[Mapbender-commits] r8835 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon May 12 00:41:02 PDT 2014
Author: hwbllmnn
Date: 2014-05-12 00:41:02 -0700 (Mon, 12 May 2014)
New Revision: 8835
   trunk/mapbender/http/plugins/mb_digitize_widget.php
reorganized kml digitizer a bit, connected various dialogs
Modified: trunk/mapbender/http/plugins/mb_digitize_widget.php
--- trunk/mapbender/http/plugins/mb_digitize_widget.php	2014-05-08 14:52:35 UTC (rev 8834)
+++ trunk/mapbender/http/plugins/mb_digitize_widget.php	2014-05-12 07:41:02 UTC (rev 8835)
@@ -113,7 +113,7 @@
         '</ul>';
     var geomMenu = '<ul class="digitize-contextmenu">' +
-        '<li><div class="digitize-image digitize-pencil"></div><span class="margin-left: 30px;">Edit</span></li>' +
+        '<li><div class="digitize-image digitize-pencil"></div>Edit</li>' +
         '<li><div class="digitize-image digitize-zoomto"></div>Zoom to</li>' +
         '<li><div class="digitize-image digitize-add"></div>New</li>' +
         '<li><div class="digitize-image digitize-export"></div>Export</li>' +
@@ -131,17 +131,18 @@
         '</ul>';
     var digitizeDialog,
+        editDialog,
+        attributesDialog,
         button,
         that = this,
         inProgress = false,
-        title = o.title,
-        defaultHtml = digitizeHtml;
+        title = o.title;
-    var create = function () {
+    var create = function() {
         // Initialise digitize dialog
-        digitizeDialog = $(defaultHtml);
+        digitizeDialog = $(digitizeHtml);
         digitizeDialog.dialog({
             autoOpen: false,
             position: [o.$target.offset().left, o.$target.offset().top]
@@ -149,6 +150,22 @@
             button.stop();
             that.destroy();
+        editDialog = $(editHtml);
+        editDialog.dialog({
+            autoOpen: false,
+            position: [o.$target.offset().left, o.$target.offset().top]
+        }).bind("dialogclose", function () {
+            button.stop();
+            that.destroy();
+        attributesDialog = $(editAttributesHtml);
+        attributesDialog.dialog({
+            autoOpen: false,
+            button.stop();
+            that.destroy();
         // Initialise button
@@ -169,58 +186,73 @@
         $('#mapframe1').bind('kml:loaded', function(evt, item) {
             var url = item.url;
-            $('li[title="' + url + '"] > a').live('contextmenu', function() {
-                var $link = $(this);
-                var menu = $(folderMenu);
-                $(document.body).append(menu);
-                var pos = $link.offset();
-                menu.css({position: 'absolute', top: pos.top, left: pos.left}).menu()
-                    .children().addClass('ui-menu-item')
-                    .hover(function() {$(this).addClass('ui-state-hover'); },
-                          function() {$(this).removeClass('ui-state-hover'); });
-                menu.children('li:has(.digitize-zoomto)').bind('click', function() {
-                    $link.click();
-                    menu.menu('destroy').remove();
-                menu.children('li:has(.digitize-remove)').bind('click', function() {
-                    $('#mapframe1').data('kml').remove(item.url);
-                    $link.parent().remove();
-                return false;
-            $('li[title="' + url + '"] > ul > li').live('contextmenu', function() {
-                var menu = $(geomMenu);
-                    $link.click();
-                    var kml = $('#mapframe1').data('kml');
-                    var url = $link.parent().parent().attr('title');
-                    var ids = [];
-                    var i = 0;
-                    $.each($link.siblings(), function(k, v) {
-                        ids.push($(v).attr('idx'));
-                        $(v).attr('idx', i++);
-                    $link.remove();
-                    kml.reorderFeatures(url, ids);
+            $('li[title="' + url + '"] > a').live('contextmenu', contextmenuLayer);
+            $('li[title="' + url + '"] > ul > li').live('contextmenu', contextmenuObject);
-                return false;
+    var contextmenuObject = function() {
+        var $link = $(this);
+        var menu = $(geomMenu);
+        $(document.body).append(menu);
+        var pos = $link.offset();
+        menu.css({position: 'absolute', top: pos.top, left: pos.left}).menu()
+            .children().addClass('ui-menu-item')
+            .hover(function() {$(this).addClass('ui-state-hover'); },
+                   function() {$(this).removeClass('ui-state-hover'); });
+        menu.children('li:has(.digitize-zoomto)').bind('click', function() {
+            $link.click();
+            menu.menu('destroy').remove();
+        menu.children('li:has(.digitize-pencil)').bind('click', function() {
+            editDialog.dialog('open');
+            editDialog.find('.digitize-attributes').bind('click', function() {
+                attributesDialog.dialog('open');
+        menu.children('li:has(.digitize-remove)').bind('click', function() {
+            var kml = $('#mapframe1').data('kml');
+            var url = $link.parent().parent().attr('title');
+            var ids = [];
+            var i = 0;
+            $.each($link.siblings(), function(k, v) {
+                ids.push($(v).attr('idx'));
+                $(v).attr('idx', i++);
+            $link.remove();
+            kml.reorderFeatures(url, ids);
+        return false;
+    var contextmenuLayer = function() {
+        var menu = $(folderMenu);
+            $link.click();
+            $('#mapframe1').data('kml').remove(item.url);
+            $link.parent().remove();
+        menu.children('li:has(.digitize-add)').bind('click', function() {
+            digitizeDialog.dialog('open');
+        return false;
     var finishDigitize = function () {
         inProgress = false;
         that.deactivate();
@@ -253,7 +285,6 @@
         if (!inProgress) {
             inProgress = true;
-            digitizeDialog.html(defaultHtml);
         digitizeDialog.dialog("open");
@@ -269,7 +300,6 @@
         if (digitizeDialog.dialog("isOpen")) {
             digitizeDialog.dialog("close");
                 //remove digitized x and y values from print dialog
                 $('input[name="digitized_x_values"]').val("");
More information about the Mapbender_commits mailing list
