[Mapbender-commits] r8886 - in trunk/mapbender: http/php lib
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed May 21 05:29:21 PDT 2014
Author: hwbllmnn
Date: 2014-05-21 05:29:21 -0700 (Wed, 21 May 2014)
New Revision: 8886
Added:
   trunk/mapbender/http/php/transformgeojson.php
   trunk/mapbender/lib/mb.ui.displayKmlFeatures.js
use server side transformation for geometries for better accuracy
Added: trunk/mapbender/http/php/transformgeojson.php
--- trunk/mapbender/http/php/transformgeojson.php	                        (rev 0)
+++ trunk/mapbender/http/php/transformgeojson.php	2014-05-21 12:29:21 UTC (rev 8886)
@@ -0,0 +1,84 @@
+<?php
+# http://www.mapbender.org/index.php/Administration
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+header("Content-Type: application/json");
+$json = file_get_contents("php://input");
+try {
+    $json = json_decode($json);
+    $epsg = explode(':', $_GET["targetEPSG"]);
+    $epsg = $epsg[1];
+    $gui_id = Mapbender::session()->get("mb_user_gui");
+    $con = db_connect($DBSERVER,$OWNER,$PW);
+    db_select_db(DB,$con);
+    foreach($json as $feat) {
+        if(preg_match('/point/i', $feat->geometry->type)) {
+            $sql = "SELECT st_asgeojson(st_transform(st_setsrid(st_geomfromtext($1), 4326), $2)) as geom";
+            $v = array('POINT(' . $feat->geometry->coordinates[0] . ' ' . $feat->geometry->coordinates[1] . ')', $epsg);
+            $t = array('s', 'i');
+            $res = db_prep_query($sql,$v,$t);
+            db_fetch_row($res);
+            $geom = json_decode(db_result($res, 0, 'geom'));
+            $feat->geometry = $geom;
+        if(preg_match('/linestring/i', $feat->geometry->type)) {
+            $geom = 'LINESTRING(';
+            $coords = array();
+            foreach($feat->geometry->coordinates as $coord) {
+                $coords[] = $coord[0] . ' ' . $coord[1];
+            $geom = $geom . implode(',', $coords) . ')';
+            $v = array($geom, $epsg);
+        if(preg_match('/polygon/i', $feat->geometry->type)) {
+            $geom = 'POLYGON((';
+            foreach($feat->geometry->coordinates[0] as $coord) {
+            $geom = $geom . implode(',', $coords) . '))';
+    $json = json_encode($json);
+    echo($json);
+} catch (Exception $e) {
+    echo($e);
+    die;
Modified: trunk/mapbender/lib/mb.ui.displayKmlFeatures.js
--- trunk/mapbender/lib/mb.ui.displayKmlFeatures.js	2014-05-20 14:51:36 UTC (rev 8885)
+++ trunk/mapbender/lib/mb.ui.displayKmlFeatures.js	2014-05-21 12:29:21 UTC (rev 8886)
@@ -43,6 +43,7 @@
     wgs84: new Proj4js.Proj('EPSG:4326'),
     targetProj: new Proj4js.Proj('EPSG:25832'),
     _kmls: {},
+    cache: {},
     kmlOrder: [],
     _popup : null,
     _create: function(){
@@ -160,6 +161,7 @@
     addGeometry: function(pts, url, attributesDialog) {
+        this.cache = {};
         var $map = $(this.element).mapbender();
         var self = this;
         var tp = pts.closedPolygon ? geomType.polygon : (pts.closedLine ? geomType.line : geomType.point);
@@ -335,7 +337,6 @@
                   y: feature.geometry.coordinates[1]};
         if(isNaN(pt.x) || isNaN(pt.y)) return;
         if(!feature.preview) {
-            pt = Proj4js.transform(this.wgs84, this.targetProj, pt);
             pt = $('#mapframe1').mapbender().convertRealToPixel(pt);
@@ -371,7 +372,6 @@
         $.each(feature.geometry.coordinates, function(_, v) {
             var pt = {x: v[0], y: v[1]};
-                pt = Proj4js.transform(self.wgs84, self.targetProj, pt);
                 pt = map.convertRealToPixel(pt);
@@ -392,7 +392,6 @@
         $.each(feature.geometry.coordinates[0], function(_, v) {
@@ -471,9 +470,32 @@
         var canvas = Raphael(target, map.getWidth(), map.getHeight());
         $.each(this.kmlOrder, function(_, url) {
             var item = self._kmls[url];
-            if(item && item.display) {
-                $.each(item.data.features, $.proxy(self, self.renderFeature(canvas)));
+            var feats = item.data.features;
+            if(!map.getSrs().match(/:4326/)) {
+                if(!self.cache[url]) {
+                    self.cache[url] = {};
+                feats = self.cache[url][map.getSrs()];
+                if(!feats) {
+                    $.ajax({
+                        url: '../php/transformgeojson.php?targetEPSG=' + map.getSrs(),
+                        type: 'POST',
+                        data: JSON.stringify(item.data.features),
+                        success: function(data) {
+                            if(!$.isArray(data)) {
+                                data = JSON.parse(data);
+                            self.cache[url][map.getSrs()] = data;
+                            self.render();
+            if(item.display && feats) {
+                $.each(feats, $.proxy(self, self.renderFeature(canvas)));
More information about the Mapbender_commits mailing list
