[Mapbender-commits] r9261 - in trunk/mapbender/http/geoportal: . xslt
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Jul 17 02:24:14 PDT 2015
Author: armin11
Date: 2015-07-17 02:24:13 -0700 (Fri, 17 Jul 2015)
New Revision: 9261
Added:
   trunk/mapbender/http/geoportal/xslt/
   trunk/mapbender/http/geoportal/xslt/iso-19139-to-dcat-ap.xsl
xslt script from the European Working group on GeoDCAT-AP for the transformation of iso19139 to DCAT  More information under https://joinup.ec.europa.eu/node/137964
Added: trunk/mapbender/http/geoportal/xslt/iso-19139-to-dcat-ap.xsl
--- trunk/mapbender/http/geoportal/xslt/iso-19139-to-dcat-ap.xsl	                        (rev 0)
+++ trunk/mapbender/http/geoportal/xslt/iso-19139-to-dcat-ap.xsl	2015-07-17 09:24:13 UTC (rev 9261)
@@ -0,0 +1,1924 @@
+<?xml version="1.0" encoding="UTF-8"?>
+  Copyright 2015 EUROPEAN UNION
+  Licensed under the EUPL, Version 1.1 or - as soon they will be approved by
+  the European Commission - subsequent versions of the EUPL (the "Licence");
+  You may not use this work except in compliance with the Licence.
+  You may obtain a copy of the Licence at:
+  http://ec.europa.eu/idabc/eupl
+  Unless required by applicable law or agreed to in writing, software
+  distributed under the Licence is distributed on an "AS IS" basis,
+  WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
+  See the Licence for the specific language governing permissions and
+  limitations under the Licence.
+  Authors: European Commission - Joint Research Centre
+           Andrea Perego <andrea.perego at jrc.ec.europa.eu>
+  This work was supported by the EU Interoperability Solutions for
+  European Public Administrations Programme (http://ec.europa.eu/isa)
+  through Action 1.17: Re-usable INSPIRE Reference Platform
+  (http://ec.europa.eu/isa/actions/01-trusted-information-exchange/1-17action_en.htm).
+  PURPOSE AND USAGE
+  This XSLT is a proof of concept for the implementation of the specification
+  concerning the geospatial profile of DCAT-AP (GeoDCAT-AP), available on
+  Joinup, the collaboration platform of the EU ISA Programme:
+    https://joinup.ec.europa.eu/node/139283/
+  As such, this XSLT must be considered as unstable, and can be updated any
+  time based on the revisions to the GeoDCAT-AP specifications and
+  related work in the framework of INSPIRE and the EU ISA Programme.
+<xsl:transform xmlns:xsl="http://www.w3.org/1999/XSL/Transform" xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#" xmlns:rdfs="http://www.w3.org/2000/01/rdf-schema#" xmlns:owl="http://www.w3.org/2002/07/owl#" xmlns:skos="http://www.w3.org/2004/02/skos/core#" xmlns:cnt="http://www.w3.org/2011/content#" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:dct="http://purl.org/dc/terms/" xmlns:dctype="http://purl.org/dc/dcmitype/" xmlns:dcam="http://purl.org/dc/dcam/" xmlns:time="http://www.w3.org/2006/time#" xmlns:earl="http://www.w3.org/ns/earl#" xmlns:dcat="http://www.w3.org/ns/dcat#" xmlns:foaf="http://xmlns.com/foaf/0.1/" xmlns:wdrs="http://www.w3.org/2007/05/powder-s#" xmlns:prov="http://www.w3.org/ns/prov#" xmlns:vcard="http://www.w3.org/2006/vcard/ns#" xmlns:adms="http://www.w3.org/ns/adms#" xmlns:gsp="http://www.opengis.net/ont/geosparql#" xmlns:ecodp="http://ec.europa.eu/open-data/ontologies/ec-odp#" xmlns:locn="http://www.w3.org/ns/locn#" xmlns:gmd="http://www.isotc211.org
 /2005/gmd" xmlns:gmx="http://www.isotc211.org/2005/gmx" xmlns:gco="http://www.isotc211.org/2005/gco" xmlns:srv="http://www.isotc211.org/2005/srv" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:gml="http://www.opengis.net/gml" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:ns9="http://inspire.ec.europa.eu/schemas/geoportal/1.0" xmlns:i="http://inspire.ec.europa.eu/schemas/common/1.0" xmlns:schema="http://schema.org/" version="1.0">
+  <xsl:output method="xml" indent="yes" encoding="utf-8" cdata-section-elements="locn:geometry"/>
+  Mapping parameters
+  This section includes mapping parameters to be modified manually.
+<!-- Parameter $profile -->
+  This parameter specifies the GeoDCAT-AP profile to be used:
+  - value "core": the GeoDCAT-AP Core profile, which includes only the INSPIRE and ISO 19115 core metadata elements supported in DCAT-AP
+  - value "extended": the GeoDCAT-AP Extended profile, which defines mappings for all the INSPIRE and ISO 19115 core metadata elements
+  The current specifications for the core and extended GeoDCAT-AP profiles are available on the Joinup collaboration platform:
+<!-- Uncomment to use GeoDCAT-AP Core -->
+<!--   <xsl:param name="profile">core</xsl:param> -->
+<!-- Uncomment to use GeoDCAT-AP Extended -->
+  <xsl:param name="profile">extended</xsl:param>
+  Other global parameters
+<!-- URI and URN of the spatial reference system (SRS) used in the bounding box.
+     The default SRS is CRS84. If a different SRS is used, also parameter
+     $SrsAxisOrder must be specified. -->
+<!-- Old param
+  <xsl:param name="srid">4326</xsl:param>
+<!-- The SRS URI is used in the WKT and GML encodings of the bounding box. -->
+  <xsl:param name="SrsUri">http://www.opengis.net/def/crs/OGC/1.3/CRS84</xsl:param>
+<!-- The SRS URN is used in the GeoJSON encoding of the bounding box. -->
+  <xsl:param name="SrsUrn">urn:ogc:def:crs:OGC:1.3:CRS84</xsl:param>
+<!-- Axis order for the reference SRS:
+     - "LonLat": longitude / latitude
+     - "LatLon": latitude / longitude.
+     The axis order must be specified only if the reference SRS is different from CRS84.
+     If the reference SRS is CRS84, this parameter is ignored. -->
+  <xsl:param name="SrsAxisOrder">LonLat</xsl:param>
+<!-- Namespaces -->
+  <xsl:param name="xsd">http://www.w3.org/2001/XMLSchema#</xsl:param>
+  <xsl:param name="dct">http://purl.org/dc/terms/</xsl:param>
+  <xsl:param name="dctype">http://purl.org/dc/dcmitype/</xsl:param>
+<!-- Currently not used.
+  <xsl:param name="timeUri">http://placetime.com/</xsl:param>
+  <xsl:param name="timeInstantUri" select="concat($timeUri,'instant/gregorian/')"/>
+  <xsl:param name="timeIntervalUri" select="concat($timeUri,'interval/gregorian/')"/>
+  <xsl:param name="dcat">http://www.w3.org/ns/dcat#</xsl:param>
+  <xsl:param name="gsp">http://www.opengis.net/ont/geosparql#</xsl:param>
+<!-- Old params used for the SRS
+  <xsl:param name="ogcCrsBaseUri">http://www.opengis.net/def/EPSG/0/</xsl:param>
+  <xsl:param name="ogcCrsBaseUrn">urn:ogc:def:EPSG::</xsl:param>
+  <xsl:param name="inspire">http://inspire.ec.europa.eu/schemas/md/</xsl:param>
+  <xsl:param name="kos">http://ec.europa.eu/open-data/kos/</xsl:param>
+  <xsl:param name="kosil" select="concat($kos,'interoperability-level/')"/>
+  <xsl:param name="kosdst" select="concat($kos,'dataset-type/')"/>
+  <xsl:param name="kosdss" select="concat($kos,'dataset-status/Completed')"/>
+  <xsl:param name="kosdoct" select="concat($kos,'documentation-type/')"/>
+  <xsl:param name="koslic" select="concat($kos,'licence/EuropeanCommission')"/>
+  <xsl:param name="op">http://publications.europa.eu/resource/authority/</xsl:param>
+  <xsl:param name="opcountry" select="concat($op,'country/')"/>
+  <xsl:param name="oplang" select="concat($op,'language/')"/>
+  <xsl:param name="opcb" select="concat($op,'corporate-body/')"/>
+  <xsl:param name="opfq" select="concat($op,'frequency/')"/>
+  <xsl:param name="cldFrequency">http://purl.org/cld/freq/</xsl:param>
+<!-- This is used as the datatype for the GeoJSON-based encoding of the bounding box. -->
+  <xsl:param name="geojsonMediaTypeUri">https://www.iana.org/assignments/media-types/application/vnd.geo+json</xsl:param>
+<!-- INSPIRE code list URIs -->
+  <xsl:param name="INSPIRECodelistUri">http://inspire.ec.europa.eu/metadata-codelist/</xsl:param>
+  <xsl:param name="SpatialDataServiceCategoryCodelistUri" select="concat($INSPIRECodelistUri,'SpatialDataServiceCategory')"/>
+  <xsl:param name="DegreeOfConformityCodelistUri" select="concat($INSPIRECodelistUri,'DegreeOfConformity')"/>
+  <xsl:param name="ResourceTypeCodelistUri" select="concat($INSPIRECodelistUri,'ResourceType')"/>
+  <xsl:param name="ResponsiblePartyRoleCodelistUri" select="concat($INSPIRECodelistUri,'ResponsiblePartyRole')"/>
+  <xsl:param name="SpatialDataServiceTypeCodelistUri" select="concat($INSPIRECodelistUri,'SpatialDataServiceType')"/>
+  <xsl:param name="TopicCategoryCodelistUri" select="concat($INSPIRECodelistUri,'TopicCategory')"/>
+<!-- INSPIRE code list URIs (not yet supported; the URI pattern is tentative) -->
+  <xsl:param name="SpatialRepresentationTypeCodelistUri" select="concat($INSPIRECodelistUri,'SpatialRepresentationTypeCode')"/>
+  <xsl:param name="MaintenanceFrequencyCodelistUri" select="concat($INSPIRECodelistUri,'MaintenanceFrequencyCode')"/>
+  Master template
+  <xsl:template match="/">
+    <rdf:RDF>
+      <xsl:apply-templates select="gmd:MD_Metadata|//gmd:MD_Metadata"/>
+    </rdf:RDF>
+  </xsl:template>
+  Metadata template
+  <xsl:template match="gmd:MD_Metadata|//gmd:MD_Metadata">
+  Parameters to create HTTP URIs for the resource and the corresponding metadata record
+  These parameters must be customised depending on the strategy used to assign HTTP URIs.
+  The default rule implies that HTTP URIs are specified for the metadata file identifier
+  (metadata URI) and the resource identifier (resource URI).
+  <xsl:param name="ResourceUri">
+    <xsl:variable name="rURI" select="gmd:identificationInfo/gmd:MD_DataIdentification/gmd:citation/gmd:CI_Citation/gmd:identifier/gmd:RS_Identifier/gmd:code/gco:CharacterString"/>
+    <xsl:if test="$rURI != '' and ( starts-with($rURI, 'http://') or starts-with($rURI, 'https://') )">
+      <xsl:value-of select="$rURI"/>
+    </xsl:if>
+  </xsl:param>
+  <xsl:param name="MetadataUri">
+    <xsl:variable name="mURI" select="gmd:fileIdentifier/gco:CharacterString"/>
+    <xsl:if test="$mURI != '' and ( starts-with($mURI, 'http://') or starts-with($mURI, 'https://') )">
+      <xsl:value-of select="$mURI"/>
+    </xsl:if>
+  </xsl:param>
+  Other parameters
+<!-- Metadata language: corresponding Alpha-2 codes -->
+    <xsl:param name="ormlang">
+      <xsl:value-of select="gmd:language/gmd:LanguageCode/@codeListValue"/>
+    </xsl:param>
+    <xsl:param name="MetadataLanguage">
+      <xsl:choose>
+        <xsl:when test="$ormlang = 'bul'">
+          <xsl:text>bg</xsl:text>
+        </xsl:when>
+        <xsl:when test="$ormlang = 'cze'">
+          <xsl:text>cs</xsl:text>
+        </xsl:when>
+        <xsl:when test="$ormlang = 'dan'">
+          <xsl:text>da</xsl:text>
+        </xsl:when>
+        <xsl:when test="$ormlang = 'ger'">
+          <xsl:text>de</xsl:text>
+        </xsl:when>
+        <xsl:when test="$ormlang = 'gre'">
+          <xsl:text>el</xsl:text>
+        </xsl:when>
+        <xsl:when test="$ormlang = 'eng'">
+          <xsl:text>en</xsl:text>
+        </xsl:when>
+        <xsl:when test="$ormlang = 'spa'">
+          <xsl:text>es</xsl:text>
+        </xsl:when>
+        <xsl:when test="$ormlang = 'est'">
+          <xsl:text>et</xsl:text>
+        </xsl:when>
+        <xsl:when test="$ormlang = 'fin'">
+          <xsl:text>fi</xsl:text>
+        </xsl:when>
+        <xsl:when test="$ormlang = 'fre'">
+          <xsl:text>fr</xsl:text>
+        </xsl:when>
+        <xsl:when test="$ormlang = 'gle'">
+          <xsl:text>ga</xsl:text>
+        </xsl:when>
+        <xsl:when test="$ormlang = 'ita'">
+          <xsl:text>it</xsl:text>
+        </xsl:when>
+        <xsl:when test="$ormlang = 'lav'">
+          <xsl:text>lv</xsl:text>
+        </xsl:when>
+        <xsl:when test="$ormlang = 'lit'">
+          <xsl:text>lt</xsl:text>
+        </xsl:when>
+        <xsl:when test="$ormlang = 'hun'">
+          <xsl:text>hu</xsl:text>
+        </xsl:when>
+        <xsl:when test="$ormlang = 'mlt'">
+          <xsl:text>mt</xsl:text>
+        </xsl:when>
+        <xsl:when test="$ormlang = 'dut'">
+          <xsl:text>nl</xsl:text>
+        </xsl:when>
+        <xsl:when test="$ormlang = 'pol'">
+          <xsl:text>pl</xsl:text>
+        </xsl:when>
+        <xsl:when test="$ormlang = 'por'">
+          <xsl:text>pt</xsl:text>
+        </xsl:when>
+        <xsl:when test="$ormlang = 'rum'">
+          <xsl:text>ru</xsl:text>
+        </xsl:when>
+        <xsl:when test="$ormlang = 'slo'">
+          <xsl:text>sk</xsl:text>
+        </xsl:when>
+        <xsl:when test="$ormlang = 'slv'">
+          <xsl:text>sl</xsl:text>
+        </xsl:when>
+        <xsl:when test="$ormlang = 'swe'">
+          <xsl:text>sv</xsl:text>
+        </xsl:when>
+        <xsl:otherwise>
+          <xsl:value-of select="$ormlang"/>
+        </xsl:otherwise>
+      </xsl:choose>
+    </xsl:param>
+<!-- Resource language: corresponding Alpha-2 codes -->
+    <xsl:param name="orrlang">
+      <xsl:value-of select="gmd:identificationInfo/*/gmd:language/gmd:LanguageCode/@codeListValue"/>
+    </xsl:param>
+    <xsl:param name="ResourceLanguage">
+      <xsl:choose>
+        <xsl:when test="$orrlang = 'bul'">
+        </xsl:when>
+        <xsl:when test="$orrlang = 'cze'">
+        </xsl:when>
+        <xsl:when test="$orrlang = 'dan'">
+        </xsl:when>
+        <xsl:when test="$orrlang = 'ger'">
+        </xsl:when>
+        <xsl:when test="$orrlang = 'gre'">
+        </xsl:when>
+        <xsl:when test="$orrlang = 'eng'">
+        </xsl:when>
+        <xsl:when test="$orrlang = 'spa'">
+        </xsl:when>
+        <xsl:when test="$orrlang = 'est'">
+        </xsl:when>
+        <xsl:when test="$orrlang = 'fin'">
+        </xsl:when>
+        <xsl:when test="$orrlang = 'fre'">
+        </xsl:when>
+        <xsl:when test="$orrlang = 'gle'">
+        </xsl:when>
+        <xsl:when test="$orrlang = 'ita'">
+        </xsl:when>
+        <xsl:when test="$orrlang = 'lav'">
+        </xsl:when>
+        <xsl:when test="$orrlang = 'lit'">
+        </xsl:when>
+        <xsl:when test="$orrlang = 'hun'">
+        </xsl:when>
+        <xsl:when test="$orrlang = 'mlt'">
+        </xsl:when>
+        <xsl:when test="$orrlang = 'dut'">
+        </xsl:when>
+        <xsl:when test="$orrlang = 'pol'">
+        </xsl:when>
+        <xsl:when test="$orrlang = 'por'">
+        </xsl:when>
+        <xsl:when test="$orrlang = 'rum'">
+        </xsl:when>
+        <xsl:when test="$orrlang = 'slo'">
+        </xsl:when>
+        <xsl:when test="$orrlang = 'slv'">
+        </xsl:when>
+        <xsl:when test="$orrlang = 'swe'">
+        </xsl:when>
+        <xsl:otherwise>
+          <xsl:value-of select="$orrlang"/>
+        </xsl:otherwise>
+      </xsl:choose>
+    </xsl:param>
+    <xsl:param name="ResourceType">
+      <xsl:value-of select="gmd:dataQualityInfo/gmd:DQ_DataQuality/gmd:scope/gmd:DQ_Scope/gmd:level/gmd:MD_ScopeCode/@codeListValue"/>
+    </xsl:param>
+    <xsl:param name="ServiceType">
+      <xsl:value-of select="gmd:identificationInfo/*/srv:serviceType/gco:LocalName"/>
+    </xsl:param>
+    <xsl:param name="ResourceTitle">
+      <xsl:value-of select="gmd:identificationInfo[1]/*/gmd:citation/*/gmd:title/gco:CharacterString"/>
+    </xsl:param>
+    <xsl:param name="ResourceAbstract">
+      <xsl:value-of select="gmd:identificationInfo[1]/*/gmd:abstract/gco:CharacterString"/>
+    </xsl:param>
+    <xsl:param name="Lineage">
+      <xsl:value-of select="gmd:dataQualityInfo/*/gmd:lineage/*/gmd:statement/gco:CharacterString"/>
+    </xsl:param>
+    <xsl:param name="MetadataDate">
+      <xsl:choose>
+        <xsl:when test="gmd:dateStamp/gco:Date">
+          <xsl:value-of select="gmd:dateStamp/gco:Date"/>
+        </xsl:when>
+        <xsl:when test="gmd:dateStamp/gco:DateTime">
+          <xsl:value-of select="substring(gmd:dateStamp/gco:DateTime/text(),1,10)"/>
+        </xsl:when>
+      </xsl:choose>
+    </xsl:param>
+    <xsl:param name="UniqueResourceIdentifier">
+      <xsl:for-each select="gmd:identificationInfo[1]/*/gmd:citation/*/gmd:identifier/gmd:RS_Identifier">
+        <xsl:choose>
+          <xsl:when test="gmd:codeSpace/gco:CharacterString/text() != ''">
+            <xsl:value-of select="concat(translate(gmd:codeSpace/gco:CharacterString/text(),' ','%20'),translate(gmd:code/gco:CharacterString/text(),' ','%20'))"/>
+          </xsl:when>
+          <xsl:otherwise>
+            <xsl:value-of select="translate(gmd:code/gco:CharacterString/text(),' ','%20')"/>
+          </xsl:otherwise>
+        </xsl:choose>
+      </xsl:for-each>
+    </xsl:param>
+    <xsl:param name="ConstraintsRelatedToAccessAndUse">
+      <xsl:apply-templates select="gmd:identificationInfo[1]/*/gmd:resourceConstraints/*">
+        <xsl:with-param name="MetadataLanguage" select="$MetadataLanguage"/>
+      </xsl:apply-templates>
+    </xsl:param>
+<!-- Conformity, expressed by using an earl:Assertion (only for the extended profile) -->
+    <xsl:param name="Conformity">
+      <xsl:for-each select="gmd:dataQualityInfo/*/gmd:report/*/gmd:result/*/gmd:specification/gmd:CI_Citation">
+        <xsl:variable name="specinfo">
+          <dct:title xml:lang="{$MetadataLanguage}">
+            <xsl:value-of select="gmd:title/gco:CharacterString"/>
+          </dct:title>
+          <xsl:apply-templates select="gmd:date/gmd:CI_Date"/>
+        </xsl:variable>
+        <xsl:variable name="degree">
+          <xsl:choose>
+            <xsl:when test="../../gmd:pass/gco:Boolean = 'true'">
+              <xsl:value-of select="concat($DegreeOfConformityCodelistUri,'/conformant')"/>
+            </xsl:when>
+            <xsl:when test="../../gmd:pass/gco:Boolean = 'false'">
+              <xsl:value-of select="concat($DegreeOfConformityCodelistUri,'/notConformant')"/>
+            </xsl:when>
+            <xsl:otherwise>
+              <xsl:value-of select="concat($DegreeOfConformityCodelistUri,'/notEvaluated')"/>
+            </xsl:otherwise>
+          </xsl:choose>
+        </xsl:variable>
+        <xsl:variable name="explanation">
+          <xsl:value-of select="../../gmd:explanation/gco:CharacterString"/>
+        </xsl:variable>
+        <earl:Assertion>
+          <xsl:if test="$ResourceUri != ''">
+            <earl:subject rdf:resource="{$ResourceUri}"/>
+          </xsl:if>
+          <xsl:choose>
+            <xsl:when test="../@xlink:href and ../@xlink:href != ''">
+              <earl:test>
+                <rdf:Description rdf:about="{../@xlink:href}">
+                  <xsl:copy-of select="$specinfo"/>
+                </rdf:Description>
+              </earl:test>
+            </xsl:when>
+            <xsl:otherwise>
+              <earl:test rdf:parseType="Resource">
+              </earl:test>
+            </xsl:otherwise>
+          </xsl:choose>
+          <earl:result>
+            <earl:TestResult>
+              <earl:outcome rdf:resource="{$degree}"/>
+              <xsl:if test="$explanation and $explanation != ''">
+                <earl:info xml:lang="{$MetadataLanguage}"><xsl:value-of select="$explanation"/></earl:info>
+              </xsl:if>
+            </earl:TestResult>
+          </earl:result>
+        </earl:Assertion>
+      </xsl:for-each>
+    </xsl:param>
+<!-- Conformity, expressed by using a prov:Activity (only for the extended profile) -->
+          </dct:title>
+        </xsl:variable>
+          <xsl:choose>
+            </xsl:when>
+            </xsl:when>
+            <xsl:otherwise>
+            <xsl:when test="../../gmd:pass/gco:Boolean = ''">
+            </xsl:when>
+            </xsl:otherwise>
+          </xsl:choose>
+        </xsl:variable>
+        </xsl:variable>
+        <prov:Activity>
+            <prov:used rdf:resource="{$ResourceUri}"/>
+          </xsl:if>
+          <prov:qualifiedAssociation rdf:parseType="Resource">
+            <prov:hadPlan rdf:parseType="Resource">
+              <xsl:choose>
+                  <prov:wasDerivedFrom rdf:resource="{../@xlink:href}"/>
+                  <prov:wasDerivedFrom>
+                  </prov:wasDerivedFrom>
+                </xsl:when>
+                <xsl:otherwise>
+                  <prov:wasDerivedFrom rdf:parseType="Resource">
+                </xsl:otherwise>
+              </xsl:choose>
+            </prov:hadPlan>
+          </prov:qualifiedAssociation>
+          <prov:generated rdf:parseType="Resource">
+            <dct:type rdf:resource="{$degree}"/>
+              <dct:description xml:lang="{$MetadataLanguage}"><xsl:value-of select="$explanation"/></dct:description>
+            </xsl:if>
+          </prov:generated>
+        </prov:Activity>
+      </xsl:for-each>
+    </xsl:param>
+<!-- Metadata character encoding (only for the extended profile) -->
+    <xsl:param name="MetadataCharacterEncoding">
+      <xsl:apply-templates select="gmd:characterSet/gmd:MD_CharacterSetCode"/>
+    </xsl:param>
+    <xsl:param name="ResourceCharacterEncoding">
+      <xsl:for-each select="gmd:identificationInfo/gmd:MD_DataIdentification">
+      </xsl:for-each>
+    </xsl:param>
+<!-- Metadata description (metadata on metadata) -->
+    <xsl:param name="MetadataDescription">
+      <rdf:type rdf:resource="{$dcat}CatalogRecord"/>
+<!-- Metadata language -->
+      <dct:language rdf:resource="{concat($oplang,translate($ormlang,'abcdefghijklmnopqrstuvwxyz','ABCDEFGHIJKLMNOPQRSTUVWXYZ'))}"/>
+<!-- Metadata date -->
+      <dct:modified rdf:datatype="{$xsd}date">
+        <xsl:value-of select="$MetadataDate"/>
+      </dct:modified>
+<!-- Metadata point of contact: only for the extended profile -->
+      <xsl:if test="$profile = 'extended'">
+        <xsl:apply-templates select="gmd:contact/gmd:CI_ResponsibleParty">
+      </xsl:if>
+<!-- Metadata file identifier (tentative): only for the extended profile -->
+        <xsl:for-each select="gmd:fileIdentifier/gco:CharacterString">
+          <dct:identifier rdf:datatype="{$xsd}string"><xsl:value-of select="."/></dct:identifier>
+        </xsl:for-each>
+      </xsl:if>
+<!-- Metadata standard (tentative): only for the extended profile -->
+        <xsl:variable name="MetadataStandardURI" select="gmd:metadataStandardName/gmx:Anchor/@xlink:href"/>
+        <xsl:variable name="MetadataStandardName" select="gmd:metadataStandardName/*[self::gco:CharacterString|self::gmx:Anchor]"/>
+        <xsl:variable name="MetadataStandardVersion" select="gmd:metadataStandardVersion/gco:CharacterString"/>
+        <xsl:if test="$MetadataCharacterEncoding != '' or $MetadataStandardURI != '' or $MetadataStandardName != ''">
+          <dct:source rdf:parseType="Resource">
+            <xsl:if test="$MetadataCharacterEncoding != ''">
+<!-- Metadata character encoding (tentative): only for the extended profile -->
+              <xsl:copy-of select="$MetadataCharacterEncoding"/>
+            </xsl:if>
+            <xsl:choose>
+              <xsl:when test="$MetadataStandardURI != ''">
+<!-- Metadata standard, denoted by a URI -->
+                <dct:conformsTo rdf:resource="{$MetadataStandardURI}"/>
+              </xsl:when>
+              <xsl:when test="$MetadataStandardName != ''">
+                <dct:conformsTo rdf:parseType="Resource">
+<!-- Metadata standard name -->
+                  <dct:title xml:lang="{$MetadataLanguage}"><xsl:value-of select="$MetadataStandardName"/></dct:title>
+                  <xsl:if test="$MetadataStandardVersion != ''">
+<!-- Metadata standard version -->
+                    <owl:versionInfo xml:lang="{$MetadataLanguage}"><xsl:value-of select="$MetadataStandardVersion"/></owl:versionInfo>
+                  </xsl:if>
+                </dct:conformsTo>
+              </xsl:when>
+            </xsl:choose>
+          </dct:source>
+        </xsl:if>
+<!-- Old version:
+        <xsl:for-each select="gmd:metadataStandardName/gco:CharacterString">
+          <xsl:if test="text() != '' or ../../gmd:metadataStandardVersion/gco:CharacterString/text() != ''">
+              </xsl:if>
+                <xsl:if test="text() != ''">
+                  <dct:title xml:lang="{$MetadataLanguage}"><xsl:value-of select="."/></dct:title>
+                </xsl:if>
+                <xsl:if test="../../gmd:metadataStandardName/gco:CharacterString/text() != ''">
+                  <owl:versionInfo xml:lang="{$MetadataLanguage}"><xsl:value-of select="../../gmd:metadataStandardVersion/gco:CharacterString"/></owl:versionInfo>
+                </xsl:if>
+              </dct:conformsTo>
+            </dct:source>
+          </xsl:if>
+        </xsl:for-each>
+      </xsl:if>
+    </xsl:param>
+<!-- Resource description (resource metadata) -->
+    <xsl:param name="ResourceDescription">
+      <xsl:choose>
+        <xsl:when test="$ResourceType = 'dataset'">
+          <rdf:type rdf:resource="{$dcat}Dataset"/>
+        </xsl:when>
+        <xsl:when test="$ResourceType = 'series'">
+        </xsl:when>
+        <xsl:when test="$ResourceType = 'service'">
+            <rdf:type rdf:resource="{$dctype}Service"/>
+          </xsl:if>
+          <xsl:if test="$ServiceType = 'discovery'">
+            <rdf:type rdf:resource="{$dcat}Catalog"/>
+          </xsl:if>
+        </xsl:when>
+      </xsl:choose>
+        <dct:type rdf:resource="{$ResourceTypeCodelistUri}/{$ResourceType}"/>
+      </xsl:if>
+      <dct:title xml:lang="{$MetadataLanguage}"><xsl:value-of select="$ResourceTitle"/></dct:title>
+        <xsl:value-of select="normalize-space($ResourceAbstract)"/>
+      </dct:description>
+<!-- Maintenance information (tentative) -->
+      <xsl:for-each select="gmd:identificationInfo/*/gmd:resourceMaintenance">
+        <xsl:apply-templates select="gmd:MD_MaintenanceInformation/gmd:maintenanceAndUpdateFrequency/gmd:MD_MaintenanceFrequencyCode"/>
+      </xsl:for-each>
+<!-- Topic category -->
+        <xsl:apply-templates select="gmd:identificationInfo/*/gmd:topicCategory">
+      </xsl:if>
+<!-- Keyword -->
+      <xsl:apply-templates select="gmd:identificationInfo/*/gmd:descriptiveKeywords/gmd:MD_Keywords">
+        <xsl:with-param name="ResourceType" select="$ResourceType"/>
+        <xsl:with-param name="ServiceType" select="$ServiceType"/>
+<!-- Identifier, 0..1 -->
+      <xsl:apply-templates select="gmd:identificationInfo/gmd:MD_DataIdentification/gmd:citation/gmd:CI_Citation/gmd:identifier/gmd:RS_Identifier">
+<!-- Resource locators -->
+      <xsl:apply-templates select="gmd:distributionInfo/*/gmd:transferOptions/*/gmd:onLine/*/gmd:linkage">
+<!-- Unique Resource Identifier -->
+      <xsl:apply-templates select="gmd:identificationInfo/*/gmd:citation/*/gmd:identifier/gmd:RS_Identifier"/>
+<!-- Coupled resources -->
+      <xsl:apply-templates select="gmd:identificationInfo[1]/*/srv:operatesOn">
+<!-- Resource Language -->
+      <xsl:if test="$ResourceType = 'dataset' or $ResourceType = 'series'">
+        <xsl:choose>
+          <xsl:when test="$orrlang != ''">
+            <dct:language rdf:resource="{concat($oplang,translate($orrlang,'abcdefghijklmnopqrstuvwxyz','ABCDEFGHIJKLMNOPQRSTUVWXYZ'))}"/>
+          </xsl:when>
+          <xsl:otherwise>
+<!-- To be decided (when the resource language is not specified, it defaults to the metadata language): -->
+             <xsl:if test="$ormlang != ''">
+             </xsl:if>
+          </xsl:otherwise>
+        </xsl:choose>
+      </xsl:if>
+<!-- Spatial service type -->
+      <xsl:if test="$ResourceType = 'service' and $profile = 'extended'">
+<!-- Replaced by param $ServiceType -->
+        <xsl:apply-templates select="gmd:identificationInfo/*/srv:serviceType">
+        <dct:type rdf:resource="{$SpatialDataServiceTypeCodelistUri}/{$ServiceType}"/>
+      </xsl:if>
+<!-- Spatial extent -->
+      <xsl:apply-templates select="gmd:identificationInfo[1]/*/*[self::gmd:extent|self::srv:extent]/*/gmd:geographicElement/gmd:EX_GeographicBoundingBox"/>
+      <xsl:apply-templates select="gmd:identificationInfo[1]/*/*[self::gmd:extent|self::srv:extent]/*/gmd:geographicElement">
+<!-- Temporal extent -->
+      <xsl:apply-templates select="gmd:identificationInfo/*/gmd:extent/gmd:EX_Extent/gmd:temporalElement/gmd:EX_TemporalExtent"/>
+<!-- Creation date, publication date, date of last revision -->
+      <xsl:apply-templates select="gmd:identificationInfo/*/gmd:citation/gmd:CI_Citation"/>
+<!-- Lineage -->
+      <xsl:if test="$ResourceType != 'service'">
+        <dct:provenance>
+          <dct:ProvenanceStatement>
+            <rdfs:label xml:lang="{$MetadataLanguage}">
+              <xsl:value-of select="normalize-space($Lineage)"/>
+            </rdfs:label>
+          </dct:ProvenanceStatement>
+        </dct:provenance>
+      </xsl:if>
+<!-- Coordinate and temporal reference systems (tentative) -->
+      <xsl:apply-templates select="gmd:referenceSystemInfo/gmd:MD_ReferenceSystem/gmd:referenceSystemIdentifier/gmd:RS_Identifier">
+<!-- Spatial resolution -->
+        <xsl:apply-templates select="gmd:identificationInfo/*/gmd:spatialResolution/gmd:MD_Resolution"/>
+      </xsl:if>
+<!-- Conformity -->
+      <xsl:apply-templates select="gmd:dataQualityInfo/*/gmd:report/*/gmd:result/*/gmd:specification/gmd:CI_Citation">
+        <xsl:with-param name="ResourceUri" select="$ResourceUri"/>
+        <xsl:with-param name="Conformity" select="$Conformity"/>
+      <xsl:choose>
+        <xsl:when test="$ResourceType = 'service' and ($ServiceType = 'discovery' or $profile = 'extended')">
+          <xsl:copy-of select="$ConstraintsRelatedToAccessAndUse"/>
+        </xsl:when>
+<!-- Distributions -->
+        <xsl:when test="$ResourceType = 'dataset' or $ResourceType = 'series'">
+<!-- Spatial representation type -->
+          <xsl:variable name="SpatialRepresentationType">
+            <xsl:apply-templates select="gmd:identificationInfo/*/gmd:spatialRepresentationType/gmd:MD_SpatialRepresentationTypeCode"/>
+          </xsl:variable>
+          <xsl:for-each select="gmd:distributionInfo/gmd:MD_Distribution">
+<!-- Encoding -->
+            <xsl:variable name="Encoding">
+               <xsl:apply-templates select="gmd:distributionFormat/gmd:MD_Format/gmd:name/*"/>
+            </xsl:variable>
+<!-- Resource locators (access / download URLs) -->
+            <xsl:for-each select="gmd:transferOptions/*/gmd:onLine/*">
+              <xsl:variable name="function" select="gmd:function/gmd:CI_OnLineFunctionCode/@codeListValue"/>
+              <xsl:variable name="TitleAndDescription">
+                <xsl:for-each select="gmd:name/gco:CharacterString">
+                </xsl:for-each>
+                <xsl:for-each select="gmd:description/gco:CharacterString">
+                  <dct:description xml:lang="{$MetadataLanguage}"><xsl:value-of select="."/></dct:description>
+                </xsl:for-each>
+              </xsl:variable>
+              <xsl:choose>
+                <xsl:when test="$function = 'download'or $function = 'offlineAccess' or $function = 'order'">
+                  <dcat:distribution>
+                    <dcat:Distribution>
+<!-- Title and description -->
+                      <xsl:copy-of select="$TitleAndDescription"/>
+<!-- Access URL -->
+                      <xsl:for-each select="gmd:linkage/gmd:URL">
+                        <dcat:accessURL rdf:resource="{.}"/>
+                      </xsl:for-each>
+<!-- Constraints related to access and use -->
+<!-- Spatial representation type (tentative) -->
+                      <xsl:copy-of select="$SpatialRepresentationType"/>
+<!-- Encoding -->
+                      <xsl:copy-of select="$Encoding"/>
+<!-- Resource character encoding -->
+                        <xsl:copy-of select="$ResourceCharacterEncoding"/>
+                      </xsl:if>
+                    </dcat:Distribution>
+                  </dcat:distribution>
+                </xsl:when>
+                <xsl:when test="$function = 'information' or $function = 'search'">
+<!-- ?? Should foaf:page be detailed with title, description, etc.? -->
+                    <foaf:page>
+                      <foaf:Document rdf:about="{.}">
+                      </foaf:Document>
+                    </foaf:page>
+                  </xsl:for-each>
+                </xsl:when>
+<!-- ?? Should dcat:landingPage be detailed with title, description, etc.? -->
+                <xsl:otherwise>
+                    <dcat:landingPage>
+                      </foaf:Document>
+                    </dcat:landingPage>
+                  </xsl:for-each>
+                </xsl:otherwise>
+              </xsl:choose>
+            </xsl:for-each>
+          </xsl:for-each>
+        </xsl:when>
+      </xsl:choose>
+<!-- Responsible organisation -->
+      <xsl:apply-templates select="gmd:identificationInfo/*/gmd:pointOfContact/gmd:CI_ResponsibleParty">
+    </xsl:param>
+    <xsl:choose>
+      <xsl:when test="$ResourceUri != ''">
+          <xsl:choose>
+            <xsl:when test="$MetadataUri != ''">
+              <rdf:Description rdf:about="{$MetadataUri}">
+                <foaf:primaryTopic rdf:resource="{$ResourceUri}"/>
+                <xsl:copy-of select="$MetadataDescription"/>
+            </xsl:when>
+            <xsl:otherwise>
+              <rdf:Description>
+            </xsl:otherwise>
+          </xsl:choose>
+        </xsl:if>
+        <rdf:Description rdf:about="{$ResourceUri}">
+          <xsl:copy-of select="$ResourceDescription"/>
+      </xsl:when>
+      <xsl:otherwise>
+        <rdf:Description>
+            <foaf:isPrimaryTopicOf>
+              <rdf:Description>
+            </foaf:isPrimaryTopicOf>
+          </xsl:if>
+      </xsl:otherwise>
+    </xsl:choose>
+    <xsl:if test="$profile = 'extended' and $ResourceUri != '' and $Conformity != ''">
+      <xsl:copy-of select="$Conformity"/>
+    </xsl:if>
+  </xsl:template>
+  Templates for specific metadata elements
+  <xsl:template name="UniqueResourceIdentifier" match="gmd:identificationInfo/*/gmd:citation/*/gmd:identifier/gmd:RS_Identifier">
+    <xsl:param name="ns">
+      <xsl:value-of select="gmd:codeSpace/gco:CharacterString"/>
+    </xsl:param>
+    <xsl:param name="code">
+      <xsl:value-of select="gmd:code/gco:CharacterString"/>
+    </xsl:param>
+    <xsl:param name="id">
+      <xsl:choose>
+        <xsl:when test="$ns != ''">
+          <xsl:choose>
+            <xsl:when test="substring($ns,string-length($ns),1) = '/'">
+          <xsl:value-of select="concat(translate($ns,' ','%20'),translate($code,' ','%20'))"/>
+            </xsl:when>
+            <xsl:otherwise>
+          <xsl:value-of select="concat(translate($ns,' ','%20'),'/',translate($code,' ','%20'))"/>
+            </xsl:otherwise>
+          </xsl:choose>
+        </xsl:when>
+        <xsl:otherwise>
+          <xsl:value-of select="translate($code,' ','%20')"/>
+        </xsl:otherwise>
+      </xsl:choose>
+    </xsl:param>
+    <xsl:param name="idDatatypeURI">
+      <xsl:choose>
+        <xsl:when test="starts-with($id, 'http://') or starts-with($id, 'https://') or starts-with($id, 'urn:')">
+          <xsl:value-of select="concat($xsd,'anyURI')"/>
+        </xsl:when>
+        <xsl:otherwise>
+          <xsl:value-of select="concat($xsd,'string')"/>
+        </xsl:otherwise>
+      </xsl:choose>
+    </xsl:param>
+    <dct:identifier rdf:datatype="{$idDatatypeURI}"><xsl:value-of select="$id"/></dct:identifier>
+  </xsl:template>
+<!-- Responsible Organisation -->
+  <xsl:template name="ResponsibleOrganisation" match="gmd:identificationInfo/*/gmd:pointOfContact/gmd:CI_ResponsibleParty">
+    <xsl:param name="MetadataLanguage"/>
+    <xsl:param name="ResourceType"/>
+    <xsl:param name="role">
+<!-- ISSUE The same problem we have for ResourceLocator function: the RDSI editor saves the relevant code as the text node of the relevant element, instead of using the correct attribute (@codeListValue) -->
+      <xsl:value-of select="gmd:role/gmd:CI_RoleCode/@codeListValue"/>
+    </xsl:param>
+    <xsl:param name="ResponsiblePartyRole">
+      <xsl:value-of select="concat($ResponsiblePartyRoleCodelistUri,'/',$role)"/>
+    </xsl:param>
+    <xsl:param name="OrganisationName">
+      <xsl:value-of select="gmd:organisationName/gco:CharacterString"/>
+    </xsl:param>
+    <xsl:param name="ROInfo">
+      <foaf:Organization>
+        <foaf:name xml:lang="{$MetadataLanguage}">
+          <xsl:value-of select="$OrganisationName"/>
+        </foaf:name>
+        <xsl:for-each select="gmd:contactInfo/gmd:CI_Contact/gmd:address/gmd:CI_Address/gmd:electronicMailAddress/gco:CharacterString">
+          <foaf:mbox rdf:resource="mailto:{.}"/>
+        </xsl:for-each>
+        <xsl:for-each select="gmd:contactInfo/gmd:CI_Contact/gmd:onlineResource/gmd:CI_OnlineResource/gmd:linkage/gmd:URL">
+<!-- ?? Should another property be used instead? E.g., foaf:homepage? -->
+          <foaf:workplaceHomepage rdf:resource="{.}"/>
+        </xsl:for-each>
+      </foaf:Organization>
+    </xsl:param>
+    <xsl:param name="ResponsibleParty">
+      <vcard:Kind>
+        <vcard:organization-name xml:lang="{$MetadataLanguage}">
+        </vcard:organization-name>
+          <vcard:hasEmail rdf:resource="mailto:{.}"/>
+        </xsl:for-each>
+          <vcard:hasURL rdf:resource="{.}"/>
+        </xsl:for-each>
+      </vcard:Kind>
+    </xsl:param>
+    <xsl:choose>
+      <xsl:when test="$role = 'resourceProvider'">
+        <schema:provider>
+          <xsl:copy-of select="$ROInfo"/>
+        </schema:provider>
+      </xsl:when>
+      <xsl:when test="$role = 'custodian'">
+        <rdarole:custodian>
+        </rdarole:custodian>
+      </xsl:when>
+      <xsl:when test="$role = 'owner' and $profile = 'extended'">
+        <dct:rightsHolder>
+        </dct:rightsHolder>
+      </xsl:when>
+      <xsl:when test="$role = 'user'">
+        <prov:wasUsedBy>
+          <prov:Activity>
+            <prov:wasAssociatedWith>
+            </prov:wasAssociatedWith>
+          </prov:Activity>
+        </prov:wasUsedBy>
+      </xsl:when>
+      <xsl:when test="$role = 'distributor'">
+        <rdarole:distributor>
+        </rdarole:distributor>
+      </xsl:when>
+      <xsl:when test="$role = 'originator' and $ResourceType != 'service'">
+        <dct:creator>
+        </dct:creator>
+      </xsl:when>
+      <xsl:when test="$role = 'pointOfContact' and $ResourceType != 'service'">
+        <dcat:contactPoint>
+          <xsl:copy-of select="$ResponsibleParty"/>
+        </dcat:contactPoint>
+      </xsl:when>
+      <xsl:when test="$role = 'principalInvestigator'">
+        <dct:contributor>
+        </dct:contributor>
+      </xsl:when>
+      <xsl:when test="$role = 'processor'">
+        <prov:entityOfInfluence>
+          <prov:Derivation>
+            <prov:hadActivity>
+              <prov:Activity>
+              </prov:Activity>
+            </prov:hadActivity>
+          </prov:Derivation>
+        </prov:entityOfInfluence>
+      </xsl:when>
+      <xsl:when test="$role = 'publisher'">
+        <dct:publisher>
+        </dct:publisher>
+      </xsl:when>
+      <xsl:when test="$role = 'author'">
+        <rdarole:author>
+        </rdarole:author>
+      </xsl:when>
+    </xsl:choose>
+      <prov:qualifiedAttribution>
+        <prov:Attribution>
+          <prov:agent>
+          </prov:agent>
+          <dct:type rdf:resource="{$ResponsiblePartyRole}"/>
+        </prov:Attribution>
+      </prov:qualifiedAttribution>
+    </xsl:if>
+  </xsl:template>
+<!-- Metadata point of contact -->
+  <xsl:template name="MetadataPointOfContact" match="gmd:contact/gmd:CI_ResponsibleParty">
+      <xsl:value-of select="concat($ResponsiblePartyRoleCodelistUri,'/','pointOfContact')"/>
+    </xsl:param>
+    </xsl:param>
+      <vcard:Kind>
+        </xsl:for-each>
+      </vcard:Kind>
+    </xsl:param>
+          <prov:agent>
+          </prov:agent>
+    </xsl:if>
+  </xsl:template>
+<!-- Resource locator -->
+<!-- Old version, applied to the resource (not to the resource distribution)
+  <xsl:template name="ResourceLocator" match="gmd:distributionInfo/*/gmd:transferOptions/*/gmd:onLine/*/gmd:linkage">
+    <xsl:choose>
+        <dcat:landingPage rdf:resource="{gmd:URL}"/>
+      </xsl:when>
+        <foaf:homepage rdf:resource="{gmd:URL}"/>
+      </xsl:when>
+    </xsl:choose>
+  </xsl:template>
+  <xsl:template name="ResourceLocator" match="gmd:transferOptions/*/gmd:onLine/*/gmd:linkage">
+    <xsl:choose>
+        <dct:title xml:lang="{$MetadataLanguage}"><xsl:value-of select="../gmd:description/gco:CharacterString"/></dct:title>
+        <dcat:accessURL rdf:resource="{gmd:URL}"/>
+     </xsl:when>
+      </xsl:when>
+    </xsl:choose>
+  </xsl:template>
+<!-- Coupled resource -->
+  <xsl:template name="CoupledResource" match="gmd:identificationInfo[1]/*/srv:operatesOn">
+    <dcat:dataset rdf:resource="{@xlink:href}"/>
+    <dct:hasPart rdf:resource="{@xlink:href}"/>
+  </xsl:template>
+<!-- Spatial data service type -->
+  <xsl:template match="gmd:identificationInfo/*/srv:serviceType">
+    <dct:type rdf:resource="{$SpatialDataServiceTypeCodelistUri}/{gco:LocalName}"/>
+  </xsl:template>
+  <xsl:template name="Conformity" match="gmd:dataQualityInfo/*/gmd:report/*/gmd:result/*/gmd:specification/gmd:CI_Citation">
+    <xsl:param name="ResourceUri"/>
+    <xsl:param name="Conformity"/>
+      </dct:title>
+    </xsl:variable>
+      <xsl:choose>
+        </xsl:when>
+        </xsl:when>
+        <xsl:otherwise>
+        </xsl:when>
+        </xsl:otherwise>
+      </xsl:choose>
+    </xsl:variable>
+    <xsl:if test="../../gmd:pass/gco:Boolean = 'true'">
+      <xsl:choose>
+          <dct:conformsTo rdf:resource="{../@xlink:href}"/>
+          <dct:conformsTo>
+          </dct:conformsTo>
+        </xsl:when>
+        <xsl:otherwise>
+          </dct:conformsTo>
+        </xsl:otherwise>
+      </xsl:choose>
+    </xsl:if>
+      <xsl:if test="$Conformity != '' and $ResourceUri = ''">
+        <prov:wasUsedBy>
+        </prov:wasUsedBy>
+      </xsl:if>
+      <xsl:choose>
+          <wdrs:describedby>
+            <earl:Assertion>
+              <earl:test>
+              </earl:test>
+              <earl:result>
+                <earl:TestResult>
+              </earl:result>
+            </earl:Assertion>
+          </wdrs:describedby>
+        </xsl:when>
+        <xsl:otherwise>
+            <earl:Assertion>
+              </earl:test>
+              <earl:result>
+                <earl:TestResult>
+              </earl:result>
+            </earl:Assertion>
+        </xsl:otherwise>
+      </xsl:choose>
+    </xsl:if>
+  </xsl:template>
+<!-- Geographic extent -->
+  <xsl:template name="GeographicExtent" match="gmd:identificationInfo[1]/*/*[self::gmd:extent|self::srv:extent]/*/gmd:geographicElement">
+      <xsl:otherwise>
+        <dct:spatial>
+          <dct:Location>
+            <xsl:for-each select="gmd:description">
+              <rdfs:label xml:lang="{$MetadataLanguage}"><xsl:value-of select="gco:CharacterString"/></rdfs:label>
+            </xsl:for-each>
+            <xsl:apply-templates select="gmd:EX_GeographicDescription/gmd:geographicIdentifier/*">
+            <xsl:apply-templates select="gmd:EX_GeographicBoundingBox"/>
+          </dct:Location>
+        </dct:spatial>
+      </xsl:otherwise>
+    </xsl:choose>
+  </xsl:template>
+<!-- Geographic identifier -->
+  <xsl:template name="GeographicIdentifier" match="gmd:EX_GeographicDescription/gmd:geographicIdentifier/*">
+    <xsl:param name="GeoCode" select="gmd:code/*[self::gco:CharacterString|self::gmx:Anchor/@xlink:href]"/>
+    <xsl:param name="GeoURI" select="gmd:code/gmx:Anchor/@xlink:href"/>
+    <xsl:param name="GeoCode">
+      <xsl:choose>
+        <xsl:when test="gmd:code/gco:CharacterString">
+        </xsl:when>
+        <xsl:when test="gmd:code/gmx:Anchor">
+          <xsl:value-of select="gmd:code/gmx:Anchor/@xlink:href"/>
+        </xsl:when>
+      </xsl:choose>
+    </xsl:param>
+    <xsl:param name="GeoURI">
+      <xsl:if test="starts-with($GeoCode,'http://') or starts-with($GeoCode,'https://')">
+        <xsl:value-of select="$GeoCode"/>
+      </xsl:if>
+    </xsl:param>
+    <xsl:param name="GeoURN">
+      <xsl:if test="starts-with($GeoCode,'urn:')">
+      </xsl:if>
+    </xsl:param>
+    <xsl:choose>
+      <xsl:when test="$GeoURI != ''">
+        <xsl:choose>
+          <xsl:when test="gmd:EX_GeographicBoundingBox">
+            <dct:spatial>
+              <dct:Location rdf:about="{$GeoURI}">
+                <xsl:if test="$GeoCode != ''">
+                  <rdfs:label xml:lang="{$MetadataLanguage}"><xsl:value-of select="$GeoCode"/></rdfs:label>
+                </xsl:if>
+              </dct:Location>
+            </dct:spatial>
+          </xsl:when>
+          <xsl:otherwise>
+            <dct:spatial rdf:resource="{$GeoURI}"/>
+          </xsl:otherwise>
+        </xsl:choose>
+      </xsl:when>
+      <xsl:when test="$GeoCode != ''">
+        <dct:spatial rdf:parseType="Resource">
+          <rdfs:seeAlso rdf:parseType="Resource">
+          <xsl:choose>
+            <xsl:when test="$GeoURN != ''">
+              <dct:identifier rdf:datatype="{$xsd}anyURI"><xsl:value-of select="$GeoURN"/></dct:identifier>
+            </xsl:when>
+            <xsl:otherwise>
+              <skos:prefLabel xml:lang="{$MetadataLanguage}">
+              </skos:prefLabel>
+            </xsl:otherwise>
+          </xsl:choose>
+          <xsl:for-each select="gmd:authority/gmd:CI_Citation">
+            <skos:inScheme>
+              <skos:ConceptScheme>
+                </dct:title>
+              </skos:ConceptScheme>
+            </skos:inScheme>
+          </xsl:for-each>
+          </rdfs:seeAlso>
+        </dct:spatial>
+      </xsl:when>
+    </xsl:choose>
+  </xsl:template>
+<!-- Geographic bounding box -->
+  <xsl:template name="GeographicBoundingBox" match="gmd:identificationInfo[1]/*/*[self::gmd:extent|self::srv:extent]/*/gmd:geographicElement/gmd:EX_GeographicBoundingBox">
+  <xsl:template name="GeographicBoundingBox" match="gmd:EX_GeographicBoundingBox">
+<!-- Bbox as a dct:Box -->
+<!-- Need to check whether this is correct - in particular, the "projection" parameter -->
+    <xsl:param name="DCTBox">northlimit=<xsl:value-of select="gmd:northBoundLatitude/gco:Decimal"/>; eastlimit=<xsl:value-of select="gmd:eastBoundLongitude/gco:Decimal"/>; southlimit=<xsl:value-of select="gmd:southBoundLatitude/gco:Decimal"/>; westlimit=<xsl:value-of select="gmd:westBoundLongitude/gco:Decimal"/>; projection=EPSG:<xsl:value-of select="$srid"/></xsl:param>
+<!-- Bbox as GML (GeoSPARQL) -->
+    <xsl:param name="GMLLiteral">
+      <xsl:choose>
+        <xsl:when test="$SrsUri = 'http://www.opengis.net/def/crs/OGC/1.3/CRS84'"><gml:Envelope srsName="<xsl:value-of select="$SrsUri"/>"><gml:lowerCorner><xsl:value-of select="gmd:westBoundLongitude/gco:Decimal"/><xsl:text> </xsl:text><xsl:value-of select="gmd:southBoundLatitude/gco:Decimal"/></gml:lowerCorner><gml:upperCorner><xsl:value-of select="gmd:eastBoundLongitude/gco:Decimal"/><xsl:text> </xsl:text><xsl:value-of select="gmd:northBoundLatitude/gco:Decimal"/></gml:upperCorner></gml:Envelope></xsl:when>
+        <xsl:when test="$SrsAxisOrder = 'LonLat'"><gml:Envelope srsName="<xsl:value-of select="$SrsUri"/>"><gml:lowerCorner><xsl:value-of select="gmd:westBoundLongitude/gco:Decimal"/><xsl:text> </xsl:text><xsl:value-of select="gmd:southBoundLatitude/gco:Decimal"/></gml:lowerCorner><gml:upperCorner><xsl:value-of select="gmd:eastBoundLongitude/gco:Decimal"/><xsl:text> </xsl:text><xsl:value-of select="gmd:northBoundLatitude/gco:Decimal"/></gml:upperCorner></gml:Envelope></xsl:when>
+        <xsl:when test="$SrsAxisOrder = 'LatLon'"><gml:Envelope srsName="<xsl:value-of select="$SrsUri"/>"><gml:lowerCorner><xsl:value-of select="gmd:southBoundLatitude/gco:Decimal"/><xsl:text> </xsl:text><xsl:value-of select="gmd:westBoundLongitude/gco:Decimal"/></gml:lowerCorner><gml:upperCorner><xsl:value-of select="gmd:northBoundLatitude/gco:Decimal"/><xsl:text> </xsl:text><xsl:value-of select="gmd:eastBoundLongitude/gco:Decimal"/></gml:upperCorner></gml:Envelope></xsl:when>
+      </xsl:choose>
+    </xsl:param>
+<!-- Bbox as WKT (GeoSPARQL) -->
+    <xsl:param name="WKTLiteral">
+      <xsl:choose>
+        <xsl:when test="$SrsUri = 'http://www.opengis.net/def/crs/OGC/1.3/CRS84'">POLYGON((<xsl:value-of select="gmd:westBoundLongitude/gco:Decimal"/><xsl:text> </xsl:text><xsl:value-of select="gmd:northBoundLatitude/gco:Decimal"/>,<xsl:value-of select="gmd:eastBoundLongitude/gco:Decimal"/><xsl:text> </xsl:text><xsl:value-of select="gmd:northBoundLatitude/gco:Decimal"/>,<xsl:value-of select="gmd:eastBoundLongitude/gco:Decimal"/><xsl:text> </xsl:text><xsl:value-of select="gmd:southBoundLatitude/gco:Decimal"/>,<xsl:value-of select="gmd:westBoundLongitude/gco:Decimal"/><xsl:text> </xsl:text><xsl:value-of select="gmd:southBoundLatitude/gco:Decimal"/>,<xsl:value-of select="gmd:westBoundLongitude/gco:Decimal"/><xsl:text> </xsl:text><xsl:value-of select="gmd:northBoundLatitude/gco:Decimal"/>))</xsl:when>
+        <xsl:when test="$SrsAxisOrder = 'LonLat'"><<xsl:value-of select="$SrsUri"/>> POLYGON((<xsl:value-of select="gmd:westBoundLongitude/gco:Decimal"/><xsl:text> </xsl:text><xsl:value-of select="gmd:northBoundLatitude/gco:Decimal"/>,<xsl:value-of select="gmd:eastBoundLongitude/gco:Decimal"/><xsl:text> </xsl:text><xsl:value-of select="gmd:northBoundLatitude/gco:Decimal"/>,<xsl:value-of select="gmd:eastBoundLongitude/gco:Decimal"/><xsl:text> </xsl:text><xsl:value-of select="gmd:southBoundLatitude/gco:Decimal"/>,<xsl:value-of select="gmd:westBoundLongitude/gco:Decimal"/><xsl:text> </xsl:text><xsl:value-of select="gmd:southBoundLatitude/gco:Decimal"/>,<xsl:value-of select="gmd:westBoundLongitude/gco:Decimal"/><xsl:text> </xsl:text><xsl:value-of select="gmd:northBoundLatitude/gco:Decimal"/>))</xsl:when>
+        <xsl:when test="$SrsAxisOrder = 'LatLon'"><<xsl:value-of select="$SrsUri"/>> POLYGON((<xsl:value-of select="gmd:northBoundLatitude/gco:Decimal"/><xsl:text> </xsl:text><xsl:value-of select="gmd:westBoundLongitude/gco:Decimal"/>,<xsl:value-of select="gmd:northBoundLatitude/gco:Decimal"/><xsl:text> </xsl:text><xsl:value-of select="gmd:eastBoundLongitude/gco:Decimal"/>,<xsl:value-of select="gmd:southBoundLatitude/gco:Decimal"/><xsl:text> </xsl:text><xsl:value-of select="gmd:eastBoundLongitude/gco:Decimal"/>,<xsl:value-of select="gmd:southBoundLatitude/gco:Decimal"/><xsl:text> </xsl:text><xsl:value-of select="gmd:westBoundLongitude/gco:Decimal"/>,<xsl:value-of select="gmd:northBoundLatitude/gco:Decimal"/><xsl:text> </xsl:text><xsl:value-of select="gmd:westBoundLongitude/gco:Decimal"/>))</xsl:when>
+        </xsl:choose>
+    </xsl:param>
+<!-- Bbox as GeoJSON -->
+    <xsl:param name="GeoJSONLiteral">{"type":"Polygon","crs":{"type":"name","properties":{"name":"<xsl:value-of select="$SrsUrn"/>"}},"coordinates":[[[<xsl:value-of select="gmd:westBoundLongitude/gco:Decimal"/><xsl:text>,</xsl:text><xsl:value-of select="gmd:northBoundLatitude/gco:Decimal"/>],[<xsl:value-of select="gmd:eastBoundLongitude/gco:Decimal"/><xsl:text>,</xsl:text><xsl:value-of select="gmd:northBoundLatitude/gco:Decimal"/>],[<xsl:value-of select="gmd:eastBoundLongitude/gco:Decimal"/><xsl:text>,</xsl:text><xsl:value-of select="gmd:southBoundLatitude/gco:Decimal"/>],[<xsl:value-of select="gmd:westBoundLongitude/gco:Decimal"/><xsl:text>,</xsl:text><xsl:value-of select="gmd:southBoundLatitude/gco:Decimal"/>],[<xsl:value-of select="gmd:westBoundLongitude/gco:Decimal"/><xsl:text>,</xsl:text><xsl:value-of select="gmd:northBoundLatitude/gco:Decimal"/>]]]}</xsl:param>
+<!-- Recommended geometry encodings -->
+      <locn:geometry rdf:datatype="{$gsp}wktLiteral"><xsl:value-of select="$WKTLiteral"/></locn:geometry>
+      <locn:geometry rdf:datatype="{$gsp}gmlLiteral"><xsl:value-of select="$GMLLiteral"/></locn:geometry>
+<!-- Additional geometry encodings -->
+      <locn:geometry rdf:datatype="{$geojsonMediaTypeUri}"><xsl:value-of select="$GeoJSONLiteral"/></locn:geometry>
+      <locn:geometry rdf:datatype="{$dct}Box"><xsl:value-of select="$DCTBox"/></locn:geometry>
+    </dct:spatial>
+  </xsl:template>
+  <xsl:template name="TemporalExtent" match="gmd:identificationInfo/*/gmd:extent/gmd:EX_Extent/gmd:temporalElement/gmd:EX_TemporalExtent">
+    <xsl:for-each select="gmd:extent/gml:TimeInstant|gmd:extent/gml:TimePeriod">
+      <xsl:if test="local-name(.) = 'TimeInstant' or ( local-name(.) = 'TimePeriod' and gml:beginPosition and gml:endPosition )">
+        <xsl:variable name="dctperiod">
+          <xsl:choose>
+            <xsl:when test="local-name(.) = 'TimeInstant'">start=<xsl:value-of select="gml:timePosition"/>; end=<xsl:value-of select="gml:timePosition"/></xsl:when>
+            <xsl:otherwise>start=<xsl:value-of select="gml:beginPosition"/>; end=<xsl:value-of select="gml:endPosition"/></xsl:otherwise>
+          </xsl:choose>
+        </xsl:variable>
+        <xsl:variable name="dateStart">
+          <xsl:choose>
+            <xsl:when test="local-name(.) = 'TimeInstant'"><xsl:value-of select="gml:timePosition"/></xsl:when>
+            <xsl:otherwise><xsl:value-of select="gml:beginPosition"/></xsl:otherwise>
+          </xsl:choose>
+        </xsl:variable>
+        <xsl:variable name="dateEnd">
+          <xsl:choose>
+            <xsl:otherwise><xsl:value-of select="gml:endPosition"/></xsl:otherwise>
+          </xsl:choose>
+        </xsl:variable>
+        <dct:temporal>
+          <dct:PeriodOfTime>
+            <schema:startDate rdf:datatype="{$xsd}date"><xsl:value-of select="$dateStart"/></schema:startDate>
+            <schema:endDate rdf:datatype="{$xsd}date"><xsl:value-of select="$dateEnd"/></schema:endDate>
+          </dct:PeriodOfTime>
+        </dct:temporal>
+      </xsl:if>
+    </xsl:for-each>
+  </xsl:template>
+<!-- Dates of publication, last revision, creation -->
+  <xsl:template name="ResourceDates" match="gmd:identificationInfo/*/gmd:citation/gmd:CI_Citation">
+  </xsl:template>
+<!-- Generic date template -->
+  <xsl:template name="Dates" match="gmd:date/gmd:CI_Date">
+    <xsl:param name="date">
+      <xsl:value-of select="gmd:date/gco:Date"/>
+    </xsl:param>
+    <xsl:param name="type">
+      <xsl:value-of select="gmd:dateType/gmd:CI_DateTypeCode/@codeListValue"/>
+    </xsl:param>
+    <xsl:choose>
+      <xsl:when test="$type = 'publication'">
+        <dct:issued rdf:datatype="{$xsd}date">
+          <xsl:value-of select="$date"/>
+        </dct:issued>
+      </xsl:when>
+      <xsl:when test="$type = 'revision'">
+        </dct:modified>
+      </xsl:when>
+      <xsl:when test="$type = 'creation' and $profile = 'extended'">
+        <dct:created rdf:datatype="{$xsd}date">
+        </dct:created>
+      </xsl:when>
+    </xsl:choose>
+  </xsl:template>
+  <xsl:template name="ConstraintsRelatedToAccesAndUse" match="gmd:identificationInfo[1]/*/gmd:resourceConstraints/*">
+    <xsl:param name="LimitationsOnPublicAccess">
+      <xsl:value-of select="gmd:MD_LegalConstraints/gmd:otherConstraints/gco:CharacterString"/>
+    </xsl:param>
+    <xsl:for-each select="gmd:useLimitation">
+      <xsl:choose>
+<!-- In case the rights/licence URL IS NOT provided -->
+        <xsl:when test="gco:CharacterString">
+          <dct:license>
+            <dct:LicenseDocument>
+              <rdfs:label xml:lang="{$MetadataLanguage}"><xsl:value-of select="normalize-space(gmx:Anchor)"/></rdfs:label>
+            </dct:LicenseDocument>
+          </dct:license>
+          <dct:rights>
+            <dct:RightsStatement>
+              <rdfs:label xml:lang="{$MetadataLanguage}"><xsl:value-of select="normalize-space(gco:CharacterString)"/></rdfs:label>
+            </dct:RightsStatement>
+          </dct:rights>
+        </xsl:when>
+<!-- In case the rights/licence URL IS provided -->
+        <xsl:when test="gmx:Anchor/@xlink:href">
+          <dct:license rdf:resource="{gmx:Anchor/@xlink:href}"/>
+          <dct:license>
+            <dct:LicenseDocument rdf:about="{gmx:Anchor/@xlink:href}">
+          </dct:license>
+        </xsl:when>
+      </xsl:choose>
+    </xsl:for-each>
+    <xsl:for-each select="gmd:otherConstraints">
+        <dct:accessRights>
+        </dct:accessRights>
+      </xsl:if>
+    </xsl:for-each>
+    <xsl:for-each select="gmd:accessConstraints">
+      <dct:accessRights rdf:resource="{$MD_RestrictionCode}_{gmd:MD_RestrictionCode/@codeListValue}"/>
+    </xsl:for-each>
+    <xsl:for-each select="gmd:classification">
+      <dct:accessRights rdf:resource="{$MD_ClassificationCode}_{gmd:MD_ClassificationCode/@codeListValue}"/>
+    </xsl:for-each>
+  </xsl:template>
+<!-- Keyword -->
+  <xsl:template name="Keyword" match="gmd:identificationInfo/*/gmd:descriptiveKeywords/gmd:MD_Keywords">
+    <xsl:param name="ServiceType"/>
+    <xsl:param name="OriginatingControlledVocabulary">
+      <xsl:for-each select="gmd:thesaurusName/gmd:CI_Citation">
+        </dct:title>
+      </xsl:for-each>
+    </xsl:param>
+    <xsl:for-each select="gmd:keyword">
+      <xsl:variable name="lckw" select="translate(gco:CharacterString,'ABCDEFGHIJKLMNOPQRSTUVWXYZ','abcdefghijklmnopqrstuvwxyz')"/>
+      <xsl:choose>
+        <xsl:when test="$OriginatingControlledVocabulary = ''">
+          <xsl:choose>
+                <dc:subject xml:lang="{$MetadataLanguage}"><xsl:value-of select="gco:CharacterString"/></dc:subject>
+              </xsl:if>
+            </xsl:when>
+            <xsl:otherwise>
+              <dcat:keyword xml:lang="{$MetadataLanguage}"><xsl:value-of select="gco:CharacterString"/></dcat:keyword>
+            </xsl:otherwise>
+          </xsl:choose>
+        </xsl:when>
+        <xsl:otherwise>
+          <xsl:choose>
+<!-- In case the concept's URI is NOT provided -->
+              <xsl:choose>
+                <xsl:when test="$ResourceType != 'service'">
+                  <dcat:theme rdf:parseType="Resource">
+                      <xsl:value-of select="gco:CharacterString"/>
+                    </skos:prefLabel>
+                    <skos:inScheme>
+                        <xsl:copy-of select="$OriginatingControlledVocabulary"/>
+                    </skos:inScheme>
+                  </dcat:theme>
+                </xsl:when>
+                <xsl:otherwise>
+                    <dct:subject rdf:parseType="Resource">
+                      </skos:prefLabel>
+                      <skos:inScheme>
+                      </skos:inScheme>
+                    </dct:subject>
+                  </xsl:if>
+                </xsl:otherwise>
+              </xsl:choose>
+            </xsl:when>
+<!-- In case the concept's URI is provided -->
+              <xsl:choose>
+                  <dcat:theme rdf:resource="{gmx:Anchor/@xlink:href}"/>
+                  <skos:Concept rdf:about="{gmx:Anchor/@xlink:href}">
+                      <xsl:value-of select="gmx:Anchor"/>
+                    </skos:prefLabel>
+                    <skos:inScheme>
+                    </skos:inScheme>
+                  </skos:Concept>
+                </xsl:when>
+                <xsl:otherwise>
+                    <dct:subject rdf:resource="{gmx:Anchor/@xlink:href}"/>
+                  </xsl:if>
+                </xsl:otherwise>
+              </xsl:choose>
+            </xsl:when>
+          </xsl:choose>
+        </xsl:otherwise>
+      </xsl:choose>
+    </xsl:for-each>
+  </xsl:template>
+  <xsl:template name="TopicCategory" match="gmd:identificationInfo/*/gmd:topicCategory">
+    <xsl:param name="TopicCategory"><xsl:value-of select="gmd:MD_TopicCategoryCode"/></xsl:param>
+    <dct:subject rdf:resource="{$TopicCategoryCodelistUri}/{$TopicCategory}"/>
+  </xsl:template>
+<!-- Spatial resolution (unstable - to be replaced with a standard-based solution, when available) -->
+  <xsl:template name="SpatialResolution" match="gmd:identificationInfo/*/gmd:spatialResolution/gmd:MD_Resolution">
+<!-- dcat:granularity is deprecated -->
+    <xsl:for-each select="gmd:distance/gco:Distance">
+      <dcat:granularity rdf:datatype="{$xsd}string"><xsl:value-of select="."/> <xsl:value-of select="@uom"/></dcat:granularity>
+    </xsl:for-each>
+    <xsl:for-each select="gmd:equivalentScale/gmd:MD_RepresentativeFraction/gmd:denominator">
+      <dcat:granularity rdf:datatype="{$xsd}string">1/<xsl:value-of select="gco:Integer"/></dcat:granularity>
+    </xsl:for-each>
+      <xsl:variable name="UoM">
+        <xsl:choose>
+          <xsl:when test="@uom = 'EPSG::9001' or @uom = 'urn:ogc:def:uom:EPSG::9001' or @uom = 'urn:ogc:def:uom:UCUM::m' or @uom = 'urn:ogc:def:uom:OGC::m'">
+            <xsl:value-of select="concat('m',' (', at uom,')')"/>
+          </xsl:when>
+          <xsl:when test="@uom = 'EPSG::9002' or @uom = 'urn:ogc:def:uom:EPSG::9002' or @uom = 'urn:ogc:def:uom:UCUM::[ft_i]' or @uom = 'urn:ogc:def:uom:OGC::[ft_i]'">
+            <xsl:value-of select="concat('ft',' (', at uom,')')"/>
+          </xsl:when>
+<!-- To be completed -->
+          <xsl:otherwise>
+            <xsl:value-of select="@uom"/>
+          </xsl:otherwise>
+        </xsl:choose>
+      </xsl:variable>
+      <rdfs:comment xml:lang="en">Spatial resolution (distance): <xsl:value-of select="."/> <xsl:value-of select="$UoM"/></rdfs:comment>
+    </xsl:for-each>
+      <rdfs:comment xml:lang="en">Spatial resolution (equivalent scale): 1:<xsl:value-of select="gco:Integer"/></rdfs:comment>
+    </xsl:for-each>
+  </xsl:template>
+<!-- Character encoding -->
+  <xsl:template name="CharacterEncoding" match="gmd:characterSet/gmd:MD_CharacterSetCode">
+    <xsl:variable name="CharSetCode">
+      <xsl:choose>
+        <xsl:when test="@codeListValue = 'ucs2'">
+          <xsl:text>ISO-10646-UCS-2</xsl:text>
+        </xsl:when>
+        <xsl:when test="@codeListValue = 'ucs4'">
+          <xsl:text>ISO-10646-UCS-4</xsl:text>
+        </xsl:when>
+        <xsl:when test="@codeListValue = 'utf7'">
+          <xsl:text>UTF-7</xsl:text>
+        </xsl:when>
+        <xsl:when test="@codeListValue = 'utf8'">
+          <xsl:text>UTF-8</xsl:text>
+        </xsl:when>
+        <xsl:when test="@codeListValue = 'utf16'">
+          <xsl:text>UTF-16</xsl:text>
+        </xsl:when>
+        <xsl:when test="@codeListValue = '8859part1'">
+          <xsl:text>ISO-8859-1</xsl:text>
+        </xsl:when>
+        <xsl:when test="@codeListValue = '8859part2'">
+          <xsl:text>ISO-8859-2</xsl:text>
+        </xsl:when>
+        <xsl:when test="@codeListValue = '8859part3'">
+          <xsl:text>ISO-8859-3</xsl:text>
+        </xsl:when>
+        <xsl:when test="@codeListValue = '8859part4'">
+          <xsl:text>ISO-8859-4</xsl:text>
+        </xsl:when>
+        <xsl:when test="@codeListValue = '8859part5'">
+          <xsl:text>ISO-8859-5</xsl:text>
+        </xsl:when>
+        <xsl:when test="@codeListValue = '8859part6'">
+          <xsl:text>ISO-8859-6</xsl:text>
+        </xsl:when>
+        <xsl:when test="@codeListValue = '8859part7'">
+          <xsl:text>ISO-8859-7</xsl:text>
+        </xsl:when>
+        <xsl:when test="@codeListValue = '8859part8'">
+          <xsl:text>ISO-8859-8</xsl:text>
+        </xsl:when>
+        <xsl:when test="@codeListValue = '8859part9'">
+          <xsl:text>ISO-8859-9</xsl:text>
+        </xsl:when>
+        <xsl:when test="@codeListValue = '8859part10'">
+          <xsl:text>ISO-8859-10</xsl:text>
+        </xsl:when>
+        <xsl:when test="@codeListValue = '8859part11'">
+          <xsl:text>ISO-8859-11</xsl:text>
+        </xsl:when>
+        <xsl:when test="@codeListValue = '8859part12'">
+          <xsl:text>ISO-8859-12</xsl:text>
+        </xsl:when>
+        <xsl:when test="@codeListValue = '8859part13'">
+          <xsl:text>ISO-8859-13</xsl:text>
+        </xsl:when>
+        <xsl:when test="@codeListValue = '8859part14'">
+          <xsl:text>ISO-8859-14</xsl:text>
+        </xsl:when>
+        <xsl:when test="@codeListValue = '8859part15'">
+          <xsl:text>ISO-8859-15</xsl:text>
+        </xsl:when>
+        <xsl:when test="@codeListValue = '8859part16'">
+          <xsl:text>ISO-8859-16</xsl:text>
+        </xsl:when>
+<!-- Mapping to be verified: multiple candidates are available in the IANA register for jis -->
+        <xsl:when test="@codeListValue = 'jis'">
+          <xsl:text>JIS_Encoding</xsl:text>
+        </xsl:when>
+        <xsl:when test="@codeListValue = 'shiftJIS'">
+          <xsl:text>Shift_JIS</xsl:text>
+        </xsl:when>
+        <xsl:when test="@codeListValue = 'eucJP'">
+          <xsl:text>EUC-JP</xsl:text>
+        </xsl:when>
+        <xsl:when test="@codeListValue = 'usAscii'">
+          <xsl:text>US-ASCII</xsl:text>
+        </xsl:when>
+<!-- Mapping to be verified: multiple candidates are available in the IANA register ebcdic  -->
+        <xsl:when test="@codeListValue = 'ebcdic'">
+          <xsl:text>IBM037</xsl:text>
+        </xsl:when>
+        <xsl:when test="@codeListValue = 'eucKR'">
+          <xsl:text>EUC-KR</xsl:text>
+        </xsl:when>
+        <xsl:when test="@codeListValue = 'big5'">
+          <xsl:text>Big5</xsl:text>
+        </xsl:when>
+        <xsl:when test="@codeListValue = 'GB2312'">
+          <xsl:text>GB2312</xsl:text>
+        </xsl:when>
+      </xsl:choose>
+    </xsl:variable>
+    <cnt:characterEncoding rdf:datatype="{$xsd}string"><xsl:value-of select="$CharSetCode"/></cnt:characterEncoding>
+    <cnt:characterEncoding rdf:datatype="{$xsd}string"><xsl:value-of select="@codeListValue"/></cnt:characterEncoding>
+  </xsl:template>
+<!-- Encoding -->
+  <xsl:template name="Encoding" match="gmd:distributionFormat/gmd:MD_Format/gmd:name/*">
+    <xsl:choose>
+      <xsl:when test="@xlink:href and @xlink:href != ''">
+        <dct:format rdf:resource="{@xlink:href}"/>
+        <dct:format>
+          <rdf:Description rdf:about="{@xlink:href}">
+            <rdfs:label><xsl:value-of select="."/></rdfs:label>
+        </dct:format>
+      </xsl:when>
+      <xsl:otherwise>
+        <dct:format rdf:parseType="Resource">
+        </dct:format>
+      </xsl:otherwise>
+    </xsl:choose>
+  </xsl:template>
+<!-- Maintenance information -->
+  <xsl:template name="MaintenanceInformation" match="gmd:MD_MaintenanceInformation/gmd:maintenanceAndUpdateFrequency/gmd:MD_MaintenanceFrequencyCode">
+<!-- The following parameter maps frequency codes used in ISO 19139 metadata to the corresponding ones of the Dublin Core Collection Description Frequency Vocabulary (when available). -->
+    <xsl:param name="FrequencyCodeURI">
+      <xsl:if test="@codeListValue != ''">
+        <xsl:choose>
+          <xsl:when test="@codeListValue = 'continual'">
+<!--  DC Freq voc
+             <xsl:value-of select="concat($cldFrequency,'continuous')"/>
+            <xsl:value-of select="concat($opfq,'CONT')"/>
+          </xsl:when>
+          <xsl:when test="@codeListValue = 'daily'">
+<!--  DC Freq voc
+            <xsl:value-of select="concat($cldFrequency,'daily')"/>
+            <xsl:value-of select="concat($opfq,'DAILY')"/>
+          </xsl:when>
+          <xsl:when test="@codeListValue = 'weekly'">
+<!--  DC Freq voc
+            <xsl:value-of select="concat($cldFrequency,'weekly')"/>
+            <xsl:value-of select="concat($opfq,'WEEKLY')"/>
+          </xsl:when>
+          <xsl:when test="@codeListValue = 'fortnightly'">
+<!--  DC Freq voc
+            <xsl:value-of select="concat($cldFrequency,'biweekly')"/>
+            <xsl:value-of select="concat($opfq,'BIWEEKLY')"/>
+          </xsl:when>
+          <xsl:when test="@codeListValue = 'monthly'">
+<!--  DC Freq voc
+            <xsl:value-of select="concat($cldFrequency,'monthly')"/>
+            <xsl:value-of select="concat($opfq,'MONTHLY')"/>
+          </xsl:when>
+          <xsl:when test="@codeListValue = 'quarterly'">
+<!--  DC Freq voc
+            <xsl:value-of select="concat($cldFrequency,'quarterly')"/>
+            <xsl:value-of select="concat($opfq,'QUARTERLY')"/>
+          </xsl:when>
+          <xsl:when test="@codeListValue = 'biannually'">
+<!--  DC Freq voc
+            <xsl:value-of select="concat($cldFrequency,'semiannual')"/>
+            <xsl:value-of select="concat($opfq,'ANNUAL_2')"/>
+          </xsl:when>
+          <xsl:when test="@codeListValue = 'annually'">
+<!--  DC Freq voc
+            <xsl:value-of select="concat($cldFrequency,'annual')"/>
+            <xsl:value-of select="concat($opfq,'ANNUAL')"/>
+          </xsl:when>
+          <xsl:when test="@codeListValue = 'asNeeded'">
+<!--  A mapping is missing in Dublin Core -->
+<!--  A mapping is missing in MDR Freq NAL -->
+            <xsl:value-of select="concat($MaintenanceFrequencyCodelistUri,'/', at codeListValue)"/>
+          </xsl:when>
+          <xsl:when test="@codeListValue = 'irregular'">
+<!--  DC Freq voc
+            <xsl:value-of select="concat($cldFrequency,'irregular')"/>
+            <xsl:value-of select="concat($opfq,'IRREG')"/>
+          </xsl:when>
+          <xsl:when test="@codeListValue = 'notPlanned'">
+          </xsl:when>
+          <xsl:when test="@codeListValue = 'unknown'">
+<!--  INSPIRE Freq code list (not yet available)
+            <xsl:value-of select="concat($opfq,'UNKNOWN')"/>
+          </xsl:when>
+        </xsl:choose>
+      </xsl:if>
+    </xsl:param>
+    <xsl:if test="$FrequencyCodeURI != ''">
+      <dct:accrualPeriodicity rdf:resource="{$FrequencyCodeURI}"/>
+    </xsl:if>
+  </xsl:template>
+<!-- Coordinate and temporal reference system (tentative) -->
+  <xsl:template name="ReferenceSystem" match="gmd:referenceSystemInfo/gmd:MD_ReferenceSystem/gmd:referenceSystemIdentifier/gmd:RS_Identifier">
+    <xsl:param name="code" select="gmd:code/gco:CharacterString"/>
+    <xsl:param name="codespace" select="gmd:codeSpace/gco:CharacterString"/>
+    <xsl:param name="version" select="gmd:version/gco:CharacterString"/>
+    <xsl:choose>
+      <xsl:when test="starts-with($code, 'http://') or starts-with($code, 'https://')">
+        <dct:conformsTo rdf:resource="{$code}"/>
+      </xsl:when>
+      <xsl:when test="starts-with($code, 'urn:')">
+          <dct:identifier rdf:datatype="{$xsd}anyURI"><xsl:value-of select="$code"/></dct:identifier>
+          <xsl:if test="$codespace != ''">
+            <skos:inScheme>
+                <dct:title xml:lang="{$MetadataLanguage}"><xsl:value-of select="$codespace"/></dct:title>
+            </skos:inScheme>
+          </xsl:if>
+          <xsl:if test="$version != ''">
+            <owl:versionInfo xml:lang="{$MetadataLanguage}"><xsl:value-of select="$version"/></owl:versionInfo>
+          </xsl:if>
+        </dct:conformsTo>
+      </xsl:when>
+      <xsl:otherwise>
+          <skos:prefLabel xml:lang="{$MetadataLanguage}"><xsl:value-of select="$code"/></skos:prefLabel>
+            <skos:inScheme>
+            </skos:inScheme>
+          </xsl:if>
+          </xsl:if>
+        </dct:conformsTo>
+      </xsl:otherwise>
+    </xsl:choose>
+  </xsl:template>
+  <xsl:template name="SpatialRepresentationType" match="gmd:identificationInfo/*/gmd:spatialRepresentationType/gmd:MD_SpatialRepresentationTypeCode">
+    <adms:representationTechnique rdf:resource="{$SpatialRepresentationTypeCodelistUri}/{@codeListValue}"/>
+  </xsl:template>
+</xsl:transform>
More information about the Mapbender_commits mailing list
