[Mapbender-commits] r8862 - in trunk/mapbender/http: plugins widgets
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed May 14 02:23:24 PDT 2014
Author: hwbllmnn
Date: 2014-05-14 02:23:24 -0700 (Wed, 14 May 2014)
New Revision: 8862
   trunk/mapbender/http/plugins/mb_digitize_widget.php
   trunk/mapbender/http/widgets/w_digitize.js
fixed geometry editing for polygons
Modified: trunk/mapbender/http/plugins/mb_digitize_widget.php
--- trunk/mapbender/http/plugins/mb_digitize_widget.php	2014-05-14 08:45:08 UTC (rev 8861)
+++ trunk/mapbender/http/plugins/mb_digitize_widget.php	2014-05-14 09:23:24 UTC (rev 8862)
@@ -409,11 +409,16 @@
         var pts = digit._digitizePoints;
         if(status === 'edit-point') {
             editedFeature.geometry.coordinates = [pts[0].pos.x, pts[0].pos.y];
-        } else {
+        } else if(status === 'edit-line') {
             editedFeature.geometry.coordinates = [];
             $.each(pts, function(_, v) {
                 editedFeature.geometry.coordinates.push([v.pos.x, v.pos.y]);
+        } else if(status === 'edit-polygon') {
+            editedFeature.geometry.coordinates = [[]];
+            $.each(pts, function(_, v) {
+                editedFeature.geometry.coordinates[0].push([v.pos.x, v.pos.y]);
         kml.refresh(digitizingFor);
Modified: trunk/mapbender/http/widgets/w_digitize.js
--- trunk/mapbender/http/widgets/w_digitize.js	2014-05-14 08:45:08 UTC (rev 8861)
+++ trunk/mapbender/http/widgets/w_digitize.js	2014-05-14 09:23:24 UTC (rev 8862)
@@ -580,9 +580,17 @@
         if($.isArray(coords[0])) {
             var pts = [];
             $.each(coords, function(_, v) {
-                var pos = {x: v[0], y: v[1]};
-                var mousePos = map.convertRealToPixel(pos);
-                pts.push({pos: pos, mousePos: mousePos});
+                if($.isArray(v[0])) {
+                    $.each(v, function(_, v2) {
+                        var pos = {x: v2[0], y: v2[1]};
+                        var mousePos = map.convertRealToPixel(pos);
+                        pts.push({pos: pos, mousePos: mousePos});
+                } else {
+                    var pos = {x: v[0], y: v[1]};
             return pts;
         } else {
More information about the Mapbender_commits mailing list
