[Mapbender-commits] r8837 - in trunk/mapbender: http/css http/plugins lib
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon May 12 01:42:40 PDT 2014
Author: hwbllmnn
Date: 2014-05-12 01:42:40 -0700 (Mon, 12 May 2014)
New Revision: 8837
   trunk/mapbender/http/css/digitize_new.css
   trunk/mapbender/http/plugins/kmlTree.js
   trunk/mapbender/http/plugins/mb_digitize_widget.php
   trunk/mapbender/lib/mb.ui.displayKmlFeatures.js
reworking the kml tree:
* don't zoom to feature on click
* left click on blue arrow also opens context menu
Modified: trunk/mapbender/http/css/digitize_new.css
--- trunk/mapbender/http/css/digitize_new.css	2014-05-12 08:36:17 UTC (rev 8836)
+++ trunk/mapbender/http/css/digitize_new.css	2014-05-12 08:42:40 UTC (rev 8837)
@@ -141,3 +141,9 @@
 .digitize-contextmenu {
     line-height: 28px;
+.digitize-menu-arrow {
+    background-image: url('../img/tree_new/menu.png');
+    background-repeat: no-repeat;
+    background-position: center;
Modified: trunk/mapbender/http/plugins/kmlTree.js
--- trunk/mapbender/http/plugins/kmlTree.js	2014-05-12 08:36:17 UTC (rev 8836)
+++ trunk/mapbender/http/plugins/kmlTree.js	2014-05-12 08:42:40 UTC (rev 8837)
@@ -66,8 +66,9 @@
             $KMLfolder.find('ul li[title="' + title + '"]').remove();
         abbrevTitle = title.length < 20 ?  title : title.substr(0,17) + "...";
-        $kmlEntry = $('<li title="'+ title +'" class="open"><button class="toggle" name="toggle" value="toggle" ></button> <input type="checkbox"'+checked  +'/><button class="digitize-layer" name="digitize-layer" value="digitize-layer"></button><button class="remove" name="remove" value="remove" ></button><a href="#">'+abbrevTitle+'</a></li>');
+        $kmlEntry = $('<li title="'+ title +'" class="open"><button class="digitize-menu-arrow"></button><button class="toggle" name="toggle" value="toggle" ></button> <input type="checkbox"'+checked  +'/><a href="#">'+abbrevTitle+'</a></li>');
         $KMLfolder.children("ul").append($kmlEntry);
         $kmlEntry.find("a").bind("click",(function(jsonFeatureCollection){return function(){
        var map = o.$target.mapbender();
        var g = new GeometryArray();
@@ -90,33 +91,32 @@
         $featureList = $("<ul />");
         $kmlEntry.append($featureList);
         for(var i = 0;i < obj.data.features.length;i++){
             title = obj.data.features[i].properties.name;
-            $feature = $('<li idx="' + i + '" title="'+ title +'"><a href="#" >'+ abbrevTitle + '</a></li>');
+            $feature = $('<li idx="' + i + '" title="'+ title +'"><button class="digitize-menu-arrow"></button><a href="#" >'+ abbrevTitle + '</a></li>');
             $featureList.append($feature);
-            $feature.bind('click',(function(jsonFeature){return function(){
+            // $feature.bind('click',(function(jsonFeature){return function(){
-                                                             var map = o.$target.mapbender();
-                                                             var g = new GeometryArray();
-                                                             g.importGeoJSON(jsonFeature,false);
-                                                             var feature = g.get(0);
+            //                                                  var map = o.$target.mapbender();
+            //                                                  var g = new GeometryArray();
+            //                                                  g.importGeoJSON(jsonFeature,false);
+            //                                                  var feature = g.get(0);
-                                                             var bbox = feature.getBBox();
-                                                             var bufferFloat = parseFloat(o.buffer);
-                                                             var buffer = new Point(bufferFloat,bufferFloat);
-                                                             bbox[0] = bbox[0].minus(buffer);
-                                                             bbox[1] = bbox[1].plus(buffer);
+            //                                                  var bbox = feature.getBBox();
+            //                                                  var bufferFloat = parseFloat(o.buffer);
+            //                                                  var buffer = new Point(bufferFloat,bufferFloat);
+            //                                                  bbox[0] = bbox[0].minus(buffer);
+            //                                                  bbox[1] = bbox[1].plus(buffer);
-                                                             map.calculateExtent(
-        new Mapbender.Extent(bbox[0], bbox[1])
-                                                             map.setMapRequest();
+            //                                                  map.calculateExtent(
+            //                                                      new Mapbender.Extent(bbox[0], bbox[1])
+            //                                                  map.setMapRequest();
-                                                        })(obj.data.features[i]));
+            //                                             })(obj.data.features[i]));
             $feature.bind('mouseout',(function(jsonFeature){return function(){
Modified: trunk/mapbender/http/plugins/mb_digitize_widget.php
--- trunk/mapbender/http/plugins/mb_digitize_widget.php	2014-05-12 08:36:17 UTC (rev 8836)
+++ trunk/mapbender/http/plugins/mb_digitize_widget.php	2014-05-12 08:42:40 UTC (rev 8837)
@@ -1,3 +1,4 @@
+// -*- mode: js3;-*-
  * Package: digitize_widget
@@ -188,6 +189,8 @@
             var url = item.url;
             $('li[title="' + url + '"] > a').live('contextmenu', contextmenuLayer);
             $('li[title="' + url + '"] > ul > li').live('contextmenu', contextmenuObject);
+            $('li[title="' + url + '"] > .digitize-menu-arrow').live('click', contextmenuLayer);
+            $('li[title="' + url + '"] > ul > li > .digitize-menu-arrow').live('click', contextmenuObject);
@@ -201,7 +204,9 @@
             .hover(function() {$(this).addClass('ui-state-hover'); },
                    function() {$(this).removeClass('ui-state-hover'); });
         menu.children('li:has(.digitize-zoomto)').bind('click', function() {
-            $link.click();
+            var kml = $('#mapframe1').data('kml');
+            var url = $link.parent().parent().parent().attr('title');
+            kml.zoomToFeature(url, $link.parent().attr('idx'));
             menu.menu('destroy').remove();
         menu.children('li:has(.digitize-pencil)').bind('click', function() {
Modified: trunk/mapbender/lib/mb.ui.displayKmlFeatures.js
--- trunk/mapbender/lib/mb.ui.displayKmlFeatures.js	2014-05-12 08:36:17 UTC (rev 8836)
+++ trunk/mapbender/lib/mb.ui.displayKmlFeatures.js	2014-05-12 08:42:40 UTC (rev 8837)
@@ -207,6 +207,23 @@
+    zoomToFeature: function(url, idx) {
+        var map = $('#mapframe1').mapbender();
+        var item = this._kmls[url];
+        var bbox = item.geomArray.list[idx].getBBox();
+        var bufferFloat = 100;
+        var buffer = new Point(bufferFloat,bufferFloat);
+        bbox[0] = bbox[0].minus(buffer);
+        bbox[1] = bbox[1].plus(buffer);
+        map.calculateExtent(
+            new Mapbender.Extent(bbox[0], bbox[1])
+        map.setMapRequest();
     addGeometry: function(pts) {
         var $map = $(this.element).mapbender();
         var self = this;
More information about the Mapbender_commits mailing list
