[Mapbender-commits] r9544 - in trunk/mapbender/http: classes php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Jul 14 08:01:52 PDT 2016
Author: armin11
Date: 2016-07-14 08:01:52 -0700 (Thu, 14 Jul 2016)
New Revision: 9544
   trunk/mapbender/http/classes/class_administration.php
   trunk/mapbender/http/classes/class_cswClient.php
   trunk/mapbender/http/php/mod_deleteWMS.php
New possibility to sync mapbender registry with external csw via csw-t - done for wms layer resources
Modified: trunk/mapbender/http/classes/class_administration.php
--- trunk/mapbender/http/classes/class_administration.php	2016-07-14 15:01:01 UTC (rev 9543)
+++ trunk/mapbender/http/classes/class_administration.php	2016-07-14 15:01:52 UTC (rev 9544)
@@ -1803,25 +1803,29 @@
 			return false;
 		$array_guis = $this->getGuisByPermission($user_id,true);
-		$v = array();
-		$t = array();
-		$sql = "SELECT * FROM gui_layer WHERE fkey_gui_id IN (";
-		$c = 1;
-		for($i=0; $i<count($array_guis); $i++){
-			if($i>0){ $sql .= ",";}
-			$sql .= "$".$c;
-			$c++;
-			array_push($v, $array_guis[$i]);
-			array_push($t, 's');
-		$sql .= ") AND fkey_layer_id = $".$c." AND gui_layer_status = 1";
-		array_push($v,$layer_id);
-		array_push($t,'i');
-		$res = db_prep_query($sql,$v,$t);
-		if($row = db_fetch_array($res)){
-			return true;
-		else{
+		if (count($array_guis) > 0) {
+			$v = array();
+			$t = array();
+			$sql = "SELECT * FROM gui_layer WHERE fkey_gui_id IN (";
+			$c = 1;
+			for($i=0; $i<count($array_guis); $i++){
+				if($i>0){ $sql .= ",";}
+				$sql .= "$".$c;
+				$c++;
+				array_push($v, $array_guis[$i]);
+				array_push($t, 's');
+			$sql .= ") AND fkey_layer_id = $".$c." AND gui_layer_status = 1";
+			array_push($v,$layer_id);
+			array_push($t,'i');
+			$res = db_prep_query($sql,$v,$t);
+			if($row = db_fetch_array($res)){
+				return true;
+			else{
+				return false;
+		} else {
 			return false;
Modified: trunk/mapbender/http/classes/class_cswClient.php
--- trunk/mapbender/http/classes/class_cswClient.php	2016-07-14 15:01:01 UTC (rev 9543)
+++ trunk/mapbender/http/classes/class_cswClient.php	2016-07-14 15:01:52 UTC (rev 9544)
@@ -181,7 +181,7 @@
 						if (is_array($metadataRecord) && count($metadataRecord) <> 1 || !is_array($metadataRecord)) {
 							//$err = new mb_exception(count($metadataRecord));
 							//$err = new mb_exception($metadataRecord[0]->asXml());
-							$err = new mb_exception("class_cswClient.php: More or less than one metadata returned for a getrecordby id response!");
+							//$err = new mb_exception("class_cswClient.php: More or less than one metadata returned for a getrecordby id response!");
 							$this->operationResult = "More or less than one metadata returned for a getrecordby id response!";
 							return false;
 						} else {
@@ -202,10 +202,10 @@
 	public function pushRecord($isoMetadataObject, $auth=false) {
 		//check if metadata already in catalogue
 		if ($this->doRequest($this->cswId, 'getrecordbyid', $isoMetadataObject->fileIdentifier)) {
-			$err = new mb_exception("class_cswClient.php: do a transaction update");
+			//$err = new mb_exception("class_cswClient.php: do a transaction update");
 			$response = $this->doRequest($this->cswId, 'transactionupdate', false, $isoMetadataObject);
 		} else {
-			$err = new mb_exception("class_cswClient.php: do a transaction insert");
+			//$err = new mb_exception("class_cswClient.php: do a transaction insert");
 			$response = $this->doRequest($this->cswId, 'transactioninsert', false, $isoMetadataObject);
 		return $response;
@@ -230,7 +230,14 @@
 	public function deleteRecord($fileIdentifier, $auth=false) {
-		$response = $this->doRequest($this->cswId, 'transactiondelete', $fileIdentifier, false);
+		//check if exists before!
+		if ($this->doRequest($this->cswId, 'getrecordbyid', $fileIdentifier, false)) {
+			//$err = new mb_exception("class_cswClient.php: do a transaction delete");
+			$response = $this->doRequest($this->cswId, 'transactiondelete', $fileIdentifier, false);
+		} else {
+			//$err = new mb_exception("class_cswClient.php: Don't delete object - cause it doen't exists!");
+			$response = "<cswClient>Don't delete record ".$fileIdentifier." - cause it doen't exists!</cswClient>";
 		return $response;
Modified: trunk/mapbender/http/php/mod_deleteWMS.php
--- trunk/mapbender/http/php/mod_deleteWMS.php	2016-07-14 15:01:01 UTC (rev 9543)
+++ trunk/mapbender/http/php/mod_deleteWMS.php	2016-07-14 15:01:52 UTC (rev 9544)
@@ -20,7 +20,8 @@
 $e_id="deleteWMS";
 require_once(dirname(__FILE__)."/../php/mb_validatePermission.php");
+require_once dirname(__FILE__) . "/../classes/class_iso19139.php";
+require_once(dirname(__FILE__) . "/../classes/class_cswClient.php");
  * @security_patch irv done
@@ -223,6 +224,19 @@
 	$v = array($wmsList);
 	$t = array('i');
+	//before delete the wms get the published layers to delete their metadata afterwards
+	//select all layer which are searchable
+	$sql = "SELECT layer_id, uuid FROM layer WHERE fkey_wms_id = $1 and layer_searchable = 1";
+	$v = array($wmsList);
+	$t = array('i');
+	$layerArray = array();
+	while($row = db_fetch_array($res)){
+		$layerArray[] = array(
+				"id" => $row['layer_id'],
+				"uuid" => $row['uuid']
 	   $sql = "DELETE FROM wms WHERE wms_id = $1";
@@ -243,7 +257,26 @@
 			$timestamp = date(DATE_RSS,time());
 			$geoRssItem->setPubDate($timestamp);
 			$geoRss->appendTop($geoRssItem);
-			$geoRss->saveAsFile();
+			$geoRss->saveAsFile();
+			//delete metadata of connected catalogue
+			//Propagate information for each new layer to csw if configured
+			if (defined("SYNC_CHANGES_TO_CSW") && SYNC_CHANGES_TO_CSW == true && defined("SYNC_CATALOGUE_ID") && is_int(SYNC_CATALOGUE_ID)) {
+				/*if (defined("MAPBENDER_PATH") && MAPBENDER_PATH !== "") {
+					//layer service metadata generator
+					$servMdPath = MAPBENDER_PATH."/php/mod_layerISOMetadata.php?SERVICE=WMS&outputFormat=iso19139&Id=";
+				} else {
+					$servMdPath = "http://".$_SERVER['HTTP_HOST']."/mapbender"."/php/mod_layerISOMetadata.php?SERVICE=WMS&outputFormat=iso19139&Id=";
+				$cswClient = new cswClient();
+				$cswClient->cswId = SYNC_CATALOGUE_ID;
+				//$isoMetadata = new Iso19139();
+				foreach ($layerArray as $layer) {
+						$result = $cswClient->deleteRecord($layer['uuid']);
+						$e = new mb_notice($result);
+						//$metadata = $isoMetadata->createFromUrl($servMdPath.$layer['id']);
+						//$result = $cswClient->pushRecord($metadata);
 	// display WMS List
More information about the Mapbender_commits mailing list
