[Mapbender-commits] r8885 - trunk/mapbender/http/extensions
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue May 20 07:51:36 PDT 2014
Author: hwbllmnn
Date: 2014-05-20 07:51:36 -0700 (Tue, 20 May 2014)
New Revision: 8885
Added:
   trunk/mapbender/http/extensions/spectrum-min.js
   trunk/mapbender/http/extensions/spectrum.css
added color picker files
Added: trunk/mapbender/http/extensions/spectrum-min.js
--- trunk/mapbender/http/extensions/spectrum-min.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/spectrum-min.js	2014-05-20 14:51:36 UTC (rev 8885)
@@ -0,0 +1,2 @@
+!function(window,$,undefined){function paletteTemplate(p,color,className,tooltipFormat){for(var html=[],i=0;i<p.length;i++){var current=p[i];if(current){var tiny=tinycolor(current),c=tiny.toHsl().l<.5?"sp-thumb-el sp-thumb-dark":"sp-thumb-el sp-thumb-light";c+=tinycolor.equals(color,current)?" sp-thumb-active":"";var formattedString=tiny.toString(tooltipFormat||"rgb"),swatchStyle=rgbaSupport?"background-color:"+tiny.toRgbString():"filter:"+tiny.toFilter();html.push('<span title="'+formattedString+'" data-color="'+tiny.toRgbString()+'" class="'+c+'"><span class="sp-thumb-inner" style="'+swatchStyle+';" /></span>')}else{var cls="sp-clear-display";html.push('<span title="No Color Selected" data-color="" style="background-color:transparent;" class="'+cls+'"></span>')}}return"<div class='sp-cf "+className+"'>"+html.join("")+"</div>"}function hideAll(){for(var i=0;i<spectrums.length;i++)spectrums[i]&&spectrums[i].hide()}function instanceOptions(o,callbackContext){var opts=$.extend
 ({},defaultOpts,o);return opts.callbacks={move:bind(opts.move,callbackContext),change:bind(opts.change,callbackContext),show:bind(opts.show,callbackContext),hide:bind(opts.hide,callbackContext),beforeShow:bind(opts.beforeShow,callbackContext)},opts}function spectrum(element,o){function applyOptions(){if(opts.showPaletteOnly&&(opts.showPalette=!0),opts.palette){palette=opts.palette.slice(0),paletteArray=$.isArray(palette[0])?palette:[palette],paletteLookup={};for(var i=0;i<paletteArray.length;i++)for(var j=0;j<paletteArray[i].length;j++){var rgb=tinycolor(paletteArray[i][j]).toRgbString();paletteLookup[rgb]=!0}}container.toggleClass("sp-flat",flat),container.toggleClass("sp-input-disabled",!opts.showInput),container.toggleClass("sp-alpha-enabled",opts.showAlpha),container.toggleClass("sp-clear-enabled",allowEmpty),container.toggleClass("sp-buttons-disabled",!opts.showButtons),container.toggleClass("sp-palette-disabled",!opts.showPalette),container.toggleClass("sp-palette-only
 ",opts.showPaletteOnly),container.toggleClass("sp-initial-disabled",!opts.showInitial),container.addClass(opts.className).addClass(opts.containerClassName),reflow()}function initialize(){function palletElementClick(e){return e.data&&e.data.ignore?(set($(this).data("color")),move()):(set($(this).data("color")),move(),updateOriginalInput(!0),hide()),!1}if(IE&&container.find("*:not(input)").attr("unselectable","on"),applyOptions(),shouldReplace&&boundElement.after(replacer).hide(),allowEmpty||clearButton.hide(),flat)boundElement.after(container).hide();else{var appendTo="parent"===opts.appendTo?boundElement.parent():$(opts.appendTo);1!==appendTo.length&&(appendTo=$("body")),appendTo.append(container)}updateSelectionPaletteFromStorage(),offsetElement.bind("click.spectrum touchstart.spectrum",function(e){disabled||toggle(),e.stopPropagation(),$(e.target).is("input")||e.preventDefault()}),(boundElement.is(":disabled")||opts.disabled===!0)&&disable(),container.click(stopPropagation
 ),textInput.change(setFromTextInput),textInput.bind("paste",function(){setTimeout(setFromTextInput,1)}),textInput.keydown(function(e){13==e.keyCode&&setFromTextInput()}),cancelButton.text(opts.cancelText),cancelButton.bind("click.spectrum",function(e){e.stopPropagation(),e.preventDefault(),hide("cancel")}),clearButton.attr("title",opts.clearText),clearButton.bind("click.spectrum",function(e){e.stopPropagation(),e.preventDefault(),isEmpty=!0,move(),flat&&updateOriginalInput(!0)}),chooseButton.text(opts.chooseText),chooseButton.bind("click.spectrum",function(e){e.stopPropagation(),e.preventDefault(),isValid()&&(updateOriginalInput(!0),hide())}),draggable(alphaSlider,function(dragX,dragY,e){currentAlpha=dragX/alphaWidth,isEmpty=!1,e.shiftKey&&(currentAlpha=Math.round(10*currentAlpha)/10),move()},dragStart,dragStop),draggable(slider,function(dragX,dragY){currentHue=parseFloat(dragY/slideHeight),isEmpty=!1,opts.showAlpha||(currentAlpha=1),move()},dragStart,dragStop),draggable(dra
 gger,function(dragX,dragY,e){if(e.shiftKey){if(!shiftMovementDirection){var oldDragX=currentSaturation*dragWidth,oldDragY=dragHeight-currentValue*dragHeight,furtherFromX=Math.abs(dragX-oldDragX)>Math.abs(dragY-oldDragY);shiftMovementDirection=furtherFromX?"x":"y"}}else shiftMovementDirection=null;var setSaturation=!shiftMovementDirection||"x"===shiftMovementDirection,setValue=!shiftMovementDirection||"y"===shiftMovementDirection;setSaturation&&(currentSaturation=parseFloat(dragX/dragWidth)),setValue&&(currentValue=parseFloat((dragHeight-dragY)/dragHeight)),isEmpty=!1,opts.showAlpha||(currentAlpha=1),move()},dragStart,dragStop),initialColor?(set(initialColor),updateUI(),currentPreferredFormat=preferredFormat||tinycolor(initialColor).format,addColorToSelectionPalette(initialColor)):updateUI(),flat&&show();var paletteEvent=IE?"mousedown.spectrum":"click.spectrum touchstart.spectrum";paletteContainer.delegate(".sp-thumb-el",paletteEvent,palletElementClick),initialColorContainer.
 delegate(".sp-thumb-el:nth-child(1)",paletteEvent,{ignore:!0},palletElementClick)}function updateSelectionPaletteFromStorage(){if(localStorageKey&&window.localStorage){try{var oldPalette=window.localStorage[localStorageKey].split(",#");oldPalette.length>1&&(delete window.localStorage[localStorageKey],$.each(oldPalette,function(i,c){addColorToSelectionPalette(c)}))}catch(e){}try{selectionPalette=window.localStorage[localStorageKey].split(";")}catch(e){}}}function addColorToSelectionPalette(color){if(showSelectionPalette){var rgb=tinycolor(color).toRgbString();if(!paletteLookup[rgb]&&-1===$.inArray(rgb,selectionPalette))for(selectionPalette.push(rgb);selectionPalette.length>maxSelectionSize;)selectionPalette.shift();if(localStorageKey&&window.localStorage)try{window.localStorage[localStorageKey]=selectionPalette.join(";")}catch(e){}}}function getUniqueSelectionPalette(){var unique=[];if(opts.showPalette)for(i=0;i<selectionPalette.length;i++){var rgb=tinycolor(selectionPalette[
 i]).toRgbString();paletteLookup[rgb]||unique.push(selectionPalette[i])}return unique.reverse().slice(0,opts.maxSelectionSize)}function drawPalette(){var currentColor=get(),html=$.map(paletteArray,function(palette,i){return paletteTemplate(palette,currentColor,"sp-palette-row sp-palette-row-"+i,opts.preferredFormat)});updateSelectionPaletteFromStorage(),selectionPalette&&html.push(paletteTemplate(getUniqueSelectionPalette(),currentColor,"sp-palette-row sp-palette-row-selection",opts.preferredFormat)),paletteContainer.html(html.join(""))}function drawInitial(){if(opts.showInitial){var initial=colorOnShow,current=get();initialColorContainer.html(paletteTemplate([initial,current],current,"sp-palette-row-initial",opts.preferredFormat))}}function dragStart(){(0>=dragHeight||0>=dragWidth||0>=slideHeight)&&reflow(),container.addClass(draggingClass),shiftMovementDirection=null,boundElement.trigger("dragstart.spectrum",[get()])}function dragStop(){container.removeClass(draggingClass),
 boundElement.trigger("dragstop.spectrum",[get()])}function setFromTextInput(){var value=textInput.val();if(null!==value&&""!==value||!allowEmpty){var tiny=tinycolor(value);tiny.ok?(set(tiny),updateOriginalInput(!0)):textInput.addClass("sp-validation-error")}else set(null),updateOriginalInput(!0)}function toggle(){visible?hide():show()}function show(){var event=$.Event("beforeShow.spectrum");return visible?void reflow():(boundElement.trigger(event,[get()]),void(callbacks.beforeShow(get())===!1||event.isDefaultPrevented()||(hideAll(),visible=!0,$(doc).bind("click.spectrum",hide),$(window).bind("resize.spectrum",resize),replacer.addClass("sp-active"),container.removeClass("sp-hidden"),reflow(),updateUI(),colorOnShow=get(),drawInitial(),callbacks.show(colorOnShow),boundElement.trigger("show.spectrum",[colorOnShow]))))}function hide(e){if((!e||"click"!=e.type||2!=e.button)&&visible&&!flat){visible=!1,$(doc).unbind("click.spectrum",hide),$(window).unbind("resize.spectrum",resize),
 replacer.removeClass("sp-active"),container.addClass("sp-hidden");var colorHasChanged=!tinycolor.equals(get(),colorOnShow);colorHasChanged&&(clickoutFiresChange&&"cancel"!==e?updateOriginalInput(!0):revert()),callbacks.hide(get()),boundElement.trigger("hide.spectrum",[get()])}}function revert(){set(colorOnShow,!0)}function set(color,ignoreFormatChange){if(tinycolor.equals(color,get()))return void updateUI();var newColor,newHsv;!color&&allowEmpty?isEmpty=!0:(isEmpty=!1,newColor=tinycolor(color),newHsv=newColor.toHsv(),currentHue=newHsv.h%360/360,currentSaturation=newHsv.s,currentValue=newHsv.v,currentAlpha=newHsv.a),updateUI(),newColor&&newColor.ok&&!ignoreFormatChange&&(currentPreferredFormat=preferredFormat||newColor.format)}function get(opts){return opts=opts||{},allowEmpty&&isEmpty?null:tinycolor.fromRatio({h:currentHue,s:currentSaturation,v:currentValue,a:Math.round(100*currentAlpha)/100},{format:opts.format||currentPreferredFormat})}function isValid(){return!textInput.h
 asClass("sp-validation-error")}function move(){updateUI(),callbacks.move(get()),boundElement.trigger("move.spectrum",[get()])}function updateUI(){textInput.removeClass("sp-validation-error"),updateHelperLocations();var flatColor=tinycolor.fromRatio({h:currentHue,s:1,v:1});dragger.css("background-color",flatColor.toHexString());var format=currentPreferredFormat;1>currentAlpha&&(0!==currentAlpha||"name"!==format)&&("hex"===format||"hex3"===format||"hex6"===format||"name"===format)&&(format="rgb");var realColor=get({format:format}),displayColor="";if(previewElement.removeClass("sp-clear-display"),previewElement.css("background-color","transparent"),!realColor&&allowEmpty)previewElement.addClass("sp-clear-display");else{var realHex=realColor.toHexString(),realRgb=realColor.toRgbString();if(rgbaSupport||1===realColor.alpha?previewElement.css("background-color",realRgb):(previewElement.css("background-color","transparent"),previewElement.css("filter",realColor.toFilter())),opts.sh
 owAlpha){var rgb=realColor.toRgb();rgb.a=0;var realAlpha=tinycolor(rgb).toRgbString(),gradient="linear-gradient(left, "+realAlpha+", "+realHex+")";IE?alphaSliderInner.css("filter",tinycolor(realAlpha).toFilter({gradientType:1},realHex)):(alphaSliderInner.css("background","-webkit-"+gradient),alphaSliderInner.css("background","-moz-"+gradient),alphaSliderInner.css("background","-ms-"+gradient),alphaSliderInner.css("background","linear-gradient(to right, "+realAlpha+", "+realHex+")"))}displayColor=realColor.toString(format)}opts.showInput&&textInput.val(displayColor),opts.showPalette&&drawPalette(),drawInitial()}function updateHelperLocations(){var s=currentSaturation,v=currentValue;if(allowEmpty&&isEmpty)alphaSlideHelper.hide(),slideHelper.hide(),dragHelper.hide();else{alphaSlideHelper.show(),slideHelper.show(),dragHelper.show();var dragX=s*dragWidth,dragY=dragHeight-v*dragHeight;dragX=Math.max(-dragHelperHeight,Math.min(dragWidth-dragHelperHeight,dragX-dragHelperHeight)),dra
 gY=Math.max(-dragHelperHeight,Math.min(dragHeight-dragHelperHeight,dragY-dragHelperHeight)),dragHelper.css({top:dragY+"px",left:dragX+"px"});var alphaX=currentAlpha*alphaWidth;alphaSlideHelper.css({left:alphaX-alphaSlideHelperWidth/2+"px"});var slideY=currentHue*slideHeight;slideHelper.css({top:slideY-slideHelperHeight+"px"})}}function updateOriginalInput(fireCallback){var color=get(),displayColor="",hasChanged=!tinycolor.equals(color,colorOnShow);color&&(displayColor=color.toString(currentPreferredFormat),addColorToSelectionPalette(color)),isInput&&boundElement.val(displayColor),colorOnShow=color,fireCallback&&hasChanged&&(callbacks.change(color),boundElement.trigger("change",[color]))}function reflow(){dragWidth=dragger.width(),dragHeight=dragger.height(),dragHelperHeight=dragHelper.height(),slideWidth=slider.width(),slideHeight=slider.height(),slideHelperHeight=slideHelper.height(),alphaWidth=alphaSlider.width(),alphaSlideHelperWidth=alphaSlideHelper.width(),flat||(contai
 ner.css("position","absolute"),container.offset(getOffset(container,offsetElement))),updateHelperLocations(),opts.showPalette&&drawPalette(),boundElement.trigger("reflow.spectrum")}function destroy(){boundElement.show(),offsetElement.unbind("click.spectrum touchstart.spectrum"),container.remove(),replacer.remove(),spectrums[spect.id]=null}function option(optionName,optionValue){return optionName===undefined?$.extend({},opts):optionValue===undefined?opts[optionName]:(opts[optionName]=optionValue,void applyOptions())}function enable(){disabled=!1,boundElement.attr("disabled",!1),offsetElement.removeClass("sp-disabled")}function disable(){hide(),disabled=!0,boundElement.attr("disabled",!0),offsetElement.addClass("sp-disabled")}var opts=instanceOptions(o,element),flat=opts.flat,showSelectionPalette=opts.showSelectionPalette,localStorageKey=opts.localStorageKey,theme=opts.theme,callbacks=opts.callbacks,resize=throttle(reflow,10),visible=!1,dragWidth=0,dragHeight=0,dragHelperHeigh
 t=0,slideHeight=0,slideWidth=0,alphaWidth=0,alphaSlideHelperWidth=0,slideHelperHeight=0,currentHue=0,currentSaturation=0,currentValue=0,currentAlpha=1,palette=[],paletteArray=[],paletteLookup={},selectionPalette=opts.selectionPalette.slice(0),maxSelectionSize=opts.maxSelectionSize,draggingClass="sp-dragging",shiftMovementDirection=null,doc=element.ownerDocument,boundElement=(doc.body,$(element)),disabled=!1,container=$(markup,doc).addClass(theme),dragger=container.find(".sp-color"),dragHelper=container.find(".sp-dragger"),slider=container.find(".sp-hue"),slideHelper=container.find(".sp-slider"),alphaSliderInner=container.find(".sp-alpha-inner"),alphaSlider=container.find(".sp-alpha"),alphaSlideHelper=container.find(".sp-alpha-handle"),textInput=container.find(".sp-input"),paletteContainer=container.find(".sp-palette"),initialColorContainer=container.find(".sp-initial"),cancelButton=container.find(".sp-cancel"),clearButton=container.find(".sp-clear"),chooseButton=container.fi
 nd(".sp-choose"),isInput=boundElement.is("input"),isInputTypeColor=isInput&&inputTypeColorSupport&&"color"===boundElement.attr("type"),shouldReplace=isInput&&!flat,replacer=shouldReplace?$(replaceInput).addClass(theme).addClass(opts.className).addClass(opts.replacerClassName):$([]),offsetElement=shouldReplace?replacer:boundElement,previewElement=replacer.find(".sp-preview-inner"),initialColor=opts.color||isInput&&boundElement.val(),colorOnShow=!1,preferredFormat=opts.preferredFormat,currentPreferredFormat=preferredFormat,clickoutFiresChange=!opts.showButtons||opts.clickoutFiresChange,isEmpty=!initialColor,allowEmpty=opts.allowEmpty&&!isInputTypeColor;initialize();var spect={show:show,hide:hide,toggle:toggle,reflow:reflow,option:option,enable:enable,disable:disable,set:function(c){set(c),updateOriginalInput()},get:get,destroy:destroy,container:container};return spect.id=spectrums.push(spect)-1,spect}function getOffset(picker,input){var extraY=0,dpWidth=picker.outerWidth(),dpH
 eight=picker.outerHeight(),inputHeight=input.outerHeight(),doc=picker[0].ownerDocument,docElem=doc.documentElement,viewWidth=docElem.clientWidth+$(doc).scrollLeft(),viewHeight=docElem.clientHeight+$(doc).scrollTop(),offset=input.offset();return offset.top+=inputHeight,offset.left-=Math.min(offset.left,offset.left+dpWidth>viewWidth&&viewWidth>dpWidth?Math.abs(offset.left+dpWidth-viewWidth):0),offset.top-=Math.min(offset.top,offset.top+dpHeight>viewHeight&&viewHeight>dpHeight?Math.abs(dpHeight+inputHeight-extraY):extraY),offset}function noop(){}function stopPropagation(e){e.stopPropagation()}function bind(func,obj){var slice=Array.prototype.slice,args=slice.call(arguments,2);return function(){return func.apply(obj,args.concat(slice.call(arguments)))}}function draggable(element,onmove,onstart,onstop){function prevent(e){e.stopPropagation&&e.stopPropagation(),e.preventDefault&&e.preventDefault(),e.returnValue=!1}function move(e){if(dragging){if(IE&&document.documentMode<9&&!e.bu
 tton)return stop();var touches=e.originalEvent.touches,pageX=touches?touches[0].pageX:e.pageX,pageY=touches?touches[0].pageY:e.pageY,dragX=Math.max(0,Math.min(pageX-offset.left,maxWidth)),dragY=Math.max(0,Math.min(pageY-offset.top,maxHeight));hasTouch&&prevent(e),onmove.apply(element,[dragX,dragY,e])}}function start(e){{var rightclick=e.which?3==e.which:2==e.button;e.originalEvent.touches}rightclick||dragging||onstart.apply(element,arguments)!==!1&&(dragging=!0,maxHeight=$(element).height(),maxWidth=$(element).width(),offset=$(element).offset(),$(doc).bind(duringDragEvents),$(doc.body).addClass("sp-dragging"),hasTouch||move(e),prevent(e))}function stop(){dragging&&($(doc).unbind(duringDragEvents),$(doc.body).removeClass("sp-dragging"),onstop.apply(element,arguments)),dragging=!1}onmove=onmove||function(){},onstart=onstart||function(){},onstop=onstop||function(){};var doc=element.ownerDocument||document,dragging=!1,offset={},maxHeight=0,maxWidth=0,hasTouch="ontouchstart"in wi
 ndow,duringDragEvents={};duringDragEvents.selectstart=prevent,duringDragEvents.dragstart=prevent,duringDragEvents["touchmove mousemove"]=move,duringDragEvents["touchend mouseup"]=stop,$(element).bind("touchstart mousedown",start)}function throttle(func,wait,debounce){var timeout;return function(){var context=this,args=arguments,throttler=function(){timeout=null,func.apply(context,args)};debounce&&clearTimeout(timeout),(debounce||!timeout)&&(timeout=setTimeout(throttler,wait))}}var defaultOpts={beforeShow:noop,move:noop,change:noop,show:noop,hide:noop,color:!1,flat:!1,showInput:!1,allowEmpty:!1,showButtons:!0,clickoutFiresChange:!1,showInitial:!1,showPalette:!1,showPaletteOnly:!1,showSelectionPalette:!0,localStorageKey:!1,appendTo:"body",maxSelectionSize:7,cancelText:"cancel",chooseText:"choose",clearText:"Clear Color Selection",preferredFormat:!1,className:"",containerClassName:"",replacerClassName:"",showAlpha:!1,theme:"sp-light",palette:[["#ffffff","#000000","#ff0000","#ff
 8000","#ffff00","#008000","#0000ff","#4b0082","#9400d3"]],selectionPalette:[],disabled:!1},spectrums=[],IE=!!/msie/i.exec(window.navigator.userAgent),rgbaSupport=function(){function contains(str,substr){return!!~(""+str).indexOf(substr)}var elem=document.createElement("div"),style=elem.style;return style.cssText="background-color:rgba(0,0,0,.5)",contains(style.backgroundColor,"rgba")||contains(style.backgroundColor,"hsla")}(),inputTypeColorSupport=function(){var colorInput=$("<input type='color' value='!' />")[0];return"color"===colorInput.type&&"!"!==colorInput.value}(),replaceInput=["<div class='sp-replacer'>","<div class='sp-preview'><div class='sp-preview-inner'></div></div>","<div class='sp-dd'>▼</div>","</div>"].join(""),markup=function(){var gradientFix="";if(IE)for(var i=1;6>=i;i++)gradientFix+="<div class='sp-"+i+"'></div>";return["<div class='sp-container sp-hidden'>","<div class='sp-palette-container'>","<div class='sp-palette sp-thumb sp-cf'></div>","</div>
 ","<div class='sp-picker-container'>","<div class='sp-top sp-cf'>","<div class='sp-fill'></div>","<div class='sp-top-inner'>","<div class='sp-color'>","<div class='sp-sat'>","<div class='sp-val'>","<div class='sp-dragger'></div>","</div>","</div>","</div>","<div class='sp-clear sp-clear-display'>","</div>","<div class='sp-hue'>","<div class='sp-slider'></div>",gradientFix,"</div>","</div>","<div class='sp-alpha'><div class='sp-alpha-inner'><div class='sp-alpha-handle'></div></div></div>","</div>","<div class='sp-input-container sp-cf'>","<input class='sp-input' type='text' spellcheck='false'  />","</div>","<div class='sp-initial sp-thumb sp-cf'></div>","<div class='sp-button-container sp-cf'>","<a class='sp-cancel' href='#'></a>","<button type='button' class='sp-choose'></button>","</div>","</div>","</div>"].join("")}(),dataID="spectrum.id";$.fn.spectrum=function(opts){if("string"==typeof opts){var returnValue=this,args=Array.prototype.slice.call(arguments,1);return this.eac
 h(function(){var spect=spectrums[$(this).data(dataID)];if(spect){var method=spect[opts];if(!method)throw new Error("Spectrum: no such method: '"+opts+"'");"get"==opts?returnValue=spect.get():"container"==opts?returnValue=spect.container:"option"==opts?returnValue=spect.option.apply(spect,args):"destroy"==opts?(spect.destroy(),$(this).removeData(dataID)):method.apply(spect,args)}}),returnValue}return this.spectrum("destroy").each(function(){var options=$.extend({},opts,$(this).data()),spect=spectrum(this,options);$(this).data(dataID,spect.id)})},$.fn.spectrum.load=!0,$.fn.spectrum.loadOpts={},$.fn.spectrum.draggable=draggable,$.fn.spectrum.defaults=defaultOpts,$.spectrum={},$.spectrum.localization={},$.spectrum.palettes={},$.fn.spectrum.processNativeColorInputs=function(){inputTypeColorSupport||$("input[type=color]").spectrum({preferredFormat:"hex6"})},function(){function tinycolor(color,opts){if(color=color?color:"",opts=opts||{},"object"==typeof color&&color.hasOwnProperty(
 "_tc_id"))return color;var rgb=inputToRGB(color),r=rgb.r,g=rgb.g,b=rgb.b,a=rgb.a,roundA=mathRound(100*a)/100,format=opts.format||rgb.format;return 1>r&&(r=mathRound(r)),1>g&&(g=mathRound(g)),1>b&&(b=mathRound(b)),{ok:rgb.ok,format:format,_tc_id:tinyCounter++,alpha:a,getAlpha:function(){return a},setAlpha:function(value){a=boundAlpha(value),roundA=mathRound(100*a)/100},toHsv:function(){var hsv=rgbToHsv(r,g,b);return{h:360*hsv.h,s:hsv.s,v:hsv.v,a:a}},toHsvString:function(){var hsv=rgbToHsv(r,g,b),h=mathRound(360*hsv.h),s=mathRound(100*hsv.s),v=mathRound(100*hsv.v);return 1==a?"hsv("+h+", "+s+"%, "+v+"%)":"hsva("+h+", "+s+"%, "+v+"%, "+roundA+")"},toHsl:function(){var hsl=rgbToHsl(r,g,b);return{h:360*hsl.h,s:hsl.s,l:hsl.l,a:a}},toHslString:function(){var hsl=rgbToHsl(r,g,b),h=mathRound(360*hsl.h),s=mathRound(100*hsl.s),l=mathRound(100*hsl.l);return 1==a?"hsl("+h+", "+s+"%, "+l+"%)":"hsla("+h+", "+s+"%, "+l+"%, "+roundA+")"},toHex:function(allow3Char){return rgbToHex(r,g,b,allow
 3Char)},toHexString:function(allow3Char){return"#"+this.toHex(allow3Char)},toHex8:function(){return rgbaToHex(r,g,b,a)},toHex8String:function(){return"#"+this.toHex8()},toRgb:function(){return{r:mathRound(r),g:mathRound(g),b:mathRound(b),a:a}},toRgbString:function(){return 1==a?"rgb("+mathRound(r)+", "+mathRound(g)+", "+mathRound(b)+")":"rgba("+mathRound(r)+", "+mathRound(g)+", "+mathRound(b)+", "+roundA+")"},toPercentageRgb:function(){return{r:mathRound(100*bound01(r,255))+"%",g:mathRound(100*bound01(g,255))+"%",b:mathRound(100*bound01(b,255))+"%",a:a}},toPercentageRgbString:function(){return 1==a?"rgb("+mathRound(100*bound01(r,255))+"%, "+mathRound(100*bound01(g,255))+"%, "+mathRound(100*bound01(b,255))+"%)":"rgba("+mathRound(100*bound01(r,255))+"%, "+mathRound(100*bound01(g,255))+"%, "+mathRound(100*bound01(b,255))+"%, "+roundA+")"},toName:function(){return 0===a?"transparent":hexNames[rgbToHex(r,g,b,!0)]||!1},toFilter:function(secondColor){var hex8String="#"+rgbaToHex(r,
 g,b,a),secondHex8String=hex8String,gradientType=opts&&opts.gradientType?"GradientType = 1, ":"";if(secondColor){var s=tinycolor(secondColor);secondHex8String=s.toHex8String()}return"progid:DXImageTransform.Microsoft.gradient("+gradientType+"startColorstr="+hex8String+",endColorstr="+secondHex8String+")"},toString:function(format){var formatSet=!!format;format=format||this.format;var formattedString=!1,hasAlphaAndFormatNotSet=!formatSet&&1>a&&a>0,formatWithAlpha=hasAlphaAndFormatNotSet&&("hex"===format||"hex6"===format||"hex3"===format||"name"===format);return"rgb"===format&&(formattedString=this.toRgbString()),"prgb"===format&&(formattedString=this.toPercentageRgbString()),("hex"===format||"hex6"===format)&&(formattedString=this.toHexString()),"hex3"===format&&(formattedString=this.toHexString(!0)),"hex8"===format&&(formattedString=this.toHex8String()),"name"===format&&(formattedString=this.toName()),"hsl"===format&&(formattedString=this.toHslString()),"hsv"===format&&(forma
 ttedString=this.toHsvString()),formatWithAlpha?this.toRgbString():formattedString||this.toHexString()}}}function inputToRGB(color){var rgb={r:0,g:0,b:0},a=1,ok=!1,format=!1;return"string"==typeof color&&(color=stringInputToObject(color)),"object"==typeof color&&(color.hasOwnProperty("r")&&color.hasOwnProperty("g")&&color.hasOwnProperty("b")?(rgb=rgbToRgb(color.r,color.g,color.b),ok=!0,format="%"===String(color.r).substr(-1)?"prgb":"rgb"):color.hasOwnProperty("h")&&color.hasOwnProperty("s")&&color.hasOwnProperty("v")?(color.s=convertToPercentage(color.s),color.v=convertToPercentage(color.v),rgb=hsvToRgb(color.h,color.s,color.v),ok=!0,format="hsv"):color.hasOwnProperty("h")&&color.hasOwnProperty("s")&&color.hasOwnProperty("l")&&(color.s=convertToPercentage(color.s),color.l=convertToPercentage(color.l),rgb=hslToRgb(color.h,color.s,color.l),ok=!0,format="hsl"),color.hasOwnProperty("a")&&(a=color.a)),a=boundAlpha(a),{ok:ok,format:color.format||format,r:mathMin(255,mathMax(rgb.r,0
 )),g:mathMin(255,mathMax(rgb.g,0)),b:mathMin(255,mathMax(rgb.b,0)),a:a}}function rgbToRgb(r,g,b){return{r:255*bound01(r,255),g:255*bound01(g,255),b:255*bound01(b,255)}}function rgbToHsl(r,g,b){r=bound01(r,255),g=bound01(g,255),b=bound01(b,255);var h,s,max=mathMax(r,g,b),min=mathMin(r,g,b),l=(max+min)/2;if(max==min)h=s=0;else{var d=max-min;switch(s=l>.5?d/(2-max-min):d/(max+min),max){case r:h=(g-b)/d+(b>g?6:0);break;case g:h=(b-r)/d+2;break;case b:h=(r-g)/d+4}h/=6}return{h:h,s:s,l:l}}function hslToRgb(h,s,l){function hue2rgb(p,q,t){return 0>t&&(t+=1),t>1&&(t-=1),1/6>t?p+6*(q-p)*t:.5>t?q:2/3>t?p+(q-p)*(2/3-t)*6:p}var r,g,b;if(h=bound01(h,360),s=bound01(s,100),l=bound01(l,100),0===s)r=g=b=l;else{var q=.5>l?l*(1+s):l+s-l*s,p=2*l-q;r=hue2rgb(p,q,h+1/3),g=hue2rgb(p,q,h),b=hue2rgb(p,q,h-1/3)}return{r:255*r,g:255*g,b:255*b}}function rgbToHsv(r,g,b){r=bound01(r,255),g=bound01(g,255),b=bound01(b,255);var h,s,max=mathMax(r,g,b),min=mathMin(r,g,b),v=max,d=max-min;if(s=0===max?0:d/max,ma
 x==min)h=0;else{switch(max){case r:h=(g-b)/d+(b>g?6:0);break;case g:h=(b-r)/d+2;break;case b:h=(r-g)/d+4}h/=6}return{h:h,s:s,v:v}}function hsvToRgb(h,s,v){h=6*bound01(h,360),s=bound01(s,100),v=bound01(v,100);var i=math.floor(h),f=h-i,p=v*(1-s),q=v*(1-f*s),t=v*(1-(1-f)*s),mod=i%6,r=[v,q,p,p,t,v][mod],g=[t,v,v,q,p,p][mod],b=[p,p,t,v,v,q][mod];return{r:255*r,g:255*g,b:255*b}}function rgbToHex(r,g,b,allow3Char){var hex=[pad2(mathRound(r).toString(16)),pad2(mathRound(g).toString(16)),pad2(mathRound(b).toString(16))];return allow3Char&&hex[0].charAt(0)==hex[0].charAt(1)&&hex[1].charAt(0)==hex[1].charAt(1)&&hex[2].charAt(0)==hex[2].charAt(1)?hex[0].charAt(0)+hex[1].charAt(0)+hex[2].charAt(0):hex.join("")}function rgbaToHex(r,g,b,a){var hex=[pad2(convertDecimalToHex(a)),pad2(mathRound(r).toString(16)),pad2(mathRound(g).toString(16)),pad2(mathRound(b).toString(16))];return hex.join("")}function flip(o){var flipped={};for(var i in o)o.hasOwnProperty(i)&&(flipped[o[i]]=i);return flippe
 d}function boundAlpha(a){return a=parseFloat(a),(isNaN(a)||0>a||a>1)&&(a=1),a}function bound01(n,max){isOnePointZero(n)&&(n="100%");var processPercent=isPercentage(n);return n=mathMin(max,mathMax(0,parseFloat(n))),processPercent&&(n=parseInt(n*max,10)/100),math.abs(n-max)<1e-6?1:n%max/parseFloat(max)}function clamp01(val){return mathMin(1,mathMax(0,val))}function parseIntFromHex(val){return parseInt(val,16)}function isOnePointZero(n){return"string"==typeof n&&-1!=n.indexOf(".")&&1===parseFloat(n)}function isPercentage(n){return"string"==typeof n&&-1!=n.indexOf("%")}function pad2(c){return 1==c.length?"0"+c:""+c}function convertToPercentage(n){return 1>=n&&(n=100*n+"%"),n}function convertDecimalToHex(d){return Math.round(255*parseFloat(d)).toString(16)}function convertHexToDecimal(h){return parseIntFromHex(h)/255}function stringInputToObject(color){color=color.replace(trimLeft,"").replace(trimRight,"").toLowerCase();var named=!1;if(names[color])color=names[color],named=!0;els
 e if("transparent"==color)return{r:0,g:0,b:0,a:0,format:"name"};var match;return(match=matchers.rgb.exec(color))?{r:match[1],g:match[2],b:match[3]}:(match=matchers.rgba.exec(color))?{r:match[1],g:match[2],b:match[3],a:match[4]}:(match=matchers.hsl.exec(color))?{h:match[1],s:match[2],l:match[3]}:(match=matchers.hsla.exec(color))?{h:match[1],s:match[2],l:match[3],a:match[4]}:(match=matchers.hsv.exec(color))?{h:match[1],s:match[2],v:match[3]}:(match=matchers.hex8.exec(color))?{a:convertHexToDecimal(match[1]),r:parseIntFromHex(match[2]),g:parseIntFromHex(match[3]),b:parseIntFromHex(match[4]),format:named?"name":"hex8"}:(match=matchers.hex6.exec(color))?{r:parseIntFromHex(match[1]),g:parseIntFromHex(match[2]),b:parseIntFromHex(match[3]),format:named?"name":"hex"}:(match=matchers.hex3.exec(color))?{r:parseIntFromHex(match[1]+""+match[1]),g:parseIntFromHex(match[2]+""+match[2]),b:parseIntFromHex(match[3]+""+match[3]),format:named?"name":"hex"}:!1}var trimLeft=/^[\s,#]+/,trimRight=/
 \s+$/,tinyCounter=0,math=Math,mathRound=math.round,mathMin=math.min,mathMax=math.max,mathRandom=math.random;tinycolor.fromRatio=function(color,opts){if("object"==typeof color){var newColor={};for(var i in color)color.hasOwnProperty(i)&&(newColor[i]="a"===i?color[i]:convertToPercentage(color[i]));color=newColor}return tinycolor(color,opts)},tinycolor.equals=function(color1,color2){return color1&&color2?tinycolor(color1).toRgbString()==tinycolor(color2).toRgbString():!1},tinycolor.random=function(){return tinycolor.fromRatio({r:mathRandom(),g:mathRandom(),b:mathRandom()})},tinycolor.desaturate=function(color,amount){amount=0===amount?0:amount||10;var hsl=tinycolor(color).toHsl();return hsl.s-=amount/100,hsl.s=clamp01(hsl.s),tinycolor(hsl)},tinycolor.saturate=function(color,amount){amount=0===amount?0:amount||10;var hsl=tinycolor(color).toHsl();return hsl.s+=amount/100,hsl.s=clamp01(hsl.s),tinycolor(hsl)},tinycolor.greyscale=function(color){return tinycolor.desaturate(color,100
 )},tinycolor.lighten=function(color,amount){amount=0===amount?0:amount||10;var hsl=tinycolor(color).toHsl();return hsl.l+=amount/100,hsl.l=clamp01(hsl.l),tinycolor(hsl)},tinycolor.darken=function(color,amount){amount=0===amount?0:amount||10;var hsl=tinycolor(color).toHsl();return hsl.l-=amount/100,hsl.l=clamp01(hsl.l),tinycolor(hsl)},tinycolor.complement=function(color){var hsl=tinycolor(color).toHsl();return hsl.h=(hsl.h+180)%360,tinycolor(hsl)},tinycolor.triad=function(color){var hsl=tinycolor(color).toHsl(),h=hsl.h;return[tinycolor(color),tinycolor({h:(h+120)%360,s:hsl.s,l:hsl.l}),tinycolor({h:(h+240)%360,s:hsl.s,l:hsl.l})]},tinycolor.tetrad=function(color){var hsl=tinycolor(color).toHsl(),h=hsl.h;return[tinycolor(color),tinycolor({h:(h+90)%360,s:hsl.s,l:hsl.l}),tinycolor({h:(h+180)%360,s:hsl.s,l:hsl.l}),tinycolor({h:(h+270)%360,s:hsl.s,l:hsl.l})]},tinycolor.splitcomplement=function(color){var hsl=tinycolor(color).toHsl(),h=hsl.h;return[tinycolor(color),tinycolor({h:(h+72
 )%360,s:hsl.s,l:hsl.l}),tinycolor({h:(h+216)%360,s:hsl.s,l:hsl.l})]},tinycolor.analogous=function(color,results,slices){results=results||6,slices=slices||30;var hsl=tinycolor(color).toHsl(),part=360/slices,ret=[tinycolor(color)];for(hsl.h=(hsl.h-(part*results>>1)+720)%360;--results;)hsl.h=(hsl.h+part)%360,ret.push(tinycolor(hsl));return ret},tinycolor.monochromatic=function(color,results){results=results||6;for(var hsv=tinycolor(color).toHsv(),h=hsv.h,s=hsv.s,v=hsv.v,ret=[],modification=1/results;results--;)ret.push(tinycolor({h:h,s:s,v:v})),v=(v+modification)%1;return ret},tinycolor.readability=function(color1,color2){var a=tinycolor(color1).toRgb(),b=tinycolor(color2).toRgb(),brightnessA=(299*a.r+587*a.g+114*a.b)/1e3,brightnessB=(299*b.r+587*b.g+114*b.b)/1e3,colorDiff=Math.max(a.r,b.r)-Math.min(a.r,b.r)+Math.max(a.g,b.g)-Math.min(a.g,b.g)+Math.max(a.b,b.b)-Math.min(a.b,b.b);return{brightness:Math.abs(brightnessA-brightnessB),color:colorDiff}},tinycolor.readable=function(co
 lor1,color2){var readability=tinycolor.readability(color1,color2);return readability.brightness>125&&readability.color>500},tinycolor.mostReadable=function(baseColor,colorList){for(var bestColor=null,bestScore=0,bestIsReadable=!1,i=0;i<colorList.length;i++){var readability=tinycolor.readability(baseColor,colorList[i]),readable=readability.brightness>125&&readability.color>500,score=3*(readability.brightness/125)+readability.color/500;
+(readable&&!bestIsReadable||readable&&bestIsReadable&&score>bestScore||!readable&&!bestIsReadable&&score>bestScore)&&(bestIsReadable=readable,bestScore=score,bestColor=tinycolor(colorList[i]))}return bestColor};var names=tinycolor.names={aliceblue:"f0f8ff",antiquewhite:"faebd7",aqua:"0ff",aquamarine:"7fffd4",azure:"f0ffff",beige:"f5f5dc",bisque:"ffe4c4",black:"000",blanchedalmond:"ffebcd",blue:"00f",blueviolet:"8a2be2",brown:"a52a2a",burlywood:"deb887",burntsienna:"ea7e5d",cadetblue:"5f9ea0",chartreuse:"7fff00",chocolate:"d2691e",coral:"ff7f50",cornflowerblue:"6495ed",cornsilk:"fff8dc",crimson:"dc143c",cyan:"0ff",darkblue:"00008b",darkcyan:"008b8b",darkgoldenrod:"b8860b",darkgray:"a9a9a9",darkgreen:"006400",darkgrey:"a9a9a9",darkkhaki:"bdb76b",darkmagenta:"8b008b",darkolivegreen:"556b2f",darkorange:"ff8c00",darkorchid:"9932cc",darkred:"8b0000",darksalmon:"e9967a",darkseagreen:"8fbc8f",darkslateblue:"483d8b",darkslategray:"2f4f4f",darkslategrey:"2f4f4f",darkturquoise:"00ced1"
 ,darkviolet:"9400d3",deeppink:"ff1493",deepskyblue:"00bfff",dimgray:"696969",dimgrey:"696969",dodgerblue:"1e90ff",firebrick:"b22222",floralwhite:"fffaf0",forestgreen:"228b22",fuchsia:"f0f",gainsboro:"dcdcdc",ghostwhite:"f8f8ff",gold:"ffd700",goldenrod:"daa520",gray:"808080",green:"008000",greenyellow:"adff2f",grey:"808080",honeydew:"f0fff0",hotpink:"ff69b4",indianred:"cd5c5c",indigo:"4b0082",ivory:"fffff0",khaki:"f0e68c",lavender:"e6e6fa",lavenderblush:"fff0f5",lawngreen:"7cfc00",lemonchiffon:"fffacd",lightblue:"add8e6",lightcoral:"f08080",lightcyan:"e0ffff",lightgoldenrodyellow:"fafad2",lightgray:"d3d3d3",lightgreen:"90ee90",lightgrey:"d3d3d3",lightpink:"ffb6c1",lightsalmon:"ffa07a",lightseagreen:"20b2aa",lightskyblue:"87cefa",lightslategray:"789",lightslategrey:"789",lightsteelblue:"b0c4de",lightyellow:"ffffe0",lime:"0f0",limegreen:"32cd32",linen:"faf0e6",magenta:"f0f",maroon:"800000",mediumaquamarine:"66cdaa",mediumblue:"0000cd",mediumorchid:"ba55d3",mediumpurple:"9370db"
 ,mediumseagreen:"3cb371",mediumslateblue:"7b68ee",mediumspringgreen:"00fa9a",mediumturquoise:"48d1cc",mediumvioletred:"c71585",midnightblue:"191970",mintcream:"f5fffa",mistyrose:"ffe4e1",moccasin:"ffe4b5",navajowhite:"ffdead",navy:"000080",oldlace:"fdf5e6",olive:"808000",olivedrab:"6b8e23",orange:"ffa500",orangered:"ff4500",orchid:"da70d6",palegoldenrod:"eee8aa",palegreen:"98fb98",paleturquoise:"afeeee",palevioletred:"db7093",papayawhip:"ffefd5",peachpuff:"ffdab9",peru:"cd853f",pink:"ffc0cb",plum:"dda0dd",powderblue:"b0e0e6",purple:"800080",red:"f00",rosybrown:"bc8f8f",royalblue:"4169e1",saddlebrown:"8b4513",salmon:"fa8072",sandybrown:"f4a460",seagreen:"2e8b57",seashell:"fff5ee",sienna:"a0522d",silver:"c0c0c0",skyblue:"87ceeb",slateblue:"6a5acd",slategray:"708090",slategrey:"708090",snow:"fffafa",springgreen:"00ff7f",steelblue:"4682b4",tan:"d2b48c",teal:"008080",thistle:"d8bfd8",tomato:"ff6347",turquoise:"40e0d0",violet:"ee82ee",wheat:"f5deb3",white:"fff",whitesmoke:"f5f5f5"
 ,yellow:"ff0",yellowgreen:"9acd32"},hexNames=tinycolor.hexNames=flip(names),matchers=function(){var CSS_INTEGER="[-\\+]?\\d+%?",CSS_NUMBER="[-\\+]?\\d*\\.\\d+%?",CSS_UNIT="(?:"+CSS_NUMBER+")|(?:"+CSS_INTEGER+")",PERMISSIVE_MATCH3="[\\s|\\(]+("+CSS_UNIT+")[,|\\s]+("+CSS_UNIT+")[,|\\s]+("+CSS_UNIT+")\\s*\\)?",PERMISSIVE_MATCH4="[\\s|\\(]+("+CSS_UNIT+")[,|\\s]+("+CSS_UNIT+")[,|\\s]+("+CSS_UNIT+")[,|\\s]+("+CSS_UNIT+")\\s*\\)?";return{rgb:new RegExp("rgb"+PERMISSIVE_MATCH3),rgba:new RegExp("rgba"+PERMISSIVE_MATCH4),hsl:new RegExp("hsl"+PERMISSIVE_MATCH3),hsla:new RegExp("hsla"+PERMISSIVE_MATCH4),hsv:new RegExp("hsv"+PERMISSIVE_MATCH3),hex3:/^([0-9a-fA-F]{1})([0-9a-fA-F]{1})([0-9a-fA-F]{1})$/,hex6:/^([0-9a-fA-F]{2})([0-9a-fA-F]{2})([0-9a-fA-F]{2})$/,hex8:/^([0-9a-fA-F]{2})([0-9a-fA-F]{2})([0-9a-fA-F]{2})([0-9a-fA-F]{2})$/}}();window.tinycolor=tinycolor}(),$(function(){$.fn.spectrum.load&&$.fn.spectrum.processNativeColorInputs()})}(window,jQuery);
\ No newline at end of file
Added: trunk/mapbender/http/extensions/spectrum.css
--- trunk/mapbender/http/extensions/spectrum.css	                        (rev 0)
+++ trunk/mapbender/http/extensions/spectrum.css	2014-05-20 14:51:36 UTC (rev 8885)
@@ -0,0 +1,519 @@
+Spectrum Colorpicker v1.3.4
+https://github.com/bgrins/spectrum
+Author: Brian Grinstead
+License: MIT
+.sp-container {
+    position:absolute;
+    top:0;
+    left:0;
+    display:inline-block;
+    *display: inline;
+    *zoom: 1;
+    /* https://github.com/bgrins/spectrum/issues/40 */
+    z-index: 9999994;
+    overflow: hidden;
+.sp-container.sp-flat {
+    position: relative;
+/* Fix for * { box-sizing: border-box; } */
+.sp-container,
+.sp-container * {
+    -webkit-box-sizing: content-box;
+       -moz-box-sizing: content-box;
+            box-sizing: content-box;
+/* http://ansciath.tumblr.com/post/7347495869/css-aspect-ratio */
+.sp-top {
+  position:relative;
+  width: 100%;
+.sp-top-inner {
+   top:0;
+   left:0;
+   bottom:0;
+   right:0;
+.sp-color {
+    position: absolute;
+    top:0;
+    left:0;
+    bottom:0;
+    right:20%;
+.sp-hue {
+    top:0;
+    right:0;
+    bottom:0;
+    left:84%;
+    height: 100%;
+.sp-clear-enabled .sp-hue {
+    top:33px;
+    height: 77.5%;
+.sp-fill {
+    padding-top: 80%;
+.sp-sat, .sp-val {
+    top:0;
+    left:0;
+    right:0;
+    bottom:0;
+.sp-alpha-enabled .sp-top {
+    margin-bottom: 18px;
+.sp-alpha-enabled .sp-alpha {
+    display: block;
+.sp-alpha-handle {
+    top:-4px;
+    bottom: -4px;
+    width: 6px;
+    left: 50%;
+    cursor: pointer;
+    border: 1px solid black;
+    background: white;
+    opacity: .8;
+.sp-alpha {
+    display: none;
+    bottom: -14px;
+    right: 0;
+    left: 0;
+    height: 8px;
+.sp-alpha-inner {
+    border: solid 1px #333;
+.sp-clear {
+    display: none;
+.sp-clear.sp-clear-display {
+    background-position: center;
+.sp-clear-enabled .sp-clear {
+    display: block;
+    top:0px;
+    right:0;
+    bottom:0;
+    left:84%;
+    height: 28px;
+/* Don't allow text selection */
+.sp-container, .sp-replacer, .sp-preview, .sp-dragger, .sp-slider, .sp-alpha, .sp-clear, .sp-alpha-handle, .sp-container.sp-dragging .sp-input, .sp-container button  {
+    -webkit-user-select:none;
+    -moz-user-select: -moz-none;
+    -o-user-select:none;
+    user-select: none;
+.sp-container.sp-input-disabled .sp-input-container {
+    display: none;
+.sp-container.sp-buttons-disabled .sp-button-container {
+    display: none;
+.sp-palette-only .sp-picker-container {
+    display: none;
+.sp-palette-disabled .sp-palette-container {
+    display: none;
+.sp-initial-disabled .sp-initial {
+    display: none;
+/* Gradients for hue, saturation and value instead of images.  Not pretty... but it works */
+.sp-sat {
+    background-image: -webkit-gradient(linear,  0 0, 100% 0, from(#FFF), to(rgba(204, 154, 129, 0)));
+    background-image: -webkit-linear-gradient(left, #FFF, rgba(204, 154, 129, 0));
+    background-image: -moz-linear-gradient(left, #fff, rgba(204, 154, 129, 0));
+    background-image: -o-linear-gradient(left, #fff, rgba(204, 154, 129, 0));
+    background-image: -ms-linear-gradient(left, #fff, rgba(204, 154, 129, 0));
+    background-image: linear-gradient(to right, #fff, rgba(204, 154, 129, 0));
+    -ms-filter: "progid:DXImageTransform.Microsoft.gradient(GradientType = 1, startColorstr=#FFFFFFFF, endColorstr=#00CC9A81)";
+    filter : progid:DXImageTransform.Microsoft.gradient(GradientType = 1, startColorstr='#FFFFFFFF', endColorstr='#00CC9A81');
+.sp-val {
+    background-image: -webkit-gradient(linear, 0 100%, 0 0, from(#000000), to(rgba(204, 154, 129, 0)));
+    background-image: -webkit-linear-gradient(bottom, #000000, rgba(204, 154, 129, 0));
+    background-image: -moz-linear-gradient(bottom, #000, rgba(204, 154, 129, 0));
+    background-image: -o-linear-gradient(bottom, #000, rgba(204, 154, 129, 0));
+    background-image: -ms-linear-gradient(bottom, #000, rgba(204, 154, 129, 0));
+    background-image: linear-gradient(to top, #000, rgba(204, 154, 129, 0));
+    -ms-filter: "progid:DXImageTransform.Microsoft.gradient(startColorstr=#00CC9A81, endColorstr=#FF000000)";
+    filter : progid:DXImageTransform.Microsoft.gradient(startColorstr='#00CC9A81', endColorstr='#FF000000');
+.sp-hue {
+    background: -moz-linear-gradient(top, #ff0000 0%, #ffff00 17%, #00ff00 33%, #00ffff 50%, #0000ff 67%, #ff00ff 83%, #ff0000 100%);
+    background: -ms-linear-gradient(top, #ff0000 0%, #ffff00 17%, #00ff00 33%, #00ffff 50%, #0000ff 67%, #ff00ff 83%, #ff0000 100%);
+    background: -o-linear-gradient(top, #ff0000 0%, #ffff00 17%, #00ff00 33%, #00ffff 50%, #0000ff 67%, #ff00ff 83%, #ff0000 100%);
+    background: -webkit-gradient(linear, left top, left bottom, from(#ff0000), color-stop(0.17, #ffff00), color-stop(0.33, #00ff00), color-stop(0.5, #00ffff), color-stop(0.67, #0000ff), color-stop(0.83, #ff00ff), to(#ff0000));
+    background: -webkit-linear-gradient(top, #ff0000 0%, #ffff00 17%, #00ff00 33%, #00ffff 50%, #0000ff 67%, #ff00ff 83%, #ff0000 100%);
+/* IE filters do not support multiple color stops.
+   Generate 6 divs, line them up, and do two color gradients for each.
+   Yes, really.
+.sp-1 {
+    height:17%;
+    filter: progid:DXImageTransform.Microsoft.gradient(startColorstr='#ff0000', endColorstr='#ffff00');
+.sp-2 {
+    height:16%;
+    filter: progid:DXImageTransform.Microsoft.gradient(startColorstr='#ffff00', endColorstr='#00ff00');
+.sp-3 {
+    height:17%;
+    filter: progid:DXImageTransform.Microsoft.gradient(startColorstr='#00ff00', endColorstr='#00ffff');
+.sp-4 {
+    height:17%;
+    filter: progid:DXImageTransform.Microsoft.gradient(startColorstr='#00ffff', endColorstr='#0000ff');
+.sp-5 {
+    height:16%;
+    filter: progid:DXImageTransform.Microsoft.gradient(startColorstr='#0000ff', endColorstr='#ff00ff');
+.sp-6 {
+    height:17%;
+    filter: progid:DXImageTransform.Microsoft.gradient(startColorstr='#ff00ff', endColorstr='#ff0000');
+.sp-hidden {
+    display: none !important;
+/* Clearfix hack */
+.sp-cf:before, .sp-cf:after { content: ""; display: table; }
+.sp-cf:after { clear: both; }
+.sp-cf { *zoom: 1; }
+/* Mobile devices, make hue slider bigger so it is easier to slide */
+ at media (max-device-width: 480px) {
+    .sp-color { right: 40%; }
+    .sp-hue { left: 63%; }
+    .sp-fill { padding-top: 60%; }
+.sp-dragger {
+   border-radius: 5px;
+   height: 5px;
+   width: 5px;
+   border: 1px solid #fff;
+   background: #000;
+   cursor: pointer;
+   top:0;
+   left: 0;
+.sp-slider {
+    top:0;
+    cursor:pointer;
+    height: 3px;
+    left: -1px;
+    right: -1px;
+    border: 1px solid #000;
+    opacity: .8;
+Theme authors:
+Here are the basic themeable display options (colors, fonts, global widths).
+See http://bgrins.github.io/spectrum/themes/ for instructions.
+.sp-container {
+    border-radius: 0;
+    background-color: #ECECEC;
+    border: solid 1px #f0c49B;
+    padding: 0;
+.sp-container, .sp-container button, .sp-container input, .sp-color, .sp-hue, .sp-clear
+    font: normal 12px "Lucida Grande", "Lucida Sans Unicode", "Lucida Sans", Geneva, Verdana, sans-serif;
+    -webkit-box-sizing: border-box;
+    -moz-box-sizing: border-box;
+    -ms-box-sizing: border-box;
+    box-sizing: border-box;
+.sp-top
+    margin-bottom: 3px;
+.sp-color, .sp-hue, .sp-clear
+    border: solid 1px #666;
+/* Input */
+.sp-input-container {
+    float:right;
+    width: 100px;
+    margin-bottom: 4px;
+.sp-initial-disabled  .sp-input-container {
+    width: 100%;
+.sp-input {
+   font-size: 12px !important;
+   border: 1px inset;
+   padding: 4px 5px;
+   margin: 0;
+   width: 100%;
+   background:transparent;
+   border-radius: 3px;
+   color: #222;
+.sp-input:focus  {
+    border: 1px solid orange;
+.sp-input.sp-validation-error
+    border: 1px solid red;
+    background: #fdd;
+.sp-picker-container , .sp-palette-container
+    float:left;
+    padding: 10px;
+    padding-bottom: 300px;
+    margin-bottom: -290px;
+    width: 172px;
+    border-left: solid 1px #fff;
+/* Palettes */
+.sp-palette-container
+    border-right: solid 1px #ccc;
+.sp-palette .sp-thumb-el {
+    display: block;
+    float:left;
+    width: 24px;
+    height: 15px;
+    margin: 3px;
+    cursor: pointer;
+    border:solid 2px transparent;
+.sp-palette .sp-thumb-el:hover, .sp-palette .sp-thumb-el.sp-thumb-active {
+    border-color: orange;
+.sp-thumb-el
+/* Initial */
+.sp-initial
+    float: left;
+.sp-initial span {
+    width: 30px;
+    height: 25px;
+    border:none;
+    display:block;
+    float:left;
+    margin:0;
+.sp-initial .sp-clear-display {
+/* Buttons */
+.sp-button-container {
+    float: right;
+/* Replacer (the little preview div that shows up instead of the <input>) */
+.sp-replacer {
+    margin:0;
+    overflow:hidden;
+    cursor:pointer;
+    padding: 4px;
+    *zoom: 1;
+    *display: inline;
+    border: solid 1px #91765d;
+    background: #eee;
+    color: #333;
+    vertical-align: middle;
+.sp-replacer:hover, .sp-replacer.sp-active {
+    border-color: #F0C49B;
+    color: #111;
+.sp-replacer.sp-disabled {
+    cursor:default;
+    border-color: silver;
+    color: silver;
+.sp-dd {
+    padding: 2px 0;
+    height: 16px;
+    line-height: 16px;
+    float:left;
+    font-size:10px;
+.sp-preview
+    width:25px;
+    height: 20px;
+    border: solid 1px #222;
+    margin-right: 5px;
+    float:left;
+    z-index: 0;
+.sp-palette
+    *width: 220px;
+    max-width: 220px;
+    width:16px;
+    height: 16px;
+    margin:2px 1px;
+    border: solid 1px #d0d0d0;
+.sp-container
+    padding-bottom:0;
+/* Buttons: http://hellohappy.org/css3-buttons/ */
+.sp-container button {
+  background-color: #eeeeee;
+  background-image: -webkit-linear-gradient(top, #eeeeee, #cccccc);
+  background-image: -moz-linear-gradient(top, #eeeeee, #cccccc);
+  background-image: -ms-linear-gradient(top, #eeeeee, #cccccc);
+  background-image: -o-linear-gradient(top, #eeeeee, #cccccc);
+  background-image: linear-gradient(to bottom, #eeeeee, #cccccc);
+  border: 1px solid #ccc;
+  border-bottom: 1px solid #bbb;
+  color: #333;
+  font-size: 14px;
+  line-height: 1;
+  padding: 5px 4px;
+  text-align: center;
+  text-shadow: 0 1px 0 #eee;
+.sp-container button:hover {
+    background-color: #dddddd;
+    background-image: -webkit-linear-gradient(top, #dddddd, #bbbbbb);
+    background-image: -moz-linear-gradient(top, #dddddd, #bbbbbb);
+    background-image: -ms-linear-gradient(top, #dddddd, #bbbbbb);
+    background-image: -o-linear-gradient(top, #dddddd, #bbbbbb);
+    background-image: linear-gradient(to bottom, #dddddd, #bbbbbb);
+    border: 1px solid #bbb;
+    border-bottom: 1px solid #999;
+    cursor: pointer;
+    text-shadow: 0 1px 0 #ddd;
+.sp-container button:active {
+    border: 1px solid #aaa;
+    border-bottom: 1px solid #888;
+    -webkit-box-shadow: inset 0 0 5px 2px #aaaaaa, 0 1px 0 0 #eeeeee;
+    -moz-box-shadow: inset 0 0 5px 2px #aaaaaa, 0 1px 0 0 #eeeeee;
+    -ms-box-shadow: inset 0 0 5px 2px #aaaaaa, 0 1px 0 0 #eeeeee;
+    -o-box-shadow: inset 0 0 5px 2px #aaaaaa, 0 1px 0 0 #eeeeee;
+    box-shadow: inset 0 0 5px 2px #aaaaaa, 0 1px 0 0 #eeeeee;
+.sp-cancel
+    font-size: 11px;
+    color: #d93f3f !important;
+    margin:0;
+    padding:2px;
+    text-decoration:none;
+.sp-cancel:hover
+    text-decoration: underline;
+.sp-palette span:hover, .sp-palette span.sp-thumb-active
+    border-color: #000;
+.sp-preview, .sp-alpha, .sp-thumb-el
+    background-image: url(data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAAwAAAAMCAIAAADZF8uwAAAAGUlEQVQYV2M4gwH+YwCGIasIUwhT25BVBADtzYNYrHvv4gAAAABJRU5ErkJggg==);
+.sp-preview-inner, .sp-alpha-inner, .sp-thumb-inner
+    display:block;
+    top:0;left:0;bottom:0;right:0;
+.sp-palette .sp-thumb-inner
+    background-position: 50% 50%;
+    background-repeat: no-repeat;
+.sp-palette .sp-thumb-light.sp-thumb-active .sp-thumb-inner
+    background-image: url(data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAABIAAAASCAYAAABWzo5XAAAAGXRFWHRTb2Z0d2FyZQBBZG9iZSBJbWFnZVJlYWR5ccllPAAAAIVJREFUeNpiYBhsgJFMffxAXABlN5JruT4Q3wfi/0DsT64h8UD8HmpIPCWG/KemIfOJCUB+Aoacx6EGBZyHBqI+WsDCwuQ9mhxeg2A210Ntfo8klk9sOMijaURm7yc1UP2RNCMbKE9ODK1HM6iegYLkfx8pligC9lCD7KmRof0ZhjQACDAAceovrtpVBRkAAAAASUVORK5CYII=);
+.sp-palette .sp-thumb-dark.sp-thumb-active .sp-thumb-inner
+    background-image: url(data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAABIAAAASCAYAAABWzo5XAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAAadEVYdFNvZnR3YXJlAFBhaW50Lk5FVCB2My41LjEwMPRyoQAAAMdJREFUOE+tkgsNwzAMRMugEAahEAahEAZhEAqlEAZhEAohEAYh81X2dIm8fKpEspLGvudPOsUYpxE2BIJCroJmEW9qJ+MKaBFhEMNabSy9oIcIPwrB+afvAUFoK4H0tMaQ3XtlrggDhOVVMuT4E5MMG0FBbCEYzjYT7OxLEvIHQLY2zWwQ3D+9luyOQTfKDiFD3iUIfPk8VqrKjgAiSfGFPecrg6HN6m/iBcwiDAo7WiBeawa+Kwh7tZoSCGLMqwlSAzVDhoK+6vH4G0P5wdkAAAAASUVORK5CYII=);
+.sp-clear-display {
+    background-repeat:no-repeat;
+    background-image: url(data:image/gif;base64,R0lGODlhFAAUAPcAAAAAAJmZmZ2dnZ6enqKioqOjo6SkpKWlpaampqenp6ioqKmpqaqqqqurq/Hx8fLy8vT09PX19ff39/j4+Pn5+fr6+vv7+wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
 AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH5BAEAAP8ALAAAAAAUABQAAAihAP9FoPCvoMGDBy08+EdhQAIJCCMybCDAAYUEARBAlFiQQoMABQhKUJBxY0SPICEYHBnggEmDKAuoPMjS5cGYMxHW3IiT478JJA8M/CjTZ0GgLRekNGpwAsYABHIypcAgQMsITDtWJYBR6NSqMico9cqR6tKfY7GeBCuVwlipDNmefAtTrkSzB1RaIAoXodsABiZAEFB06gIBWC1mLVgBa0AAOw==);
More information about the Mapbender_commits mailing list
