[Mapbender-commits] r9337 - trunk/mapbender/http/geoportal/xslt
svn_mapbender at osgeo.org
Wed Dec 16 08:48:02 PST 2015
Author: armin11
Date: 2015-12-16 08:48:02 -0800 (Wed, 16 Dec 2015)
New Revision: 9337
trunk/mapbender/http/geoportal/xslt/iso-19139-to-dcat-ap.xsl
New version of xslt from 2015-11-21, see https://webgate.ec.europa.eu/CITnet/stash/projects/ODCKAN/repos/iso-19139-to-dcat-ap/commits
Modified: trunk/mapbender/http/geoportal/xslt/iso-19139-to-dcat-ap.xsl
--- trunk/mapbender/http/geoportal/xslt/iso-19139-to-dcat-ap.xsl 2015-12-11 11:13:45 UTC (rev 9336)
+++ trunk/mapbender/http/geoportal/xslt/iso-19139-to-dcat-ap.xsl 2015-12-16 16:48:02 UTC (rev 9337)
@@ -1,4 +1,5 @@
Copyright 2015 EUROPEAN UNION
@@ -24,6 +25,7 @@
(http://ec.europa.eu/isa/actions/01-trusted-information-exchange/1-17action_en.htm).
PURPOSE AND USAGE
@@ -39,10 +41,43 @@
related work in the framework of INSPIRE and the EU ISA Programme.
-<xsl:transform xmlns:xsl="http://www.w3.org/1999/XSL/Transform" xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#" xmlns:rdfs="http://www.w3.org/2000/01/rdf-schema#" xmlns:owl="http://www.w3.org/2002/07/owl#" xmlns:skos="http://www.w3.org/2004/02/skos/core#" xmlns:cnt="http://www.w3.org/2011/content#" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:dct="http://purl.org/dc/terms/" xmlns:dctype="http://purl.org/dc/dcmitype/" xmlns:dcam="http://purl.org/dc/dcam/" xmlns:time="http://www.w3.org/2006/time#" xmlns:earl="http://www.w3.org/ns/earl#" xmlns:dcat="http://www.w3.org/ns/dcat#" xmlns:foaf="http://xmlns.com/foaf/0.1/" xmlns:wdrs="http://www.w3.org/2007/05/powder-s#" xmlns:prov="http://www.w3.org/ns/prov#" xmlns:vcard="http://www.w3.org/2006/vcard/ns#" xmlns:adms="http://www.w3.org/ns/adms#" xmlns:gsp="http://www.opengis.net/ont/geosparql#" xmlns:ecodp="http://ec.europa.eu/open-data/ontologies/ec-odp#" xmlns:locn="http://www.w3.org/ns/locn#" xmlns:gmd="http://www.isotc211.org
/2005/gmd" xmlns:gmx="http://www.isotc211.org/2005/gmx" xmlns:gco="http://www.isotc211.org/2005/gco" xmlns:srv="http://www.isotc211.org/2005/srv" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:gml="http://www.opengis.net/gml" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:ns9="http://inspire.ec.europa.eu/schemas/geoportal/1.0" xmlns:i="http://inspire.ec.europa.eu/schemas/common/1.0" xmlns:schema="http://schema.org/" version="1.0">
- <xsl:output method="xml" indent="yes" encoding="utf-8" cdata-section-elements="locn:geometry"/>
+<xsl:transform
+ xmlns:xsl = "http://www.w3.org/1999/XSL/Transform"
+ xmlns:rdf = "http://www.w3.org/1999/02/22-rdf-syntax-ns#"
+ xmlns:rdfs = "http://www.w3.org/2000/01/rdf-schema#"
+ xmlns:owl = "http://www.w3.org/2002/07/owl#"
+ xmlns:skos = "http://www.w3.org/2004/02/skos/core#"
+ xmlns:cnt = "http://www.w3.org/2011/content#"
+ xmlns:dc = "http://purl.org/dc/elements/1.1/"
+ xmlns:dct = "http://purl.org/dc/terms/"
+ xmlns:dctype = "http://purl.org/dc/dcmitype/"
+ xmlns:earl = "http://www.w3.org/ns/earl#"
+ xmlns:dcat = "http://www.w3.org/ns/dcat#"
+ xmlns:foaf = "http://xmlns.com/foaf/0.1/"
+ xmlns:wdrs = "http://www.w3.org/2007/05/powder-s#"
+ xmlns:prov = "http://www.w3.org/ns/prov#"
+ xmlns:vcard = "http://www.w3.org/2006/vcard/ns#"
+ xmlns:adms = "http://www.w3.org/ns/adms#"
+ xmlns:gsp = "http://www.opengis.net/ont/geosparql#"
+ xmlns:locn = "http://www.w3.org/ns/locn#"
+ xmlns:gmd = "http://www.isotc211.org/2005/gmd"
+ xmlns:gmx = "http://www.isotc211.org/2005/gmx"
+ xmlns:gco = "http://www.isotc211.org/2005/gco"
+ xmlns:srv = "http://www.isotc211.org/2005/srv"
+ xmlns:xsi = "http://www.w3.org/2001/XMLSchema-instance"
+ xmlns:gml = "http://www.opengis.net/gml"
+ xmlns:xlink = "http://www.w3.org/1999/xlink"
+ xmlns:ns9 = "http://inspire.ec.europa.eu/schemas/geoportal/1.0"
+ xmlns:i = "http://inspire.ec.europa.eu/schemas/common/1.0"
+ xmlns:schema = "http://schema.org/"
+ version="1.0">
+ <xsl:output method="xml"
+ indent="yes"
+ encoding="utf-8"
+ cdata-section-elements="locn:geometry" />
Mapping parameters
@@ -66,11 +101,10 @@
<!-- Uncomment to use GeoDCAT-AP Core -->
-<!-- <xsl:param name="profile">core</xsl:param> -->
+ <xsl:param name="profile">core</xsl:param>
<!-- Uncomment to use GeoDCAT-AP Extended -->
<xsl:param name="profile">extended</xsl:param>
@@ -79,18 +113,37 @@
+<!-- Variables to be used to convert strings into lower/uppercase by using the translate() function. -->
+ <xsl:variable name="lowercase">abcdefghijklmnopqrstuvwxyz</xsl:variable>
+ <xsl:variable name="uppercase">ABCDEFGHIJKLMNOPQRSTUVWXYZ</xsl:variable>
+<!-- URIs and URNs for spatial reference system registers. -->
+ <xsl:param name="EpsgSrsBaseUri">http://www.opengis.net/def/crs/EPSG/0/</xsl:param>
+ <xsl:param name="EpsgSrsBaseUrn">urn:ogc:def:crs:EPSG</xsl:param>
+ <xsl:param name="OgcSrsBaseUri">http://www.opengis.net/def/crs/OGC/</xsl:param>
+ <xsl:param name="OgcSrsBaseUrn">urn:ogc:def:crs:OGC</xsl:param>
+<!-- URI and URN for CRS84. -->
+ <xsl:param name="Crs84Uri" select="concat($OgcSrsBaseUri,'1.3/CRS84')"/>
+ <xsl:param name="Crs84Urn" select="concat($OgcSrsBaseUrn,':1.3:CRS84')"/>
+<!-- URI and URN for ETRS89. -->
+ <xsl:param name="Etrs89Uri" select="concat($EpsgSrsBaseUri,'4258')"/>
+ <xsl:param name="Etrs89Urn" select="concat($EpsgSrsBaseUrn,'::4258')"/>
<!-- URI and URN of the spatial reference system (SRS) used in the bounding box.
The default SRS is CRS84. If a different SRS is used, also parameter
$SrsAxisOrder must be specified. -->
-<!-- Old param
- <xsl:param name="srid">4326</xsl:param>
<!-- The SRS URI is used in the WKT and GML encodings of the bounding box. -->
- <xsl:param name="SrsUri">http://www.opengis.net/def/crs/OGC/1.3/CRS84</xsl:param>
+ <xsl:param name="SrsUri" select="$Crs84Uri"/>
<!-- The SRS URN is used in the GeoJSON encoding of the bounding box. -->
- <xsl:param name="SrsUrn">urn:ogc:def:crs:OGC:1.3:CRS84</xsl:param>
+ <xsl:param name="SrsUrn" select="$Crs84Urn"/>
<!-- Axis order for the reference SRS:
- "LonLat": longitude / latitude
@@ -151,6 +204,10 @@
<xsl:param name="SpatialRepresentationTypeCodelistUri" select="concat($INSPIRECodelistUri,'SpatialRepresentationTypeCode')"/>
<xsl:param name="MaintenanceFrequencyCodelistUri" select="concat($INSPIRECodelistUri,'MaintenanceFrequencyCode')"/>
+<!-- INSPIRE glossary URI -->
+ <xsl:param name="INSPIREGlossaryUri">http://inspire.ec.europa.eu/glossary/</xsl:param>
Master template
@@ -247,6 +304,9 @@
<xsl:when test="$ormlang = 'gle'">
<xsl:text>ga</xsl:text>
</xsl:when>
+ <xsl:when test="$ormlang = 'hrv'">
+ <xsl:text>hr</xsl:text>
+ </xsl:when>
<xsl:when test="$ormlang = 'ita'">
<xsl:text>it</xsl:text>
</xsl:when>
@@ -329,6 +389,9 @@
<xsl:when test="$orrlang = 'gle'">
</xsl:when>
+ <xsl:when test="$orrlang = 'hrv'">
+ </xsl:when>
<xsl:when test="$orrlang = 'ita'">
</xsl:when>
@@ -372,7 +435,7 @@
</xsl:param>
<xsl:param name="ResourceType">
- <xsl:value-of select="gmd:dataQualityInfo/gmd:DQ_DataQuality/gmd:scope/gmd:DQ_Scope/gmd:level/gmd:MD_ScopeCode/@codeListValue"/>
+ <xsl:value-of select="gmd:hierarchyLevel/gmd:MD_ScopeCode/@codeListValue"/>
</xsl:param>
<xsl:param name="ServiceType">
@@ -509,6 +572,7 @@
<xsl:variable name="explanation">
<xsl:value-of select="../../gmd:explanation/gco:CharacterString"/>
</xsl:variable>
+ <xsl:variable name="Activity">
<prov:Activity>
<xsl:if test="$ResourceUri != ''">
<prov:used rdf:resource="{$ResourceUri}"/>
@@ -541,6 +605,17 @@
</xsl:if>
</prov:generated>
</prov:Activity>
+ </xsl:variable>
+ <xsl:choose>
+ <xsl:when test="$ResourceUri != ''">
+ <xsl:copy-of select="$Activity"/>
+ </xsl:when>
+ <xsl:otherwise>
+ <prov:wasUsedBy>
+ </prov:wasUsedBy>
+ </xsl:otherwise>
+ </xsl:choose>
</xsl:for-each>
</xsl:param>
@@ -559,13 +634,16 @@
<!-- Metadata description (metadata on metadata) -->
<xsl:param name="MetadataDescription">
- <rdf:type rdf:resource="{$dcat}CatalogRecord"/>
<!-- Metadata language -->
- <dct:language rdf:resource="{concat($oplang,translate($ormlang,'abcdefghijklmnopqrstuvwxyz','ABCDEFGHIJKLMNOPQRSTUVWXYZ'))}"/>
+ <xsl:if test="$ormlang != ''">
+ <dct:language rdf:resource="{concat($oplang,translate($ormlang,$lowercase,$uppercase))}"/>
+ </xsl:if>
<!-- Metadata date -->
- <dct:modified rdf:datatype="{$xsd}date">
- <xsl:value-of select="$MetadataDate"/>
- </dct:modified>
+ <xsl:if test="$MetadataDate != ''">
+ <dct:modified rdf:datatype="{$xsd}date">
+ <xsl:value-of select="$MetadataDate"/>
+ </dct:modified>
+ </xsl:if>
<!-- Metadata point of contact: only for the extended profile -->
<xsl:if test="$profile = 'extended'">
<xsl:apply-templates select="gmd:contact/gmd:CI_ResponsibleParty">
@@ -698,13 +776,13 @@
<xsl:if test="$ResourceType = 'dataset' or $ResourceType = 'series'">
<xsl:choose>
<xsl:when test="$orrlang != ''">
- <dct:language rdf:resource="{concat($oplang,translate($orrlang,'abcdefghijklmnopqrstuvwxyz','ABCDEFGHIJKLMNOPQRSTUVWXYZ'))}"/>
+ <dct:language rdf:resource="{concat($oplang,translate($orrlang,$lowercase,$uppercase))}"/>
</xsl:when>
<xsl:otherwise>
<!-- To be decided (when the resource language is not specified, it defaults to the metadata language): -->
</xsl:if>
</xsl:otherwise>
@@ -732,7 +810,7 @@
<!-- Creation date, publication date, date of last revision -->
<xsl:apply-templates select="gmd:identificationInfo/*/gmd:citation/gmd:CI_Citation"/>
<!-- Lineage -->
- <xsl:if test="$ResourceType != 'service'">
+ <xsl:if test="$ResourceType != 'service' and $Lineage != ''">
<dct:provenance>
<dct:ProvenanceStatement>
<rdfs:label xml:lang="{$MetadataLanguage}">
@@ -844,15 +922,19 @@
<xsl:choose>
<xsl:when test="$MetadataUri != ''">
<rdf:Description rdf:about="{$MetadataUri}">
+ <rdf:type rdf:resource="{$dcat}CatalogRecord"/>
<foaf:primaryTopic rdf:resource="{$ResourceUri}"/>
<xsl:copy-of select="$MetadataDescription"/>
</rdf:Description>
</xsl:when>
<xsl:otherwise>
- <rdf:Description>
- <foaf:primaryTopic rdf:resource="{$ResourceUri}"/>
- <xsl:copy-of select="$MetadataDescription"/>
- </rdf:Description>
+ <xsl:if test="normalize-space($MetadataDescription)">
+ <rdf:Description>
+ <foaf:primaryTopic rdf:resource="{$ResourceUri}"/>
+ <xsl:copy-of select="$MetadataDescription"/>
+ </rdf:Description>
+ </xsl:if>
</xsl:otherwise>
</xsl:choose>
@@ -864,17 +946,14 @@
</xsl:when>
<xsl:otherwise>
<rdf:Description>
- <xsl:if test="$profile = 'extended'">
<foaf:isPrimaryTopicOf>
<rdf:Description>
</rdf:Description>
</foaf:isPrimaryTopicOf>
</xsl:if>
<xsl:copy-of select="$ResourceDescription"/>
</rdf:Description>
</xsl:otherwise>
@@ -1141,7 +1220,18 @@
<dcat:dataset rdf:resource="{@xlink:href}"/>
- <dct:hasPart rdf:resource="{@xlink:href}"/>
+ <xsl:choose>
+ <xsl:when test="@uriref">
+ <dct:hasPart rdf:resource="{@uriref}"/>
+ </xsl:when>
+ <xsl:when test="@xlink:href">
+ <dct:hasPart rdf:parseType="Resource">
+ <foaf:isPrimaryTopicOf>
+ <dcat:CatalogRecord rdf:about="{@xlink:href}"/>
+ </foaf:isPrimaryTopicOf>
+ </dct:hasPart>
+ </xsl:when>
+ </xsl:choose>
</xsl:template>
<!-- Spatial data service type -->
@@ -1204,9 +1294,7 @@
</xsl:if>
<xsl:if test="$Conformity != '' and $ResourceUri = ''">
- <prov:wasUsedBy>
- <xsl:copy-of select="$Conformity"/>
- </prov:wasUsedBy>
+ <xsl:copy-of select="$Conformity"/>
</xsl:if>
<xsl:choose>
@@ -1360,20 +1448,24 @@
<xsl:template name="GeographicBoundingBox" match="gmd:identificationInfo[1]/*/*[self::gmd:extent|self::srv:extent]/*/gmd:geographicElement/gmd:EX_GeographicBoundingBox">
<xsl:template name="GeographicBoundingBox" match="gmd:EX_GeographicBoundingBox">
+ <xsl:param name="north" select="gmd:northBoundLatitude/gco:Decimal"/>
+ <xsl:param name="east" select="gmd:eastBoundLongitude/gco:Decimal"/>
+ <xsl:param name="south" select="gmd:southBoundLatitude/gco:Decimal"/>
+ <xsl:param name="west" select="gmd:westBoundLongitude/gco:Decimal"/>
<!-- Bbox as a dct:Box -->
<!-- Need to check whether this is correct - in particular, the "projection" parameter -->
- <xsl:param name="DCTBox">northlimit=<xsl:value-of select="gmd:northBoundLatitude/gco:Decimal"/>; eastlimit=<xsl:value-of select="gmd:eastBoundLongitude/gco:Decimal"/>; southlimit=<xsl:value-of select="gmd:southBoundLatitude/gco:Decimal"/>; westlimit=<xsl:value-of select="gmd:westBoundLongitude/gco:Decimal"/>; projection=EPSG:<xsl:value-of select="$srid"/></xsl:param>
+ <xsl:param name="DCTBox">northlimit=<xsl:value-of select="$north"/>; eastlimit=<xsl:value-of select="$east"/>; southlimit=<xsl:value-of select="$south"/>; westlimit=<xsl:value-of select="$west"/>; projection=EPSG:<xsl:value-of select="$srid"/></xsl:param>
<!-- Bbox as GML (GeoSPARQL) -->
<xsl:param name="GMLLiteral">
<xsl:choose>
- <xsl:when test="$SrsUri = 'http://www.opengis.net/def/crs/OGC/1.3/CRS84'"><gml:Envelope srsName="<xsl:value-of select="$SrsUri"/>"><gml:lowerCorner><xsl:value-of select="gmd:westBoundLongitude/gco:Decimal"/><xsl:text> </xsl:text><xsl:value-of select="gmd:southBoundLatitude/gco:Decimal"/></gml:lowerCorner><gml:upperCorner><xsl:value-of select="gmd:eastBoundLongitude/gco:Decimal"/><xsl:text> </xsl:text><xsl:value-of select="gmd:northBoundLatitude/gco:Decimal"/></gml:upperCorner></gml:Envelope></xsl:when>
- <xsl:when test="$SrsAxisOrder = 'LonLat'"><gml:Envelope srsName="<xsl:value-of select="$SrsUri"/>"><gml:lowerCorner><xsl:value-of select="gmd:westBoundLongitude/gco:Decimal"/><xsl:text> </xsl:text><xsl:value-of select="gmd:southBoundLatitude/gco:Decimal"/></gml:lowerCorner><gml:upperCorner><xsl:value-of select="gmd:eastBoundLongitude/gco:Decimal"/><xsl:text> </xsl:text><xsl:value-of select="gmd:northBoundLatitude/gco:Decimal"/></gml:upperCorner></gml:Envelope></xsl:when>
- <xsl:when test="$SrsAxisOrder = 'LatLon'"><gml:Envelope srsName="<xsl:value-of select="$SrsUri"/>"><gml:lowerCorner><xsl:value-of select="gmd:southBoundLatitude/gco:Decimal"/><xsl:text> </xsl:text><xsl:value-of select="gmd:westBoundLongitude/gco:Decimal"/></gml:lowerCorner><gml:upperCorner><xsl:value-of select="gmd:northBoundLatitude/gco:Decimal"/><xsl:text> </xsl:text><xsl:value-of select="gmd:eastBoundLongitude/gco:Decimal"/></gml:upperCorner></gml:Envelope></xsl:when>
+ <xsl:when test="$SrsUri = 'http://www.opengis.net/def/crs/OGC/1.3/CRS84'"><gml:Envelope srsName="<xsl:value-of select="$SrsUri"/>"><gml:lowerCorner><xsl:value-of select="$west"/><xsl:text> </xsl:text><xsl:value-of select="$south"/></gml:lowerCorner><gml:upperCorner><xsl:value-of select="$east"/><xsl:text> </xsl:text><xsl:value-of select="$north"/></gml:upperCorner></gml:Envelope></xsl:when>
+ <xsl:when test="$SrsAxisOrder = 'LonLat'"><gml:Envelope srsName="<xsl:value-of select="$SrsUri"/>"><gml:lowerCorner><xsl:value-of select="$west"/><xsl:text> </xsl:text><xsl:value-of select="$south"/></gml:lowerCorner><gml:upperCorner><xsl:value-of select="$east"/><xsl:text> </xsl:text><xsl:value-of select="$north"/></gml:upperCorner></gml:Envelope></xsl:when>
+ <xsl:when test="$SrsAxisOrder = 'LatLon'"><gml:Envelope srsName="<xsl:value-of select="$SrsUri"/>"><gml:lowerCorner><xsl:value-of select="$south"/><xsl:text> </xsl:text><xsl:value-of select="$west"/></gml:lowerCorner><gml:upperCorner><xsl:value-of select="$north"/><xsl:text> </xsl:text><xsl:value-of select="$east"/></gml:upperCorner></gml:Envelope></xsl:when>
</xsl:choose>
</xsl:param>
@@ -1381,15 +1473,15 @@
<xsl:param name="WKTLiteral">
<xsl:choose>
- <xsl:when test="$SrsUri = 'http://www.opengis.net/def/crs/OGC/1.3/CRS84'">POLYGON((<xsl:value-of select="gmd:westBoundLongitude/gco:Decimal"/><xsl:text> </xsl:text><xsl:value-of select="gmd:northBoundLatitude/gco:Decimal"/>,<xsl:value-of select="gmd:eastBoundLongitude/gco:Decimal"/><xsl:text> </xsl:text><xsl:value-of select="gmd:northBoundLatitude/gco:Decimal"/>,<xsl:value-of select="gmd:eastBoundLongitude/gco:Decimal"/><xsl:text> </xsl:text><xsl:value-of select="gmd:southBoundLatitude/gco:Decimal"/>,<xsl:value-of select="gmd:westBoundLongitude/gco:Decimal"/><xsl:text> </xsl:text><xsl:value-of select="gmd:southBoundLatitude/gco:Decimal"/>,<xsl:value-of select="gmd:westBoundLongitude/gco:Decimal"/><xsl:text> </xsl:text><xsl:value-of select="gmd:northBoundLatitude/gco:Decimal"/>))</xsl:when>
- <xsl:when test="$SrsAxisOrder = 'LonLat'"><<xsl:value-of select="$SrsUri"/>> POLYGON((<xsl:value-of select="gmd:westBoundLongitude/gco:Decimal"/><xsl:text> </xsl:text><xsl:value-of select="gmd:northBoundLatitude/gco:Decimal"/>,<xsl:value-of select="gmd:eastBoundLongitude/gco:Decimal"/><xsl:text> </xsl:text><xsl:value-of select="gmd:northBoundLatitude/gco:Decimal"/>,<xsl:value-of select="gmd:eastBoundLongitude/gco:Decimal"/><xsl:text> </xsl:text><xsl:value-of select="gmd:southBoundLatitude/gco:Decimal"/>,<xsl:value-of select="gmd:westBoundLongitude/gco:Decimal"/><xsl:text> </xsl:text><xsl:value-of select="gmd:southBoundLatitude/gco:Decimal"/>,<xsl:value-of select="gmd:westBoundLongitude/gco:Decimal"/><xsl:text> </xsl:text><xsl:value-of select="gmd:northBoundLatitude/gco:Decimal"/>))</xsl:when>
- <xsl:when test="$SrsAxisOrder = 'LatLon'"><<xsl:value-of select="$SrsUri"/>> POLYGON((<xsl:value-of select="gmd:northBoundLatitude/gco:Decimal"/><xsl:text> </xsl:text><xsl:value-of select="gmd:westBoundLongitude/gco:Decimal"/>,<xsl:value-of select="gmd:northBoundLatitude/gco:Decimal"/><xsl:text> </xsl:text><xsl:value-of select="gmd:eastBoundLongitude/gco:Decimal"/>,<xsl:value-of select="gmd:southBoundLatitude/gco:Decimal"/><xsl:text> </xsl:text><xsl:value-of select="gmd:eastBoundLongitude/gco:Decimal"/>,<xsl:value-of select="gmd:southBoundLatitude/gco:Decimal"/><xsl:text> </xsl:text><xsl:value-of select="gmd:westBoundLongitude/gco:Decimal"/>,<xsl:value-of select="gmd:northBoundLatitude/gco:Decimal"/><xsl:text> </xsl:text><xsl:value-of select="gmd:westBoundLongitude/gco:Decimal"/>))</xsl:when>
+ <xsl:when test="$SrsUri = 'http://www.opengis.net/def/crs/OGC/1.3/CRS84'">POLYGON((<xsl:value-of select="$west"/><xsl:text> </xsl:text><xsl:value-of select="$north"/>,<xsl:value-of select="$east"/><xsl:text> </xsl:text><xsl:value-of select="$north"/>,<xsl:value-of select="$east"/><xsl:text> </xsl:text><xsl:value-of select="$south"/>,<xsl:value-of select="$west"/><xsl:text> </xsl:text><xsl:value-of select="$south"/>,<xsl:value-of select="$west"/><xsl:text> </xsl:text><xsl:value-of select="$north"/>))</xsl:when>
+ <xsl:when test="$SrsAxisOrder = 'LonLat'"><<xsl:value-of select="$SrsUri"/>> POLYGON((<xsl:value-of select="$west"/><xsl:text> </xsl:text><xsl:value-of select="$north"/>,<xsl:value-of select="$east"/><xsl:text> </xsl:text><xsl:value-of select="$north"/>,<xsl:value-of select="$east"/><xsl:text> </xsl:text><xsl:value-of select="$south"/>,<xsl:value-of select="$west"/><xsl:text> </xsl:text><xsl:value-of select="$south"/>,<xsl:value-of select="$west"/><xsl:text> </xsl:text><xsl:value-of select="$north"/>))</xsl:when>
+ <xsl:when test="$SrsAxisOrder = 'LatLon'"><<xsl:value-of select="$SrsUri"/>> POLYGON((<xsl:value-of select="$north"/><xsl:text> </xsl:text><xsl:value-of select="$west"/>,<xsl:value-of select="$north"/><xsl:text> </xsl:text><xsl:value-of select="$east"/>,<xsl:value-of select="$south"/><xsl:text> </xsl:text><xsl:value-of select="$east"/>,<xsl:value-of select="$south"/><xsl:text> </xsl:text><xsl:value-of select="$west"/>,<xsl:value-of select="$north"/><xsl:text> </xsl:text><xsl:value-of select="$west"/>))</xsl:when>
</xsl:choose>
</xsl:param>
<!-- Bbox as GeoJSON -->
- <xsl:param name="GeoJSONLiteral">{"type":"Polygon","crs":{"type":"name","properties":{"name":"<xsl:value-of select="$SrsUrn"/>"}},"coordinates":[[[<xsl:value-of select="gmd:westBoundLongitude/gco:Decimal"/><xsl:text>,</xsl:text><xsl:value-of select="gmd:northBoundLatitude/gco:Decimal"/>],[<xsl:value-of select="gmd:eastBoundLongitude/gco:Decimal"/><xsl:text>,</xsl:text><xsl:value-of select="gmd:northBoundLatitude/gco:Decimal"/>],[<xsl:value-of select="gmd:eastBoundLongitude/gco:Decimal"/><xsl:text>,</xsl:text><xsl:value-of select="gmd:southBoundLatitude/gco:Decimal"/>],[<xsl:value-of select="gmd:westBoundLongitude/gco:Decimal"/><xsl:text>,</xsl:text><xsl:value-of select="gmd:southBoundLatitude/gco:Decimal"/>],[<xsl:value-of select="gmd:westBoundLongitude/gco:Decimal"/><xsl:text>,</xsl:text><xsl:value-of select="gmd:northBoundLatitude/gco:Decimal"/>]]]}</xsl:param>
+ <xsl:param name="GeoJSONLiteral">{"type":"Polygon","crs":{"type":"name","properties":{"name":"<xsl:value-of select="$SrsUrn"/>"}},"coordinates":[[[<xsl:value-of select="$west"/><xsl:text>,</xsl:text><xsl:value-of select="$north"/>],[<xsl:value-of select="$east"/><xsl:text>,</xsl:text><xsl:value-of select="$north"/>],[<xsl:value-of select="$east"/><xsl:text>,</xsl:text><xsl:value-of select="$south"/>],[<xsl:value-of select="$west"/><xsl:text>,</xsl:text><xsl:value-of select="$south"/>],[<xsl:value-of select="$west"/><xsl:text>,</xsl:text><xsl:value-of select="$north"/>]]]}</xsl:param>
<dct:spatial rdf:parseType="Resource">
<!-- Recommended geometry encodings -->
<locn:geometry rdf:datatype="{$gsp}wktLiteral"><xsl:value-of select="$WKTLiteral"/></locn:geometry>
@@ -1484,7 +1576,7 @@
<xsl:when test="gco:CharacterString">
<dct:license>
<dct:LicenseDocument>
- <rdfs:label xml:lang="{$MetadataLanguage}"><xsl:value-of select="normalize-space(gmx:Anchor)"/></rdfs:label>
+ <rdfs:label xml:lang="{$MetadataLanguage}"><xsl:value-of select="normalize-space(gco:CharacterString)"/></rdfs:label>
</dct:LicenseDocument>
</dct:license>
@@ -1542,7 +1634,7 @@
</xsl:for-each>
</xsl:param>
<xsl:for-each select="gmd:keyword">
- <xsl:variable name="lckw" select="translate(gco:CharacterString,'ABCDEFGHIJKLMNOPQRSTUVWXYZ','abcdefghijklmnopqrstuvwxyz')"/>
+ <xsl:variable name="lckw" select="translate(gco:CharacterString,$uppercase,$lowercase)"/>
<xsl:choose>
<xsl:when test="$OriginatingControlledVocabulary = ''">
<xsl:choose>
@@ -1654,7 +1746,7 @@
</xsl:otherwise>
</xsl:choose>
</xsl:variable>
- <rdfs:comment xml:lang="en">Spatial resolution (distance): <xsl:value-of select="."/> <xsl:value-of select="$UoM"/></rdfs:comment>
+ <rdfs:comment xml:lang="en">Spatial resolution (distance): <xsl:value-of select="."/> <xsl:value-of select="$UoM"/></rdfs:comment>
</xsl:for-each>
<xsl:for-each select="gmd:equivalentScale/gmd:MD_RepresentativeFraction/gmd:denominator">
<rdfs:comment xml:lang="en">Spatial resolution (equivalent scale): 1:<xsl:value-of select="gco:Integer"/></rdfs:comment>
@@ -1880,37 +1972,119 @@
<xsl:param name="version" select="gmd:version/gco:CharacterString"/>
<xsl:choose>
<xsl:when test="starts-with($code, 'http://') or starts-with($code, 'https://')">
- <dct:conformsTo rdf:resource="{$code}"/>
+ <dct:conformsTo>
+ <rdf:Description rdf:about="{$code}">
+ <dct:type rdf:resource="{$INSPIREGlossaryUri}SpatialReferenceSystem"/>
+ </dct:conformsTo>
</xsl:when>
<xsl:when test="starts-with($code, 'urn:')">
- <dct:conformsTo rdf:parseType="Resource">
- <dct:identifier rdf:datatype="{$xsd}anyURI"><xsl:value-of select="$code"/></dct:identifier>
- <xsl:if test="$codespace != ''">
- <skos:inScheme>
- <skos:ConceptScheme>
- <dct:title xml:lang="{$MetadataLanguage}"><xsl:value-of select="$codespace"/></dct:title>
- </skos:ConceptScheme>
- </skos:inScheme>
- </xsl:if>
- <xsl:if test="$version != ''">
- <owl:versionInfo xml:lang="{$MetadataLanguage}"><xsl:value-of select="$version"/></owl:versionInfo>
- </xsl:if>
- </dct:conformsTo>
+ <xsl:choose>
+ <xsl:when test="starts-with(translate($code,$uppercase,$lowercase), translate($EpsgSrsBaseUrn,$uppercase,$lowercase))">
+ <xsl:variable name="srid" select="substring-after(substring-after(substring-after(substring-after(substring-after(substring-after($code,':'),':'),':'),':'),':'),':')"/>
+ <xsl:variable name="sridVersion" select="substring-before(substring-after(substring-after(substring-after(substring-after(substring-after($code,':'),':'),':'),':'),':'),':')"/>
+ <dct:conformsTo>
+ <rdf:Description rdf:about="{$EpsgSrsBaseUri}{$srid}">
+ <dct:identifier rdf:datatype="{$xsd}anyURI"><xsl:value-of select="$code"/></dct:identifier>
+ <skos:inScheme>
+ <skos:ConceptScheme rdf:about="{$EpsgSrsBaseUri}">
+ <dct:title xml:lang="en">EPSG</dct:title>
+ </skos:ConceptScheme>
+ </skos:inScheme>
+ <xsl:if test="$sridVersion != ''">
+ <owl:versionInfo xml:lang="{$MetadataLanguage}"><xsl:value-of select="$sridVersion"/></owl:versionInfo>
+ </xsl:if>
+ </dct:conformsTo>
+ </xsl:when>
+ <xsl:otherwise>
+ <dct:conformsTo rdf:parseType="Resource">
+ <xsl:if test="$codespace != ''">
+ <skos:inScheme>
+ <skos:ConceptScheme>
+ <dct:title xml:lang="{$MetadataLanguage}"><xsl:value-of select="$codespace"/></dct:title>
+ </skos:inScheme>
+ </xsl:if>
+ <xsl:if test="$version != ''">
+ <owl:versionInfo xml:lang="{$MetadataLanguage}"><xsl:value-of select="$version"/></owl:versionInfo>
+ </xsl:if>
+ </dct:conformsTo>
+ </xsl:otherwise>
+ </xsl:choose>
</xsl:when>
<xsl:otherwise>
- <skos:prefLabel xml:lang="{$MetadataLanguage}"><xsl:value-of select="$code"/></skos:prefLabel>
- <skos:inScheme>
- </skos:inScheme>
- </xsl:if>
- </xsl:if>
- </dct:conformsTo>
+ <xsl:choose>
+ <xsl:when test="$code = number($code) and (translate($codespace,$uppercase,$lowercase) = 'epsg' or starts-with(translate($codespace,$uppercase,$lowercase),translate($EpsgSrsBaseUrn,$uppercase,$lowercase)))">
+ <dct:conformsTo>
+ <rdf:Description rdf:about="{$EpsgSrsBaseUri}{$code}">
+ <dct:identifier rdf:datatype="{$xsd}anyURI"><xsl:value-of select="concat($EpsgSrsBaseUrn,':',$version,':',$code)"/></dct:identifier>
+ <skos:inScheme>
+ </skos:inScheme>
+ </xsl:if>
+ </dct:conformsTo>
+ </xsl:when>
+ <xsl:when test="translate(normalize-space(translate($code,$uppercase,$lowercase)),': ','') = 'etrs89'">
+ <dct:conformsTo>
+ <rdf:Description rdf:about="{$Etrs89Uri}">
+ <dct:identifier rdf:datatype="{$xsd}anyURI"><xsl:value-of select="$Etrs89Urn"/></dct:identifier>
+ <skos:prefLabel xml:lang="en">ETRS89 - European Terrestrial Reference System 1989</skos:prefLabel>
+ <skos:inScheme>
+ </skos:inScheme>
+ </xsl:if>
+ </dct:conformsTo>
+ </xsl:when>
+ <xsl:when test="translate(normalize-space(translate($code,$uppercase,$lowercase)),': ','') = 'crs84'">
+ <dct:conformsTo>
+ <rdf:Description rdf:about="{$Crs84Uri}">
+ <dct:identifier rdf:datatype="{$xsd}anyURI"><xsl:value-of select="$Crs84Urn"/></dct:identifier>
+ <skos:prefLabel xml:lang="en">CRS84</skos:prefLabel>
+ <skos:inScheme>
+ <skos:ConceptScheme rdf:about="{$OgcSrsBaseUri}">
+ <dct:title xml:lang="en">OGC</dct:title>
+ </skos:inScheme>
+ </xsl:if>
+ </dct:conformsTo>
+ </xsl:when>
+ <xsl:otherwise>
+ <skos:prefLabel xml:lang="{$MetadataLanguage}"><xsl:value-of select="$code"/></skos:prefLabel>
+ <skos:inScheme>
+ </skos:inScheme>
+ </xsl:if>
+ </xsl:if>
+ </dct:conformsTo>
+ </xsl:otherwise>
+ </xsl:choose>
</xsl:otherwise>
</xsl:choose>
</xsl:template>
More information about the Mapbender_commits
