[Mapbender-commits] r9153 - in trunk/mapbender/http: css php plugins
svn_mapbender at osgeo.org
Wed Feb 18 07:16:49 PST 2015
Author: syed
Date: 2015-02-18 07:16:49 -0800 (Wed, 18 Feb 2015)
New Revision: 9153
Added:
trunk/mapbender/http/php/mb_publish_wmc.php
trunk/mapbender/http/php/mb_unpublish_wmc.php
trunk/mapbender/http/css/kmltree.css
trunk/mapbender/http/php/mb_list_wmc_local_data.php
trunk/mapbender/http/plugins/kmlTree.js
add dataset-publication
Modified: trunk/mapbender/http/css/kmltree.css
--- trunk/mapbender/http/css/kmltree.css 2015-02-17 11:03:48 UTC (rev 9152)
+++ trunk/mapbender/http/css/kmltree.css 2015-02-18 15:16:49 UTC (rev 9153)
@@ -177,3 +177,28 @@
background-repeat: no-repeat;
background-position: 50% 50%;
+.kmltree-metadata-list {
+ list-style-type: none;
+.kmltree-metadata-list li {
+ cursor: pointer;
+ line-height: 22px;
+.kmltree-metadata-list li img {
+ vertical-align: middle;
+#licenseTbl td, #licenseTbl th{
+border: 1px solid rgb(211, 214, 255);
+#licenseTbl td:empty{
+border: none !important;
Modified: trunk/mapbender/http/php/mb_list_wmc_local_data.php
--- trunk/mapbender/http/php/mb_list_wmc_local_data.php 2015-02-17 11:03:48 UTC (rev 9152)
+++ trunk/mapbender/http/php/mb_list_wmc_local_data.php 2015-02-18 15:16:49 UTC (rev 9153)
@@ -20,7 +20,7 @@
$user_id = Mapbender::session()->get("mb_user_id");
-$sql = 'select wmc_id, wmc_title, wmc_timestamp, wmc_local_data_size from mb_user_wmc where wmc_has_local_data = 1 and (fkey_user_id = $1 or wmc_local_data_public = 1);';
+$sql = 'select a.wmc_id, a.wmc_local_data_public, a.wmc_title, a.wmc_timestamp, a.wmc_local_data_size, termsofuse.symbollink from mb_user_wmc a left join termsofuse on termsofuse.termsofuse_id = a.wmc_local_data_fkey_termsofuse_id where wmc_has_local_data = 1 and (fkey_user_id = $1 or wmc_local_data_public = 1);';
$v = array($user_id);
$t = array("i");
@@ -31,6 +31,8 @@
$wmc[] = $row['wmc_id'];
$wmc[] = $row['wmc_title'];
$wmc[] = $row['wmc_timestamp'];
+ $wmc[] = $row['symbollink'];
+ $wmc[] = $row['wmc_local_data_public'] == 1;
$wmc[] = $row['wmc_local_data_size'];
$wmcs[] = $wmc;
Added: trunk/mapbender/http/php/mb_publish_wmc.php
--- trunk/mapbender/http/php/mb_publish_wmc.php (rev 0)
+++ trunk/mapbender/http/php/mb_publish_wmc.php 2015-02-18 15:16:49 UTC (rev 9153)
@@ -0,0 +1,56 @@
+<?php
+ * @version Changed: ### 2015-02-12 14:11:41 UTC ###
+ * @author Raphael.Syed <raphael.syed at WhereGroup.com> http://WhereGroup.com
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+// require_once(dirname(__FILE__) . "/../classes/class_wmc.php");
+ * unpublish the the given wmc
+$user_id = Mapbender::session()->get("mb_user_id");
+$wmc_id = $_POST["wmc_id"];
+$dataMode = $_POST['mode'];
+$dataLicense = $_POST['license'];
+if($dataMode === 'getLicenseMode'){
+ $sql = 'SELECT symbollink,description,isopen FROM termsofuse WHERE name = $1';
+ $v = array($dataLicense);
+ $t = array("s");
+ header('Content-Type: application/json');
+ $res = db_prep_query($sql, $v, $t);
+ while($row = db_fetch_array($res)){
+ echo json_encode($row);
+}else if($dataMode === 'saveLicenseMode'){
+ // #1 Update wmc_local_data_public
+ $sql = 'UPDATE mb_user_wmc mb SET wmc_local_data_public = 1, wmc_local_data_fkey_termsofuse_id = t.termsofuse_id from termsofuse t WHERE mb.wmc_id = $1 AND mb.fkey_user_id = $2 AND t.name = $3';
+ $v = array($wmc_id,$user_id,$dataLicense);
+ $t = array("s","i","s");
+}else if($dataMode === 'getAllLicencesMode'){
+ $resultArray = array();
+ $sql = 'SELECT name FROM termsofuse';
+ $res = db_query($sql);
+ //echo db_fetch_array($res);
+ $resultArray[]= $row;
+ echo json_encode($resultArray);
Added: trunk/mapbender/http/php/mb_unpublish_wmc.php
--- trunk/mapbender/http/php/mb_unpublish_wmc.php (rev 0)
+++ trunk/mapbender/http/php/mb_unpublish_wmc.php 2015-02-18 15:16:49 UTC (rev 9153)
@@ -0,0 +1,37 @@
+<?php
+// $wmc = new wmc();
+// $sql = 'UPDATE mb_user_wmc SET wmc_local_data_public=0, wmc_local_data_fkey_termsofuse_id =8 WHERE wmc_id= $1 AND fkey_user_id = $2'; // $sql = 'select wmc from mb_user_wmc where wmc_id = $1 and wmc_has_local_data = 1 and fkey_user_id = $2;';
+$sql = 'UPDATE mb_user_wmc SET wmc_local_data_public=0, wmc_local_data_fkey_termsofuse_id = null WHERE wmc_id= $1 AND fkey_user_id = $2'; // $sql = 'select wmc from mb_user_wmc where wmc_id = $1 and wmc_has_local_data = 1 and fkey_user_id = $2;';
+// $sql = 'SELECT wmc_local_data_public FROM mb_user_wmc WHERE wmc_id= $1 AND fkey_user_id = $2'; // $sql = 'select wmc from mb_user_wmc where wmc_id = $1 and wmc_has_local_data = 1 and fkey_user_id = $2;';
+$v = array($wmc_id, $user_id);
+$t = array("i", "i");
+$res = db_prep_query($sql, $v, $t);
+if (!$res) {
+ return false;
+else {
+ echo true;
Modified: trunk/mapbender/http/plugins/kmlTree.js
--- trunk/mapbender/http/plugins/kmlTree.js 2015-02-17 11:03:48 UTC (rev 9152)
+++ trunk/mapbender/http/plugins/kmlTree.js 2015-02-18 15:16:49 UTC (rev 9153)
@@ -36,25 +36,25 @@
* http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
-if( typeof window.DOMParser === "undefined" ){
- window.DOMParser = function(){};
+if (typeof window.DOMParser === "undefined") {
+ window.DOMParser = function() {};
- window.DOMParser.prototype.parseFromString = function(str, contentType){
- if(typeof ActiveXObject !== 'undefined'){
+ window.DOMParser.prototype.parseFromString = function(str, contentType) {
+ if (typeof ActiveXObject !== 'undefined') {
var xmldata = new ActiveXObject('MSXML.DomDocument');
xmldata.async = false;
xmldata.loadXML(str);
return xmldata;
- } else if(typeof XMLHttpRequest !== 'undefined'){
+ } else if (typeof XMLHttpRequest !== 'undefined') {
var xmldata = new XMLHttpRequest;
- if(!contentType){
+ if (!contentType) {
contentType = 'application/xml';
xmldata.open('GET', 'data:' + contentType + ';charset=utf-8,' + encodeURIComponent(str), false);
- if(xmldata.overrideMimeType) {
+ if (xmldata.overrideMimeType) {
xmldata.overrideMimeType(contentType);
@@ -66,7 +66,7 @@
var $kmlTree = $(this);
-var KmlTree = function(o){
+var KmlTree = function(o) {
$kmlTree.children().remove();
$kmlTree.addClass('kmlTree');
var $KMLfolder = $('<li class="open kml"><ul></ul></li>');
@@ -76,115 +76,409 @@
var selectButton = $('<img id="toggle-select-features" src="../img/osgeo_graphics/geosilk/cursor.png"></img>');
- $addButton.click(function(){
- var dlg = $('<div ></div>').dialog({
- "title": "My spatial data",
- width: 450,
- height: 420,
- close: function() {
- $('#kml-load-tabs').tabs('destroy');
- $(this).html('').dialog('destroy');
- var dlgcontent = '<div id="kml-load-tabs">'
- + '<ul><li><a class="icon icon-wmc" href="#kml-from-wmc">Stored data</a></li>'
- + '<li><a class="icon icon-local" href="#kml-from-upload">Upload</a></li>'
- + '<li><a class="icon icon-remote" href="#kml-from-url">External source</a></li>'
- + '<li><a class="icon icon-new" href="#kml-new">New</a></li></ul>'
- + '<div id="kml-from-wmc">wmc</div>'
- + '<div id="kml-from-upload">'
- + '<iframe name="kml-upload-target" style="width: 0; height: 0; border: 0px;"></iframe>'
- + '<form action="../php/uploadKml.php" method="post" enctype="multipart/form-data" target="kml-upload-target">'
- + '<input type="file" name="kml"></input>'
- + '<input type="submit" class="upload" value="Upload"></input><br>'
- + 'You can upload local KML, GPX and geoJSON files here. The filename should'
- + ' have the typical file extension (.kml, .gpx or .geojson) and the size'
- + ' is limited to 250kb of data.'
- + '</div>'
- + '</form>'
- + '<div id="kml-from-url">URL: <input class="kmlurl" /><button class="add" name="add" value="add"></button><br>'
- + 'You can give an url to a datafile which is located somewhere in the www. '
- + 'Only KML, geoJSON and GPX files are supported. The files will be validated before they'
- + ' are loaded into the mapviewer.'
- + '</div>'
- + '<div id="kml-new">'
- + '<label>Title: <input type="text" name="kml-new-title"></input></label>'
- + '<button class="add-kml"></button>'
- + '</div>'
- + '</div>';
- $('#kml-load-tabs').remove();
- $(dlg).append(dlgcontent);
- $.ajax({
- type: 'get',
- url: '../php/mb_list_wmc_local_data.php',
- success: function(data) {
- $.each(data, function(_, v) {
- v[2] = new Date(v[2] * 1000);
- v[3] = Math.round(v[3] / 1024) + 'kb';
- $('#kml-from-wmc').html('<table class="display"></table>').find('table').dataTable({
- aaData: data,
- aoColumns: [{sTitle: 'ID'}, {sTitle: 'Title'}, {sTitle: 'last change'}, {sTitle: 'size'}]
- .find('tr').bind('click', function() {
- $(this).addClass('row_selected').siblings().removeClass('row_selected');
- .bind('dblclick', function() {
- var id = $($(this).find('td')[0]).text();
- $.ajax({
- type: 'post',
- url: '../php/mb_load_local_data.php',
- data: {
- id: id
- var kml = $('#mapframe1').data('kml');
- $.each(data, function(url, json) {
- kml.addLayer(url, json.data);
- $(dlg).dialog('destroy');
+ $addButton.click(function() {
+ if ($('#mySpatialData').dialog('isOpen') === true) {
+ return;
+ } else {
+ var dlg = $('<div id="mySpatialData"></div>').dialog({
+ "title": "My spatial data",
+ width: 720,
+ height: 420,
+ close: function() {
+ $('#kml-load-tabs').tabs('destroy');
+ $(this).html('').dialog('destroy');
+ // $('#mySpatialData').dialog('destroy');
+ $('#mySpatialData').remove();
+ var dlgcontent = '<div id="kml-load-tabs">' + '<ul><li><a class="icon icon-wmc" href="#kml-from-wmc">Stored data</a></li>' + '<li><a class="icon icon-local" href="#kml-from-upload">Upload</a></li>' + '<li><a class="icon icon-remote" href="#kml-from-url">External source</a></li>' + '<li><a class="icon icon-new" href="#kml-new">New</a></li></ul>' + '<div id="kml-from-wmc">wmc</div>' + '<div id="kml-from-upload">' + '<iframe name="kml-upload-target" style="width: 0; height: 0; border: 0px;"></iframe>' + '<form action="../php/uploadKml.php" method="post" enctype="multipart/form-data" target="kml-upload-target">' + '<input type="file" name="kml"></input>' + '<input type="submit" class="upload" value="Upload"></input><br>' + 'You can upload local KML, GPX and geoJSON files here. The filename should' + ' have the typical file extension (.kml, .gpx or .geojson) and the size' + ' is limited to 250kb of data.' + '</div>' + '</form>' + '<div id="kml-from-url">URL: <input cl
ass="kmlurl" /><button class="add" name="add" value="add"></button><br>' + 'You can give an url to a datafile which is located somewhere in the www. ' + 'Only KML, geoJSON and GPX files are supported. The files will be validated before they' + ' are loaded into the mapviewer.' + '</div>' + '<div id="kml-new">' + '<label>Title: <input type="text" name="kml-new-title"></input></label>' + '<button class="add-kml"></button>' + '</div>' + '</div>';
+ $('#kml-load-tabs').remove();
+ $(dlg).append(dlgcontent);
+ $.ajax({
+ type: 'get',
+ url: '../php/mb_list_wmc_local_data.php',
+ success: function(data) {
+ var origData = $.extend(true, {}, data);
+ $.each(data, function(_, v) {
+ v[2] = new Date(v[2] * 1000);
+ if (v[3]) {
+ v[3] = '<img src="' + v[3] + '"></img>';
+ if (v[4]) {
+ v[4] = '<img src="../img/osgeo_graphics/check.png"></img><img src="../img/osgeo_graphics/geosilk/link22.png"></img>';
+ } else {
+ v[4] = '<img src="../img/button_digitize/geomRemove.png"></img>';
+ v[5] = Math.round(v[5] / 1024) + 'kb';
+ $('#kml-from-wmc').html('<table class="display"></table>').find('table').dataTable({
+ aaData: data,
+ aoColumns: [{
+ sTitle: 'ID'
+ sTitle: 'Title'
+ sTitle: 'last change'
+ sTitle: 'License'
+ sTitle: 'public'
+ sTitle: 'size'
+ .find('tr').bind('click', function() {
+ var id = $($(this).find('td')[0]).text();
+ var d;
+ $.each(origData, function(_, val) {
+ if (val[0] == id) {
+ d = val;
+ var dlg = '<div title="Options ' + d[1] + '">' +
+ '<ul class="kmltree-metadata-list">' + '<li class="kmltree-metadata-delete"><img style="vertical-align: middle;" src="../img/button_digitize/geomRemove.png"></img>Delete datacollection</li>';
+ if (d[4]) {
+ dlg += '<li class="kmltree-metadata-unpublish"><img style="vertical-align: middle;" src="../img/gnome/emblem-unreadable.png"></img>Withdraw publication</li>';
+ } else {
+ dlg += '<li class="kmltree-metadata-publish"><img style="vertical-align: middle;" src="../img/gnome/share.png"></img>Publish datacollection</li>';
+ dlg += '</ul></div>';
+ dlg = $(dlg).appendTo('body');
+ $(dlg).dialog({
+ create: function() {
+ $(dlg).find('li.kmltree-metadata-delete').bind('click', function() {
+ if (confirm('Really delete spatial data set?')) {
+ $(dlg).dialog('destroy');
+ $.ajax({
+ type: 'post',
+ url: '../php/mb_delete_local_data.php',
+ data: {
+ id: id
+ if (!data.success) {
+ alert('Problem when deleting local data: ' + data.message);
+ $(dlg).find('li.kmltree-metadata-unpublish').bind('click', function() {
+ if (confirm('Really unpublish spatial data set?')) {
+ $.ajax({
+ url: '../php/mb_unpublish_wmc.php',
+ type: 'POST',
+ data: {
+ wmc_id: id
+ $('#mySpatialData').dialog('destroy');
+ $($addButton).trigger('click');
+ $(dlg).find('li.kmltree-metadata-publish').bind('click', function() {
+ var publishDialog;
+ if ($('#wmcPublishConfirm').dialog('isOpen') === true) {
+ return;
+ } else {
+ publishDialog = $('<div id="wmcPublishConfirm"></div>').dialog({
+ title: "Publish datacollection " + d[1],
+ width: 720,
+ height: 180,
+ position: {
+ my: "center",
+ at: "top",
+ of: window
+ // $('#kml-load-tabs').tabs('destroy');
+ // $(this).html('').dialog('destroy');
+ $('#wmcPublishConfirm').dialog('destroy');
+ $('#wmcPublishConfirm').remove();
+ var publishDlgContent = "<div style='font-size:16px;text-align:justify'>If you want to publish a datacolletcion, you first have to choose a license" +
+ " under which you want to distribute your data. Actually only OpenData compatible" +
+ " licences are supported in this application. Please read the licenses carefully before" +
+ " you activate this option. All of your data will be available for each person in the web" +
+ " in different formats and may be redistributed freely without any copyright. </div>" +
+ "<table style='margin-top:7px' ><tr><th id = 'publishDenied' style='width:50%;cursor:pointer'><img src='../img/button_digitize/geomRemove.png'></img> No, I dont't want to publish</th>" +
+ "<th style='width:16%;visibility:hidden'>empty</th>" +
+ "<th id = 'publishConfirmed' style='width:50%;cursor:pointer'><img src='../img/osgeo_graphics/check.png'></img> Yes, I know what I am doing </th></tr></table>";
+ $(publishDialog).append(publishDlgContent);
+ $(publishDialog).find('#publishConfirmed').bind('click', function() {
+ $(publishDialog).dialog('close');
+ // var initialLicense;
+ var chooseLicenseDialog = $('<div id="chooseLicenseDialog"></div>').dialog({
+ title: "Choose OpenData license for datacollection " + d[1],
+ width: 720,
+ height: 150,
+ position: {
+ my: "center",
+ at: "top",
+ of: window
+ $('#chooseLicenseDialog').dialog('destroy');
+ $('#chooseLicenseDialog').remove();
+ var chooseLicenseDlgCont = "<div><table id='licenseTbl'style='border-collapse: collapse'>" +
+ "<tr><th>Lizenz</th>" +
+ "<th>Logo</th><th>Beschreibung</th><th>Opendata</th></tr>" +
+ "<tr><td><select id='licenseChooser name='license'>" +
+ // "<option>Lizenz wählen</option>" +
+ // "<option>cc-by</option><option>cc-by-nc</option>" +
+ // "<option>cc-by-nd</option><option>cc-by-nc-nd</option>" +
+ // "<option>cc-by-sa</option><option>cc-by-nc-sa</option>"+
+ "</select></td>" +
+ "<td id='licenseImg'></td>" +
+ "<td id='licenseDescription'></td>" +
+ "<td id='licenseOpen'></td></tr>" + // TODO: add content for this field
+ "<tr id='submitLicense' ><td style='border:none;cursor:pointer; nowrap'><img src='../img/osgeo_graphics/check.png' style='margin-top:10px'/> <span>Publish data</span></td></tr>" +
+ "</table></div>";
+ // add options for the select box
+ $(chooseLicenseDialog).append(chooseLicenseDlgCont);
+ $.ajax({
+ url: '../php/mb_publish_wmc.php',
+ type: 'POST',
+ data: {
+ wmc_id: id,
+ mode: 'getAllLicencesMode',
+ license: 'empty'
+ for (var i = 0; i < data.length; i++) {
+ $('#licenseTbl select').append("<option>" + data[i].name + "</option>");
+ $.ajax({
+ type: 'POST',
+ data: {
+ wmc_id: id,
+ mode: 'getLicenseMode',
+ license: 'cc-by-nc-nd'
+ $('#licenseImg').html('<img src="' + data.symbollink + '" />');
+ $('#licenseDescription').html('<a href="' + data.description + '" />' + data.description + '</a>');
+ if (data.isopen == 1) {
+ $('#licenseOpen').html('<img src="../img/od_80x15_blue.png" />');
+ }else{
+ $('#licenseOpen').html('<span>No OpenData</span>');
+ // console.log(data['description']);
+ $('#licenseTbl select').bind('change', function(event) {
+ $('#licenseImg').html('');
+ $('#licenseDescription').html('');
+ $.ajax({
+ type: 'POST',
+ data: {
+ wmc_id: id,
+ license: $('#licenseTbl select').val()
+ }else{
+ $('#submitLicense').bind('click', function(event) {
+ //save the license from the choosed wmc
+ $.ajax({
+ type: 'POST',
+ data: {
+ wmc_id: id,
+ mode: 'saveLicenseMode',
+ $(publishDialog).find('#publishDenied').bind('click', function() {
+ .bind('dblclick', function() {
+ $.ajax({
+ type: 'post',
+ url: '../php/mb_load_local_data.php',
+ data: {
+ id: id
+ var kml = $('#mapframe1').data('kml');
+ $.each(data, function(url, json) {
+ kml.addLayer(url, json.data);
+ $('#kml-load-tabs').tabs();
+ $('#kml-load-tabs').find('button.add').bind('click', function() {
+ $('#mapframe1').kml({
+ url: $('#kml-load-tabs').find('.kmlurl').val()
- $('#kml-load-tabs').tabs();
- $('#kml-load-tabs').find('button.add').bind('click', function() {
- $('#mapframe1').kml({ url: $('#kml-load-tabs').find('.kmlurl').val()});
- $('#kml-load-tabs').find('button.add-kml').bind('click', function() {
- var title = $('#kml-load-tabs input[name="kml-new-title"]').val();
- if(title == '') {
- return;
- kml.addLayer(title, {features: [], type: 'FeatureCollection'});
- var ifr = $('iframe[name="kml-upload-target"]')[0];
- var onloadfun = function() {
- ifr.onload = null;
- var txt = $(this).contents().find('pre').text();
- var data;
- try {
- data = JSON.parse(txt);
- } catch(e) {
- var xml = new DOMParser().parseFromString(txt, 'application/xml');
- data = toGeoJSON.gpx(xml);
- var name = $('#kml-from-upload input[type="file"]').val();
- if(name.match(/[\\]([^\\]+)/g)) {
- name = name.match(/[\\]([^\\]+)/g);
- name = name[name.length-1];
- kml.addLayer(name, data);
- $('#kml-from-upload form').bind('submit', function() {
- ifr.onload = onloadfun;
+ $('#kml-load-tabs').find('button.add-kml').bind('click', function() {
+ var title = $('#kml-load-tabs input[name="kml-new-title"]').val();
+ if (title == '') {
+ return;
+ kml.addLayer(title, {
+ features: [],
+ type: 'FeatureCollection'
+ var ifr = $('iframe[name="kml-upload-target"]')[0];
+ var onloadfun = function() {
+ ifr.onload = null;
+ var txt = $(this).contents().find('pre').text();
+ var data;
+ try {
+ data = JSON.parse(txt);
+ } catch (e) {
+ var xml = new DOMParser().parseFromString(txt, 'application/xml');
+ data = toGeoJSON.gpx(xml);
+ var name = $('#kml-from-upload input[type="file"]').val();
+ if (name.match(/[\\]([^\\]+)/g)) {
+ name = name.match(/[\\]([^\\]+)/g);
+ name = name[name.length - 1];
+ kml.addLayer(name, data);
+ $('#kml-from-upload form').bind('submit', function() {
+ ifr.onload = onloadfun;
$KMLfolder.find('ul').before(selectButton);
$KMLfolder.find("ul").before($addButton);
@@ -205,35 +499,36 @@
- o.$target.bind('kml:loaded',function(e,obj){
+ o.$target.bind('kml:loaded', function(e, obj) {
//console.log(obj);
- var checked = obj.display ? 'checked="checked"':'';
+ var checked = obj.display ? 'checked="checked"' : '';
title = obj.url;
- if(obj.refreshing) {
+ if (obj.refreshing) {
$KMLfolder.find('ul li[title="' + title + '"]').remove();
- abbrevTitle = title.length < 20 ? title : title.substr(0,17) + "...";
- $kmlEntry = $('<li title="'+ title +'" class="open"><button class="digitize-menu-arrow"></button><button class="toggle" name="toggle" value="toggle" ></button> <input type="checkbox"'+checked +'/><a href="#">'+abbrevTitle+'</a></li>');
+ abbrevTitle = title.length < 20 ? title : title.substr(0, 17) + "...";
+ $kmlEntry = $('<li title="' + title + '" class="open"><button class="digitize-menu-arrow"></button><button class="toggle" name="toggle" value="toggle" ></button> <input type="checkbox"' + checked + '/><a href="#">' + abbrevTitle + '</a></li>');
$KMLfolder.children("ul").append($kmlEntry);
- $kmlEntry.find("a").bind("click",(function(url){return function(){
- $('#mapframe1').data('kml').zoomToLayer(url);
- })(obj.url));
+ $kmlEntry.find("a").bind("click", (function(url) {
+ return function() {
+ $('#mapframe1').data('kml').zoomToLayer(url);
+ })(obj.url));
$featureList = $("<ul />");
$kmlEntry.append($featureList);
- for(var i = obj.data.features.length - 1;i >= 0; --i){
+ for (var i = obj.data.features.length - 1; i >= 0; --i) {
var multi = obj.data.features[i].geometry.type.match(/^Multi/i);
var toggle = '';
- if(multi) {
+ if (multi) {
toggle = '<button class="toggle" name="toggle" value="toggle"></button>';
title = obj.data.features[i].properties.name;
var displ = obj.data.features[i].display === true || obj.data.features[i].display === undefined;
- $feature = $('<li idx="' + i + '" title="'+ title +'"><button class="digitize-menu-arrow"></button>' + toggle + '<input type="checkbox" ' + (displ ? 'checked="checked"' : '') + '/><div class="style-preview" style="width: 20px; height: 20px; display: inline;"></div><a href="#" >'+ abbrevTitle + '</a></li>');
+ $feature = $('<li idx="' + i + '" title="' + title + '"><button class="digitize-menu-arrow"></button>' + toggle + '<input type="checkbox" ' + (displ ? 'checked="checked"' : '') + '/><div class="style-preview" style="width: 20px; height: 20px; display: inline;"></div><a href="#" >' + abbrevTitle + '</a></li>');
$featureList.append($feature);
var preview = $feature.find('.style-preview').get(0);
@@ -241,47 +536,53 @@
- $feature.bind('mouseout',(function(jsonFeature){return function(){
- var map = o.$target.mapbender();
- var g = new GeometryArray();
- g.importGeoJSON(jsonFeature,false);
- var feature = g.get(0);
+ $feature.bind('mouseout', (function(jsonFeature) {
+ var map = o.$target.mapbender();
+ var g = new GeometryArray();
+ g.importGeoJSON(jsonFeature, false);
+ var feature = g.get(0);
- if(feature.geomType != "point"){
- var me = $kmlTree.mapbender();
- me.resultHighlight.clean();
- me.resultHighlight.paint();
- }})(obj.data.features[i]));
- $feature.bind('mouseover',(function(jsonFeature){return function(){
+ if (feature.geomType != "point") {
+ var me = $kmlTree.mapbender();
+ me.resultHighlight.clean();
+ me.resultHighlight.paint();
+ })(obj.data.features[i]));
+ $feature.bind('mouseover', (function(jsonFeature) {
- feature = feature.getBBox4();
- me.resultHighlight = new Highlight(
- [o.target],
- "KmlTreeHighlight",
- {"position":"absolute", "top":"0px", "left":"0px", "z-index":100},
- 2);
+ feature = feature.getBBox4();
+ me.resultHighlight = new Highlight(
+ [o.target],
+ "KmlTreeHighlight", {
+ "position": "absolute",
+ "top": "0px",
+ "left": "0px",
+ "z-index": 100
+ 2);
- me.resultHighlight.add(feature, "#00ff00");
- else if(feature.geomType == "point"){
+ me.resultHighlight.add(feature, "#00ff00");
+ } else if (feature.geomType == "point") {
- })(obj.data.features[i]));
$('button.digitize-layer', $kmlEntry).bind('click', function() {
var active = $(this).toggleClass('active').hasClass('active');
- if(active) {
+ if (active) {
$(this).parent().siblings().find('button.digitize-layer').removeClass('active');
@@ -311,18 +612,18 @@
- $('input[type="checkbox"]', $kmlEntry).bind('click', function(){
+ $('input[type="checkbox"]', $kmlEntry).bind('click', function() {
var idx = $(this).parent().attr('idx');
- if(idx === undefined) {
- if($(this).attr('checked')){
- o.$target.kml('show',obj.url);
- }else{
- o.$target.kml('hide',obj.url);
+ if (idx === undefined) {
+ if ($(this).attr('checked')) {
+ o.$target.kml('show', obj.url);
+ } else {
+ o.$target.kml('hide', obj.url);
} else {
- if($(this).attr('checked')) {
kml.showFeature(obj.url, idx);
} else {
kml.hideFeature(obj.url, idx);
@@ -330,11 +631,11 @@
- $("button.toggle",$kmlEntry).bind('click', function(){
- if($(this).parent().hasClass("open")){
+ $("button.toggle", $kmlEntry).bind('click', function() {
+ if ($(this).parent().hasClass("open")) {
$(this).parent().removeClass("open");
$(this).parent().addClass("closed");
- }else{
+ } else {
$(this).parent().removeClass("closed");
$(this).parent().addClass("open");
@@ -354,6 +655,6 @@
-Mapbender.events.init.register(function(){
+Mapbender.events.init.register(function() {
$kmlTree.mapbender(new KmlTree(options));
More information about the Mapbender_commits
