[Mapbender-commits] r8861 - trunk/mapbender/http/widgets
    svn_mapbender at osgeo.org
    Wed May 14 01:45:08 PDT 2014
Author: hwbllmnn
Date: 2014-05-14 01:45:08 -0700 (Wed, 14 May 2014)
New Revision: 8861
   trunk/mapbender/http/widgets/w_digitize.js
added vertex adding
Modified: trunk/mapbender/http/widgets/w_digitize.js
--- trunk/mapbender/http/widgets/w_digitize.js	2014-05-14 08:03:26 UTC (rev 8860)
+++ trunk/mapbender/http/widgets/w_digitize.js	2014-05-14 08:45:08 UTC (rev 8861)
@@ -162,7 +162,7 @@
                             this.options.lineStrokeSnapped : this.options.lineStrokeDefault,
                         "stroke-width": drawOptions && drawOptions.highlightLast ?
                             this.options.lineStrokeWidthSnapped : this.options.lineStrokeWidthDefault
                 if(this.options.type === 'polygon') {
@@ -179,6 +179,24 @@
+            if(this.addingVertex) {
+                var last;
+                for(i = 0; i < this._digitizePoints.length; ++i) {
+                    var pt = this._digitizePoints[i].mousePos;
+                    if(last) {
+                        var x = last.x + (pt.x - last.x) / 2;
+                        var y = last.y + (pt.y - last.y) / 2;
+                        this._canvas.circle(x, y, this.options.digitizePointDiameter)
+                            .attr({
+                                fill: this.options.pointFillSnapped,
+                                "fill-opacity": this.options.opacity,
+                                stroke: this.options.pointStrokeSnapped,
+                                "stroke-width": this.options.pointStrokeWidthDefault
+                    last = pt;
         // if (pos && drawOptions && !drawOptions.highlightFirst) {
@@ -491,6 +509,38 @@
             .css('cursor', 'crosshair');
+    addVertex: function(e) {
+        var pt = this.pointFromEvent(e);
+        var last;
+        for(var i = 0; i < this._digitizePoints.length; ++i) {
+            if(last) {
+                var cur = new Mapbender.Point(
+                    last.mousePos.x + (this._digitizePoints[i].mousePos.x - last.mousePos.x) / 2,
+                    last.mousePos.y + (this._digitizePoints[i].mousePos.y - last.mousePos.y) / 2
+                if(this._isPointSnapped(cur, pt.mousePos)) {
+                    this._digitizePoints.splice(i, 0, pt);
+                    this.vertexMoving = true;
+                    this.vertexMovingIndex = i;
+                    return;
+            last = this._digitizePoints[i];
+    addVertexMode: function() {
+        this.addingVertex = true;
+        this.element
+            .unbind('mousedown').unbind('mousemove').unbind('mouseup')
+            .bind('mousedown', $.proxy(this, 'addVertex'))
+            .bind('mousemove', $.proxy(this, 'vertexMove'))
+            .bind('mouseup', $.proxy(this, 'stopVertexMoving'))
+            .css('cursor', 'crosshair');
+        this._redraw();
     deleteVertex: function(e) {
         var self = this;
More information about the Mapbender_commits
