[Mapbender-commits] r9156 - in trunk/mapbender/http: extensions/jquery-validate geoportal plugins
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Feb 26 05:46:06 PST 2015
Author: syed
Date: 2015-02-26 05:46:06 -0800 (Thu, 26 Feb 2015)
New Revision: 9156
   trunk/mapbender/http/extensions/jquery-validate/jquery.validate.js
   trunk/mapbender/http/geoportal/mod_showPreview.php
   trunk/mapbender/http/plugins/kmlTree.js
   trunk/mapbender/http/plugins/mb_metadata_layer.js
   trunk/mapbender/http/plugins/mb_metadata_layer.php
   trunk/mapbender/http/plugins/mb_metadata_layerPreview.js
   trunk/mapbender/http/plugins/mb_metadata_wmc_edit.js
   trunk/mapbender/http/plugins/mb_metadata_wmc_edit.php
add upload preview image(saarland)
Modified: trunk/mapbender/http/extensions/jquery-validate/jquery.validate.js
--- trunk/mapbender/http/extensions/jquery-validate/jquery.validate.js	2015-02-23 15:43:43 UTC (rev 9155)
+++ trunk/mapbender/http/extensions/jquery-validate/jquery.validate.js	2015-02-26 13:46:06 UTC (rev 9156)
@@ -30,30 +30,30 @@
 		if ( validator ) {
 			return validator;
 		validator = new $.validator( options, this[0] );
-		$.data(this[0], 'validator', validator);
+		$.data(this[0], 'validator', validator);
 		if ( validator.settings.onsubmit ) {
 			// allow suppresing validation by adding a cancel class to the submit button
 			this.find("input, button").filter(".cancel").click(function() {
 				validator.cancelSubmit = true;
 			// when a submitHandler is used, capture the submitting button
 			if (validator.settings.submitHandler) {
 				this.find("input, button").filter(":submit").click(function() {
 					validator.submitButton = this;
 			// validate the form on submit
 			this.submit( function( event ) {
 				if ( validator.settings.debug )
 					// prevent form submit to be able to see console output
 					event.preventDefault();
 				function handle() {
 					if ( validator.settings.submitHandler ) {
 						if (validator.submitButton) {
@@ -69,7 +69,7 @@
 					return true;
 				// prevent submit for invalid forms or custom submit handlers
 				if ( validator.cancelSubmit ) {
 					validator.cancelSubmit = false;
@@ -87,7 +87,7 @@
 		return validator;
 	// http://docs.jquery.com/Plugins/Validation/valid
@@ -116,7 +116,7 @@
 	// http://docs.jquery.com/Plugins/Validation/rules
 	rules: function(command, argument) {
 		var element = this[0];
 		if (command) {
 			var settings = $.data(element.form, 'validator').settings;
 			var staticRules = settings.rules;
@@ -141,7 +141,7 @@
 				return filtered;
 		var data = $.validator.normalizeRules(
 		$.extend(
@@ -150,14 +150,14 @@
 			$.validator.attributeRules(element),
 			$.validator.staticRules(element)
 		), element);
 		// make sure required is at front
 		if (data.required) {
 			var param = data.required;
 			delete data.required;
 			data = $.extend({required: param}, data);
 		return data;
@@ -180,7 +180,7 @@
 $.validator.format = function(source, params) {
-	if ( arguments.length == 1 )
+	if ( arguments.length == 1 )
 		return function() {
 			var args = $.makeArray(arguments);
 			args.unshift(source);
@@ -199,7 +199,7 @@
 $.extend($.validator, {
 	defaults: {
 		messages: {},
 		groups: {},
@@ -215,7 +215,7 @@
 		ignoreTitle: false,
 		onfocusin: function(element) {
 			this.lastActive = element;
 			// hide error label and remove error class on focus if enabled
 			if ( this.settings.focusCleanup && !this.blockFocusCleanup ) {
 				this.settings.unhighlight && this.settings.unhighlight.call( this, element, this.settings.errorClass, this.settings.validClass );
@@ -272,11 +272,11 @@
 		max: $.validator.format("Please enter a value less than or equal to {0}."),
 		min: $.validator.format("Please enter a value greater than or equal to {0}.")
 	autoCreateRanges: false,
 	prototype: {
 		init: function() {
 			this.labelContainer = $(this.settings.errorLabelContainer);
 			this.errorContext = this.labelContainer.length && this.labelContainer || $(this.currentForm);
@@ -287,7 +287,7 @@
 			this.pending = {};
 			this.invalid = {};
 			this.reset();
 			var groups = (this.groups = {});
 			$.each(this.settings.groups, function(key, value) {
 				$.each(value.split(/\s/), function(index, name) {
@@ -298,11 +298,13 @@
 			$.each(rules, function(key, value) {
 				rules[key] = $.validator.normalizeRule(value);
 			function delegate(event) {
 				var validator = $.data(this[0].form, "validator"),
 					eventType = "on" + event.type.replace(/^validate/, "");
-				validator.settings[eventType] && validator.settings[eventType].call(validator, this[0] );
+				 // this fixes handling the deleted validator:
+  				if (!validator) return;
+  				validator.settings[eventType] && validator.settings[eventType].call(validator, this[0], event);
 			$(this.currentForm)
 				.validateDelegate(":text, :password, :file, select, textarea", "focusin focusout keyup", delegate)
@@ -322,15 +324,15 @@
 			this.showErrors();
 			return this.valid();
 		checkForm: function() {
 			this.prepareForm();
 			for ( var i = 0, elements = (this.currentElements = this.elements()); elements[i]; i++ ) {
 				this.check( elements[i] );
-			return this.valid();
+			return this.valid();
 		// http://docs.jquery.com/Plugins/Validation/Validator/element
 		element: function( element ) {
 			element = this.clean( element );
@@ -372,7 +374,7 @@
 				? this.settings.showErrors.call( this, this.errorMap, this.errorList )
 				: this.defaultShowErrors();
 		// http://docs.jquery.com/Plugins/Validation/Validator/resetForm
 		resetForm: function() {
 			if ( $.fn.resetForm )
@@ -382,30 +384,30 @@
 			this.hideErrors();
 			this.elements().removeClass( this.settings.errorClass );
 		numberOfInvalids: function() {
 			return this.objectLength(this.invalid);
 		objectLength: function( obj ) {
 			var count = 0;
 			for ( var i in obj )
 				count++;
 			return count;
 		hideErrors: function() {
 			this.addWrapper( this.toHide ).hide();
 		valid: function() {
 			return this.size() == 0;
 			return this.errorList.length;
 		focusInvalid: function() {
 			if( this.settings.focusInvalid ) {
 				try {
@@ -419,18 +421,18 @@
 		findLastActive: function() {
 			var lastActive = this.lastActive;
 			return lastActive && $.grep(this.errorList, function(n) {
 				return n.element.name == lastActive.name;
 			}).length == 1 && lastActive;
 		elements: function() {
 			var validator = this,
 				rulesCache = {};
 			// select all valid inputs inside the form (no submit or reset buttons)
 			// workaround $Query([]).add until http://dev.jquery.com/ticket/2114 is solved
 			return $([]).add(this.currentForm.elements)
@@ -439,24 +441,24 @@
 			.not( this.settings.ignore )
 			.filter(function() {
 				!this.name && validator.settings.debug && window.console && console.error( "%o has no name assigned", this);
 				// select only the first element for each name, and only those with rules specified
 				if ( this.name in rulesCache || !validator.objectLength($(this).rules()) )
 					return false;
 				rulesCache[this.name] = true;
 				return true;
 		clean: function( selector ) {
 			return $( selector )[0];
 		errors: function() {
 			return $( this.settings.errorElement + "." + this.settings.errorClass, this.errorContext );
 		reset: function() {
 			this.successList = [];
 			this.errorList = [];
@@ -465,32 +467,32 @@
 			this.toHide = $([]);
 			this.currentElements = $([]);
 		prepareForm: function() {
 			this.reset();
 			this.toHide = this.errors().add( this.containers );
 		prepareElement: function( element ) {
 			this.reset();
 			this.toHide = this.errorsFor(element);
 		check: function( element ) {
 			// if radio/checkbox, validate first element in group instead
 			if (this.checkable(element)) {
 				element = this.findByName( element.name )[0];
 			var rules = $(element).rules();
 			var dependencyMismatch = false;
 			for( method in rules ) {
 				var rule = { method: method, parameters: rules[method] };
 				try {
 					var result = $.validator.methods[method].call( this, element.value.replace(/\r/g, ""), element, rule.parameters );
 					// if a method indicates that the field is optional and therefore valid,
 					// don't mark it as valid when there are no other rules
 					if ( result == "dependency-mismatch" ) {
@@ -498,12 +500,12 @@
 						continue;
 					if ( result == "pending" ) {
 						this.toHide = this.toHide.not( this.errorsFor(element) );
 						return;
 					if( !result ) {
 						this.formatAndAdd( element, rule );
 						return false;
@@ -520,20 +522,20 @@
 				this.successList.push(element);
 			return true;
 		// return the custom message for the given element and validation method
 		// specified in the element's "messages" metadata
 		customMetaMessage: function(element, method) {
 			if (!$.metadata)
 				return;
 			var meta = this.settings.meta
 				? $(element).metadata()[this.settings.meta]
 				: $(element).metadata();
 			return meta && meta.messages && meta.messages[method];
 		// return the custom message for the given element name and validation method
 		customMessage: function( name, method ) {
 			var m = this.settings.messages[name];
@@ -541,7 +543,7 @@
 				? m
 				: m[method]);
 		// return the first defined argument, allowing empty strings
 		findDefined: function() {
 			for(var i = 0; i < arguments.length; i++) {
@@ -550,7 +552,7 @@
 			return undefined;
 		defaultMessage: function( element, method) {
 			return this.findDefined(
 				this.customMessage( element.name, method ),
@@ -561,7 +563,7 @@
 				"<strong>Warning: No message defined for " + element.name + "</strong>"
 		formatAndAdd: function( element, rule ) {
 			var message = this.defaultMessage( element, rule.method ),
 				theregex = /\$?\{(\d+)\}/g;
@@ -569,22 +571,22 @@
 				message = message.call(this, rule.parameters, element);
 			} else if (theregex.test(message)) {
 				message = jQuery.format(message.replace(theregex, '{$1}'), rule.parameters);
 			this.errorList.push({
 				message: message,
 				element: element
 			this.errorMap[element.name] = message;
 			this.submitted[element.name] = message;
 		addWrapper: function(toToggle) {
 			if ( this.settings.wrapper )
 				toToggle = toToggle.add( toToggle.parent( this.settings.wrapper ) );
 			return toToggle;
 		defaultShowErrors: function() {
 			for ( var i = 0; this.errorList[i]; i++ ) {
 				var error = this.errorList[i];
@@ -608,23 +610,23 @@
 			this.hideErrors();
 			this.addWrapper( this.toShow ).show();
 		validElements: function() {
 			return this.currentElements.not(this.invalidElements());
 		invalidElements: function() {
 			return $(this.errorList).map(function() {
 				return this.element;
 		showLabel: function(element, message) {
 			var label = this.errorsFor( element );
 			if ( label.length ) {
 				// refresh error/success class
 				label.removeClass().addClass( this.settings.errorClass );
 				// check if we have a generated label, replace the message then
 				label.attr("generated") && label.html(message);
 			} else {
@@ -651,14 +653,14 @@
 			this.toShow = this.toShow.add(label);
 		errorsFor: function(element) {
 			var name = this.idOrName(element);
     		return this.errors().filter(function() {
 				return $(this).attr('for') == name;
 		idOrName: function(element) {
 			return this.groups[element.name] || (this.checkable(element) ? element.name : element.id || element.name);
@@ -666,7 +668,7 @@
 		checkable: function( element ) {
 			return /radio|checkbox/i.test(element.type);
 		findByName: function( name ) {
 			// select by name and filter by form for performance over form.find("[name=...]")
 			var form = this.currentForm;
@@ -674,7 +676,7 @@
 				return element.form == form && element.name == name && element  || null;
 		getLength: function(value, element) {
 			switch( element.nodeName.toLowerCase() ) {
 			case 'select':
@@ -685,13 +687,13 @@
 			return value.length;
 		depend: function(param, element) {
 			return this.dependTypes[typeof param]
 				? this.dependTypes[typeof param](param, element)
 				: true;
 		dependTypes: {
 			"boolean": function(param, element) {
 				return param;
@@ -703,18 +705,18 @@
 				return param(element);
 		optional: function(element) {
 			return !$.validator.methods.required.call(this, $.trim(element.value), element) && "dependency-mismatch";
 		startRequest: function(element) {
 			if (!this.pending[element.name]) {
 				this.pendingRequest++;
 				this.pending[element.name] = true;
 		stopRequest: function(element, valid) {
 			this.pendingRequest--;
 			// sometimes synchronization fails, make sure pendingRequest is never < 0
@@ -729,7 +731,7 @@
 				this.formSubmitted = false;
 		previousValue: function(element) {
 			return $.data(element, "previousValue") || $.data(element, "previousValue", {
 				old: null,
@@ -737,9 +739,9 @@
 				message: this.defaultMessage( element, "remote" )
 	classRuleSettings: {
 		required: {required: true},
 		email: {email: true},
@@ -752,13 +754,13 @@
 		digits: {digits: true},
 		creditcard: {creditcard: true}
 	addClassRules: function(className, rules) {
 		className.constructor == String ?
 			this.classRuleSettings[className] = rules :
 			$.extend(this.classRuleSettings, className);
 	classRules: function(element) {
 		var rules = {};
 		var classes = $(element).attr('class');
@@ -769,35 +771,35 @@
 		return rules;
 	attributeRules: function(element) {
 		var rules = {};
 		var $element = $(element);
 		for (method in $.validator.methods) {
 			var value = $element.attr(method);
 			if (value) {
 				rules[method] = value;
 		// maxlength may be returned as -1, 2147483647 (IE) and 524288 (safari) for text inputs
 		if (rules.maxlength && /-1|2147483647|524288/.test(rules.maxlength)) {
 			delete rules.maxlength;
 		return rules;
 	metadataRules: function(element) {
 		if (!$.metadata) return {};
 		var meta = $.data(element.form, 'validator').settings.meta;
 		return meta ?
 			$(element).metadata()[meta] :
 	staticRules: function(element) {
 		var rules = {};
 		var validator = $.data(element.form, 'validator');
@@ -806,7 +808,7 @@
 		return rules;
 	normalizeRules: function(rules, element) {
 		// handle dependency check
 		$.each(rules, function(prop, val) {
@@ -832,12 +834,12 @@
 		// evaluate parameters
 		$.each(rules, function(rule, parameter) {
 			rules[rule] = $.isFunction(parameter) ? parameter(element) : parameter;
 		// clean number parameters
 		$.each(['minlength', 'maxlength', 'min', 'max'], function() {
 			if (rules[this]) {
@@ -849,7 +851,7 @@
 				rules[this] = [Number(rules[this][0]), Number(rules[this][1])];
 		if ($.validator.autoCreateRanges) {
 			// auto-create ranges
 			if (rules.min && rules.max) {
@@ -863,15 +865,15 @@
 		// To support custom messages in metadata ignore rule methods titled "messages"
 		if (rules.messages) {
 			delete rules.messages;
 		return rules;
 	// Converts a simple string to a {string: true} rule, e.g., "required" to {required:true}
 	normalizeRule: function(data) {
 		if( typeof data == "string" ) {
@@ -883,7 +885,7 @@
 		return data;
 	// http://docs.jquery.com/Plugins/Validation/Validator/addMethod
 	addMethod: function(name, method, message) {
 		$.validator.methods[name] = method;
@@ -912,20 +914,20 @@
 				return $.trim(value).length > 0;
 		// http://docs.jquery.com/Plugins/Validation/Methods/remote
 		remote: function(value, element, param) {
 			if ( this.optional(element) )
 				return "dependency-mismatch";
 			var previous = this.previousValue(element);
 			if (!this.settings.messages[element.name] )
 				this.settings.messages[element.name] = {};
 			previous.originalMessage = this.settings.messages[element.name].remote;
 			this.settings.messages[element.name].remote = previous.message;
-			param = typeof param == "string" && {url:param} || param;
+			param = typeof param == "string" && {url:param} || param;
 			if ( previous.old !== value ) {
 				previous.old = value;
 				var validator = this;
@@ -968,65 +970,65 @@
 		minlength: function(value, element, param) {
 			return this.optional(element) || this.getLength($.trim(value), element) >= param;
 		// http://docs.jquery.com/Plugins/Validation/Methods/maxlength
 		maxlength: function(value, element, param) {
 			return this.optional(element) || this.getLength($.trim(value), element) <= param;
 		// http://docs.jquery.com/Plugins/Validation/Methods/rangelength
 		rangelength: function(value, element, param) {
 			var length = this.getLength($.trim(value), element);
 			return this.optional(element) || ( length >= param[0] && length <= param[1] );
 		// http://docs.jquery.com/Plugins/Validation/Methods/min
 		min: function( value, element, param ) {
 			return this.optional(element) || value >= param;
 		max: function( value, element, param ) {
 			return this.optional(element) || value <= param;
 		range: function( value, element, param ) {
 			return this.optional(element) || ( value >= param[0] && value <= param[1] );
 		// http://docs.jquery.com/Plugins/Validation/Methods/email
 		email: function(value, element) {
 			// contributed by Scott Gonzalez: http://projects.scottsplayground.com/email_address_validation/
 			return this.optional(element) || /^((([a-z]|\d|[!#\$%&'\*\+\-\/=\?\^_`{\|}~]|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])+(\.([a-z]|\d|[!#\$%&'\*\+\-\/=\?\^_`{\|}~]|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])+)*)|((\x22)((((\x20|\x09)*(\x0d\x0a))?(\x20|\x09)+)?(([\x01-\x08\x0b\x0c\x0e-\x1f\x7f]|\x21|[\x23-\x5b]|[\x5d-\x7e]|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])|(\\([\x01-\x09\x0b\x0c\x0d-\x7f]|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF]))))*(((\x20|\x09)*(\x0d\x0a))?(\x20|\x09)+)?(\x22)))@((([a-z]|\d|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])|(([a-z]|\d|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])([a-z]|\d|-|\.|_|~|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])*([a-z]|\d|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])))\.)+(([a-z]|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])|(([a-z]|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])([a-z]|\d|-|\.|_|~|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])*([a-z]|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])))\.?$/i.test(value);
 		// http://docs.jquery.com/Plugins/Validation/Methods/url
 		url: function(value, element) {
 			// contributed by Scott Gonzalez: http://projects.scottsplayground.com/iri/
 			return this.optional(element) || /^(https?|ftp):\/\/(((([a-z]|\d|-|\.|_|~|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])|(%[\da-f]{2})|[!\$&'\(\)\*\+,;=]|:)*@)?(((\d|[1-9]\d|1\d\d|2[0-4]\d|25[0-5])\.(\d|[1-9]\d|1\d\d|2[0-4]\d|25[0-5])\.(\d|[1-9]\d|1\d\d|2[0-4]\d|25[0-5])\.(\d|[1-9]\d|1\d\d|2[0-4]\d|25[0-5]))|((([a-z]|\d|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])|(([a-z]|\d|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])([a-z]|\d|-|\.|_|~|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])*([a-z]|\d|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])))\.)+(([a-z]|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])|(([a-z]|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])([a-z]|\d|-|\.|_|~|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])*([a-z]|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])))\.?)(:\d*)?)(\/((([a-z]|\d|-|\.|_|~|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])|(%[\da-f]{2})|[!\$&'\(\)\*\+,;=]|:|@)+(\/(([a-z]|\d|-|\.|_|~|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])|(%[\da-f]{2})|[!\$&'\(\)\*\+,;=]|:|@)*)*)?)?(\?((([a-z]
 |\d|-|\.|_|~|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])|(%[\da-f]{2})|[!\$&'\(\)\*\+,;=]|:|@)|[\uE000-\uF8FF]|\/|\?)*)?(\#((([a-z]|\d|-|\.|_|~|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])|(%[\da-f]{2})|[!\$&'\(\)\*\+,;=]|:|@)|\/|\?)*)?$/i.test(value);
 		// http://docs.jquery.com/Plugins/Validation/Methods/date
 		date: function(value, element) {
 			return this.optional(element) || !/Invalid|NaN/.test(new Date(value));
 		// http://docs.jquery.com/Plugins/Validation/Methods/dateISO
 		dateISO: function(value, element) {
 			return this.optional(element) || /^\d{4}[\/-]\d{1,2}[\/-]\d{1,2}$/.test(value);
 		// http://docs.jquery.com/Plugins/Validation/Methods/number
 		number: function(value, element) {
 			return this.optional(element) || /^-?(?:\d+|\d{1,3}(?:,\d{3})+)(?:\.\d+)?$/.test(value);
 		// http://docs.jquery.com/Plugins/Validation/Methods/digits
 		digits: function(value, element) {
 			return this.optional(element) || /^\d+$/.test(value);
 		// http://docs.jquery.com/Plugins/Validation/Methods/creditcard
 		// based on http://en.wikipedia.org/wiki/Luhn
 		creditcard: function(value, element) {
@@ -1054,13 +1056,13 @@
 			return (nCheck % 10) == 0;
 		// http://docs.jquery.com/Plugins/Validation/Methods/accept
 		accept: function(value, element, param) {
 			param = typeof param == "string" ? param.replace(/,/g, '|') : "png|jpe?g|gif";
-			return this.optional(element) || value.match(new RegExp(".(" + param + ")$", "i"));
+			return this.optional(element) || value.match(new RegExp(".(" + param + ")$", "i"));
 		// http://docs.jquery.com/Plugins/Validation/Methods/equalTo
 		equalTo: function(value, element, param) {
 			// bind to the blur event of the target in order to revalidate whenever the target field is updated
@@ -1070,9 +1072,9 @@
 			return value == target.val();
 // deprecated, use $.validator.format instead
@@ -1082,7 +1084,7 @@
 // ajax mode: abort
 // usage: $.ajax({ mode: "abort"[, port: "uniqueport"]});
-// if mode:"abort" is used, the previous request on that port (port can be undefined) is aborted via XMLHttpRequest.abort()
+// if mode:"abort" is used, the previous request on that port (port can be undefined) is aborted via XMLHttpRequest.abort()
 ;(function($) {
 	var ajax = $.ajax;
 	var pendingRequests = {};
@@ -1104,14 +1106,14 @@
 // IE has native support, in other browsers, use event caputuring (neither bubbles)
 // provides delegate(type: String, delegate: Selector, handler: Callback) plugin for easier event delegation
-// handler is only called when $(event.target).is(delegate), in the scope of the jquery-object for event.target
+// handler is only called when $(event.target).is(delegate), in the scope of the jquery-object for event.target
 ;(function($) {
 	// only implement if not provided by jQuery core (since 1.4)
 	// TODO verify if jQuery 1.4's implementation is compatible with older jQuery special-event APIs
 	if (!jQuery.event.special.focusin && !jQuery.event.special.focusout && document.addEventListener) {
 		$.each({
 			focus: 'focusin',
-			blur: 'focusout'
+			blur: 'focusout'
 		}, function( original, fix ){
 			$.event.special[fix] = {
 				setup:function() {
Modified: trunk/mapbender/http/geoportal/mod_showPreview.php
--- trunk/mapbender/http/geoportal/mod_showPreview.php	2015-02-23 15:43:43 UTC (rev 9155)
+++ trunk/mapbender/http/geoportal/mod_showPreview.php	2015-02-26 13:46:06 UTC (rev 9156)
@@ -6,9 +6,9 @@
 if (isset($_REQUEST["resource"]) & $_REQUEST["resource"] != "") {
 	//validate to csv integer list
 	$testMatch = $_REQUEST["resource"];
-	if (!($testMatch == 'layer' or $testMatch == 'wmc' or $testMatch == 'layerlegend')){
-		echo 'resource: <b>'.$testMatch.'</b> is not valid.<br/>';
-		die();
+	if (!($testMatch == 'layer' or $testMatch == 'wmc' or $testMatch == 'layerlegend')){
+		echo 'resource: <b>'.$testMatch.'</b> is not valid.<br/>';
+		die();
 	$resource = $testMatch;
 	$testMatch = NULL;
@@ -16,15 +16,14 @@
 if (isset($_REQUEST["id"]) & $_REQUEST["id"] != "") {
 	//validate to integer
 	$testMatch = $_REQUEST["id"];
-	$pattern = '/^[0-9]*$/';
- 	if (!preg_match($pattern,$testMatch)){
-		echo 'id: <b>'.$testMatch.'</b> is not valid.<br/>';
-		die();
+	$pattern = '/^[0-9]*$/';
+ 	if (!preg_match($pattern,$testMatch)){
+		echo 'id: <b>'.$testMatch.'</b> is not valid.<br/>';
+		die();
 	$id = $testMatch;
 	$testMatch = NULL;
 if ($resource == 'layer'){
 	if (file_exists(PREVIEW_DIR."/".$id."_layer_map_preview.jpg")) {
 		header("Expires: -1");
@@ -32,7 +31,15 @@
 		header("Pragma: no-cache");
 		header('Content-Type: image/jpeg');
 		readfile(PREVIEW_DIR."/".$id."_layer_map_preview.jpg");
-	} else {
+	} else if (file_exists(PREVIEW_DIR."/".$id."_layer_map_preview.png")){
+		header("Expires: -1");
+		header("Cache-Control: no-cache; must-revalidate");
+		header("Pragma: no-cache");
+		header('Content-Type: image/jpeg');
+		readfile(PREVIEW_DIR."/".$id."_layer_map_preview.png");
+	}else {
 		if (file_exists(PREVIEW_DIR."/"."keinevorschau.jpg")) {
@@ -51,7 +58,15 @@
 		readfile(PREVIEW_DIR."/".$id."_wmc_preview.jpg");
-	} else {
+	} else if (file_exists(PREVIEW_DIR."/".$id."_wmc_preview.png")){
+		readfile(PREVIEW_DIR."/".$id."_wmc_preview.png");
+	}else {
@@ -71,6 +86,12 @@
 		readfile(PREVIEW_DIR."/".$id."_layer_legend_preview.jpg");
+	}else if (file_exists(PREVIEW_DIR."/".$id."_layer_legend_preview.png")) {
+		readfile(PREVIEW_DIR."/".$id."_layer_legend_preview.png");
 	} else {
Modified: trunk/mapbender/http/plugins/kmlTree.js
--- trunk/mapbender/http/plugins/kmlTree.js	2015-02-23 15:43:43 UTC (rev 9155)
+++ trunk/mapbender/http/plugins/kmlTree.js	2015-02-26 13:46:06 UTC (rev 9156)
@@ -223,7 +223,7 @@
                                     // var exportDataLinkContent = '<div><input size="35" type="text" value="http://192.168.0.117/mapbender/php/mod_GetPublishedData.php?wmc_id='+wmc_id+'&outputFormat='+format+'/></div>';
-                                    var exportDataLinkContent = '<div><label for="exportLinkInput">Link: </label><input id="exportLinkInput" size="35" type="text" value="http://192.168.0.117/mapbender/php/mod_GetPublishedData.php?wmc_id='+wmc_id+'&outputFormat='+format+'"></div>';
+                                    var exportDataLinkContent = '<div><label for="exportLinkInput">Link: </label><input id="exportLinkInput" size="35" type="text" value="http://'+window.location.hostname+'/mapbender/php/mod_GetPublishedData.php?wmc_id='+wmc_id+'&outputFormat='+format+'"></div>';
                                     // var exportDataLinkContent = '<div>test</div>';
                                     $(exportDataLinkDlg).append(exportDataLinkContent);
Modified: trunk/mapbender/http/plugins/mb_metadata_layer.js
--- trunk/mapbender/http/plugins/mb_metadata_layer.js	2015-02-23 15:43:43 UTC (rev 9155)
+++ trunk/mapbender/http/plugins/mb_metadata_layer.js	2015-02-26 13:46:06 UTC (rev 9156)
@@ -6,7 +6,7 @@
  * Files:
  * SQL:
  * Help:
  * Maintainer:
@@ -22,207 +22,217 @@
 var $metadataLayer = $(this);
 var $metadataForm = $("<form>No layer selected.</form>").appendTo($metadataLayer);
-var MetadataLayerApi = function (o) {
-	var that = this;
-	var validator;
-	var formReady = false;
-	var wmsId;
-	var layerId;
-	var disabledFields = [
-		"layer_custom_category_id",
-		"layer_inspire_category_id",
-		"layer_md_topic_category_id",
-		"layer_keyword",
-		"layer_abstract",
-		"layer_title"
+var MetadataLayerApi = function(o) {
+    var that = this;
+    var validator;
+    var formReady = false;
+    var wmsId;
+    var layerId;
-	this.events = {
-		initialized: new Mapbender.Event(),
-		submit: new Mapbender.Event(),
-		showOriginalLayerMetadata : new Mapbender.Event()
-	this.valid = function () {
-		if (validator && validator.numberOfInvalids() > 0) {
-			$metadataForm.valid();
-			return false;
-		return true;
+    var disabledFields = [
+        "layer_custom_category_id",
+        "layer_inspire_category_id",
+        "layer_md_topic_category_id",
+        "layer_keyword",
+        "layer_abstract",
+        "layer_title"
-	this.serialize = function (callback) {
-		$metadataForm.submit();
-		var data = null;
-		if (this.valid()) {
-			data = {
-				layer: $metadataForm.easyform("serialize")
-		if ($.isFunction(callback)) {
-			callback(data);
-		return data !== null ? data.layer : data;
+    this.events = {
+        initialized: new Mapbender.Event(),
+        submit: new Mapbender.Event(),
+        showOriginalLayerMetadata: new Mapbender.Event()
-	this.fillForm = function (obj) {
-		$(disabledFields).each(function () {
-			$("#" + this).removeAttr("disabled");
+    this.valid = function() {
+        if (validator && validator.numberOfInvalids() > 0) {
+            $metadataForm.valid();
+            return false;
+        return true;
-		layerId = obj.layer_id;
+    this.serialize = function(callback) {
+        $metadataForm.submit();
+        var data = null;
+        if (this.valid()) {
+            data = {
+                layer: $metadataForm.easyform("serialize")
+        if ($.isFunction(callback)) {
+            callback(data);
+        return data !== null ? data.layer : data;
-		$metadataForm.easyform("reset");
-		// get metadata from server
-		var req = new Mapbender.Ajax.Request({
-			url: "../plugins/mb_metadata_server.php",
-			method: "getLayerMetadata",
-			parameters: {
-				"id": layerId
-			callback: function (obj, result, message) {
-				if (!result) {
-					return;
-				$metadataForm.easyform("fill", obj);
-				//delete entries of #layer_id_p if given
-				$('#layer_id_p').children().remove();
-				$('#layer_id_p').append('<a target=\"_blank\"href=\"../php/mod_showMetadata.php?resource=layer&layout=tabs&id='+layerId+'\">Metadata Preview Layer '+layerId+'</a>');
-				//delete metadataURL entries
-				$('.metadataEntry').remove();
-				//fill MetadataURLs into metadata_selectbox_id
-				that.fillMetadataURLs(obj);
-				that.valid();
-				that.enableResetButton();
-		req.send();
-	//function generate updated metadataUrl entries TODO: this function is defined in mb_metadata_layer.js before but it cannot be called - maybe s.th. have to be changed
-	this.fillMetadataURLs = function (obj) {
-		//for size of md_metadata records:
-		for (i=0;i<obj.md_metadata.metadata_id.length;i++) {
-				if (obj.md_metadata.origin[i] == "capabilities") {
-					if (obj.md_metadata.internal[i] == 1) {
-						$("<tr class='metadataEntry'><td>"+obj.md_metadata.metadata_id[i]+"</td><td><img src='../img/server_map-ilink.png' title='link to metadata from capabilities'/></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id="+obj.md_metadata.uuid[i]+"' target='_blank'>"+obj.md_metadata.uuid[i]+"</a></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id="+obj.md_metadata.uuid[i]+"&validate=true' target='_blank'>validate</a></td><td></td><td><img class='' title='delete' src='../img/cross.png' onclick='deleteInternalMetadataLinkage("+obj.md_metadata.metadata_id[i]+","+layerId+");return false;'/></td></tr>").appendTo($("#metadataTable"));
-					} else {
-						$("<tr class='metadataEntry'><td>"+obj.md_metadata.metadata_id[i]+"</td><td><img src='../img/osgeo_graphics/geosilk/server_map.png' title='capabilities'/></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id="+obj.md_metadata.uuid[i]+"' target='_blank'>"+obj.md_metadata.uuid[i]+"</a></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id="+obj.md_metadata.uuid[i]+"&validate=true' target='_blank'>validate</a></td><td></td></tr>").appendTo($("#metadataTable"));
-				if (obj.md_metadata.origin[i] == "external") {
-						$("<tr class='metadataEntry'><td>"+obj.md_metadata.metadata_id[i]+"</td><td><img src='../img/link-ilink.png' title='link to external linkage'/><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id="+obj.md_metadata.uuid[i]+"' target='_blank'>"+obj.md_metadata.uuid[i]+"</a></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id="+obj.md_metadata.uuid[i]+"&validate=true' target='_blank'>validate</a></td><td><img  class='' title='edit' src='../img/pencil.png' onclick='initMetadataAddon("+obj.md_metadata.metadata_id[i]+","+layerId+",false);return false;'/></td><td><img class='' title='delete' src='../img/cross.png' onclick='deleteInternalMetadataLinkage("+obj.md_metadata.metadata_id[i]+","+layerId+");return false;'/></td></tr>").appendTo($("#metadataTable"));
-					} else {
-						$("<tr class='metadataEntry'><td>"+obj.md_metadata.metadata_id[i]+"</td><td><img src='../img/osgeo_graphics/geosilk/link.png' title='linkage'/><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id="+obj.md_metadata.uuid[i]+"' target='_blank'>"+obj.md_metadata.uuid[i]+"</a></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id="+obj.md_metadata.uuid[i]+"&validate=true' target='_blank'>validate</a></td><td><img  class='' title='edit' src='../img/pencil.png' onclick='initMetadataAddon("+obj.md_metadata.metadata_id[i]+","+layerId+",false);return false;'/></td><td><img class='' title='delete' src='../img/cross.png' onclick='deleteAddedMetadata("+obj.md_metadata.metadata_id[i]+","+layerId+");return false;'/></td></tr>").appendTo($("#metadataTable"));
-				if (obj.md_metadata.origin[i] == "upload") {
-						$("<tr class='metadataEntry'><td>"+obj.md_metadata.metadata_id[i]+"</td><td><img src='../img/up-ilink.png' title='link to external uploaded data'/><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id="+obj.md_metadata.uuid[i]+"' target='_blank'>"+obj.md_metadata.uuid[i]+"</a></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id="+obj.md_metadata.uuid[i]+"&validate=true' target='_blank'>validate</a></td><td><img class='' title='delete' src='../img/cross.png' onclick='deleteInternalMetadataLinkage("+obj.md_metadata.metadata_id[i]+","+layerId+");return false;'/></td></tr>").appendTo($("#metadataTable"));
-					} else {
-						$("<tr class='metadataEntry'><td>"+obj.md_metadata.metadata_id[i]+"</td><td><img src='../img/button_blue_red/up.png' title='uploaded data'/><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id="+obj.md_metadata.uuid[i]+"' target='_blank'>"+obj.md_metadata.uuid[i]+"</a></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id="+obj.md_metadata.uuid[i]+"&validate=true' target='_blank'>validate</a></td><td><img class='' title='delete' src='../img/cross.png' onclick='deleteAddedMetadata("+obj.md_metadata.metadata_id[i]+","+layerId+");return false;'/></td></tr>").appendTo($("#metadataTable"));
-				if (obj.md_metadata.origin[i] == "metador") {
-						$("<tr class='metadataEntry'><td>"+obj.md_metadata.metadata_id[i]+"</td><td><img src='../img/edit-select-all-ilink.png' title='link to external edited metadata'/><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id="+obj.md_metadata.uuid[i]+"' target='_blank'>"+obj.md_metadata.uuid[i]+"</a></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id="+obj.md_metadata.uuid[i]+"&validate=true' target='_blank'>validate</a></td><td><img  class='' title='edit' src='../img/pencil.png' onclick='initMetadataAddon("+obj.md_metadata.metadata_id[i]+","+layerId+",false);return false;'/></td><td><img class='' title='delete' src='../img/cross.png' onclick='deleteInternalMetadataLinkage("+obj.md_metadata.metadata_id[i]+","+layerId+");return false;'/></td></tr>").appendTo($("#metadataTable"));
-					} else {
-						$("<tr class='metadataEntry'><td>"+obj.md_metadata.metadata_id[i]+"</td><td><img src='../img/gnome/edit-select-all.png' title='metadata'/><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id="+obj.md_metadata.uuid[i]+"' target='_blank'>"+obj.md_metadata.uuid[i]+"</a></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id="+obj.md_metadata.uuid[i]+"&validate=true' target='_blank'>validate</a></td><td><img  class='' title='edit' src='../img/pencil.png' onclick='initMetadataAddon("+obj.md_metadata.metadata_id[i]+","+layerId+",false);return false;'/></td><td><img class='' title='delete' src='../img/cross.png' onclick='deleteAddedMetadata("+obj.md_metadata.metadata_id[i]+","+layerId+");return false;'/></td></tr>").appendTo($("#metadataTable"));
+    this.fillForm = function(obj) {
+        $(disabledFields).each(function() {
+            $("#" + this).removeAttr("disabled");
-		$("<img class='metadataEntry' title='new' src='../img/add.png' onclick='initMetadataAddon("+obj.md_metadata.metadata_id[i]+","+layerId+",true);return false;'/>").appendTo($("#metadataTable"));
+        layerId = obj.layer_id;
-	this.enableResetButton = function () {
-		$("#resetIsoTopicCats").click(function () {
-			$("#layer_md_topic_category_id option").removeAttr("selected");
-		$("#resetCustomCats").click(function () {
-			$("#layer_custom_category_id option").removeAttr("selected");
-		$("#resetInspireCats").click(function () {
-			$("#layer_inspire_category_id option").removeAttr("selected");
-	this.fill = function (obj) {
-	var showOriginalLayerMetadata = function () {
-		that.events.showOriginalLayerMetadata.trigger({
-			data : {
-				wmsId : wmsId,
-				layerData : $metadataForm.easyform("serialize")
+        $metadataForm.easyform("reset");
-	this.getWmsId = function() {
-		return wmsId;
+        // get metadata from server
+        var req = new Mapbender.Ajax.Request({
+            url: "../plugins/mb_metadata_server.php",
+            method: "getLayerMetadata",
+            parameters: {
+                "id": layerId
+            callback: function(obj, result, message) {
+                if (!result) {
+                    return;
+                $metadataForm.easyform("fill", obj);
+                //delete entries of #layer_id_p if given
+                $('#layer_id_p').children().remove();
+                $('#layer_id_p').append('<a target=\"_blank\"href=\"../php/mod_showMetadata.php?resource=layer&layout=tabs&id=' + layerId + '\">Metadata Preview Layer ' + layerId + '</a>');
+                //delete metadataURL entries
+                $('.metadataEntry').remove();
+                //fill MetadataURLs into metadata_selectbox_id
+                that.fillMetadataURLs(obj);
+                that.valid();
+                that.enableResetButton();
+        req.send();
+    //function generate updated metadataUrl entries TODO: this function is defined in mb_metadata_layer.js before but it cannot be called - maybe s.th. have to be changed
+    this.fillMetadataURLs = function(obj) {
+        //for size of md_metadata records:
+        for (i = 0; i < obj.md_metadata.metadata_id.length; i++) {
+            if (obj.md_metadata.origin[i] == "capabilities") {
+                if (obj.md_metadata.internal[i] == 1) {
+                    $("<tr class='metadataEntry'><td>" + obj.md_metadata.metadata_id[i] + "</td><td><img src='../img/server_map-ilink.png' title='link to metadata from capabilities'/></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id=" + obj.md_metadata.uuid[i] + "' target='_blank'>" + obj.md_metadata.uuid[i] + "</a></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id=" + obj.md_metadata.uuid[i] + "&validate=true' target='_blank'>validate</a></td><td></td><td><img class='' title='delete' src='../img/cross.png' onclick='deleteInternalMetadataLinkage(" + obj.md_metadata.metadata_id[i] + "," + layerId + ");return false;'/></td></tr>").appendTo($("#metadataTable"));
+                } else {
+                    $("<tr class='metadataEntry'><td>" + obj.md_metadata.metadata_id[i] + "</td><td><img src='../img/osgeo_graphics/geosilk/server_map.png' title='capabilities'/></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id=" + obj.md_metadata.uuid[i] + "' target='_blank'>" + obj.md_metadata.uuid[i] + "</a></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id=" + obj.md_metadata.uuid[i] + "&validate=true' target='_blank'>validate</a></td><td></td></tr>").appendTo($("#metadataTable"));
+            if (obj.md_metadata.origin[i] == "external") {
+                    $("<tr class='metadataEntry'><td>" + obj.md_metadata.metadata_id[i] + "</td><td><img src='../img/link-ilink.png' title='link to external linkage'/><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id=" + obj.md_metadata.uuid[i] + "' target='_blank'>" + obj.md_metadata.uuid[i] + "</a></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id=" + obj.md_metadata.uuid[i] + "&validate=true' target='_blank'>validate</a></td><td><img  class='' title='edit' src='../img/pencil.png' onclick='initMetadataAddon(" + obj.md_metadata.metadata_id[i] + "," + layerId + ",false);return false;'/></td><td><img class='' title='delete' src='../img/cross.png' onclick='deleteInternalMetadataLinkage(" + obj.md_metadata.metadata_id[i] + "," + layerId + ");return false;'/></td></tr>").appendTo($("#metadataTable"));
+                } else {
+                    $("<tr class='metadataEntry'><td>" + obj.md_metadata.metadata_id[i] + "</td><td><img src='../img/osgeo_graphics/geosilk/link.png' title='linkage'/><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id=" + obj.md_metadata.uuid[i] + "' target='_blank'>" + obj.md_metadata.uuid[i] + "</a></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id=" + obj.md_metadata.uuid[i] + "&validate=true' target='_blank'>validate</a></td><td><img  class='' title='edit' src='../img/pencil.png' onclick='initMetadataAddon(" + obj.md_metadata.metadata_id[i] + "," + layerId + ",false);return false;'/></td><td><img class='' title='delete' src='../img/cross.png' onclick='deleteAddedMetadata(" + obj.md_metadata.metadata_id[i] + "," + layerId + ");return false;'/></td></tr>").appendTo($("#metadataTable"));
+            if (obj.md_metadata.origin[i] == "upload") {
+                    $("<tr class='metadataEntry'><td>" + obj.md_metadata.metadata_id[i] + "</td><td><img src='../img/up-ilink.png' title='link to external uploaded data'/><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id=" + obj.md_metadata.uuid[i] + "' target='_blank'>" + obj.md_metadata.uuid[i] + "</a></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id=" + obj.md_metadata.uuid[i] + "&validate=true' target='_blank'>validate</a></td><td><img class='' title='delete' src='../img/cross.png' onclick='deleteInternalMetadataLinkage(" + obj.md_metadata.metadata_id[i] + "," + layerId + ");return false;'/></td></tr>").appendTo($("#metadataTable"));
+                } else {
+                    $("<tr class='metadataEntry'><td>" + obj.md_metadata.metadata_id[i] + "</td><td><img src='../img/button_blue_red/up.png' title='uploaded data'/><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id=" + obj.md_metadata.uuid[i] + "' target='_blank'>" + obj.md_metadata.uuid[i] + "</a></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id=" + obj.md_metadata.uuid[i] + "&validate=true' target='_blank'>validate</a></td><td><img class='' title='delete' src='../img/cross.png' onclick='deleteAddedMetadata(" + obj.md_metadata.metadata_id[i] + "," + layerId + ");return false;'/></td></tr>").appendTo($("#metadataTable"));
+            if (obj.md_metadata.origin[i] == "metador") {
+                    $("<tr class='metadataEntry'><td>" + obj.md_metadata.metadata_id[i] + "</td><td><img src='../img/edit-select-all-ilink.png' title='link to external edited metadata'/><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id=" + obj.md_metadata.uuid[i] + "' target='_blank'>" + obj.md_metadata.uuid[i] + "</a></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id=" + obj.md_metadata.uuid[i] + "&validate=true' target='_blank'>validate</a></td><td><img  class='' title='edit' src='../img/pencil.png' onclick='initMetadataAddon(" + obj.md_metadata.metadata_id[i] + "," + layerId + ",false);return false;'/></td><td><img class='' title='delete' src='../img/cross.png' onclick='deleteInternalMetadataLinkage(" + obj.md_metadata.metadata_id[i] + "," + layerId + ");return false;'/></td></tr>").appendTo($("#metadataTable"));
+                } else {
+                    $("<tr class='metadataEntry'><td>" + obj.md_metadata.metadata_id[i] + "</td><td><img src='../img/gnome/edit-select-all.png' title='metadata'/><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id=" + obj.md_metadata.uuid[i] + "' target='_blank'>" + obj.md_metadata.uuid[i] + "</a></td><td><a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id=" + obj.md_metadata.uuid[i] + "&validate=true' target='_blank'>validate</a></td><td><img  class='' title='edit' src='../img/pencil.png' onclick='initMetadataAddon(" + obj.md_metadata.metadata_id[i] + "," + layerId + ",false);return false;'/></td><td><img class='' title='delete' src='../img/cross.png' onclick='deleteAddedMetadata(" + obj.md_metadata.metadata_id[i] + "," + layerId + ");return false;'/></td></tr>").appendTo($("#metadataTable"));
-	this.getLayerId = function() {
-		return layerId;
+        $("<img class='metadataEntry' title='new' src='../img/add.png' onclick='initMetadataAddon(" + obj.md_metadata.metadata_id[i] + "," + layerId + ",true);return false;'/>").appendTo($("#metadataTable"));
-	this.init = function (obj) {
-		delete layerId;
+    this.enableResetButton = function() {
+        $("#resetIsoTopicCats").click(function() {
+            $("#layer_md_topic_category_id option").removeAttr("selected");
+        $("#resetCustomCats").click(function() {
+            $("#layer_custom_category_id option").removeAttr("selected");
+        $("#resetInspireCats").click(function() {
+            $("#layer_inspire_category_id option").removeAttr("selected");
-		wmsId = obj;
-		if (!wmsId) {
-			return;
-		var formData = arguments.length >= 2 ? arguments[1] : undefined;
+    this.fill = function(obj) {
-		if (!formReady) {
-			$metadataForm.load("../plugins/mb_metadata_layer.php", function () {
-				$metadataForm.find(".help-dialog").helpDialog();
+    var showOriginalLayerMetadata = function() {
+        that.events.showOriginalLayerMetadata.trigger({
+            data: {
+                wmsId: wmsId,
+                layerData: $metadataForm.easyform("serialize")
-				$metadataForm.find(".original-metadata-layer").bind("click", function() {
-					showOriginalLayerMetadata();
+    this.getWmsId = function() {
+        return wmsId;
-				validator = $metadataForm.validate({
-					submitHandler: function () {
-						return false;
+    this.getLayerId = function() {
+        return layerId;
-				that.events.initialized.trigger({
-					wmsId: wmsId
-				formReady = true;
-			return;
-			$("#" + this).attr("disabled", "disabled");
-			wmsId: wmsId
-	Mapbender.events.localize.register(function () {
-		that.valid();
-		var formData = $metadataForm.easyform("serialize");
-		formReady = false;
-		that.init(wmsId, formData);
-	Mapbender.events.init.register(function () {
-		that.valid();
+    this.init = function(obj) {
+        delete layerId;
+        wmsId = obj;
+        if (!wmsId) {
+            return;
+        var formData = arguments.length >= 2 ? arguments[1] : undefined;
+        if (!formReady) {
+            $metadataForm.load("../plugins/mb_metadata_layer.php", function() {
+                // add tabs to preview fieldset
+                $('#previewTabs').tabs();
+                // add an event-handler to the form -> interaction with the form can be handled somewhere else --> mb_metadata_layerPreview.js
+                $('#mb_md_layer_preview').trigger('uploadFormReady', $('#previewImgForm'));
+                $('#mb_md_layer_preview').trigger('fileChange', $('#previewImgForm input[type=file]'));
+                $metadataForm.find(".help-dialog").helpDialog();
+                $metadataForm.find(".original-metadata-layer").bind("click", function() {
+                    showOriginalLayerMetadata();
+                validator = $metadataForm.validate({
+                    submitHandler: function() {
+                        return false;
+                that.events.initialized.trigger({
+                    wmsId: wmsId
+                formReady = true;
+            return;
+            $("#" + this).attr("disabled", "disabled");
+            wmsId: wmsId
+    Mapbender.events.localize.register(function() {
+        that.valid();
+        var formData = $metadataForm.easyform("serialize");
+        formReady = false;
+        that.init(wmsId, formData);
+    Mapbender.events.init.register(function() {
+        that.valid();
 $metadataLayer.mapbender(new MetadataLayerApi(options));
Modified: trunk/mapbender/http/plugins/mb_metadata_layer.php
--- trunk/mapbender/http/plugins/mb_metadata_layer.php	2015-02-23 15:43:43 UTC (rev 9155)
+++ trunk/mapbender/http/plugins/mb_metadata_layer.php	2015-02-26 13:46:06 UTC (rev 9156)
@@ -1,16 +1,16 @@
 <?php
 	require_once dirname(__FILE__) . "/../../core/globalSettings.php";
 	function displayCategories ($sql) {
 		if (Mapbender::session()->get("mb_lang") === "de") {
 			$sql = str_replace("category_code_en", "category_code_de", $sql);
 		$str = "";
 		$res = db_query($sql);
 		while ($row = db_fetch_assoc($res)) {
-			$str .= "<option value='" . $row["id"] . "'>" .
-				htmlentities($row["name"], ENT_QUOTES, CHARSET) .
+			$str .= "<option value='" . $row["id"] . "'>" .
+				htmlentities($row["name"], ENT_QUOTES, CHARSET) .
 				"</option>";
 		return $str;
@@ -75,16 +75,37 @@
 				</table>
 			</p>
 		    </fieldset>
-		    </div>
+		    </div>
 		</p>
 	</fieldset>
 </div>
 <div id="preview">
 	<fieldset class="">
-		<div id="map"></div>
-		<div id="toolbar_upper"></div>
-		<div id="toolbar_lower"></div>
+		<div id="previewTabs">
+			<ul>
+				<li><a href="#previewTabs-1">Bild erstellen</a></li>
+				<li><a href="#previewTabs-2">Bild hochladen</a></li>
+			</ul>
+			<div id="previewTabs-1">
+				<div id="map"></div>
+				<div id="toolbar_upper"></div>
+				<div id="toolbar_lower"></div>
+			</div>
+			<div id="previewTabs-2">
+				<div id="previewImgUpload">
+					<form id="previewImgForm" action='../php/mb_metadata_uploadLayerPreview.php' enctype="multipart/form-data">
+						<input type="file" name="image">
+						<input type="submit" value="Upload">
+						<input type="hidden" name="source_id" value="source_id" >
+						<div id="upload"></div>
+					</form>
+				</div>
+				<div id="textarea">
+				</div>
+			</div>
+		</div>
 	</fieldset>
 </div>
 <div id="classification">
Modified: trunk/mapbender/http/plugins/mb_metadata_layerPreview.js
--- trunk/mapbender/http/plugins/mb_metadata_layerPreview.js	2015-02-23 15:43:43 UTC (rev 9155)
+++ trunk/mapbender/http/plugins/mb_metadata_layerPreview.js	2015-02-26 13:46:06 UTC (rev 9156)
@@ -1,133 +1,259 @@
 var $metadataLayerPreview = $(this);
 $metadataLayerPreview.css('border', 'white');
-var MetadataLayerPreviewApi =  function (o){
+var MetadataLayerPreviewApi = function(o) {
-	var that = this;
-	options = o || {};
-	options.map = options.map || "";
-	options.buttons = options.buttons || [];
+    var that = this;
+    options = o || {};
+    options.map = options.map || "";
+    options.buttons = options.buttons || [];
-	this.wmsId = null;
+    this.wmsId = null;
-	var changeEpsgAndZoomToExtent = function (layer, map) {
-		layer.gui_layer_visible = 1;
-		var len = layer.layer_epsg.length;
-		if (len === 0) {
-			// could not zoom to extent
-			return;
-		for (var j = 0;  j < len; j++) {
-			var currentEpsg = layer.layer_epsg[j];
-			if (currentEpsg.epsg === map.epsg) {
-				var newExtent = new Mapbender.Extent(
-					currentEpsg.minx,
-					currentEpsg.miny,
-					currentEpsg.maxx,
-					currentEpsg.maxy
-				map.calculateExtent(newExtent);
-				return;
-		// current SRS is not supported, switch to a supported SRS
-		var newEpsg = layer.layer_epsg[0];
-			newEpsg.minx,
-			newEpsg.miny,
-			newEpsg.maxx,
-			newEpsg.maxy
-		map.setSrs({
-			srs: newEpsg.epsg,
-			extent: newExtent
+    var changeEpsgAndZoomToExtent = function(layer, map) {
+        layer.gui_layer_visible = 1;
+        var len = layer.layer_epsg.length;
+        if (len === 0) {
+            // could not zoom to extent
+            return;
+        for (var j = 0; j < len; j++) {
+            var currentEpsg = layer.layer_epsg[j];
+            if (currentEpsg.epsg === map.epsg) {
+                var newExtent = new Mapbender.Extent(
+                    currentEpsg.minx,
+                    currentEpsg.miny,
+                    currentEpsg.maxx,
+                    currentEpsg.maxy
+                map.calculateExtent(newExtent);
+                return;
+        // current SRS is not supported, switch to a supported SRS
+        var newEpsg = layer.layer_epsg[0];
+            newEpsg.minx,
+            newEpsg.miny,
+            newEpsg.maxx,
+            newEpsg.maxy
+        map.setSrs({
+            srs: newEpsg.epsg,
+            extent: newExtent
-	// enable layer,. disabling all others
-	this.layer = function(layer){
-		var layername = layer.layer_name;
-		if(layername === undefined){
-			return 'currentlayername';
-		var map = $('#'+options.map).mapbender();
-		var wms = map.wms[map.wms.length -1];
-		for (var i in wms.objLayer){
-			if(wms.objLayer[i].layer_name == layername){
-				changeEpsgAndZoomToExtent(wms.objLayer[i], map);
-			else{
-				wms.objLayer[i].gui_layer_visible = 0;
-		map.restateLayers(wms.wms_id);
+    // enable layer,. disabling all others
+    this.layer = function(layer) {
+        var layername = layer.layer_name;
+        if (layername === undefined) {
+            return 'currentlayername';
+        var map = $('#' + options.map).mapbender();
+        var wms = map.wms[map.wms.length - 1];
+        for (var i in wms.objLayer) {
+            if (wms.objLayer[i].layer_name == layername) {
+                changeEpsgAndZoomToExtent(wms.objLayer[i], map);
+            } else {
+                wms.objLayer[i].gui_layer_visible = 0;
+        map.restateLayers(wms.wms_id);
         map.setMapRequest();
-	// set wms, throwing out all others
-	this.wms = function(wmsid){
-		if(wmsid === undefined){
-			return 'currentwmsid';
-		$('#' + options.map).each(function () {
-			var map = $(this).mapbender();
-			if (!map) {
-				return;
-			var wms = map.wms;
-			for(var i = wms.length -1 ; i > 0; i--){
-				delete wms[i];
-				wms.length--;
-			mod_addWMSById_ajax('', wmsid, {
-				zoomToExtent: 1
+    // set wms, throwing out all others
+    this.wms = function(wmsid) {
+        if (wmsid === undefined) {
+            return 'currentwmsid';
-	this.init = function(obj){
-		if (this.init.done !== true) {
-			var $map = $('#' + options.map);
-			$map.css('position','relative');
-			$map.css('display','');
-			$map.css('top','');
-			$map.css('left','');
-			$('img',$map).css({
-				'height': $map.css('height'),
-				'width': $map.css('width')
-			var $target = $('#map');
-			$target.append($map);
-			$(options.toolbarUpper).each(function () {
-				$("#" + this).css({
-					"position": "relative",
-					"display":"",
-					"top":"",
-					"left":""
-				}).appendTo($("#toolbar_upper"));
-			$(options.toolbarLower).each(function () {
-					"display":"",
-					"top":"",
-					"left":""
-				}).appendTo($("#toolbar_lower"));
-			this.init.done = true;
-		if(typeof parseInt(obj, 10) == 'number') {
-			that.wms(obj);
+        $('#' + options.map).each(function() {
+            var map = $(this).mapbender();
+            if (!map) {
+                return;
+            var wms = map.wms;
+            for (var i = wms.length - 1; i > 0; i--) {
+                delete wms[i];
+                wms.length--;
+            mod_addWMSById_ajax('', wmsid, {
+                zoomToExtent: 1
+        if (this.init.done !== true) {
+            var $map = $('#' + options.map);
+            $map.css('position', 'relative');
+            $map.css('display', '');
+            $map.css('top', '');
+            $map.css('left', '');
+            $('img', $map).css({
+                'height': $map.css('height'),
+                'width': $map.css('width')
+            var $target = $('#map');
+            $target.append($map);
+            $(options.toolbarUpper).each(function() {
+                $("#" + this).css({
+                    "position": "relative",
+                    "display": "",
+                    "top": "",
+                    "left": ""
+                }).appendTo($("#toolbar_upper"));
+            $(options.toolbarLower).each(function() {
+                    "display": "",
+                    "top": "",
+                    "left": ""
+                }).appendTo($("#toolbar_lower"));
+            this.init.done = true;
+        if (typeof parseInt(obj, 10) == 'number') {
+            that.wms(obj);
 $metadataLayerPreview.mapbender(new MetadataLayerPreviewApi(options));
+//console.log($metadataLayerPreview);
+// upload an image to the preview fieldset
+// submit the preview form
+//$('#mb_md_layer').find('#previewImgForm').bind('submit', function(event) {
+//    event.preventDefault();
+//console.log('test');
+$metadataLayerPreview.bind('uploadFormReady', function(e, form) {
+    $(form).bind('submit', function() {
+        event.preventDefault();
+        if ($('input[id="layer_id"]').val() == undefined) { // in wmc_metadata
+            if ($('input[id="wmc_id"]').val() !== "") {
+                if ($('#previewImgForm input[type=file]').val() !== "") {
+                    fileUpload(form, '../php/mb_metadata_uploadLayerPreview.php', 'upload', 'wmc');
+            } else {
+                alert('Pleaese choose a wmc before uploading an image');
+        } else {
+            if ($('input[id="layer_id"]').val() !== "") {
+                    fileUpload(form, '../php/mb_metadata_uploadLayerPreview.php', 'upload', 'wms');
+            } else {
+                alert('Pleaese choose a layer before uploading an image');
+$metadataLayerPreview.bind('fileChange', function(e, fileInput) {
+    $(fileInput).bind('change', function() {
+        var fr = new FileReader();
+        fr.onload = function() { // file is loaded
+            if (!fileInput.files[0].name.match(/\.(jpg|jpeg|png|gif)$/)) {
+                $(fileInput).val("");
+                alert('File is not an image. Please choose an image!');
+                return;
+            var img = new Image();
+            img.onload = function() {
+                // check the file format
+                // if ((img.width > 200 && img.height > 200) || (img.width < 200 && img.height < 200)) {
+                if ((img.width != 200 || img.height != 200)) {
+                    alert('Choosed image size doesn\'t fit. The image will be scaled to 200px * 200px.');
+                    // fileInput.files[0] = img;
+                } else if ($('#previewImgForm input[type=file]')[0].files[0].name.split('.').pop() == 'bmp') {
+                    alert('Bitmaps are not supported. Please choose a valid filetype (jpg,png,gif)');
+            img.src = fr.result; // is the data URL because called with readAsDataURL
+        fr.readAsDataURL(this.files[0]);
+function fileUpload(form, action_url, div_id, type) {
+    var iframe = document.createElement("iframe");
+    iframe.setAttribute("id", "upload_iframe");
+    iframe.setAttribute("name", "upload_iframe");
+    iframe.setAttribute("width", "0");
+    iframe.setAttribute("height", "0");
+    iframe.setAttribute("border", "0");
+    iframe.setAttribute("style", "width: 0; height: 0; border: none;");
+    form.parentNode.appendChild(iframe);
+    window.frames['upload_iframe'].name = "upload_iframe";
+    iframeId = document.getElementById("upload_iframe");
+    var eventHandler = function() {
+        if (iframeId.detachEvent) iframeId.detachEvent("onload", eventHandler);
+        else iframeId.removeEventListener("load", eventHandler, false);
+        if (iframeId.contentDocument) {
+            content = iframeId.contentDocument.body.innerHTML;
+        } else if (iframeId.contentWindow) {
+            content = iframeId.contentWindow.document.body.innerHTML;
+        } else if (iframeId.document) {
+            content = iframeId.document.body.innerHTML;
+        document.getElementById(div_id).innerHTML = content;
+        setTimeout('iframeId.parentNode.removeChild(iframeId)', 250);
+    if (iframeId.addEventListener) iframeId.addEventListener("load", eventHandler, true);
+    if (iframeId.attachEvent) iframeId.attachEvent("onload", eventHandler);
+    form.setAttribute("target", "upload_iframe");
+    form.setAttribute("action", action_url);
+    form.setAttribute("method", "post");
+    form.setAttribute("enctype", "multipart/form-data");
+    form.setAttribute("encoding", "multipart/form-data");
+    //set the layer_id
+    if (type === 'wms') {
+        $('#previewImgForm input[type=hidden]').val($('input[id="layer_id"]').val());
+    } else {
+        $('#previewImgForm input[type=hidden]').val($('input[id="wmc_id"]').val());
+    form.submit();
+    document.getElementById(div_id).innerHTML = "Uploading...";
Modified: trunk/mapbender/http/plugins/mb_metadata_wmc_edit.js
--- trunk/mapbender/http/plugins/mb_metadata_wmc_edit.js	2015-02-23 15:43:43 UTC (rev 9155)
+++ trunk/mapbender/http/plugins/mb_metadata_wmc_edit.js	2015-02-26 13:46:06 UTC (rev 9156)
@@ -6,7 +6,7 @@
  * Files:
  * SQL:
  * Help:
  * Maintainer:
@@ -22,148 +22,157 @@
 var $metadataEdit = $(this);
 var $metadataForm = $("<form>No WMC selected.</form>").appendTo($metadataEdit);
-var MetadataEditApi = function (o) {
-	var that = this;
-	var validator;
-	var wmcId;
-	this.events = {
-		showOriginalMetadata : new Mapbender.Event(),
+var MetadataEditApi = function(o) {
+    var that = this;
+    var validator;
+    var wmcId;
-			return false;
-		return true;
-		var data = null;
-			data = {
-				wmc: $metadataForm.easyform("serialize")
-			callback(data);
-		return data !== null ? data.wmc : data;
-	// second optional parameter formData
-	var fillForm = function (obj) {
-		if (arguments.length >= 2) {
-			$metadataForm.easyform("fill", arguments[1]);
-			that.valid();
-			return;
-			url: "../plugins/mb_metadata_wmc_server.php",
-			method: "getWmcMetadata",
-			parameters: {
-				"id": obj
-				if (!result) {
-					return;
-				that.valid();
-				that.enableShowMetadataLink();
-		req.send();
-			$("#isoTopicCats option").removeAttr("selected");
-			$("#customCats option").removeAttr("selected");
-			$("#inspireCats option").removeAttr("selected");
-	this.enableShowMetadataLink = function () {
-		var linkHref = "../php/mod_showMetadata.php?languageCode=" + Mapbender.languageId + "&resource=wmc&id=" + wmcId;
-		$("#wmc_showMetadata").attr("href",linkHref);
+    this.events = {
+        showOriginalMetadata: new Mapbender.Event(),
-	var showOriginalMetadata = function () {
-		that.events.showOriginalMetadata.trigger({
-			data : {
-				wmcId : wmcId,
-				wmcData : $metadataForm.easyform("serialize")
-		wmcId = obj;
-		if (!formReady) {
-			$metadataForm.empty().append($metadataEdit.children("div")).children().show();
-			$metadataForm.find(".original-metadata-wmc").bind("click", function() {
-				showOriginalMetadata();
-					return false;
-			if (formData !== undefined) {
-				fillForm(obj, formData);
-			else {
-				fillForm(obj);
-			formReady = true;
-			return;
-		fillForm(obj);
-		if (!wmcId) {
-			return;
-		that.valid();
-		that.init(wmcId, formData);
-		that.valid();
-		$("<div></div>").insertAfter($metadataForm).hide().load("../plugins/mb_metadata_wmc_edit.php");
-		var loadwmc = $("#loadwmc").mapbender();
-		var map = $("#mapframe1").mapbender();
-		var width = map.getWidth();
-		var height = map.getHeight();
-		loadwmc.events.loaded.register(function () {
-			map.setDimensions(width, height);
+            return false;
+        return true;
+        var data = null;
+            data = {
+                wmc: $metadataForm.easyform("serialize")
+            callback(data);
+        return data !== null ? data.wmc : data;
+    // second optional parameter formData
+    var fillForm = function(obj) {
+        if (arguments.length >= 2) {
+            $metadataForm.easyform("fill", arguments[1]);
+            that.valid();
+            return;
+            url: "../plugins/mb_metadata_wmc_server.php",
+            method: "getWmcMetadata",
+            parameters: {
+                "id": obj
+                if (!result) {
+                    return;
+                that.valid();
+                that.enableShowMetadataLink();
+        req.send();
+            $("#isoTopicCats option").removeAttr("selected");
+            $("#customCats option").removeAttr("selected");
+            $("#inspireCats option").removeAttr("selected");
+    this.enableShowMetadataLink = function() {
+        var linkHref = "../php/mod_showMetadata.php?languageCode=" + Mapbender.languageId + "&resource=wmc&id=" + wmcId;
+        $("#wmc_showMetadata").attr("href", linkHref);
+    var showOriginalMetadata = function() {
+        that.events.showOriginalMetadata.trigger({
+            data: {
+                wmcId: wmcId,
+                wmcData: $metadataForm.easyform("serialize")
+        wmcId = obj;
+        if (!formReady) {
+            $metadataForm.empty().append($metadataEdit.children("div")).children().show();
+            $metadataForm.find(".original-metadata-wmc").bind("click", function() {
+                showOriginalMetadata();
+                    return false;
+            if (formData !== undefined) {
+                fillForm(obj, formData);
+            } else {
+                fillForm(obj);
+            formReady = true;
+            return;
+        fillForm(obj);
+        if (!wmcId) {
+            return;
+        that.valid();
+        that.init(wmcId, formData);
+        that.valid();
+        $("<div></div>").insertAfter($metadataForm).hide().load("../plugins/mb_metadata_wmc_edit.php", function() {
+            $('#mb_md_wmc_preview').trigger('uploadFormReady', $('#previewImgForm'));
+            $('#mb_md_wmc_preview').trigger('fileChange', $('#previewImgForm input[type=file]'));
+        var loadwmc = $("#loadwmc").mapbender();
+        var map = $("#mapframe1").mapbender();
+        var width = map.getWidth();
+        var height = map.getHeight();
+        loadwmc.events.loaded.register(function() {
+            map.setDimensions(width, height);
 $metadataEdit.mapbender(new MetadataEditApi(options));
Modified: trunk/mapbender/http/plugins/mb_metadata_wmc_edit.php
--- trunk/mapbender/http/plugins/mb_metadata_wmc_edit.php	2015-02-23 15:43:43 UTC (rev 9155)
+++ trunk/mapbender/http/plugins/mb_metadata_wmc_edit.php	2015-02-26 13:46:06 UTC (rev 9156)
@@ -1,16 +1,16 @@
 <?php
 		$str = "";
 				"</option>";
 		return $str;
@@ -26,7 +26,7 @@
 		<img class="original-metadata-wmc" src="../img/book.png"></img>
 		<img class="help-dialog" title="<?php #echo _mb("Help");?>" help="{text:'<?php #echo _mb("The original WMC-Metadata from the last update could be recovered or updated, so that the original Service-Metadata will be shown outward again.");?>'}" src="../img/questionmark.png"></img>
 	</p>
 	<p>
 		<a id='wmc_showMetadata' class='cancelClickEvent' target='_blank' href=''><?php echo _mb("Metadata");?></a>
 	</p>
@@ -55,9 +55,30 @@
 <div id="preview">
 	<fieldset class="">
+			<ul>
+			</ul>
+			</div>
+					</form>
+				</div>
+				</div>
+			</div>
+		</div>
 	</fieldset>
 </div>
@@ -66,7 +87,7 @@
 		<legend><?php echo _mb("Classification");?></legend>
 		<p>
 		    <label for="isoTopicCats" class="label_classification"><?php echo _mb("ISO Topic Category");?>:</label>
 			<img class="metadata_img" title="<?php echo _mb("Inspire");?>" src="../img/misc/inspire_eu_klein.png"></img>
 			<select class="metadata_selectbox" id="isoTopicCats" name="isoTopicCats" size="2" multiple="multiple">
 <?php
More information about the Mapbender_commits mailing list
