapped || firstPointSnapped) {
-			this._draw(data.pos, {
-				drawPoints: false
-			this._digitizePoints.closedPolygon = firstPointSnapped;
-			this._digitizePoints.closedLine = lastPointSnapped;
-			this._addLastPoint(e);
-		else {
-			this._digitizePoints.push(data.pos);
+        if (lastPointSnapped || firstPointSnapped) {
+            this._draw(data.pos, {
+                drawPoints: false
+            this._digitizePoints.closedPolygon = firstPointSnapped;
+            this._digitizePoints.closedLine = lastPointSnapped;
+            this._addLastPoint(e);
+        else {
+            this._digitizePoints.push(data.pos);
-			lastPointSnapped = this._isLastPointSnapped(mousePos);
-				drawPoints: true
-		return true;
-	_redraw: function () {
-		if (!$(this.element).data("mb_digitize")) {
-			return;
-		if (len === 0) {
-			return;
-		for (var i = 0; i < len; i++) {
-			var p = this._digitizePoints[i];
-			p.mousePos = this._map.convertRealToPixel(p.pos);
-		if (this._digitizePoints.closedPolygon) {
-			this._draw(undefined, {
-				highlightFirst: true,
-				highlightLast: false,
-				drawPoints: false
-		else if (this._digitizePoints.closedLine) {
-				highlightFirst: false,
-				highlightLast: true,
-				drawPoints: false
-		else {
-				drawPoints: false
-	_init: function () {
-		if (this._digitizePoints.closedLine || this._digitizePoints.closedPolygon) {
-			this._digitizePoints = [];
-		this.element
-			.bind("click", $.proxy(this, "_addPoint"))
-			.bind("mousemove", $.proxy(this, "_digitize"))
-			.css("cursor", "crosshair");
+            lastPointSnapped = this._isLastPointSnapped(mousePos);
+                drawPoints: true
+        return true;
+    _redraw: function () {
+        if (!$(this.element).data("mb_digitize")) {
+            return;
+        if (len === 0) {
+            return;
+        for (var i = 0; i < len; i++) {
+            var p = this._digitizePoints[i];
+            p.mousePos = this._map.convertRealToPixel(p.pos);
+        if (this._digitizePoints.closedPolygon) {
+            this._draw(undefined, {
+                highlightFirst: true,
+                highlightLast: false,
+                drawPoints: false
+        else if (this._digitizePoints.closedLine) {
+                highlightFirst: false,
+                highlightLast: true,
+                drawPoints: false
+        else {
+                drawPoints: false
+    _init: function () {
+        if (this._digitizePoints.closedLine || this._digitizePoints.closedPolygon) {
+            this._digitizePoints = [];
+        this.element
+            .bind("click", $.proxy(this, "_addPoint"))
+            .bind("mousemove", $.proxy(this, "_digitize"))
+            .css("cursor", "crosshair");
-	_create: function () {
+    _create: function () {
-		// ":maps" is a Mapbender selector which
-		// checks if an element is a Mapbender map
-		this.element = this.element.filter(":maps");
+        // ":maps" is a Mapbender selector which
+        // checks if an element is a Mapbender map
+        this.element = this.element.filter(":maps");
-		if (!this.element.jquery || this.element.size() === 0) {
-			$.error("This widget must be applied to a Mapbender map.");
+        if (!this.element.jquery || this.element.size() === 0) {
+            $.error("This widget must be applied to a Mapbender map.");
-		this._map = this.element.mapbender();
-		this._map.events.afterMapRequest.register($.proxy(this._redraw, this));
-		this._srs = this._map.getSrs();
+        this._map = this.element.mapbender();
+        this._map.events.afterMapRequest.register($.proxy(this._redraw, this));
+        this._srs = this._map.getSrs();
-		this._$canvas = $("<div id='digitize_canvas' />").css({
-			"z-index": 1000,
-			"position": "absolute"
-		}).appendTo(this.element);
-		this._canvas = Raphael(this._$canvas.get(0), this._map.getWidth(), this._map.getHeight());
-		mb_registerPanSubElement($(this._canvas.canvas).parent().get(0));
-	// the digitized geometry will be available, the events will be deleted
-	deactivate: function () {
-		this.element
-			.unbind("click", this._addPoint)
-			.unbind("click", this._reinitialize)
-			.css("cursor", "default");
-	// delete everything
-	destroy: function () {
-		this.deactivate();
-		this._$canvas.remove();
-		this._map.events.afterMapRequest.unregister($.proxy(this._redraw, this));
+        this._$canvas = $("<div id='digitize_canvas' />").css({
+            "z-index": 1000,
+            "position": "absolute"
+        }).appendTo(this.element);
+        this._canvas = Raphael(this._$canvas.get(0), this._map.getWidth(), this._map.getHeight());
+        mb_registerPanSubElement($(this._canvas.canvas).parent().get(0));
+    // the digitized geometry will be available, the events will be deleted
+    deactivate: function () {
+        this.element
+            .unbind("click", this._addPoint)
+            .unbind("click", this._reinitialize)
+            .css("cursor", "default");
+    // delete everything
+    destroy: function () {
+        this.deactivate();
+        this._$canvas.remove();
+        this._map.events.afterMapRequest.unregister($.proxy(this._redraw, this));
-		$.Widget.prototype.destroy.apply(this, arguments); // default destroy
-		$(this.element).data("mb_digitize", null);
+        $.Widget.prototype.destroy.apply(this, arguments); // default destroy
+        $(this.element).data("mb_digitize", null);
Modified: trunk/mapbender/lib/mb.ui.displayKmlFeatures.js
--- trunk/mapbender/lib/mb.ui.displayKmlFeatures.js	2014-05-07 08:51:46 UTC (rev 8820)
+++ trunk/mapbender/lib/mb.ui.displayKmlFeatures.js	2014-05-07 11:06:01 UTC (rev 8821)
@@ -3,196 +3,197 @@
 // 	georss:error	- a georssfeed failed to load: function(url,error);
 var originalI18nObject = {
-	"labelLoadError" : "Could not load Document",
-	"labelName":"Name",
-	"labelUntitled":"Untitled",
-	"labelUrlBox": "Paste URL here",
-	"sProcessing":   "Processing...",
-	"sLengthMenu":   "Show _MENU_ entries",
-	"sZeroRecords":  "No matching records found",
-	"sInfo":         "SLowing _START_ to _END_ of _TOTAL_ entries",
-	"sInfoEmpty":    "Showing 0 to 0 of 0 entries",
-	"sInfoFiltered": "(filtered from _MAX_ total entries)",
-	"sInfoPostFix":  "",
-	"sSearch":       "Search:",
-	"sUrl":          "",
-	"oPaginate": {
-		"sFirst":    "First",
-		"sPrevious": "Previous",
-		"sNext":     "Next",
-		"sLast":     "Last"
+    "labelLoadError" : "Could not load Document",
+    "labelName":"Name",
+    "labelUntitled":"Untitled",
+    "labelUrlBox": "Paste URL here",
+    "sProcessing":   "Processing...",
+    "sLengthMenu":   "Show _MENU_ entries",
+    "sZeroRecords":  "No matching records found",
+    "sInfo":         "SLowing _START_ to _END_ of _TOTAL_ entries",
+    "sInfoEmpty":    "Showing 0 to 0 of 0 entries",
+    "sInfoFiltered": "(filtered from _MAX_ total entries)",
+    "sInfoPostFix":  "",
+    "sSearch":       "Search:",
+    "sUrl":          "",
+    "oPaginate": {
+        "sFirst":    "First",
+        "sPrevious": "Previous",
+        "sNext":     "Next",
+        "sLast":     "Last"
 var translatedI18nObject = Mapbender.cloneObject(originalI18nObject);
 //var translatedI18nObject = originalI18nObject;
 var displayFeatures = {
-	options: {
-		url: "",
-		position: 'right',
-		autoOpen: true,
-		autoDisplay: true
-	_kmls: {},
+    options: {
+        url: "",
+        position: 'right',
+        autoOpen: true,
+        autoDisplay: true
+    _kmls: {},
     kmlOrder: [],
-	_popup : null,
-	_create: function(){
-		var self = this, o = this.options;
-		this.element.bind('click', function(e){
-			var map = self.element.mapbender();
-			var pos = map.getMousePosition(e);
-			var clickPoint =  map.convertPixelToReal(new Point(pos.x,pos.y));
-			var feed = null;
-			var requestGeometries = [];
-			// This uses two methods to determine wether a clickposition is on a geometry
-			// - Points are represented as icons, so we check if the click is on an icon
-			// - Polygons don't have a dom Element when not using Rapheljs, so we go ask postgis
-			// after that's finished the results are merged and displayed in a box
-			var pointGeometries = {};
-			var g,h,nodes = null;
-			$("*",self._popup).remove();
-			var $tabs = $("<ul></ul>");
-			for (var i in self.kmlOrder){
-				feed = self._kmls[self.kmlOrder[i]] ;
-				if(!feed.display){ continue; }
-				requestGeometries = [];
+    _popup : null,
+    _create: function(){
+        var self = this, o = this.options;
+        this.element.bind('click', function(e){
+            var map = self.element.mapbender();
+            var pos = map.getMousePosition(e);
+            var clickPoint =  map.convertPixelToReal(new Point(pos.x,pos.y));
+            var feed = null;
+            var requestGeometries = [];
+            // This uses two methods to determine wether a clickposition is on a geometry
+            // - Points are represented as icons, so we check if the click is on an icon
+            // - Polygons don't have a dom Element when not using Rapheljs, so we go ask postgis
+            // after that's finished the results are merged and displayed in a box
+            var pointGeometries = {};
+            var g,h,nodes = null;
+            $("*",self._popup).remove();
+            var $tabs = $("<ul></ul>");
+            for (var i in self.kmlOrder){
+                feed = self._kmls[self.kmlOrder[i]] ;
+                if(!feed.display){ continue; }
+                requestGeometries = [];
-				for(var j = 0; j < feed.geomArray.count(); j++){
-					g = feed.geomArray.get(j);
-					h = feed.highlightArray[j];
-					nodes = h.getNodes();
-					if(g.geomType == geomType.point){
-						// we only add one point per highlight so we can assume there's only one node
-						if(!nodes[0]){ continue;}
-						var rect = nodes[0].getBoundingClientRect();
-						if(e.clientX >= rect.left && e.clientX <= rect.right &&
-						   e.clientY >= rect.top  && e.clientY <= rect.bottom){
-							// we just need the keys to exist
-							// theywill be merged with the ones coming from the
-							// server
-							pointGeometries[j] = true;
+                for(var j = 0; j < feed.geomArray.count(); j++){
+                    g = feed.geomArray.get(j);
+                    h = feed.highlightArray[j];
+                    nodes = h.getNodes();
+                    if(g.geomType == geomType.point){
+                        // we only add one point per highlight so we can assume there's only one node
+                        if(!nodes[0]){ continue;}
+                        var rect = nodes[0].getBoundingClientRect();
+                        if(e.clientX >= rect.left && e.clientX <= rect.right &&
+                           e.clientY >= rect.top  && e.clientY <= rect.bottom){
+                            // we just need the keys to exist
+                            // theywill be merged with the ones coming from the
+                            // server
+                            pointGeometries[j] = true;
-					}else{
-						requestGeometries.push(g.toText());
-				var req = new Mapbender.Ajax.Request({
-				url: "../php/intersection.php",
-				method: "intersect",
-				parameters: {
-					clickPoint:	clickPoint.toText(),
-					geometries: requestGeometries
-				callback: (function(geomArray,pointGeometries){ return function(result, success, message){
-					if(!success){
-						return;
-					// this is basically an onclick handler, !intersects means
-					// the click didn't happen on the polygon
-					$.extend(result.geometries,pointGeometries);
-					if(!result.geometries || result.geometries.length <1){
-						return;
+                    }else{
+                        requestGeometries.push(g.toText());
+                var req = new Mapbender.Ajax.Request({
+                    url: "../php/intersection.php",
+                    method: "intersect",
+                    parameters: {
+                        clickPoint:	clickPoint.toText(),
+                        geometries: requestGeometries
+                    callback: (function(geomArray,pointGeometries){ return function(result, success, message){
+        if(!success){
+        return;
+        // this is basically an onclick handler, !intersects means
+        // the click didn't happen on the polygon
+        $.extend(result.geometries,pointGeometries);
+        if(!result.geometries || result.geometries.length <1){
+        return;
-					// this iterates over an object where the keys are _not_ the incremential
-					// basically a sparse array. therefore It cannot be used to count the entries in the object
-					// this is why j is used
-					for(i in result.geometries){
-						var g = geomArray.get(i);
-						title = g.e.getElementValueByName("title");
-						name  = g.e.getElementValueByName("name");
-						if(typeof(name) == "string"){
-							title = name != "false" ? name : title;
-							if (icon == "false"){
-								g.e.setElement("Mapbender:icon","../img/marker/red.png");
-						}else{
-							//sane browsers go here
-							title = name != false ? name : title;
-							if (icon === false){
-						description = g.e.getElementValueByName("description");
-						$tabs.append('<li><a href="#rsspopup_'+ i +'">'+ title + '</a></li>');
-						self._popup.append('<div id="rsspopup_'+ i +'"><h1>'+ title +'</h1><p>'+ description +'</p></h1>');
+        // this iterates over an object where the keys are _not_ the incremential
+        // basically a sparse array. therefore It cannot be used to count the entries in the object
+        // this is why j is used
+        for(i in result.geometries){
+        var g = geomArray.get(i);
+        title = g.e.getElementValueByName("title");
+        name  = g.e.getElementValueByName("name");
+        if(typeof(name) == "string"){
+        title = name != "false" ? name : title;
+        if (icon == "false"){
+        g.e.setElement("Mapbender:icon","../img/marker/red.png");
+        }else{
+        //sane browsers go here
+        title = name != false ? name : title;
+        if (icon === false){
+        description = g.e.getElementValueByName("description");
+        $tabs.append('<li><a href="#rsspopup_'+ i +'">'+ title + '</a></li>');
+        self._popup.append('<div id="rsspopup_'+ i +'"><h1>'+ title +'</h1><p>'+ description +'</p></h1>');
-						if($tabs.children().size() > 1){
-						self._popup.dialog('open');
+        if($tabs.children().size() > 1){
+        self._popup.dialog('open');
-						var $tabcontainer = $("<div><div>");
-						$tabcontainer.append($tabs);
-						$tabcontainer.append($('div',self._popup));
-						$tabs.css("display","none");
-						self._popup.append($tabcontainer);
-						$tabcontainer.tabs();
-						// -1 because we need it zero based later
-						var tabcount = $tabcontainer.find(".ui-tabs-panel").size() -1;
-						$tabcontainer.find(".ui-tabs-panel").each(function(i){
+        var $tabcontainer = $("<div><div>");
+        $tabcontainer.append($tabs);
+        $tabcontainer.append($('div',self._popup));
+        $tabs.css("display","none");
+        self._popup.append($tabcontainer);
+        $tabcontainer.tabs();
+        // -1 because we need it zero based later
+        var tabcount = $tabcontainer.find(".ui-tabs-panel").size() -1;
+        $tabcontainer.find(".ui-tabs-panel").each(function(i){
-							var  $navbar = $("<div></div>");
-							$(this).append($navbar);
-							// add to first panel
-							if(i == 0 ){
-								var next = i+1;
-								$navbar.append('<a style="float:right;" href="#" class="next-tab" rel="'+next+'">mehr</a>');
-							// add to all except the first panel
-							if(i > 0 ){
-								var prev = i-1;
-								$navbar.append('<a href="#" class="prev-tab" rel="'+prev+'">zurück</a>');
-							// add to all except first and last panel
-							if( tabcount  > i && i > 0  ){
-								var next = i+1;
-								$navbar.append('<a style="float:right;" href="#" class="next-tab" rel="'+next+'">vor</a>');
-						$tabcontainer.find(".next-tab, .prev-tab").click(function(){
-							$tabcontainer.tabs("select",$(this).attr("rel"));
-							return false;
-				};})(feed.geomArray, pointGeometries)
-				req.send();
-				pointGeometries = {};
-		self.element.bind('kml:loaded',function(event,obj){
-			if(o.autoOpen){
-				self._display(obj);
-		self.element.bind('kml:error',function(event,message){
-			alert(message);
+        var  $navbar = $("<div></div>");
+        $(this).append($navbar);
+        // add to first panel
+        if(i == 0 ){
+        var next = i+1;
+        $navbar.append('<a style="float:right;" href="#" class="next-tab" rel="'+next+'">mehr</a>');
+        // add to all except the first panel
+        if(i > 0 ){
+        var prev = i-1;
+        $navbar.append('<a href="#" class="prev-tab" rel="'+prev+'">zurück</a>');
+        // add to all except first and last panel
+        if( tabcount  > i && i > 0  ){
+        var next = i+1;
+        $navbar.append('<a style="float:right;" href="#" class="next-tab" rel="'+next+'">vor</a>');
+        $tabcontainer.find(".next-tab, .prev-tab").click(function(){
+        $tabcontainer.tabs("select",$(this).attr("rel"));
+        return false;
+        };})(feed.geomArray, pointGeometries)
+                req.send();
+                pointGeometries = {};
+        self.element.bind('kml:loaded',function(event,obj){
+            if(o.autoOpen){
+                self._display(obj);
+        self.element.bind('kml:error',function(event,message){
+            alert(message);
-	_init: function(){
-		this._popup = $('<div></div>').dialog({autoOpen : false, height: 500, width: 500});
-		if(o.url){
-			self._load(o.url);
+    _init: function(){
+        this._popup = $('<div></div>').dialog({autoOpen : false, height: 500, width: 500});
+        if(o.url){
+            self._load(o.url);
     addGeometry: function(pts) {
         var $map = $(this.element).mapbender();
         var self = this;
         var tp = pts.closedPolygon ? geomType.polygon : (pts.closedLine ? geomType.line : geomType.point);
         var itm;
-        // todo select the one that's marked for editing
         $.each(this._kmls, function(k, v) {
-            itm = v;
+            if($('li[title="' + k + '"] > button[name="digitize-layer"]').hasClass('active')) {
+                itm = v;
         for(var i in itm.highlightArray){
@@ -231,146 +232,146 @@
         this.element.trigger('kml:loaded',{type:"geojson",data:itm.data,url:itm.url,display: itm.display, refreshing: true});
-	_load : function(url){
-		var epsg = $(self.element).mapbender().epsg;
-		epsg = epsg.split(":")[1];
-		if(self._kmls[o.url]){
-			//not adding feed twice
-			return;
-            $.ajax({url: '../php/getOriginalKml.php',
-                    data: {url: o.url},
-                    type: 'POST',
-                    dataType: 'text/plain',
-                    success: function(data) {
-                        if(!self.originalKmls) {
-                            self.originalKmls = {};
-                        self.originalKmls[o.url] = data;
-                        self.kmlOrder.push(o.url);
+    _load : function(url){
+        var epsg = $(self.element).mapbender().epsg;
+        epsg = epsg.split(":")[1];
+        if(self._kmls[o.url]){
+            //not adding feed twice
+            return;
+        $.ajax({url: '../php/getOriginalKml.php',
+                data: {url: o.url},
+                type: 'POST',
+                dataType: 'text/plain',
+                success: function(data) {
+                    if(!self.originalKmls) {
+                        self.originalKmls = {};
+                    self.originalKmls[o.url] = data;
+                    self.kmlOrder.push(o.url);
-		$.ajax({ url: '../php/kmlToGeoJSON.php',
-			data: {url: o.url, targetEPSG: epsg},
-			type: 'POST',
-			dataType: "json",
-			success : function(data,textStatus,xhr){
-				if(!data){
-					self.element.trigger('kml:error',"request returned no data");
-				else if(data.errorMessage){
-					self.element.trigger('kml:error',data.errorMessage);
-				}else{
-					self._kmls[o.url] = {type:"geojson",data:data,url:o.url,display: o.autoDisplay};
-					self.element.trigger('kml:loaded',{type:"geojson",data:data,url:o.url,display: o.autoDisplay});
-			error: function(XMLHttpRequest, textStatus, errorThrown){
-				self.element.trigger('kml:error',"Problem talking to server: " + errorThrown);
-            var kmls = mb_getWmcExtensionData('KMLS');
+        $.ajax({ url: '../php/kmlToGeoJSON.php',
+                 data: {url: o.url, targetEPSG: epsg},
+                 type: 'POST',
+                 dataType: "json",
+                 success : function(data,textStatus,xhr){
+                     if(!data){
+                         self.element.trigger('kml:error',"request returned no data");
+                     else if(data.errorMessage){
+                         self.element.trigger('kml:error',data.errorMessage);
+                     }else{
+                         self._kmls[o.url] = {type:"geojson",data:data,url:o.url,display: o.autoDisplay};
+                         self.element.trigger('kml:loaded',{type:"geojson",data:data,url:o.url,display: o.autoDisplay});
+                 error: function(XMLHttpRequest, textStatus, errorThrown){
+                     self.element.trigger('kml:error',"Problem talking to server: " + errorThrown);
+        var kmls = mb_getWmcExtensionData('KMLS');
         // try{
-            if(kmls) {
-                kmls = JSON.parse(kmls);
-                this._kmls = kmls;
-                for(var k in kmls) {
-                    kmls[k].loadedOnStartup = true;
+        if(kmls) {
+            kmls = JSON.parse(kmls);
+            this._kmls = kmls;
+            for(var k in kmls) {
+                kmls[k].loadedOnStartup = true;
                 self._convertFromJson(kmls[k]);
-                    self.element.trigger('kml:loaded',kmls[k]);
+                self.element.trigger('kml:loaded',kmls[k]);
-            kmls = mb_getWmcExtensionData('ORIGINALKMLS');
-            if(kmls) {
-                this.originalKmls = kmls;
-            kmls = mb_getWmcExtensionData('KMLORDER');
-            if(kmls) {
-                this.kmlOrder = JSON.parse(kmls);
+        kmls = mb_getWmcExtensionData('ORIGINALKMLS');
+        if(kmls) {
+            this.originalKmls = kmls;
+        kmls = mb_getWmcExtensionData('KMLORDER');
+        if(kmls) {
+            this.kmlOrder = JSON.parse(kmls);
         // }catch(e){
         //     console.log(e)
-                    reload: function() {
+    reload: function() {
-                        $.each(self.kmlOrder, function(k, url) {
-                            var o = self._kmls[url];
-                            if(!o) return;
-                            $('li[title="' + url + '"] > button[name="remove"]').click();
-		            $.ajax({ url: self._endpointURL + '?targetEPSG= ' + epsg,
-			             data: self.originalKmls[url],
-			             type: 'POST',
-			             dataType: "json",
-				         if(!data){
-				         }else{
-					     self._kmls[o.url] = {type:"geojson",data:data,url:o.url,display: o.display, loadedOnStartup: true};
-				             self.element.trigger('kml:loaded',{type:"geojson",data:data,url:o.url,display: o.display});
+        $.each(self.kmlOrder, function(k, url) {
+            var o = self._kmls[url];
+            if(!o) return;
+            $('li[title="' + url + '"] > button[name="remove"]').click();
+            $.ajax({ url: self._endpointURL + '?targetEPSG= ' + epsg,
+                     data: self.originalKmls[url],
+                     type: 'POST',
+                     dataType: "json",
+                         if(!data){
+                         }else{
+                             self._kmls[o.url] = {type:"geojson",data:data,url:o.url,display: o.display, loadedOnStartup: true};
+                             self.element.trigger('kml:loaded',{type:"geojson",data:data,url:o.url,display: o.display});
     setOrder: function(order) {
         this.kmlOrder = order;
         this.reload();
-	show : function(url){
-		this._kmls[url].display = true;
-		var $map = $(this.element).mapbender();
-		var extent = $map.getExtentInfos();
-		$map.calculateExtent(extent);
-		$map.setMapRequest();
-		$(this.element).mapbender().setMapRequest();
+    show : function(url){
+        this._kmls[url].display = true;
+        var $map = $(this.element).mapbender();
+        var extent = $map.getExtentInfos();
+        $map.calculateExtent(extent);
+        $map.setMapRequest();
+        $(this.element).mapbender().setMapRequest();
-	hide : function(url){
-		this._kmls[url].display = false;
+    hide : function(url){
+        this._kmls[url].display = false;
-	remove: function(url){
-		// nrgh there are still references to the highlightobjects somewhere!
-		for(var i in this._kmls[url].highlightArray){
-			this._kmls[url].highlightArray[i].clean();
-		delete(this._kmls[url]);
+    remove: function(url){
+        // nrgh there are still references to the highlightobjects somewhere!
+        for(var i in this._kmls[url].highlightArray){
+            this._kmls[url].highlightArray[i].clean();
+        delete(this._kmls[url]);
     _convertFromJson: function(mapitem) {
-		var geojson = mapitem.data;
+        var geojson = mapitem.data;
         var self = this;
-			var $map = $(self.element).mapbender();
-			var markers = [];
-			var title = "";
-				// we always transform _from_ 4326 KML use this as their default
-				// var projSrc = new Proj4js.Proj('EPSG:4326');
-				// var projDest = new Proj4js.Proj($map.epsg);
-				var markeroptions = {width: "19px", height: "34px"};
-				var g = null;
+        var $map = $(self.element).mapbender();
+        var markers = [];
+        var title = "";
+        // we always transform _from_ 4326 KML use this as their default
+        // var projSrc = new Proj4js.Proj('EPSG:4326');
+        // var projDest = new Proj4js.Proj($map.epsg);
+        var markeroptions = {width: "19px", height: "34px"};
+        var g = null;
         for(var i in mapitem.highlightArray){
             var h = mapitem.highlightArray[i].hide;
@@ -378,68 +379,68 @@
-				mapitem.geomArray = new GeometryArray();
-				mapitem.highlightArray = [];
-				mapitem.geomArray.importGeoJSON(geojson);
-				//get bbox for array
-				var bbox = mapitem.geomArray.getBBox();
-				var bufferFloat = parseFloat(0.1);
-				for(var i =0; i < mapitem.geomArray.count(); i++){
-					var h = new Highlight([self.element.attr('id')], "mapframe1_" + parseInt(Math.random()*100000,10),{
-						"position":"absolute",
-						"top": "0px",
-						"left": "0px",
-						"z-index": "80" },1);
-					g = mapitem.geomArray.get(i);
-					icon = g.e.getElementValueByName("Mapbender:icon");
-					//title = g.e.getElementValueByName("title");
+        mapitem.geomArray = new GeometryArray();
+        mapitem.highlightArray = [];
+        mapitem.geomArray.importGeoJSON(geojson);
+        //get bbox for array
+        var bbox = mapitem.geomArray.getBBox();
+        var bufferFloat = parseFloat(0.1);
+        for(var i =0; i < mapitem.geomArray.count(); i++){
+            var h = new Highlight([self.element.attr('id')], "mapframe1_" + parseInt(Math.random()*100000,10),{
+                "position":"absolute",
+                "top": "0px",
+                "left": "0px",
+                "z-index": "80" },1);
+            g = mapitem.geomArray.get(i);
+            icon = g.e.getElementValueByName("Mapbender:icon");
+            //title = g.e.getElementValueByName("title");
-					if(name != "false" && name !== false){
-						title = name; // use for tooltip
-					if(icon == "false" || icon === false){
-						g.e.setElement("Mapbender:iconOffsetX", -10);
-						g.e.setElement("Mapbender:iconOffsetY", -34);
+            if(name != "false" && name !== false){
+                title = name; // use for tooltip
+            if(icon == "false" || icon === false){
+                g.e.setElement("Mapbender:iconOffsetX", -10);
+                g.e.setElement("Mapbender:iconOffsetY", -34);
-					h.add(g);
-					mapitem.highlightArray.push(h);
-					title = "";
-					name = "";
-				if(mapitem.display){
-					for(var j in mapitem.highlightArray){
-						mapitem.highlightArray[j].paint();
-				}else{
-						mapitem.highlightArray[j].hide();
-				self.element.mapbender().events.afterMapRequest.register(function () {
-						for(var i in mapitem.highlightArray){
-							mapitem.highlightArray[i].paint();
-					}else{
-							mapitem.highlightArray[i].hide();
-				// set new bbox for mapframe
-                            if(!mapitem.loadedOnStartup) {
+            h.add(g);
+            mapitem.highlightArray.push(h);
+            title = "";
+            name = "";
+        if(mapitem.display){
+            for(var j in mapitem.highlightArray){
+                mapitem.highlightArray[j].paint();
+        }else{
+                mapitem.highlightArray[j].hide();
+        self.element.mapbender().events.afterMapRequest.register(function () {
+                for(var i in mapitem.highlightArray){
+                    mapitem.highlightArray[i].paint();
+            }else{
+                    mapitem.highlightArray[i].hide();
+        // set new bbox for mapframe
+        if(!mapitem.loadedOnStartup) {
     _display : function(mapitem){
@@ -448,32 +449,32 @@
         mapitem = self._kmls[mapitem.url];
         if(typeof(Mapbender) != "undefined"){
             this._convertFromJson(mapitem);
 var displayKML = $.extend({},displayFeatures, {
-	_endpointURL: "../php/kml2transformedgeojson.php",
-	_eventNamespace : "kml"
+    _endpointURL: "../php/kml2transformedgeojson.php",
+    _eventNamespace : "kml"
 $.widget('ui.kml',displayKML);
 var displayGeoJSON = $.extend({},displayFeatures,{
-	_endpointURL: "",
-	_load: function(){
-		$.ajax({ url: o.url,
-			type: "GET",
-			dataType: "json",
-				self._display(data);
+    _endpointURL: "",
+    _load: function(){
+        $.ajax({ url: o.url,
+                 type: "GET",
+                 dataType: "json",
+                     self._display(data);
 $.widget('ui.geojson',displayKML);
More information about the Mapbender_commits mailing list
