[Mapbender-commits] r8836 - in trunk/mapbender/http: classes javascripts php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon May 12 01:36:17 PDT 2014
Author: armin11
Date: 2014-05-12 01:36:17 -0700 (Mon, 12 May 2014)
New Revision: 8836
   trunk/mapbender/http/classes/class_metadata_new.php
   trunk/mapbender/http/javascripts/initWmcObj.php
   trunk/mapbender/http/php/mod_callMetadata.php
   trunk/mapbender/http/php/mod_savewmc_server.php
Bugfix for CORS proxy and possibility to store temporal wmc at other storage e.g. memcached server.
Modified: trunk/mapbender/http/classes/class_metadata_new.php
--- trunk/mapbender/http/classes/class_metadata_new.php	2014-05-12 07:41:02 UTC (rev 8835)
+++ trunk/mapbender/http/classes/class_metadata_new.php	2014-05-12 08:36:17 UTC (rev 8836)
@@ -58,9 +58,10 @@
 	var $orderBy;
 	var $hostName;
 	var $resourceIds;
-	var $restrictToOpenData;
+	var $restrictToOpenData;
+	var $originFromHeader;
-	function __construct($userId, $searchId, $searchText, $registratingDepartments, $isoCategories, $inspireThemes, $timeBegin, $timeEnd, $regTimeBegin, $regTimeEnd, $maxResults, $searchBbox, $searchTypeBbox, $accessRestrictions, $languageCode, $searchEPSG, $searchResources, $searchPages, $outputFormat, $resultTarget, $searchURL, $customCategories, $hostName, $orderBy, $resourceIds, $restrictToOpenData){
+	function __construct($userId, $searchId, $searchText, $registratingDepartments, $isoCategories, $inspireThemes, $timeBegin, $timeEnd, $regTimeBegin, $regTimeEnd, $maxResults, $searchBbox, $searchTypeBbox, $accessRestrictions, $languageCode, $searchEPSG, $searchResources, $searchPages, $outputFormat, $resultTarget, $searchURL, $customCategories, $hostName, $orderBy, $resourceIds, $restrictToOpenData, $originFromHeader){
 		$this->userId = (integer)$userId;
 		$this->searchId = $searchId;
 		$this->searchText = $searchText;
@@ -92,6 +93,7 @@
 		} else {
 			$this->restrictToOpenData = false;
+		$this->originFromHeader = $originFromHeader;
 		//definitions for generating tagClouds
 		$this->maxObjects = 15;
 		$this->maxFontSize = 30;
@@ -828,9 +830,13 @@
 					$this->allJSON->filter = $filterJSON;
 				$this->allJSON->wms = $this->json->decode($this->wmsJSON);
-				if (defined("CORS_WHITELIST") && CORS_WHITELIST != "") {
-					header('Access-Control-Allow-Origin: '.CORS_WHITELIST);
+				//$e = new mb_exception("originFromHeader: ".$this->originFromHeader);
+				if ($this->originFromHeader != false) {
+					header('Access-Control-Allow-Origin: '.$this->originFromHeader);
+				//if (defined("CORS_WHITELIST") && CORS_WHITELIST != "") {
+				//	header('Access-Control-Allow-Origin: '.CORS_WHITELIST);
 				echo  $this->json->encode($this->allJSON);
 				//echo "test";
Modified: trunk/mapbender/http/javascripts/initWmcObj.php
--- trunk/mapbender/http/javascripts/initWmcObj.php	2014-05-12 07:41:02 UTC (rev 8835)
+++ trunk/mapbender/http/javascripts/initWmcObj.php	2014-05-12 08:36:17 UTC (rev 8836)
@@ -34,6 +34,45 @@
+function getWmcFromStorage($filename) {
+	switch (TMP_WMC_SAVE_STORAGE) {
+		case "memcache":
+			$memcache_obj = new Memcache;
+			if (defined("MEMCACHED_IP") && MEMCACHED_IP != "" && defined("MEMCACHED_PORT") && MEMCACHED_PORT != "") {
+				$memcache_obj->connect(MEMCACHED_IP, MEMCACHED_PORT);
+			} else {
+				//use standard options
+				$memcache_obj->connect('localhost', 11211);
+			new mb_notice("wmc sessions stored via memcache");
+			$wmc = $memcache_obj->get($filename);
+			$memcache_obj->close();
+			return $wmc;
+		break;
+		case "memcached":
+			$memcached_obj = new Memcached;
+				$memcached_obj->addServer(MEMCACHED_IP, MEMCACHED_PORT);
+			} else {
+				$memcached_obj->addServer('localhost', 11211);
+			new mb_notice("wmc stored via memcacheD");
+			$wmc = $memcached_obj->get($filename);
+			//$memcached_obj->quit();
+			return $wmc;
+		break;
+		case "file":
+			$wmc = file_get_contents($filename);
+			return $wmc;
+		break;
+		default:
+			return $wmc;
+		break;
 $admin = new administration();
 $resultObj = array(
 	"noPermission" => array(
@@ -69,7 +108,12 @@
 //check if wmc filename is in session - TODO only if should be loaded from session not else! (Module loadWMC)
 if(Mapbender::session()->get("mb_wmc")) {
     $wmc_filename = Mapbender::session()->get("mb_wmc");
-    $wmcDocSession = file_get_contents($wmc_filename);
+    $time_start = microtime();
+    //load it from whereever it has been stored
+    $wmcDocSession = getWmcFromStorage($wmc_filename);
+    $time_end = microtime();
+    $timediff = $time_end - $time_start;
+    $e = new mb_exception('initWmcObj.php: time to load wmc from storage: '.$timediff. '('.TMP_WMC_SAVE_STORAGE.')');
 try {
 	$loadFromSession = new ElementVar($app, "loadwmc", "loadFromSession");
Modified: trunk/mapbender/http/php/mod_callMetadata.php
--- trunk/mapbender/http/php/mod_callMetadata.php	2014-05-12 07:41:02 UTC (rev 8835)
+++ trunk/mapbender/http/php/mod_callMetadata.php	2014-05-12 08:36:17 UTC (rev 8836)
@@ -52,7 +52,14 @@
 $tempFolder = TMPDIR;
 $orderBy = "rank"; //rank or title or id or date
 $hostName = $_SERVER['HTTP_HOST'];
+$headers = apache_request_headers();
+$originFromHeader = false;
+foreach ($headers as $header => $value) {
+    	if ($header === "Origin") {
+		//$e = new mb_exception("Origin: ".$value);
+		$originFromHeader = $value;
 //read the whole query string:
 $searchURL = $_SERVER['QUERY_STRING'];
 //decode it !
@@ -1004,7 +1011,8 @@
 if ($resultTarget == 'web' or $resultTarget == 'debug' or $resultTarget == 'webclient') {
 	if (count($searchResources) == 1) {
-		$metadata = new searchMetadata($userId, $searchId, $searchText, $registratingDepartments, $isoCategories, $inspireThemes, $timeBegin, $timeEnd, $regTimeBegin, $regTimeEnd, $maxResults, $searchBbox, $searchTypeBbox, $accessRestrictions, $languageCode, $searchEPSG, $searchResources[0], $searchPages[0], $outputFormat, $resultTarget, $searchURL, $customCategories, $hostName, $orderBy, $resourceIds, $restrictToOpenData);
+		//$e = new mb_exception("originFromHeader: ".$originFromHeader);
+		$metadata = new searchMetadata($userId, $searchId, $searchText, $registratingDepartments, $isoCategories, $inspireThemes, $timeBegin, $timeEnd, $regTimeBegin, $regTimeEnd, $maxResults, $searchBbox, $searchTypeBbox, $accessRestrictions, $languageCode, $searchEPSG, $searchResources[0], $searchPages[0], $outputFormat, $resultTarget, $searchURL, $customCategories, $hostName, $orderBy, $resourceIds, $restrictToOpenData, $originFromHeader);
 		#if ($outputFormat == 'xml') {
 		#	header("Content-type: application/xhtml+xml; charset=UTF-8");
Modified: trunk/mapbender/http/php/mod_savewmc_server.php
--- trunk/mapbender/http/php/mod_savewmc_server.php	2014-05-12 07:41:02 UTC (rev 8835)
+++ trunk/mapbender/http/php/mod_savewmc_server.php	2014-05-12 08:36:17 UTC (rev 8836)
@@ -13,6 +13,47 @@
 require_once(dirname(__FILE__)."/../classes/class_json.php");
 require_once(dirname(__FILE__)."/../classes/class_lzw_decompress.php");
+function putWmcToStorage($filename, $xml) {
+		case "memcache":
+			} else {
+			$memcache_obj->set($filename, $xml, 0, TMP_WMC_MAX_AGE);
+			return true;
+		break;
+		case "memcached":
+			} else {
+			return $memcached_obj->set($filename, $xml, TMP_WMC_MAX_AGE);
+			return true;
+		break;
+		case "file":
+			file_put_contents($filename, $xml);
+		break;
+		default:
+		break;
 $ajaxResponse = new AjaxResponse($_POST);
 if($ajaxResponse->getMethod() != "saveWMC") {
 	$ajaxResponse->setSuccess(false);
@@ -61,30 +102,25 @@
 if ($saveInSession === 1) {
-	// CLEAN SESSION WMC FILES
-	//do this by cronjob!
-	//$tmp = scandir(TMPDIR);
-	// get all files from tmp folder
-	/*for($p = 0; $p < count($tmp); $p++) {
-	// match timestamp on begin of the filename
-       	if(preg_match("/^([\d]+).*$/i", $tmp[$p],$timestamp)) {
-            	// if file older than 24h, remove it.
-            	if((time() - $timestamp[1]) >= 86400) { // 86400 = 24h
-             	   unlink(TMPDIR."/wmc/".$tmp[$p]);
-    	// store XML in tmp folder
+	//CLEAN SESSION WMC FILES
+	//do this by cronjob or handled by memcached itself!
+    	//store XML location, that is defined in mapbender.conf (memcached server, session or file)
+        //look for existing referenced wmc in session
         	$filename = Mapbender::session()->get("mb_wmc");
     	} else {
         	$filename = TMPDIR."/wmc/".time()."_".uniqid();//will be set to new one cause ?
-    	file_put_contents($filename, $wmc->xml);
+	putWmcToStorage($filename, $wmc->xml);
+	$e = new mb_exception('mod_savewmc_server.php: time to save wmc to storage: '.$timediff. '('.TMP_WMC_SAVE_STORAGE.')');
+    	//file_put_contents($filename, $wmc->xml);
+	//put filename into session
     	Mapbender::session()->set("mb_wmc",$filename);
-	// store XML in session
-    	//Mapbender::session()->set("mb_wmc",$wmc->xml);
-	//$epsgTest=$wmc->mainMap->extent->toJavaScript();
 	$epsgString = $wmc->mainMap->extentToJavascript();
 	// get epsg code from jquery string
 	preg_match('/EPSG:\d{4,5}/',$epsgString, $matches);
@@ -96,14 +132,12 @@
 		Mapbender::session()->set("epsg",$epsg);
 	Mapbender::session()->set("previous_gui", Mapbender::session()->get("mb_user_gui"));
-	$e = new mb_notice("mod_insertWMCIntoDB: save WMC in session succeeded.");
+	$e = new mb_notice("mod_savewmc_server: save WMC into storage succeeded.");
 	$ajaxResponse->setSuccess(true);
-	$ajaxResponse->setResult(_mb("saved wmc document to session"));
+	$ajaxResponse->setResult(_mb("saved wmc document to temporal storage"));
 else {
 	// insert WMC into database
 	if(isset($attributes->title)) {
 		$attributes->title = trim($attributes->title);
 		if($attributes->title == "") {
More information about the Mapbender_commits mailing list
